RTEMS  5.1
ti-ads-16bit-adc.h
1 /*
2  * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org>
3  * All rights reserved.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /*
11  * TI ADS1113 and ADS1115.
12  * http://www.ti.com/product/ads1113/description
13  */
14
15 #ifndef TI_ADS1113_ADS1115_H
16 #define TI_ADS1113_ADS1115_H
17
18 #include <dev/i2c/i2c.h>
19
20 /*
21  * Supported devices. Please others once tested.
22  */
23 typedef enum {
24  TI_ADS1113,
25  TI_ADS1114,
26  TI_ADS1115
27 } ti_ads_adc;
28
29 /*
30  * Multiplexer interface. Avalable on ADS1115.
31  */
32 typedef enum {
33  TI_ADS_MUX_ApA0_AnA1 = 0, /* default */
34  TI_ADS_MUX_ApA0_AnA3 = 1,
35  TI_ADS_MUX_ApA1_AnA3 = 2,
36  TI_ADS_MUX_ApA2_AnA3 = 3,
37  TI_ADS_MUX_ApA0_AnGND = 4,
38  TI_ADS_MUX_ApA1_AnGND = 5,
39  TI_ADS_MUX_ApA2_AnGND = 6,
40  TI_ADS_MUX_ApA3_AnGND = 7
41 } ti_ads_adc_mux;
42
43 /*
44  * Programmable Gain Amplifier. Avalable on ADS1114 and ADS1115.
45  */
46 typedef enum {
47  TI_ADS_PGA_FS_6_144V = 0,
48  TI_ADS_PGA_FS_4_096V = 1,
49  TI_ADS_PGA_FS_2_048V = 2, /* default */
50  TI_ADS_PGA_FS_1_024V = 3,
51  TI_ADS_PGA_FS_0_512V = 4,
52  TI_ADS_PGA_FS_0_256V = 5,
53  TI_ADS_PGA_FS_0_256V_2 = 6,
54  TI_ADS_PGA_FS_0_256V_3 = 7,
55 } ti_ads_adc_pga;
56
57 /*
58  * Mode.
59  */
60 typedef enum {
61  TI_ADS_MODE_CONTINUOUS = 0,
62  TI_ADS_MODE_SINGLE_SHOT = 1, /* default */
63 } ti_ads_adc_mode;
64
65 /*
66  * Data rate.
67  */
68 typedef enum {
69  TI_ADS_DATARATE_8SPS = 0,
70  TI_ADS_DATARATE_16SPS = 1,
71  TI_ADS_DATARATE_32SPS = 2,
72  TI_ADS_DATARATE_64SPS = 3,
73  TI_ADS_DATARATE_128SPS = 4, /* default */
74  TI_ADS_DATARATE_250SPS = 5,
75  TI_ADS_DATARATE_475SPS = 6,
76  TI_ADS_DATARATE_860SPS = 7,
77 } ti_ads_adc_data_rate;
78
79 /*
80  * Comparitor interface. Avalable on ADS1114 and ADS1115.
81  *
82  * Create a value to write.
83  */
84 #define TI_ADS_COMP_MODE_HYSTERESIS (0 << 4) /* default */
85 #define TI_ADS_COMP_MODE_WINDOW (1 << 4)
86 #define TI_ADS_COMP_POL_ACTIVE_LOW (0 << 3) /* default */
87 #define TI_ADS_COMP_POL_ACTIVE_HIGH (1 << 3)
88 #define TI_ADS_COMP_LAT_NON_LATCHING (0 << 2) /* default */
89 #define TI_ADS_COMP_LAT_LATCHING (1 << 2)
90 #define TI_ADS_COMP_QUE_DISABLE_COMP (3 << 0) /* default */
91 #define TI_ADS_COMP_QUE_AFTER_4 (2 << 0)
92 #define TI_ADS_COMP_QUE_AFTER_2 (1 << 0)
93 #define TI_ADS_COMP_QUE_AFTER_1 (0 << 0)
94
95 /*
96  * IO control interface.
97  *
98  * Note: if in Power-down single-shot mode (default) a conversion requires the
99  * device to power up and perform a conversion and this can take
100  * while. The TI_ADS_ADC_GET_CONV_WAIT call sets the micro-seconds to
101  * wait between polls. The actual rate will depend on the system tick.
