RTEMS  5.1
threads.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_THREADS_H
37 #define _RTEMS_CONFDEFS_THREADS_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #include <rtems/confdefs/bdbuf.h>
47 #include <rtems/confdefs/percpu.h>
50 #include <rtems/score/thread.h>
51 #include <rtems/posix/threadsup.h>
52 #include <rtems/rtems/tasksdata.h>
53
54 #ifndef CONFIGURE_MAXIMUM_TASKS
55  #define CONFIGURE_MAXIMUM_TASKS 0
56 #endif
57
58 #define _CONFIGURE_TASKS ( CONFIGURE_MAXIMUM_TASKS + _CONFIGURE_LIBBLOCK_TASKS )
59
60 #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
61  #define CONFIGURE_MAXIMUM_POSIX_THREADS 0
62 #endif
63
64 #if CONFIGURE_MAXIMUM_POSIX_THREADS > 0
65  #include <rtems/posix/pthread.h>
66 #endif
67
68 #if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) \
69  && CONFIGURE_MAXIMUM_TASKS == 0 \
70  && CONFIGURE_MAXIMUM_POSIX_THREADS == 0
71  #error "You must define one of CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION, CONFIGURE_MAXIMUM_TASKS, and CONFIGURE_MAXIMUM_POSIX_THREADS"
72 #endif
73
74 #if !defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) \
75  && !defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) \
76  && !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION)
77  #error "You must define one of CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION, CONFIGURE_RTEMS_INIT_TASKS_TABLE, and CONFIGURE_POSIX_INIT_THREAD_TABLE"
78 #endif
79
80 #ifndef CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
81  #define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE THREAD_DEFAULT_MAXIMUM_NAME_SIZE
82 #endif
83
84 #ifdef __cplusplus
85 extern "C" {
86 #endif
87
88 typedef union {
89  Scheduler_Node Base;
90  #ifdef CONFIGURE_SCHEDULER_CBS
92  #endif
93  #ifdef CONFIGURE_SCHEDULER_EDF
95  #endif
96  #ifdef CONFIGURE_SCHEDULER_EDF_SMP
97  Scheduler_EDF_SMP_Node EDF_SMP;
98  #endif
99  #ifdef CONFIGURE_SCHEDULER_PRIORITY
100  Scheduler_priority_Node Priority;
101  #endif
102  #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
103  Scheduler_SMP_Node Simple_SMP;
104  #endif
105  #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
106  Scheduler_priority_SMP_Node Priority_SMP;
107  #endif
108  #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
109  Scheduler_priority_affinity_SMP_Node Priority_affinity_SMP;
110  #endif
111  #ifdef CONFIGURE_SCHEDULER_STRONG_APA
112  Scheduler_strong_APA_Node Strong_APA;
113  #endif
114  #ifdef CONFIGURE_SCHEDULER_USER_PER_THREAD
115  CONFIGURE_SCHEDULER_USER_PER_THREAD User;
116  #endif
117 } Configuration_Scheduler_node;
118
119 #ifdef RTEMS_SMP
120  const size_t _Scheduler_Node_size = sizeof( Configuration_Scheduler_node );
121 #endif
122
123 const size_t _Thread_Maximum_name_size = CONFIGURE_MAXIMUM_THREAD_NAME_SIZE;
124
126  Thread_Control Control;
127  #if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0
128  void *extensions[ CONFIGURE_MAXIMUM_USER_EXTENSIONS + 1 ];
129  #endif
130  Configuration_Scheduler_node Scheduler_nodes[ _CONFIGURE_SCHEDULER_COUNT ];
131  RTEMS_API_Control API_RTEMS;
132  #ifdef RTEMS_POSIX_API
133  POSIX_API_Control API_POSIX;
134  #endif
135  #if CONFIGURE_MAXIMUM_THREAD_NAME_SIZE > 1
136  char name[ CONFIGURE_MAXIMUM_THREAD_NAME_SIZE ];
137  #endif
138  #ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
139  struct _reent Newlib;
140  #else
141  struct { /* Empty */ } Newlib;
142  #endif
143 };
144
146  {
147  offsetof( Thread_Configured_control, Control.Scheduler.nodes ),
148  offsetof( Thread_Configured_control, Scheduler_nodes )
149  }, {
150  offsetof(
152  Control.API_Extensions[ THREAD_API_RTEMS ]
153  ),
154  offsetof( Thread_Configured_control, API_RTEMS )
155  }, {
156  offsetof(
158  Control.libc_reent
159  ),
160  offsetof( Thread_Configured_control, Newlib )
161  }
162  #if CONFIGURE_MAXIMUM_THREAD_NAME_SIZE > 1
