RTEMS  5.1
rtems-debugger-block.h
1 /*
2  * Copyright (c) 2016 Chris Johns <chrisj@rtems.org>.
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  */
26
27 /*
28  * Debugger for RTEMS.
29  */
30
31 #ifndef _RTEMS_DEBUGGER_BLOCK_h
32 #define _RTEMS_DEBUGGER_BLOCK_h
33
34 #include <rtems/rtems-debugger.h>
35
36 #ifdef __cplusplus
37 extern "C" {
38 #endif /* __cplusplus */
39
45 typedef struct rtems_debugger_block
46 {
47  void* block;
48  size_t step;
49  size_t size;
50  size_t count;
51  size_t level;
53
57 extern int rtems_debugger_block_create(rtems_debugger_block* block,
58  size_t step,
59  size_t size);
60
64 extern int rtems_debugger_block_destroy(rtems_debugger_block* block);
65
69 extern int rtems_debugger_block_resize(rtems_debugger_block* block);
70
71 #ifdef __cplusplus
72 }
73 #endif /* __cplusplus */
74
75
76 #endif
size_t step
Definition: rtems-debugger-block.h:48
size_t size
Definition: rtems-debugger-block.h:49
size_t count
Definition: rtems-debugger-block.h:50
size_t level
Definition: rtems-debugger-block.h:51
void * block
Definition: rtems-debugger-block.h:47
Definition: rtems-debugger-block.h:45
unsigned size
Definition: tte.h:74
