RTEMS  5.1
riscv-utility.h
1 /* Copyright (c) 2013, The Regents of the University of California (Regents).
2  * All Rights Reserved.
3  *
4  * Redistribution and use in source and binary forms, with or without
5  * modification, are permitted provided that the following conditions are met:
6  * 1. Redistributions of source code must retain the above copyright
7  * notice, this list of conditions and the following disclaimer.
8  * 2. Redistributions in binary form must reproduce the above copyright
9  * notice, this list of conditions and the following disclaimer in the
10  * documentation and/or other materials provided with the distribution.
11  * 3. Neither the name of the Regents nor the
12  * names of its contributors may be used to endorse or promote products
13  * derived from this software without specific prior written
14  * permission.
15  *
16  * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
17  * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
18  * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
19  * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
20  *
21  * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
22  * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
23  * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
24  * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
25  * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
26  */
27
33 /*
34  * COPYRIGHT (c) 2015 Hesham Almatary <hesham@alumni.york.ac.uk>
35  *
36  * The license and distribution terms for this file may be
37  * found in the file LICENSE in this distribution or at
38  * http://www.rtems.org/license/LICENSE.
39  */
40
41 /* This file is copied from riscv-tools/encoding.h with additions/modifications to work
42  * with RTEMS.
43  */
44 #ifndef _RTEMS_SCORE_RISCV_UTILITY_H
45 #define _RTEMS_SCORE_RISCV_UTILITY_H
46
47 #define MSTATUS_UIE 0x00000001
48 #define MSTATUS_SIE 0x00000002
49 #define MSTATUS_HIE 0x00000004
50 #define MSTATUS_MIE 0x00000008
51 #define MSTATUS_UPIE 0x00000010
52 #define MSTATUS_SPIE 0x00000020
53 #define MSTATUS_HPIE 0x00000040
54 #define MSTATUS_MPIE 0x00000080
55 #define MSTATUS_SPP 0x00000100
56 #define MSTATUS_HPP 0x00000600
57 #define MSTATUS_MPP 0x00001800
58 #define MSTATUS_FS 0x00006000
59 #define MSTATUS_XS 0x00018000
60 #define MSTATUS_MPRV 0x00020000
61 #define MSTATUS_SUM 0x00040000
62 #define MSTATUS_MXR 0x00080000
63 #define MSTATUS_TVM 0x00100000
64 #define MSTATUS_TW 0x00200000
65 #define MSTATUS_TSR 0x00400000
66 #define MSTATUS32_SD 0x80000000
67 #define MSTATUS64_SD 0x8000000000000000
68
69 #define SSTATUS_UIE 0x00000001
70 #define SSTATUS_SIE 0x00000002
71 #define SSTATUS_UPIE 0x00000010
72 #define SSTATUS_SPIE 0x00000020
73 #define SSTATUS_SPP 0x00000100
74 #define SSTATUS_FS 0x00006000
75 #define SSTATUS_XS 0x00018000
76 #define SSTATUS_SUM 0x00040000
77 #define SSTATUS_MXR 0x00080000
78 #define SSTATUS32_SD 0x80000000
79 #define SSTATUS64_SD 0x8000000000000000
80
81 #define DCSR_XDEBUGVER (3U<<30)
82 #define DCSR_NDRESET (1<<29)
83 #define DCSR_FULLRESET (1<<28)
84 #define DCSR_EBREAKM (1<<15)
85 #define DCSR_EBREAKH (1<<14)
86 #define DCSR_EBREAKS (1<<13)
87 #define DCSR_EBREAKU (1<<12)
88 #define DCSR_STOPCYCLE (1<<10)
89 #define DCSR_STOPTIME (1<<9)
90 #define DCSR_CAUSE (7<<6)
91 #define DCSR_DEBUGINT (1<<5)
92 #define DCSR_HALT (1<<3)
93 #define DCSR_STEP (1<<2)
94 #define DCSR_PRV (3<<0)
95
96 #define DCSR_CAUSE_NONE 0
97 #define DCSR_CAUSE_SWBP 1
98 #define DCSR_CAUSE_HWBP 2
99 #define DCSR_CAUSE_DEBUGINT 3
100 #define DCSR_CAUSE_STEP 4
101 #define DCSR_CAUSE_HALT 5
102
103 #define MCONTROL_TYPE(xlen) (0xfULL<<((xlen)-4))
104 #define MCONTROL_DMODE(xlen) (1ULL<<((xlen)-5))
105 #define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
106
107 #define MCONTROL_SELECT (1<<19)
108 #define MCONTROL_TIMING (1<<18)
109 #define MCONTROL_ACTION (0x3f<<12)
110 #define MCONTROL_CHAIN (1<<11)
111 #define MCONTROL_MATCH (0xf<<7)
112 #define MCONTROL_M (1<<6)
113 #define MCONTROL_H (1<<5)
114 #define MCONTROL_S (1<<4)
115 #define MCONTROL_U (1<<3)
116 #define MCONTROL_EXECUTE (1<<2)
117 #define MCONTROL_STORE (1<<1)
118 #define MCONTROL_LOAD (1<<0)
119
120 #define MCONTROL_TYPE_NONE 0
121 #define MCONTROL_TYPE_MATCH 2
122
123 #define MCONTROL_ACTION_DEBUG_EXCEPTION 0
124 #define MCONTROL_ACTION_DEBUG_MODE 1
125 #define MCONTROL_ACTION_TRACE_START 2
126 #define MCONTROL_ACTION_TRACE_STOP 3
127 #define MCONTROL_ACTION_TRACE_EMIT 4
128
129 #define MCONTROL_MATCH_EQUAL 0
130 #define MCONTROL_MATCH_NAPOT 1
131 #define MCONTROL_MATCH_GE 2
132 #define MCONTROL_MATCH_LT 3
133 #define MCONTROL_MATCH_MASK_LOW 4
134 #define MCONTROL_MATCH_MASK_HIGH 5
135
136 #define MIP_SSIP (1 << IRQ_S_SOFT)
137 #define MIP_HSIP (1 << IRQ_H_SOFT)
138 #define MIP_MSIP (1 << IRQ_M_SOFT)
139 #define MIP_STIP (1 << IRQ_S_TIMER)
140 #define MIP_HTIP (1 << IRQ_H_TIMER)
141 #define MIP_MTIP (1 << IRQ_M_TIMER)
142 #define MIP_SEIP (1 << IRQ_S_EXT)
143 #define MIP_HEIP (1 << IRQ_H_EXT)
144 #define MIP_MEIP (1 << IRQ_M_EXT)
145
146 #define SIP_SSIP MIP_SSIP
147 #define SIP_STIP MIP_STIP
148
149 #define PRV_U 0
150 #define PRV_S 1
151 #define PRV_H 2
152 #define PRV_M 3
153
154 #define SPTBR32_MODE 0x80000000
155 #define SPTBR32_ASID 0x7FC00000
156 #define SPTBR32_PPN 0x003FFFFF
157 #define SPTBR64_MODE 0xF000000000000000
158 #define SPTBR64_ASID 0x0FFFF00000000000
159 #define SPTBR64_PPN 0x00000FFFFFFFFFFF
160
161 #define SPTBR_MODE_OFF 0
162 #define SPTBR_MODE_SV32 1
163 #define SPTBR_MODE_SV39 8
164 #define SPTBR_MODE_SV48 9
165 #define SPTBR_MODE_SV57 10
166 #define SPTBR_MODE_SV64 11
167
168 #define PMP_R 0x01
169 #define PMP_W 0x02
170 #define PMP_X 0x04
171 #define PMP_A 0x18
172 #define PMP_L 0x80
173 #define PMP_SHIFT 2
174
175 #define PMP_TOR 0x08
176 #define PMP_NA4 0x10
177 #define PMP_NAPOT 0x18
178
179 #define IRQ_S_SOFT 1
180 #define IRQ_H_SOFT 2
181 #define IRQ_M_SOFT 3
182 #define IRQ_S_TIMER 5
183 #define IRQ_H_TIMER 6
184 #define IRQ_M_TIMER 7
185 #define IRQ_S_EXT 9
186 #define IRQ_H_EXT 10
187 #define IRQ_M_EXT 11
188 #define IRQ_COP 12
189 #define IRQ_HOST 13
190
191 #define DEFAULT_RSTVEC 0x00001000
192 #define CLINT_BASE 0x02000000
193 #define CLINT_SIZE 0x000c0000
194 #define EXT_IO_BASE 0x40000000
195 #define DRAM_BASE 0x80000000
196
197 // page table entry (PTE) fields
198 #define PTE_V 0x001 // Valid
199 #define PTE_R 0x002 // Read
200 #define PTE_W 0x004 // Write
201 #define PTE_X 0x008 // Execute
202 #define PTE_U 0x010 // User
203 #define PTE_G 0x020 // Global
204 #define PTE_A 0x040 // Accessed
205 #define PTE_D 0x080 // Dirty
206 #define PTE_SOFT 0x300 // Reserved for Software
207
208 #define PTE_PPN_SHIFT 10
209
210 #define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
211
212 #ifdef __riscv
213
214 #if __riscv_xlen == 64
215 # define MSTATUS_SD MSTATUS64_SD
216 # define SSTATUS_SD SSTATUS64_SD
217 # define RISCV_PGLEVEL_BITS 9
218 # define SPTBR_MODE SPTBR64_MODE
219 #else
220 # define MSTATUS_SD MSTATUS32_SD
221 # define SSTATUS_SD SSTATUS32_SD
222 # define RISCV_PGLEVEL_BITS 10
223 # define SPTBR_MODE SPTBR32_MODE
224 #endif
225 #define RISCV_PGSHIFT 12
226 #define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
227
228 #ifndef __ASSEMBLER__
229
235 typedef enum {
236  RISCV_USER_INTERRUPT = 0,
237  RISCV_SUPERVISOR_SW_INTERRUPT = 1,
238  RISCV_MACHINE_SW_INTERRUPT = 3,
239  RISCV_USER_TIMER_INTERRUPT = 4,
240  RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
241  RISCV_MACHINE_TIMER_INTERRUPT = 7,
242  RISCV_USER_EXTERNAL_INTERRUPT = 8,
243  RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
244  RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
245 } RISCV_Symbolic_interrupt_name;
246
247 #ifdef __GNUC__
248
249 #define read_csr(reg) ({ unsigned long __tmp; \