102  */
103 #define TI_ADS_ADC_GET_CONVERSION (I2C_DEV_IO_CONTROL + 0)
104 #define TI_ADS_ADC_SET_MUX (I2C_DEV_IO_CONTROL + 1)
105 #define TI_ADS_ADC_SET_PGA (I2C_DEV_IO_CONTROL + 2)
106 #define TI_ADS_ADC_SET_MODE (I2C_DEV_IO_CONTROL + 3)
107 #define TI_ADS_ADC_SET_DATA_RATE (I2C_DEV_IO_CONTROL + 4)
108 #define TI_ADS_ADC_SET_COMP (I2C_DEV_IO_CONTROL + 5)
109 #define TI_ADS_ADC_SET_LO_THRESH (I2C_DEV_IO_CONTROL + 6)
110 #define TI_ADS_ADC_SET_HI_THRESH (I2C_DEV_IO_CONTROL + 7)
111 #define TI_ADS_ADC_SET_CONV_WAIT (I2C_DEV_IO_CONTROL + 8)
112
113 /*
114  * Register the device.
115  */
116 int i2c_dev_register_ti_ads_adc(const char* bus_path,
117  const char* dev_path,
118  uint16_t address,
119  ti_ads_adc device);
120
121 /*
122  * Perform a conversion. If the mode is single shot a single shot conversion is
123  * started and the call waits for the conversion to complete.
124  */
125 static inline int
126 ti_ads_adc_convert(int fd, uint16_t* sample)
127 {
128  return ioctl(fd, TI_ADS_ADC_GET_CONVERSION, sample);
129 }
130
131 /*
132  * Set the multipler.
133  */
134 static inline int
135 ti_ads_adc_set_mux(int fd, ti_ads_adc_mux mux)
136 {
137  return ioctl(fd, TI_ADS_ADC_SET_MUX, (void *)(uintptr_t) mux);
138 }
139
140 /*
141  * Set the PGA.
142  */
143 static inline int
144 ti_ads_adc_set_pga(int fd, ti_ads_adc_pga pga)
145 {
146  return ioctl(fd, TI_ADS_ADC_SET_PGA, (void *)(uintptr_t) pga);
147 }
148
149 /*
150  * Set the mode.
151  */
152 static inline int
153 ti_ads_adc_set_mode(int fd, ti_ads_adc_mode mode)
154 {
155  return ioctl(fd, TI_ADS_ADC_SET_MODE, (void *)(uintptr_t) mode);
156 }
157
158 /*
159  * Set the data rate.
160  */
161 static inline int
162 ti_ads_adc_set_data_rate(int fd, ti_ads_adc_data_rate rate)
163 {
164  return ioctl(fd, TI_ADS_ADC_SET_DATA_RATE, (void *)(uintptr_t) rate);
165 }
166
167 /*
168  * Configure the comparator.
169  */
170 static inline int
171 ti_ads_adc_set_comparator(int fd, uint16_t comp)
172 {
173  return ioctl(fd, TI_ADS_ADC_SET_COMP, (void *)(uintptr_t) comp);
174 }
175
176 /*
177  * Set the lower threshold.
178  */
179 static inline int
180 ti_ads_adc_set_low_threshold(int fd, uint16_t level)
181 {
182  return ioctl(fd, TI_ADS_ADC_SET_LO_THRESH, (void *)(uintptr_t) level);
183 }
184
185 /*
186  * Set the upper threshold.
187  */
188 static inline int
189 ti_ads_adc_set_high_threshold(int fd, uint16_t level)
190 {
191  return ioctl(fd, TI_ADS_ADC_SET_HI_THRESH, (void *)(uintptr_t) level);
192 }
193
194 /*
195  * Set the conversion poll wait period.
196  */
197 static inline int
198 ti_ads_adc_set_conversion_poll_wait(int fd, uint32_t micro_seconds)
199 {
200  return ioctl(fd, TI_ADS_ADC_SET_CONV_WAIT, (void *)(uintptr_t) micro_seconds);
201 }
202
203 #endif
Definition: rtemscompat1.h:15
Inter-Integrated Circuit (I2C) Driver API.
