RTEMS  5.1
component_dacc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_DACC_COMPONENT_
31 #define _SAME70_DACC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t DACC_CR;
43  __IO uint32_t DACC_MR;
44  __IO uint32_t DACC_TRIGR;
45  __I uint32_t Reserved1[1];
46  __O uint32_t DACC_CHER;
47  __O uint32_t DACC_CHDR;
48  __I uint32_t DACC_CHSR;
49  __O uint32_t DACC_CDR[2];
50  __O uint32_t DACC_IER;
51  __O uint32_t DACC_IDR;
52  __I uint32_t DACC_IMR;
53  __I uint32_t DACC_ISR;
54  __I uint32_t Reserved2[24];
55  __IO uint32_t DACC_ACR;
56  __I uint32_t Reserved3[19];
57  __IO uint32_t DACC_WPMR;
58  __I uint32_t DACC_WPSR;
59 } Dacc;
60 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
61 /* -------- DACC_CR : (DACC Offset: 0x00) Control Register -------- */
62 #define DACC_CR_SWRST (0x1u << 0)
63 /* -------- DACC_MR : (DACC Offset: 0x04) Mode Register -------- */
64 #define DACC_MR_MAXS0 (0x1u << 0)
65 #define DACC_MR_MAXS0_TRIG_EVENT (0x0u << 0)
66 #define DACC_MR_MAXS0_MAXIMUM (0x1u << 0)
67 #define DACC_MR_MAXS1 (0x1u << 1)
68 #define DACC_MR_MAXS1_TRIG_EVENT (0x0u << 1)
69 #define DACC_MR_MAXS1_MAXIMUM (0x1u << 1)
70 #define DACC_MR_WORD (0x1u << 4)
71 #define DACC_MR_WORD_DISABLED (0x0u << 4)
72 #define DACC_MR_WORD_ENABLED (0x1u << 4)
73 #define DACC_MR_ZERO (0x1u << 5)
74 #define DACC_MR_DIFF (0x1u << 23)
75 #define DACC_MR_DIFF_DISABLED (0x0u << 23)
76 #define DACC_MR_DIFF_ENABLED (0x1u << 23)
77 #define DACC_MR_PRESCALER_Pos 24
78 #define DACC_MR_PRESCALER_Msk (0xfu << DACC_MR_PRESCALER_Pos)
79 #define DACC_MR_PRESCALER(value) ((DACC_MR_PRESCALER_Msk & ((value) << DACC_MR_PRESCALER_Pos)))
80 /* -------- DACC_TRIGR : (DACC Offset: 0x08) Trigger Register -------- */
81 #define DACC_TRIGR_TRGEN0 (0x1u << 0)
82 #define DACC_TRIGR_TRGEN0_DIS (0x0u << 0)
83 #define DACC_TRIGR_TRGEN0_EN (0x1u << 0)
84 #define DACC_TRIGR_TRGEN1 (0x1u << 1)
85 #define DACC_TRIGR_TRGEN1_DIS (0x0u << 1)
86 #define DACC_TRIGR_TRGEN1_EN (0x1u << 1)
87 #define DACC_TRIGR_TRGSEL0_Pos 4
88 #define DACC_TRIGR_TRGSEL0_Msk (0x7u << DACC_TRIGR_TRGSEL0_Pos)
89 #define DACC_TRIGR_TRGSEL0(value) ((DACC_TRIGR_TRGSEL0_Msk & ((value) << DACC_TRIGR_TRGSEL0_Pos)))
90 #define DACC_TRIGR_TRGSEL0_TRGSEL0 (0x0u << 4)
91 #define DACC_TRIGR_TRGSEL0_TRGSEL1 (0x1u << 4)
92 #define DACC_TRIGR_TRGSEL0_TRGSEL2 (0x2u << 4)
93 #define DACC_TRIGR_TRGSEL0_TRGSEL3 (0x3u << 4)
94 #define DACC_TRIGR_TRGSEL0_TRGSEL4 (0x4u << 4)
95 #define DACC_TRIGR_TRGSEL0_TRGSEL5 (0x5u << 4)
96 #define DACC_TRIGR_TRGSEL0_TRGSEL6 (0x6u << 4)
97 #define DACC_TRIGR_TRGSEL1_Pos 8
98 #define DACC_TRIGR_TRGSEL1_Msk (0x7u << DACC_TRIGR_TRGSEL1_Pos)
99 #define DACC_TRIGR_TRGSEL1(value) ((DACC_TRIGR_TRGSEL1_Msk & ((value) << DACC_TRIGR_TRGSEL1_Pos)))
100 #define DACC_TRIGR_TRGSEL1_TRGSEL0 (0x0u << 8)