250  asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
251  __tmp; })
252
253 #define write_csr(reg, val) ({ \
254  asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })
255
256 #define swap_csr(reg, val) ({ unsigned long __tmp; \
257  asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \
258  __tmp; })
259
260 #define set_csr(reg, bit) ({ unsigned long __tmp; \
261  asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
262  __tmp; })
263
264 #define clear_csr(reg, bit) ({ unsigned long __tmp; \
265  asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
266  __tmp; })
267
268 #define rdtime() read_csr(time)
269 #define rdcycle() read_csr(cycle)
270 #define rdinstret() read_csr(instret)
271
272 #endif
273
274 #endif
275
276 #endif
277
278 #endif
279 /* Automatically generated by parse-opcodes. */
280 #ifndef RISCV_ENCODING_H
281 #define RISCV_ENCODING_H
282 #define MATCH_BEQ 0x63
283 #define MASK_BEQ 0x707f
284 #define MATCH_BNE 0x1063
285 #define MASK_BNE 0x707f
286 #define MATCH_BLT 0x4063
287 #define MASK_BLT 0x707f
288 #define MATCH_BGE 0x5063
289 #define MASK_BGE 0x707f
290 #define MATCH_BLTU 0x6063
291 #define MASK_BLTU 0x707f
292 #define MATCH_BGEU 0x7063
293 #define MASK_BGEU 0x707f
294 #define MATCH_JALR 0x67
295 #define MASK_JALR 0x707f
296 #define MATCH_JAL 0x6f
297 #define MASK_JAL 0x7f
298 #define MATCH_LUI 0x37
299 #define MASK_LUI 0x7f
300 #define MATCH_AUIPC 0x17
301 #define MASK_AUIPC 0x7f
302 #define MATCH_ADDI 0x13
303 #define MASK_ADDI 0x707f
304 #define MATCH_SLLI 0x1013
305 #define MASK_SLLI 0xfc00707f
306 #define MATCH_SLTI 0x2013
307 #define MASK_SLTI 0x707f
308 #define MATCH_SLTIU 0x3013
309 #define MASK_SLTIU 0x707f
310 #define MATCH_XORI 0x4013
311 #define MASK_XORI 0x707f
312 #define MATCH_SRLI 0x5013
313 #define MASK_SRLI 0xfc00707f
314 #define MATCH_SRAI 0x40005013
315 #define MASK_SRAI 0xfc00707f
316 #define MATCH_ORI 0x6013
317 #define MASK_ORI 0x707f
318 #define MATCH_ANDI 0x7013
319 #define MASK_ANDI 0x707f
320 #define MATCH_ADD 0x33
321 #define MASK_ADD 0xfe00707f
322 #define MATCH_SUB 0x40000033
323 #define MASK_SUB 0xfe00707f
324 #define MATCH_SLL 0x1033
325 #define MASK_SLL 0xfe00707f
326 #define MATCH_SLT 0x2033
327 #define MASK_SLT 0xfe00707f
328 #define MATCH_SLTU 0x3033
329 #define MASK_SLTU 0xfe00707f
330 #define MATCH_XOR 0x4033
331 #define MASK_XOR 0xfe00707f
332 #define MATCH_SRL 0x5033
333 #define MASK_SRL 0xfe00707f
334 #define MATCH_SRA 0x40005033
335 #define MASK_SRA 0xfe00707f
336 #define MATCH_OR 0x6033
337 #define MASK_OR 0xfe00707f
338 #define MATCH_AND 0x7033
339 #define MASK_AND 0xfe00707f
340 #define MATCH_ADDIW 0x1b
341 #define MASK_ADDIW 0x707f
342 #define MATCH_SLLIW 0x101b
343 #define MASK_SLLIW 0xfe00707f
344 #define MATCH_SRLIW 0x501b
345 #define MASK_SRLIW 0xfe00707f
346 #define MATCH_SRAIW 0x4000501b
347 #define MASK_SRAIW 0xfe00707f
348 #define MATCH_ADDW 0x3b
349 #define MASK_ADDW 0xfe00707f
350 #define MATCH_SUBW 0x4000003b
351 #define MASK_SUBW 0xfe00707f
352 #define MATCH_SLLW 0x103b
353 #define MASK_SLLW 0xfe00707f
354 #define MATCH_SRLW 0x503b
355 #define MASK_SRLW 0xfe00707f
356 #define MATCH_SRAW 0x4000503b
357 #define MASK_SRAW 0xfe00707f
358 #define MATCH_LB 0x3
359 #define MASK_LB 0x707f
360 #define MATCH_LH 0x1003
361 #define MASK_LH 0x707f
362 #define MATCH_LW 0x2003
363 #define MASK_LW 0x707f
364 #define MATCH_LD 0x3003
365 #define MASK_LD 0x707f
366 #define MATCH_LBU 0x4003
367 #define MASK_LBU 0x707f
368 #define MATCH_LHU 0x5003
369 #define MASK_LHU 0x707f
370 #define MATCH_LWU 0x6003
371 #define MASK_LWU 0x707f
372 #define MATCH_SB 0x23
373 #define MASK_SB 0x707f
374 #define MATCH_SH 0x1023
375 #define MASK_SH 0x707f
376 #define MATCH_SW 0x2023
377 #define MASK_SW 0x707f
378 #define MATCH_SD 0x3023
379 #define MASK_SD 0x707f
380 #define MATCH_FENCE 0xf
381 #define MASK_FENCE 0x707f
382 #define MATCH_FENCE_I 0x100f
383 #define MASK_FENCE_I 0x707f
384 #define MATCH_MUL 0x2000033
385 #define MASK_MUL 0xfe00707f
386 #define MATCH_MULH 0x2001033
387 #define MASK_MULH 0xfe00707f
388 #define MATCH_MULHSU 0x2002033
389 #define MASK_MULHSU 0xfe00707f
390 #define MATCH_MULHU 0x2003033
391 #define MASK_MULHU 0xfe00707f
392 #define MATCH_DIV 0x2004033
393 #define MASK_DIV 0xfe00707f
394 #define MATCH_DIVU 0x2005033
395 #define MASK_DIVU 0xfe00707f
396 #define MATCH_REM 0x2006033
397 #define MASK_REM 0xfe00707f
398 #define MATCH_REMU 0x2007033
399 #define MASK_REMU 0xfe00707f
400 #define MATCH_MULW 0x200003b
401 #define MASK_MULW 0xfe00707f
402 #define MATCH_DIVW 0x200403b
403 #define MASK_DIVW 0xfe00707f
404 #define MATCH_DIVUW 0x200503b
405 #define MASK_DIVUW 0xfe00707f
406 #define MATCH_REMW 0x200603b
407 #define MASK_REMW 0xfe00707f
408 #define MATCH_REMUW 0x200703b
409 #define MASK_REMUW 0xfe00707f
410 #define MATCH_AMOADD_W 0x202f
411 #define MASK_AMOADD_W 0xf800707f
412 #define MATCH_AMOXOR_W 0x2000202f
413 #define MASK_AMOXOR_W 0xf800707f
414 #define MATCH_AMOOR_W 0x4000202f
415 #define MASK_AMOOR_W 0xf800707f
416 #define MATCH_AMOAND_W 0x6000202f
417 #define MASK_AMOAND_W 0xf800707f
418 #define MATCH_AMOMIN_W 0x8000202f
419 #define MASK_AMOMIN_W 0xf800707f
420 #define MATCH_AMOMAX_W 0xa000202f
421 #define MASK_AMOMAX_W 0xf800707f
422 #define MATCH_AMOMINU_W 0xc000202f
423 #define MASK_AMOMINU_W 0xf800707f
424 #define MATCH_AMOMAXU_W 0xe000202f
425 #define MASK_AMOMAXU_W 0xf800707f
426 #define MATCH_AMOSWAP_W 0x800202f
427 #define MASK_AMOSWAP_W 0xf800707f
428 #define MATCH_LR_W 0x1000202f
429 #define MASK_LR_W 0xf9f0707f
430 #define MATCH_SC_W 0x1800202f
431 #define MASK_SC_W 0xf800707f
432 #define MATCH_AMOADD_D 0x302f
433 #define MASK_AMOADD_D 0xf800707f
434 #define MATCH_AMOXOR_D 0x2000302f
435 #define MASK_AMOXOR_D 0xf800707f
436 #define MATCH_AMOOR_D 0x4000302f
437 #define MASK_AMOOR_D 0xf800707f
438 #define MATCH_AMOAND_D 0x6000302f
439 #define MASK_AMOAND_D 0xf800707f
440 #define MATCH_AMOMIN_D 0x8000302f
441 #define MASK_AMOMIN_D 0xf800707f
442 #define MATCH_AMOMAX_D 0xa000302f
443 #define MASK_AMOMAX_D 0xf800707f
444 #define MATCH_AMOMINU_D 0xc000302f
445 #define MASK_AMOMINU_D 0xf800707f
446 #define MATCH_AMOMAXU_D 0xe000302f
447 #define MASK_AMOMAXU_D 0xf800707f
448 #define MATCH_AMOSWAP_D 0x800302f
449 #define MASK_AMOSWAP_D 0xf800707f
450 #define MATCH_LR_D 0x1000302f
451 #define MASK_LR_D 0xf9f0707f
452 #define MATCH_SC_D 0x1800302f
453 #define MASK_SC_D 0xf800707f
454 #define MATCH_ECALL 0x73
455 #define MASK_ECALL 0xffffffff
456 #define MATCH_EBREAK 0x100073
457 #define MASK_EBREAK 0xffffffff
458 #define MATCH_URET 0x200073
459 #define MASK_URET 0xffffffff
460 #define MATCH_SRET 0x10200073
461 #define MASK_SRET 0xffffffff
462 #define MATCH_MRET 0x30200073
463 #define MASK_MRET 0xffffffff
464 #define MATCH_DRET 0x7b200073
465 #define MASK_DRET 0xffffffff
466 #define MATCH_SFENCE_VMA 0x12000073
467 #define MASK_SFENCE_VMA 0xfe007fff
468 #define MATCH_WFI 0x10500073
469 #define MASK_WFI 0xffffffff
470 #define MATCH_CSRRW 0x1073
471 #define MASK_CSRRW 0x707f
472 #define MATCH_CSRRS 0x2073
473 #define MASK_CSRRS 0x707f
474 #define MATCH_CSRRC 0x3073
475 #define MASK_CSRRC 0x707f
476 #define MATCH_CSRRWI 0x5073
477 #define MASK_CSRRWI 0x707f
478 #define MATCH_CSRRSI 0x6073
479 #define MASK_CSRRSI 0x707f
480 #define MATCH_CSRRCI 0x7073
481 #define MASK_CSRRCI 0x707f
482 #define MATCH_FADD_S 0x53
483 #define MASK_FADD_S 0xfe00007f
484 #define MATCH_FSUB_S 0x8000053
485 #define MASK_FSUB_S 0xfe00007f
486 #define MATCH_FMUL_S 0x10000053
487 #define MASK_FMUL_S 0xfe00007f
488 #define MATCH_FDIV_S 0x18000053
489 #define MASK_FDIV_S 0xfe00007f
490 #define MATCH_FSGNJ_S 0x20000053
491 #define MASK_FSGNJ_S 0xfe00707f
492 #define MATCH_FSGNJN_S 0x20001053
493 #define MASK_FSGNJN_S 0xfe00707f
494 #define MATCH_FSGNJX_S 0x20002053
495 #define MASK_FSGNJX_S 0xfe00707f
