RTEMS  5.1
stm32_i2c.h
1
7 /*
8  * Copyright (c) 2013 Christian Mauderer. All rights reserved.
9  *
10  * embedded brains GmbH
11  * Obere Lagerstr. 30
12  * 82178 Puchheim
13  * Germany
14  * <rtems@embedded-brains.de>
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef LIBBSP_ARM_STM32F4_STM32_I2C_H
22 #define LIBBSP_ARM_STM32F4_STM32_I2C_H
23
24 #include <bsp/utility.h>
25
33 typedef struct {
34  uint32_t cr1;
35 #define STM32F4_I2C_CR1_SWRST BSP_BIT32(15)
36 #define STM32F4_I2C_CR1_ALERT BSP_BIT32(13)
37 #define STM32F4_I2C_CR1_PEC BSP_BIT32(12)
38 #define STM32F4_I2C_CR1_POS BSP_BIT32(11)
39 #define STM32F4_I2C_CR1_ACK BSP_BIT32(10)
40 #define STM32F4_I2C_CR1_STOP BSP_BIT32(9)
41 #define STM32F4_I2C_CR1_START BSP_BIT32(8)
42 #define STM32F4_I2C_CR1_NOSTRETCH BSP_BIT32(7)
43 #define STM32F4_I2C_CR1_ENGC BSP_BIT32(6)
44 #define STM32F4_I2C_CR1_ENPEC BSP_BIT32(5)
45 #define STM32F4_I2C_CR1_ENARP BSP_BIT32(4)
46 #define STM32F4_I2C_CR1_SMBTYPE BSP_BIT32(3)
47 #define STM32F4_I2C_CR1_SMBUS BSP_BIT32(1)
48 #define STM32F4_I2C_CR1_PE BSP_BIT32(0)
49  uint32_t cr2;
50 #define STM32F4_I2C_CR2_LAST BSP_BIT32(12)
51 #define STM32F4_I2C_CR2_DMAEN BSP_BIT32(11)
52 #define STM32F4_I2C_CR2_ITBUFEN BSP_BIT32(10)
53 #define STM32F4_I2C_CR2_ITEVTEN BSP_BIT32(9)
54 #define STM32F4_I2C_CR2_ITERREN BSP_BIT32(8)
55 #define STM32F4_I2C_CR2_FREQ(val) BSP_FLD32(val, 0, 5)
56 #define STM32F4_I2C_CR2_FREQ_GET(reg) BSP_FLD32GET(reg, 0, 5)
57 #define STM32F4_I2C_CR2_FREQ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
58  uint32_t oar1;
59 #define STM32F4_I2C_OAR1_ADDMODE BSP_BIT32(15)
60 #define STM32F4_I2C_OAR1_ADD(val) BSP_FLD32(val, 0, 9)
61 #define STM32F4_I2C_OAR1_ADD_GET(reg) BSP_FLD32GET(reg, 0, 9)
62 #define STM32F4_I2C_OAR1_ADD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
63  uint32_t oar2;
64 #define STM32F4_I2C_OAR2_ADD2(val) BSP_FLD32(val, 1, 7)
65 #define STM32F4_I2C_OAR2_ADD2_GET(reg) BSP_FLD32GET(reg, 1, 7)
66 #define STM32F4_I2C_OAR2_ADD2_SET(reg, val) BSP_FLD32SET(reg, val, 1, 7)
67 #define STM32F4_I2C_OAR2_ENDUAL BSP_BIT32(0)
68  uint32_t dr;
69 #define STM32F4_I2C_DR(val) BSP_FLD32(val, 0, 7)
70 #define STM32F4_I2C_DR_GET(reg) BSP_FLD32GET(reg, 0, 7)
71 #define STM32F4_I2C_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
72  uint32_t sr1;
73 #define STM32F4_I2C_SR1_SMBALERT BSP_BIT32(15)
74 #define STM32F4_I2C_SR1_TIMEOUT BSP_BIT32(14)
75 #define STM32F4_I2C_SR1_PECERR BSP_BIT32(12)
76 #define STM32F4_I2C_SR1_OVR BSP_BIT32(11)
77 #define STM32F4_I2C_SR1_AF BSP_BIT32(10)
78 #define STM32F4_I2C_SR1_ARLO BSP_BIT32(9)
79 #define STM32F4_I2C_SR1_BERR BSP_BIT32(8)
80 #define STM32F4_I2C_SR1_TxE BSP_BIT32(7)
81 #define STM32F4_I2C_SR1_RxNE BSP_BIT32(6)
82 #define STM32F4_I2C_SR1_STOPF BSP_BIT32(4)
83 #define STM32F4_I2C_SR1_ADD10 BSP_BIT32(3)
84 #define STM32F4_I2C_SR1_BTF BSP_BIT32(2)
85 #define STM32F4_I2C_SR1_ADDR BSP_BIT32(1)
86 #define STM32F4_I2C_SR1_SB BSP_BIT32(0)
87  uint32_t sr2;
88 #define STM32F4_I2C_SR2_PEC(val) BSP_FLD32(val, 8, 15)
89 #define STM32F4_I2C_SR2_PEC_GET(reg) BSP_FLD32GET(reg, 8, 15)
90 #define STM32F4_I2C_SR2_PEC_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
91 #define STM32F4_I2C_SR2_DUALF BSP_BIT32(7)
92 #define STM32F4_I2C_SR2_SMBHOST BSP_BIT32(6)
93 #define STM32F4_I2C_SR2_SMBDEFAULT BSP_BIT32(5)
94 #define STM32F4_I2C_SR2_GENCALL BSP_BIT32(4)
95 #define STM32F4_I2C_SR2_TRA BSP_BIT32(2)
96 #define STM32F4_I2C_SR2_BUSY BSP_BIT32(1)
97 #define STM32F4_I2C_SR2_MSL BSP_BIT32(0)
98  uint32_t ccr;
99 #define STM32F4_I2C_CCR_FS BSP_BIT32(15)
100 #define STM32F4_I2C_CCR_DUTY BSP_BIT32(14)
101 #define STM32F4_I2C_CCR_CCR(val) BSP_FLD32(val, 0, 11)
102 #define STM32F4_I2C_CCR_CCR_GET(reg) BSP_FLD32GET(reg, 0, 11)
103 #define STM32F4_I2C_CCR_CCR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
104 #define STM32F4_I2C_CCR_CCR_MAX STM32F4_I2C_CCR_CCR_GET(BSP_MSK32(0, 11))
105  uint32_t trise;
106 #define STM32F4_I2C_TRISE(val) BSP_FLD32(val, 0, 5)
107 #define STM32F4_I2C_TRISE_GET(reg) BSP_FLD32GET(reg, 0, 5)
108 #define STM32F4_I2C_TRISE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
109 } stm32f4_i2c;
110
113 #endif /* LIBBSP_ARM_STM32F4_STM32_I2C_H */
Definition: stm32_i2c.h:33
Utility macros.
