RTEMS  5.1
stm32f4xxxx_adc.h
1 /*
2  * Copyright (c) 2014 Chris Nott. All rights reserved.
3  *
4  * Virtual Logic
5  * 21-25 King St.
6  * Rockdale NSW 2216
7  * Australia
8  * <rtems@vl.com.au>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H
16 #define LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H
17
18 #include <bsp/utility.h>
19
21  uint32_t sr; // 0x00: Status register
22 #define STM32F4_ADC_SR_OVR BSP_BIT32(5) // Overrun
23 #define STM32F4_ADC_SR_STRT BSP_BIT32(4) // Regular channel start flag
24 #define STM32F4_ADC_SR_JSTRT BSP_BIT32(3) // Injected channel start flag
25 #define STM32F4_ADC_SR_JEOC BSP_BIT32(2) // Injected channel end of conversion
26 #define STM32F4_ADC_SR_EOC BSP_BIT32(1) // Regular channel end of conversion
27 #define STM32F4_ADC_SR_AWD BSP_BIT32(0) // Analog watchdog flag
28
29  uint32_t cr1; // 0x04: Control register 1
30 #define STM32F4_ADC_CR1_OVRIE BSP_BIT32(26) // Overrun interrupt enable
31 #define STM32F4_ADC_CR1_RES(val) BSP_FLD32(val, 24, 25) // Resolution
32 #define STM32F4_ADC_CR1_RES_GET(reg) BSP_FLD32GET(reg, 24, 25)
33 #define STM32F4_ADC_CR1_RES_SET(reg, val) BSP_FLD32SET(reg, val, 24, 25)
34 #define ADC_CR1_RES_12BIT 0
35 #define ADC_CR1_RES_10BIT 1
36 #define ADC_CR1_RES_8BIT 2
37 #define ADC_CR1_RES_6BIT 3
38 #define STM32F4_ADC_CR1_AWDEN BSP_BIT32(23) // Analog watchdog enable on regular channels
39 #define STM32F4_ADC_CR1_JAWDEN BSP_BIT32(22) // Analog watchdog enable on injected channels
40 #define STM32F4_ADC_CR1_DISCNUM(val) BSP_FLD32(val, 13, 15) // Discontinuous mode channel count
41 #define STM32F4_ADC_CR1_DISCNUM_GET(reg) BSP_FLD32GET(reg, 13, 15)
42 #define STM32F4_ADC_CR1_DISCNUM_SET(reg, val) BSP_FLD32SET(reg, val, 13, 15)
43 #define STM32F4_ADC_CR1_JDISCEN BSP_BIT32(12) // Discontinous mode on injected channels
44 #define STM32F4_ADC_CR1_DISCEN BSP_BIT32(11) // Discontinous mode on regular channels
45 #define STM32F4_ADC_CR1_JAUTO BSP_BIT32(10) // Automated injected group conversion
46 #define STM32F4_ADC_CR1_AWDSGL BSP_BIT32(9) // Enable watchdog on single channel in scan mode
47 #define STM32F4_ADC_CR1_SCAN BSP_BIT32(8) // Scan mode
48 #define STM32F4_ADC_CR1_JEOCIE BSP_BIT32(7) // Interrupt enable for injected channels
49 #define STM32F4_ADC_CR1_AWDIE BSP_BIT32(6) // Analog watchdog interrupt enable
50 #define STM32F4_ADC_CR1_EOCIE BSP_BIT32(5) // Interrupt enable for EOC
51 #define STM32F4_ADC_CR1_AWDCH(val) BSP_FLD32(val, 0, 4) // Analog watchdog channel select bits
52 #define STM32F4_ADC_CR1_AWDCH_GET(reg) BSP_FLD32GET(reg, 0, 4)
53 #define STM32F4_ADC_CR1_AWDCH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
54