496 #define MATCH_FMIN_S 0x28000053
497 #define MASK_FMIN_S 0xfe00707f
498 #define MATCH_FMAX_S 0x28001053
499 #define MASK_FMAX_S 0xfe00707f
500 #define MATCH_FSQRT_S 0x58000053
501 #define MASK_FSQRT_S 0xfff0007f
502 #define MATCH_FADD_D 0x2000053
503 #define MASK_FADD_D 0xfe00007f
504 #define MATCH_FSUB_D 0xa000053
505 #define MASK_FSUB_D 0xfe00007f
506 #define MATCH_FMUL_D 0x12000053
507 #define MASK_FMUL_D 0xfe00007f
508 #define MATCH_FDIV_D 0x1a000053
509 #define MASK_FDIV_D 0xfe00007f
510 #define MATCH_FSGNJ_D 0x22000053
511 #define MASK_FSGNJ_D 0xfe00707f
512 #define MATCH_FSGNJN_D 0x22001053
513 #define MASK_FSGNJN_D 0xfe00707f
514 #define MATCH_FSGNJX_D 0x22002053
515 #define MASK_FSGNJX_D 0xfe00707f
516 #define MATCH_FMIN_D 0x2a000053
517 #define MASK_FMIN_D 0xfe00707f
518 #define MATCH_FMAX_D 0x2a001053
519 #define MASK_FMAX_D 0xfe00707f
520 #define MATCH_FCVT_S_D 0x40100053
521 #define MASK_FCVT_S_D 0xfff0007f
522 #define MATCH_FCVT_D_S 0x42000053
523 #define MASK_FCVT_D_S 0xfff0007f
524 #define MATCH_FSQRT_D 0x5a000053
525 #define MASK_FSQRT_D 0xfff0007f
526 #define MATCH_FADD_Q 0x6000053
527 #define MASK_FADD_Q 0xfe00007f
528 #define MATCH_FSUB_Q 0xe000053
529 #define MASK_FSUB_Q 0xfe00007f
530 #define MATCH_FMUL_Q 0x16000053
531 #define MASK_FMUL_Q 0xfe00007f
532 #define MATCH_FDIV_Q 0x1e000053
533 #define MASK_FDIV_Q 0xfe00007f
534 #define MATCH_FSGNJ_Q 0x26000053
535 #define MASK_FSGNJ_Q 0xfe00707f
536 #define MATCH_FSGNJN_Q 0x26001053
537 #define MASK_FSGNJN_Q 0xfe00707f
538 #define MATCH_FSGNJX_Q 0x26002053
539 #define MASK_FSGNJX_Q 0xfe00707f
540 #define MATCH_FMIN_Q 0x2e000053
541 #define MASK_FMIN_Q 0xfe00707f
542 #define MATCH_FMAX_Q 0x2e001053
543 #define MASK_FMAX_Q 0xfe00707f
544 #define MATCH_FCVT_S_Q 0x40300053
545 #define MASK_FCVT_S_Q 0xfff0007f
546 #define MATCH_FCVT_Q_S 0x46000053
547 #define MASK_FCVT_Q_S 0xfff0007f
548 #define MATCH_FCVT_D_Q 0x42300053
549 #define MASK_FCVT_D_Q 0xfff0007f
550 #define MATCH_FCVT_Q_D 0x46100053
551 #define MASK_FCVT_Q_D 0xfff0007f
552 #define MATCH_FSQRT_Q 0x5e000053
553 #define MASK_FSQRT_Q 0xfff0007f
554 #define MATCH_FLE_S 0xa0000053
555 #define MASK_FLE_S 0xfe00707f
556 #define MATCH_FLT_S 0xa0001053
557 #define MASK_FLT_S 0xfe00707f
558 #define MATCH_FEQ_S 0xa0002053
559 #define MASK_FEQ_S 0xfe00707f
560 #define MATCH_FLE_D 0xa2000053
561 #define MASK_FLE_D 0xfe00707f
562 #define MATCH_FLT_D 0xa2001053
563 #define MASK_FLT_D 0xfe00707f
564 #define MATCH_FEQ_D 0xa2002053
565 #define MASK_FEQ_D 0xfe00707f
566 #define MATCH_FLE_Q 0xa6000053
567 #define MASK_FLE_Q 0xfe00707f
568 #define MATCH_FLT_Q 0xa6001053
569 #define MASK_FLT_Q 0xfe00707f
570 #define MATCH_FEQ_Q 0xa6002053
571 #define MASK_FEQ_Q 0xfe00707f
572 #define MATCH_FCVT_W_S 0xc0000053
573 #define MASK_FCVT_W_S 0xfff0007f
574 #define MATCH_FCVT_WU_S 0xc0100053
575 #define MASK_FCVT_WU_S 0xfff0007f
576 #define MATCH_FCVT_L_S 0xc0200053
577 #define MASK_FCVT_L_S 0xfff0007f
578 #define MATCH_FCVT_LU_S 0xc0300053
579 #define MASK_FCVT_LU_S 0xfff0007f
580 #define MATCH_FMV_X_W 0xe0000053
581 #define MASK_FMV_X_W 0xfff0707f
582 #define MATCH_FCLASS_S 0xe0001053
583 #define MASK_FCLASS_S 0xfff0707f
584 #define MATCH_FCVT_W_D 0xc2000053
585 #define MASK_FCVT_W_D 0xfff0007f
586 #define MATCH_FCVT_WU_D 0xc2100053
587 #define MASK_FCVT_WU_D 0xfff0007f
588 #define MATCH_FCVT_L_D 0xc2200053
589 #define MASK_FCVT_L_D 0xfff0007f
590 #define MATCH_FCVT_LU_D 0xc2300053
591 #define MASK_FCVT_LU_D 0xfff0007f
592 #define MATCH_FMV_X_D 0xe2000053
593 #define MASK_FMV_X_D 0xfff0707f
594 #define MATCH_FCLASS_D 0xe2001053
595 #define MASK_FCLASS_D 0xfff0707f
596 #define MATCH_FCVT_W_Q 0xc6000053
597 #define MASK_FCVT_W_Q 0xfff0007f
598 #define MATCH_FCVT_WU_Q 0xc6100053
599 #define MASK_FCVT_WU_Q 0xfff0007f
600 #define MATCH_FCVT_L_Q 0xc6200053
601 #define MASK_FCVT_L_Q 0xfff0007f
602 #define MATCH_FCVT_LU_Q 0xc6300053
603 #define MASK_FCVT_LU_Q 0xfff0007f
604 #define MATCH_FMV_X_Q 0xe6000053
605 #define MASK_FMV_X_Q 0xfff0707f
606 #define MATCH_FCLASS_Q 0xe6001053
607 #define MASK_FCLASS_Q 0xfff0707f
608 #define MATCH_FCVT_S_W 0xd0000053
609 #define MASK_FCVT_S_W 0xfff0007f
610 #define MATCH_FCVT_S_WU 0xd0100053
611 #define MASK_FCVT_S_WU 0xfff0007f
612 #define MATCH_FCVT_S_L 0xd0200053
613 #define MASK_FCVT_S_L 0xfff0007f
614 #define MATCH_FCVT_S_LU 0xd0300053
615 #define MASK_FCVT_S_LU 0xfff0007f
616 #define MATCH_FMV_W_X 0xf0000053
617 #define MASK_FMV_W_X 0xfff0707f
618 #define MATCH_FCVT_D_W 0xd2000053
619 #define MASK_FCVT_D_W 0xfff0007f
620 #define MATCH_FCVT_D_WU 0xd2100053
621 #define MASK_FCVT_D_WU 0xfff0007f
622 #define MATCH_FCVT_D_L 0xd2200053
623 #define MASK_FCVT_D_L 0xfff0007f
624 #define MATCH_FCVT_D_LU 0xd2300053
625 #define MASK_FCVT_D_LU 0xfff0007f
626 #define MATCH_FMV_D_X 0xf2000053
627 #define MASK_FMV_D_X 0xfff0707f
628 #define MATCH_FCVT_Q_W 0xd6000053
629 #define MASK_FCVT_Q_W 0xfff0007f
630 #define MATCH_FCVT_Q_WU 0xd6100053
631 #define MASK_FCVT_Q_WU 0xfff0007f
632 #define MATCH_FCVT_Q_L 0xd6200053
633 #define MASK_FCVT_Q_L 0xfff0007f
634 #define MATCH_FCVT_Q_LU 0xd6300053
635 #define MASK_FCVT_Q_LU 0xfff0007f
636 #define MATCH_FMV_Q_X 0xf6000053
637 #define MASK_FMV_Q_X 0xfff0707f
638 #define MATCH_FLW 0x2007
639 #define MASK_FLW 0x707f
640 #define MATCH_FLD 0x3007
641 #define MASK_FLD 0x707f
642 #define MATCH_FLQ 0x4007
643 #define MASK_FLQ 0x707f
644 #define MATCH_FSW 0x2027
645 #define MASK_FSW 0x707f
646 #define MATCH_FSD 0x3027
647 #define MASK_FSD 0x707f
648 #define MATCH_FSQ 0x4027
649 #define MASK_FSQ 0x707f
650 #define MATCH_FMADD_S 0x43
651 #define MASK_FMADD_S 0x600007f
652 #define MATCH_FMSUB_S 0x47
653 #define MASK_FMSUB_S 0x600007f
654 #define MATCH_FNMSUB_S 0x4b
655 #define MASK_FNMSUB_S 0x600007f
656 #define MATCH_FNMADD_S 0x4f
657 #define MASK_FNMADD_S 0x600007f
658 #define MATCH_FMADD_D 0x2000043
659 #define MASK_FMADD_D 0x600007f
660 #define MATCH_FMSUB_D 0x2000047
661 #define MASK_FMSUB_D 0x600007f
662 #define MATCH_FNMSUB_D 0x200004b
663 #define MASK_FNMSUB_D 0x600007f
664 #define MATCH_FNMADD_D 0x200004f
665 #define MASK_FNMADD_D 0x600007f
666 #define MATCH_FMADD_Q 0x6000043
667 #define MASK_FMADD_Q 0x600007f
668 #define MATCH_FMSUB_Q 0x6000047
669 #define MASK_FMSUB_Q 0x600007f
670 #define MATCH_FNMSUB_Q 0x600004b
671 #define MASK_FNMSUB_Q 0x600007f
672 #define MATCH_FNMADD_Q 0x600004f
673 #define MASK_FNMADD_Q 0x600007f
674 #define MATCH_C_NOP 0x1
675 #define MASK_C_NOP 0xffff
676 #define MATCH_C_ADDI16SP 0x6101
677 #define MASK_C_ADDI16SP 0xef83
678 #define MATCH_C_JR 0x8002
679 #define MASK_C_JR 0xf07f
680 #define MATCH_C_JALR 0x9002
681 #define MASK_C_JALR 0xf07f
682 #define MATCH_C_EBREAK 0x9002
683 #define MASK_C_EBREAK 0xffff
684 #define MATCH_C_LD 0x6000
685 #define MASK_C_LD 0xe003
686 #define MATCH_C_SD 0xe000
687 #define MASK_C_SD 0xe003
688 #define MATCH_C_ADDIW 0x2001
689 #define MASK_C_ADDIW 0xe003
690 #define MATCH_C_LDSP 0x6002
691 #define MASK_C_LDSP 0xe003
692 #define MATCH_C_SDSP 0xe002
693 #define MASK_C_SDSP 0xe003
694 #define MATCH_C_ADDI4SPN 0x0
695 #define MASK_C_ADDI4SPN 0xe003
696 #define MATCH_C_FLD 0x2000
697 #define MASK_C_FLD 0xe003
698 #define MATCH_C_LW 0x4000
699 #define MASK_C_LW 0xe003
700 #define MATCH_C_FLW 0x6000
701 #define MASK_C_FLW 0xe003
702 #define MATCH_C_FSD 0xa000
703 #define MASK_C_FSD 0xe003
704 #define MATCH_C_SW 0xc000
705 #define MASK_C_SW 0xe003
706 #define MATCH_C_FSW 0xe000
707 #define MASK_C_FSW 0xe003
708 #define MATCH_C_ADDI 0x1
709 #define MASK_C_ADDI 0xe003
710 #define MATCH_C_JAL 0x2001
711 #define MASK_C_JAL 0xe003
712 #define MATCH_C_LI 0x4001
713 #define MASK_C_LI 0xe003
714 #define MATCH_C_LUI 0x6001
715 #define MASK_C_LUI 0xe003
716 #define MATCH_C_SRLI 0x8001
717 #define MASK_C_SRLI 0xec03
718 #define MATCH_C_SRAI 0x8401
