RTEMS  5.1
satcan.h
1 /*
2  * Header file for RTEMS SATCAN FPGA driver
3  *
4  * COPYRIGHT (c) 2009.
5  * Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __SATCAN_H__
13 #define __SATCAN_H__
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 /* Config structure passed to SatCAN_init(..) */
20 typedef struct {
21  /* Configuration */
22  int nodeno;
23  int dps;
24  /* Callback functions */
25  void (*ahb_irq_callback)(void);
26  void (*pps_irq_callback)(void);
27  void (*m5_irq_callback)(void);
28  void (*m4_irq_callback)(void);
29  void (*m3_irq_callback)(void);
30  void (*m2_irq_callback)(void);
31  void (*m1_irq_callback)(void);
32  void (*sync_irq_callback)(void);
33  void (*can_irq_callback)(unsigned int fifo);
35
36 #define SATCAN_HEADER_SIZE 4
37 #define SATCAN_HEADER_NMM_POS 3
38 #define SATCAN_PAYLOAD_SIZE 8
39
40 /* SatCAN message */
41 typedef struct {
42  unsigned char header[SATCAN_HEADER_SIZE]; /* Header of SatCAN message */
43  unsigned char payload[SATCAN_PAYLOAD_SIZE]; /* Payload of SatCAN message */
44 } satcan_msg;
45
46 /* SatCAN modify register structure */
47 typedef struct {
48  unsigned int reg;
49  unsigned int val;
51
52 /* Driver interface */
53 int satcan_register(satcan_config *conf);
54
55 /* SatCAN interrupt IDs */
56 #define SATCAN_IRQ_NONACT_TO_ACT 0
57 #define SATCAN_IRQ_ACTIVE_TO_NONACT 1
58 #define SATCAN_IRQ_STR1_TO_DPS 2
59 #define SATCAN_IRQ_DPS_TO_STR1 3
60 #define SATCAN_IRQ_STR2_TO_DPS 4
61 #define SATCAN_IRQ_DPS_TO_STR2 5
62 #define SATCAN_IRQ_STR3_TO_DPS 6
63 #define SATCAN_IRQ_DPS_TO_STR3 7
64 #define SATCAN_IRQ_PLD1_TO_DPS 8
65 #define SATCAN_IRQ_DPS_TO_PLD1 9
66 #define SATCAN_IRQ_PLD2_TO_DPS 10
67 #define SATCAN_IRQ_DPS_TO_PLD2 11
68 #define SATCAN_IRQ_SYNC 16
69 #define SATCAN_IRQ_TIME_MARKER1 17
70 #define SATCAN_IRQ_TIME_MARKER2 18
71 #define SATCAN_IRQ_TIME_MARKER3 19
72 #define SATCAN_IRQ_TIME_MARKER4 20
73 #define SATCAN_IRQ_TIME_MARKER5 21
74 #define SATCAN_IRQ_EOD1 22
75 #define SATCAN_IRQ_EOD2 23
76 #define SATCAN_IRQ_TOD 24
77 #define SATCAN_IRQ_CRITICAL 25
78
79 /* IOC */
80 #define SATCAN_IOC_DMA_2K 1 /* Use DMA area for 2K messages */
81 #define SATCAN_IOC_DMA_8K 2 /* Use DMA area for 8K messages */
82 #define SATCAN_IOC_GET_REG 3 /* Provides direct read access to all core registers */
83 #define SATCAN_IOC_SET_REG 4 /* Provides direct write access to all core registers */
84 #define SATCAN_IOC_OR_REG 5 /* Provides direct read access to all core registers */
85 #define SATCAN_IOC_AND_REG 6 /* Provides direct write access to all core registers */
86 #define SATCAN_IOC_EN_TX1_DIS_TX2 7 /* Enable DMA TX channel 1, Disable DMA TX channel 2 */
87 #define SATCAN_IOC_EN_TX2_DIS_TX1 8 /* Enable DMA TX channel 2, Disable DMA TX channel 1 */
