RTEMS  5.1
component_isi.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_ISI_COMPONENT_
31 #define _SAME70_ISI_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t ISI_CFG1;
43  __IO uint32_t ISI_CFG2;
44  __IO uint32_t ISI_PSIZE;
45  __IO uint32_t ISI_PDECF;
46  __IO uint32_t ISI_Y2R_SET0;
47  __IO uint32_t ISI_Y2R_SET1;
48  __IO uint32_t ISI_R2Y_SET0;
49  __IO uint32_t ISI_R2Y_SET1;
50  __IO uint32_t ISI_R2Y_SET2;
51  __O uint32_t ISI_CR;
52  __I uint32_t ISI_SR;
53  __O uint32_t ISI_IER;
54  __O uint32_t ISI_IDR;
55  __I uint32_t ISI_IMR;
56  __O uint32_t ISI_DMA_CHER;
57  __O uint32_t ISI_DMA_CHDR;
58  __I uint32_t ISI_DMA_CHSR;
59  __IO uint32_t ISI_DMA_P_ADDR;
60  __IO uint32_t ISI_DMA_P_CTRL;
61  __IO uint32_t ISI_DMA_P_DSCR;
62  __IO uint32_t ISI_DMA_C_ADDR;
63  __IO uint32_t ISI_DMA_C_CTRL;
64  __IO uint32_t ISI_DMA_C_DSCR;
65  __I uint32_t Reserved1[34];
66  __IO uint32_t ISI_WPMR;
67  __I uint32_t ISI_WPSR;
68 } Isi;
69 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
70 /* -------- ISI_CFG1 : (ISI Offset: 0x00) ISI Configuration 1 Register -------- */
71 #define ISI_CFG1_HSYNC_POL (0x1u << 2)
72 #define ISI_CFG1_VSYNC_POL (0x1u << 3)
73 #define ISI_CFG1_PIXCLK_POL (0x1u << 4)
74 #define ISI_CFG1_EMB_SYNC (0x1u << 6)
75 #define ISI_CFG1_CRC_SYNC (0x1u << 7)
76 #define ISI_CFG1_FRATE_Pos 8
77 #define ISI_CFG1_FRATE_Msk (0x7u << ISI_CFG1_FRATE_Pos)
78 #define ISI_CFG1_FRATE(value) ((ISI_CFG1_FRATE_Msk & ((value) << ISI_CFG1_FRATE_Pos)))
79 #define ISI_CFG1_DISCR (0x1u << 11)
80 #define ISI_CFG1_FULL (0x1u << 12)
81 #define ISI_CFG1_THMASK_Pos 13
82 #define ISI_CFG1_THMASK_Msk (0x3u << ISI_CFG1_THMASK_Pos)
83 #define ISI_CFG1_THMASK(value) ((ISI_CFG1_THMASK_Msk & ((value) << ISI_CFG1_THMASK_Pos)))
84 #define ISI_CFG1_THMASK_BEATS_4 (0x0u << 13)
85 #define ISI_CFG1_THMASK_BEATS_8 (0x1u << 13)
86 #define ISI_CFG1_THMASK_BEATS_16 (0x2u << 13)
87 #define ISI_CFG1_SLD_Pos 16
88 #define ISI_CFG1_SLD_Msk (0xffu << ISI_CFG1_SLD_Pos)
89 #define ISI_CFG1_SLD(value) ((ISI_CFG1_SLD_Msk & ((value) << ISI_CFG1_SLD_Pos)))
90 #define ISI_CFG1_SFD_Pos 24
91 #define ISI_CFG1_SFD_Msk (0xffu << ISI_CFG1_SFD_Pos)
92 #define ISI_CFG1_SFD(value) ((ISI_CFG1_SFD_Msk & ((value) << ISI_CFG1_SFD_Pos)))
93 /* -------- ISI_CFG2 : (ISI Offset: 0x04) ISI Configuration 2 Register -------- */
94 #define ISI_CFG2_IM_VSIZE_Pos 0
95 #define ISI_CFG2_IM_VSIZE_Msk (0x7ffu << ISI_CFG2_IM_VSIZE_Pos)
96 #define ISI_CFG2_IM_VSIZE(value) ((ISI_CFG2_IM_VSIZE_Msk & ((value) << ISI_CFG2_IM_VSIZE_Pos)))
97 #define ISI_CFG2_GS_MODE (0x1u << 11)
98 #define ISI_CFG2_RGB_MODE (0x1u << 12)
