RTEMS  5.1
sams70q21.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70Q21_
31 #define _SAMS70Q21_
32
41
42 #ifdef __cplusplus
43  extern "C" {
44 #endif
45
46 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
47 #include <stdint.h>
48 #endif
49
50 /* ************************************************************************** */
51 /* CMSIS DEFINITIONS FOR SAMS70Q21 */
52 /* ************************************************************************** */
55
57 typedef enum IRQn
58 {
59 /****** Cortex-M7 Processor Exceptions Numbers ******************************/
63  BusFault_IRQn = -11,
65  SVCall_IRQn = -5,
67  PendSV_IRQn = -2,
68  SysTick_IRQn = -1,
69 /****** SAMS70Q21 specific Interrupt Numbers *********************************/
70
71  SUPC_IRQn = 0,
72  RSTC_IRQn = 1,
73  RTC_IRQn = 2,
74  RTT_IRQn = 3,
75  WDT_IRQn = 4,
76  PMC_IRQn = 5,
77  EFC_IRQn = 6,
78  UART0_IRQn = 7,
79  UART1_IRQn = 8,
80  PIOA_IRQn = 10,
81  PIOB_IRQn = 11,
82  PIOC_IRQn = 12,
83  USART0_IRQn = 13,
84  USART1_IRQn = 14,
85  USART2_IRQn = 15,
86  PIOD_IRQn = 16,
87  PIOE_IRQn = 17,
88  HSMCI_IRQn = 18,
89  TWIHS0_IRQn = 19,
90  TWIHS1_IRQn = 20,
91  SPI0_IRQn = 21,
92  SSC_IRQn = 22,
93  TC0_IRQn = 23,
94  TC1_IRQn = 24,
95  TC2_IRQn = 25,
96  TC3_IRQn = 26,
97  TC4_IRQn = 27,
98  TC5_IRQn = 28,
99  AFEC0_IRQn = 29,
100  DACC_IRQn = 30,
101  PWM0_IRQn = 31,
102  ICM_IRQn = 32,
103  ACC_IRQn = 33,
104  USBHS_IRQn = 34,
105  AFEC1_IRQn = 40,
106  TWIHS2_IRQn = 41,
107  SPI1_IRQn = 42,
108  QSPI_IRQn = 43,
109  UART2_IRQn = 44,
110  UART3_IRQn = 45,
111  UART4_IRQn = 46,
112  TC6_IRQn = 47,
113  TC7_IRQn = 48,
114  TC8_IRQn = 49,
115  TC9_IRQn = 50,
116  TC10_IRQn = 51,
117  TC11_IRQn = 52,
118  AES_IRQn = 56,
119  TRNG_IRQn = 57,
120  XDMAC_IRQn = 58,
121  ISI_IRQn = 59,
122  PWM1_IRQn = 60,
123  SDRAMC_IRQn = 62,
124  RSWDT_IRQn = 63,
127 } IRQn_Type;
128
129 typedef struct _DeviceVectors
130 {
131  /* Stack pointer */
132  void* pvStack;
133
134  /* Cortex-M handlers */
135  void* pfnReset_Handler;
136  void* pfnNMI_Handler;
137  void* pfnHardFault_Handler;
138  void* pfnMemManage_Handler;
139  void* pfnBusFault_Handler;
140  void* pfnUsageFault_Handler;
141  void* pfnReserved1_Handler;
142  void* pfnReserved2_Handler;
143  void* pfnReserved3_Handler;
144  void* pfnReserved4_Handler;
145  void* pfnSVC_Handler;
146  void* pfnDebugMon_Handler;
147  void* pfnReserved5_Handler;
148  void* pfnPendSV_Handler;
149  void* pfnSysTick_Handler;
150
151  /* Peripheral handlers */
152  void* pfnSUPC_Handler; /* 0 Supply Controller */
153  void* pfnRSTC_Handler; /* 1 Reset Controller */
154  void* pfnRTC_Handler; /* 2 Real Time Clock */
155  void* pfnRTT_Handler; /* 3 Real Time Timer */
156  void* pfnWDT_Handler; /* 4 Watchdog Timer */
157  void* pfnPMC_Handler; /* 5 Power Management Controller */
158  void* pfnEFC_Handler; /* 6 Enhanced Embedded Flash Controller */
159  void* pfnUART0_Handler; /* 7 UART 0 */
160  void* pfnUART1_Handler; /* 8 UART 1 */
161  void* pvReserved9;
162  void* pfnPIOA_Handler; /* 10 Parallel I/O Controller A */
163  void* pfnPIOB_Handler; /* 11 Parallel I/O Controller B */
164  void* pfnPIOC_Handler; /* 12 Parallel I/O Controller C */
165  void* pfnUSART0_Handler; /* 13 USART 0 */
166  void* pfnUSART1_Handler; /* 14 USART 1 */