719 #define MASK_C_SRAI 0xec03
720 #define MATCH_C_ANDI 0x8801
721 #define MASK_C_ANDI 0xec03
722 #define MATCH_C_SUB 0x8c01
723 #define MASK_C_SUB 0xfc63
724 #define MATCH_C_XOR 0x8c21
725 #define MASK_C_XOR 0xfc63
726 #define MATCH_C_OR 0x8c41
727 #define MASK_C_OR 0xfc63
728 #define MATCH_C_AND 0x8c61
729 #define MASK_C_AND 0xfc63
730 #define MATCH_C_SUBW 0x9c01
731 #define MASK_C_SUBW 0xfc63
732 #define MATCH_C_ADDW 0x9c21
733 #define MASK_C_ADDW 0xfc63
734 #define MATCH_C_J 0xa001
735 #define MASK_C_J 0xe003
736 #define MATCH_C_BEQZ 0xc001
737 #define MASK_C_BEQZ 0xe003
738 #define MATCH_C_BNEZ 0xe001
739 #define MASK_C_BNEZ 0xe003
740 #define MATCH_C_SLLI 0x2
741 #define MASK_C_SLLI 0xe003
742 #define MATCH_C_FLDSP 0x2002
743 #define MASK_C_FLDSP 0xe003
744 #define MATCH_C_LWSP 0x4002
745 #define MASK_C_LWSP 0xe003
746 #define MATCH_C_FLWSP 0x6002
747 #define MASK_C_FLWSP 0xe003
748 #define MATCH_C_MV 0x8002
749 #define MASK_C_MV 0xf003
750 #define MATCH_C_ADD 0x9002
751 #define MASK_C_ADD 0xf003
752 #define MATCH_C_FSDSP 0xa002
753 #define MASK_C_FSDSP 0xe003
754 #define MATCH_C_SWSP 0xc002
755 #define MASK_C_SWSP 0xe003
756 #define MATCH_C_FSWSP 0xe002
757 #define MASK_C_FSWSP 0xe003
758 #define MATCH_CUSTOM0 0xb
759 #define MASK_CUSTOM0 0x707f
760 #define MATCH_CUSTOM0_RS1 0x200b
761 #define MASK_CUSTOM0_RS1 0x707f
762 #define MATCH_CUSTOM0_RS1_RS2 0x300b
763 #define MASK_CUSTOM0_RS1_RS2 0x707f
764 #define MATCH_CUSTOM0_RD 0x400b
765 #define MASK_CUSTOM0_RD 0x707f
766 #define MATCH_CUSTOM0_RD_RS1 0x600b
767 #define MASK_CUSTOM0_RD_RS1 0x707f
768 #define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
769 #define MASK_CUSTOM0_RD_RS1_RS2 0x707f
770 #define MATCH_CUSTOM1 0x2b
771 #define MASK_CUSTOM1 0x707f
772 #define MATCH_CUSTOM1_RS1 0x202b
773 #define MASK_CUSTOM1_RS1 0x707f
774 #define MATCH_CUSTOM1_RS1_RS2 0x302b
775 #define MASK_CUSTOM1_RS1_RS2 0x707f
776 #define MATCH_CUSTOM1_RD 0x402b
777 #define MASK_CUSTOM1_RD 0x707f
778 #define MATCH_CUSTOM1_RD_RS1 0x602b
779 #define MASK_CUSTOM1_RD_RS1 0x707f
780 #define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
781 #define MASK_CUSTOM1_RD_RS1_RS2 0x707f
782 #define MATCH_CUSTOM2 0x5b
783 #define MASK_CUSTOM2 0x707f
784 #define MATCH_CUSTOM2_RS1 0x205b
785 #define MASK_CUSTOM2_RS1 0x707f
786 #define MATCH_CUSTOM2_RS1_RS2 0x305b
787 #define MASK_CUSTOM2_RS1_RS2 0x707f
788 #define MATCH_CUSTOM2_RD 0x405b
789 #define MASK_CUSTOM2_RD 0x707f
790 #define MATCH_CUSTOM2_RD_RS1 0x605b
791 #define MASK_CUSTOM2_RD_RS1 0x707f
792 #define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
793 #define MASK_CUSTOM2_RD_RS1_RS2 0x707f
794 #define MATCH_CUSTOM3 0x7b
795 #define MASK_CUSTOM3 0x707f
796 #define MATCH_CUSTOM3_RS1 0x207b
797 #define MASK_CUSTOM3_RS1 0x707f
798 #define MATCH_CUSTOM3_RS1_RS2 0x307b
799 #define MASK_CUSTOM3_RS1_RS2 0x707f
800 #define MATCH_CUSTOM3_RD 0x407b
801 #define MASK_CUSTOM3_RD 0x707f
802 #define MATCH_CUSTOM3_RD_RS1 0x607b
803 #define MASK_CUSTOM3_RD_RS1 0x707f
804 #define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
805 #define MASK_CUSTOM3_RD_RS1_RS2 0x707f
806 #define CSR_FFLAGS 0x1
807 #define CSR_FRM 0x2
808 #define CSR_FCSR 0x3
809 #define CSR_CYCLE 0xc00
810 #define CSR_TIME 0xc01
811 #define CSR_INSTRET 0xc02
812 #define CSR_HPMCOUNTER3 0xc03
813 #define CSR_HPMCOUNTER4 0xc04
814 #define CSR_HPMCOUNTER5 0xc05
815 #define CSR_HPMCOUNTER6 0xc06
816 #define CSR_HPMCOUNTER7 0xc07
817 #define CSR_HPMCOUNTER8 0xc08
818 #define CSR_HPMCOUNTER9 0xc09
819 #define CSR_HPMCOUNTER10 0xc0a
820 #define CSR_HPMCOUNTER11 0xc0b
821 #define CSR_HPMCOUNTER12 0xc0c
822 #define CSR_HPMCOUNTER13 0xc0d
823 #define CSR_HPMCOUNTER14 0xc0e
824 #define CSR_HPMCOUNTER15 0xc0f
825 #define CSR_HPMCOUNTER16 0xc10
826 #define CSR_HPMCOUNTER17 0xc11
827 #define CSR_HPMCOUNTER18 0xc12
828 #define CSR_HPMCOUNTER19 0xc13
829 #define CSR_HPMCOUNTER20 0xc14
830 #define CSR_HPMCOUNTER21 0xc15
831 #define CSR_HPMCOUNTER22 0xc16
832 #define CSR_HPMCOUNTER23 0xc17
833 #define CSR_HPMCOUNTER24 0xc18
834 #define CSR_HPMCOUNTER25 0xc19
835 #define CSR_HPMCOUNTER26 0xc1a
836 #define CSR_HPMCOUNTER27 0xc1b
837 #define CSR_HPMCOUNTER28 0xc1c
838 #define CSR_HPMCOUNTER29 0xc1d
839 #define CSR_HPMCOUNTER30 0xc1e
840 #define CSR_HPMCOUNTER31 0xc1f
841 #define CSR_SSTATUS 0x100
842 #define CSR_SIE 0x104
843 #define CSR_STVEC 0x105
844 #define CSR_SCOUNTEREN 0x106
845 #define CSR_SSCRATCH 0x140
846 #define CSR_SEPC 0x141
847 #define CSR_SCAUSE 0x142
848 #define CSR_SBADADDR 0x143
849 #define CSR_SIP 0x144
850 #define CSR_SPTBR 0x180
851 #define CSR_MSTATUS 0x300
852 #define CSR_MISA 0x301
853 #define CSR_MEDELEG 0x302
854 #define CSR_MIDELEG 0x303
855 #define CSR_MIE 0x304
856 #define CSR_MTVEC 0x305
857 #define CSR_MCOUNTEREN 0x306
858 #define CSR_MSCRATCH 0x340
859 #define CSR_MEPC 0x341
860 #define CSR_MCAUSE 0x342
861 #define CSR_MBADADDR 0x343
862 #define CSR_MIP 0x344
863 #define CSR_PMPCFG0 0x3a0
864 #define CSR_PMPCFG1 0x3a1
865 #define CSR_PMPCFG2 0x3a2
866 #define CSR_PMPCFG3 0x3a3
867 #define CSR_PMPADDR0 0x3b0
868 #define CSR_PMPADDR1 0x3b1
869 #define CSR_PMPADDR2 0x3b2
870 #define CSR_PMPADDR3 0x3b3
871 #define CSR_PMPADDR4 0x3b4
872 #define CSR_PMPADDR5 0x3b5
873 #define CSR_PMPADDR6 0x3b6
874 #define CSR_PMPADDR7 0x3b7
875 #define CSR_PMPADDR8 0x3b8
876 #define CSR_PMPADDR9 0x3b9
877 #define CSR_PMPADDR10 0x3ba
878 #define CSR_PMPADDR11 0x3bb
879 #define CSR_PMPADDR12 0x3bc
880 #define CSR_PMPADDR13 0x3bd
881 #define CSR_PMPADDR14 0x3be
882 #define CSR_PMPADDR15 0x3bf
883 #define CSR_TSELECT 0x7a0
884 #define CSR_TDATA1 0x7a1
885 #define CSR_TDATA2 0x7a2
886 #define CSR_TDATA3 0x7a3
887 #define CSR_DCSR 0x7b0
888 #define CSR_DPC 0x7b1
889 #define CSR_DSCRATCH 0x7b2
890 #define CSR_MCYCLE 0xb00
891 #define CSR_MINSTRET 0xb02
892 #define CSR_MHPMCOUNTER3 0xb03
893 #define CSR_MHPMCOUNTER4 0xb04
894 #define CSR_MHPMCOUNTER5 0xb05
895 #define CSR_MHPMCOUNTER6 0xb06
896 #define CSR_MHPMCOUNTER7 0xb07
897 #define CSR_MHPMCOUNTER8 0xb08
898 #define CSR_MHPMCOUNTER9 0xb09
899 #define CSR_MHPMCOUNTER10 0xb0a
900 #define CSR_MHPMCOUNTER11 0xb0b
901 #define CSR_MHPMCOUNTER12 0xb0c
902 #define CSR_MHPMCOUNTER13 0xb0d
903 #define CSR_MHPMCOUNTER14 0xb0e
904 #define CSR_MHPMCOUNTER15 0xb0f
905 #define CSR_MHPMCOUNTER16 0xb10
906 #define CSR_MHPMCOUNTER17 0xb11
907 #define CSR_MHPMCOUNTER18 0xb12
908 #define CSR_MHPMCOUNTER19 0xb13
909 #define CSR_MHPMCOUNTER20 0xb14
910 #define CSR_MHPMCOUNTER21 0xb15
911 #define CSR_MHPMCOUNTER22 0xb16
912 #define CSR_MHPMCOUNTER23 0xb17
913 #define CSR_MHPMCOUNTER24 0xb18
914 #define CSR_MHPMCOUNTER25 0xb19
915 #define CSR_MHPMCOUNTER26 0xb1a
916 #define CSR_MHPMCOUNTER27 0xb1b
917 #define CSR_MHPMCOUNTER28 0xb1c
918 #define CSR_MHPMCOUNTER29 0xb1d
919 #define CSR_MHPMCOUNTER30 0xb1e
920 #define CSR_MHPMCOUNTER31 0xb1f
921 #define CSR_MHPMEVENT3 0x323
922 #define CSR_MHPMEVENT4 0x324
923 #define CSR_MHPMEVENT5 0x325
924 #define CSR_MHPMEVENT6 0x326
925 #define CSR_MHPMEVENT7 0x327
926 #define CSR_MHPMEVENT8 0x328
927 #define CSR_MHPMEVENT9 0x329
928 #define CSR_MHPMEVENT10 0x32a
929 #define CSR_MHPMEVENT11 0x32b
930 #define CSR_MHPMEVENT12 0x32c
931 #define CSR_MHPMEVENT13 0x32d
932 #define CSR_MHPMEVENT14 0x32e
933 #define CSR_MHPMEVENT15 0x32f
934 #define CSR_MHPMEVENT16 0x330
935 #define CSR_MHPMEVENT17 0x331
936 #define CSR_MHPMEVENT18 0x332
937 #define CSR_MHPMEVENT19 0x333
938 #define CSR_MHPMEVENT20 0x334
939 #define CSR_MHPMEVENT21 0x335
940 #define CSR_MHPMEVENT22 0x336
941 #define CSR_MHPMEVENT23 0x337
942 #define CSR_MHPMEVENT24 0x338
943 #define CSR_MHPMEVENT25 0x339
944 #define CSR_MHPMEVENT26 0x33a
945 #define CSR_MHPMEVENT27 0x33b
946 #define CSR_MHPMEVENT28 0x33c
947 #define CSR_MHPMEVENT29 0x33d
948 #define CSR_MHPMEVENT30 0x33e
