RTEMS  5.1
spidev.h
1
9 /*
10  * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _UAPI_LINUX_SPI_H
24 #define _UAPI_LINUX_SPI_H
25
26 #include <sys/ioccom.h>
27 #include <stddef.h>
28 #include <stdint.h>
29
53 #define SPI_CPHA 0x01
54
58 #define SPI_CPOL 0x02
59
64 #define SPI_MODE_0 0
65
70 #define SPI_MODE_1 SPI_CPHA
71
76 #define SPI_MODE_2 SPI_CPOL
77
82 #define SPI_MODE_3 (SPI_CPOL | SPI_CPHA)
83
88 #define SPI_CS_HIGH 0x04
89
94 #define SPI_LSB_FIRST 0x08
95
100 #define SPI_3WIRE 0x10
101
105 #define SPI_LOOP 0x20
106
111 #define SPI_NO_CS 0x40
112
116 #define SPI_READY 0x80
117
121 #define SPI_TX_DUAL 0x100
122
126 #define SPI_TX_QUAD 0x200
127
131 #define SPI_RX_DUAL 0x400
132
136 #define SPI_RX_QUAD 0x800
137
140 #define SPI_IOC_MAGIC 's'
141
149  void *rx_buf;
150
154  const void *tx_buf;
155
159  size_t len;
160
164  uint32_t speed_hz;
165
170  uint16_t delay_usecs;
171
175  uint8_t bits_per_word;
176
181  uint8_t cs_change;
182
186  uint8_t rx_nbits;
187
191  uint8_t tx_nbits;
192
197  uint32_t mode;
198
202  uint8_t cs;
203 };
204
208 #define SPI_MSGSIZE(n) \
209  (((n) * sizeof(struct spi_ioc_transfer) < IOCPARM_MAX) ? \
210  (n) * sizeof(struct spi_ioc_transfer) : 0)
211
215 #define SPI_IOC_MESSAGE(n) _IOW(SPI_IOC_MAGIC, 0, char[SPI_MSGSIZE(n)])
216
220 #define SPI_IOC_RD_MODE _IOR(SPI_IOC_MAGIC, 1, uint8_t)
221
226 #define SPI_IOC_WR_MODE _IOW(SPI_IOC_MAGIC, 1, uint8_t)
227
231 #define SPI_IOC_RD_LSB_FIRST _IOR(SPI_IOC_MAGIC, 2, uint8_t)
232
236 #define SPI_IOC_WR_LSB_FIRST _IOW(SPI_IOC_MAGIC, 2, uint8_t)
237
241 #define SPI_IOC_RD_BITS_PER_WORD _IOR(SPI_IOC_MAGIC, 3, uint8_t)
242
246 #define SPI_IOC_WR_BITS_PER_WORD _IOW(SPI_IOC_MAGIC, 3, uint8_t)
247
251 #define SPI_IOC_RD_MAX_SPEED_HZ _IOR(SPI_IOC_MAGIC, 4, uint32_t)
252
256 #define SPI_IOC_WR_MAX_SPEED_HZ _IOW(SPI_IOC_MAGIC, 4, uint32_t)
257
261 #define SPI_IOC_RD_MODE32 _IOR(SPI_IOC_MAGIC, 5, uint32_t)
262
266 #define SPI_IOC_WR_MODE32 _IOW(SPI_IOC_MAGIC, 5, uint32_t)
267
268 #endif /* _UAPI_LINUX_SPI_H */
Sets the delay after a transfer before the chip select status is changed and the next transfer is tri...
Definition: spidev.h:170
uint8_t cs
Indicates which device is currently used.
Definition: spidev.h:202
SPI transfer message.
Definition: spidev.h:145
void * rx_buf
Buffer for receive data.
Definition: spidev.h:149
const void * tx_buf
Buffer for transmit data.
Definition: spidev.h:154
uint32_t speed_hz
Sets the bit-rate of the device.
Definition: spidev.h:164
uint8_t tx_nbits
Amount of bits that are used for writing.
Definition: spidev.h:191
uint32_t mode
Sets one of the possible modes that can be used for SPI transfers (dependent on clock phase and polar...
Definition: spidev.h:197
uint8_t rx_nbits
Amount of bits that are used for reading.
Definition: spidev.h:186
size_t len
Length of receive and transmit buffers in bytes.
Definition: spidev.h:159
uint8_t cs_change
If true, device is deselected after transfer ended and before a new transfer is started.
Definition: spidev.h:181
Sets the device wordsize.
Definition: spidev.h:175
