RTEMS  5.1
smsc9218i.h
1
9 /*
10  * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #include <bsp.h>
24
30 typedef struct {
31  uint32_t rx_fifo_data;
32  uint32_t rx_fifo_data_aliases [7];
33  uint32_t tx_fifo_data;
34  uint32_t tx_fifo_data_aliases [7];
35  uint32_t rx_fifo_status;
36  uint32_t rx_fifo_status_peek;
37  uint32_t tx_fifo_status;
38  uint32_t tx_fifo_status_peek;
39  uint32_t id_rev;
40  uint32_t irq_cfg;
41  uint32_t int_sts;
42  uint32_t int_en;
43  uint32_t reserved_0;
44  uint32_t byte_test;
45  uint32_t fifo_int;
46  uint32_t rx_cfg;
47  uint32_t tx_cfg;
48  uint32_t hw_cfg;
49  uint32_t rx_dp_ctl;
50  uint32_t rx_fifo_inf;
51  uint32_t tx_fifo_inf;
52  uint32_t pmt_ctrl;
53  uint32_t gpio_cfg;
54  uint32_t gpt_cfg;
55  uint32_t gpt_cnt;
56  uint32_t reserved_1;
57  uint32_t word_swap;
58  uint32_t free_run;
59  uint32_t rx_drop;
60  uint32_t mac_csr_cmd;
61  uint32_t mac_csr_data;
62  uint32_t afc_cfg;
63  uint32_t e2p_cmd;
64  uint32_t e2p_data;
66
67 /*
68  * SMSC9218 registers are accessed little-endian (address 0x3fff8000, A22 used
69  * as END_SEL).
70  */
71 #ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
72  volatile smsc9218i_registers *const smsc9218i =
73  (volatile smsc9218i_registers *) 0x3fff8000;
74  volatile smsc9218i_registers *const smsc9218i_dma =
75  (volatile smsc9218i_registers *) 0x3fff8200;
76 #else
77  volatile smsc9218i_registers *const smsc9218i =
78  (volatile smsc9218i_registers *) 0x3fff8000;
79  volatile smsc9218i_registers *const smsc9218i_dma =
80  (volatile smsc9218i_registers *) 0x3fff8000;
81 #endif
82
85 #ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
86  #define SMSC9218I_BIT_POS(pos) (pos)
87 #else
88  #define SMSC9218I_BIT_POS(pos) \
89  ((pos) > 15 ? \
90  ((pos) > 23 ? (pos) - 24 : (pos) - 8) \
91  : ((pos) > 7 ? (pos) + 8 : (pos) + 24))
92 #endif
93
94 #define SMSC9218I_FLAG(pos) \
95  (1U << SMSC9218I_BIT_POS(pos))
96
97 #define SMSC9218I_FIELD_8(val, pos) \
98  (((val) & 0xff) << SMSC9218I_BIT_POS(pos))
99
100 #define SMSC9218I_GET_FIELD_8(reg, pos) \
101  (((reg) >> SMSC9218I_BIT_POS(pos)) & 0xff)
102
103 #define SMSC9218I_FIELD_16(val, pos) \
104  (SMSC9218I_FIELD_8((val) >> 8, (pos) + 8) \
105  | SMSC9218I_FIELD_8((val), pos))
106
107 #define SMSC9218I_GET_FIELD_16(reg, pos) \
108  ((SMSC9218I_GET_FIELD_8(reg, (pos) + 8) << 8) \
109  | SMSC9218I_GET_FIELD_8(reg, pos))
110
111 #ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
112  #define SMSC9218I_SWAP(val) (val)
113 #else
114  #define SMSC9218I_SWAP(val) \
115  ((((val) >> 24) & 0xff) \
116  | ((((val) >> 16) & 0xff) << 8) \
