RTEMS  5.1
smc91111config.h
1 #ifndef _SMC91111_CONFIG_H_
2 #define _SMC91111_CONFIG_H_
3
4 /*
5  * RTEMS event used by interrupt handler to signal driver tasks.
6  * This must not be any of the events used by the network task synchronization.
7  */
8 #define INTERRUPT_EVENT RTEMS_EVENT_1
9
10 /*
11  * RTEMS event used to start transmit daemon.
12  * This must not be the same as INTERRUPT_EVENT.
13  */
14 #define START_TRANSMIT_EVENT RTEMS_EVENT_2
15
16  /* event to send when tx buffers become available */
17 #define SMC91111_TX_WAIT_EVENT RTEMS_EVENT_3
18
19
20 /* Number of OCs supported by this driver*/
21 #define NOCDRIVER 1
22
23 /* Receive buffer size -- Allow for a full ethernet packet including CRC */
24 #define RBUF_SIZE 1536
25
26 #define ET_MINLEN 64 /* minimum message length */
27
28 #if (MCLBYTES < RBUF_SIZE)
29 # error "Driver must have MCLBYTES > RBUF_SIZE"
30 #endif
31
32 /* ----------------- cygdriver params ----------------- */
33
34 #define LAN91CXX_32BIT_RX
35 #define LAN91CXX_IS_LAN91C111
36
37 /* ----------------- compat layer ----------------- */
38
39 #include <stdint.h>
40
41 typedef uint32_t CYG_WORD;
42 typedef uint8_t CYG_BYTE;
43 typedef uint16_t CYG_WORD16;
44 typedef uint32_t CYG_WORD32;
45
46 #ifndef CYG_SWAP16
47 # define CYG_SWAP16(_x_) \
48  ({ uint16_t _x = (_x_); ((_x << 8) | (_x >> 8)); })
49 #endif
50
51 #ifndef CYG_SWAP32
52 # define CYG_SWAP32(_x_) \
53  ({ uint32_t _x = (_x_); \
54  ((_x << 24) | \
55  ((0x0000FF00UL & _x) << 8) | \
56  ((0x00FF0000UL & _x) >> 8) | \
57  (_x >> 24)); })
58 #endif
59
60 # define CYG_CPU_TO_BE16(_x_) (_x_)
61 # define CYG_CPU_TO_BE32(_x_) (_x_)
62 # define CYG_BE16_TO_CPU(_x_) (_x_)
63 # define CYG_BE32_TO_CPU(_x_) (_x_)
64
65 # define CYG_CPU_TO_LE16(_x_) CYG_SWAP16((_x_))
66 # define CYG_CPU_TO_LE32(_x_) CYG_SWAP32((_x_))
67 # define CYG_LE16_TO_CPU(_x_) CYG_SWAP16((_x_))
68 # define CYG_LE32_TO_CPU(_x_) CYG_SWAP32((_x_))
69
70 #define CYG_MACRO_START do {
71 #define CYG_MACRO_END } while (0)
72 #define HAL_IO_BARRIER() \
73  __asm__ volatile ( "" : : : "memory" )
74
75 #define HAL_READ_UINT8( _register_, _value_ ) \
76  CYG_MACRO_START \
77  ((_value_) = *((volatile CYG_BYTE *)(_register_))); \
78  HAL_IO_BARRIER (); \
79  CYG_MACRO_END
80
81 #define HAL_WRITE_UINT8( _register_, _value_ ) \
82  CYG_MACRO_START \
83  (*((volatile CYG_BYTE *)(_register_)) = (_value_)); \
84  HAL_IO_BARRIER (); \
85  CYG_MACRO_END
86
87 #define HAL_READ_UINT16( _register_, _value_ ) \
88  CYG_MACRO_START \
89  ((_value_) = *((volatile CYG_WORD16 *)(_register_))); \
90  HAL_IO_BARRIER (); \
91  CYG_MACRO_END
92
93 #define HAL_WRITE_UINT16( _register_, _value_ ) \
94  CYG_MACRO_START \
95  (*((volatile CYG_WORD16 *)(_register_)) = (_value_)); \
96  HAL_IO_BARRIER (); \
97  CYG_MACRO_END
98
99 #define HAL_READ_UINT32( _register_, _value_ ) \
100  CYG_MACRO_START \
101  ((_value_) = *((volatile CYG_WORD32 *)(_register_))); \
102  HAL_IO_BARRIER (); \
103  CYG_MACRO_END
104
105 #define HAL_READ_UINT16( _register_, _value_ ) \
106  CYG_MACRO_START \
107  ((_value_) = *((volatile CYG_WORD16 *)(_register_))); \
108  HAL_IO_BARRIER (); \
109  CYG_MACRO_END
110
111 #define CYG_ASSERT(c,p) do { if (!(c)) { while(1) { printf(p);} }; } while(0)
112
113 #define HAL_DELAY_US(p) rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (p))
114
115
116 #endif /* _SMC_91111_CONFIG_H_ */
117
118
