RTEMS  5.1
component_utmi.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_UTMI_COMPONENT_
31 #define _SAME70_UTMI_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __I uint32_t Reserved1[4];
43  __IO uint32_t UTMI_OHCIICR;
44  __I uint32_t Reserved2[7];
45  __IO uint32_t UTMI_CKTRIM;
46 } Utmi;
47 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
48 /* -------- UTMI_OHCIICR : (UTMI Offset: 0x10) OHCI Interrupt Configuration Register -------- */
49 #define UTMI_OHCIICR_RES0 (0x1u << 0)
50 #define UTMI_OHCIICR_ARIE (0x1u << 4)
51 #define UTMI_OHCIICR_APPSTART (0x1u << 5)
52 #define UTMI_OHCIICR_UDPPUDIS (0x1u << 23)
53 /* -------- UTMI_CKTRIM : (UTMI Offset: 0x30) UTMI Clock Trimming Register -------- */
54 #define UTMI_CKTRIM_FREQ_Pos 0
55 #define UTMI_CKTRIM_FREQ_Msk (0x3u << UTMI_CKTRIM_FREQ_Pos)
56 #define UTMI_CKTRIM_FREQ(value) ((UTMI_CKTRIM_FREQ_Msk & ((value) << UTMI_CKTRIM_FREQ_Pos)))
57 #define UTMI_CKTRIM_FREQ_XTAL12 (0x0u << 0)
58 #define UTMI_CKTRIM_FREQ_XTAL16 (0x1u << 0)
61
62
63 #endif /* _SAME70_UTMI_COMPONENT_ */
(Utmi Offset: 0x30) UTMI Clock Trimming Register
Definition: component_utmi.h:45
Utmi hardware registers.
Definition: component_utmi.h:41
#define __IO
Definition: core_cm7.h:287
(Utmi Offset: 0x10) OHCI Interrupt Configuration Register
Definition: component_utmi.h:43
#define __I
Definition: core_cm7.h:284
