RTEMS  5.1
stm32f4xxxx_otgfs.h
1 /*
2  * Copyright (c) 2013 Chris Nott. All rights reserved.
3  *
4  * Virtual Logic
5  * 21-25 King St.
6  * Rockdale NSW 2216
7  * Australia
8  * <rtems@vl.com.au>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H
16 #define LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H
17
18 #include <bsp/utility.h>
19
20 #define USB_OTG_NUM_EPS 4
21 #define USB_OTG_MAX_TX_FIFOS 4
22
23 #define USB_FIFO_BASE 0x1000
24 #define USB_FIFO_OFFS 0x1000
25
27  uint32_t gotgctl; // 0x00: Control and status register
28 #define STM32F4_OTGFS_GOTGCTL_BSVLD BSP_BIT32(19) // B-session valid
29 #define STM32F4_OTGFS_GOTGCTL_ASVLD BSP_BIT32(18) // A-session valid
30 #define STM32F4_OTGFS_GOTGCTL_DBCT BSP_BIT32(17) // Debounce time
31 #define STM32F4_OTGFS_GOTGCTL_CIDSTS BSP_BIT32(16) // Connector ID status
32 #define STM32F4_OTGFS_GOTGCTL_DHNPEN BSP_BIT32(11) // Device HNP enable
33 #define STM32F4_OTGFS_GOTGCTL_HSHNPEN BSP_BIT32(10) // Host set HNP enable
34 #define STM32F4_OTGFS_GOTGCTL_HNPRQ BSP_BIT32(9) // HNP request
35 #define STM32F4_OTGFS_GOTGCTL_HNGSCS BSP_BIT32(8) // Host negotiation status
36 #define STM32F4_OTGFS_GOTGCTL_SRQ BSP_BIT32(1) // Session request
37 #define STM32F4_OTGFS_GOTGCTL_SRQSCS BSP_BIT32(0) // Session request success
38
39  uint32_t gotgint; // 0x04: Interrupt register
40 #define STM32F4_OTGFS_GOTGINT_DBCDNE BSP_BIT32(19) // Debounce done
41 #define STM32F4_OTGFS_GOTGINT_ADTOCHG BSP_BIT32(18) // A-device timeout change
42 #define STM32F4_OTGFS_GOTGINT_HNGDET BSP_BIT32(17) // Host negotiation detected
43 #define STM32F4_OTGFS_GOTGINT_HNSSCHG BSP_BIT32(9) // Host negotiation success status change
44 #define STM32F4_OTGFS_GOTGINT_SRSSCHG BSP_BIT32(8) // Session request status change
45 #define STM32F4_OTGFS_GOTGINT_SEDET BSP_BIT32(2) // Session end detected
46
47  uint32_t gahbcfg; // 0x08: AHB configuration register
48 #define STM32F4_OTGFS_GAHBCFG_PTXFELVL BSP_BIT32(8) // Periodic txfifo empty level
49 #define STM32F4_OTGFS_GAHBCFG_TXFELVL BSP_BIT32(7) // Txfifo empty level
50 #define STM32F4_OTGFS_GAHBCFG_GINTMSK BSP_BIT32(0) // Global interrupt mask
51
52  uint32_t gusbcfg; // 0x0C: USB configuration register
53 #define STM32F4_OTGFS_GUSBCFG_CTXPKT BSP_BIT32(31) // Corrupt TX packet
54 #define STM32F4_OTGFS_GUSBCFG_FDMOD BSP_BIT32(30) // Force device mode
55 #define STM32F4_OTGFS_GUSBCFG_FHMOD BSP_BIT32(29) // Force host mode
56 #define STM32F4_OTGFS_GUSBCFG_TRDT(val) BSP_FLD32(val, 10, 13) // USB turnaround time
57 #define STM32F4_OTGFS_GUSBCFG_TRDT_GET(reg) BSP_FLD32GET(reg, 10, 13)
58 #define STM32F4_OTGFS_GUSBCFG_TRDT_SET(reg, val) BSP_FLD32SET(reg, val, 10, 13)
59 #define STM32F4_OTGFS_GUSBCFG_HNPCAP BSP_BIT32(9) // HNP-capable
60 #define STM32F4_OTGFS_GUSBCFG_SRPCAP BSP_BIT32(8) // SRP-capable
61 #define STM32F4_OTGFS_GUSBCFG_PHYSEL BSP_BIT32(6) // Full speed serial transceiver select
62 #define STM32F4_OTGFS_GUSBCFG_TOCAL(val) BSP_FLD32(val, 0, 2) // FS timeout calibration
63 #define STM32F4_OTGFS_GUSBCFG_TOCAL_GET(reg) BSP_FLD32GET(reg, 0, 2)
64 #define STM32F4_OTGFS_GUSBCFG_TOCAL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
65
66  uint32_t grstctl; // 0x10: Reset register
67 #define STM32F4_OTGFS_GRSTCTL_AHBIDL BSP_BIT32(31) // AHB master idle
68 #define STM32F4_OTGFS_GRSTCTL_TXFNUM(val) BSP_FLD32(val, 6, 10) // Tx fifo number
69 #define STM32F4_OTGFS_GRSTCTL_TXFNUM_GET(reg) BSP_FLD32GET(reg, 6, 10)
70 #define STM32F4_OTGFS_GRSTCTL_TXFNUM_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)