55  uint32_t cr2; // 0x08: Control register 2
56 #define STM32F4_ADC_CR2_SWSTART BSP_BIT32(30) // Start conversion of regular channels
57 #define STM32F4_ADC_CR2_EXTEN(val) BSP_FLD32(val, 28, 29) // External trigger enable for regular channels
58 #define STM32F4_ADC_CR2_EXTEN_GET(reg) BSP_FLD32GET(reg, 28, 29)
59 #define STM32F4_ADC_CR2_EXTEN_SET(reg, val) BSP_FLD32SET(reg, val, 28, 29)
60 #define STM32F4_ADC_CR2_JEXTEN(val) BSP_FLD32(val, 20, 21) // External trigger enable for injected channels
61 #define STM32F4_ADC_CR2_JEXTEN_GET(reg) BSP_FLD32GET(reg, 20, 21)
62 #define STM32F4_ADC_CR2_JEXTEN_SET(reg, val) BSP_FLD32SET(reg, val, 20, 21)
63 #define ADC_CR2_TRIGGER_DISABLE 0
64 #define ADC_CR2_TRIGGER_RISING 1
65 #define ADC_CR2_TRIGGER_FALLING 2
66 #define ADC_CR2_TRIGGER_BOTH 3
67 #define STM32F4_ADC_CR2_EXTSEL(val) BSP_FLD32(val, 24, 27) // External event select for regular group
68 #define STM32F4_ADC_CR2_EXTSEL_GET(reg) BSP_FLD32GET(reg, 24, 27)
69 #define STM32F4_ADC_CR2_EXTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 24, 27)
70 #define ADC_CR2_EVT_TIMER1_CC1 0x0
71 #define ADC_CR2_EVT_TIMER1_CC2 0x1
72 #define ADC_CR2_EVT_TIMER1_CC3 0x2
73 #define ADC_CR2_EVT_TIMER2_CC2 0x3
74 #define ADC_CR2_EVT_TIMER2_CC3 0x4
75 #define ADC_CR2_EVT_TIMER2_CC4 0x5
76 #define ADC_CR2_EVT_TIMER2_TRGO 0x6
77 #define ADC_CR2_EVT_TIMER3_CC1 0x7
78 #define ADC_CR2_EVT_TIMER3_TRGO 0x8
79 #define ADC_CR2_EVT_TIMER4_CC1 0x9
80 #define ADC_CR2_EVT_TIMER5_CC1 0xa
81 #define ADC_CR2_EVT_TIMER5_CC2 0xb
82 #define ADC_CR2_EVT_TIMER5_CC3 0xc
83 #define ADC_CR2_EVT_TIMER8_CC1 0xd
84 #define ADC_CR2_EVT_TIMER8_TRGO 0xe
85 #define ADC_CR2_EVT_EXTI_11 0xf
86 #define STM32F4_ADC_CR2_JSWSTART BSP_BIT32(22) // Start conversion of injected channels
87 #define STM32F4_ADC_CR2_JEXTSEL(val) BSP_FLD32(val, 16, 19) // External event select for injected group
88 #define STM32F4_ADC_CR2_JEXTSEL_GET(reg) BSP_FLD32GET(reg, 16, 19)
89 #define STM32F4_ADC_CR2_JEXTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
90 #define ADC_CR2_JEVT_TIMER1_CC4 0x0
91 #define ADC_CR2_JEVT_TIMER1_TRGO 0x1
92 #define ADC_CR2_JEVT_TIMER2_CC1 0x2
93 #define ADC_CR2_JEVT_TIMER2_TRGO 0x3
94 #define ADC_CR2_JEVT_TIMER3_CC2 0x4
95 #define ADC_CR2_JEVT_TIMER3_CC4 0x5
96 #define ADC_CR2_JEVT_TIMER4_CC1 0x6
97 #define ADC_CR2_JEVT_TIMER4_CC2 0x7
98 #define ADC_CR2_JEVT_TIMER4_CC3 0x8
99 #define ADC_CR2_JEVT_TIMER4_TRGO 0x9
100 #define ADC_CR2_JEVT_TIMER5_CC4 0xa
101 #define ADC_CR2_JEVT_TIMER5_TRGO 0xb
102 #define ADC_CR2_JEVT_TIMER8_CC2 0xc
103 #define ADC_CR2_JEVT_TIMER8_CC3 0xd
104 #define ADC_CR2_JEVT_TIMER8_CC4 0xe
105 #define ADC_CR2_JEVT_EXTI_15 0xf
