RTEMS  5.1
component_trng.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMV71_TRNG_COMPONENT_
31 #define _SAMV71_TRNG_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t TRNG_CR;
43  __I uint32_t Reserved1[3];
44  __O uint32_t TRNG_IER;
45  __O uint32_t TRNG_IDR;
46  __I uint32_t TRNG_IMR;
47  __I uint32_t TRNG_ISR;
48  __I uint32_t Reserved2[12];
49  __I uint32_t TRNG_ODATA;
50  __I uint32_t Reserved3[42];
51  __I uint32_t TRNG_VERSION;
52 } Trng;
53 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
54 /* -------- TRNG_CR : (TRNG Offset: 0x00) Control Register -------- */
55 #define TRNG_CR_ENABLE (0x1u << 0)
56 #define TRNG_CR_KEY_Pos 8
57 #define TRNG_CR_KEY_Msk (0xffffffu << TRNG_CR_KEY_Pos)
58 #define TRNG_CR_KEY(value) ((TRNG_CR_KEY_Msk & ((value) << TRNG_CR_KEY_Pos)))
59 #define TRNG_CR_KEY_PASSWD (0x524E47u << 8)
60 /* -------- TRNG_IER : (TRNG Offset: 0x10) Interrupt Enable Register -------- */
61 #define TRNG_IER_DATRDY (0x1u << 0)
62 /* -------- TRNG_IDR : (TRNG Offset: 0x14) Interrupt Disable Register -------- */
63 #define TRNG_IDR_DATRDY (0x1u << 0)
64 /* -------- TRNG_IMR : (TRNG Offset: 0x18) Interrupt Mask Register -------- */
65 #define TRNG_IMR_DATRDY (0x1u << 0)
66 /* -------- TRNG_ISR : (TRNG Offset: 0x1C) Interrupt Status Register -------- */
67 #define TRNG_ISR_DATRDY (0x1u << 0)
68 /* -------- TRNG_ODATA : (TRNG Offset: 0x50) Output Data Register -------- */
69 #define TRNG_ODATA_ODATA_Pos 0
70 #define TRNG_ODATA_ODATA_Msk (0xffffffffu << TRNG_ODATA_ODATA_Pos)
71 /* -------- TRNG_VERSION : (TRNG Offset: 0xFC) Version Register -------- */
72 #define TRNG_VERSION_VERSION_Pos 0
73 #define TRNG_VERSION_VERSION_Msk (0xfffu << TRNG_VERSION_VERSION_Pos)
74 #define TRNG_VERSION_MFN_Pos 16
75 #define TRNG_VERSION_MFN_Msk (0x7u << TRNG_VERSION_MFN_Pos)
78
79
80 #endif /* _SAMV71_TRNG_COMPONENT_ */
#define __O
Definition: core_cm7.h:286
Trng hardware registers.
Definition: component_trng.h:41
(Trng Offset: 0xFC) Version Register
Definition: component_trng.h:51
#define __I
Definition: core_cm7.h:284