167  void* pfnUSART2_Handler; /* 15 USART 2 */
168  void* pfnPIOD_Handler; /* 16 Parallel I/O Controller D */
169  void* pfnPIOE_Handler; /* 17 Parallel I/O Controller E */
170  void* pfnHSMCI_Handler; /* 18 Multimedia Card Interface */
171  void* pfnTWIHS0_Handler; /* 19 Two Wire Interface 0 HS */
172  void* pfnTWIHS1_Handler; /* 20 Two Wire Interface 1 HS */
173  void* pfnSPI0_Handler; /* 21 Serial Peripheral Interface 0 */
174  void* pfnSSC_Handler; /* 22 Synchronous Serial Controller */
175  void* pfnTC0_Handler; /* 23 Timer/Counter 0 */
176  void* pfnTC1_Handler; /* 24 Timer/Counter 1 */
177  void* pfnTC2_Handler; /* 25 Timer/Counter 2 */
178  void* pfnTC3_Handler; /* 26 Timer/Counter 3 */
179  void* pfnTC4_Handler; /* 27 Timer/Counter 4 */
180  void* pfnTC5_Handler; /* 28 Timer/Counter 5 */
181  void* pfnAFEC0_Handler; /* 29 Analog Front End 0 */
182  void* pfnDACC_Handler; /* 30 Digital To Analog Converter */
183  void* pfnPWM0_Handler; /* 31 Pulse Width Modulation 0 */
184  void* pfnICM_Handler; /* 32 Integrity Check Monitor */
185  void* pfnACC_Handler; /* 33 Analog Comparator */
186  void* pfnUSBHS_Handler; /* 34 USB Host / Device Controller */
187  void* pvReserved35;
188  void* pvReserved36;
189  void* pvReserved37;
190  void* pvReserved38;
191  void* pvReserved39;
192  void* pfnAFEC1_Handler; /* 40 Analog Front End 1 */
193  void* pfnTWIHS2_Handler; /* 41 Two Wire Interface 2 HS */
194  void* pfnSPI1_Handler; /* 42 Serial Peripheral Interface 1 */
195  void* pfnQSPI_Handler; /* 43 Quad I/O Serial Peripheral Interface */
196  void* pfnUART2_Handler; /* 44 UART 2 */
197  void* pfnUART3_Handler; /* 45 UART 3 */
198  void* pfnUART4_Handler; /* 46 UART 4 */
199  void* pfnTC6_Handler; /* 47 Timer/Counter 6 */
200  void* pfnTC7_Handler; /* 48 Timer/Counter 7 */
201  void* pfnTC8_Handler; /* 49 Timer/Counter 8 */
202  void* pfnTC9_Handler; /* 50 Timer/Counter 9 */
203  void* pfnTC10_Handler; /* 51 Timer/Counter 10 */
204  void* pfnTC11_Handler; /* 52 Timer/Counter 11 */
205  void* pvReserved53;
206  void* pvReserved54;
207  void* pvReserved55;
208  void* pfnAES_Handler; /* 56 AES */
209  void* pfnTRNG_Handler; /* 57 True Random Generator */
210  void* pfnXDMAC_Handler; /* 58 DMA */
211  void* pfnISI_Handler; /* 59 Camera Interface */
212  void* pfnPWM1_Handler; /* 60 Pulse Width Modulation 1 */
213  void* pvReserved61;
214  void* pfnSDRAMC_Handler; /* 62 SDRAM Controller */
215  void* pfnRSWDT_Handler; /* 63 Reinforced Secure Watchdog Timer */
216 } DeviceVectors;
217
218 /* Cortex-M7 core handlers */
219 void Reset_Handler ( void );
220 void NMI_Handler ( void );
221 void HardFault_Handler ( void );
222 void MemManage_Handler ( void );
223 void BusFault_Handler ( void );
224 void UsageFault_Handler ( void );
225 void SVC_Handler ( void );
226 void DebugMon_Handler ( void );
227 void PendSV_Handler ( void );
228 void SysTick_Handler ( void );
229
230 /* Peripherals handlers */
231 void ACC_Handler ( void );
232 void AES_Handler ( void );
233 void AFEC0_Handler ( void );
234 void AFEC1_Handler ( void );
235 void DACC_Handler ( void );
236 void EFC_Handler ( void );
237 void HSMCI_Handler ( void );
238 void ICM_Handler ( void );
239 void ISI_Handler ( void );
240 void PIOA_Handler ( void );
