RTEMS  5.1
xattr.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  * Copyright © 2006 NEC Corporation
5  *
6  * Created by KaiGai Kohei <kaigai@ak.jp.nec.com>
7  *
8  * For licensing information, see the file 'LICENCE' in this directory.
9  *
10  */
11
12 #ifndef _JFFS2_FS_XATTR_H_
13 #define _JFFS2_FS_XATTR_H_
14
15 #include <linux/xattr.h>
16 #include <linux/list.h>
17
18 #define JFFS2_XFLAGS_HOT (0x01) /* This datum is HOT */
19 #define JFFS2_XFLAGS_BIND (0x02) /* This datum is not reclaimed */
20 #define JFFS2_XFLAGS_DEAD (0x40) /* This datum is already dead */
21 #define JFFS2_XFLAGS_INVALID (0x80) /* This datum contains crc error */
22
24 {
25  void *always_null;
26  struct jffs2_raw_node_ref *node;
27  uint8_t class;
28  uint8_t flags;
29  uint16_t xprefix; /* see JFFS2_XATTR_PREFIX_* */
30
31  struct list_head xindex; /* chained from c->xattrindex[n] */
32  atomic_t refcnt; /* # of xattr_ref refers this */
33  uint32_t xid;
34  uint32_t version;
35
36  uint32_t data_crc;
37  uint32_t hashkey;
38  char *xname; /* XATTR name without prefix */
39  uint32_t name_len; /* length of xname */
40  char *xvalue; /* XATTR value */
41  uint32_t value_len; /* length of xvalue */
42 };
43
44 struct jffs2_inode_cache;
46 {
47  void *always_null;
48  struct jffs2_raw_node_ref *node;
49  uint8_t class;
50  uint8_t flags; /* Currently unused */
51  u16 unused;
52
53  uint32_t xseqno;
54  union {
55  struct jffs2_inode_cache *ic; /* reference to jffs2_inode_cache */
56  uint32_t ino; /* only used in scanning/building */
57  };
58  union {
59  struct jffs2_xattr_datum *xd; /* reference to jffs2_xattr_datum */
60  uint32_t xid; /* only used in sccanning/building */
61  };
62  struct jffs2_xattr_ref *next; /* chained from ic->xref_list */
63 };
64
65 #define XREF_DELETE_MARKER (0x00000001)
66 static inline int is_xattr_ref_dead(struct jffs2_xattr_ref *ref)
67 {
68  return ((ref->xseqno & XREF_DELETE_MARKER) != 0);
69 }
70
71 #ifdef CONFIG_JFFS2_FS_XATTR
72
73 extern void jffs2_init_xattr_subsystem(struct jffs2_sb_info *c);
74 extern void jffs2_build_xattr_subsystem(struct jffs2_sb_info *c);
75 extern void jffs2_clear_xattr_subsystem(struct jffs2_sb_info *c);
76
77 extern struct jffs2_xattr_datum *jffs2_setup_xattr_datum(struct jffs2_sb_info *c,
78  uint32_t xid, uint32_t version);
79
80 extern void jffs2_xattr_do_crccheck_inode(struct jffs2_sb_info *c, struct jffs2_inode_cache *ic);
81 extern void jffs2_xattr_delete_inode(struct jffs2_sb_info *c, struct jffs2_inode_cache *ic);
82 extern void jffs2_xattr_free_inode(struct jffs2_sb_info *c, struct jffs2_inode_cache *ic);
83
84 extern int jffs2_garbage_collect_xattr_datum(struct jffs2_sb_info *c, struct jffs2_xattr_datum *xd,
85  struct jffs2_raw_node_ref *raw);
86 extern int jffs2_garbage_collect_xattr_ref(struct jffs2_sb_info *c, struct jffs2_xattr_ref *ref,
87  struct jffs2_raw_node_ref *raw);
88 extern int jffs2_verify_xattr(struct jffs2_sb_info *c);
89 extern void jffs2_release_xattr_datum(struct jffs2_sb_info *c, struct jffs2_xattr_datum *xd);
90 extern void jffs2_release_xattr_ref(struct jffs2_sb_info *c, struct jffs2_xattr_ref *ref);
91
92 extern int do_jffs2_getxattr(struct inode *inode, int xprefix, const char *xname,
93  char *buffer, size_t size);
94 extern int do_jffs2_setxattr(struct inode *inode, int xprefix, const char *xname,
95  const char *buffer, size_t size, int flags);
96
97 extern const struct xattr_handler *jffs2_xattr_handlers[];
98 extern const struct xattr_handler jffs2_user_xattr_handler;
99 extern const struct xattr_handler jffs2_trusted_xattr_handler;
100
101 extern ssize_t jffs2_listxattr(struct dentry *, char *, size_t);
102
103 #else
104
105 #define jffs2_init_xattr_subsystem(c)
106 #define jffs2_build_xattr_subsystem(c)
107 #define jffs2_clear_xattr_subsystem(c)
108
109 #define jffs2_xattr_do_crccheck_inode(c, ic)
110 #define jffs2_xattr_delete_inode(c, ic)
111 #define jffs2_xattr_free_inode(c, ic)
112 #define jffs2_verify_xattr(c) (1)
113
114 #define jffs2_xattr_handlers NULL
115 #define jffs2_listxattr NULL
116
117 #endif /* CONFIG_JFFS2_FS_XATTR */
118
119 #ifdef CONFIG_JFFS2_FS_SECURITY
120 extern int jffs2_init_security(struct inode *inode, struct inode *dir,
121  const struct qstr *qstr);
122 extern const struct xattr_handler jffs2_security_xattr_handler;
123 #else
124 #define jffs2_init_security(inode,dir,qstr) (0)
125 #endif /* CONFIG_JFFS2_FS_SECURITY */
126
127 #endif /* _JFFS2_FS_XATTR_H_ */
Definition: nodelist.h:82
Definition: xattr.h:23
Definition: nodelist.h:158
Definition: list.h:57
Definition: misc.c:34
Definition: jffs2_fs_sb.h:48
unsigned size
Definition: tte.h:74
Definition: xattr.h:45
Definition: types.h:19