163  , {
164  offsetof(
166  Control.Join_queue.Queue.name
167  ),
168  offsetof( Thread_Configured_control, name )
169  }
170  #endif
171  #ifdef RTEMS_POSIX_API
172  , {
173  offsetof(
175  Control.API_Extensions[ THREAD_API_POSIX ]
176  ),
177  offsetof( Thread_Configured_control, API_POSIX )
178  }
179  #endif
180 };
181
182 const size_t _Thread_Control_add_on_count =
183  RTEMS_ARRAY_SIZE( _Thread_Control_add_ons );
184
185 #ifdef RTEMS_SMP
188  Thread_queue_Priority_queue Priority[ _CONFIGURE_SCHEDULER_COUNT ];
189  };
190
191  const size_t _Thread_queue_Heads_size =
193 #endif
194
195 const size_t _Thread_Initial_thread_count =
196  rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
197  rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS );
198
199 #if defined(RTEMS_MULTIPROCESSING) && defined(CONFIGURE_MP_APPLICATION)
200  #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
201 #else
202  #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
203 #endif
204
205 THREAD_INFORMATION_DEFINE(
206  _Thread,
207  OBJECTS_INTERNAL_API,
208  OBJECTS_INTERNAL_THREADS,
209  _CONFIGURE_MAXIMUM_PROCESSORS + _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT
210 );
211
212 #if _CONFIGURE_TASKS > 0
213  THREAD_INFORMATION_DEFINE(
214  _RTEMS_tasks,
215  OBJECTS_CLASSIC_API,
216  OBJECTS_RTEMS_TASKS,
217  _CONFIGURE_TASKS
218  );
219 #endif
220
221 #if CONFIGURE_MAXIMUM_POSIX_THREADS > 0
222  const size_t _POSIX_Threads_Minimum_stack_size =
223  CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE;
224
225  THREAD_INFORMATION_DEFINE(
226  _POSIX_Threads,
227  OBJECTS_POSIX_API,
228  OBJECTS_POSIX_THREADS,
229  CONFIGURE_MAXIMUM_POSIX_THREADS
230  );
231 #endif
232
233 #ifdef __cplusplus
234 }
235 #endif
236
237 #endif /* CONFIGURE_INIT */
238
239 #endif /* _RTEMS_CONFDEFS_THREADS_H */
Definition: tasksdata.h:41
union _Thread_queue_Heads::@3986 Heads
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:90
Thread priority queue.
Definition: threadq.h:324
Evaluate Per-CPU Configuration Options.
Definition: thread.h:593
Evaluate Unlimited Objects Configuration Options.
Evaluate Scheduler Configuration Options.
POSIX Threads Private Support.
POSIX Thread API Support.
This is the set of threads for priority discipline waiting.
Definition: threadq.h:378
#define _Thread_queue_Heads_size
Size of the thread queue heads of a particular application.
Definition: thread.h:991
Thread control add-on count.
const Thread_Control_add_on _Thread_Control_add_ons[]
Thread control add-ons.
Thread queue heads.
Definition: threadq.h:360
Definition: scheduleredfsmp.h:38
Definition: thread.h:732
Evaluate User Extensions Configuration Options.
Thread control add-on.
Definition: thread.h:900
Scheduler node specialization for SMP schedulers.
Definition: schedulersmp.h:100
Scheduler node specialization for Deterministic Priority schedulers.
Definition: schedulerpriority.h:101
Scheduler node specialization for Strong APA schedulers.
Definition: schedulerstrongapa.h:66
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Scheduler node specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:66
Definition: thread.h:591
Definition: schedulercbs.h:138
Thread_queue_Heads Thread_queue_Configured_heads
The configured thread queue heads.
Definition: thread.h:980
Evaluate Block Device Cache Configuration Options.
Constants and Structures Related with the Thread Control Block.
struct Thread_Configured_control Thread_Configured_control
The configured thread control block.
Definition: thread.h:969
Scheduler node specialization for Deterministic Priority Affinity SMP schedulers.
Definition: schedulerpriorityaffinitysmp.h:230
Count of configured threads.
Maximum size of a thread name in characters (including the terminating '\0' character).
Classic Tasks Manager Data Structures.