949 #define CSR_MHPMEVENT31 0x33f
950 #define CSR_MVENDORID 0xf11
951 #define CSR_MARCHID 0xf12
952 #define CSR_MIMPID 0xf13
953 #define CSR_MHARTID 0xf14
954 #define CSR_CYCLEH 0xc80
955 #define CSR_TIMEH 0xc81
956 #define CSR_INSTRETH 0xc82
957 #define CSR_HPMCOUNTER3H 0xc83
958 #define CSR_HPMCOUNTER4H 0xc84
959 #define CSR_HPMCOUNTER5H 0xc85
960 #define CSR_HPMCOUNTER6H 0xc86
961 #define CSR_HPMCOUNTER7H 0xc87
962 #define CSR_HPMCOUNTER8H 0xc88
963 #define CSR_HPMCOUNTER9H 0xc89
964 #define CSR_HPMCOUNTER10H 0xc8a
965 #define CSR_HPMCOUNTER11H 0xc8b
966 #define CSR_HPMCOUNTER12H 0xc8c
967 #define CSR_HPMCOUNTER13H 0xc8d
968 #define CSR_HPMCOUNTER14H 0xc8e
969 #define CSR_HPMCOUNTER15H 0xc8f
970 #define CSR_HPMCOUNTER16H 0xc90
971 #define CSR_HPMCOUNTER17H 0xc91
972 #define CSR_HPMCOUNTER18H 0xc92
973 #define CSR_HPMCOUNTER19H 0xc93
974 #define CSR_HPMCOUNTER20H 0xc94
975 #define CSR_HPMCOUNTER21H 0xc95
976 #define CSR_HPMCOUNTER22H 0xc96
977 #define CSR_HPMCOUNTER23H 0xc97
978 #define CSR_HPMCOUNTER24H 0xc98
979 #define CSR_HPMCOUNTER25H 0xc99
980 #define CSR_HPMCOUNTER26H 0xc9a
981 #define CSR_HPMCOUNTER27H 0xc9b
982 #define CSR_HPMCOUNTER28H 0xc9c
983 #define CSR_HPMCOUNTER29H 0xc9d
984 #define CSR_HPMCOUNTER30H 0xc9e
985 #define CSR_HPMCOUNTER31H 0xc9f
986 #define CSR_MCYCLEH 0xb80
987 #define CSR_MINSTRETH 0xb82
988 #define CSR_MHPMCOUNTER3H 0xb83
989 #define CSR_MHPMCOUNTER4H 0xb84
990 #define CSR_MHPMCOUNTER5H 0xb85
991 #define CSR_MHPMCOUNTER6H 0xb86
992 #define CSR_MHPMCOUNTER7H 0xb87
993 #define CSR_MHPMCOUNTER8H 0xb88
994 #define CSR_MHPMCOUNTER9H 0xb89
995 #define CSR_MHPMCOUNTER10H 0xb8a
996 #define CSR_MHPMCOUNTER11H 0xb8b
997 #define CSR_MHPMCOUNTER12H 0xb8c
998 #define CSR_MHPMCOUNTER13H 0xb8d
999 #define CSR_MHPMCOUNTER14H 0xb8e
1000 #define CSR_MHPMCOUNTER15H 0xb8f
1001 #define CSR_MHPMCOUNTER16H 0xb90
1002 #define CSR_MHPMCOUNTER17H 0xb91
1003 #define CSR_MHPMCOUNTER18H 0xb92
1004 #define CSR_MHPMCOUNTER19H 0xb93
1005 #define CSR_MHPMCOUNTER20H 0xb94
1006 #define CSR_MHPMCOUNTER21H 0xb95
1007 #define CSR_MHPMCOUNTER22H 0xb96
1008 #define CSR_MHPMCOUNTER23H 0xb97
1009 #define CSR_MHPMCOUNTER24H 0xb98
1010 #define CSR_MHPMCOUNTER25H 0xb99
1011 #define CSR_MHPMCOUNTER26H 0xb9a
1012 #define CSR_MHPMCOUNTER27H 0xb9b
1013 #define CSR_MHPMCOUNTER28H 0xb9c
1014 #define CSR_MHPMCOUNTER29H 0xb9d
1015 #define CSR_MHPMCOUNTER30H 0xb9e
1016 #define CSR_MHPMCOUNTER31H 0xb9f
1017 #define CAUSE_MISALIGNED_FETCH 0x0
1018 #define CAUSE_FETCH_ACCESS 0x1
1019 #define CAUSE_ILLEGAL_INSTRUCTION 0x2
1020 #define CAUSE_BREAKPOINT 0x3
1021 #define CAUSE_MISALIGNED_LOAD 0x4
1022 #define CAUSE_LOAD_ACCESS 0x5
1023 #define CAUSE_MISALIGNED_STORE 0x6
1024 #define CAUSE_STORE_ACCESS 0x7
1025 #define CAUSE_USER_ECALL 0x8
1026 #define CAUSE_SUPERVISOR_ECALL 0x9
1027 #define CAUSE_HYPERVISOR_ECALL 0xa
1028 #define CAUSE_MACHINE_ECALL 0xb
1029 #define CAUSE_FETCH_PAGE_FAULT 0xc
1030 #define CAUSE_LOAD_PAGE_FAULT 0xd
1031 #define CAUSE_STORE_PAGE_FAULT 0xf
1032 #endif
1033 #ifdef DECLARE_INSN
1034 DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
1035 DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
1036 DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
1037 DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
1038 DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
1039 DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
1040 DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
1041 DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
1042 DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
1043 DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
1044 DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
1045 DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
1046 DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
1047 DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
1048 DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
1049 DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
1050 DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
1051 DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
1052 DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
1053 DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
1054 DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
1055 DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
1056 DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
1057 DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
1058 DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
1059 DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
1060 DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
1061 DECLARE_INSN( or , MATCH_OR, MASK_OR)
1062 DECLARE_INSN( and , MATCH_AND, MASK_AND)
1063 DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
1064 DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
1065 DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
1066 DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
1067 DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
1068 DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
1069 DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
1070 DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
1071 DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
1072 DECLARE_INSN(lb, MATCH_LB, MASK_LB)
1073 DECLARE_INSN(lh, MATCH_LH, MASK_LH)
1074 DECLARE_INSN(lw, MATCH_LW, MASK_LW)
1075 DECLARE_INSN(ld, MATCH_LD, MASK_LD)
1076 DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
1077 DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
1078 DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
1079 DECLARE_INSN(sb, MATCH_SB, MASK_SB)
1080 DECLARE_INSN(sh, MATCH_SH, MASK_SH)
1081 DECLARE_INSN(sw, MATCH_SW, MASK_SW)
1082 DECLARE_INSN(sd, MATCH_SD, MASK_SD)
1083 DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
1084 DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
1085 DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
1086 DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
1087 DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
1088 DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
1089 DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
1090 DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
1091 DECLARE_INSN(rem, MATCH_REM, MASK_REM)
1092 DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
1093 DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
1094 DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
1095 DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
1096 DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
1097 DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
1098 DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
1099 DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
1100 DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
1101 DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
1102 DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
1103 DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
1104 DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
1105 DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
1106 DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
1107 DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
1108 DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
1109 DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
1110 DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
1111 DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
1112 DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
1113 DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
1114 DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
1115 DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
1116 DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
