RTEMS  5.1
component_pwm.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_PWM_COMPONENT_
31 #define _SAMS70_PWM_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t PWM_CMR;
43  __IO uint32_t PWM_CDTY;
44  __O uint32_t PWM_CDTYUPD;
45  __IO uint32_t PWM_CPRD;
46  __O uint32_t PWM_CPRDUPD;
47  __I uint32_t PWM_CCNT;
48  __IO uint32_t PWM_DT;
49  __O uint32_t PWM_DTUPD;
50 } PwmCh_num;
52 #define PWMCH_NUM_NUMBER 4
53 typedef struct {
54  __IO uint32_t PWM_CLK;
55  __O uint32_t PWM_ENA;
56  __O uint32_t PWM_DIS;
57  __I uint32_t PWM_SR;
58  __O uint32_t PWM_IER1;
59  __O uint32_t PWM_IDR1;
60  __I uint32_t PWM_IMR1;
61  __I uint32_t PWM_ISR1;
62  __IO uint32_t PWM_SCM;
63  __O uint32_t PWM_DMAR;
64  __IO uint32_t PWM_SCUC;
65  __IO uint32_t PWM_SCUP;
66  __O uint32_t PWM_SCUPUPD;
67  __O uint32_t PWM_IER2;
68  __O uint32_t PWM_IDR2;
69  __I uint32_t PWM_IMR2;
70  __I uint32_t PWM_ISR2;
71  __IO uint32_t PWM_OOV;
72  __IO uint32_t PWM_OS;
73  __O uint32_t PWM_OSS;
74  __O uint32_t PWM_OSC;
75  __O uint32_t PWM_OSSUPD;
76  __O uint32_t PWM_OSCUPD;
77  __IO uint32_t PWM_FMR;
78  __I uint32_t PWM_FSR;
79  __O uint32_t PWM_FCR;
80  __IO uint32_t PWM_FPV1;
81  __IO uint32_t PWM_FPE;
82  __I uint32_t Reserved1[3];
83  __IO uint32_t PWM_ELMR[2];
84  __I uint32_t Reserved2[7];
85  __IO uint32_t PWM_SSPR;
86  __O uint32_t PWM_SSPUP;
87  __I uint32_t Reserved3[2];
88  __IO uint32_t PWM_SMMR;
89  __I uint32_t Reserved4[3];
90  __IO uint32_t PWM_FPV2;
91  __I uint32_t Reserved5[8];
92  __O uint32_t PWM_WPCR;
93  __I uint32_t PWM_WPSR;
94  __I uint32_t Reserved6[17];
95  __IO uint32_t PWM_CMPV0;
96  __O uint32_t PWM_CMPVUPD0;
97  __IO uint32_t PWM_CMPM0;
98  __O uint32_t PWM_CMPMUPD0;
99  __IO uint32_t PWM_CMPV1;
100  __O uint32_t PWM_CMPVUPD1;
101  __IO uint32_t PWM_CMPM1;
102  __O uint32_t PWM_CMPMUPD1;
103  __IO uint32_t PWM_CMPV2;
104  __O uint32_t PWM_CMPVUPD2;
105  __IO uint32_t PWM_CMPM2;
106  __O uint32_t PWM_CMPMUPD2;
107  __IO uint32_t PWM_CMPV3;
108  __O uint32_t PWM_CMPVUPD3;
109  __IO uint32_t PWM_CMPM3;
110  __O uint32_t PWM_CMPMUPD3;
111  __IO uint32_t PWM_CMPV4;
112  __O uint32_t PWM_CMPVUPD4;
113  __IO uint32_t PWM_CMPM4;
114  __O uint32_t PWM_CMPMUPD4;
115  __IO uint32_t PWM_CMPV5;
116  __O uint32_t PWM_CMPVUPD5;
117  __IO uint32_t PWM_CMPM5;
118  __O uint32_t PWM_CMPMUPD5;
119  __IO uint32_t PWM_CMPV6;
120  __O uint32_t PWM_CMPVUPD6;
121  __IO uint32_t PWM_CMPM6;
122  __O uint32_t PWM_CMPMUPD6;
123  __IO uint32_t PWM_CMPV7;
124  __O uint32_t PWM_CMPVUPD7;
125  __IO uint32_t PWM_CMPM7;
126  __O uint32_t PWM_CMPMUPD7;
127  __I uint32_t Reserved7[20];
128  PwmCh_num PWM_CH_NUM[PWMCH_NUM_NUMBER];
129  __I uint32_t Reserved8[96];
130  __O uint32_t PWM_CMUPD0;
131  __I uint32_t Reserved9[7];
132  __O uint32_t PWM_CMUPD1;
133  __I uint32_t Reserved10[2];
134  __IO uint32_t PWM_ETRG1;
135  __IO uint32_t PWM_LEBR1;
136  __I uint32_t Reserved11[3];
137  __O uint32_t PWM_CMUPD2;
138  __I uint32_t Reserved12[2];
139  __IO uint32_t PWM_ETRG2;
140  __IO uint32_t PWM_LEBR2;
141  __I uint32_t Reserved13[3];
142  __O uint32_t PWM_CMUPD3;
143 } Pwm;
144 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
145 /* -------- PWM_CLK : (PWM Offset: 0x00) PWM Clock Register -------- */
146 #define PWM_CLK_DIVA_Pos 0
147 #define PWM_CLK_DIVA_Msk (0xffu << PWM_CLK_DIVA_Pos)
148 #define PWM_CLK_DIVA(value) ((PWM_CLK_DIVA_Msk & ((value) << PWM_CLK_DIVA_Pos)))
149 #define PWM_CLK_DIVA_CLKA_POFF (0x0u << 0)
150 #define PWM_CLK_DIVA_PREA (0x1u << 0)
151 #define PWM_CLK_PREA_Pos 8
152 #define PWM_CLK_PREA_Msk (0xfu << PWM_CLK_PREA_Pos)
153 #define PWM_CLK_PREA(value) ((PWM_CLK_PREA_Msk & ((value) << PWM_CLK_PREA_Pos)))
154 #define PWM_CLK_PREA_CLK (0x0u << 8)
155 #define PWM_CLK_PREA_CLK_DIV2 (0x1u << 8)
156 #define PWM_CLK_PREA_CLK_DIV4 (0x2u << 8)
157 #define PWM_CLK_PREA_CLK_DIV8 (0x3u << 8)
158 #define PWM_CLK_PREA_CLK_DIV16 (0x4u << 8)
159 #define PWM_CLK_PREA_CLK_DIV32 (0x5u << 8)
160 #define PWM_CLK_PREA_CLK_DIV64 (0x6u << 8)
161 #define PWM_CLK_PREA_CLK_DIV128 (0x7u << 8)
162 #define PWM_CLK_PREA_CLK_DIV256 (0x8u << 8)
163 #define PWM_CLK_PREA_CLK_DIV512 (0x9u << 8)
164 #define PWM_CLK_PREA_CLK_DIV1024 (0xAu << 8)
