RTEMS  5.1
sdramc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
36 // ---------------------------------------------------------------------------
37 // SDRAM
38 // ---------------------------------------------------------------------------
40 #define EBI_SDRAMC_ADDR (0x70000000u)
41
43 #define BOARD_SDRAM_BUSWIDTH 16
44
45
46 typedef struct _SSdramc_config {
47  uint32_t dwColumnBits; // Number of Column Bits
48  uint32_t dwRowBits; // Number of Row Bits
49  uint32_t dwBanks; // Number of Banks
50  uint32_t dwCAS; // CAS Latency
51  uint32_t dwDataBusWidth; // Data Bus Width
52  uint32_t dwWriteRecoveryDelay; // Write Recovery Delay
53  uint32_t dwRowCycleDelay_RowRefreshCycle; // Row Cycle Delay and Row Refresh Cycle
54  uint32_t dwRowPrechargeDelay; // Row Precharge Delay
55  uint32_t dwRowColumnDelay; // Row to Column Delay
56  uint32_t dwActivePrechargeDelay; // Active to Precharge Delay
57  uint32_t dwExitSelfRefreshActiveDelay; // Exit Self Refresh to Active Delay
58  uint32_t dwBK1; // bk1 addr
59
61
62 typedef struct _SSdramc_Memory {
63  SSdramc_config cfg;
64
66
67 extern void SDRAMC_Configure(SSdramc_Memory *pMemory,
68  uint32_t dwClockFrequency);
Definition: sdramc.h:62
void SDRAMC_Configure(SSdramc_Memory *pMemory, uint32_t dwClockFrequency)
Configure and initialize the SDRAM controller.
Definition: sdramc.c:106
Definition: sdramc.h:46