1117 DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
1118 DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
1119 DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
1120 DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
1121 DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
1122 DECLARE_INSN(uret, MATCH_URET, MASK_URET)
1123 DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
1124 DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
1125 DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
1126 DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
1127 DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
1128 DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
1129 DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
1130 DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
1131 DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
1132 DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
1133 DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
1134 DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
1135 DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
1136 DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
1137 DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
1138 DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
1139 DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
1140 DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
1141 DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
1142 DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
1143 DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
1144 DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
1145 DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
1146 DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
1147 DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
1148 DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
1149 DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
1150 DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
1151 DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
1152 DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
1153 DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
1154 DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
1155 DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
1156 DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
1157 DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
1158 DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
1159 DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
1160 DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
1161 DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
1162 DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
1163 DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
1164 DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
1165 DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
1166 DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
1167 DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
1168 DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
1169 DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
1170 DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
1171 DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
1172 DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
1173 DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
1174 DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
1175 DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
1176 DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
1177 DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
1178 DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
1179 DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
1180 DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
1181 DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
1182 DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
1183 DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
1184 DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
1185 DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
1186 DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
1187 DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
1188 DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
1189 DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
1190 DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
1191 DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
1192 DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
1193 DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
1194 DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
1195 DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
1196 DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
1197 DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
1198 DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
1199 DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
1200 DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
1201 DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
1202 DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
1203 DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
1204 DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
1205 DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
1206 DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
1207 DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
1208 DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
1209 DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
1210 DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
1211 DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
1212 DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
1213 DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
1214 DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
1215 DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
1216 DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
1217 DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
1218 DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
1219 DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
1220 DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
1221 DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
1222 DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
1223 DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
1224 DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
1225 DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
1226 DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
1227 DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
1228 DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
1229 DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
1230 DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
1231 DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
1232 DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
1233 DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
1234 DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
1235 DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
1236 DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
1237 DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
1238 DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
1239 DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
1240 DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
1241 DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
1242 DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
1243 DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
1244 DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
1245 DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
1246 DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