241 void PIOB_Handler ( void );
242 void PIOC_Handler ( void );
243 void PIOD_Handler ( void );
244 void PIOE_Handler ( void );
245 void PMC_Handler ( void );
246 void PWM0_Handler ( void );
247 void PWM1_Handler ( void );
248 void QSPI_Handler ( void );
249 void RSTC_Handler ( void );
250 void RSWDT_Handler ( void );
251 void RTC_Handler ( void );
252 void RTT_Handler ( void );
253 void SDRAMC_Handler ( void );
254 void SPI0_Handler ( void );
255 void SPI1_Handler ( void );
256 void SSC_Handler ( void );
257 void SUPC_Handler ( void );
258 void TC0_Handler ( void );
259 void TC1_Handler ( void );
260 void TC2_Handler ( void );
261 void TC3_Handler ( void );
262 void TC4_Handler ( void );
263 void TC5_Handler ( void );
264 void TC6_Handler ( void );
265 void TC7_Handler ( void );
266 void TC8_Handler ( void );
267 void TC9_Handler ( void );
268 void TC10_Handler ( void );
269 void TC11_Handler ( void );
270 void TRNG_Handler ( void );
271 void TWIHS0_Handler ( void );
272 void TWIHS1_Handler ( void );
273 void TWIHS2_Handler ( void );
274 void UART0_Handler ( void );
275 void UART1_Handler ( void );
276 void UART2_Handler ( void );
277 void UART3_Handler ( void );
278 void UART4_Handler ( void );
279 void USART0_Handler ( void );
280 void USART1_Handler ( void );
281 void USART2_Handler ( void );
282 void USBHS_Handler ( void );
283 void WDT_Handler ( void );
284 void XDMAC_Handler ( void );
285
290 #define __CM7_REV 0x0000
291 #define __MPU_PRESENT 1
292 #define __NVIC_PRIO_BITS 3
293 #define __FPU_PRESENT 1
294 #define __FPU_DP 1
295 #define __ICACHE_PRESENT 1
296 #define __DCACHE_PRESENT 1
297 #define __DTCM_PRESENT 1
298 #define __ITCM_PRESENT 1
299 #define __Vendor_SysTickConfig 0
301 /*
302  * \brief CMSIS includes
303  */
304
305 #include <core_cm7.h>
306 #if !defined DONT_USE_CMSIS_INIT
307 #include "system_sams70.h"
308 #endif /* DONT_USE_CMSIS_INIT */
309
312 /* ************************************************************************** */
314 /* ************************************************************************** */
317
318 #include "component/component_acc.h"
319 #include "component/component_aes.h"
320 #include "component/component_afec.h"
321 #include "component/component_chipid.h"
322 #include "component/component_dacc.h"
323 #include "component/component_efc.h"
324 #include "component/component_gpbr.h"
325 #include "component/component_hsmci.h"
326 #include "component/component_icm.h"
327 #include "component/component_isi.h"
328 #include "component/component_matrix.h"
329 #include "component/component_pio.h"
330 #include "component/component_pmc.h"
331 #include "component/component_pwm.h"
332 #include "component/component_qspi.h"
333 #include "component/component_rstc.h"
334 #include "component/component_rswdt.h"
335 #include "component/component_rtc.h"
336 #include "component/component_rtt.h"
337 #include "component/component_sdramc.h"
338 #include "component/component_smc.h"
339 #include "component/component_spi.h"
340 #include "component/component_ssc.h"
341 #include "component/component_supc.h"
342 #include "component/component_tc.h"
343 #include "component/component_trng.h"
344 #include "component/component_twihs.h"
345 #include "component/component_uart.h"
