RTEMS  5.1
component_supc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_SUPC_COMPONENT_
31 #define _SAME70_SUPC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t SUPC_CR;
43  __IO uint32_t SUPC_SMMR;
44  __IO uint32_t SUPC_MR;
45  __IO uint32_t SUPC_WUMR;
46  __IO uint32_t SUPC_WUIR;
47  __I uint32_t SUPC_SR;
48 } Supc;
49 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
50 /* -------- SUPC_CR : (SUPC Offset: 0x00) Supply Controller Control Register -------- */
51 #define SUPC_CR_VROFF (0x1u << 2)
52 #define SUPC_CR_VROFF_NO_EFFECT (0x0u << 2)
53 #define SUPC_CR_VROFF_STOP_VREG (0x1u << 2)
54 #define SUPC_CR_XTALSEL (0x1u << 3)
55 #define SUPC_CR_XTALSEL_NO_EFFECT (0x0u << 3)
56 #define SUPC_CR_XTALSEL_CRYSTAL_SEL (0x1u << 3)
57 #define SUPC_CR_KEY_Pos 24
58 #define SUPC_CR_KEY_Msk (0xffu << SUPC_CR_KEY_Pos)
59 #define SUPC_CR_KEY(value) ((SUPC_CR_KEY_Msk & ((value) << SUPC_CR_KEY_Pos)))
60 #define SUPC_CR_KEY_PASSWD (0xA5u << 24)
61 /* -------- SUPC_SMMR : (SUPC Offset: 0x04) Supply Controller Supply Monitor Mode Register -------- */
62 #define SUPC_SMMR_SMTH_Pos 0
63 #define SUPC_SMMR_SMTH_Msk (0xfu << SUPC_SMMR_SMTH_Pos)
64 #define SUPC_SMMR_SMTH(value) ((SUPC_SMMR_SMTH_Msk & ((value) << SUPC_SMMR_SMTH_Pos)))
65 #define SUPC_SMMR_SMSMPL_Pos 8
66 #define SUPC_SMMR_SMSMPL_Msk (0x7u << SUPC_SMMR_SMSMPL_Pos)
67 #define SUPC_SMMR_SMSMPL(value) ((SUPC_SMMR_SMSMPL_Msk & ((value) << SUPC_SMMR_SMSMPL_Pos)))
68 #define SUPC_SMMR_SMSMPL_SMD (0x0u << 8)
69 #define SUPC_SMMR_SMSMPL_CSM (0x1u << 8)
70 #define SUPC_SMMR_SMSMPL_32SLCK (0x2u << 8)
71 #define SUPC_SMMR_SMSMPL_256SLCK (0x3u << 8)
72 #define SUPC_SMMR_SMSMPL_2048SLCK (0x4u << 8)
73 #define SUPC_SMMR_SMRSTEN (0x1u << 12)
74 #define SUPC_SMMR_SMRSTEN_NOT_ENABLE (0x0u << 12)
75 #define SUPC_SMMR_SMRSTEN_ENABLE (0x1u << 12)
76 #define SUPC_SMMR_SMIEN (0x1u << 13)
77 #define SUPC_SMMR_SMIEN_NOT_ENABLE (0x0u << 13)
78 #define SUPC_SMMR_SMIEN_ENABLE (0x1u << 13)
79 /* -------- SUPC_MR : (SUPC Offset: 0x08) Supply Controller Mode Register -------- */
80 #define SUPC_MR_BODRSTEN (0x1u << 12)
81 #define SUPC_MR_BODRSTEN_NOT_ENABLE (0x0u << 12)
82 #define SUPC_MR_BODRSTEN_ENABLE (0x1u << 12)
83 #define SUPC_MR_BODDIS (0x1u << 13)
84 #define SUPC_MR_BODDIS_ENABLE (0x0u << 13)
85 #define SUPC_MR_BODDIS_DISABLE (0x1u << 13)
86 #define SUPC_MR_ONREG (0x1u << 14)
87 #define SUPC_MR_ONREG_ONREG_UNUSED (0x0u << 14)
88 #define SUPC_MR_ONREG_ONREG_USED (0x1u << 14)
89 #define SUPC_MR_BKUPRETON (0x1u << 17)
90 #define SUPC_MR_OSCBYPASS (0x1u << 20)