106 #define STM32F4_ADC_CR2_ALIGN BSP_BIT32(11) // Data alignment
107 #define STM32F4_ADC_CR2_ALIGN_RIGHT 0
108 #define STM32F4_ADC_CR2_ALIGN_LEFT STM32F4_ADC_CR2_ALIGN
109 #define STM32F4_ADC_CR2_EOCS BSP_BIT32(10) // End of conversion selection
110 #define STM32F4_ADC_CR2_DDS BSP_BIT32(9) // DMA disable selection (single ADC mode)
111 #define STM32F4_ADC_CR2_DMA BSP_BIT32(8) // DMA access mode (single ADC)
112 #define STM32F4_ADC_CR2_CONT BSP_BIT32(1) // Continuous conversion
113 #define STM32F4_ADC_CR2_ADON BSP_BIT32(0) // A/D converter ON
114
115  uint32_t smpr1; // 0x0C: Sample time register 1
116 #define ADC_SAMPLE_3CYCLE 0
117 #define ADC_SAMPLE_15CYCLE 1
118 #define ADC_SAMPLE_28CYCLE 2
119 #define ADC_SAMPLE_56CYCLE 3
120 #define ADC_SAMPLE_84CYCLE 4
121 #define ADC_SAMPLE_112CYCLE 5
122 #define ADC_SAMPLE_144CYCLE 6
123 #define ADC_SAMPLE_480CYCLE 7
124 #define STM32F4_ADC_SMP18(val) BSP_FLD32(val, 24, 26) // Channel 18 sampling time selection
125 #define STM32F4_ADC_SMP18_GET(reg) BSP_FLD32GET(reg, 24, 26)
126 #define STM32F4_ADC_SMP18_SET(reg, val) BSP_FLD32SET(reg, val, 24, 26)
127 #define STM32F4_ADC_SMP17(val) BSP_FLD32(val, 21, 23) // Channel 17 sampling time selection
128 #define STM32F4_ADC_SMP17_GET(reg) BSP_FLD32GET(reg, 21, 23)
129 #define STM32F4_ADC_SMP17_SET(reg, val) BSP_FLD32SET(reg, val, 21, 23)
130 #define STM32F4_ADC_SMP16(val) BSP_FLD32(val, 18, 20) // Channel 16 sampling time selection
131 #define STM32F4_ADC_SMP16_GET(reg) BSP_FLD32GET(reg, 18, 20)
132 #define STM32F4_ADC_SMP16_SET(reg, val) BSP_FLD32SET(reg, val, 18, 20)
133 #define STM32F4_ADC_SMP15(val) BSP_FLD32(val, 15, 17) // Channel 15 sampling time selection
134 #define STM32F4_ADC_SMP15_GET(reg) BSP_FLD32GET(reg, 15, 17)
135 #define STM32F4_ADC_SMP15_SET(reg, val) BSP_FLD32SET(reg, val, 15, 17)
136 #define STM32F4_ADC_SMP14(val) BSP_FLD32(val, 12, 14) // Channel 14 sampling time selection
137 #define STM32F4_ADC_SMP14_GET(reg) BSP_FLD32GET(reg, 12, 14)
138 #define STM32F4_ADC_SMP14_SET(reg, val) BSP_FLD32SET(reg, val, 12, 14)
139 #define STM32F4_ADC_SMP13(val) BSP_FLD32(val, 9, 11) // Channel 13 sampling time selection
140 #define STM32F4_ADC_SMP13_GET(reg) BSP_FLD32GET(reg, 9, 11)
141 #define STM32F4_ADC_SMP13_SET(reg, val) BSP_FLD32SET(reg, val, 9, 11)
142 #define STM32F4_ADC_SMP12(val) BSP_FLD32(val, 6, 8) // Channel 12 sampling time selection
143 #define STM32F4_ADC_SMP12_GET(reg) BSP_FLD32GET(reg, 6, 8)
144 #define STM32F4_ADC_SMP12_SET(reg, val) BSP_FLD32SET(reg, val, 6, 8)
145 #define STM32F4_ADC_SMP11(val) BSP_FLD32(val, 3, 5) // Channel 11 sampling time selection
146 #define STM32F4_ADC_SMP11_GET(reg) BSP_FLD32GET(reg, 3, 5)