165 #define PWM_CLK_DIVB_Pos 16
166 #define PWM_CLK_DIVB_Msk (0xffu << PWM_CLK_DIVB_Pos)
167 #define PWM_CLK_DIVB(value) ((PWM_CLK_DIVB_Msk & ((value) << PWM_CLK_DIVB_Pos)))
168 #define PWM_CLK_DIVB_CLKB_POFF (0x0u << 16)
169 #define PWM_CLK_DIVB_PREB (0x1u << 16)
170 #define PWM_CLK_PREB_Pos 24
171 #define PWM_CLK_PREB_Msk (0xfu << PWM_CLK_PREB_Pos)
172 #define PWM_CLK_PREB(value) ((PWM_CLK_PREB_Msk & ((value) << PWM_CLK_PREB_Pos)))
173 #define PWM_CLK_PREB_CLK (0x0u << 24)
174 #define PWM_CLK_PREB_CLK_DIV2 (0x1u << 24)
175 #define PWM_CLK_PREB_CLK_DIV4 (0x2u << 24)
176 #define PWM_CLK_PREB_CLK_DIV8 (0x3u << 24)
177 #define PWM_CLK_PREB_CLK_DIV16 (0x4u << 24)
178 #define PWM_CLK_PREB_CLK_DIV32 (0x5u << 24)
179 #define PWM_CLK_PREB_CLK_DIV64 (0x6u << 24)
180 #define PWM_CLK_PREB_CLK_DIV128 (0x7u << 24)
181 #define PWM_CLK_PREB_CLK_DIV256 (0x8u << 24)
182 #define PWM_CLK_PREB_CLK_DIV512 (0x9u << 24)
183 #define PWM_CLK_PREB_CLK_DIV1024 (0xAu << 24)
184 /* -------- PWM_ENA : (PWM Offset: 0x04) PWM Enable Register -------- */
185 #define PWM_ENA_CHID0 (0x1u << 0)
186 #define PWM_ENA_CHID1 (0x1u << 1)
187 #define PWM_ENA_CHID2 (0x1u << 2)
188 #define PWM_ENA_CHID3 (0x1u << 3)
189 /* -------- PWM_DIS : (PWM Offset: 0x08) PWM Disable Register -------- */
190 #define PWM_DIS_CHID0 (0x1u << 0)
191 #define PWM_DIS_CHID1 (0x1u << 1)
192 #define PWM_DIS_CHID2 (0x1u << 2)
193 #define PWM_DIS_CHID3 (0x1u << 3)
194 /* -------- PWM_SR : (PWM Offset: 0x0C) PWM Status Register -------- */
195 #define PWM_SR_CHID0 (0x1u << 0)
196 #define PWM_SR_CHID1 (0x1u << 1)
197 #define PWM_SR_CHID2 (0x1u << 2)
198 #define PWM_SR_CHID3 (0x1u << 3)
199 /* -------- PWM_IER1 : (PWM Offset: 0x10) PWM Interrupt Enable Register 1 -------- */
200 #define PWM_IER1_CHID0 (0x1u << 0)
201 #define PWM_IER1_CHID1 (0x1u << 1)
202 #define PWM_IER1_CHID2 (0x1u << 2)
203 #define PWM_IER1_CHID3 (0x1u << 3)
204 #define PWM_IER1_FCHID0 (0x1u << 16)
205 #define PWM_IER1_FCHID1 (0x1u << 17)
206 #define PWM_IER1_FCHID2 (0x1u << 18)
207 #define PWM_IER1_FCHID3 (0x1u << 19)
208 /* -------- PWM_IDR1 : (PWM Offset: 0x14) PWM Interrupt Disable Register 1 -------- */
209 #define PWM_IDR1_CHID0 (0x1u << 0)
210 #define PWM_IDR1_CHID1 (0x1u << 1)
211 #define PWM_IDR1_CHID2 (0x1u << 2)
212 #define PWM_IDR1_CHID3 (0x1u << 3)
213 #define PWM_IDR1_FCHID0 (0x1u << 16)
214 #define PWM_IDR1_FCHID1 (0x1u << 17)
215 #define PWM_IDR1_FCHID2 (0x1u << 18)
216 #define PWM_IDR1_FCHID3 (0x1u << 19)
217 /* -------- PWM_IMR1 : (PWM Offset: 0x18) PWM Interrupt Mask Register 1 -------- */
218 #define PWM_IMR1_CHID0 (0x1u << 0)
219 #define PWM_IMR1_CHID1 (0x1u << 1)
220 #define PWM_IMR1_CHID2 (0x1u << 2)
221 #define PWM_IMR1_CHID3 (0x1u << 3)
222 #define PWM_IMR1_FCHID0 (0x1u << 16)
223 #define PWM_IMR1_FCHID1 (0x1u << 17)
224 #define PWM_IMR1_FCHID2 (0x1u << 18)
225 #define PWM_IMR1_FCHID3 (0x1u << 19)
226 /* -------- PWM_ISR1 : (PWM Offset: 0x1C) PWM Interrupt Status Register 1 -------- */
227 #define PWM_ISR1_CHID0 (0x1u << 0)
228 #define PWM_ISR1_CHID1 (0x1u << 1)
229 #define PWM_ISR1_CHID2 (0x1u << 2)
230 #define PWM_ISR1_CHID3 (0x1u << 3)
231 #define PWM_ISR1_FCHID0 (0x1u << 16)
232 #define PWM_ISR1_FCHID1 (0x1u << 17)
233 #define PWM_ISR1_FCHID2 (0x1u << 18)
234 #define PWM_ISR1_FCHID3 (0x1u << 19)
235 /* -------- PWM_SCM : (PWM Offset: 0x20) PWM Sync Channels Mode Register -------- */
236 #define PWM_SCM_SYNC0 (0x1u << 0)
237 #define PWM_SCM_SYNC1 (0x1u << 1)
238 #define PWM_SCM_SYNC2 (0x1u << 2)
239 #define PWM_SCM_SYNC3 (0x1u << 3)
240 #define PWM_SCM_UPDM_Pos 16
241 #define PWM_SCM_UPDM_Msk (0x3u << PWM_SCM_UPDM_Pos)
242 #define PWM_SCM_UPDM(value) ((PWM_SCM_UPDM_Msk & ((value) << PWM_SCM_UPDM_Pos)))
243 #define PWM_SCM_UPDM_MODE0 (0x0u << 16)
244 #define PWM_SCM_UPDM_MODE1 (0x1u << 16)
245 #define PWM_SCM_UPDM_MODE2 (0x2u << 16)
246 #define PWM_SCM_PTRM (0x1u << 20)
247 #define PWM_SCM_PTRCS_Pos 21
248 #define PWM_SCM_PTRCS_Msk (0x7u << PWM_SCM_PTRCS_Pos)
249 #define PWM_SCM_PTRCS(value) ((PWM_SCM_PTRCS_Msk & ((value) << PWM_SCM_PTRCS_Pos)))
250 /* -------- PWM_DMAR : (PWM Offset: 0x24) PWM DMA Register -------- */
251 #define PWM_DMAR_DMADUTY_Pos 0