99 #define ISI_CFG2_GRAYSCALE (0x1u << 13)
100 #define ISI_CFG2_RGB_SWAP (0x1u << 14)
101 #define ISI_CFG2_COL_SPACE (0x1u << 15)
102 #define ISI_CFG2_IM_HSIZE_Pos 16
103 #define ISI_CFG2_IM_HSIZE_Msk (0x7ffu << ISI_CFG2_IM_HSIZE_Pos)
104 #define ISI_CFG2_IM_HSIZE(value) ((ISI_CFG2_IM_HSIZE_Msk & ((value) << ISI_CFG2_IM_HSIZE_Pos)))
105 #define ISI_CFG2_YCC_SWAP_Pos 28
106 #define ISI_CFG2_YCC_SWAP_Msk (0x3u << ISI_CFG2_YCC_SWAP_Pos)
107 #define ISI_CFG2_YCC_SWAP(value) ((ISI_CFG2_YCC_SWAP_Msk & ((value) << ISI_CFG2_YCC_SWAP_Pos)))
108 #define ISI_CFG2_YCC_SWAP_DEFAULT (0x0u << 28)
109 #define ISI_CFG2_YCC_SWAP_MODE1 (0x1u << 28)
110 #define ISI_CFG2_YCC_SWAP_MODE2 (0x2u << 28)
111 #define ISI_CFG2_YCC_SWAP_MODE3 (0x3u << 28)
112 #define ISI_CFG2_RGB_CFG_Pos 30
113 #define ISI_CFG2_RGB_CFG_Msk (0x3u << ISI_CFG2_RGB_CFG_Pos)
114 #define ISI_CFG2_RGB_CFG(value) ((ISI_CFG2_RGB_CFG_Msk & ((value) << ISI_CFG2_RGB_CFG_Pos)))
115 #define ISI_CFG2_RGB_CFG_DEFAULT (0x0u << 30)
116 #define ISI_CFG2_RGB_CFG_MODE1 (0x1u << 30)
117 #define ISI_CFG2_RGB_CFG_MODE2 (0x2u << 30)
118 #define ISI_CFG2_RGB_CFG_MODE3 (0x3u << 30)
119 /* -------- ISI_PSIZE : (ISI Offset: 0x08) ISI Preview Size Register -------- */
120 #define ISI_PSIZE_PREV_VSIZE_Pos 0
121 #define ISI_PSIZE_PREV_VSIZE_Msk (0x3ffu << ISI_PSIZE_PREV_VSIZE_Pos)
122 #define ISI_PSIZE_PREV_VSIZE(value) ((ISI_PSIZE_PREV_VSIZE_Msk & ((value) << ISI_PSIZE_PREV_VSIZE_Pos)))
123 #define ISI_PSIZE_PREV_HSIZE_Pos 16
124 #define ISI_PSIZE_PREV_HSIZE_Msk (0x3ffu << ISI_PSIZE_PREV_HSIZE_Pos)
125 #define ISI_PSIZE_PREV_HSIZE(value) ((ISI_PSIZE_PREV_HSIZE_Msk & ((value) << ISI_PSIZE_PREV_HSIZE_Pos)))
126 /* -------- ISI_PDECF : (ISI Offset: 0x0C) ISI Preview Decimation Factor Register -------- */
127 #define ISI_PDECF_DEC_FACTOR_Pos 0
128 #define ISI_PDECF_DEC_FACTOR_Msk (0xffu << ISI_PDECF_DEC_FACTOR_Pos)
129 #define ISI_PDECF_DEC_FACTOR(value) ((ISI_PDECF_DEC_FACTOR_Msk & ((value) << ISI_PDECF_DEC_FACTOR_Pos)))
130 /* -------- ISI_Y2R_SET0 : (ISI Offset: 0x10) ISI Color Space Conversion YCrCb To RGB Set 0 Register -------- */
131 #define ISI_Y2R_SET0_C0_Pos 0
132 #define ISI_Y2R_SET0_C0_Msk (0xffu << ISI_Y2R_SET0_C0_Pos)
133 #define ISI_Y2R_SET0_C0(value) ((ISI_Y2R_SET0_C0_Msk & ((value) << ISI_Y2R_SET0_C0_Pos)))
134 #define ISI_Y2R_SET0_C1_Pos 8
135 #define ISI_Y2R_SET0_C1_Msk (0xffu << ISI_Y2R_SET0_C1_Pos)
136 #define ISI_Y2R_SET0_C1(value) ((ISI_Y2R_SET0_C1_Msk & ((value) << ISI_Y2R_SET0_C1_Pos)))
137 #define ISI_Y2R_SET0_C2_Pos 16
138 #define ISI_Y2R_SET0_C2_Msk (0xffu << ISI_Y2R_SET0_C2_Pos)