147 #define STM32F4_ADC_SMP11_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
148 #define STM32F4_ADC_SMP10(val) BSP_FLD32(val, 0, 2) // Channel 10 sampling time selection
149 #define STM32F4_ADC_SMP10_GET(reg) BSP_FLD32GET(reg, 0, 2)
150 #define STM32F4_ADC_SMP10_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
151
152  uint32_t smpr2; // 0x10: Sample time register 2
153 #define STM32F4_ADC_SMP9(val) BSP_FLD32(val, 27, 29) // Channel 9 sampling time selection
154 #define STM32F4_ADC_SMP9_GET(reg) BSP_FLD32GET(reg, 27, 29)
155 #define STM32F4_ADC_SMP9_SET(reg, val) BSP_FLD32SET(reg, val, 27, 29)
156 #define STM32F4_ADC_SMP8(val) BSP_FLD32(val, 24, 26) // Channel 8 sampling time selection
157 #define STM32F4_ADC_SMP8_GET(reg) BSP_FLD32GET(reg, 24, 26)
158 #define STM32F4_ADC_SMP8_SET(reg, val) BSP_FLD32SET(reg, val, 24, 26)
159 #define STM32F4_ADC_SMP7(val) BSP_FLD32(val, 21, 23) // Channel 7 sampling time selection
160 #define STM32F4_ADC_SMP7_GET(reg) BSP_FLD32GET(reg, 21, 23)
161 #define STM32F4_ADC_SMP7_SET(reg, val) BSP_FLD32SET(reg, val, 21, 23)
162 #define STM32F4_ADC_SMP6(val) BSP_FLD32(val, 18, 20) // Channel 6 sampling time selection
163 #define STM32F4_ADC_SMP6_GET(reg) BSP_FLD32GET(reg, 18, 20)
164 #define STM32F4_ADC_SMP6_SET(reg, val) BSP_FLD32SET(reg, val, 18, 20)
165 #define STM32F4_ADC_SMP5(val) BSP_FLD32(val, 15, 17) // Channel 5 sampling time selection
166 #define STM32F4_ADC_SMP5_GET(reg) BSP_FLD32GET(reg, 15, 17)
167 #define STM32F4_ADC_SMP5_SET(reg, val) BSP_FLD32SET(reg, val, 15, 17)
168 #define STM32F4_ADC_SMP4(val) BSP_FLD32(val, 12, 14) // Channel 4 sampling time selection
169 #define STM32F4_ADC_SMP4_GET(reg) BSP_FLD32GET(reg, 12, 14)
170 #define STM32F4_ADC_SMP4_SET(reg, val) BSP_FLD32SET(reg, val, 12, 14)
171 #define STM32F4_ADC_SMP3(val) BSP_FLD32(val, 9, 11) // Channel 3 sampling time selection
172 #define STM32F4_ADC_SMP3_GET(reg) BSP_FLD32GET(reg, 9, 11)
173 #define STM32F4_ADC_SMP3_SET(reg, val) BSP_FLD32SET(reg, val, 9, 11)
174 #define STM32F4_ADC_SMP2(val) BSP_FLD32(val, 6, 8) // Channel 2 sampling time selection
175 #define STM32F4_ADC_SMP2_GET(reg) BSP_FLD32GET(reg, 6, 8)
176 #define STM32F4_ADC_SMP2_SET(reg, val) BSP_FLD32SET(reg, val, 6, 8)
177 #define STM32F4_ADC_SMP1(val) BSP_FLD32(val, 3, 5) // Channel 1 sampling time selection
178 #define STM32F4_ADC_SMP1_GET(reg) BSP_FLD32GET(reg, 3, 5)
179 #define STM32F4_ADC_SMP1_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
180 #define STM32F4_ADC_SMP0(val) BSP_FLD32(val, 0, 2) // Channel 0 sampling time selection
181 #define STM32F4_ADC_SMP0_GET(reg) BSP_FLD32GET(reg, 0, 2)