91 #define SUPC_MR_OSCBYPASS_NO_EFFECT (0x0u << 20)
92 #define SUPC_MR_OSCBYPASS_BYPASS (0x1u << 20)
93 #define SUPC_MR_KEY_Pos 24
94 #define SUPC_MR_KEY_Msk (0xffu << SUPC_MR_KEY_Pos)
95 #define SUPC_MR_KEY(value) ((SUPC_MR_KEY_Msk & ((value) << SUPC_MR_KEY_Pos)))
96 #define SUPC_MR_KEY_PASSWD (0xA5u << 24)
97 /* -------- SUPC_WUMR : (SUPC Offset: 0x0C) Supply Controller Wake-up Mode Register -------- */
98 #define SUPC_WUMR_SMEN (0x1u << 1)
99 #define SUPC_WUMR_SMEN_NOT_ENABLE (0x0u << 1)
100 #define SUPC_WUMR_SMEN_ENABLE (0x1u << 1)
101 #define SUPC_WUMR_RTTEN (0x1u << 2)
102 #define SUPC_WUMR_RTTEN_NOT_ENABLE (0x0u << 2)
103 #define SUPC_WUMR_RTTEN_ENABLE (0x1u << 2)
104 #define SUPC_WUMR_RTCEN (0x1u << 3)
105 #define SUPC_WUMR_RTCEN_NOT_ENABLE (0x0u << 3)
106 #define SUPC_WUMR_RTCEN_ENABLE (0x1u << 3)
107 #define SUPC_WUMR_LPDBCEN0 (0x1u << 5)
108 #define SUPC_WUMR_LPDBCEN0_NOT_ENABLE (0x0u << 5)
109 #define SUPC_WUMR_LPDBCEN0_ENABLE (0x1u << 5)
110 #define SUPC_WUMR_LPDBCEN1 (0x1u << 6)
111 #define SUPC_WUMR_LPDBCEN1_NOT_ENABLE (0x0u << 6)
112 #define SUPC_WUMR_LPDBCEN1_ENABLE (0x1u << 6)
113 #define SUPC_WUMR_LPDBCCLR (0x1u << 7)
114 #define SUPC_WUMR_LPDBCCLR_NOT_ENABLE (0x0u << 7)
115 #define SUPC_WUMR_LPDBCCLR_ENABLE (0x1u << 7)
116 #define SUPC_WUMR_WKUPDBC_Pos 12
117 #define SUPC_WUMR_WKUPDBC_Msk (0x7u << SUPC_WUMR_WKUPDBC_Pos)
118 #define SUPC_WUMR_WKUPDBC(value) ((SUPC_WUMR_WKUPDBC_Msk & ((value) << SUPC_WUMR_WKUPDBC_Pos)))
119 #define SUPC_WUMR_WKUPDBC_IMMEDIATE (0x0u << 12)
120 #define SUPC_WUMR_WKUPDBC_3_SLCK (0x1u << 12)
121 #define SUPC_WUMR_WKUPDBC_32_SLCK (0x2u << 12)
122 #define SUPC_WUMR_WKUPDBC_512_SLCK (0x3u << 12)
123 #define SUPC_WUMR_WKUPDBC_4096_SLCK (0x4u << 12)
124 #define SUPC_WUMR_WKUPDBC_32768_SLCK (0x5u << 12)
125 #define SUPC_WUMR_LPDBC_Pos 16
126 #define SUPC_WUMR_LPDBC_Msk (0x7u << SUPC_WUMR_LPDBC_Pos)
127 #define SUPC_WUMR_LPDBC(value) ((SUPC_WUMR_LPDBC_Msk & ((value) << SUPC_WUMR_LPDBC_Pos)))
128 #define SUPC_WUMR_LPDBC_DISABLE (0x0u << 16)
129 #define SUPC_WUMR_LPDBC_2_RTCOUT (0x1u << 16)
130 #define SUPC_WUMR_LPDBC_3_RTCOUT (0x2u << 16)
131 #define SUPC_WUMR_LPDBC_4_RTCOUT (0x3u << 16)
132 #define SUPC_WUMR_LPDBC_5_RTCOUT (0x4u << 16)
133 #define SUPC_WUMR_LPDBC_6_RTCOUT (0x5u << 16)
134 #define SUPC_WUMR_LPDBC_7_RTCOUT (0x6u << 16)
135 #define SUPC_WUMR_LPDBC_8_RTCOUT (0x7u << 16)
136 /* -------- SUPC_WUIR : (SUPC Offset: 0x10) Supply Controller Wake-up Inputs Register -------- */
137 #define SUPC_WUIR_WKUPEN0 (0x1u << 0)
138 #define SUPC_WUIR_WKUPEN0_DISABLE (0x0u << 0)
