RTEMS  5.1
component_matrix.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_MATRIX_COMPONENT_
31 #define _SAME70_MATRIX_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t MATRIX_PRAS;
43  __IO uint32_t MATRIX_PRBS;
44 } MatrixPr;
46 #define MATRIXPR_NUMBER 9
47 typedef struct {
48  __IO uint32_t MATRIX_MCFG0;
49  __IO uint32_t MATRIX_MCFG1;
50  __IO uint32_t MATRIX_MCFG2;
51  __IO uint32_t MATRIX_MCFG3;
52  __IO uint32_t MATRIX_MCFG4;
53  __IO uint32_t MATRIX_MCFG5;
54  __IO uint32_t MATRIX_MCFG6;
55  __I uint32_t Reserved1[1];
56  __IO uint32_t MATRIX_MCFG8;
57  __IO uint32_t MATRIX_MCFG9;
58  __IO uint32_t MATRIX_MCFG10;
59  __IO uint32_t MATRIX_MCFG11;
60  __I uint32_t Reserved2[4];
61  __IO uint32_t MATRIX_SCFG[9];
62  __I uint32_t Reserved3[7];
64  __I uint32_t Reserved4[14];
65  __IO uint32_t MATRIX_MRCR;
66  __I uint32_t Reserved5[3];
67  __IO uint32_t CCFG_CAN0;
68  __IO uint32_t CCFG_SYSIO;
69  __I uint32_t Reserved6[3];
70  __IO uint32_t CCFG_SMCNFCS;
71  __I uint32_t Reserved7[47];
72  __IO uint32_t MATRIX_WPMR;
73  __I uint32_t MATRIX_WPSR;
74 } Matrix;
75 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
76 /* -------- MATRIX_MCFG0 : (MATRIX Offset: 0x0000) Master Configuration Register 0 -------- */
77 #define MATRIX_MCFG0_ULBT_Pos 0
78 #define MATRIX_MCFG0_ULBT_Msk (0x7u << MATRIX_MCFG0_ULBT_Pos)
79 #define MATRIX_MCFG0_ULBT(value) ((MATRIX_MCFG0_ULBT_Msk & ((value) << MATRIX_MCFG0_ULBT_Pos)))
80 #define MATRIX_MCFG0_ULBT_UNLTD_LENGTH (0x0u << 0)
81 #define MATRIX_MCFG0_ULBT_SINGLE_ACCESS (0x1u << 0)
82 #define MATRIX_MCFG0_ULBT_4BEAT_BURST (0x2u << 0)
83 #define MATRIX_MCFG0_ULBT_8BEAT_BURST (0x3u << 0)
84 #define MATRIX_MCFG0_ULBT_16BEAT_BURST (0x4u << 0)
85 #define MATRIX_MCFG0_ULBT_32BEAT_BURST (0x5u << 0)
86 #define MATRIX_MCFG0_ULBT_64BEAT_BURST (0x6u << 0)
87 #define MATRIX_MCFG0_ULBT_128BEAT_BURST (0x7u << 0)
88 /* -------- MATRIX_MCFG1 : (MATRIX Offset: 0x0004) Master Configuration Register 1 -------- */
89 #define MATRIX_MCFG1_ULBT_Pos 0
90 #define MATRIX_MCFG1_ULBT_Msk (0x7u << MATRIX_MCFG1_ULBT_Pos)
91 #define MATRIX_MCFG1_ULBT(value) ((MATRIX_MCFG1_ULBT_Msk & ((value) << MATRIX_MCFG1_ULBT_Pos)))
92 #define MATRIX_MCFG1_ULBT_UNLTD_LENGTH (0x0u << 0)
93 #define MATRIX_MCFG1_ULBT_SINGLE_ACCESS (0x1u << 0)
94 #define MATRIX_MCFG1_ULBT_4BEAT_BURST (0x2u << 0)
95 #define MATRIX_MCFG1_ULBT_8BEAT_BURST (0x3u << 0)
96 #define MATRIX_MCFG1_ULBT_16BEAT_BURST (0x4u << 0)
