RTEMS  5.1
start-config.h
1
9 /*
10  * Copyright (c) 2011-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_LPC24XX_START_CONFIG_H
24 #define LIBBSP_ARM_LPC24XX_START_CONFIG_H
25
26 #include <rtems/score/armv7m.h>
27
28 #include <bsp.h>
29 #include <bsp/io.h>
30 #include <bsp/start.h>
31 #include <bsp/lpc-emc.h>
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif /* __cplusplus */
36
40 #define LPC24XX_PS_TO_CLK(ps, f) \
41  (((((uint64_t) (ps)) * ((uint64_t) (f))) + 1000000000000ULL - 1ULL) \
42  / 1000000000000ULL)
43
47 #define LPC24XX_PS_TO_EMCCLK(ps, m) \
48  (LPC24XX_PS_TO_CLK(ps, LPC24XX_EMCCLK) > (m) ? \
49  LPC24XX_PS_TO_CLK(ps, LPC24XX_EMCCLK) - (m) : 0)
50
51 typedef struct {
52  uint32_t refresh;
53  uint32_t readconfig;
54  uint32_t trp;
55  uint32_t tras;
56  uint32_t tsrex;
57  uint32_t tapr;
58  uint32_t tdal;
59  uint32_t twr;
60  uint32_t trc;
61  uint32_t trfc;
62  uint32_t txsr;
63  uint32_t trrd;
64  uint32_t tmrd;
65  uint32_t emcdlyctl;
67
68 typedef struct {
69  volatile lpc_emc_dynamic *chip_select;
70  uint32_t address;
71  uint32_t config;
72  uint32_t rascas;
73  uint32_t mode;
75
76 typedef struct {
77  volatile lpc_emc_static *chip_select;
78  struct {
79  uint32_t config;
80  uint32_t waitwen;
81  uint32_t waitoen;
82  uint32_t waitrd;
83  uint32_t waitpage;
84  uint32_t waitwr;
85  uint32_t waitrun;
86  } config;
88
89 extern BSP_START_DATA_SECTION const lpc24xx_pin_range
90  lpc24xx_start_config_pinsel [];
91
92 extern BSP_START_DATA_SECTION const lpc24xx_emc_dynamic_config
93  lpc24xx_start_config_emc_dynamic [];
94
95 extern BSP_START_DATA_SECTION const lpc24xx_emc_dynamic_chip_config
96  lpc24xx_start_config_emc_dynamic_chip [];
97
98 extern BSP_START_DATA_SECTION const size_t
99  lpc24xx_start_config_emc_dynamic_chip_count;
100
101 extern BSP_START_DATA_SECTION const lpc24xx_emc_static_chip_config
102  lpc24xx_start_config_emc_static_chip [];
103
104 extern BSP_START_DATA_SECTION const size_t
105  lpc24xx_start_config_emc_static_chip_count;
106
107 #ifdef ARM_MULTILIB_ARCH_V7M
108
109 extern BSP_START_DATA_SECTION const ARMV7M_MPU_Region
110  lpc24xx_start_config_mpu_region [];
111
112 extern BSP_START_DATA_SECTION const size_t
113  lpc24xx_start_config_mpu_region_count;
114
115 #endif /* ARM_MULTILIB_ARCH_V7M */
116
117 #ifdef __cplusplus
118 }
119 #endif /* __cplusplus */
120
121 #endif /* LIBBSP_ARM_LPC24XX_START_CONFIG_H */
Definition: deflate.c:115
Definition: lpc-emc.h:124
ARMV7M Architecture Support.
Definition: start-config.h:51
Definition: start-config.h:68
Definition: start-config.h:76
Definition: io.h:224
Definition: lpc-emc.h:118
EMC support API.