71 #define STM32F4_OTGFS_GRSTCTL_TXFNUM_ALL STM32F4_OTGFS_GRSTCTL_TXFNUM(0x10)
72 #define STM32F4_OTGFS_GRSTCTL_TXFFLSH BSP_BIT32(5) // TX fifo flush
73 #define STM32F4_OTGFS_GRSTCTL_RXFFLSH BSP_BIT32(4) // RX fifo flush
74 #define STM32F4_OTGFS_GRSTCTL_FCRST BSP_BIT32(2) // Host frame counter reset
75 #define STM32F4_OTGFS_GRSTCTL_HSRST BSP_BIT32(1) // HCLK soft reset
76 #define STM32F4_OTGFS_GRSTCTL_CSRST BSP_BIT32(0) // Core soft reset
77
78  uint32_t gintsts; // 0x14: Core interrupt register
79 #define STM32F4_OTGFS_GINTSTS_WKUPINT BSP_BIT32(31) // Resume / remote wakeup detected interrupt
80 #define STM32F4_OTGFS_GINTSTS_SRQINT BSP_BIT32(30) // Session request / new session detected interrupt
81 #define STM32F4_OTGFS_GINTSTS_DISCINT BSP_BIT32(29) // Disconnect detected interrupt
82 #define STM32F4_OTGFS_GINTSTS_CIDSCHG BSP_BIT32(28) // Connector ID status change
83 #define STM32F4_OTGFS_GINTSTS_PTXFE BSP_BIT32(26) // Periodic TX fifo empty
84 #define STM32F4_OTGFS_GINTSTS_HCINT BSP_BIT32(25) // Host channels interrupt
85 #define STM32F4_OTGFS_GINTSTS_HPRTINT BSP_BIT32(24) // Host port interrupt
86 #define STM32F4_OTGFS_GINTSTS_IPXFR BSP_BIT32(21) // Incomplete periodic transfer
87 #define STM32F4_OTGFS_GINTSTS_IISOOXFR BSP_BIT32(21) // Incomplete isochronous OUT transfer
88 #define STM32F4_OTGFS_GINTSTS_IISOIXFR BSP_BIT32(20) // Incomplete isochronous IN transfer
89 #define STM32F4_OTGFS_GINTSTS_OEPINT BSP_BIT32(19) // OUT endpoint interrupt
90 #define STM32F4_OTGFS_GINTSTS_IEPINT BSP_BIT32(18) // IN endpoint interrupt
91 #define STM32F4_OTGFS_GINTSTS_EOPF BSP_BIT32(15) // End of periodic frame interrupt
92 #define STM32F4_OTGFS_GINTSTS_ISOODRP BSP_BIT32(14) // Isochronous OUT packet dropped interrupt
93 #define STM32F4_OTGFS_GINTSTS_ENUMDNE BSP_BIT32(13) // Enumeration done
94 #define STM32F4_OTGFS_GINTSTS_USBRST BSP_BIT32(12) // USB reset
95 #define STM32F4_OTGFS_GINTSTS_USBSUSP BSP_BIT32(11) // USB suspend
96 #define STM32F4_OTGFS_GINTSTS_ESUSP BSP_BIT32(10) // Early suspend
97 #define STM32F4_OTGFS_GINTSTS_GONAKEFF BSP_BIT32(7) // Global OUT NAK effective
98 #define STM32F4_OTGFS_GINTSTS_GINAKEFF BSP_BIT32(6) // Global IN non-periodic NAK effective
99 #define STM32F4_OTGFS_GINTSTS_NPTXFE BSP_BIT32(5) // Non-periodic TX fifo empty
100 #define STM32F4_OTGFS_GINTSTS_RXFLVL BSP_BIT32(4) // RX fifo non-empty
101 #define STM32F4_OTGFS_GINTSTS_SOF BSP_BIT32(3) // Start of frame
102 #define STM32F4_OTGFS_GINTSTS_OTGINT BSP_BIT32(2) // OTG interrupt
103 #define STM32F4_OTGFS_GINTSTS_MMIS BSP_BIT32(1) // Mode mismatch interrupt
104 #define STM32F4_OTGFS_GINTSTS_CMOD BSP_BIT32(0) // Current mode of operation
105
106  uint32_t gintmsk; // 0x18: Interrupt mask register
107
108  uint32_t grxstsr; // 0x1C: Receive status debug read
109
110  uint32_t grxstsp; // 0x20: OTG status read and pop
111 #define STM32F4_OTGFS_GRXSTSP_FRMNUM(val) BSP_FLD32(val, 21, 24) // Frame number
112 #define STM32F4_OTGFS_GRXSTSP_FRMNUM_GET(reg) BSP_FLD32GET(reg, 21, 24)
113 #define STM32F4_OTGFS_GRXSTSP_FRMNUM_SET(reg, val) BSP_FLD32SET(reg, val, 21, 24)
114 #define STM32F4_OTGFS_GRXSTSP_PKTSTS(val) BSP_FLD32(val, 17, 20) // Packet status
115 #define STM32F4_OTGFS_GRXSTSP_PKTSTS_GET(reg) BSP_FLD32GET(reg, 17, 20)
116 #define STM32F4_OTGFS_GRXSTSP_PKTSTS_SET(reg, val) BSP_FLD32SET(reg, val, 17, 20)
117 #define PKTSTS_IN_DATA (0x2)
118 #define PKTSTS_IN_COMPLETE (0x3)
119 #define PKTSTS_TOGGLE_ERR (0x5)
120 #define PKTSTS_HALTED (0x7)