182 #define STM32F4_ADC_SMP0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
183
184  uint32_t jofr[4]; // 0x14-0x20: Injected channel data offset registers
185 #define STM32F4_ADC_JOFFSET(val) BSP_FLD32(val, 0, 11) // Data offset for injected channel
186 #define STM32F4_ADC_JOFFSET_GET(reg) BSP_FLD32GET(reg, 0, 11)
187 #define STM32F4_ADC_JOFFSET_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
188
189  uint32_t htr; // 0x24: Watchdog higher threshold register
190 #define STM32F4_ADC_HT(val) BSP_FLD32(val, 0, 11) // Analog watchdog higher threshold
191 #define STM32F4_ADC_HT_GET(reg) BSP_FLD32GET(reg, 0, 11)
192 #define STM32F4_ADC_HT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
193
194  uint32_t ltr; // 0x28: Watchdog lower threshold register
195 #define STM32F4_ADC_LT(val) BSP_FLD32(val, 0, 11) // Analog watchdog lower threshold
196 #define STM32F4_ADC_LT_GET(reg) BSP_FLD32GET(reg, 0, 11)
197 #define STM32F4_ADC_LT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
198
199  uint32_t sqr[3]; // 0x2c-0x34: Regular sequence registers
200 #define STM32F4_ADC_SQR_L(val) BSP_FLD32(val, 20, 23) // Regular channel sequence length
201 #define STM32F4_ADC_SQR_L_GET(reg) BSP_FLD32GET(reg, 20, 23)
202 #define STM32F4_ADC_SQR_L_SET(reg, val) BSP_FLD32SET(reg, val, 20, 23)
203
204  uint32_t jsqr; // 0x38: Injected sequence register
205 #define STM32F4_ADC_JSQR_JL(val) BSP_FLD32(val, 20, 21) // Injected sequence length
206 #define STM32F4_ADC_JSQR_JL_GET(reg) BSP_FLD32GET(reg, 20, 21)
207 #define STM32F4_ADC_JSQR_JL_SET(reg, val) BSP_FLD32SET(reg, val, 20, 21)
208 #define STM32F4_ADC_JSQR_JSQ4(val) BSP_FLD32(val, 15, 19) // 4th conversion in injected sequence
209 #define STM32F4_ADC_JSQR_JSQ4_GET(reg) BSP_FLD32GET(reg, 15, 19)
210 #define STM32F4_ADC_JSQR_JSQ4_SET(reg, val) BSP_FLD32SET(reg, val, 15, 19)
211 #define STM32F4_ADC_JSQR_JSQ3(val) BSP_FLD32(val, 10, 14) // 3rd conversion in injected sequence
212 #define STM32F4_ADC_JSQR_JSQ3_GET(reg) BSP_FLD32GET(reg, 10, 14)
213 #define STM32F4_ADC_JSQR_JSQ3_SET(reg, val) BSP_FLD32SET(reg, val, 10, 14)
214 #define STM32F4_ADC_JSQR_JSQ2(val) BSP_FLD32(val, 5, 9) // 2nd conversion in injected sequence
215 #define STM32F4_ADC_JSQR_JSQ2_GET(reg) BSP_FLD32GET(reg, 5, 9)
216 #define STM32F4_ADC_JSQR_JSQ2_SET(reg, val) BSP_FLD32SET(reg, val, 5, 9)
217 #define STM32F4_ADC_JSQR_JSQ1(val) BSP_FLD32(val, 0, 4) // 1st conversion in injected sequence
218 #define STM32F4_ADC_JSQR_JSQ1_GET(reg) BSP_FLD32GET(reg, 0, 4)
219 #define STM32F4_ADC_JSQR_JSQ1_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
220
221  uint32_t jdr[4]; // 0x3c-0x48: Injected data registers
