RTEMS  5.1
stm32f4xxxx_flash.h
1 /*
2  * Copyright (c) 2013 Chris Nott. All rights reserved.
3  *
4  * Virtual Logic
5  * 21-25 King St.
6  * Rockdale NSW 2216
7  * Australia
8  * <rtems@vl.com.au>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
16 #define LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
17
18 #include <bsp/utility.h>
19
21
22  uint32_t acr; // Access and control register
23 #define STM32F4_FLASH_ACR_DCRST BSP_BIT32(12) // Data cache reset
24 #define STM32F4_FLASH_ACR_ICRST BSP_BIT32(11) // Instruction cache reset
25 #define STM32F4_FLASH_ACR_DCEN BSP_BIT32(10) // Data cache enable
26 #define STM32F4_FLASH_ACR_ICEN BSP_BIT32(9) // Instruction cache enable
27 #define STM32F4_FLASH_ACR_PRFTEN BSP_BIT32(8) // Prefetch enable
28 #define STM32F4_FLASH_ACR_LATENCY(val) BSP_FLD32(val, 0, 2) // Flash access latency
29 #define STM32F4_FLASH_ACR_LATENCY_GET(reg) BSP_FLD32GET(reg, 0, 2)
30 #define STM32F4_FLASH_ACR_LATENCY_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
31
32  uint32_t keyr; // Key register
33 #define STM32F4_FLASH_KEYR_KEY1 0x45670123
34 #define STM32F4_FLASH_KEYR_KEY2 0xCDEF89AB
35
36  uint32_t optkeyr; // Option key register
37 #define STM32F4_FLASH_OPTKEYR_OPTKEY1 0x08192A3B
38 #define STM32F4_FLASH_OPTKEYR_OPTKEY2 0x4C5D6E7F
39
40  uint32_t sr; // Status register
41 #define STM32F4_FLASH_SR_BSY BSP_BIT32(16) // Busy
42 #define STM32F4_FLASH_SR_PGSERR BSP_BIT32(7) // Programming sequence error
43 #define STM32F4_FLASH_SR_PGPERR BSP_BIT32(6) // Programming parallelism error
44 #define STM32F4_FLASH_SR_PGAERR BSP_BIT32(5) // Programming alignment error
45 #define STM32F4_FLASH_SR_WRPERR BSP_BIT32(4) // Write protection error
46 #define STM32F4_FLASH_SR_OPERR BSP_BIT32(1) // Operation error
47 #define STM32F4_FLASH_SR_EOP BSP_BIT32(0) // End of operation
48
49  uint32_t cr; // Control register
50 #define STM32F4_FLASH_CR_LOCK BSP_BIT32(31) // Lock
51 #define STM32F4_FLASH_CR_ERRIE BSP_BIT32(25) // Error interrupt enable
52 #define STM32F4_FLASH_CR_EOPIE BSP_BIT32(24) // End of operation interrupt enable
53 #define STM32F4_FLASH_CR_STRT BSP_BIT32(16) // Start
54 #define STM32F4_FLASH_CR_PSIZE(val) BSP_FLD32(val, 8, 9) // Program size
55 #define STM32F4_FLASH_CR_PSIZE_GET(reg) BSP_FLD32GET(reg, 8, 9)
56 #define STM32F4_FLASH_CR_PSIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 9)
57 #define STM32F4_FLASH_CR_SNB BSP_FLD32(val, 3, 6) // Sector number
58 #define STM32F4_FLASH_CR_SNB_GET(reg) BSP_FLD32GET(reg, 3, 6)
59 #define STM32F4_FLASH_CR_SNB_SET(reg, val) BSP_FLD32SET(reg, val, 3, 6)
60 #define STM32F4_FLASH_CR_MER BSP_BIT32(2) // Mass erase
61 #define STM32F4_FLASH_CR_SER BSP_BIT32(1) // Sector erase
62 #define STM32F4_FLASH_CR_PG BSP_BIT32(0) // Programming
63
64  uint32_t optcr; // Option control register
65 #define STM32F4_FLASH_OPTCR_NWRP(val) BSP_FLD32(val, 16, 27) // Not write protect
66 #define STM32F4_FLASH_OPTCR_NWRP_GET(reg) BSP_FLD32GET(reg, 16, 27)
67 #define STM32F4_FLASH_OPTCR_NWRP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 27)
68 #define STM32F4_FLASH_OPTCR_RDP(val) BSP_FLD32(val, 8, 15) // Read protect
69 #define STM32F4_FLASH_OPTCR_RDP_GET(reg) BSP_FLD32GET(reg, 8, 15)
70 #define STM32F4_FLASH_OPTCR_RDP_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
71 #define STM32F4_FLASH_OPTCR_USER(val) BSP_FLD32(val, 5, 7) // User option bytes
72 #define STM32F4_FLASH_OPTCR_USER_GET(reg) BSP_FLD32GET(reg, 5, 7)
73 #define STM32F4_FLASH_OPTCR_USER_SET(reg, val) BSP_FLD32SET(reg, val, 5, 7)
74 #define STM32F4_FLASH_OPTCR_BOR_LEVEL(val) BSP_FLD32(val, 2, 3) // BOR reset level
75 #define STM32F4_FLASH_OPTCR_BOR_LEVEL_GET(reg) BSP_FLD32GET(reg, 2, 3)
76 #define STM32F4_FLASH_OPTCR_BOR_LEVEL_SET(reg, val) BSP_FLD32SET(reg, val, 2, 3)
77 #define STM32F4_FLASH_CR_OPTSTRT BSP_BIT32(1) // Option start
78 #define STM32F4_FLASH_CR_OPTLOCK BSP_BIT32(0) // Option lock
79
80 } __attribute__ ((packed));
81 typedef struct stm32f4_flash_s stm32f4_flash;
82
83 #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H */
Utility macros.
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
Definition: stm32f4xxxx_flash.h:20