139 #define ISI_Y2R_SET0_C2(value) ((ISI_Y2R_SET0_C2_Msk & ((value) << ISI_Y2R_SET0_C2_Pos)))
140 #define ISI_Y2R_SET0_C3_Pos 24
141 #define ISI_Y2R_SET0_C3_Msk (0xffu << ISI_Y2R_SET0_C3_Pos)
142 #define ISI_Y2R_SET0_C3(value) ((ISI_Y2R_SET0_C3_Msk & ((value) << ISI_Y2R_SET0_C3_Pos)))
143 /* -------- ISI_Y2R_SET1 : (ISI Offset: 0x14) ISI Color Space Conversion YCrCb To RGB Set 1 Register -------- */
144 #define ISI_Y2R_SET1_C4_Pos 0
145 #define ISI_Y2R_SET1_C4_Msk (0x1ffu << ISI_Y2R_SET1_C4_Pos)
146 #define ISI_Y2R_SET1_C4(value) ((ISI_Y2R_SET1_C4_Msk & ((value) << ISI_Y2R_SET1_C4_Pos)))
147 #define ISI_Y2R_SET1_Yoff (0x1u << 12)
148 #define ISI_Y2R_SET1_Croff (0x1u << 13)
149 #define ISI_Y2R_SET1_Cboff (0x1u << 14)
150 /* -------- ISI_R2Y_SET0 : (ISI Offset: 0x18) ISI Color Space Conversion RGB To YCrCb Set 0 Register -------- */
151 #define ISI_R2Y_SET0_C0_Pos 0
152 #define ISI_R2Y_SET0_C0_Msk (0x7fu << ISI_R2Y_SET0_C0_Pos)
153 #define ISI_R2Y_SET0_C0(value) ((ISI_R2Y_SET0_C0_Msk & ((value) << ISI_R2Y_SET0_C0_Pos)))
154 #define ISI_R2Y_SET0_C1_Pos 8
155 #define ISI_R2Y_SET0_C1_Msk (0x7fu << ISI_R2Y_SET0_C1_Pos)
156 #define ISI_R2Y_SET0_C1(value) ((ISI_R2Y_SET0_C1_Msk & ((value) << ISI_R2Y_SET0_C1_Pos)))
157 #define ISI_R2Y_SET0_C2_Pos 16
158 #define ISI_R2Y_SET0_C2_Msk (0x7fu << ISI_R2Y_SET0_C2_Pos)
159 #define ISI_R2Y_SET0_C2(value) ((ISI_R2Y_SET0_C2_Msk & ((value) << ISI_R2Y_SET0_C2_Pos)))
160 #define ISI_R2Y_SET0_Roff (0x1u << 24)
161 /* -------- ISI_R2Y_SET1 : (ISI Offset: 0x1C) ISI Color Space Conversion RGB To YCrCb Set 1 Register -------- */
162 #define ISI_R2Y_SET1_C3_Pos 0
163 #define ISI_R2Y_SET1_C3_Msk (0x7fu << ISI_R2Y_SET1_C3_Pos)
164 #define ISI_R2Y_SET1_C3(value) ((ISI_R2Y_SET1_C3_Msk & ((value) << ISI_R2Y_SET1_C3_Pos)))
165 #define ISI_R2Y_SET1_C4_Pos 8
166 #define ISI_R2Y_SET1_C4_Msk (0x7fu << ISI_R2Y_SET1_C4_Pos)
167 #define ISI_R2Y_SET1_C4(value) ((ISI_R2Y_SET1_C4_Msk & ((value) << ISI_R2Y_SET1_C4_Pos)))
168 #define ISI_R2Y_SET1_C5_Pos 16
169 #define ISI_R2Y_SET1_C5_Msk (0x7fu << ISI_R2Y_SET1_C5_Pos)
170 #define ISI_R2Y_SET1_C5(value) ((ISI_R2Y_SET1_C5_Msk & ((value) << ISI_R2Y_SET1_C5_Pos)))
171 #define ISI_R2Y_SET1_Goff (0x1u << 24)
172 /* -------- ISI_R2Y_SET2 : (ISI Offset: 0x20) ISI Color Space Conversion RGB To YCrCb Set 2 Register -------- */
173 #define ISI_R2Y_SET2_C6_Pos 0
174 #define ISI_R2Y_SET2_C6_Msk (0x7fu << ISI_R2Y_SET2_C6_Pos)
175 #define ISI_R2Y_SET2_C6(value) ((ISI_R2Y_SET2_C6_Msk & ((value) << ISI_R2Y_SET2_C6_Pos)))
176 #define ISI_R2Y_SET2_C7_Pos 8
177 #define ISI_R2Y_SET2_C7_Msk (0x7fu << ISI_R2Y_SET2_C7_Pos)