252 #define PWM_DMAR_DMADUTY_Msk (0xffffffu << PWM_DMAR_DMADUTY_Pos)
253 #define PWM_DMAR_DMADUTY(value) ((PWM_DMAR_DMADUTY_Msk & ((value) << PWM_DMAR_DMADUTY_Pos)))
254 /* -------- PWM_SCUC : (PWM Offset: 0x28) PWM Sync Channels Update Control Register -------- */
255 #define PWM_SCUC_UPDULOCK (0x1u << 0)
256 /* -------- PWM_SCUP : (PWM Offset: 0x2C) PWM Sync Channels Update Period Register -------- */
257 #define PWM_SCUP_UPR_Pos 0
258 #define PWM_SCUP_UPR_Msk (0xfu << PWM_SCUP_UPR_Pos)
259 #define PWM_SCUP_UPR(value) ((PWM_SCUP_UPR_Msk & ((value) << PWM_SCUP_UPR_Pos)))
260 #define PWM_SCUP_UPRCNT_Pos 4
261 #define PWM_SCUP_UPRCNT_Msk (0xfu << PWM_SCUP_UPRCNT_Pos)
262 #define PWM_SCUP_UPRCNT(value) ((PWM_SCUP_UPRCNT_Msk & ((value) << PWM_SCUP_UPRCNT_Pos)))
263 /* -------- PWM_SCUPUPD : (PWM Offset: 0x30) PWM Sync Channels Update Period Update Register -------- */
264 #define PWM_SCUPUPD_UPRUPD_Pos 0
265 #define PWM_SCUPUPD_UPRUPD_Msk (0xfu << PWM_SCUPUPD_UPRUPD_Pos)
266 #define PWM_SCUPUPD_UPRUPD(value) ((PWM_SCUPUPD_UPRUPD_Msk & ((value) << PWM_SCUPUPD_UPRUPD_Pos)))
267 /* -------- PWM_IER2 : (PWM Offset: 0x34) PWM Interrupt Enable Register 2 -------- */
268 #define PWM_IER2_WRDY (0x1u << 0)
269 #define PWM_IER2_UNRE (0x1u << 3)
270 #define PWM_IER2_CMPM0 (0x1u << 8)
271 #define PWM_IER2_CMPM1 (0x1u << 9)
272 #define PWM_IER2_CMPM2 (0x1u << 10)
273 #define PWM_IER2_CMPM3 (0x1u << 11)
274 #define PWM_IER2_CMPM4 (0x1u << 12)
275 #define PWM_IER2_CMPM5 (0x1u << 13)
276 #define PWM_IER2_CMPM6 (0x1u << 14)
277 #define PWM_IER2_CMPM7 (0x1u << 15)
278 #define PWM_IER2_CMPU0 (0x1u << 16)
279 #define PWM_IER2_CMPU1 (0x1u << 17)
280 #define PWM_IER2_CMPU2 (0x1u << 18)
281 #define PWM_IER2_CMPU3 (0x1u << 19)
282 #define PWM_IER2_CMPU4 (0x1u << 20)
283 #define PWM_IER2_CMPU5 (0x1u << 21)
284 #define PWM_IER2_CMPU6 (0x1u << 22)
285 #define PWM_IER2_CMPU7 (0x1u << 23)
286 /* -------- PWM_IDR2 : (PWM Offset: 0x38) PWM Interrupt Disable Register 2 -------- */
287 #define PWM_IDR2_WRDY (0x1u << 0)
288 #define PWM_IDR2_UNRE (0x1u << 3)
289 #define PWM_IDR2_CMPM0 (0x1u << 8)
290 #define PWM_IDR2_CMPM1 (0x1u << 9)
291 #define PWM_IDR2_CMPM2 (0x1u << 10)
292 #define PWM_IDR2_CMPM3 (0x1u << 11)
293 #define PWM_IDR2_CMPM4 (0x1u << 12)
294 #define PWM_IDR2_CMPM5 (0x1u << 13)
295 #define PWM_IDR2_CMPM6 (0x1u << 14)
296 #define PWM_IDR2_CMPM7 (0x1u << 15)
297 #define PWM_IDR2_CMPU0 (0x1u << 16)
298 #define PWM_IDR2_CMPU1 (0x1u << 17)
299 #define PWM_IDR2_CMPU2 (0x1u << 18)
300 #define PWM_IDR2_CMPU3 (0x1u << 19)
301 #define PWM_IDR2_CMPU4 (0x1u << 20)
302 #define PWM_IDR2_CMPU5 (0x1u << 21)
303 #define PWM_IDR2_CMPU6 (0x1u << 22)
304 #define PWM_IDR2_CMPU7 (0x1u << 23)
305 /* -------- PWM_IMR2 : (PWM Offset: 0x3C) PWM Interrupt Mask Register 2 -------- */
306 #define PWM_IMR2_WRDY (0x1u << 0)
307 #define PWM_IMR2_UNRE (0x1u << 3)
308 #define PWM_IMR2_CMPM0 (0x1u << 8)
309 #define PWM_IMR2_CMPM1 (0x1u << 9)
310 #define PWM_IMR2_CMPM2 (0x1u << 10)
311 #define PWM_IMR2_CMPM3 (0x1u << 11)
312 #define PWM_IMR2_CMPM4 (0x1u << 12)
313 #define PWM_IMR2_CMPM5 (0x1u << 13)
314 #define PWM_IMR2_CMPM6 (0x1u << 14)
315 #define PWM_IMR2_CMPM7 (0x1u << 15)
316 #define PWM_IMR2_CMPU0 (0x1u << 16)
317 #define PWM_IMR2_CMPU1 (0x1u << 17)
318 #define PWM_IMR2_CMPU2 (0x1u << 18)
319 #define PWM_IMR2_CMPU3 (0x1u << 19)
320 #define PWM_IMR2_CMPU4 (0x1u << 20)
321 #define PWM_IMR2_CMPU5 (0x1u << 21)
322 #define PWM_IMR2_CMPU6 (0x1u << 22)
323 #define PWM_IMR2_CMPU7 (0x1u << 23)
324 /* -------- PWM_ISR2 : (PWM Offset: 0x40) PWM Interrupt Status Register 2 -------- */
325 #define PWM_ISR2_WRDY (0x1u << 0)
326 #define PWM_ISR2_UNRE (0x1u << 3)
327 #define PWM_ISR2_CMPM0 (0x1u << 8)
328 #define PWM_ISR2_CMPM1 (0x1u << 9)
329 #define PWM_ISR2_CMPM2 (0x1u << 10)
330 #define PWM_ISR2_CMPM3 (0x1u << 11)
331 #define PWM_ISR2_CMPM4 (0x1u << 12)
332 #define PWM_ISR2_CMPM5 (0x1u << 13)
333 #define PWM_ISR2_CMPM6 (0x1u << 14)
334 #define PWM_ISR2_CMPM7 (0x1u << 15)
335 #define PWM_ISR2_CMPU0 (0x1u << 16)
336 #define PWM_ISR2_CMPU1 (0x1u << 17)
337 #define PWM_ISR2_CMPU2 (0x1u << 18)
338 #define PWM_ISR2_CMPU3 (0x1u << 19)
339 #define PWM_ISR2_CMPU4 (0x1u << 20)
340 #define PWM_ISR2_CMPU5 (0x1u << 21)