121 #define PKTSTS_OUTNAK (0x1)
122 #define PKTSTS_OUT_DATA (0x2)
123 #define PKTSTS_OUT_COMPLETE (0x3)
124 #define PKTSTS_SETUP_COMPLETE (0x4)
125 #define PKTSTS_SETUP_DATA (0x6)
126 #define STM32F4_OTGFS_GRXSTSP_DPIG(val) BSP_FLD32(val, 15, 16) // Data PID
127 #define STM32F4_OTGFS_GRXSTSP_DPID_GET(reg) BSP_FLD32GET(reg, 15, 16)
128 #define STM32F4_OTGFS_GRXSTSP_DPID_SET(reg, val) BSP_FLD32SET(reg, val, 15, 16)
129 #define STM32F4_OTGFS_GRXSTSP_DPID_DATA0 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x0)
130 #define STM32F4_OTGFS_GRXSTSP_DPID_DATA1 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x1)
131 #define STM32F4_OTGFS_GRXSTSP_DPID_DATA2 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x2)
132 #define STM32F4_OTGFS_GRXSTSP_DPID_MDATA0 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x3)
133 #define STM32F4_OTGFS_GRXSTSP_BCNT(val) BSP_FLD32(val, 4, 14) // Byte count
134 #define STM32F4_OTGFS_GRXSTSP_BCNT_GET(reg) BSP_FLD32GET(reg, 4, 14)
135 #define STM32F4_OTGFS_GRXSTSP_BCNT_SET(reg, val) BSP_FLD32SET(reg, val, 4, 14)
136 #define STM32F4_OTGFS_GRXSTSP_CHNUM(val) BSP_FLD32(val, 0, 3) // Channel number
137 #define STM32F4_OTGFS_GRXSTSP_CHNUM_GET(reg) BSP_FLD32GET(reg, 0, 3)
138 #define STM32F4_OTGFS_GRXSTSP_CHNUM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
139 #define STM32F4_OTGFS_GRXSTSP_EPNUM(val) BSP_FLD32(val, 0, 3) // Endpoint number
140 #define STM32F4_OTGFS_GRXSTSP_EPNUM_GET(reg) BSP_FLD32GET(reg, 0, 3)
141 #define STM32F4_OTGFS_GRXSTSP_EPNUM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
142
143  uint32_t grxfsiz; // 0x24: Receive FIFO size register
144 #define STM32F4_OTGFS_GRXFSIZ_RXFD(val) BSP_FLD32(val, 0, 15)
145 #define STM32F4_OTGFS_GRXFSIZ_RXFD_GET(reg) BSP_FLD32GET(reg, 0, 15)
146 #define STM32F4_OTGFS_GRXFSIZ_RXFD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
147 #define STM32F4_OTGFS_GRXFSIZ_RXFD_MIN 16
148 #define STM32F4_OTGFS_GRXFSIZ_RXFD_MAX 256
149
150  uint32_t dieptxf0; // 0x28: EP 0 transmit fifo size
151 #define STM32F4_OTGFS_DIEPTXF_DEPTH(val) BSP_FLD32(val, 16, 31)
152 #define STM32F4_OTGFS_DIEPTXF_DEPTH_GET(reg) BSP_FLD32GET(reg, 16, 31)
153 #define STM32F4_OTGFS_DIEPTXF_DEPTH_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
154 #define STM32F4_OTGFS_DIEPTXF_DEPTH_MIN 16
155 #define STM32F4_OTGFS_DIEPTXF_DEPTH_MAX 256
156 #define STM32F4_OTGFS_DIEPTXF_SADDR(val) BSP_FLD32(val, 0, 15)
157 #define STM32F4_OTGFS_DIEPTXF_SADDR_GET(reg) BSP_FLD32GET(reg, 0, 15)
158 #define STM32F4_OTGFS_DIEPTXF_SADDR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
159
160  uint32_t resv2C;
161
162  uint32_t gi2cctl; // 0x30
163  uint32_t resv34; // 0x34
164
165  uint32_t gccfg; // 0x38: General core configuration register
166 #define STM32F4_OTGFS_GCCFG_NOVBUSSENS BSP_BIT32(21) // Vbus sensing disable
167 #define STM32F4_OTGFS_GCCFG_SOFOUTEN BSP_BIT32(20) // SOF output enable
168 #define STM32F4_OTGFS_GCCFG_VBUSBSEN BSP_BIT32(19) // Vbus sensing "B" device
169 #define STM32F4_OTGFS_GCCFG_VBUSASEN BSP_BIT32(18) // Vbus sensing "A" device
170 #define STM32F4_OTGFS_GCCFG_PWRDWN BSP_BIT32(16) // Power down
171
172  uint32_t cid; // 0x3C: Product ID
173
174  uint32_t resv40[48]; // 0x40 - 0x9C
175
176  uint32_t hptxfsiz; // 0x100
177
178  uint32_t dieptxf[USB_OTG_MAX_TX_FIFOS]; // 0x104
179
180 } __attribute__ ((packed));
181 typedef struct stm32f4_otgfs_s stm32f4_otgfs;
182
184  uint32_t dcfg; // 0x800
185 #define STM32F4_OTGFS_DCFG_PFIVL(val) BSP_FLD32(val, 11, 12) // Periodic frame interval