117  | ((((val) >> 8) & 0xff) << 16) \
118  | (((val) & 0xff) << 24))
119 #endif
120
126 #define SMSC9218I_RX_STS_FILTER_FAIL SMSC9218I_FLAG(30)
127 #define SMSC9218I_RX_STS_GET_LENGTH(reg) (SMSC9218I_GET_FIELD_16(reg, 16) & 0x3fff)
128 #define SMSC9218I_RX_STS_ERROR SMSC9218I_FLAG(15)
129 #define SMSC9218I_RX_STS_BROADCAST SMSC9218I_FLAG(13)
130 #define SMSC9218I_RX_STS_ERROR_LENGTH SMSC9218I_FLAG(12)
131 #define SMSC9218I_RX_STS_ERROR_RUNT_FRAME SMSC9218I_FLAG(11)
132 #define SMSC9218I_RX_STS_MULTICAST SMSC9218I_FLAG(10)
133 #define SMSC9218I_RX_STS_ERROR_TOO_LONG SMSC9218I_FLAG(7)
134 #define SMSC9218I_RX_STS_ERROR_COLLISION SMSC9218I_FLAG(6)
135 #define SMSC9218I_RX_STS_TYPE SMSC9218I_FLAG(5)
136 #define SMSC9218I_RX_STS_WATCHDOG SMSC9218I_FLAG(4)
137 #define SMSC9218I_RX_STS_ERROR_MII SMSC9218I_FLAG(3)
138 #define SMSC9218I_RX_STS_DRIBBLING_BIT SMSC9218I_FLAG(2)
139 #define SMSC9218I_RX_STS_ERROR_CRC SMSC9218I_FLAG(1)
140
148 #define SMSC9218I_TX_STS_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16)
149 #define SMSC9218I_TX_STS_ERROR SMSC9218I_FLAG(15)
150 #define SMSC9218I_TX_STS_ERROR_LOSS_OF_CARRIER SMSC9218I_FLAG(11)
151 #define SMSC9218I_TX_STS_ERROR_NO_CARRIER SMSC9218I_FLAG(10)
152 #define SMSC9218I_TX_STS_ERROR_LATE_COLLISION SMSC9218I_FLAG(9)
153 #define SMSC9218I_TX_STS_ERROR_EXCESSIVE_COLLISIONS SMSC9218I_FLAG(8)
154 #define SMSC9218I_TX_STS_ERROR_EXCESSIVE_DEFERRAL SMSC9218I_FLAG(2)
155 #define SMSC9218I_TX_STS_ERROR_DEFERRED SMSC9218I_FLAG(0)
156
164 #define SMSC9218I_TX_A_IOC SMSC9218I_FLAG(31)
165 #define SMSC9218I_TX_A_END_ALIGN_4 0
166 #define SMSC9218I_TX_A_END_ALIGN_16 SMSC9218I_FLAG(24)
167 #define SMSC9218I_TX_A_END_ALIGN_32 SMSC9218I_FLAG(25)
168 #define SMSC9218I_TX_A_DOFF(val) SMSC9218I_FIELD_8(val, 16)
169 #define SMSC9218I_TX_A_FIRST SMSC9218I_FLAG(13)
170 #define SMSC9218I_TX_A_LAST SMSC9218I_FLAG(12)
171 #define SMSC9218I_TX_A_FRAGMENT_LENGTH(val) SMSC9218I_FIELD_16(val, 0)
172
180 #define SMSC9218I_TX_B_TAG(val) SMSC9218I_FIELD_16(val, 16)
181 #define SMSC9218I_TX_B_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16)
182 #define SMSC9218I_TX_B_DISABLE_CRC SMSC9218I_FLAG(13)
183 #define SMSC9218I_TX_B_DISABLE_PAD SMSC9218I_FLAG(12)
184 #define SMSC9218I_TX_B_FRAME_LENGTH(val) SMSC9218I_FIELD_16(val, 0)
185
193 #define SMSC9218I_ID_REV_GET_ID(reg) SMSC9218I_GET_FIELD_16(reg, 16)
194 #define SMSC9218I_ID_REV_GET_REV(reg) SMSC9218I_GET_FIELD_16(reg, 0)
195 #define SMSC9218I_ID_REV_ID_CHIP_118 0x0118U
196 #define SMSC9218I_ID_REV_ID_CHIP_218 0x118aU
197
205 #define SMSC9218I_IRQ_CFG_INT_DEAS(val) SMSC9218I_FIELD_8(val, 24)
206 #define SMSC9218I_IRQ_CFG_GET_INT_DEAS(reg) SMSC9218I_GET_FIELD_8(reg, 24)