97 #define MATRIX_MCFG1_ULBT_32BEAT_BURST (0x5u << 0)
98 #define MATRIX_MCFG1_ULBT_64BEAT_BURST (0x6u << 0)
99 #define MATRIX_MCFG1_ULBT_128BEAT_BURST (0x7u << 0)
100 /* -------- MATRIX_MCFG2 : (MATRIX Offset: 0x0008) Master Configuration Register 2 -------- */
101 #define MATRIX_MCFG2_ULBT_Pos 0
102 #define MATRIX_MCFG2_ULBT_Msk (0x7u << MATRIX_MCFG2_ULBT_Pos)
103 #define MATRIX_MCFG2_ULBT(value) ((MATRIX_MCFG2_ULBT_Msk & ((value) << MATRIX_MCFG2_ULBT_Pos)))
104 #define MATRIX_MCFG2_ULBT_UNLTD_LENGTH (0x0u << 0)
105 #define MATRIX_MCFG2_ULBT_SINGLE_ACCESS (0x1u << 0)
106 #define MATRIX_MCFG2_ULBT_4BEAT_BURST (0x2u << 0)
107 #define MATRIX_MCFG2_ULBT_8BEAT_BURST (0x3u << 0)
108 #define MATRIX_MCFG2_ULBT_16BEAT_BURST (0x4u << 0)
109 #define MATRIX_MCFG2_ULBT_32BEAT_BURST (0x5u << 0)
110 #define MATRIX_MCFG2_ULBT_64BEAT_BURST (0x6u << 0)
111 #define MATRIX_MCFG2_ULBT_128BEAT_BURST (0x7u << 0)
112 /* -------- MATRIX_MCFG3 : (MATRIX Offset: 0x000C) Master Configuration Register 3 -------- */
113 #define MATRIX_MCFG3_ULBT_Pos 0
114 #define MATRIX_MCFG3_ULBT_Msk (0x7u << MATRIX_MCFG3_ULBT_Pos)
115 #define MATRIX_MCFG3_ULBT(value) ((MATRIX_MCFG3_ULBT_Msk & ((value) << MATRIX_MCFG3_ULBT_Pos)))
116 #define MATRIX_MCFG3_ULBT_UNLTD_LENGTH (0x0u << 0)
117 #define MATRIX_MCFG3_ULBT_SINGLE_ACCESS (0x1u << 0)
118 #define MATRIX_MCFG3_ULBT_4BEAT_BURST (0x2u << 0)
119 #define MATRIX_MCFG3_ULBT_8BEAT_BURST (0x3u << 0)
120 #define MATRIX_MCFG3_ULBT_16BEAT_BURST (0x4u << 0)
121 #define MATRIX_MCFG3_ULBT_32BEAT_BURST (0x5u << 0)
122 #define MATRIX_MCFG3_ULBT_64BEAT_BURST (0x6u << 0)
123 #define MATRIX_MCFG3_ULBT_128BEAT_BURST (0x7u << 0)
124 /* -------- MATRIX_MCFG4 : (MATRIX Offset: 0x0010) Master Configuration Register 4 -------- */
125 #define MATRIX_MCFG4_ULBT_Pos 0
126 #define MATRIX_MCFG4_ULBT_Msk (0x7u << MATRIX_MCFG4_ULBT_Pos)
127 #define MATRIX_MCFG4_ULBT(value) ((MATRIX_MCFG4_ULBT_Msk & ((value) << MATRIX_MCFG4_ULBT_Pos)))
128 #define MATRIX_MCFG4_ULBT_UNLTD_LENGTH (0x0u << 0)
129 #define MATRIX_MCFG4_ULBT_SINGLE_ACCESS (0x1u << 0)
130 #define MATRIX_MCFG4_ULBT_4BEAT_BURST (0x2u << 0)
131 #define MATRIX_MCFG4_ULBT_8BEAT_BURST (0x3u << 0)
132 #define MATRIX_MCFG4_ULBT_16BEAT_BURST (0x4u << 0)
133 #define MATRIX_MCFG4_ULBT_32BEAT_BURST (0x5u << 0)
134 #define MATRIX_MCFG4_ULBT_64BEAT_BURST (0x6u << 0)
135 #define MATRIX_MCFG4_ULBT_128BEAT_BURST (0x7u << 0)
136 /* -------- MATRIX_MCFG5 : (MATRIX Offset: 0x0014) Master Configuration Register 5 -------- */