222 #define STM32F4_ADC_JDATA(val) BSP_FLD32(val, 0, 15) // Injected data
223 #define STM32F4_ADC_JDATA_GET(reg) BSP_FLD32GET(reg, 0, 15)
224 #define STM32F4_ADC_JDATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
225
226  uint32_t dr; // 0x4c: Regular data register
227 #define STM32F4_ADC_DATA(val) BSP_FLD32(val, 0, 15) // Regular data
228 #define STM32F4_ADC_DATA_GET(reg) BSP_FLD32GET(reg, 0, 15)
229 #define STM32F4_ADC_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
230
231 } __attribute__ ((packed));
232 typedef struct stm32f4_adc_chan_s stm32f4_adc_chan;
233
235  uint32_t csr; // 0x00: Common status register
236 #define STM32F4_ADC_CSR_OVR3 BSP_BIT32(21) // Overrun flag ADC3
237 #define STM32F4_ADC_CSR_STRT3 BSP_BIT32(20) // Regular start flag ADC3
238 #define STM32F4_ADC_CSR_JSTRT3 BSP_BIT32(19) // Injected start flag ADC3
239 #define STM32F4_ADC_CSR_JEOC3 BSP_BIT32(18) // Injected channel end of conversion flag ADC3
240 #define STM32F4_ADC_CSR_EOC3 BSP_BIT32(17) // Channel end of conversion flag ADC3
241 #define STM32F4_ADC_CSR_AWD3 BSP_BIT32(16) // Analog watchdog flag ADC3
242 #define STM32F4_ADC_CSR_OVR2 BSP_BIT32(13) // Overrun flag ADC2
243 #define STM32F4_ADC_CSR_STRT2 BSP_BIT32(12) // Regular start flag ADC2
244 #define STM32F4_ADC_CSR_JSTRT2 BSP_BIT32(11) // Injected start flag ADC2
245 #define STM32F4_ADC_CSR_JEOC2 BSP_BIT32(10) // Injected channel end of conversion flag ADC2
246 #define STM32F4_ADC_CSR_EOC2 BSP_BIT32(9) // Channel end of conversion flag ADC2
247 #define STM32F4_ADC_CSR_AWD2 BSP_BIT32(8) // Analog watchdog flag ADC2
248 #define STM32F4_ADC_CSR_OVR1 BSP_BIT32(5) // Overrun flag ADC1
249 #define STM32F4_ADC_CSR_STRT1 BSP_BIT32(4) // Regular start flag ADC1
250 #define STM32F4_ADC_CSR_JSTRT1 BSP_BIT32(3) // Injected start flag ADC1
251 #define STM32F4_ADC_CSR_JEOC1 BSP_BIT32(2) // Injected channel end of conversion flag ADC1
252 #define STM32F4_ADC_CSR_EOC1 BSP_BIT32(1) // Channel end of conversion flag ADC1
253 #define STM32F4_ADC_CSR_AWD1 BSP_BIT32(0) // Analog watchdog flag ADC1
254
255  uint32_t ccr; // 0x00: Common control register
256 #define STM32F4_ADC_CCR_TSVREFE BSP_BIT32(23) // Temp sensor and Vrefint enable
257 #define STM32F4_ADC_CCR_VBATE BSP_BIT32(22) // Vbat enable
258 #define STM32F4_ADC_CCR_ADCPRE(val) BSP_FLD32(val, 16, 17) // ADC prescalar
259 #define STM32F4_ADC_CCR_ADCPRE_GET(reg) BSP_FLD32GET(reg, 16, 17)
260 #define STM32F4_ADC_CCR_ADCPRE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 17)
261 #define ADC_ADCPRE_PCLK2_2 0
262 #define ADC_ADCPRE_PCLK2_4 1
263 #define ADC_ADCPRE_PCLK2_6 2
264 #define ADC_ADCPRE_PCLK2_8 3