186 #define STM32F4_OTGFS_DCFG_PFIVL_GET(reg) BSP_FLD32GET(reg, 11, 12)
187 #define STM32F4_OTGFS_DCFG_PFIVL_SET(reg, val) BSP_FLD32SET(reg, val, 11, 12)
188 #define PFIVL_80 0
189 #define PFIVL_85 1
190 #define PFIVL_90 2
191 #define PFIVL_95 3
192 #define STM32F4_OTGFS_DCFG_DAD(val) BSP_FLD32(val, 4, 10) // Device address
193 #define STM32F4_OTGFS_DCFG_DAD_GET(reg) BSP_FLD32GET(reg, 4, 10)
194 #define STM32F4_OTGFS_DCFG_DAD_SET(reg, val) BSP_FLD32SET(reg, val, 4, 10)
195 #define STM32F4_OTGFS_DCFG_NZLSOHSK BSP_BIT32(2) // Non-zero-length status OUT handshake
196 #define STM32F4_OTGFS_DCFG_DSPD(val) BSP_FLD32(val, 0, 1) // Device speed
197 #define STM32F4_OTGFS_DCFG_DSPD_GET(reg) BSP_FLD32GET(reg, 0, 1)
198 #define STM32F4_OTGFS_DCFG_DSPD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
199 #define STM32F4_OTGFS_DCFG_DSPD_FULL STM32F4_OTGFS_DCFG_DSPD(0x3)
200
201  uint32_t dctl; // 0x804
202 #define STM32F4_OTGFS_DCTL_POPRGDNE BSP_BIT32(11) // Power-on programming done
203 #define STM32F4_OTGFS_DCTL_CGONAK BSP_BIT32(10) // Clear global OUT NAK
204 #define STM32F4_OTGFS_DCTL_SGONAK BSP_BIT32(9) // Set global OUT NAK
205 #define STM32F4_OTGFS_DCTL_CGINAK BSP_BIT32(8) // Clear global IN NAK
206 #define STM32F4_OTGFS_DCTL_SGINAK BSP_BIT32(7) // Set global IN NAK
207 #define STM32F4_OTGFS_DCTL_TCTL(val) BSP_FLD32(val, 4, 6) // Test control
208 #define STM32F4_OTGFS_DCTL_TCTL_GET(reg) BSP_FLD32GET(reg, 4, 6)
209 #define STM32F4_OTGFS_DCTL_TCTL_SET(reg, val) BSP_FLD32SET(reg, val, 4, 6)
210 #define STM32F4_OTGFS_DCTL_GONSTS BSP_BIT32(3) // Global OUT NAK status
211 #define STM32F4_OTGFS_DCTL_GINSTS BSP_BIT32(2) // Global IN NAK status
212 #define STM32F4_OTGFS_DCTL_SDIS BSP_BIT32(1) // Soft disconnect
213 #define STM32F4_OTGFS_DCTL_RWUSIG BSP_BIT32(0) // Remote wakeup signalling
214
215  uint32_t dsts; // 0x808
216 #define STM32F4_OTGFS_DSTS_FNSOF(val) BSP_FLD32(val, 8, 21) // Frame number of received SOF
217 #define STM32F4_OTGFS_DSTS_FNSOF_GET(reg) BSP_FLD32GET(reg, 8, 21)
218 #define STM32F4_OTGFS_DSTS_EERR BSP_BIT32(3) // Erratic error
219 #define STM32F4_OTGFS_DSTS_ENUMSPD(val) BSP_FLD32(val, 1, 2) // Enumerated speed
220 #define STM32F4_OTGFS_DSTS_ENUMSPD_GET(reg) BSP_FLD32GET(reg, 1, 2)
221 #define STM32F4_OTGFS_DSTS_ENUMSPD_FULL STM32F4_OTGFS_DSTS_ENUMSPD(0x3)
222 #define STM32F4_OTGFS_DSTS_SUSPSTS BSP_BIT32(0) // Suspend status
223
224  uint32_t unused4; // 0x80C
225
226  uint32_t diepmsk; // 0x810
227
228  uint32_t doepmsk; // 0x814
229
230  uint32_t daint; // 0x818
231 #define STM32F4_OTGFS_DAINT_OEPINT15 BSP_BIT32(31) // OUT endpoint 15 interrupt
232 #define STM32F4_OTGFS_DAINT_OEPINT14 BSP_BIT32(30) // OUT endpoint 14 interrupt
233 #define STM32F4_OTGFS_DAINT_OEPINT13 BSP_BIT32(29) // OUT endpoint 13 interrupt
234 #define STM32F4_OTGFS_DAINT_OEPINT12 BSP_BIT32(28) // OUT endpoint 12 interrupt
235 #define STM32F4_OTGFS_DAINT_OEPINT11 BSP_BIT32(27) // OUT endpoint 11 interrupt
236 #define STM32F4_OTGFS_DAINT_OEPINT10 BSP_BIT32(26) // OUT endpoint 10 interrupt
237 #define STM32F4_OTGFS_DAINT_OEPINT9 BSP_BIT32(25) // OUT endpoint 9 interrupt
238 #define STM32F4_OTGFS_DAINT_OEPINT8 BSP_BIT32(24) // OUT endpoint 8 interrupt
239 #define STM32F4_OTGFS_DAINT_OEPINT7 BSP_BIT32(23) // OUT endpoint 7 interrupt
240 #define STM32F4_OTGFS_DAINT_OEPINT6 BSP_BIT32(22) // OUT endpoint 6 interrupt
241 #define STM32F4_OTGFS_DAINT_OEPINT5 BSP_BIT32(21) // OUT endpoint 5 interrupt