139 #define SUPC_WUIR_WKUPEN0_ENABLE (0x1u << 0)
140 #define SUPC_WUIR_WKUPEN1 (0x1u << 1)
141 #define SUPC_WUIR_WKUPEN1_DISABLE (0x0u << 1)
142 #define SUPC_WUIR_WKUPEN1_ENABLE (0x1u << 1)
143 #define SUPC_WUIR_WKUPEN2 (0x1u << 2)
144 #define SUPC_WUIR_WKUPEN2_DISABLE (0x0u << 2)
145 #define SUPC_WUIR_WKUPEN2_ENABLE (0x1u << 2)
146 #define SUPC_WUIR_WKUPEN3 (0x1u << 3)
147 #define SUPC_WUIR_WKUPEN3_DISABLE (0x0u << 3)
148 #define SUPC_WUIR_WKUPEN3_ENABLE (0x1u << 3)
149 #define SUPC_WUIR_WKUPEN4 (0x1u << 4)
150 #define SUPC_WUIR_WKUPEN4_DISABLE (0x0u << 4)
151 #define SUPC_WUIR_WKUPEN4_ENABLE (0x1u << 4)
152 #define SUPC_WUIR_WKUPEN5 (0x1u << 5)
153 #define SUPC_WUIR_WKUPEN5_DISABLE (0x0u << 5)
154 #define SUPC_WUIR_WKUPEN5_ENABLE (0x1u << 5)
155 #define SUPC_WUIR_WKUPEN6 (0x1u << 6)
156 #define SUPC_WUIR_WKUPEN6_DISABLE (0x0u << 6)
157 #define SUPC_WUIR_WKUPEN6_ENABLE (0x1u << 6)
158 #define SUPC_WUIR_WKUPEN7 (0x1u << 7)
159 #define SUPC_WUIR_WKUPEN7_DISABLE (0x0u << 7)
160 #define SUPC_WUIR_WKUPEN7_ENABLE (0x1u << 7)
161 #define SUPC_WUIR_WKUPEN8 (0x1u << 8)
162 #define SUPC_WUIR_WKUPEN8_DISABLE (0x0u << 8)
163 #define SUPC_WUIR_WKUPEN8_ENABLE (0x1u << 8)
164 #define SUPC_WUIR_WKUPEN9 (0x1u << 9)
165 #define SUPC_WUIR_WKUPEN9_DISABLE (0x0u << 9)
166 #define SUPC_WUIR_WKUPEN9_ENABLE (0x1u << 9)
167 #define SUPC_WUIR_WKUPEN10 (0x1u << 10)
168 #define SUPC_WUIR_WKUPEN10_DISABLE (0x0u << 10)
169 #define SUPC_WUIR_WKUPEN10_ENABLE (0x1u << 10)
170 #define SUPC_WUIR_WKUPEN11 (0x1u << 11)
171 #define SUPC_WUIR_WKUPEN11_DISABLE (0x0u << 11)
172 #define SUPC_WUIR_WKUPEN11_ENABLE (0x1u << 11)
173 #define SUPC_WUIR_WKUPEN12 (0x1u << 12)
174 #define SUPC_WUIR_WKUPEN12_DISABLE (0x0u << 12)
175 #define SUPC_WUIR_WKUPEN12_ENABLE (0x1u << 12)
176 #define SUPC_WUIR_WKUPEN13 (0x1u << 13)
177 #define SUPC_WUIR_WKUPEN13_DISABLE (0x0u << 13)
178 #define SUPC_WUIR_WKUPEN13_ENABLE (0x1u << 13)
179 #define SUPC_WUIR_WKUPT0 (0x1u << 16)
180 #define SUPC_WUIR_WKUPT0_LOW (0x0u << 16)
181 #define SUPC_WUIR_WKUPT0_HIGH (0x1u << 16)
182 #define SUPC_WUIR_WKUPT1 (0x1u << 17)
183 #define SUPC_WUIR_WKUPT1_LOW (0x0u << 17)
184 #define SUPC_WUIR_WKUPT1_HIGH (0x1u << 17)
185 #define SUPC_WUIR_WKUPT2 (0x1u << 18)
186 #define SUPC_WUIR_WKUPT2_LOW (0x0u << 18)
187 #define SUPC_WUIR_WKUPT2_HIGH (0x1u << 18)
188 #define SUPC_WUIR_WKUPT3 (0x1u << 19)
189 #define SUPC_WUIR_WKUPT3_LOW (0x0u << 19)
190 #define SUPC_WUIR_WKUPT3_HIGH (0x1u << 19)
191 #define SUPC_WUIR_WKUPT4 (0x1u << 20)
192 #define SUPC_WUIR_WKUPT4_LOW (0x0u << 20)