137 #define MATRIX_MCFG5_ULBT_Pos 0
138 #define MATRIX_MCFG5_ULBT_Msk (0x7u << MATRIX_MCFG5_ULBT_Pos)
139 #define MATRIX_MCFG5_ULBT(value) ((MATRIX_MCFG5_ULBT_Msk & ((value) << MATRIX_MCFG5_ULBT_Pos)))
140 #define MATRIX_MCFG5_ULBT_UNLTD_LENGTH (0x0u << 0)
141 #define MATRIX_MCFG5_ULBT_SINGLE_ACCESS (0x1u << 0)
142 #define MATRIX_MCFG5_ULBT_4BEAT_BURST (0x2u << 0)
143 #define MATRIX_MCFG5_ULBT_8BEAT_BURST (0x3u << 0)
144 #define MATRIX_MCFG5_ULBT_16BEAT_BURST (0x4u << 0)
145 #define MATRIX_MCFG5_ULBT_32BEAT_BURST (0x5u << 0)
146 #define MATRIX_MCFG5_ULBT_64BEAT_BURST (0x6u << 0)
147 #define MATRIX_MCFG5_ULBT_128BEAT_BURST (0x7u << 0)
148 /* -------- MATRIX_MCFG6 : (MATRIX Offset: 0x0018) Master Configuration Register 6 -------- */
149 #define MATRIX_MCFG6_ULBT_Pos 0
150 #define MATRIX_MCFG6_ULBT_Msk (0x7u << MATRIX_MCFG6_ULBT_Pos)
151 #define MATRIX_MCFG6_ULBT(value) ((MATRIX_MCFG6_ULBT_Msk & ((value) << MATRIX_MCFG6_ULBT_Pos)))
152 #define MATRIX_MCFG6_ULBT_UNLTD_LENGTH (0x0u << 0)
153 #define MATRIX_MCFG6_ULBT_SINGLE_ACCESS (0x1u << 0)
154 #define MATRIX_MCFG6_ULBT_4BEAT_BURST (0x2u << 0)
155 #define MATRIX_MCFG6_ULBT_8BEAT_BURST (0x3u << 0)
156 #define MATRIX_MCFG6_ULBT_16BEAT_BURST (0x4u << 0)
157 #define MATRIX_MCFG6_ULBT_32BEAT_BURST (0x5u << 0)
158 #define MATRIX_MCFG6_ULBT_64BEAT_BURST (0x6u << 0)
159 #define MATRIX_MCFG6_ULBT_128BEAT_BURST (0x7u << 0)
160 /* -------- MATRIX_MCFG8 : (MATRIX Offset: 0x0020) Master Configuration Register 8 -------- */
161 #define MATRIX_MCFG8_ULBT_Pos 0
162 #define MATRIX_MCFG8_ULBT_Msk (0x7u << MATRIX_MCFG8_ULBT_Pos)
163 #define MATRIX_MCFG8_ULBT(value) ((MATRIX_MCFG8_ULBT_Msk & ((value) << MATRIX_MCFG8_ULBT_Pos)))
164 #define MATRIX_MCFG8_ULBT_UNLTD_LENGTH (0x0u << 0)
165 #define MATRIX_MCFG8_ULBT_SINGLE_ACCESS (0x1u << 0)
166 #define MATRIX_MCFG8_ULBT_4BEAT_BURST (0x2u << 0)
167 #define MATRIX_MCFG8_ULBT_8BEAT_BURST (0x3u << 0)
168 #define MATRIX_MCFG8_ULBT_16BEAT_BURST (0x4u << 0)
169 #define MATRIX_MCFG8_ULBT_32BEAT_BURST (0x5u << 0)
170 #define MATRIX_MCFG8_ULBT_64BEAT_BURST (0x6u << 0)
171 #define MATRIX_MCFG8_ULBT_128BEAT_BURST (0x7u << 0)
172 /* -------- MATRIX_MCFG9 : (MATRIX Offset: 0x0024) Master Configuration Register 9 -------- */
173 #define MATRIX_MCFG9_ULBT_Pos 0
174 #define MATRIX_MCFG9_ULBT_Msk (0x7u << MATRIX_MCFG9_ULBT_Pos)
175 #define MATRIX_MCFG9_ULBT(value) ((MATRIX_MCFG9_ULBT_Msk & ((value) << MATRIX_MCFG9_ULBT_Pos)))
