RTEMS  5.1
ALT_I2C_raw_s Struct Reference
volatile uint32_t ic_con
volatile uint32_t ic_tar
volatile uint32_t ic_sar
volatile uint32_t _pad_0xc_0xf
volatile uint32_t ic_data_cmd
volatile uint32_t ic_ss_scl_hcnt
volatile uint32_t ic_ss_scl_lcnt
volatile uint32_t ic_fs_scl_hcnt
volatile uint32_t ic_fs_scl_lcnt
volatile uint32_t _pad_0x24_0x2b [2]
volatile uint32_t ic_intr_stat
volatile uint32_t ic_intr_mask
volatile uint32_t ic_raw_intr_stat
volatile uint32_t ic_rx_tl
volatile uint32_t ic_tx_tl
volatile uint32_t ic_clr_intr
volatile uint32_t ic_clr_rx_under
volatile uint32_t ic_clr_rx_over
volatile uint32_t ic_clr_tx_over
volatile uint32_t ic_clr_rd_req
volatile uint32_t ic_clr_tx_abrt
volatile uint32_t ic_clr_rx_done
volatile uint32_t ic_clr_activity
volatile uint32_t ic_clr_stop_det
volatile uint32_t ic_clr_start_det
volatile uint32_t ic_clr_gen_call
volatile uint32_t ic_enable
volatile uint32_t ic_status
volatile uint32_t ic_txflr
volatile uint32_t ic_rxflr
volatile uint32_t ic_sda_hold
volatile uint32_t ic_tx_abrt_source
volatile uint32_t ic_slv_data_nack_only
volatile uint32_t ic_dma_cr
volatile uint32_t ic_dma_tdlr
volatile uint32_t ic_dma_rdlr
volatile uint32_t ic_sda_setup
volatile uint32_t ic_ack_general_call
volatile uint32_t ic_enable_status
volatile uint32_t ic_fs_spklen
volatile uint32_t _pad_0xa4_0xf3 [20]
volatile uint32_t ic_comp_param_1
volatile uint32_t ic_comp_version
volatile uint32_t ic_comp_type