1247 DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
1248 DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
1249 DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
1250 DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
1251 DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
1252 DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
1253 DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
1254 DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
1255 DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
1256 DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
1257 DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
1258 DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
1259 DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
1260 DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
1261 DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
1262 DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
1263 DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
1264 DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
1265 DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
1266 DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
1267 DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
1268 DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
1269 DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
1270 DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
1271 DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
1272 DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
1273 DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
1274 DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
1275 DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
1276 DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
1277 DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
1278 DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
1279 DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
1280 DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
1281 DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
1282 DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
1283 DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
1284 DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
1285 DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
1286 DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
1287 DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
1288 DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
1289 DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
1290 DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
1291 DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
1292 DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
1293 DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
1294 DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
1295 DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
1296 #endif
1297 #ifdef DECLARE_CSR
1298 DECLARE_CSR(fflags, CSR_FFLAGS)
1299 DECLARE_CSR(frm, CSR_FRM)
1300 DECLARE_CSR(fcsr, CSR_FCSR)
1301 DECLARE_CSR(cycle, CSR_CYCLE)
1302 DECLARE_CSR(time, CSR_TIME)
1303 DECLARE_CSR(instret, CSR_INSTRET)
1304 DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
1305 DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
1306 DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
1307 DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
1308 DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
1309 DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
1310 DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
1311 DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
1312 DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
1313 DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
1314 DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
1315 DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
1316 DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
1317 DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
1318 DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
1319 DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
1320 DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
1321 DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
1322 DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
1323 DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
1324 DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
1325 DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
1326 DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
1327 DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
1328 DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
1329 DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
1330 DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
1331 DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
1332 DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
1333 DECLARE_CSR(sstatus, CSR_SSTATUS)
1334 DECLARE_CSR(sie, CSR_SIE)
1335 DECLARE_CSR(stvec, CSR_STVEC)
1336 DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
1337 DECLARE_CSR(sscratch, CSR_SSCRATCH)
1338 DECLARE_CSR(sepc, CSR_SEPC)
1339 DECLARE_CSR(scause, CSR_SCAUSE)
1340 DECLARE_CSR(sbadaddr, CSR_SBADADDR)
1341 DECLARE_CSR(sip, CSR_SIP)
1342 DECLARE_CSR(sptbr, CSR_SPTBR)
1343 DECLARE_CSR(mstatus, CSR_MSTATUS)
1344 DECLARE_CSR(misa, CSR_MISA)
1345 DECLARE_CSR(medeleg, CSR_MEDELEG)
1346 DECLARE_CSR(mideleg, CSR_MIDELEG)
1347 DECLARE_CSR(mie, CSR_MIE)
1348 DECLARE_CSR(mtvec, CSR_MTVEC)
1349 DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
1350 DECLARE_CSR(mscratch, CSR_MSCRATCH)
1351 DECLARE_CSR(mepc, CSR_MEPC)
1352 DECLARE_CSR(mcause, CSR_MCAUSE)
1353 DECLARE_CSR(mbadaddr, CSR_MBADADDR)
1354 DECLARE_CSR(mip, CSR_MIP)
1355 DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
1356 DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
1357 DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
1358 DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
1359 DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
1360 DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
1361 DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
1362 DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
1363 DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
1364 DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
1365 DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
1366 DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
1367 DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
1368 DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
1369 DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
1370 DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
1371 DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
1372 DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
1373 DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
1374 DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
1375 DECLARE_CSR(tselect, CSR_TSELECT)
1376 DECLARE_CSR(tdata1, CSR_TDATA1)
1377 DECLARE_CSR(tdata2, CSR_TDATA2)
1378 DECLARE_CSR(tdata3, CSR_TDATA3)
1379 DECLARE_CSR(dcsr, CSR_DCSR)
1380 DECLARE_CSR(dpc, CSR_DPC)
1381 DECLARE_CSR(dscratch, CSR_DSCRATCH)
1382 DECLARE_CSR(mcycle, CSR_MCYCLE)
1383 DECLARE_CSR(minstret, CSR_MINSTRET)
1384 DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
1385 DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
1386 DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
1387 DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
1388 DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
1389 DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
1390 DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
1391 DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