346 #include "component/component_usart.h"
347 #include "component/component_usbhs.h"
348 #include "component/component_utmi.h"
349 #include "component/component_wdt.h"
350 #include "component/component_xdmac.h"
353 #ifndef __rtems__
354 /* ************************************************************************** */
355 /* REGISTER ACCESS DEFINITIONS FOR SAMS70Q21 */
356 /* ************************************************************************** */
359
360 #include "instance/instance_hsmci.h"
361 #include "instance/instance_ssc.h"
362 #include "instance/instance_spi0.h"
363 #include "instance/instance_tc0.h"
364 #include "instance/instance_tc1.h"
365 #include "instance/instance_tc2.h"
366 #include "instance/instance_twihs0.h"
367 #include "instance/instance_twihs1.h"
368 #include "instance/instance_pwm0.h"
369 #include "instance/instance_usart0.h"
370 #include "instance/instance_usart1.h"
371 #include "instance/instance_usart2.h"
372 #include "instance/instance_usbhs.h"
373 #include "instance/instance_afec0.h"
374 #include "instance/instance_dacc.h"
375 #include "instance/instance_acc.h"
376 #include "instance/instance_icm.h"
377 #include "instance/instance_isi.h"
378 #include "instance/instance_tc3.h"
379 #include "instance/instance_spi1.h"
380 #include "instance/instance_pwm1.h"
381 #include "instance/instance_twihs2.h"
382 #include "instance/instance_afec1.h"
383 #include "instance/instance_aes.h"
384 #include "instance/instance_trng.h"
385 #include "instance/instance_xdmac.h"
386 #include "instance/instance_qspi.h"
387 #include "instance/instance_smc.h"
388 #include "instance/instance_sdramc.h"
389 #include "instance/instance_matrix.h"
390 #include "instance/instance_utmi.h"
391 #include "instance/instance_pmc.h"
392 #include "instance/instance_uart0.h"
393 #include "instance/instance_chipid.h"
394 #include "instance/instance_uart1.h"
395 #include "instance/instance_efc.h"
396 #include "instance/instance_pioa.h"
397 #include "instance/instance_piob.h"
398 #include "instance/instance_pioc.h"
399 #include "instance/instance_piod.h"
400 #include "instance/instance_pioe.h"
401 #include "instance/instance_rstc.h"
402 #include "instance/instance_supc.h"
403 #include "instance/instance_rtt.h"
404 #include "instance/instance_wdt.h"
405 #include "instance/instance_rtc.h"
406 #include "instance/instance_gpbr.h"
407 #include "instance/instance_rswdt.h"
408 #include "instance/instance_uart2.h"
409 #include "instance/instance_uart3.h"
410 #include "instance/instance_uart4.h"
412 #endif /* __rtems__ */
413
414 /* ************************************************************************** */
415 /* PERIPHERAL ID DEFINITIONS FOR SAMS70Q21 */
416 /* ************************************************************************** */
419
420 #define ID_SUPC ( 0)
421 #define ID_RSTC ( 1)
422 #define ID_RTC ( 2)
423 #define ID_RTT ( 3)
424 #define ID_WDT ( 4)
425 #define ID_PMC ( 5)
426 #define ID_EFC ( 6)
427 #define ID_UART0 ( 7)
428 #define ID_UART1 ( 8)
429 #define ID_SMC ( 9)
430 #define ID_PIOA (10)
431 #define ID_PIOB (11)
432 #define ID_PIOC (12)
433 #define ID_USART0 (13)
434 #define ID_USART1 (14)
435 #define ID_USART2 (15)
436 #define ID_PIOD (16)
437 #define ID_PIOE (17)
438 #define ID_HSMCI (18)
439 #define ID_TWIHS0 (19)