242 #define STM32F4_OTGFS_DAINT_OEPINT4 BSP_BIT32(20) // OUT endpoint 4 interrupt
243 #define STM32F4_OTGFS_DAINT_OEPINT3 BSP_BIT32(19) // OUT endpoint 3 interrupt
244 #define STM32F4_OTGFS_DAINT_OEPINT2 BSP_BIT32(18) // OUT endpoint 2 interrupt
245 #define STM32F4_OTGFS_DAINT_OEPINT1 BSP_BIT32(17) // OUT endpoint 1 interrupt
246 #define STM32F4_OTGFS_DAINT_OEPINT0 BSP_BIT32(16) // OUT endpoint 0 interrupt
247 #define STM32F4_OTGFS_DAINT_IEPINT15 BSP_BIT32(15) // IN endpoint 15 interrupt
248 #define STM32F4_OTGFS_DAINT_IEPINT14 BSP_BIT32(14) // IN endpoint 14 interrupt
249 #define STM32F4_OTGFS_DAINT_IEPINT13 BSP_BIT32(13) // IN endpoint 13 interrupt
250 #define STM32F4_OTGFS_DAINT_IEPINT12 BSP_BIT32(12) // IN endpoint 12 interrupt
251 #define STM32F4_OTGFS_DAINT_IEPINT11 BSP_BIT32(11) // IN endpoint 11 interrupt
252 #define STM32F4_OTGFS_DAINT_IEPINT10 BSP_BIT32(10) // IN endpoint 10 interrupt
253 #define STM32F4_OTGFS_DAINT_IEPINT9 BSP_BIT32(9) // IN endpoint 9 interrupt
254 #define STM32F4_OTGFS_DAINT_IEPINT8 BSP_BIT32(8) // IN endpoint 8 interrupt
255 #define STM32F4_OTGFS_DAINT_IEPINT7 BSP_BIT32(7) // IN endpoint 7 interrupt
256 #define STM32F4_OTGFS_DAINT_IEPINT6 BSP_BIT32(6) // IN endpoint 6 interrupt
257 #define STM32F4_OTGFS_DAINT_IEPINT5 BSP_BIT32(5) // IN endpoint 5 interrupt
258 #define STM32F4_OTGFS_DAINT_IEPINT4 BSP_BIT32(4) // IN endpoint 4 interrupt
259 #define STM32F4_OTGFS_DAINT_IEPINT3 BSP_BIT32(3) // IN endpoint 3 interrupt
260 #define STM32F4_OTGFS_DAINT_IEPINT2 BSP_BIT32(2) // IN endpoint 2 interrupt
261 #define STM32F4_OTGFS_DAINT_IEPINT1 BSP_BIT32(1) // IN endpoint 1 interrupt
262 #define STM32F4_OTGFS_DAINT_IEPINT0 BSP_BIT32(0) // IN endpoint 0 interrupt
263
264  uint32_t daintmsk; // 0x81C
265 #define STM32F4_OTGFS_DAINTMSK_OEPM(val) BSP_FLD32(val, 16, 31) // OUT endpoint interrupt mask
266 #define STM32F4_OTGFS_DAINTMSK_OEPM_GET(reg) BSP_FLD32GET(reg, 16, 31)
267 #define STM32F4_OTGFS_DAINTMSK_OEPM_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
268 #define STM32F4_OTGFS_DAINTMSK_IEPM(val) BSP_FLD32(val, 0, 15) // IN endpoint interrupt mask
269 #define STM32F4_OTGFS_DAINTMSK_IEPM_GET(reg) BSP_FLD32GET(reg, 0, 15)
270 #define STM32F4_OTGFS_DAINTMSK_IEPM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
271
272  uint32_t unused5[2]; // 0x820 - 0x824
273
274  uint32_t dvbusdis; // 0x828
275 #define STM32F4_OTGFS_DVBUSDIS_VBUSDT(val) BSP_FLD32(val, 0, 15) // Device Vbus discharge time
276 #define STM32F4_OTGFS_DVBUSDIS_VBUSDT_GET(reg) BSP_FLD32GET(reg, 0, 15)
277 #define STM32F4_OTGFS_DVBUSDIS_VBUSDT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
278
279  uint32_t dvbuspulse; // 0x82C
280 #define STM32F4_OTGFS_DVBUSPULSE_DVBUSP(val) BSP_FLD32(val, 0, 15) // Device Vbus pulsing time
281 #define STM32F4_OTGFS_DVBUSPULSE_DVBUSP_GET(reg) BSP_FLD32GET(reg, 0, 15)
282 #define STM32F4_OTGFS_DVBUSPULSE_DVBUSP_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
283
284  uint32_t unused6; // 0x830
285
286  uint32_t diepempmsk; // 0x834
287 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM15 BSP_BIT32(15) // IN endpoint 15 TxFIFO empty interrupt mask
288 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM14 BSP_BIT32(14) // IN endpoint 14 TxFIFO empty interrupt mask
289 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM13 BSP_BIT32(13) // IN endpoint 13 TxFIFO empty interrupt mask
290 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM12 BSP_BIT32(12) // IN endpoint 12 TxFIFO empty interrupt mask