101 #define DACC_TRIGR_TRGSEL1_TRGSEL1 (0x1u << 8)
102 #define DACC_TRIGR_TRGSEL1_TRGSEL2 (0x2u << 8)
103 #define DACC_TRIGR_TRGSEL1_TRGSEL3 (0x3u << 8)
104 #define DACC_TRIGR_TRGSEL1_TRGSEL4 (0x4u << 8)
105 #define DACC_TRIGR_TRGSEL1_TRGSEL5 (0x5u << 8)
106 #define DACC_TRIGR_TRGSEL1_TRGSEL6 (0x6u << 8)
107 #define DACC_TRIGR_OSR0_Pos 16
108 #define DACC_TRIGR_OSR0_Msk (0x7u << DACC_TRIGR_OSR0_Pos)
109 #define DACC_TRIGR_OSR0(value) ((DACC_TRIGR_OSR0_Msk & ((value) << DACC_TRIGR_OSR0_Pos)))
110 #define DACC_TRIGR_OSR0_OSR_1 (0x0u << 16)
111 #define DACC_TRIGR_OSR0_OSR_2 (0x1u << 16)
112 #define DACC_TRIGR_OSR0_OSR_4 (0x2u << 16)
113 #define DACC_TRIGR_OSR0_OSR_8 (0x3u << 16)
114 #define DACC_TRIGR_OSR0_OSR_16 (0x4u << 16)
115 #define DACC_TRIGR_OSR0_OSR_32 (0x5u << 16)
116 #define DACC_TRIGR_OSR1_Pos 20
117 #define DACC_TRIGR_OSR1_Msk (0x7u << DACC_TRIGR_OSR1_Pos)
118 #define DACC_TRIGR_OSR1(value) ((DACC_TRIGR_OSR1_Msk & ((value) << DACC_TRIGR_OSR1_Pos)))
119 #define DACC_TRIGR_OSR1_OSR_1 (0x0u << 20)
120 #define DACC_TRIGR_OSR1_OSR_2 (0x1u << 20)
121 #define DACC_TRIGR_OSR1_OSR_4 (0x2u << 20)
122 #define DACC_TRIGR_OSR1_OSR_8 (0x3u << 20)
123 #define DACC_TRIGR_OSR1_OSR_16 (0x4u << 20)
124 #define DACC_TRIGR_OSR1_OSR_32 (0x5u << 20)
125 /* -------- DACC_CHER : (DACC Offset: 0x10) Channel Enable Register -------- */
126 #define DACC_CHER_CH0 (0x1u << 0)
127 #define DACC_CHER_CH1 (0x1u << 1)
128 /* -------- DACC_CHDR : (DACC Offset: 0x14) Channel Disable Register -------- */
129 #define DACC_CHDR_CH0 (0x1u << 0)
130 #define DACC_CHDR_CH1 (0x1u << 1)
131 /* -------- DACC_CHSR : (DACC Offset: 0x18) Channel Status Register -------- */
132 #define DACC_CHSR_CH0 (0x1u << 0)
133 #define DACC_CHSR_CH1 (0x1u << 1)
134 #define DACC_CHSR_DACRDY0 (0x1u << 8)
135 #define DACC_CHSR_DACRDY1 (0x1u << 9)
136 /* -------- DACC_CDR[2] : (DACC Offset: 0x1C) Conversion Data Register -------- */
137 #define DACC_CDR_DATA0_Pos 0
138 #define DACC_CDR_DATA0_Msk (0xffffu << DACC_CDR_DATA0_Pos)
139 #define DACC_CDR_DATA0(value) ((DACC_CDR_DATA0_Msk & ((value) << DACC_CDR_DATA0_Pos)))
140 #define DACC_CDR_DATA1_Pos 16
141 #define DACC_CDR_DATA1_Msk (0xffffu << DACC_CDR_DATA1_Pos)
142 #define DACC_CDR_DATA1(value) ((DACC_CDR_DATA1_Msk & ((value) << DACC_CDR_DATA1_Pos)))
143 /* -------- DACC_IER : (DACC Offset: 0x24) Interrupt Enable Register -------- */
144 #define DACC_IER_TXRDY0 (0x1u << 0)
145 #define DACC_IER_TXRDY1 (0x1u << 1)
146 #define DACC_IER_EOC0 (0x1u << 4)
147 #define DACC_IER_EOC1 (0x1u << 5)
148 /* -------- DACC_IDR : (DACC Offset: 0x28) Interrupt Disable Register -------- */
149 #define DACC_IDR_TXRDY0 (0x1u << 0)
150 #define DACC_IDR_TXRDY1 (0x1u << 1)
151 #define DACC_IDR_EOC0 (0x1u << 4)
152 #define DACC_IDR_EOC1 (0x1u << 5)