341 #define PWM_ISR2_CMPU6 (0x1u << 22)
342 #define PWM_ISR2_CMPU7 (0x1u << 23)
343 /* -------- PWM_OOV : (PWM Offset: 0x44) PWM Output Override Value Register -------- */
344 #define PWM_OOV_OOVH0 (0x1u << 0)
345 #define PWM_OOV_OOVH1 (0x1u << 1)
346 #define PWM_OOV_OOVH2 (0x1u << 2)
347 #define PWM_OOV_OOVH3 (0x1u << 3)
348 #define PWM_OOV_OOVL0 (0x1u << 16)
349 #define PWM_OOV_OOVL1 (0x1u << 17)
350 #define PWM_OOV_OOVL2 (0x1u << 18)
351 #define PWM_OOV_OOVL3 (0x1u << 19)
352 /* -------- PWM_OS : (PWM Offset: 0x48) PWM Output Selection Register -------- */
353 #define PWM_OS_OSH0 (0x1u << 0)
354 #define PWM_OS_OSH1 (0x1u << 1)
355 #define PWM_OS_OSH2 (0x1u << 2)
356 #define PWM_OS_OSH3 (0x1u << 3)
357 #define PWM_OS_OSL0 (0x1u << 16)
358 #define PWM_OS_OSL1 (0x1u << 17)
359 #define PWM_OS_OSL2 (0x1u << 18)
360 #define PWM_OS_OSL3 (0x1u << 19)
361 /* -------- PWM_OSS : (PWM Offset: 0x4C) PWM Output Selection Set Register -------- */
362 #define PWM_OSS_OSSH0 (0x1u << 0)
363 #define PWM_OSS_OSSH1 (0x1u << 1)
364 #define PWM_OSS_OSSH2 (0x1u << 2)
365 #define PWM_OSS_OSSH3 (0x1u << 3)
366 #define PWM_OSS_OSSL0 (0x1u << 16)
367 #define PWM_OSS_OSSL1 (0x1u << 17)
368 #define PWM_OSS_OSSL2 (0x1u << 18)
369 #define PWM_OSS_OSSL3 (0x1u << 19)
370 /* -------- PWM_OSC : (PWM Offset: 0x50) PWM Output Selection Clear Register -------- */
371 #define PWM_OSC_OSCH0 (0x1u << 0)
372 #define PWM_OSC_OSCH1 (0x1u << 1)
373 #define PWM_OSC_OSCH2 (0x1u << 2)
374 #define PWM_OSC_OSCH3 (0x1u << 3)
375 #define PWM_OSC_OSCL0 (0x1u << 16)
376 #define PWM_OSC_OSCL1 (0x1u << 17)
377 #define PWM_OSC_OSCL2 (0x1u << 18)
378 #define PWM_OSC_OSCL3 (0x1u << 19)
379 /* -------- PWM_OSSUPD : (PWM Offset: 0x54) PWM Output Selection Set Update Register -------- */
380 #define PWM_OSSUPD_OSSUPH0 (0x1u << 0)
381 #define PWM_OSSUPD_OSSUPH1 (0x1u << 1)
382 #define PWM_OSSUPD_OSSUPH2 (0x1u << 2)
383 #define PWM_OSSUPD_OSSUPH3 (0x1u << 3)
384 #define PWM_OSSUPD_OSSUPL0 (0x1u << 16)
385 #define PWM_OSSUPD_OSSUPL1 (0x1u << 17)
386 #define PWM_OSSUPD_OSSUPL2 (0x1u << 18)
387 #define PWM_OSSUPD_OSSUPL3 (0x1u << 19)
388 /* -------- PWM_OSCUPD : (PWM Offset: 0x58) PWM Output Selection Clear Update Register -------- */
389 #define PWM_OSCUPD_OSCUPH0 (0x1u << 0)
390 #define PWM_OSCUPD_OSCUPH1 (0x1u << 1)
391 #define PWM_OSCUPD_OSCUPH2 (0x1u << 2)
392 #define PWM_OSCUPD_OSCUPH3 (0x1u << 3)
393 #define PWM_OSCUPD_OSCUPL0 (0x1u << 16)
394 #define PWM_OSCUPD_OSCUPL1 (0x1u << 17)
395 #define PWM_OSCUPD_OSCUPL2 (0x1u << 18)
396 #define PWM_OSCUPD_OSCUPL3 (0x1u << 19)
397 /* -------- PWM_FMR : (PWM Offset: 0x5C) PWM Fault Mode Register -------- */
398 #define PWM_FMR_FPOL_Pos 0
399 #define PWM_FMR_FPOL_Msk (0xffu << PWM_FMR_FPOL_Pos)
400 #define PWM_FMR_FPOL(value) ((PWM_FMR_FPOL_Msk & ((value) << PWM_FMR_FPOL_Pos)))
401 #define PWM_FMR_FMOD_Pos 8
402 #define PWM_FMR_FMOD_Msk (0xffu << PWM_FMR_FMOD_Pos)
403 #define PWM_FMR_FMOD(value) ((PWM_FMR_FMOD_Msk & ((value) << PWM_FMR_FMOD_Pos)))
404 #define PWM_FMR_FFIL_Pos 16
405 #define PWM_FMR_FFIL_Msk (0xffu << PWM_FMR_FFIL_Pos)
406 #define PWM_FMR_FFIL(value) ((PWM_FMR_FFIL_Msk & ((value) << PWM_FMR_FFIL_Pos)))
407 /* -------- PWM_FSR : (PWM Offset: 0x60) PWM Fault Status Register -------- */
408 #define PWM_FSR_FIV_Pos 0
409 #define PWM_FSR_FIV_Msk (0xffu << PWM_FSR_FIV_Pos)
410 #define PWM_FSR_FS_Pos 8
411 #define PWM_FSR_FS_Msk (0xffu << PWM_FSR_FS_Pos)
412 /* -------- PWM_FCR : (PWM Offset: 0x64) PWM Fault Clear Register -------- */
413 #define PWM_FCR_FCLR_Pos 0
414 #define PWM_FCR_FCLR_Msk (0xffu << PWM_FCR_FCLR_Pos)
415 #define PWM_FCR_FCLR(value) ((PWM_FCR_FCLR_Msk & ((value) << PWM_FCR_FCLR_Pos)))
416 /* -------- PWM_FPV1 : (PWM Offset: 0x68) PWM Fault Protection Value Register 1 -------- */
417 #define PWM_FPV1_FPVH0 (0x1u << 0)
418 #define PWM_FPV1_FPVH1 (0x1u << 1)
419 #define PWM_FPV1_FPVH2 (0x1u << 2)
420 #define PWM_FPV1_FPVH3 (0x1u << 3)
421 #define PWM_FPV1_FPVL0 (0x1u << 16)
422 #define PWM_FPV1_FPVL1 (0x1u << 17)
423 #define PWM_FPV1_FPVL2 (0x1u << 18)
424 #define PWM_FPV1_FPVL3 (0x1u << 19)
425 /* -------- PWM_FPE : (PWM Offset: 0x6C) PWM Fault Protection Enable Register -------- */