291 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM11 BSP_BIT32(11) // IN endpoint 11 TxFIFO empty interrupt mask
292 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM10 BSP_BIT32(10) // IN endpoint 10 TxFIFO empty interrupt mask
293 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM9 BSP_BIT32(9) // IN endpoint 9 TxFIFO empty interrupt mask
294 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM8 BSP_BIT32(8) // IN endpoint 8 TxFIFO empty interrupt mask
295 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM7 BSP_BIT32(7) // IN endpoint 7 TxFIFO empty interrupt mask
296 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM6 BSP_BIT32(6) // IN endpoint 6 TxFIFO empty interrupt mask
297 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM5 BSP_BIT32(5) // IN endpoint 5 TxFIFO empty interrupt mask
298 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM4 BSP_BIT32(4) // IN endpoint 4 TxFIFO empty interrupt mask
299 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM3 BSP_BIT32(3) // IN endpoint 3 TxFIFO empty interrupt mask
300 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM2 BSP_BIT32(2) // IN endpoint 2 TxFIFO empty interrupt mask
301 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM1 BSP_BIT32(1) // IN endpoint 1 TxFIFO empty interrupt mask
302 #define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM0 BSP_BIT32(0) // IN endpoint 0 TxFIFO empty interrupt mask
303
304 } __attribute__ ((packed));
306
308  uint32_t diepctl; // 0x900
309 #define STM32F4_OTGFS_DIEPCTL_EPENA BSP_BIT32(31) // Endpoint enable
310 #define STM32F4_OTGFS_DIEPCTL_EPDIS BSP_BIT32(30) // Endpoint disable
311 #define STM32F4_OTGFS_DIEPCTL_SODDFRM BSP_BIT32(29) // Set odd frame
312 #define STM32F4_OTGFS_DIEPCTL_SD0PID BSP_BIT32(28) // Set DATA0 PID / Set even frame
313 #define STM32F4_OTGFS_DIEPCTL_SEVNFRM BSP_BIT32(28) // Set DATA0 PID / Set even frame
314 #define STM32F4_OTGFS_DIEPCTL_SNAK BSP_BIT32(27) // Set NAK
315 #define STM32F4_OTGFS_DIEPCTL_CNAK BSP_BIT32(26) // Clear NAK
316 #define STM32F4_OTGFS_DIEPCTL_TXFNUM(val) BSP_FLD32(val, 22, 25) // TxFIFO number
317 #define STM32F4_OTGFS_DIEPCTL_TXFNUM_GET(reg) BSP_FLD32GET(reg, 22, 25)
318 #define STM32F4_OTGFS_DIEPCTL_TXFNUM_SET(reg, val) BSP_FLD32SET(reg, val, 22, 25)
319 #define STM32F4_OTGFS_DIEPCTL_STALL BSP_BIT32(21) // Stall handshake
320 #define STM32F4_OTGFS_DIEPCTL_EPTYP(val) BSP_FLD32(val, 18, 19) // Endpoint type - 00 = Control, 01 = Isoch, 10 = Bulk, 11 = Interrupt
321 #define STM32F4_OTGFS_DIEPCTL_EPTYP_GET(reg) BSP_FLD32GET(reg, 18, 19)
322 #define STM32F4_OTGFS_DIEPCTL_EPTYP_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
323 #define EPTYPE_CTRL 0
324 #define EPTYPE_ISOC 1
325 #define EPTYPE_BULK 2
326 #define EPTYPE_INTR 3
327 #define STM32F4_OTGFS_DIEPCTL_NAKSTS BSP_BIT32(17) // NAK status
328 #define STM32F4_OTGFS_DIEPCTL_EONUM_DPID BSP_BIT32(16) // Data PID / Even/odd frame
329 #define STM32F4_OTGFS_DIEPCTL_USBAEP BSP_BIT32(15) // USB active endpoint
330 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ(val) BSP_FLD32(val, 0, 1) // Maximum packet size (bytes)
331 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 1)
332 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
333 #define EP0_MPSIZ_8 3
334 #define EP0_MPSIZ_16 2
335 #define EP0_MPSIZ_32 1
336 #define EP0_MPSIZ_64 0
337 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_8 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_8)