178 #define ISI_R2Y_SET2_C7(value) ((ISI_R2Y_SET2_C7_Msk & ((value) << ISI_R2Y_SET2_C7_Pos)))
179 #define ISI_R2Y_SET2_C8_Pos 16
180 #define ISI_R2Y_SET2_C8_Msk (0x7fu << ISI_R2Y_SET2_C8_Pos)
181 #define ISI_R2Y_SET2_C8(value) ((ISI_R2Y_SET2_C8_Msk & ((value) << ISI_R2Y_SET2_C8_Pos)))
182 #define ISI_R2Y_SET2_Boff (0x1u << 24)
183 /* -------- ISI_CR : (ISI Offset: 0x24) ISI Control Register -------- */
184 #define ISI_CR_ISI_EN (0x1u << 0)
185 #define ISI_CR_ISI_DIS (0x1u << 1)
186 #define ISI_CR_ISI_SRST (0x1u << 2)
187 #define ISI_CR_ISI_CDC (0x1u << 8)
188 /* -------- ISI_SR : (ISI Offset: 0x28) ISI Status Register -------- */
189 #define ISI_SR_ENABLE (0x1u << 0)
190 #define ISI_SR_DIS_DONE (0x1u << 1)
191 #define ISI_SR_SRST (0x1u << 2)
192 #define ISI_SR_CDC_PND (0x1u << 8)
193 #define ISI_SR_VSYNC (0x1u << 10)
194 #define ISI_SR_PXFR_DONE (0x1u << 16)
195 #define ISI_SR_CXFR_DONE (0x1u << 17)
196 #define ISI_SR_SIP (0x1u << 19)
197 #define ISI_SR_P_OVR (0x1u << 24)
198 #define ISI_SR_C_OVR (0x1u << 25)
199 #define ISI_SR_CRC_ERR (0x1u << 26)
200 #define ISI_SR_FR_OVR (0x1u << 27)
201 /* -------- ISI_IER : (ISI Offset: 0x2C) ISI Interrupt Enable Register -------- */
202 #define ISI_IER_DIS_DONE (0x1u << 1)
203 #define ISI_IER_SRST (0x1u << 2)
204 #define ISI_IER_VSYNC (0x1u << 10)
205 #define ISI_IER_PXFR_DONE (0x1u << 16)
206 #define ISI_IER_CXFR_DONE (0x1u << 17)
207 #define ISI_IER_P_OVR (0x1u << 24)
208 #define ISI_IER_C_OVR (0x1u << 25)
209 #define ISI_IER_CRC_ERR (0x1u << 26)
210 #define ISI_IER_FR_OVR (0x1u << 27)
211 /* -------- ISI_IDR : (ISI Offset: 0x30) ISI Interrupt Disable Register -------- */
212 #define ISI_IDR_DIS_DONE (0x1u << 1)
213 #define ISI_IDR_SRST (0x1u << 2)
214 #define ISI_IDR_VSYNC (0x1u << 10)
215 #define ISI_IDR_PXFR_DONE (0x1u << 16)
216 #define ISI_IDR_CXFR_DONE (0x1u << 17)
217 #define ISI_IDR_P_OVR (0x1u << 24)
218 #define ISI_IDR_C_OVR (0x1u << 25)
219 #define ISI_IDR_CRC_ERR (0x1u << 26)
220 #define ISI_IDR_FR_OVR (0x1u << 27)
221 /* -------- ISI_IMR : (ISI Offset: 0x34) ISI Interrupt Mask Register -------- */
222 #define ISI_IMR_DIS_DONE (0x1u << 1)
223 #define ISI_IMR_SRST (0x1u << 2)
224 #define ISI_IMR_VSYNC (0x1u << 10)
225 #define ISI_IMR_PXFR_DONE (0x1u << 16)
226 #define ISI_IMR_CXFR_DONE (0x1u << 17)
227 #define ISI_IMR_P_OVR (0x1u << 24)
228 #define ISI_IMR_C_OVR (0x1u << 25)
229 #define ISI_IMR_CRC_ERR (0x1u << 26)
230 #define ISI_IMR_FR_OVR (0x1u << 27)
231 /* -------- ISI_DMA_CHER : (ISI Offset: 0x38) DMA Channel Enable Register -------- */
232 #define ISI_DMA_CHER_P_CH_EN (0x1u << 0)
233 #define ISI_DMA_CHER_C_CH_EN (0x1u << 1)
