RTEMS  5.1
system_same70.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef SYSTEM_SAME70_H_INCLUDED
31 #define SYSTEM_SAME70_H_INCLUDED
32 #ifdef __rtems__
33 #include <bsp/atsam-clock-config.h>
34 #endif /* __rtems__ */
35
36 /* @cond 0 */
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
42 /* @endcond */
43
44 #include <stdint.h>
45
46 extern uint32_t SystemCoreClock; /* System Clock Frequency (Core Clock) */
47
52 #ifndef __rtems__
53 void SystemInit(void);
54 #else /* __rtems__ */
55 void ATSAM_START_SRAM_SECTION SystemInit(void);
56 #endif /* __rtems__ */
57
62 void SystemCoreClockUpdate(void);
63
67 void system_init_flash(uint32_t dw_clk);
68
69 void sysclk_enable_usb(void);
70 void sysclk_disable_usb(void);
71
72 /* @cond 0 */
74 #ifdef __cplusplus
75 }
76 #endif
77
78 /* @endcond */
79
80 #endif /* SYSTEM_SAME70_H_INCLUDED */
