RTEMS  5.1
component_wdt.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_WDT_COMPONENT_
31 #define _SAMS70_WDT_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t WDT_CR;
43  __IO uint32_t WDT_MR;
44  __I uint32_t WDT_SR;
45 } Wdt;
46 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
47 /* -------- WDT_CR : (WDT Offset: 0x00) Control Register -------- */
48 #define WDT_CR_WDRSTT (0x1u << 0)
49 #define WDT_CR_KEY_Pos 24
50 #define WDT_CR_KEY_Msk (0xffu << WDT_CR_KEY_Pos)
51 #define WDT_CR_KEY(value) ((WDT_CR_KEY_Msk & ((value) << WDT_CR_KEY_Pos)))
52 #define WDT_CR_KEY_PASSWD (0xA5u << 24)
53 /* -------- WDT_MR : (WDT Offset: 0x04) Mode Register -------- */
54 #define WDT_MR_WDV_Pos 0
55 #define WDT_MR_WDV_Msk (0xfffu << WDT_MR_WDV_Pos)
56 #define WDT_MR_WDV(value) ((WDT_MR_WDV_Msk & ((value) << WDT_MR_WDV_Pos)))
57 #define WDT_MR_WDFIEN (0x1u << 12)
58 #define WDT_MR_WDRSTEN (0x1u << 13)
59 #define WDT_MR_WDDIS (0x1u << 15)
60 #define WDT_MR_WDD_Pos 16
61 #define WDT_MR_WDD_Msk (0xfffu << WDT_MR_WDD_Pos)
62 #define WDT_MR_WDD(value) ((WDT_MR_WDD_Msk & ((value) << WDT_MR_WDD_Pos)))
63 #define WDT_MR_WDDBGHLT (0x1u << 28)
64 #define WDT_MR_WDIDLEHLT (0x1u << 29)
65 /* -------- WDT_SR : (WDT Offset: 0x08) Status Register -------- */
66 #define WDT_SR_WDUNF (0x1u << 0)
67 #define WDT_SR_WDERR (0x1u << 1)
70
71
72 #endif /* _SAMS70_WDT_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Wdt hardware registers.
Definition: component_wdt.h:41
#define __I
Definition: core_cm7.h:284