153 /* -------- DACC_IMR : (DACC Offset: 0x2C) Interrupt Mask Register -------- */
154 #define DACC_IMR_TXRDY0 (0x1u << 0)
155 #define DACC_IMR_TXRDY1 (0x1u << 1)
156 #define DACC_IMR_EOC0 (0x1u << 4)
157 #define DACC_IMR_EOC1 (0x1u << 5)
158 /* -------- DACC_ISR : (DACC Offset: 0x30) Interrupt Status Register -------- */
159 #define DACC_ISR_TXRDY0 (0x1u << 0)
160 #define DACC_ISR_TXRDY1 (0x1u << 1)
161 #define DACC_ISR_EOC0 (0x1u << 4)
162 #define DACC_ISR_EOC1 (0x1u << 5)
163 /* -------- DACC_ACR : (DACC Offset: 0x94) Analog Current Register -------- */
164 #define DACC_ACR_IBCTLCH0_Pos 0
165 #define DACC_ACR_IBCTLCH0_Msk (0x3u << DACC_ACR_IBCTLCH0_Pos)
166 #define DACC_ACR_IBCTLCH0(value) ((DACC_ACR_IBCTLCH0_Msk & ((value) << DACC_ACR_IBCTLCH0_Pos)))
167 #define DACC_ACR_IBCTLCH1_Pos 2
168 #define DACC_ACR_IBCTLCH1_Msk (0x3u << DACC_ACR_IBCTLCH1_Pos)
169 #define DACC_ACR_IBCTLCH1(value) ((DACC_ACR_IBCTLCH1_Msk & ((value) << DACC_ACR_IBCTLCH1_Pos)))
170 /* -------- DACC_WPMR : (DACC Offset: 0xE4) Write Protection Mode Register -------- */
171 #define DACC_WPMR_WPEN (0x1u << 0)
172 #define DACC_WPMR_WPKEY_Pos 8
173 #define DACC_WPMR_WPKEY_Msk (0xffffffu << DACC_WPMR_WPKEY_Pos)
174 #define DACC_WPMR_WPKEY(value) ((DACC_WPMR_WPKEY_Msk & ((value) << DACC_WPMR_WPKEY_Pos)))
175 #define DACC_WPMR_WPKEY_PASSWD (0x444143u << 8)
176 /* -------- DACC_WPSR : (DACC Offset: 0xE8) Write Protection Status Register -------- */
177 #define DACC_WPSR_WPVS (0x1u << 0)
178 #define DACC_WPSR_WPVSRC_Pos 8
179 #define DACC_WPSR_WPVSRC_Msk (0xffu << DACC_WPSR_WPVSRC_Pos)
182
183
184 #endif /* _SAME70_DACC_COMPONENT_ */
(Dacc Offset: 0xE4) Write Protection Mode Register
Definition: component_dacc.h:57
(Dacc Offset: 0x94) Analog Current Register
Definition: component_dacc.h:55
(Dacc Offset: 0x00) Control Register
Definition: component_dacc.h:42
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
(Dacc Offset: 0xE8) Write Protection Status Register
Definition: component_dacc.h:58
(Dacc Offset: 0x04) Mode Register
Definition: component_dacc.h:43
(Dacc Offset: 0x08) Trigger Register
Definition: component_dacc.h:44
(Dacc Offset: 0x30) Interrupt Status Register
Definition: component_dacc.h:53
(Dacc Offset: 0x10) Channel Enable Register
Definition: component_dacc.h:46
(Dacc Offset: 0x28) Interrupt Disable Register
Definition: component_dacc.h:51
Dacc hardware registers.
Definition: component_dacc.h:41
(Dacc Offset: 0x14) Channel Disable Register
Definition: component_dacc.h:47
(Dacc Offset: 0x24) Interrupt Enable Register
Definition: component_dacc.h:50
(Dacc Offset: 0x2C) Interrupt Mask Register
Definition: component_dacc.h:52
(Dacc Offset: 0x18) Channel Status Register
Definition: component_dacc.h:48
#define __I
Definition: core_cm7.h:284