338 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_16 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_16)
339 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_32 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_32)
340 #define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_64 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_64)
341 #define STM32F4_OTGFS_DIEPCTL_MPSIZ(val) BSP_FLD32(val, 0, 10) // Maximum packet size (bytes)
342 #define STM32F4_OTGFS_DIEPCTL_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 10)
343 #define STM32F4_OTGFS_DIEPCTL_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
344
345  uint32_t reserved_04;
346
347  uint32_t diepint; // 0x908
348 #define STM32F4_OTGFS_DIEPINT_TXFE BSP_BIT32(7) // Transmit FIFO empty
349 #define STM32F4_OTGFS_DIEPINT_INEPNE BSP_BIT32(6) // IN endpoint NAK effective
350 #define STM32F4_OTGFS_DIEPINT_ITTXFE BSP_BIT32(4) // IN token received, TxFIFO empty
351 #define STM32F4_OTGFS_DIEPINT_TOC BSP_BIT32(3) // Timeout condition
352 #define STM32F4_OTGFS_DIEPINT_EPDISD BSP_BIT32(1) // Endpoint disabled
353 #define STM32F4_OTGFS_DIEPINT_XFRC BSP_BIT32(0) // Transfer complete
354
355  uint32_t reserved_0C;
356
357  uint32_t dieptsiz; // 0x910
358 #define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT(val) BSP_FLD32(val, 19, 20) // EP0 packet count
359 #define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 20)
360 #define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 20)
361 #define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ(val) BSP_FLD32(val, 0, 6) // EP0 transfer size
362 #define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 6)
363 #define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
364 #define STM32F4_OTGFS_DIEPTSIZ_MCNT(val) BSP_FLD32(val, 29, 30) // Multi count
365 #define STM32F4_OTGFS_DIEPTSIZ_MCNT_GET(reg) BSP_FLD32GET(reg, 29, 30)
366 #define STM32F4_OTGFS_DIEPTSIZ_MCNT_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
367 #define STM32F4_OTGFS_DIEPTSIZ_PKTCNT(val) BSP_FLD32(val, 19, 28) // Packet count
368 #define STM32F4_OTGFS_DIEPTSIZ_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 28)
369 #define STM32F4_OTGFS_DIEPTSIZ_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 28)
370 #define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ(val) BSP_FLD32(val, 0, 18) // Transfer size
371 #define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 18)
372 #define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 18)
373
374  uint32_t reserved_14;
375
376  uint32_t dtxfsts; // 0x918
377 #define STM32F4_OTGFS_DTXFSTS_INEPTFSAV(val) BSP_FLD32(val, 0, 15) // IN endpoint TxFIFO space available
378 #define STM32F4_OTGFS_DTXFSTS_INEPTFSAV_GET(reg) BSP_FLD32(reg, 0, 15)
379 #define STM32F4_OTGFS_DTXFSTS_INEPTFSAV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
380
381  uint32_t reserved_1C;
382
383 } __attribute__ ((packed));
385
387  uint32_t doepctl; // 0xBx0: Endpoint control register
388 #define STM32F4_OTGFS_DOEPCTL_EPENA BSP_BIT32(31) // Endpoint enable
389 #define STM32F4_OTGFS_DOEPCTL_EPDIS BSP_BIT32(30) // Endpoint disable
390 #define STM32F4_OTGFS_DOEPCTL_SD1PID BSP_BIT32(29) // Set DATA1 PID / Set odd frame
391 #define STM32F4_OTGFS_DOEPCTL_SD0PID BSP_BIT32(28) // Set DATA0 PID / Set even frame
392 #define STM32F4_OTGFS_DOEPCTL_SNAK BSP_BIT32(27) // Set NAK
393 #define STM32F4_OTGFS_DOEPCTL_CNAK BSP_BIT32(26) // Clear NAK
394 #define STM32F4_OTGFS_DOEPCTL_STALL BSP_BIT32(21) // Stall handshake
395 #define STM32F4_OTGFS_DOEPCTL_SNPM BSP_BIT32(20) // Snoop mode