1392 DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
1393 DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
1394 DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
1395 DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
1396 DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
1397 DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
1398 DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
1399 DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
1400 DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
1401 DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
1402 DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
1403 DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
1404 DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
1405 DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
1406 DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
1407 DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
1408 DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
1409 DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
1410 DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
1411 DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
1412 DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
1413 DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
1414 DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
1415 DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
1416 DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
1417 DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
1418 DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
1419 DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
1420 DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
1421 DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
1422 DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
1423 DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
1424 DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
1425 DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
1426 DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
1427 DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
1428 DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
1429 DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
1430 DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
1431 DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
1432 DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
1433 DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
1434 DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
1435 DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
1436 DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
1437 DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
1438 DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
1439 DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
1440 DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
1441 DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
1442 DECLARE_CSR(mvendorid, CSR_MVENDORID)
1443 DECLARE_CSR(marchid, CSR_MARCHID)
1444 DECLARE_CSR(mimpid, CSR_MIMPID)
1445 DECLARE_CSR(mhartid, CSR_MHARTID)
1446 DECLARE_CSR(cycleh, CSR_CYCLEH)
1447 DECLARE_CSR(timeh, CSR_TIMEH)
1448 DECLARE_CSR(instreth, CSR_INSTRETH)
1449 DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
1450 DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
1451 DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
1452 DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
1453 DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
1454 DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
1455 DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
1456 DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
1457 DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
1458 DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
1459 DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
1460 DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
1461 DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
1462 DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
1463 DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
1464 DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
1465 DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
1466 DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
1467 DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
1468 DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
1469 DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
1470 DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
1471 DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
1472 DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
1473 DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
1474 DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
1475 DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
1476 DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
1477 DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
1478 DECLARE_CSR(mcycleh, CSR_MCYCLEH)
1479 DECLARE_CSR(minstreth, CSR_MINSTRETH)
1480 DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
1481 DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
1482 DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
1483 DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
1484 DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
1485 DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
1486 DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
1487 DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
1488 DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
1489 DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
1490 DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
1491 DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
1492 DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
1493 DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
1494 DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
1495 DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
1496 DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
1497 DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
1498 DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
1499 DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
1500 DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
1501 DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
1502 DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
1503 DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
1504 DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
1505 DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
1506 DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
1507 DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
1508 DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
1509 #endif
1510 #ifdef DECLARE_CAUSE
1511 DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
1512 DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
1513 DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
1514 DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
1515 DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
1516 DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
1517 DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
1518 DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
1519 DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
1520 DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
1521 DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
1522 DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
1523 DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
1524 DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
1525 DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
1526 #endif