207 #define SMSC9218I_IRQ_CFG_INT_DEAS_CLR SMSC9218I_FLAG(14)
208 #define SMSC9218I_IRQ_CFG_INT_DEAS_STS SMSC9218I_FLAG(13)
209 #define SMSC9218I_IRQ_CFG_IRQ_INT SMSC9218I_FLAG(12)
210 #define SMSC9218I_IRQ_CFG_IRQ_EN SMSC9218I_FLAG(8)
211 #define SMSC9218I_IRQ_CFG_IRQ_POL SMSC9218I_FLAG(4)
212 #define SMSC9218I_IRQ_CFG_IRQ_TYPE SMSC9218I_FLAG(0)
213
221 #define SMSC9218I_INT_SW SMSC9218I_FLAG(31)
222 #define SMSC9218I_INT_TXSTOP SMSC9218I_FLAG(25)
223 #define SMSC9218I_INT_RXSTOP SMSC9218I_FLAG(24)
224 #define SMSC9218I_INT_RXDFH SMSC9218I_FLAG(23)
225 #define SMSC9218I_INT_TIOC SMSC9218I_FLAG(21)
226 #define SMSC9218I_INT_RXD SMSC9218I_FLAG(20)
227 #define SMSC9218I_INT_GPT SMSC9218I_FLAG(19)
228 #define SMSC9218I_INT_PHY SMSC9218I_FLAG(18)
229 #define SMSC9218I_INT_PME SMSC9218I_FLAG(17)
230 #define SMSC9218I_INT_TXSO SMSC9218I_FLAG(16)
231 #define SMSC9218I_INT_RWT SMSC9218I_FLAG(15)
232 #define SMSC9218I_INT_RXE SMSC9218I_FLAG(14)
233 #define SMSC9218I_INT_TXE SMSC9218I_FLAG(13)
234 #define SMSC9218I_INT_TDFO SMSC9218I_FLAG(10)
235 #define SMSC9218I_INT_TDFA SMSC9218I_FLAG(9)
236 #define SMSC9218I_INT_TSFF SMSC9218I_FLAG(8)
237 #define SMSC9218I_INT_TSFL SMSC9218I_FLAG(7)
238 #define SMSC9218I_INT_RSFF SMSC9218I_FLAG(4)
239 #define SMSC9218I_INT_RSFL SMSC9218I_FLAG(3)
240 #define SMSC9218I_INT_GPIO2 SMSC9218I_FLAG(2)
241 #define SMSC9218I_INT_GPIO1 SMSC9218I_FLAG(1)
242 #define SMSC9218I_INT_GPIO0 SMSC9218I_FLAG(0)
243
251 #define SMSC9218I_BYTE_TEST SMSC9218I_SWAP(0x87654321U)
252
260 #define SMSC9218I_FIFO_INT_TDAL(val) SMSC9218I_FIELD_8(val, 24)
261 #define SMSC9218I_FIFO_INT_GET_TDAL(reg) SMSC9218I_GET_FIELD_8(reg, 24)
262 #define SMSC9218I_FIFO_INT_TSL(val) SMSC9218I_FIELD_8(val, 16)
263 #define SMSC9218I_FIFO_INT_GET_TSL(reg) SMSC9218I_GET_FIELD_8(reg, 16)
264 #define SMSC9218I_FIFO_INT_RSL(val) SMSC9218I_FIELD_8(val, 0)
265 #define SMSC9218I_FIFO_INT_GET_RSL(reg) SMSC9218I_GET_FIELD_8(reg, 0)
266
274 #define SMSC9218I_RX_CFG_END_ALIGN_4 0
275 #define SMSC9218I_RX_CFG_END_ALIGN_16 SMSC9218I_FLAG(30)
276 #define SMSC9218I_RX_CFG_END_ALIGN_32 SMSC9218I_FLAG(31)
277 #define SMSC9218I_RX_CFG_DMA_CNT(val) SMSC9218I_FIELD_8(val, 24)
278 #define SMSC9218I_RX_CFG_GET_DMA_CNT(reg) SMSC9218I_GET_FIELD_8(reg, 24)
279 #define SMSC9218I_RX_CFG_DUMP SMSC9218I_FLAG(15)
280 #define SMSC9218I_RX_CFG_DOFF(val) SMSC9218I_FIELD_8(val, 8)
281 #define SMSC9218I_RX_CFG_GET_DOFF(reg) SMSC9218I_GET_FIELD_8(reg, 8)
282
290 #define SMSC9218I_TX_CFG_SDUMP SMSC9218I_FLAG(15)
291 #define SMSC9218I_TX_CFG_DDUMP SMSC9218I_FLAG(14)
292 #define SMSC9218I_TX_CFG_SAO SMSC9218I_FLAG(2)