426 #define PWM_FPE_FPE0_Pos 0
427 #define PWM_FPE_FPE0_Msk (0xffu << PWM_FPE_FPE0_Pos)
428 #define PWM_FPE_FPE0(value) ((PWM_FPE_FPE0_Msk & ((value) << PWM_FPE_FPE0_Pos)))
429 #define PWM_FPE_FPE1_Pos 8
430 #define PWM_FPE_FPE1_Msk (0xffu << PWM_FPE_FPE1_Pos)
431 #define PWM_FPE_FPE1(value) ((PWM_FPE_FPE1_Msk & ((value) << PWM_FPE_FPE1_Pos)))
432 #define PWM_FPE_FPE2_Pos 16
433 #define PWM_FPE_FPE2_Msk (0xffu << PWM_FPE_FPE2_Pos)
434 #define PWM_FPE_FPE2(value) ((PWM_FPE_FPE2_Msk & ((value) << PWM_FPE_FPE2_Pos)))
435 #define PWM_FPE_FPE3_Pos 24
436 #define PWM_FPE_FPE3_Msk (0xffu << PWM_FPE_FPE3_Pos)
437 #define PWM_FPE_FPE3(value) ((PWM_FPE_FPE3_Msk & ((value) << PWM_FPE_FPE3_Pos)))
438 /* -------- PWM_ELMR[2] : (PWM Offset: 0x7C) PWM Event Line 0 Mode Register -------- */
439 #define PWM_ELMR_CSEL0 (0x1u << 0)
440 #define PWM_ELMR_CSEL1 (0x1u << 1)
441 #define PWM_ELMR_CSEL2 (0x1u << 2)
442 #define PWM_ELMR_CSEL3 (0x1u << 3)
443 #define PWM_ELMR_CSEL4 (0x1u << 4)
444 #define PWM_ELMR_CSEL5 (0x1u << 5)
445 #define PWM_ELMR_CSEL6 (0x1u << 6)
446 #define PWM_ELMR_CSEL7 (0x1u << 7)
447 /* -------- PWM_SSPR : (PWM Offset: 0xA0) PWM Spread Spectrum Register -------- */
448 #define PWM_SSPR_SPRD_Pos 0
449 #define PWM_SSPR_SPRD_Msk (0xffffffu << PWM_SSPR_SPRD_Pos)
450 #define PWM_SSPR_SPRD(value) ((PWM_SSPR_SPRD_Msk & ((value) << PWM_SSPR_SPRD_Pos)))
451 #define PWM_SSPR_SPRDM (0x1u << 24)
452 /* -------- PWM_SSPUP : (PWM Offset: 0xA4) PWM Spread Spectrum Update Register -------- */
453 #define PWM_SSPUP_SPRDUP_Pos 0
454 #define PWM_SSPUP_SPRDUP_Msk (0xffffffu << PWM_SSPUP_SPRDUP_Pos)
455 #define PWM_SSPUP_SPRDUP(value) ((PWM_SSPUP_SPRDUP_Msk & ((value) << PWM_SSPUP_SPRDUP_Pos)))
456 /* -------- PWM_SMMR : (PWM Offset: 0xB0) PWM Stepper Motor Mode Register -------- */
457 #define PWM_SMMR_GCEN0 (0x1u << 0)
458 #define PWM_SMMR_GCEN1 (0x1u << 1)
459 #define PWM_SMMR_DOWN0 (0x1u << 16)
460 #define PWM_SMMR_DOWN1 (0x1u << 17)
461 /* -------- PWM_FPV2 : (PWM Offset: 0xC0) PWM Fault Protection Value 2 Register -------- */
462 #define PWM_FPV2_FPZH0 (0x1u << 0)
463 #define PWM_FPV2_FPZH1 (0x1u << 1)
464 #define PWM_FPV2_FPZH2 (0x1u << 2)
465 #define PWM_FPV2_FPZH3 (0x1u << 3)
466 #define PWM_FPV2_FPZL0 (0x1u << 16)
467 #define PWM_FPV2_FPZL1 (0x1u << 17)
468 #define PWM_FPV2_FPZL2 (0x1u << 18)
469 #define PWM_FPV2_FPZL3 (0x1u << 19)
470 /* -------- PWM_WPCR : (PWM Offset: 0xE4) PWM Write Protection Control Register -------- */
471 #define PWM_WPCR_WPCMD_Pos 0
472 #define PWM_WPCR_WPCMD_Msk (0x3u << PWM_WPCR_WPCMD_Pos)
473 #define PWM_WPCR_WPCMD(value) ((PWM_WPCR_WPCMD_Msk & ((value) << PWM_WPCR_WPCMD_Pos)))
474 #define PWM_WPCR_WPCMD_DISABLE_SW_PROT (0x0u << 0)
475 #define PWM_WPCR_WPCMD_ENABLE_SW_PROT (0x1u << 0)
476 #define PWM_WPCR_WPCMD_ENABLE_HW_PROT (0x2u << 0)
477 #define PWM_WPCR_WPRG0 (0x1u << 2)
478 #define PWM_WPCR_WPRG1 (0x1u << 3)
479 #define PWM_WPCR_WPRG2 (0x1u << 4)
480 #define PWM_WPCR_WPRG3 (0x1u << 5)
481 #define PWM_WPCR_WPRG4 (0x1u << 6)
482 #define PWM_WPCR_WPRG5 (0x1u << 7)
483 #define PWM_WPCR_WPKEY_Pos 8
484 #define PWM_WPCR_WPKEY_Msk (0xffffffu << PWM_WPCR_WPKEY_Pos)
485 #define PWM_WPCR_WPKEY(value) ((PWM_WPCR_WPKEY_Msk & ((value) << PWM_WPCR_WPKEY_Pos)))
486 #define PWM_WPCR_WPKEY_PASSWD (0x50574Du << 8)
487 /* -------- PWM_WPSR : (PWM Offset: 0xE8) PWM Write Protection Status Register -------- */
488 #define PWM_WPSR_WPSWS0 (0x1u << 0)
489 #define PWM_WPSR_WPSWS1 (0x1u << 1)
490 #define PWM_WPSR_WPSWS2 (0x1u << 2)
491 #define PWM_WPSR_WPSWS3 (0x1u << 3)
492 #define PWM_WPSR_WPSWS4 (0x1u << 4)
493 #define PWM_WPSR_WPSWS5 (0x1u << 5)
494 #define PWM_WPSR_WPVS (0x1u << 7)
495 #define PWM_WPSR_WPHWS0 (0x1u << 8)
496 #define PWM_WPSR_WPHWS1 (0x1u << 9)
497 #define PWM_WPSR_WPHWS2 (0x1u << 10)
498 #define PWM_WPSR_WPHWS3 (0x1u << 11)
499 #define PWM_WPSR_WPHWS4 (0x1u << 12)
500 #define PWM_WPSR_WPHWS5 (0x1u << 13)
501 #define PWM_WPSR_WPVSRC_Pos 16
502 #define PWM_WPSR_WPVSRC_Msk (0xffffu << PWM_WPSR_WPVSRC_Pos)
503 /* -------- PWM_CMPV : (PWM Offset: N/A) PWM Comparison 0 Value Register -------- */
504 #define PWM_CMPV_CV_Pos 0
505 #define PWM_CMPV_CV_Msk (0xffffffu << PWM_CMPV_CV_Pos)