265 #define STM32F4_ADC_CCR_DMA(val) BSP_FLD32(val, 14, 15) // DMA access mode for multi ADC
266 #define STM32F4_ADC_CCR_DMA_GET(reg) BSP_FLD32GET(reg, 14, 15)
267 #define STM32F4_ADC_CCR_DMA_SET(reg, val) BSP_FLD32SET(reg, val, 14, 15)
268 #define ADC_DMA_DISABLE 0
269 #define ADC_DMA_MODE1 1
270 #define ADC_DMA_MODE2 2
271 #define ADC_DMA_MODE3 3
272 #define STM32F4_ADC_CCR_DDS BSP_BIT32(13) // DMA disable selection
273 #define STM32F4_ADC_CCR_DELAY(val) BSP_FLD32(val, 8, 11) // Delay between sampling phases
274 #define STM32F4_ADC_CCR_DELAY_GET(reg) BSP_FLD32GET(reg, 8, 11)
275 #define STM32F4_ADC_CCR_DELAY_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
276 #define ADC_DELAY_5T 0
277 #define ADC_DELAY_6T 1
278 #define ADC_DELAY_7T 2
279 #define ADC_DELAY_8T 3
280 #define ADC_DELAY_9T 4
281 #define ADC_DELAY_10T 5
282 #define ADC_DELAY_11T 6
283 #define ADC_DELAY_12T 7
284 #define ADC_DELAY_13T 8
285 #define ADC_DELAY_14T 9
286 #define ADC_DELAY_15T 10
287 #define ADC_DELAY_16T 11
288 #define ADC_DELAY_17T 12
289 #define ADC_DELAY_18T 13
290 #define ADC_DELAY_19T 14
291 #define ADC_DELAY_20T 15
292 #define STM32F4_ADC_CCR_MULTI(val) BSP_FLD32(val, 0, 4) // Multi ADC mode
293 #define STM32F4_ADC_CCR_MULTI_GET(reg) BSP_FLD32GET(reg, 0, 4)
294 #define STM32F4_ADC_CCR_MULTI_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
295 #define ADC_MULTI_INDEPENDENT 0x00
296 #define ADC_MULTI_DUAL_REG_INJ 0x01
297 #define ADC_MULTI_DUAL_REG_ALT 0x02
298 #define ADC_MULTI_DUAL_INJ 0x05
299 #define ADC_MULTI_DUAL_REG 0x06
300 #define ADC_MULTI_DUAL_INTRL 0x07
301 #define ADC_MULTI_DUAL_ALT_TRIG 0x09
302 #define ADC_MULTI_TRIPLE_REG_INJ 0x11
303 #define ADC_MULTI_TRIPLE_REG_ALT 0x12
304 #define ADC_MULTI_TRIPLE_INJ 0x15
305 #define ADC_MULTI_TRIPLE_REG 0x16
306 #define ADC_MULTI_TRIPLE_INTRL 0x17
307 #define ADC_MULTI_TRIPLE_ALT_TRIG 0x19
308
309  uint32_t cdr; // 0x00: Common regular data register
310 #define STM32F4_ADC_CDR_DATA2(val) BSP_FLD32(val, 16, 31) // 2nd data item
311 #define STM32F4_ADC_CDR_DATA2_GET(reg) BSP_FLD32GET(reg, 16, 31)
312 #define STM32F4_ADC_CDR_DATA2_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
313 #define STM32F4_ADC_CDR_DATA1(val) BSP_FLD32(val, 0, 15) // 1st data item
314 #define STM32F4_ADC_CDR_DATA1_GET(reg) BSP_FLD32GET(reg, 0, 15)
315 #define STM32F4_ADC_CDR_DATA1_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
316
317 } __attribute__ ((packed));
318 typedef struct stm32f4_adc_com_s stm32f4_adc_com;
319
320 #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H */
Definition: stm32f4xxxx_adc.h:20
Utility macros.
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
Definition: stm32f4xxxx_adc.h:234