193 #define SUPC_WUIR_WKUPT4_HIGH (0x1u << 20)
194 #define SUPC_WUIR_WKUPT5 (0x1u << 21)
195 #define SUPC_WUIR_WKUPT5_LOW (0x0u << 21)
196 #define SUPC_WUIR_WKUPT5_HIGH (0x1u << 21)
197 #define SUPC_WUIR_WKUPT6 (0x1u << 22)
198 #define SUPC_WUIR_WKUPT6_LOW (0x0u << 22)
199 #define SUPC_WUIR_WKUPT6_HIGH (0x1u << 22)
200 #define SUPC_WUIR_WKUPT7 (0x1u << 23)
201 #define SUPC_WUIR_WKUPT7_LOW (0x0u << 23)
202 #define SUPC_WUIR_WKUPT7_HIGH (0x1u << 23)
203 #define SUPC_WUIR_WKUPT8 (0x1u << 24)
204 #define SUPC_WUIR_WKUPT8_LOW (0x0u << 24)
205 #define SUPC_WUIR_WKUPT8_HIGH (0x1u << 24)
206 #define SUPC_WUIR_WKUPT9 (0x1u << 25)
207 #define SUPC_WUIR_WKUPT9_LOW (0x0u << 25)
208 #define SUPC_WUIR_WKUPT9_HIGH (0x1u << 25)
209 #define SUPC_WUIR_WKUPT10 (0x1u << 26)
210 #define SUPC_WUIR_WKUPT10_LOW (0x0u << 26)
211 #define SUPC_WUIR_WKUPT10_HIGH (0x1u << 26)
212 #define SUPC_WUIR_WKUPT11 (0x1u << 27)
213 #define SUPC_WUIR_WKUPT11_LOW (0x0u << 27)
214 #define SUPC_WUIR_WKUPT11_HIGH (0x1u << 27)
215 #define SUPC_WUIR_WKUPT12 (0x1u << 28)
216 #define SUPC_WUIR_WKUPT12_LOW (0x0u << 28)
217 #define SUPC_WUIR_WKUPT12_HIGH (0x1u << 28)
218 #define SUPC_WUIR_WKUPT13 (0x1u << 29)
219 #define SUPC_WUIR_WKUPT13_LOW (0x0u << 29)
220 #define SUPC_WUIR_WKUPT13_HIGH (0x1u << 29)
221 /* -------- SUPC_SR : (SUPC Offset: 0x14) Supply Controller Status Register -------- */
222 #define SUPC_SR_WKUPS (0x1u << 1)
223 #define SUPC_SR_WKUPS_NO (0x0u << 1)
224 #define SUPC_SR_WKUPS_PRESENT (0x1u << 1)
225 #define SUPC_SR_SMWS (0x1u << 2)
226 #define SUPC_SR_SMWS_NO (0x0u << 2)
227 #define SUPC_SR_SMWS_PRESENT (0x1u << 2)
228 #define SUPC_SR_BODRSTS (0x1u << 3)
229 #define SUPC_SR_BODRSTS_NO (0x0u << 3)
230 #define SUPC_SR_BODRSTS_PRESENT (0x1u << 3)
231 #define SUPC_SR_SMRSTS (0x1u << 4)
232 #define SUPC_SR_SMRSTS_NO (0x0u << 4)
233 #define SUPC_SR_SMRSTS_PRESENT (0x1u << 4)
234 #define SUPC_SR_SMS (0x1u << 5)
235 #define SUPC_SR_SMS_NO (0x0u << 5)
236 #define SUPC_SR_SMS_PRESENT (0x1u << 5)
237 #define SUPC_SR_SMOS (0x1u << 6)
238 #define SUPC_SR_SMOS_HIGH (0x0u << 6)
239 #define SUPC_SR_SMOS_LOW (0x1u << 6)
240 #define SUPC_SR_OSCSEL (0x1u << 7)
241 #define SUPC_SR_OSCSEL_RC (0x0u << 7)
242 #define SUPC_SR_OSCSEL_CRYST (0x1u << 7)
243 #define SUPC_SR_LPDBCS0 (0x1u << 13)
244 #define SUPC_SR_LPDBCS0_NO (0x0u << 13)
245 #define SUPC_SR_LPDBCS0_PRESENT (0x1u << 13)
246 #define SUPC_SR_LPDBCS1 (0x1u << 14)
247 #define SUPC_SR_LPDBCS1_NO (0x0u << 14)
248 #define SUPC_SR_LPDBCS1_PRESENT (0x1u << 14)