234 /* -------- ISI_DMA_CHDR : (ISI Offset: 0x3C) DMA Channel Disable Register -------- */
235 #define ISI_DMA_CHDR_P_CH_DIS (0x1u << 0)
236 #define ISI_DMA_CHDR_C_CH_DIS (0x1u << 1)
237 /* -------- ISI_DMA_CHSR : (ISI Offset: 0x40) DMA Channel Status Register -------- */
238 #define ISI_DMA_CHSR_P_CH_S (0x1u << 0)
239 #define ISI_DMA_CHSR_C_CH_S (0x1u << 1)
240 /* -------- ISI_DMA_P_ADDR : (ISI Offset: 0x44) DMA Preview Base Address Register -------- */
241 #define ISI_DMA_P_ADDR_P_ADDR_Pos 2
242 #define ISI_DMA_P_ADDR_P_ADDR_Msk (0x3fffffffu << ISI_DMA_P_ADDR_P_ADDR_Pos)
243 #define ISI_DMA_P_ADDR_P_ADDR(value) ((ISI_DMA_P_ADDR_P_ADDR_Msk & ((value) << ISI_DMA_P_ADDR_P_ADDR_Pos)))
244 /* -------- ISI_DMA_P_CTRL : (ISI Offset: 0x48) DMA Preview Control Register -------- */
245 #define ISI_DMA_P_CTRL_P_FETCH (0x1u << 0)
246 #define ISI_DMA_P_CTRL_P_WB (0x1u << 1)
247 #define ISI_DMA_P_CTRL_P_IEN (0x1u << 2)
248 #define ISI_DMA_P_CTRL_P_DONE (0x1u << 3)
249 /* -------- ISI_DMA_P_DSCR : (ISI Offset: 0x4C) DMA Preview Descriptor Address Register -------- */
250 #define ISI_DMA_P_DSCR_P_DSCR_Pos 2
251 #define ISI_DMA_P_DSCR_P_DSCR_Msk (0x3fffffffu << ISI_DMA_P_DSCR_P_DSCR_Pos)
252 #define ISI_DMA_P_DSCR_P_DSCR(value) ((ISI_DMA_P_DSCR_P_DSCR_Msk & ((value) << ISI_DMA_P_DSCR_P_DSCR_Pos)))
253 /* -------- ISI_DMA_C_ADDR : (ISI Offset: 0x50) DMA Codec Base Address Register -------- */
254 #define ISI_DMA_C_ADDR_C_ADDR_Pos 2
255 #define ISI_DMA_C_ADDR_C_ADDR_Msk (0x3fffffffu << ISI_DMA_C_ADDR_C_ADDR_Pos)
256 #define ISI_DMA_C_ADDR_C_ADDR(value) ((ISI_DMA_C_ADDR_C_ADDR_Msk & ((value) << ISI_DMA_C_ADDR_C_ADDR_Pos)))
257 /* -------- ISI_DMA_C_CTRL : (ISI Offset: 0x54) DMA Codec Control Register -------- */
258 #define ISI_DMA_C_CTRL_C_FETCH (0x1u << 0)
259 #define ISI_DMA_C_CTRL_C_WB (0x1u << 1)
260 #define ISI_DMA_C_CTRL_C_IEN (0x1u << 2)
261 #define ISI_DMA_C_CTRL_C_DONE (0x1u << 3)
262 /* -------- ISI_DMA_C_DSCR : (ISI Offset: 0x58) DMA Codec Descriptor Address Register -------- */
263 #define ISI_DMA_C_DSCR_C_DSCR_Pos 2
264 #define ISI_DMA_C_DSCR_C_DSCR_Msk (0x3fffffffu << ISI_DMA_C_DSCR_C_DSCR_Pos)
265 #define ISI_DMA_C_DSCR_C_DSCR(value) ((ISI_DMA_C_DSCR_C_DSCR_Msk & ((value) << ISI_DMA_C_DSCR_C_DSCR_Pos)))
266 /* -------- ISI_WPMR : (ISI Offset: 0xE4) Write Protection Mode Register -------- */
267 #define ISI_WPMR_WPEN (0x1u << 0)
268 #define ISI_WPMR_WPKEY_Pos 8
269 #define ISI_WPMR_WPKEY_Msk (0xffffffu << ISI_WPMR_WPKEY_Pos)
270 #define ISI_WPMR_WPKEY(value) ((ISI_WPMR_WPKEY_Msk & ((value) << ISI_WPMR_WPKEY_Pos)))
271 #define ISI_WPMR_WPKEY_PASSWD (0x495349u << 8)