396 #define STM32F4_OTGFS_DOEPCTL_EPTYP(val) BSP_FLD32(val, 18, 19) // Endpoint type - 00 = Control, 01 = Isoch, 10 = Bulk, 11 = Interrupt
397 #define STM32F4_OTGFS_DOEPCTL_EPTYP_GET(reg) BSP_FLD32GET(reg, 18, 19)
398 #define STM32F4_OTGFS_DOEPCTL_EPTYP_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
399 #define STM32F4_OTGFS_DOEPCTL_NAKSTS BSP_BIT32(17) // NAK status
400 #define STM32F4_OTGFS_DOEPCTL_EONUM_DPID BSP_BIT32(16) // Data PID / Even/odd frame
401 #define STM32F4_OTGFS_DOEPCTL_USBAEP BSP_BIT32(15) // USB active endpoint
402 #define STM32F4_OTGFS_DOEPCTL_MPSIZ(val) BSP_FLD32(val, 0, 10) // Maximum packet size (bytes)
403 #define STM32F4_OTGFS_DOEPCTL_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 10)
404 #define STM32F4_OTGFS_DOEPCTL_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
405
406  uint32_t resv04;
407
408  uint32_t doepint; // 0xBx8: Endpoint interrupt register
409 #define STM32F4_OTGFS_DOEPINT_B2BSTUP BSP_BIT32(6) // Back-to-back SETUP packets received
410 #define STM32F4_OTGFS_DOEPINT_OTEPDIS BSP_BIT32(4) // OUT token received when endpoint disabled
411 #define STM32F4_OTGFS_DOEPINT_STUP BSP_BIT32(3) // SETUP phase done
412 #define STM32F4_OTGFS_DOEPINT_EPDISD BSP_BIT32(1) // Endpoint disabled interrupt
413 #define STM32F4_OTGFS_DOEPINT_XFRC BSP_BIT32(0) // Transfer complete
414
415  uint32_t doeptsiz; // 0xBy0
416 #define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT(val) BSP_FLD32(val, 29, 30) // EP0 SETUP packet count
417 #define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT_GET(reg) BSP_FLD32GET(reg, 29, 30)
418 #define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
419 #define STM32F4_OTGFS_DOEPTSIZ_EP0_PKTCNT BSP_BIT32(19) // EP0 packet count
420 #define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ(val) BSP_FLD32(val, 0, 6) // EP0 transfer size
421 #define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 6)
422 #define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
423 #define STM32F4_OTGFS_DOEPTSIZ_RXDPID(val) BSP_FLD32(val, 29, 30) // Received data PID
424 #define STM32F4_OTGFS_DOEPTSIZ_RXDPID_GET(reg) BSP_FLD32GET(reg, 29, 30)
425 #define STM32F4_OTGFS_DOEPTSIZ_RXDPID_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
426 #define STM32F4_OTGFS_DOEPTSIZ_PKTCNT(val) BSP_FLD32(val, 19, 28) // Packet count
427 #define STM32F4_OTGFS_DOEPTSIZ_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 28)
428 #define STM32F4_OTGFS_DOEPTSIZ_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 28)
429 #define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ(val) BSP_FLD32(val, 0, 18) // Transfer size
430 #define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 18)
431 #define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 18)
432
433  uint32_t resv14[3];
434 } __attribute__ ((packed));
436
438  uint32_t pcgcctl; // 0xE00: Power and clock gating control register
439 #define STM32F4_OTGFS_PCGCCTL_PHYSUSP BSP_BIT32(4) // PHY suspend
440 #define STM32F4_OTGFS_PCGCCTL_GATEHCLK BSP_BIT32(1) // Gate HCLK
441 #define STM32F4_OTGFS_PCGCCTL_STPPCLK BSP_BIT32(0) // Stop PHY clk
442 } __attribute__ ((packed));
444
445 #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H */
Definition: stm32f4xxxx_otgfs.h:26
Definition: stm32f4xxxx_otgfs.h:307
Utility macros.
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
Definition: stm32f4xxxx_otgfs.h:386
Definition: stm32f4xxxx_otgfs.h:183
Definition: stm32f4xxxx_otgfs.h:437