249 #define SUPC_SR_WKUPIS0 (0x1u << 16)
250 #define SUPC_SR_WKUPIS0_DIS (0x0u << 16)
251 #define SUPC_SR_WKUPIS0_EN (0x1u << 16)
252 #define SUPC_SR_WKUPIS1 (0x1u << 17)
253 #define SUPC_SR_WKUPIS1_DIS (0x0u << 17)
254 #define SUPC_SR_WKUPIS1_EN (0x1u << 17)
255 #define SUPC_SR_WKUPIS2 (0x1u << 18)
256 #define SUPC_SR_WKUPIS2_DIS (0x0u << 18)
257 #define SUPC_SR_WKUPIS2_EN (0x1u << 18)
258 #define SUPC_SR_WKUPIS3 (0x1u << 19)
259 #define SUPC_SR_WKUPIS3_DIS (0x0u << 19)
260 #define SUPC_SR_WKUPIS3_EN (0x1u << 19)
261 #define SUPC_SR_WKUPIS4 (0x1u << 20)
262 #define SUPC_SR_WKUPIS4_DIS (0x0u << 20)
263 #define SUPC_SR_WKUPIS4_EN (0x1u << 20)
264 #define SUPC_SR_WKUPIS5 (0x1u << 21)
265 #define SUPC_SR_WKUPIS5_DIS (0x0u << 21)
266 #define SUPC_SR_WKUPIS5_EN (0x1u << 21)
267 #define SUPC_SR_WKUPIS6 (0x1u << 22)
268 #define SUPC_SR_WKUPIS6_DIS (0x0u << 22)
269 #define SUPC_SR_WKUPIS6_EN (0x1u << 22)
270 #define SUPC_SR_WKUPIS7 (0x1u << 23)
271 #define SUPC_SR_WKUPIS7_DIS (0x0u << 23)
272 #define SUPC_SR_WKUPIS7_EN (0x1u << 23)
273 #define SUPC_SR_WKUPIS8 (0x1u << 24)
274 #define SUPC_SR_WKUPIS8_DIS (0x0u << 24)
275 #define SUPC_SR_WKUPIS8_EN (0x1u << 24)
276 #define SUPC_SR_WKUPIS9 (0x1u << 25)
277 #define SUPC_SR_WKUPIS9_DIS (0x0u << 25)
278 #define SUPC_SR_WKUPIS9_EN (0x1u << 25)
279 #define SUPC_SR_WKUPIS10 (0x1u << 26)
280 #define SUPC_SR_WKUPIS10_DIS (0x0u << 26)
281 #define SUPC_SR_WKUPIS10_EN (0x1u << 26)
282 #define SUPC_SR_WKUPIS11 (0x1u << 27)
283 #define SUPC_SR_WKUPIS11_DIS (0x0u << 27)
284 #define SUPC_SR_WKUPIS11_EN (0x1u << 27)
285 #define SUPC_SR_WKUPIS12 (0x1u << 28)
286 #define SUPC_SR_WKUPIS12_DIS (0x0u << 28)
287 #define SUPC_SR_WKUPIS12_EN (0x1u << 28)
288 #define SUPC_SR_WKUPIS13 (0x1u << 29)
289 #define SUPC_SR_WKUPIS13_DIS (0x0u << 29)
290 #define SUPC_SR_WKUPIS13_EN (0x1u << 29)
293
294
295 #endif /* _SAME70_SUPC_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Supc hardware registers.
Definition: component_supc.h:41
(Supc Offset: 0x00) Supply Controller Control Register
Definition: component_supc.h:42
(Supc Offset: 0x10) Supply Controller Wake-up Inputs Register
Definition: component_supc.h:46
(Supc Offset: 0x04) Supply Controller Supply Monitor Mode Register
Definition: component_supc.h:43
(Supc Offset: 0x08) Supply Controller Mode Register
Definition: component_supc.h:44
(Supc Offset: 0x0C) Supply Controller Wake-up Mode Register
Definition: component_supc.h:45
#define __I
Definition: core_cm7.h:284
(Supc Offset: 0x14) Supply Controller Status Register
Definition: component_supc.h:47