176 #define MATRIX_MCFG9_ULBT_UNLTD_LENGTH (0x0u << 0)
177 #define MATRIX_MCFG9_ULBT_SINGLE_ACCESS (0x1u << 0)
178 #define MATRIX_MCFG9_ULBT_4BEAT_BURST (0x2u << 0)
179 #define MATRIX_MCFG9_ULBT_8BEAT_BURST (0x3u << 0)
180 #define MATRIX_MCFG9_ULBT_16BEAT_BURST (0x4u << 0)
181 #define MATRIX_MCFG9_ULBT_32BEAT_BURST (0x5u << 0)
182 #define MATRIX_MCFG9_ULBT_64BEAT_BURST (0x6u << 0)
183 #define MATRIX_MCFG9_ULBT_128BEAT_BURST (0x7u << 0)
184 /* -------- MATRIX_MCFG10 : (MATRIX Offset: 0x0028) Master Configuration Register 10 -------- */
185 #define MATRIX_MCFG10_ULBT_Pos 0
186 #define MATRIX_MCFG10_ULBT_Msk (0x7u << MATRIX_MCFG10_ULBT_Pos)
187 #define MATRIX_MCFG10_ULBT(value) ((MATRIX_MCFG10_ULBT_Msk & ((value) << MATRIX_MCFG10_ULBT_Pos)))
188 #define MATRIX_MCFG10_ULBT_UNLTD_LENGTH (0x0u << 0)
189 #define MATRIX_MCFG10_ULBT_SINGLE_ACCESS (0x1u << 0)
190 #define MATRIX_MCFG10_ULBT_4BEAT_BURST (0x2u << 0)
191 #define MATRIX_MCFG10_ULBT_8BEAT_BURST (0x3u << 0)
192 #define MATRIX_MCFG10_ULBT_16BEAT_BURST (0x4u << 0)
193 #define MATRIX_MCFG10_ULBT_32BEAT_BURST (0x5u << 0)
194 #define MATRIX_MCFG10_ULBT_64BEAT_BURST (0x6u << 0)
195 #define MATRIX_MCFG10_ULBT_128BEAT_BURST (0x7u << 0)
196 /* -------- MATRIX_MCFG11 : (MATRIX Offset: 0x002C) Master Configuration Register 11 -------- */
197 #define MATRIX_MCFG11_ULBT_Pos 0
198 #define MATRIX_MCFG11_ULBT_Msk (0x7u << MATRIX_MCFG11_ULBT_Pos)
199 #define MATRIX_MCFG11_ULBT(value) ((MATRIX_MCFG11_ULBT_Msk & ((value) << MATRIX_MCFG11_ULBT_Pos)))
200 #define MATRIX_MCFG11_ULBT_UNLTD_LENGTH (0x0u << 0)
201 #define MATRIX_MCFG11_ULBT_SINGLE_ACCESS (0x1u << 0)
202 #define MATRIX_MCFG11_ULBT_4BEAT_BURST (0x2u << 0)
203 #define MATRIX_MCFG11_ULBT_8BEAT_BURST (0x3u << 0)
204 #define MATRIX_MCFG11_ULBT_16BEAT_BURST (0x4u << 0)
205 #define MATRIX_MCFG11_ULBT_32BEAT_BURST (0x5u << 0)
206 #define MATRIX_MCFG11_ULBT_64BEAT_BURST (0x6u << 0)
207 #define MATRIX_MCFG11_ULBT_128BEAT_BURST (0x7u << 0)
208 /* -------- MATRIX_SCFG[9] : (MATRIX Offset: 0x0040) Slave Configuration Register -------- */
209 #define MATRIX_SCFG_SLOT_CYCLE_Pos 0
210 #define MATRIX_SCFG_SLOT_CYCLE_Msk (0x1ffu << MATRIX_SCFG_SLOT_CYCLE_Pos)
211 #define MATRIX_SCFG_SLOT_CYCLE(value) ((MATRIX_SCFG_SLOT_CYCLE_Msk & ((value) << MATRIX_SCFG_SLOT_CYCLE_Pos)))
212 #define MATRIX_SCFG_DEFMSTR_TYPE_Pos 16
213 #define MATRIX_SCFG_DEFMSTR_TYPE_Msk (0x3u << MATRIX_SCFG_DEFMSTR_TYPE_Pos)