440 #define ID_TWIHS1 (20)
441 #define ID_SPI0 (21)
442 #define ID_SSC (22)
443 #define ID_TC0 (23)
444 #define ID_TC1 (24)
445 #define ID_TC2 (25)
446 #define ID_TC3 (26)
447 #define ID_TC4 (27)
448 #define ID_TC5 (28)
449 #define ID_AFEC0 (29)
450 #define ID_DACC (30)
451 #define ID_PWM0 (31)
452 #define ID_ICM (32)
453 #define ID_ACC (33)
454 #define ID_USBHS (34)
455 #define ID_AFEC1 (40)
456 #define ID_TWIHS2 (41)
457 #define ID_SPI1 (42)
458 #define ID_QSPI (43)
459 #define ID_UART2 (44)
460 #define ID_UART3 (45)
461 #define ID_UART4 (46)
462 #define ID_TC6 (47)
463 #define ID_TC7 (48)
464 #define ID_TC8 (49)
465 #define ID_TC9 (50)
466 #define ID_TC10 (51)
467 #define ID_TC11 (52)
468 #define ID_AES (56)
469 #define ID_TRNG (57)
470 #define ID_XDMAC (58)
471 #define ID_ISI (59)
472 #define ID_PWM1 (60)
473 #define ID_SDRAMC (62)
474 #define ID_RSWDT (63)
476 #define ID_PERIPH_COUNT (64)
478
479 /* ************************************************************************** */
480 /* BASE ADDRESS DEFINITIONS FOR SAMS70Q21 */
481 /* ************************************************************************** */
484
485 #if (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
486 #define HSMCI (0x40000000U)
487 #define SSC (0x40004000U)
488 #define SPI0 (0x40008000U)
489 #define TC0 (0x4000C000U)
490 #define TC1 (0x40010000U)
491 #define TC2 (0x40014000U)
492 #define TWIHS0 (0x40018000U)
493 #define TWIHS1 (0x4001C000U)
494 #define PWM0 (0x40020000U)
495 #define USART0 (0x40024000U)
496 #define USART1 (0x40028000U)
497 #define USART2 (0x4002C000U)
498 #define USBHS (0x40038000U)
499 #define AFEC0 (0x4003C000U)
500 #define DACC (0x40040000U)
501 #define ACC (0x40044000U)
502 #define ICM (0x40048000U)
503 #define ISI (0x4004C000U)
504 #define TC3 (0x40054000U)
505 #define SPI1 (0x40058000U)
506 #define PWM1 (0x4005C000U)
507 #define TWIHS2 (0x40060000U)
508 #define AFEC1 (0x40064000U)
509 #define AES (0x4006C000U)
510 #define TRNG (0x40070000U)
511 #define XDMAC (0x40078000U)
512 #define QSPI (0x4007C000U)
513 #define SMC (0x40080000U)
514 #define SDRAMC (0x40084000U)
515 #define MATRIX (0x40088000U)
516 #define UTMI (0x400E0400U)
517 #define PMC (0x400E0600U)
518 #define UART0 (0x400E0800U)
519 #define CHIPID (0x400E0940U)
520 #define UART1 (0x400E0A00U)
521 #define EFC (0x400E0C00U)
522 #define PIOA (0x400E0E00U)
523 #define PIOB (0x400E1000U)
524 #define PIOC (0x400E1200U)
525 #define PIOD (0x400E1400U)
526 #define PIOE (0x400E1600U)
527 #define RSTC (0x400E1800U)
528 #define SUPC (0x400E1810U)
529 #define RTT (0x400E1830U)
530 #define WDT (0x400E1850U)
531 #define RTC (0x400E1860U)
532 #define GPBR (0x400E1890U)
533 #define RSWDT (0x400E1900U)
534 #define UART2 (0x400E1A00U)
535 #define UART3 (0x400E1C00U)
536 #define UART4 (0x400E1E00U)
537 #else
538 #define HSMCI ((Hsmci *)0x40000000U)
539 #define SSC ((Ssc *)0x40004000U)
540 #define SPI0 ((Spi *)0x40008000U)
541 #define TC0 ((Tc *)0x4000C000U)
542 #define TC1 ((Tc *)0x40010000U)
543 #define TC2 ((Tc *)0x40014000U)
544 #define TWIHS0 ((Twihs *)0x40018000U)
545 #define TWIHS1 ((Twihs *)0x4001C000U)
546 #define PWM0 ((Pwm *)0x40020000U)
547 #define USART0 ((Usart *)0x40024000U)
548 #define USART1 ((Usart *)0x40028000U)
549 #define USART2 ((Usart *)0x4002C000U)