506 #define PWM_CMPV_CV(value) ((PWM_CMPV_CV_Msk & ((value) << PWM_CMPV_CV_Pos)))
507 #define PWM_CMPV_CVM (0x1u << 24)
508 /* -------- PWM_CMPVUPD : (PWM Offset: N/A) PWM Comparison 0 Value Update Register -------- */
509 #define PWM_CMPVUPD_CVUPD_Pos 0
510 #define PWM_CMPVUPD_CVUPD_Msk (0xffffffu << PWM_CMPVUPD_CVUPD_Pos)
511 #define PWM_CMPVUPD_CVUPD(value) ((PWM_CMPVUPD_CVUPD_Msk & ((value) << PWM_CMPVUPD_CVUPD_Pos)))
512 #define PWM_CMPVUPD_CVMUPD (0x1u << 24)
513 /* -------- PWM_CMPM : (PWM Offset: N/A) PWM Comparison 0 Mode Register -------- */
514 #define PWM_CMPM_CEN (0x1u << 0)
515 #define PWM_CMPM_CTR_Pos 4
516 #define PWM_CMPM_CTR_Msk (0xfu << PWM_CMPM_CTR_Pos)
517 #define PWM_CMPM_CTR(value) ((PWM_CMPM_CTR_Msk & ((value) << PWM_CMPM_CTR_Pos)))
518 #define PWM_CMPM_CPR_Pos 8
519 #define PWM_CMPM_CPR_Msk (0xfu << PWM_CMPM_CPR_Pos)
520 #define PWM_CMPM_CPR(value) ((PWM_CMPM_CPR_Msk & ((value) << PWM_CMPM_CPR_Pos)))
521 #define PWM_CMPM_CPRCNT_Pos 12
522 #define PWM_CMPM_CPRCNT_Msk (0xfu << PWM_CMPM_CPRCNT_Pos)
523 #define PWM_CMPM_CPRCNT(value) ((PWM_CMPM_CPRCNT_Msk & ((value) << PWM_CMPM_CPRCNT_Pos)))
524 #define PWM_CMPM_CUPR_Pos 16
525 #define PWM_CMPM_CUPR_Msk (0xfu << PWM_CMPM_CUPR_Pos)
526 #define PWM_CMPM_CUPR(value) ((PWM_CMPM_CUPR_Msk & ((value) << PWM_CMPM_CUPR_Pos)))
527 #define PWM_CMPM_CUPRCNT_Pos 20
528 #define PWM_CMPM_CUPRCNT_Msk (0xfu << PWM_CMPM_CUPRCNT_Pos)
529 #define PWM_CMPM_CUPRCNT(value) ((PWM_CMPM_CUPRCNT_Msk & ((value) << PWM_CMPM_CUPRCNT_Pos)))
530 /* -------- PWM_CMPMUPD : (PWM Offset: N/A) PWM Comparison 0 Mode Update Register -------- */
531 #define PWM_CMPMUPD_CENUPD (0x1u << 0)
532 #define PWM_CMPMUPD_CTRUPD_Pos 4
533 #define PWM_CMPMUPD_CTRUPD_Msk (0xfu << PWM_CMPMUPD_CTRUPD_Pos)
534 #define PWM_CMPMUPD_CTRUPD(value) ((PWM_CMPMUPD_CTRUPD_Msk & ((value) << PWM_CMPMUPD_CTRUPD_Pos)))
535 #define PWM_CMPMUPD_CPRUPD_Pos 8
536 #define PWM_CMPMUPD_CPRUPD_Msk (0xfu << PWM_CMPMUPD_CPRUPD_Pos)
537 #define PWM_CMPMUPD_CPRUPD(value) ((PWM_CMPMUPD_CPRUPD_Msk & ((value) << PWM_CMPMUPD_CPRUPD_Pos)))
538 #define PWM_CMPMUPD_CUPRUPD_Pos 16
539 #define PWM_CMPMUPD_CUPRUPD_Msk (0xfu << PWM_CMPMUPD_CUPRUPD_Pos)
540 #define PWM_CMPMUPD_CUPRUPD(value) ((PWM_CMPMUPD_CUPRUPD_Msk & ((value) << PWM_CMPMUPD_CUPRUPD_Pos)))
541 /* -------- PWM_CMR : (PWM Offset: N/A) PWM Channel Mode Register -------- */
542 #define PWM_CMR_CPRE_Pos 0
543 #define PWM_CMR_CPRE_Msk (0xfu << PWM_CMR_CPRE_Pos)
544 #define PWM_CMR_CPRE(value) ((PWM_CMR_CPRE_Msk & ((value) << PWM_CMR_CPRE_Pos)))
545 #define PWM_CMR_CPRE_MCK (0x0u << 0)
546 #define PWM_CMR_CPRE_MCK_DIV_2 (0x1u << 0)
547 #define PWM_CMR_CPRE_MCK_DIV_4 (0x2u << 0)
548 #define PWM_CMR_CPRE_MCK_DIV_8 (0x3u << 0)
549 #define PWM_CMR_CPRE_MCK_DIV_16 (0x4u << 0)
550 #define PWM_CMR_CPRE_MCK_DIV_32 (0x5u << 0)
551 #define PWM_CMR_CPRE_MCK_DIV_64 (0x6u << 0)
552 #define PWM_CMR_CPRE_MCK_DIV_128 (0x7u << 0)
553 #define PWM_CMR_CPRE_MCK_DIV_256 (0x8u << 0)
554 #define PWM_CMR_CPRE_MCK_DIV_512 (0x9u << 0)
555 #define PWM_CMR_CPRE_MCK_DIV_1024 (0xAu << 0)
556 #define PWM_CMR_CPRE_CLKA (0xBu << 0)
557 #define PWM_CMR_CPRE_CLKB (0xCu << 0)
558 #define PWM_CMR_CALG (0x1u << 8)
559 #define PWM_CMR_CPOL (0x1u << 9)
560 #define PWM_CMR_CES (0x1u << 10)
561 #define PWM_CMR_UPDS (0x1u << 11)
562 #define PWM_CMR_DPOLI (0x1u << 12)
563 #define PWM_CMR_TCTS (0x1u << 13)
564 #define PWM_CMR_DTE (0x1u << 16)
565 #define PWM_CMR_DTHI (0x1u << 17)
566 #define PWM_CMR_DTLI (0x1u << 18)
567 #define PWM_CMR_PPM (0x1u << 19)
568 /* -------- PWM_CDTY : (PWM Offset: N/A) PWM Channel Duty Cycle Register -------- */
569 #define PWM_CDTY_CDTY_Pos 0
570 #define PWM_CDTY_CDTY_Msk (0xffffffu << PWM_CDTY_CDTY_Pos)
571 #define PWM_CDTY_CDTY(value) ((PWM_CDTY_CDTY_Msk & ((value) << PWM_CDTY_CDTY_Pos)))
572 /* -------- PWM_CDTYUPD : (PWM Offset: N/A) PWM Channel Duty Cycle Update Register -------- */
573 #define PWM_CDTYUPD_CDTYUPD_Pos 0
574 #define PWM_CDTYUPD_CDTYUPD_Msk (0xffffffu << PWM_CDTYUPD_CDTYUPD_Pos)
575 #define PWM_CDTYUPD_CDTYUPD(value) ((PWM_CDTYUPD_CDTYUPD_Msk & ((value) << PWM_CDTYUPD_CDTYUPD_Pos)))
576 /* -------- PWM_CPRD : (PWM Offset: N/A) PWM Channel Period Register -------- */