272 /* -------- ISI_WPSR : (ISI Offset: 0xE8) Write Protection Status Register -------- */
273 #define ISI_WPSR_WPVS (0x1u << 0)
274 #define ISI_WPSR_WPVSRC_Pos 8
275 #define ISI_WPSR_WPVSRC_Msk (0xffffu << ISI_WPSR_WPVSRC_Pos)
278
279
280 #endif /* _SAME70_ISI_COMPONENT_ */
(Isi Offset: 0x38) DMA Channel Enable Register
Definition: component_isi.h:56
(Isi Offset: 0x48) DMA Preview Control Register
Definition: component_isi.h:60
(Isi Offset: 0xE4) Write Protection Mode Register
Definition: component_isi.h:66
(Isi Offset: 0x0C) ISI Preview Decimation Factor Register
Definition: component_isi.h:45
#define __IO
Definition: core_cm7.h:287
(Isi Offset: 0x34) ISI Interrupt Mask Register
Definition: component_isi.h:55
#define __O
Definition: core_cm7.h:286
(Isi Offset: 0x58) DMA Codec Descriptor Address Register
Definition: component_isi.h:64
(Isi Offset: 0x54) DMA Codec Control Register
Definition: component_isi.h:63
(Isi Offset: 0x20) ISI Color Space Conversion RGB To YCrCb Set 2 Register
Definition: component_isi.h:50
(Isi Offset: 0x04) ISI Configuration 2 Register
Definition: component_isi.h:43
(Isi Offset: 0x40) DMA Channel Status Register
Definition: component_isi.h:58
__I uint32_t ISI_SR
(Isi Offset: 0x28) ISI Status Register
Definition: component_isi.h:52
(Isi Offset: 0x08) ISI Preview Size Register
Definition: component_isi.h:44
(Isi Offset: 0x10) ISI Color Space Conversion YCrCb To RGB Set 0 Register
Definition: component_isi.h:46
(Isi Offset: 0x3C) DMA Channel Disable Register
Definition: component_isi.h:57
(Isi Offset: 0x14) ISI Color Space Conversion YCrCb To RGB Set 1 Register
Definition: component_isi.h:47
(Isi Offset: 0x18) ISI Color Space Conversion RGB To YCrCb Set 0 Register
Definition: component_isi.h:48
(Isi Offset: 0x30) ISI Interrupt Disable Register
Definition: component_isi.h:54
__O uint32_t ISI_CR
(Isi Offset: 0x24) ISI Control Register
Definition: component_isi.h:51
(Isi Offset: 0x1C) ISI Color Space Conversion RGB To YCrCb Set 1 Register
Definition: component_isi.h:49
(Isi Offset: 0x4C) DMA Preview Descriptor Address Register
Definition: component_isi.h:61
(Isi Offset: 0x2C) ISI Interrupt Enable Register
Definition: component_isi.h:53
(Isi Offset: 0xE8) Write Protection Status Register
Definition: component_isi.h:67
(Isi Offset: 0x00) ISI Configuration 1 Register
Definition: component_isi.h:42
#define __I
Definition: core_cm7.h:284
(Isi Offset: 0x50) DMA Codec Base Address Register
Definition: component_isi.h:62
(Isi Offset: 0x44) DMA Preview Base Address Register
Definition: component_isi.h:59
Isi hardware registers.
Definition: component_isi.h:41
