RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
libmisc
monitor
symbols.h
1
2
* RTEMS monitor symbol table functions
3
4
* Description:
5
* Entry points for symbol table routines.
6
7
8
9
* TODO:
10
11
12
#ifndef _INCLUDE_SYMBOLS_H
13
#define _INCLUDE_SYMBOLS_H
14
15
rtems/monitor.h
16
17
#ifdef __cplusplus
18
extern
"C"
19
#endif
20
21
struct
_rtems_symbol_t
22
uint32_t value;
23
char
*name;
24
25
26
#define SYMBOL_STRING_BLOCK_SIZE 4080
27
typedef
struct
rtems_symbol_string_block_s
28
struct
*next;
29
char
buffer[SYMBOL_STRING_BLOCK_SIZE];
30
rtems_symbol_string_block_t
31
32
struct
_rtems_symbol_table_t
33
34
uint32_t sorted;
/* are symbols sorted right now? */
35
uint32_t growth_factor;
/* % to grow by when needed */
36
uint32_t next;
/* next symbol slot to use when adding */
37
uint32_t size;
/* max # of symbols */
38
39
40
* Symbol list -- sorted by address (when we do a lookup)
41
42
43
rtems_symbol_t
*addresses;
/* symbol array by address */
44
45
46
* String pool, unsorted, a list of blocks of string data
47
48
49
*string_buffer_head;
50
*string_buffer_current;
51
uint32_t strings_next;
/* next byte to use in this block */
52
53
54
55
#define rtems_symbol_name(sp) ((sp)->name)
56
#define rtems_symbol_value(sp) ((sp)->value)
57
58
#ifdef __cplusplus
59
60
#endif
61
62
#endif
/* ! _INCLUDE_SYMBOLS_H */
_rtems_symbol_t
Definition:
symbols.h:21
Definition:
symbols.h:32
monitor.h
The RTEMS Monitor Task.
Definition:
symbols.h:27