550 #define USBHS ((Usbhs *)0x40038000U)
551 #define AFEC0 ((Afec *)0x4003C000U)
552 #define DACC ((Dacc *)0x40040000U)
553 #define ACC ((Acc *)0x40044000U)
554 #define ICM ((Icm *)0x40048000U)
555 #define ISI ((Isi *)0x4004C000U)
556 #define TC3 ((Tc *)0x40054000U)
557 #define SPI1 ((Spi *)0x40058000U)
558 #define PWM1 ((Pwm *)0x4005C000U)
559 #define TWIHS2 ((Twihs *)0x40060000U)
560 #define AFEC1 ((Afec *)0x40064000U)
561 #define AES ((Aes *)0x4006C000U)
562 #define TRNG ((Trng *)0x40070000U)
563 #define XDMAC ((Xdmac *)0x40078000U)
564 #define QSPI ((Qspi *)0x4007C000U)
565 #define SMC ((Smc *)0x40080000U)
566 #define SDRAMC ((Sdramc *)0x40084000U)
567 #define MATRIX ((Matrix *)0x40088000U)
568 #define UTMI ((Utmi *)0x400E0400U)
569 #define PMC ((Pmc *)0x400E0600U)
570 #define UART0 ((Uart *)0x400E0800U)
571 #define CHIPID ((Chipid *)0x400E0940U)
572 #define UART1 ((Uart *)0x400E0A00U)
573 #define EFC ((Efc *)0x400E0C00U)
574 #define PIOA ((Pio *)0x400E0E00U)
575 #define PIOB ((Pio *)0x400E1000U)
576 #define PIOC ((Pio *)0x400E1200U)
577 #define PIOD ((Pio *)0x400E1400U)
578 #define PIOE ((Pio *)0x400E1600U)
579 #define RSTC ((Rstc *)0x400E1800U)
580 #define SUPC ((Supc *)0x400E1810U)
581 #define RTT ((Rtt *)0x400E1830U)
582 #define WDT ((Wdt *)0x400E1850U)
583 #define RTC ((Rtc *)0x400E1860U)
584 #define GPBR ((Gpbr *)0x400E1890U)
585 #define RSWDT ((Rswdt *)0x400E1900U)
586 #define UART2 ((Uart *)0x400E1A00U)
587 #define UART3 ((Uart *)0x400E1C00U)
588 #define UART4 ((Uart *)0x400E1E00U)
589 #endif /* (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
590
592 /* ************************************************************************** */
593 /* PIO DEFINITIONS FOR SAMS70Q21 */
594 /* ************************************************************************** */
597
598 #include "pio/pio_sams70q21.h"
601 /* ************************************************************************** */
602 /* MEMORY MAPPING DEFINITIONS FOR SAMS70Q21 */
603 /* ************************************************************************** */
604
605 #define IFLASH_SIZE (0x200000u)
606 #define IFLASH_PAGE_SIZE (512u)
607 #define IFLASH_LOCK_REGION_SIZE (8192u)
608 #define IFLASH_NB_OF_PAGES (4096u)
609 #define IFLASH_NB_OF_LOCK_BITS (128u)
610 #define IRAM_SIZE (0x60000u)
611
612 #define QSPIMEM_ADDR (0x80000000u)
613 #define AXIMX_ADDR (0xA0000000u)
614 #define ITCM_ADDR (0x00000000u)
615 #define IFLASH_ADDR (0x00400000u)
616 #define IROM_ADDR (0x00800000u)
617 #define DTCM_ADDR (0x20000000u)
618 #define IRAM_ADDR (0x20400000u)
619 #define EBI_CS0_ADDR (0x60000000u)
620 #define EBI_CS1_ADDR (0x61000000u)
621 #define EBI_CS2_ADDR (0x62000000u)
622 #define EBI_CS3_ADDR (0x63000000u)
623 #define SDRAM_CS_ADDR (0x70000000u)
625 /* ************************************************************************** */
626 /* MISCELLANEOUS DEFINITIONS FOR SAMS70Q21 */
627 /* ************************************************************************** */
628
629 #define CHIP_JTAGID (0x05B3D03FUL)
630 #define CHIP_CIDR (0xA1120E00UL)
631 #define CHIP_EXID (0x00000002UL)
632
633 /* ************************************************************************** */
634 /* ELECTRICAL DEFINITIONS FOR SAMS70Q21 */
