RTEMS  5.1
component_efc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_EFC_COMPONENT_
31 #define _SAMS70_EFC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t EEFC_FMR;
43  __O uint32_t EEFC_FCR;
44  __I uint32_t EEFC_FSR;
45  __I uint32_t EEFC_FRR;
46  __I uint32_t Reserved1[53];
47  __IO uint32_t EEFC_WPMR;
48 } Efc;
49 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
50 /* -------- EEFC_FMR : (EFC Offset: 0x00) EEFC Flash Mode Register -------- */
51 #define EEFC_FMR_FRDY (0x1u << 0)
52 #define EEFC_FMR_FWS_Pos 8
53 #define EEFC_FMR_FWS_Msk (0xfu << EEFC_FMR_FWS_Pos)
54 #define EEFC_FMR_FWS(value) ((EEFC_FMR_FWS_Msk & ((value) << EEFC_FMR_FWS_Pos)))
55 #define EEFC_FMR_SCOD (0x1u << 16)
56 #define EEFC_FMR_CLOE (0x1u << 26)
57 /* -------- EEFC_FCR : (EFC Offset: 0x04) EEFC Flash Command Register -------- */
58 #define EEFC_FCR_FCMD_Pos 0
59 #define EEFC_FCR_FCMD_Msk (0xffu << EEFC_FCR_FCMD_Pos)
60 #define EEFC_FCR_FCMD(value) ((EEFC_FCR_FCMD_Msk & ((value) << EEFC_FCR_FCMD_Pos)))
61 #define EEFC_FCR_FCMD_GETD (0x0u << 0)
62 #define EEFC_FCR_FCMD_WP (0x1u << 0)
63 #define EEFC_FCR_FCMD_WPL (0x2u << 0)
64 #define EEFC_FCR_FCMD_EWP (0x3u << 0)
65 #define EEFC_FCR_FCMD_EWPL (0x4u << 0)
66 #define EEFC_FCR_FCMD_EA (0x5u << 0)
67 #define EEFC_FCR_FCMD_EPA (0x7u << 0)
68 #define EEFC_FCR_FCMD_SLB (0x8u << 0)
69 #define EEFC_FCR_FCMD_CLB (0x9u << 0)
70 #define EEFC_FCR_FCMD_GLB (0xAu << 0)
71 #define EEFC_FCR_FCMD_SGPB (0xBu << 0)
72 #define EEFC_FCR_FCMD_CGPB (0xCu << 0)
73 #define EEFC_FCR_FCMD_GGPB (0xDu << 0)
74 #define EEFC_FCR_FCMD_STUI (0xEu << 0)
75 #define EEFC_FCR_FCMD_SPUI (0xFu << 0)
76 #define EEFC_FCR_FCMD_GCALB (0x10u << 0)
77 #define EEFC_FCR_FCMD_ES (0x11u << 0)
78 #define EEFC_FCR_FCMD_WUS (0x12u << 0)
79 #define EEFC_FCR_FCMD_EUS (0x13u << 0)
80 #define EEFC_FCR_FCMD_STUS (0x14u << 0)
81 #define EEFC_FCR_FCMD_SPUS (0x15u << 0)
82 #define EEFC_FCR_FARG_Pos 8
83 #define EEFC_FCR_FARG_Msk (0xffffu << EEFC_FCR_FARG_Pos)
84 #define EEFC_FCR_FARG(value) ((EEFC_FCR_FARG_Msk & ((value) << EEFC_FCR_FARG_Pos)))
85 #define EEFC_FCR_FKEY_Pos 24
86 #define EEFC_FCR_FKEY_Msk (0xffu << EEFC_FCR_FKEY_Pos)
87 #define EEFC_FCR_FKEY(value) ((EEFC_FCR_FKEY_Msk & ((value) << EEFC_FCR_FKEY_Pos)))
88 #define EEFC_FCR_FKEY_PASSWD (0x5Au << 24)
89 /* -------- EEFC_FSR : (EFC Offset: 0x08) EEFC Flash Status Register -------- */
90 #define EEFC_FSR_FRDY (0x1u << 0)
91 #define EEFC_FSR_FCMDE (0x1u << 1)
92 #define EEFC_FSR_FLOCKE (0x1u << 2)
93 #define EEFC_FSR_FLERR (0x1u << 3)
94 #define EEFC_FSR_UECCELSB (0x1u << 16)
95 #define EEFC_FSR_MECCELSB (0x1u << 17)
96 #define EEFC_FSR_UECCEMSB (0x1u << 18)
97 #define EEFC_FSR_MECCEMSB (0x1u << 19)
98 /* -------- EEFC_FRR : (EFC Offset: 0x0C) EEFC Flash Result Register -------- */
99 #define EEFC_FRR_FVALUE_Pos 0
100 #define EEFC_FRR_FVALUE_Msk (0xffffffffu << EEFC_FRR_FVALUE_Pos)
101 /* -------- EEFC_WPMR : (EFC Offset: 0xE4) Write Protection Mode Register -------- */
102 #define EEFC_WPMR_WPEN (0x1u << 0)
103 #define EEFC_WPMR_WPKEY_Pos 8
104 #define EEFC_WPMR_WPKEY_Msk (0xffffffu << EEFC_WPMR_WPKEY_Pos)
105 #define EEFC_WPMR_WPKEY(value) ((EEFC_WPMR_WPKEY_Msk & ((value) << EEFC_WPMR_WPKEY_Pos)))
106 #define EEFC_WPMR_WPKEY_PASSWD (0x454643u << 8)
109
110
111 #endif /* _SAMS70_EFC_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Efc hardware registers.
Definition: component_efc.h:41
#define __I
Definition: core_cm7.h:284