293 #define SMSC9218I_TX_CFG_ON SMSC9218I_FLAG(1)
294 #define SMSC9218I_TX_CFG_STOP SMSC9218I_FLAG(0)
295
303 #define SMSC9218I_HW_CFG_LED_3 SMSC9218I_FLAG(30)
304 #define SMSC9218I_HW_CFG_LED_2 SMSC9218I_FLAG(29)
305 #define SMSC9218I_HW_CFG_LED_1 SMSC9218I_FLAG(28)
306 #define SMSC9218I_HW_CFG_AMDIX SMSC9218I_FLAG(24)
307 #define SMSC9218I_HW_CFG_MBO SMSC9218I_FLAG(20)
308 #define SMSC9218I_HW_CFG_TX_FIF_SZ(val) SMSC9218I_FIELD_8(val, 16)
309 #define SMSC9218I_HW_CFG_GET_TX_FIF_SZ(reg) SMSC9218I_GET_FIELD_8(reg, 16)
310 #define SMSC9218I_HW_CFG_BITMD_32 SMSC9218I_FLAG(2)
311 #define SMSC9218I_HW_CFG_SRST_TO SMSC9218I_FLAG(1)
312 #define SMSC9218I_HW_CFG_SRST SMSC9218I_FLAG(0)
313
321 #define SMSC9218I_RX_DP_CTRL_FFWD SMSC9218I_FLAG(31)
322
330 #define SMSC9218I_RX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16)
331 #define SMSC9218I_RX_FIFO_INF_GET_DUSED(reg) SMSC9218I_GET_FIELD_16(reg, 0)
332
340 #define SMSC9218I_TX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16)
341 #define SMSC9218I_TX_FIFO_INF_GET_FREE(reg) SMSC9218I_GET_FIELD_16(reg, 0)
342
350 #define SMSC9218I_PMT_CTRL_PM_MODE_D0 0
351 #define SMSC9218I_PMT_CTRL_PM_MODE_D1 SMSC9218I_FLAG(12)
352 #define SMSC9218I_PMT_CTRL_PM_MODE_D2 SMSC9218I_FLAG(13)
353 #define SMSC9218I_PMT_CTRL_PHY_RST SMSC9218I_FLAG(10)
354 #define SMSC9218I_PMT_CTRL_WOL_EN SMSC9218I_FLAG(9)
355 #define SMSC9218I_PMT_CTRL_ED_EN SMSC9218I_FLAG(8)
356 #define SMSC9218I_PMT_CTRL_PME_TYPE_PUPU SMSC9218I_FLAG(6)
357 #define SMSC9218I_PMT_CTRL_WUPS_NO 0
358 #define SMSC9218I_PMT_CTRL_WUPS_ENERGY SMSC9218I_FLAG(4)
359 #define SMSC9218I_PMT_CTRL_WUPS_MAGIC SMSC9218I_FLAG(5)
360 #define SMSC9218I_PMT_CTRL_PME_IND SMSC9218I_FLAG(3)
361 #define SMSC9218I_PMT_CTRL_PME_POL SMSC9218I_FLAG(2)
362 #define SMSC9218I_PMT_CTRL_PME_EN SMSC9218I_FLAG(1)
363 #define SMSC9218I_PMT_CTRL_READY SMSC9218I_FLAG(0)
364
372 #define SMSC9218I_GPIO_CFG_LED3 SMSC9218I_FLAG(30)
373 #define SMSC9218I_GPIO_CFG_LED2 SMSC9218I_FLAG(29)
374 #define SMSC9218I_GPIO_CFG_LED1 SMSC9218I_FLAG(28)
375 #define SMSC9218I_GPIO_CFG_GPIO2_INT_POL SMSC9218I_FLAG(26)
376 #define SMSC9218I_GPIO_CFG_GPIO1_INT_POL SMSC9218I_FLAG(25)
377 #define SMSC9218I_GPIO_CFG_GPIO0_INT_POL SMSC9218I_FLAG(24)
378 #define SMSC9218I_GPIO_CFG_GPIOBUF2 SMSC9218I_FLAG(18)
379 #define SMSC9218I_GPIO_CFG_GPIOBUF1 SMSC9218I_FLAG(17)
380 #define SMSC9218I_GPIO_CFG_GPIOBUF0 SMSC9218I_FLAG(16)
381 #define SMSC9218I_GPIO_CFG_GPIODIR2 SMSC9218I_FLAG(10)
382 #define SMSC9218I_GPIO_CFG_GPIODIR1 SMSC9218I_FLAG(9)
383 #define SMSC9218I_GPIO_CFG_GPIODIR0 SMSC9218I_FLAG(8)
384 #define SMSC9218I_GPIO_CFG_GPO4 SMSC9218I_FLAG(4)