214 #define MATRIX_SCFG_DEFMSTR_TYPE(value) ((MATRIX_SCFG_DEFMSTR_TYPE_Msk & ((value) << MATRIX_SCFG_DEFMSTR_TYPE_Pos)))
215 #define MATRIX_SCFG_DEFMSTR_TYPE_NONE (0x0u << 16)
216 #define MATRIX_SCFG_DEFMSTR_TYPE_LAST (0x1u << 16)
217 #define MATRIX_SCFG_DEFMSTR_TYPE_FIXED (0x2u << 16)
218 #define MATRIX_SCFG_FIXED_DEFMSTR_Pos 18
219 #define MATRIX_SCFG_FIXED_DEFMSTR_Msk (0xfu << MATRIX_SCFG_FIXED_DEFMSTR_Pos)
220 #define MATRIX_SCFG_FIXED_DEFMSTR(value) ((MATRIX_SCFG_FIXED_DEFMSTR_Msk & ((value) << MATRIX_SCFG_FIXED_DEFMSTR_Pos)))
221 /* -------- MATRIX_PRAS : (MATRIX Offset: N/A) Priority Register A for Slave 0 -------- */
222 #define MATRIX_PRAS_M0PR_Pos 0
223 #define MATRIX_PRAS_M0PR_Msk (0x3u << MATRIX_PRAS_M0PR_Pos)
224 #define MATRIX_PRAS_M0PR(value) ((MATRIX_PRAS_M0PR_Msk & ((value) << MATRIX_PRAS_M0PR_Pos)))
225 #define MATRIX_PRAS_M1PR_Pos 4
226 #define MATRIX_PRAS_M1PR_Msk (0x3u << MATRIX_PRAS_M1PR_Pos)
227 #define MATRIX_PRAS_M1PR(value) ((MATRIX_PRAS_M1PR_Msk & ((value) << MATRIX_PRAS_M1PR_Pos)))
228 #define MATRIX_PRAS_M2PR_Pos 8
229 #define MATRIX_PRAS_M2PR_Msk (0x3u << MATRIX_PRAS_M2PR_Pos)
230 #define MATRIX_PRAS_M2PR(value) ((MATRIX_PRAS_M2PR_Msk & ((value) << MATRIX_PRAS_M2PR_Pos)))
231 #define MATRIX_PRAS_M3PR_Pos 12
232 #define MATRIX_PRAS_M3PR_Msk (0x3u << MATRIX_PRAS_M3PR_Pos)
233 #define MATRIX_PRAS_M3PR(value) ((MATRIX_PRAS_M3PR_Msk & ((value) << MATRIX_PRAS_M3PR_Pos)))
234 #define MATRIX_PRAS_M4PR_Pos 16
235 #define MATRIX_PRAS_M4PR_Msk (0x3u << MATRIX_PRAS_M4PR_Pos)
236 #define MATRIX_PRAS_M4PR(value) ((MATRIX_PRAS_M4PR_Msk & ((value) << MATRIX_PRAS_M4PR_Pos)))
237 #define MATRIX_PRAS_M5PR_Pos 20
238 #define MATRIX_PRAS_M5PR_Msk (0x3u << MATRIX_PRAS_M5PR_Pos)
239 #define MATRIX_PRAS_M5PR(value) ((MATRIX_PRAS_M5PR_Msk & ((value) << MATRIX_PRAS_M5PR_Pos)))
240 #define MATRIX_PRAS_M6PR_Pos 24
241 #define MATRIX_PRAS_M6PR_Msk (0x3u << MATRIX_PRAS_M6PR_Pos)
242 #define MATRIX_PRAS_M6PR(value) ((MATRIX_PRAS_M6PR_Msk & ((value) << MATRIX_PRAS_M6PR_Pos)))
243 /* -------- MATRIX_PRBS : (MATRIX Offset: N/A) Priority Register B for Slave 0 -------- */
244 #define MATRIX_PRBS_M8PR_Pos 0
245 #define MATRIX_PRBS_M8PR_Msk (0x3u << MATRIX_PRBS_M8PR_Pos)
246 #define MATRIX_PRBS_M8PR(value) ((MATRIX_PRBS_M8PR_Msk & ((value) << MATRIX_PRBS_M8PR_Pos)))
247 #define MATRIX_PRBS_M9PR_Pos 4
248 #define MATRIX_PRBS_M9PR_Msk (0x3u << MATRIX_PRBS_M9PR_Pos)