577 #define PWM_CPRD_CPRD_Pos 0
578 #define PWM_CPRD_CPRD_Msk (0xffffffu << PWM_CPRD_CPRD_Pos)
579 #define PWM_CPRD_CPRD(value) ((PWM_CPRD_CPRD_Msk & ((value) << PWM_CPRD_CPRD_Pos)))
580 /* -------- PWM_CPRDUPD : (PWM Offset: N/A) PWM Channel Period Update Register -------- */
581 #define PWM_CPRDUPD_CPRDUPD_Pos 0
582 #define PWM_CPRDUPD_CPRDUPD_Msk (0xffffffu << PWM_CPRDUPD_CPRDUPD_Pos)
583 #define PWM_CPRDUPD_CPRDUPD(value) ((PWM_CPRDUPD_CPRDUPD_Msk & ((value) << PWM_CPRDUPD_CPRDUPD_Pos)))
584 /* -------- PWM_CCNT : (PWM Offset: N/A) PWM Channel Counter Register -------- */
585 #define PWM_CCNT_CNT_Pos 0
586 #define PWM_CCNT_CNT_Msk (0xffffffu << PWM_CCNT_CNT_Pos)
587 /* -------- PWM_DT : (PWM Offset: N/A) PWM Channel Dead Time Register -------- */
588 #define PWM_DT_DTH_Pos 0
589 #define PWM_DT_DTH_Msk (0xffffu << PWM_DT_DTH_Pos)
590 #define PWM_DT_DTH(value) ((PWM_DT_DTH_Msk & ((value) << PWM_DT_DTH_Pos)))
591 #define PWM_DT_DTL_Pos 16
592 #define PWM_DT_DTL_Msk (0xffffu << PWM_DT_DTL_Pos)
593 #define PWM_DT_DTL(value) ((PWM_DT_DTL_Msk & ((value) << PWM_DT_DTL_Pos)))
594 /* -------- PWM_DTUPD : (PWM Offset: N/A) PWM Channel Dead Time Update Register -------- */
595 #define PWM_DTUPD_DTHUPD_Pos 0
596 #define PWM_DTUPD_DTHUPD_Msk (0xffffu << PWM_DTUPD_DTHUPD_Pos)
597 #define PWM_DTUPD_DTHUPD(value) ((PWM_DTUPD_DTHUPD_Msk & ((value) << PWM_DTUPD_DTHUPD_Pos)))
598 #define PWM_DTUPD_DTLUPD_Pos 16
599 #define PWM_DTUPD_DTLUPD_Msk (0xffffu << PWM_DTUPD_DTLUPD_Pos)
600 #define PWM_DTUPD_DTLUPD(value) ((PWM_DTUPD_DTLUPD_Msk & ((value) << PWM_DTUPD_DTLUPD_Pos)))
601 /* -------- PWM_CMUPD0 : (PWM Offset: 0x400) PWM Channel Mode Update Register (ch_num = 0) -------- */
602 #define PWM_CMUPD0_CPOLUP (0x1u << 9)
603 #define PWM_CMUPD0_CPOLINVUP (0x1u << 13)
604 /* -------- PWM_CMUPD1 : (PWM Offset: 0x420) PWM Channel Mode Update Register (ch_num = 1) -------- */
605 #define PWM_CMUPD1_CPOLUP (0x1u << 9)
606 #define PWM_CMUPD1_CPOLINVUP (0x1u << 13)
607 /* -------- PWM_ETRG1 : (PWM Offset: 0x42C) PWM External Trigger Register (trg_num = 1) -------- */
608 #define PWM_ETRG1_MAXCNT_Pos 0
609 #define PWM_ETRG1_MAXCNT_Msk (0xffffffu << PWM_ETRG1_MAXCNT_Pos)
610 #define PWM_ETRG1_MAXCNT(value) ((PWM_ETRG1_MAXCNT_Msk & ((value) << PWM_ETRG1_MAXCNT_Pos)))
611 #define PWM_ETRG1_TRGMODE_Pos 24
612 #define PWM_ETRG1_TRGMODE_Msk (0x3u << PWM_ETRG1_TRGMODE_Pos)
613 #define PWM_ETRG1_TRGMODE(value) ((PWM_ETRG1_TRGMODE_Msk & ((value) << PWM_ETRG1_TRGMODE_Pos)))
614 #define PWM_ETRG1_TRGMODE_OFF (0x0u << 24)
615 #define PWM_ETRG1_TRGMODE_MODE1 (0x1u << 24)
616 #define PWM_ETRG1_TRGMODE_MODE2 (0x2u << 24)
617 #define PWM_ETRG1_TRGMODE_MODE3 (0x3u << 24)
618 #define PWM_ETRG1_TRGEDGE (0x1u << 28)
619 #define PWM_ETRG1_TRGEDGE_FALLING_ZERO (0x0u << 28)
620 #define PWM_ETRG1_TRGEDGE_RISING_ONE (0x1u << 28)
621 #define PWM_ETRG1_TRGFILT (0x1u << 29)
622 #define PWM_ETRG1_TRGSRC (0x1u << 30)
623 #define PWM_ETRG1_RFEN (0x1u << 31)
624 /* -------- PWM_LEBR1 : (PWM Offset: 0x430) PWM Leading-Edge Blanking Register (trg_num = 1) -------- */
625 #define PWM_LEBR1_LEBDELAY_Pos 0
626 #define PWM_LEBR1_LEBDELAY_Msk (0x7fu << PWM_LEBR1_LEBDELAY_Pos)
627 #define PWM_LEBR1_LEBDELAY(value) ((PWM_LEBR1_LEBDELAY_Msk & ((value) << PWM_LEBR1_LEBDELAY_Pos)))
628 #define PWM_LEBR1_PWMLFEN (0x1u << 16)
629 #define PWM_LEBR1_PWMLREN (0x1u << 17)
630 #define PWM_LEBR1_PWMHFEN (0x1u << 18)
631 #define PWM_LEBR1_PWMHREN (0x1u << 19)
632 /* -------- PWM_CMUPD2 : (PWM Offset: 0x440) PWM Channel Mode Update Register (ch_num = 2) -------- */
633 #define PWM_CMUPD2_CPOLUP (0x1u << 9)
634 #define PWM_CMUPD2_CPOLINVUP (0x1u << 13)
635 /* -------- PWM_ETRG2 : (PWM Offset: 0x44C) PWM External Trigger Register (trg_num = 2) -------- */
636 #define PWM_ETRG2_MAXCNT_Pos 0
637 #define PWM_ETRG2_MAXCNT_Msk (0xffffffu << PWM_ETRG2_MAXCNT_Pos)
638 #define PWM_ETRG2_MAXCNT(value) ((PWM_ETRG2_MAXCNT_Msk & ((value) << PWM_ETRG2_MAXCNT_Pos)))
639 #define PWM_ETRG2_TRGMODE_Pos 24
640 #define PWM_ETRG2_TRGMODE_Msk (0x3u << PWM_ETRG2_TRGMODE_Pos)
641 #define PWM_ETRG2_TRGMODE(value) ((PWM_ETRG2_TRGMODE_Msk & ((value) << PWM_ETRG2_TRGMODE_Pos)))
642 #define PWM_ETRG2_TRGMODE_OFF (0x0u << 24)