635 /* ************************************************************************** */
636
637 /* %ATMEL_ELECTRICAL% */
638
639 /* Device characteristics */
640 #define CHIP_FREQ_SLCK_RC_MIN (20000UL)
641 #define CHIP_FREQ_SLCK_RC (32000UL)
642 #define CHIP_FREQ_SLCK_RC_MAX (44000UL)
643 #define CHIP_FREQ_MAINCK_RC_4MHZ (4000000UL)
644 #define CHIP_FREQ_MAINCK_RC_8MHZ (8000000UL)
645 #define CHIP_FREQ_MAINCK_RC_12MHZ (12000000UL)
646 #define CHIP_FREQ_CPU_MAX (120000000UL)
647 #define CHIP_FREQ_XTAL_32K (32768UL)
648 #define CHIP_FREQ_XTAL_12M (12000000UL)
649
650 /* Embedded Flash Read Wait State (VDDCORE set at 1.20V) */
651 #define CHIP_FREQ_FWS_0 (20000000UL)
652 #define CHIP_FREQ_FWS_1 (40000000UL)
653 #define CHIP_FREQ_FWS_2 (60000000UL)
654 #define CHIP_FREQ_FWS_3 (80000000UL)
655 #define CHIP_FREQ_FWS_4 (100000000UL)
656 #define CHIP_FREQ_FWS_5 (123000000UL)
658 #ifdef __cplusplus
659 }
660 #endif
661
664 #endif /* _SAMS70Q21_ */
Definition: sams70q21.h:83
Definition: sams70q21.h:114
Definition: sams70q21.h:78
Definition: sams70q21.h:94
Definition: sams70q21.h:74
Definition: sams70q21.h:90
Definition: sams70q21.h:68
Definition: sams70q21.h:95
void BusFault_Handler(void)
Default BusFault interrupt handler.
Definition: exceptions.c:193
Definition: sams70q21.h:92
Definition: sams70q21.h:121
void NMI_Handler(void)
Default NMI interrupt handler.
Definition: exceptions.c:53
Definition: sams70q21.h:65
Definition: sams70q21.h:107
Definition: sams70q21.h:80
Definition: sams70q21.h:102
void MemManage_Handler(void)
Default MemManage interrupt handler.
Definition: exceptions.c:180
Definition: sams70q21.h:86
Definition: sams70q21.h:116
Definition: sams70q21.h:82
Definition: sams70q21.h:96
Definition: sams70q21.h:117
Definition: sams70q21.h:97
Definition: sams70q21.h:91
void UsageFault_Handler(void)
Default UsageFault interrupt handler.
Definition: exceptions.c:207
Definition: sams70q21.h:126
Definition: sams70q21.h:109
Definition: sams70q21.h:110
Definition: sams70q21.h:72
Definition: sams70q21.h:76
Definition: sams70q21.h:71
Definition: sams70q21.h:87
Definition: sams70q21.h:113
CMSIS Cortex-M7 Core Peripheral Access Layer Header File.
Definition: sams70q21.h:66
Definition: sams70q21.h:123
Definition: sams70q21.h:61
enum IRQn IRQn_Type
Definition: sams70q21.h:106
Definition: same70j19.h:121
Definition: sams70q21.h:73
Definition: sams70q21.h:85
Definition: sams70q21.h:111
Definition: sams70q21.h:77
Definition: sams70q21.h:120
Definition: sams70q21.h:84
Definition: sams70q21.h:100
Definition: sams70q21.h:119
Definition: sams70q21.h:62
Definition: sams70q21.h:67
Definition: sams70q21.h:60
Definition: sams70q21.h:122
Definition: sams70q21.h:105
Definition: sams70q21.h:63
IRQn
Definition: same70j19.h:57
Definition: sams70q21.h:98
Definition: sams70q21.h:89
Definition: sams70q21.h:103
void HardFault_Handler(void)
Default HardFault interrupt handler.
Definition: exceptions.c:168
Definition: sams70q21.h:104
Definition: sams70q21.h:115
Definition: sams70q21.h:101
Definition: sams70q21.h:64
Definition: sams70q21.h:81
Definition: sams70q21.h:108
Definition: sams70q21.h:118
Definition: sams70q21.h:93
Definition: sams70q21.h:99
Definition: sams70q21.h:88
Definition: sams70q21.h:79
Definition: sams70q21.h:112
Definition: sams70q21.h:75
Definition: sams70q21.h:124