249 #define MATRIX_PRBS_M9PR(value) ((MATRIX_PRBS_M9PR_Msk & ((value) << MATRIX_PRBS_M9PR_Pos)))
250 #define MATRIX_PRBS_M10PR_Pos 8
251 #define MATRIX_PRBS_M10PR_Msk (0x3u << MATRIX_PRBS_M10PR_Pos)
252 #define MATRIX_PRBS_M10PR(value) ((MATRIX_PRBS_M10PR_Msk & ((value) << MATRIX_PRBS_M10PR_Pos)))
253 #define MATRIX_PRBS_M11PR_Pos 12
254 #define MATRIX_PRBS_M11PR_Msk (0x3u << MATRIX_PRBS_M11PR_Pos)
255 #define MATRIX_PRBS_M11PR(value) ((MATRIX_PRBS_M11PR_Msk & ((value) << MATRIX_PRBS_M11PR_Pos)))
256 /* -------- MATRIX_MRCR : (MATRIX Offset: 0x0100) Master Remap Control Register -------- */
257 #define MATRIX_MRCR_RCB0 (0x1u << 0)
258 #define MATRIX_MRCR_RCB1 (0x1u << 1)
259 #define MATRIX_MRCR_RCB2 (0x1u << 2)
260 #define MATRIX_MRCR_RCB3 (0x1u << 3)
261 #define MATRIX_MRCR_RCB4 (0x1u << 4)
262 #define MATRIX_MRCR_RCB5 (0x1u << 5)
263 #define MATRIX_MRCR_RCB6 (0x1u << 6)
264 #define MATRIX_MRCR_RCB8 (0x1u << 8)
265 #define MATRIX_MRCR_RCB9 (0x1u << 9)
266 #define MATRIX_MRCR_RCB10 (0x1u << 10)
267 #define MATRIX_MRCR_RCB11 (0x1u << 11)
268 /* -------- CCFG_CAN0 : (MATRIX Offset: 0x0110) CAN0 Configuration Register -------- */
269 #define CCFG_CAN0_CAN0DMABA_Pos 16
270 #define CCFG_CAN0_CAN0DMABA_Msk (0xffffu << CCFG_CAN0_CAN0DMABA_Pos)
271 #define CCFG_CAN0_CAN0DMABA(value) ((CCFG_CAN0_CAN0DMABA_Msk & ((value) << CCFG_CAN0_CAN0DMABA_Pos)))
272 /* -------- CCFG_SYSIO : (MATRIX Offset: 0x0114) System I/O and CAN1 Configuration Register -------- */
273 #define CCFG_SYSIO_SYSIO4 (0x1u << 4)
274 #define CCFG_SYSIO_SYSIO5 (0x1u << 5)
275 #define CCFG_SYSIO_SYSIO6 (0x1u << 6)
276 #define CCFG_SYSIO_SYSIO7 (0x1u << 7)
277 #define CCFG_SYSIO_SYSIO12 (0x1u << 12)
278 #define CCFG_SYSIO_CAN1DMABA_Pos 16
279 #define CCFG_SYSIO_CAN1DMABA_Msk (0xffffu << CCFG_SYSIO_CAN1DMABA_Pos)
280 #define CCFG_SYSIO_CAN1DMABA(value) ((CCFG_SYSIO_CAN1DMABA_Msk & ((value) << CCFG_SYSIO_CAN1DMABA_Pos)))
281 /* -------- CCFG_SMCNFCS : (MATRIX Offset: 0x0124) SMC NAND Flash Chip Select Configuration Register -------- */
282 #define CCFG_SMCNFCS_SMC_NFCS0 (0x1u << 0)
283 #define CCFG_SMCNFCS_SMC_NFCS1 (0x1u << 1)
284 #define CCFG_SMCNFCS_SMC_NFCS2 (0x1u << 2)
285 #define CCFG_SMCNFCS_SMC_NFCS3 (0x1u << 3)
286 #define CCFG_SMCNFCS_SDRAMEN (0x1u << 4)
287 /* -------- MATRIX_WPMR : (MATRIX Offset: 0x01E4) Write Protection Mode Register -------- */
288 #define MATRIX_WPMR_WPEN (0x1u << 0)
289 #define MATRIX_WPMR_WPKEY_Pos 8
290 #define MATRIX_WPMR_WPKEY_Msk (0xffffffu << MATRIX_WPMR_WPKEY_Pos)