385 #define SMSC9218I_GPIO_CFG_GPO3 SMSC9218I_FLAG(3)
386 #define SMSC9218I_GPIO_CFG_GPIO0 SMSC9218I_FLAG(0)
387 #define SMSC9218I_GPIO_CFG_GPIO2 SMSC9218I_FLAG(2)
388 #define SMSC9218I_GPIO_CFG_GPIO1 SMSC9218I_FLAG(1)
389
397 #define SMSC9218I_GPT_CFG_TIMER_EN SMSC9218I_FLAG(29)
398 #define SMSC9218I_GPT_CFG_LOAD(val) SMSC9218I_FIELD_16(val, 0)
399 #define SMSC9218I_GPT_CFG_GET_LOAD(reg) SMSC9218I_GET_FIELD_16(reg, 0)
400
408 #define SMSC9218I_GPT_CNT_GET_CNT SMSC9218I_GET_FIELD_16(reg, 0)
409
417 #define SMSC9218I_ENDIAN_BIG 0xffffffffU
418
426 #define SMSC9218I_FREE_RUN_GET(reg) SMSC9218I_SWAP(reg)
427
435 #define SMSC9218I_RX_DROP_GET(reg) SMSC9218I_SWAP(reg)
436
444 #define SMSC9218I_E2P_CMD_EPC_BUSY SMSC9218I_FLAG(31)
445
453 #define SMSC9218I_MAC_CSR_CMD_BUSY SMSC9218I_FLAG(31)
454 #define SMSC9218I_MAC_CSR_CMD_READ SMSC9218I_FLAG(30)
455 #define SMSC9218I_MAC_CSR_CMD_ADDR(val) SMSC9218I_FIELD_8(val, 0)
456 #define SMSC9218I_MAC_CSR_CMD_GET_ADDR(reg) SMSC9218I_GET_FIELD_8(reg, 0)
457
465 #define SMSC9218I_MAC_CR 0x00000001U
466 #define SMSC9218I_MAC_CR_RXALL 0x80000000U
467 #define SMSC9218I_MAC_CR_HBDIS 0x10000000U
468 #define SMSC9218I_MAC_CR_RCVOWN 0x00800000U
469 #define SMSC9218I_MAC_CR_LOOPBK 0x00200000U
470 #define SMSC9218I_MAC_CR_FDPX 0x00100000U
471 #define SMSC9218I_MAC_CR_MCPAS 0x00080000U
472 #define SMSC9218I_MAC_CR_PRMS 0x00040000U
473 #define SMSC9218I_MAC_CR_INVFILT 0x00020000U
474 #define SMSC9218I_MAC_CR_PASSBAD 0x00010000U
475 #define SMSC9218I_MAC_CR_HFILT 0x00008000U
476 #define SMSC9218I_MAC_CR_HPFILT 0x00002000U
477 #define SMSC9218I_MAC_CR_LCOLL 0x00001000U
478 #define SMSC9218I_MAC_CR_BCAST 0x00000800U
479 #define SMSC9218I_MAC_CR_DISRTY 0x00000400U
480 #define SMSC9218I_MAC_CR_PADSTR 0x00000100U
481 #define SMSC9218I_MAC_CR_BOLMT_MASK 0x000000c0U
482 #define SMSC9218I_MAC_CR_BOLMT_10 0x00000000U
483 #define SMSC9218I_MAC_CR_BOLMT_8 0x00000040U
484 #define SMSC9218I_MAC_CR_BOLMT_4 0x00000080U
485 #define SMSC9218I_MAC_CR_BOLMT_1 0x000000c0U
486 #define SMSC9218I_MAC_CR_DFCHK 0x00000020U
487 #define SMSC9218I_MAC_CR_TXEN 0x00000008U
488 #define SMSC9218I_MAC_CR_RXEN 0x00000004U
489
497 #define SMSC9218I_MAC_ADDRH 0x00000002U
498 #define SMSC9218I_MAC_ADDRH_MASK 0x0000ffffU
499
507 #define SMSC9218I_MAC_ADDRL 0x00000003U
508 #define SMSC9218I_MAC_ADDRL_MASK 0xffffffffU
509
517 #define SMSC9218I_MAC_HASHH 0x00000004U
518 #define SMSC9218I_MAC_HASHH_MASK 0xffffffffU
519
527 #define SMSC9218I_MAC_HASHL 0x00000005U
528 #define SMSC9218I_MAC_HASHL_MASK 0xffffffffU
529
537 #define SMSC9218I_MAC_MII_ACC 0x00000006U
538 #define SMSC9218I_MAC_MII_ACC_PHY_DEFAULT (1U << 11)