88 #define SATCAN_IOC_GET_DMA_MODE 9 /* Returns the current DMA mode */
89 #define SATCAN_IOC_SET_DMA_MODE 10 /* Sets the DMA mode */
90 #define SATCAN_IOC_ACTIVATE_DMA 11 /* Directly activate DMA channel */
91 #define SATCAN_IOC_DEACTIVATE_DMA 12 /* Directly deactivate DMA channel */
92 #define SATCAN_IOC_DMA_STATUS 13 /* Returns status of directly activated DMA */
93 #define SATCAN_IOC_GET_DOFFSET 14 /* Get TX DMA offset */
94 #define SATCAN_IOC_SET_DOFFSET 15 /* Set TX DMA offset */
95 #define SATCAN_IOC_GET_TIMEOUT 16 /* Set TX DMA timeout */
96 #define SATCAN_IOC_SET_TIMEOUT 17 /* Get TX DMA timeout */
97
98
99 /* Values used to select core register with IOC_SET_REG/IOC_GET_REG */
100 #define SATCAN_SWRES 0 /* Software reset */
101 #define SATCAN_INT_EN 1 /* Interrupt enable */
102 #define SATCAN_FIFO 3 /* FIFO read */
103 #define SATCAN_FIFO_RES 4 /* FIFO reset */
104 #define SATCAN_TSTAMP 5 /* Current time stamp */
105 #define SATCAN_CMD0 6 /* Command register 0 */
106 #define SATCAN_CMD1 7 /* Command register 1 */
107 #define SATCAN_START_CTC 8 /* Start cycle time counter */
108 #define SATCAN_RAM_BASE 9 /* RAM offset address */
109 #define SATCAN_STOP_CTC 10 /* Stop cycle time counter / DPS active status */
110 #define SATCAN_DPS_ACT 10 /* Stop cycle time counter / DPS active status */
111 #define SATCAN_PLL_RST 11 /* DPLL reset */
112 #define SATCAN_PLL_CMD 12 /* DPLL command */
113 #define SATCAN_PLL_STAT 13 /* DPLL status */
114 #define SATCAN_PLL_OFF 14 /* DPLL offset */
115 #define SATCAN_DMA 15 /* DMA channel enable */
116 #define SATCAN_DMA_TX_1_CUR 16 /* DMA channel 1 TX current address */
117 #define SATCAN_DMA_TX_1_END 17 /* DMA channel 1 TX end address */
118 #define SATCAN_DMA_TX_2_CUR 18 /* DMA channel 2 TX current address */
119 #define SATCAN_DMA_TX_2_END 19 /* DMA channel 2 TX end address */
120 #define SATCAN_RX 20 /* CAN RX enable / Filter start ID */
121 #define SATCAN_FILTER_START 20 /* CAN RX enable / Filter start ID */
122 #define SATCAN_FILTER_SETUP 21 /* Filter setup / Filter stop ID */
123 #define SATCAN_FILTER_STOP 21 /* Filter setup / Filter stop ID */
124 #define SATCAN_WCTRL 32 /* Wrapper status/control register */
125 #define SATCAN_WIPEND 33 /* Wrapper interrupt pending register */
126 #define SATCAN_WIMASK 34 /* Wrapper interrupt mask register */
127 #define SATCAN_WAHBADDR 35 /* Wrapper AHB address register */
128
129
130 /* Values used to communicate DMA mode */
131 #define SATCAN_DMA_MODE_USER 0
132 #define SATCAN_DMA_MODE_SYSTEM 1
133
134 /* Values used to directly activate DMA channel */
135 #define SATCAN_DMA_ENABLE_TX1 1
136 #define SATCAN_DMA_ENABLE_TX2 2
137
138 #ifdef __cplusplus
139 }
140 #endif
141
142 #endif /* __SATCAN_H__ */
Definition: satcan.h:20
Definition: satcan.h:41
Definition: satcan.h:47