291 #define MATRIX_WPMR_WPKEY(value) ((MATRIX_WPMR_WPKEY_Msk & ((value) << MATRIX_WPMR_WPKEY_Pos)))
292 #define MATRIX_WPMR_WPKEY_PASSWD (0x4D4154u << 8)
293 /* -------- MATRIX_WPSR : (MATRIX Offset: 0x01E8) Write Protection Status Register -------- */
294 #define MATRIX_WPSR_WPVS (0x1u << 0)
295 #define MATRIX_WPSR_WPVSRC_Pos 8
296 #define MATRIX_WPSR_WPVSRC_Msk (0xffffu << MATRIX_WPSR_WPVSRC_Pos)
299
300
301 #endif /* _SAME70_MATRIX_COMPONENT_ */
MatrixPr hardware registers.
Definition: component_matrix.h:41
(Matrix Offset: 0x0014) Master Configuration Register 5
Definition: component_matrix.h:53
(Matrix Offset: 0x0100) Master Remap Control Register
Definition: component_matrix.h:65
(Matrix Offset: 0x0110) CAN0 Configuration Register
Definition: component_matrix.h:67
(Matrix Offset: 0x002C) Master Configuration Register 11
Definition: component_matrix.h:59
#define __IO
Definition: core_cm7.h:287
(Matrix Offset: 0x0018) Master Configuration Register 6
Definition: component_matrix.h:54
(Matrix Offset: 0x0010) Master Configuration Register 4
Definition: component_matrix.h:52
Matrix hardware registers.
Definition: component_matrix.h:46
(Matrix Offset: 0x0114) System I/O and CAN1 Configuration Register
Definition: component_matrix.h:68
(Matrix Offset: 0x0024) Master Configuration Register 9
Definition: component_matrix.h:57
(MatrixPr Offset: 0x4) Priority Register B for Slave 0
Definition: component_matrix.h:43
(Matrix Offset: 0x000C) Master Configuration Register 3
Definition: component_matrix.h:51
(Matrix Offset: 0x01E8) Write Protection Status Register
Definition: component_matrix.h:73
(Matrix Offset: 0x01E4) Write Protection Mode Register
Definition: component_matrix.h:72
(MatrixPr Offset: 0x0) Priority Register A for Slave 0
Definition: component_matrix.h:42
(Matrix Offset: 0x0008) Master Configuration Register 2
Definition: component_matrix.h:50
(Matrix Offset: 0x0004) Master Configuration Register 1
Definition: component_matrix.h:49
(Matrix Offset: 0x0020) Master Configuration Register 8
Definition: component_matrix.h:56
(Matrix Offset: 0x0028) Master Configuration Register 10
Definition: component_matrix.h:58
(Matrix Offset: 0x0124) SMC NAND Flash Chip Select Configuration Register
Definition: component_matrix.h:70
Definition: component_matrix.h:47
(Matrix Offset: 0x0000) Master Configuration Register 0
Definition: component_matrix.h:48
#define __I
Definition: core_cm7.h:284