539 #define SMSC9218I_MAC_MII_ACC_WRITE (1U << 1)
540 #define SMSC9218I_MAC_MII_ACC_BUSY (1U << 0)
541 #define SMSC9218I_MAC_MII_ACC_ADDR(addr) ((addr) << 6)
542
550 #define SMSC9218I_MAC_MII_DATA 0x00000007U
551
559 #define SMSC9218I_MAC_FLOW 0x00000008U
560 #define SMSC9218I_MAC_FLOW_FCPT_MASK 0xffff0000U
561 #define SMSC9218I_MAC_FLOW_FCPASS 0x00000004U
562 #define SMSC9218I_MAC_FLOW_FCEN 0x00000002U
563 #define SMSC9218I_MAC_FLOW_FCBSY 0x00000001U
564
572 #define SMSC9218I_MAC_VLAN1 0x00000009U
573
581 #define SMSC9218I_MAC_VLAN2 0x0000000aU
582
590 #define SMSC9218I_MAC_WUFF 0x0000000bU
591
599 #define SMSC9218I_MAC_WUCSR 0x0000000cU
600 #define SMSC9218I_MAC_WUCSR_GUE 0x00000200U
601 #define SMSC9218I_MAC_WUCSR_WUFR 0x00000040U
602 #define SMSC9218I_MAC_WUCSR_MPR 0x00000020U
603 #define SMSC9218I_MAC_WUCSR_WUEN 0x00000004U
604 #define SMSC9218I_MAC_WUCSR_MPEN 0x00000002U
605
613 #define SMSC9218I_PHY_ID1_LAN9118 0x7
614
622 #define SMSC9218I_PHY_ID2_LAN9218 0xc0c3
623
631 #define SMSC9218I_PHY_MCSR 0x00000011U
632 #define SMSC9218I_PHY_MCSR_EDPWRDOWN 0x00002000U
633 #define SMSC9218I_PHY_MCSR_ENERGYON 0x00000002U
634
642 #define SMSC9218I_PHY_SPMODES 0x00000012U
643
651 #define SMSC9218I_PHY_CSIR 0x0000001bU
652 #define SMSC9218I_PHY_CSIR_SQEOFF 0x00000800U
653 #define SMSC9218I_PHY_CSIR_FEFIEN 0x00000020U
654 #define SMSC9218I_PHY_CSIR_XPOL 0x00000010U
655
663 #define SMSC9218I_PHY_ISR 0x0000001dU
664 #define SMSC9218I_PHY_ISR_INT7 0x00000080U
665 #define SMSC9218I_PHY_ISR_INT6 0x00000040U
666 #define SMSC9218I_PHY_ISR_INT5 0x00000020U
667 #define SMSC9218I_PHY_ISR_INT4 0x00000010U
668 #define SMSC9218I_PHY_ISR_INT3 0x00000008U
669 #define SMSC9218I_PHY_ISR_INT2 0x00000004U
670 #define SMSC9218I_PHY_ISR_INT1 0x00000002U
671
679 #define SMSC9218I_PHY_IMR 0x0000001eU
680 #define SMSC9218I_PHY_IMR_INT7 0x00000080U
681 #define SMSC9218I_PHY_IMR_INT6 0x00000040U
682 #define SMSC9218I_PHY_IMR_INT5 0x00000020U
683 #define SMSC9218I_PHY_IMR_INT4 0x00000010U
684 #define SMSC9218I_PHY_IMR_INT3 0x00000008U
685 #define SMSC9218I_PHY_IMR_INT2 0x00000004U
686 #define SMSC9218I_PHY_IMR_INT1 0x00000002U
687
695 #define SMSC9218I_PHY_PHYSCSR 0x0000001fU
696 #define SMSC9218I_PHY_PHYSCSR_ANDONE 0x00001000U
697 #define SMSC9218I_PHY_PHYSCSR_4B5B_EN 0x00000040U
698 #define SMSC9218I_PHY_PHYSCSR_SPEED_MASK 0x0000001cU
699 #define SMSC9218I_PHY_PHYSCSR_SPEED_10HD 0x00000004U
700 #define SMSC9218I_PHY_PHYSCSR_SPEED_10FD 0x00000014U
701 #define SMSC9218I_PHY_PHYSCSR_SPEED_100HD 0x00000008U
702 #define SMSC9218I_PHY_PHYSCSR_SPEED_100FD 0x00000018U
703
Definition: smsc9218i.h:30