643 #define PWM_ETRG2_TRGMODE_MODE1 (0x1u << 24)
644 #define PWM_ETRG2_TRGMODE_MODE2 (0x2u << 24)
645 #define PWM_ETRG2_TRGMODE_MODE3 (0x3u << 24)
646 #define PWM_ETRG2_TRGEDGE (0x1u << 28)
647 #define PWM_ETRG2_TRGEDGE_FALLING_ZERO (0x0u << 28)
648 #define PWM_ETRG2_TRGEDGE_RISING_ONE (0x1u << 28)
649 #define PWM_ETRG2_TRGFILT (0x1u << 29)
650 #define PWM_ETRG2_TRGSRC (0x1u << 30)
651 #define PWM_ETRG2_RFEN (0x1u << 31)
652 /* -------- PWM_LEBR2 : (PWM Offset: 0x450) PWM Leading-Edge Blanking Register (trg_num = 2) -------- */
653 #define PWM_LEBR2_LEBDELAY_Pos 0
654 #define PWM_LEBR2_LEBDELAY_Msk (0x7fu << PWM_LEBR2_LEBDELAY_Pos)
655 #define PWM_LEBR2_LEBDELAY(value) ((PWM_LEBR2_LEBDELAY_Msk & ((value) << PWM_LEBR2_LEBDELAY_Pos)))
656 #define PWM_LEBR2_PWMLFEN (0x1u << 16)
657 #define PWM_LEBR2_PWMLREN (0x1u << 17)
658 #define PWM_LEBR2_PWMHFEN (0x1u << 18)
659 #define PWM_LEBR2_PWMHREN (0x1u << 19)
660 /* -------- PWM_CMUPD3 : (PWM Offset: 0x460) PWM Channel Mode Update Register (ch_num = 3) -------- */
661 #define PWM_CMUPD3_CPOLUP (0x1u << 9)
662 #define PWM_CMUPD3_CPOLINVUP (0x1u << 13)
665
666
667 #endif /* _SAMS70_PWM_COMPONENT_ */
(Pwm Offset: 0x13C) PWM Comparison 0 Mode Update Register
Definition: component_pwm.h:98
(Pwm Offset: 0x1A4) PWM Comparison 7 Value Update Register
Definition: component_pwm.h:124
(Pwm Offset: 0x138) PWM Comparison 0 Mode Register
Definition: component_pwm.h:97
Definition: component_pwm.h:61
(Pwm Offset: 0x1AC) PWM Comparison 7 Mode Update Register
Definition: component_pwm.h:126
(Pwm Offset: 0x140) PWM Comparison 1 Value Register
Definition: component_pwm.h:99
(Pwm Offset: 0x19C) PWM Comparison 6 Mode Update Register
Definition: component_pwm.h:122
(Pwm Offset: 0x164) PWM Comparison 3 Value Update Register
Definition: component_pwm.h:108
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
(Pwm Offset: 0x1A8) PWM Comparison 7 Mode Register
Definition: component_pwm.h:125
Pwm hardware registers.
Definition: component_pwm.h:52
(Pwm Offset: 0x18C) PWM Comparison 5 Mode Update Register
Definition: component_pwm.h:118
(Pwm Offset: 0x170) PWM Comparison 4 Value Register
Definition: component_pwm.h:111
(Pwm Offset: 0x178) PWM Comparison 4 Mode Register
Definition: component_pwm.h:113
(Pwm Offset: 0x184) PWM Comparison 5 Value Update Register
Definition: component_pwm.h:116
(Pwm Offset: 0x188) PWM Comparison 5 Mode Register
Definition: component_pwm.h:117
(Pwm Offset: 0x168) PWM Comparison 3 Mode Register
Definition: component_pwm.h:109
(Pwm Offset: 0x134) PWM Comparison 0 Value Update Register
Definition: component_pwm.h:96
(Pwm Offset: 0x144) PWM Comparison 1 Value Update Register
Definition: component_pwm.h:100
(Pwm Offset: 0x130) PWM Comparison 0 Value Register
Definition: component_pwm.h:95
(Pwm Offset: 0x1A0) PWM Comparison 7 Value Register
Definition: component_pwm.h:123
(Pwm Offset: 0x16C) PWM Comparison 3 Mode Update Register
Definition: component_pwm.h:110
(Pwm Offset: 0x154) PWM Comparison 2 Value Update Register
Definition: component_pwm.h:104
(Pwm Offset: 0x148) PWM Comparison 1 Mode Register
Definition: component_pwm.h:101
(Pwm Offset: 0x194) PWM Comparison 6 Value Update Register
Definition: component_pwm.h:120
(Pwm Offset: 0x150) PWM Comparison 2 Value Register
Definition: component_pwm.h:103
(Pwm Offset: 0x14C) PWM Comparison 1 Mode Update Register
Definition: component_pwm.h:102
(Pwm Offset: 0x158) PWM Comparison 2 Mode Register
Definition: component_pwm.h:105
(Pwm Offset: 0x180) PWM Comparison 5 Value Register
Definition: component_pwm.h:115
(Pwm Offset: 0x160) PWM Comparison 3 Value Register
Definition: component_pwm.h:107
PwmCh_num hardware registers.
Definition: component_pwm.h:41
(Pwm Offset: 0x17C) PWM Comparison 4 Mode Update Register
Definition: component_pwm.h:114
(Pwm Offset: 0x198) PWM Comparison 6 Mode Register
Definition: component_pwm.h:121
(Pwm Offset: 0x15C) PWM Comparison 2 Mode Update Register
Definition: component_pwm.h:106
(Pwm Offset: 0x190) PWM Comparison 6 Value Register
Definition: component_pwm.h:119
(Pwm Offset: 0x174) PWM Comparison 4 Value Update Register
Definition: component_pwm.h:112
#define __I
Definition: core_cm7.h:284
