RTEMS  5.1
smp-imps.h
1
8 /*
9  * Author: Erich Boleyn <erich@uruk.org>
10  * http://www.uruk.org/~erich/
11  *
12  * Copyright (c) 1997-2011 Erich Boleyn. All rights reserved.
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  * 3. The name of the author may not be used to endorse or promote products
23  * derived from this software without specific prior written permission.
24  *
25  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
26  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
27  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
28  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
29  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
30  * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
31  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
32  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
33  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
34  * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
35  */
36
37 /*
38  * Header file implementing Intel MultiProcessor Specification (MPS)
39  * version 1.1 and 1.4 SMP hardware control for Intel Architecture CPUs,
40  * with hooks for running correctly on a standard PC without the hardware.
41  *
42  * This file was created from information in the Intel MPS version 1.4
43  * document, order number 242016-004, which can be ordered from the
44  * Intel literature center.
45  */
46
47 /*
48  * This file is based upon code by Eric Boleyn as documented above.
49  * RTEMS support was added and minimal other changes were made.
50  * This should make it easier to compare this file with the original
51  * version.
52  *
53  * COPYRIGHT (c) 2011.
54  * On-Line Applications Research Corporation (OAR).
55  *
56  * The license and distribution terms for this file may be
57  * found in the file LICENSE in this distribution or at
58  * http://www.rtems.org/license/LICENSE.
59  */
60
70 #ifndef _SMP_IMPS_H
71 #define _SMP_IMPS_H
72
73 /* make sure "apic.h" is included */
74 #ifndef _APIC_H
75 #error Must include "apic.h" before "smp-imps.h"
76 #endif /* !_APIC_H */
77
78 /*
79  * Defines used.
80  */
81
82 #define IMPS_READ(x) (*((volatile unsigned *) (x)))
83 #define IMPS_WRITE(x,y) (*((volatile unsigned *) (x)) = (y))
84
85 #ifdef IMPS_DEBUG
86 #define IMPS_DEBUG_PRINT(x) KERNEL_PRINT(x)
87 #else /* !IMPS_DEBUG */
88 #define IMPS_DEBUG_PRINT(x)
89 #endif /* !IMPS_DEBUG */
90
91 #define IMPS_MAX_CPUS APIC_BCAST_ID
92
97 #define IMPS_FPS_SIGNATURE ('_' | ('M'<<8) | ('P'<<16) | ('_'<<24))
98 #define IMPS_FPS_IMCRP_BIT 0x80
99 #define IMPS_FPS_DEFAULT_MAX 7
100
105 #define IMPS_CTH_SIGNATURE ('P' | ('C'<<8) | ('M'<<16) | ('P'<<24))
106
110 #define IMPS_FLAG_ENABLED 1
111 #define IMPS_BCT_PROCESSOR 0
112 #define IMPS_CPUFLAG_BOOT 2
113 #define IMPS_BCT_BUS 1
114 #define IMPS_BCT_IOAPIC 2
115 #define IMPS_BCT_IO_INTERRUPT 3
116 #define IMPS_BCT_LOCAL_INTERRUPT 4
117 #define IMPS_INT_INT 0
118 #define IMPS_INT_NMI 1
119 #define IMPS_INT_SMI 2
120 #define IMPS_INT_EXTINT 3
121
122
123 /*
124  * Typedefs and data item definitions done here.
125  */
126
127 typedef struct imps_fps imps_fps;
128 typedef struct imps_cth imps_cth;
129 typedef struct imps_processor imps_processor;
130 typedef struct imps_bus imps_bus;
131 typedef struct imps_ioapic imps_ioapic;
132 typedef struct imps_interrupt imps_interrupt;
133
134
135 /*
136  * Data structures defined here
137  */
138
145 struct imps_fps
146 {
147  unsigned sig;
148  imps_cth *cth_ptr;
149  unsigned char length;
150  unsigned char spec_rev;
151  unsigned char checksum;
152  unsigned char feature_info[5];
153 };
154
161 struct imps_cth
162 {
163  unsigned sig;
164  unsigned short base_length;
165  unsigned char spec_rev;
166  unsigned char checksum;
167  char oem_id[8];
168  char prod_id[12];
169  unsigned oem_table_ptr;
170  unsigned short oem_table_size;
171  unsigned short entry_count;
172  unsigned lapic_addr;
173  unsigned short extended_length;
174  unsigned char extended_checksum;
175  char reserved[1];
176 };
177
185 {
186  unsigned char type;
187  unsigned char apic_id;
188  unsigned char apic_ver;
189  unsigned char flags;
190  unsigned signature;
191  unsigned features;
192  char reserved[8];
193 };
194
195 struct imps_bus
196 {
197  unsigned char type;
198  unsigned char id;
199  char bus_type[6];
200 };
201
203 {
204  unsigned char type;
205  unsigned char id;
206  unsigned char ver;
207  unsigned char flags;
208  unsigned addr;
209 };
210
212 {
213  unsigned char type;
214  unsigned char int_type;
215  unsigned short flags;
216  unsigned char source_bus_id;
217  unsigned char source_bus_irq;
218  unsigned char dest_apic_id;
219  unsigned char dest_apic_intin;
220 };
221
222 /*
223  * Exported globals here.
224  */
225
229 extern unsigned char imps_cpu_apic_map[IMPS_MAX_CPUS];
230 extern unsigned char imps_apic_cpu_map[IMPS_MAX_CPUS];
231
233 extern char _binary_appstart_bin_start[];
234 extern char _binary_appstart_bin_size[];
235
237 extern unsigned imps_lapic_addr;
238
239 /*
240  * Defines that use variables
241  */
242 #define IMPS_LAPIC_READ(x) (*((volatile unsigned *) (imps_lapic_addr+(x))))
243 #define IMPS_LAPIC_WRITE(x, y) \
244  (*((volatile unsigned *) (imps_lapic_addr+(x))) = (y))
245
246 #endif /* !_SMP_IMPS_H */
247
Definition: smp-imps.h:211
unsigned char type
must be 0
Definition: smp-imps.h:186
Definition: nislib.h:49
unsigned char type
must be 1
Definition: smp-imps.h:197
Definition: smp-imps.h:202
Base MP Configuration Table Types. They are sorted according to type (i.e. all of type 0 come first,...
Definition: smp-imps.h:184
MP Floating Pointer Structure (fps)
Definition: smp-imps.h:145
MP Configuration Table Header (cth)
Definition: smp-imps.h:161
base address of the local apic. Usually 0xFEE00000
Definition: smp-imps.c:202
These map from virtual cpu numbers to APIC id's and back.
Definition: smp-imps.c:198
base address of application processor reset code at 0x70000
Definition: smp-imps.h:195
unsigned char type
must be 2
Definition: smp-imps.h:204
unsigned char type
must be 3 or 4
Definition: smp-imps.h:213
