RTEMS  5.1
residual.h
1 /* 7/18/95 */
2 /*----------------------------------------------------------------------------*/
3 /* Residual Data header definitions and prototypes */
4 /*----------------------------------------------------------------------------*/
5
6 /* Structure map for RESIDUAL on PowerPC Reference Platform */
7 /* residual.h - Residual data structure passed in r3. */
8 /* Load point passed in r4 to boot image. */
9 /* For enum's: if given in hex then they are bit significant, */
10 /* i.e. only one bit is on for each enum */
11 /* Reserved fields must be filled with zeros. */
12
13
14 #ifndef _RESIDUAL_
15 #define _RESIDUAL_
16
17 #ifndef ASM
18
19 #include <stdint.h>
20
21 #define MAX_CPUS 32 /* These should be set to the maximum */
22 #define MAX_MEMS 64 /* number possible for this system. */
23 #define MAX_DEVICES 256 /* Changing these will change the */
24 #define AVE_PNP_SIZE 32 /* structure, hence the version of */
25 #define MAX_MEM_SEGS 64 /* this header file. */
26
27 /*----------------------------------------------------------------------------*/
28 /* Public structures... */
29 /*----------------------------------------------------------------------------*/
30
31 #include <bsp/pnp.h>
32
33 typedef enum _L1CACHE_TYPE {
34  NoneCAC = 0,
35  SplitCAC = 1,
36  CombinedCAC = 2
37  } L1CACHE_TYPE;
38
39 typedef enum _TLB_TYPE {
40  NoneTLB = 0,
41  SplitTLB = 1,
42  CombinedTLB = 2
43  } TLB_TYPE;
44
45 typedef enum _FIRMWARE_SUPPORT {
46  Conventional = 0x01,
47  OpenFirmware = 0x02,
48  Diagnostics = 0x04,
49  LowDebug = 0x08,
50  Multiboot = 0x10,
51  LowClient = 0x20,
52  Hex41 = 0x40,
53  FAT = 0x80,
54  ISO9660 = 0x0100,
55  SCSI_InitiatorID_Override = 0x0200,
56  Tape_Boot = 0x0400,
57  FW_Boot_Path = 0x0800
58  } FIRMWARE_SUPPORT;
59
60 typedef enum _FIRMWARE_SUPPLIERS {
61  IBMFirmware = 0x00,
62  MotoFirmware = 0x01, /* 7/18/95 */
63  FirmWorks = 0x02, /* 10/5/95 */
64  Bull = 0x03, /* 04/03/96 */
65  QEMU = ('q'<<24) | ('e'<<16) | ('m'<<8) | ('u'<<0),
66  } FIRMWARE_SUPPLIERS;
67
68 typedef enum _ENDIAN_SWITCH_METHODS {
69  UsePort92 = 0x01,
70  UsePCIConfigA8 = 0x02,
71  UseFF001030 = 0x03,
72  } ENDIAN_SWITCH_METHODS;
73
74 typedef enum _SPREAD_IO_METHODS {
75  UsePort850 = 0x00,
76 /*UsePCIConfigA8 = 0x02,*/
77  } SPREAD_IO_METHODS;
78
79 typedef struct _VPD {
80
81  /* Box dependent stuff */
82  unsigned char PrintableModel[32]; /* Null terminated string.
83  Must be of the form:
84  vvv,<20h>,<model designation>,<0x0>
85  where vvv is the vendor ID
86  e.g. IBM PPS MODEL 6015<0x0> */
87  unsigned char Serial[16]; /* 12/94:
88  Serial Number; must be of the form:
89  vvv<serial number> where vvv is the
90  vendor ID.
91  e.g. IBM60151234567<20h><20h> */
92  unsigned char Reserved[48];
93  unsigned long FirmwareSupplier; /* See FirmwareSuppliers enum */
94  unsigned long FirmwareSupports; /* See FirmwareSupport enum */
95  unsigned long NvramSize; /* Size of nvram in bytes */
96  unsigned long NumSIMMSlots;
97  unsigned short EndianSwitchMethod; /* See EndianSwitchMethods enum */
98  unsigned short SpreadIOMethod; /* See SpreadIOMethods enum */
99  unsigned long SmpIar;
100  unsigned long RAMErrLogOffset; /* Heap offset to error log */
101  unsigned long Reserved5;
102  unsigned long Reserved6;
103  unsigned long ProcessorHz; /* Processor clock frequency in Hertz */
104  unsigned long ProcessorBusHz; /* Processor bus clock frequency */
105  unsigned long Reserved7;
106  unsigned long TimeBaseDivisor; /* (Bus clocks per timebase tic)*1000 */
107  unsigned long WordWidth; /* Word width in bits */
108  unsigned long PageSize; /* Page size in bytes */
109  unsigned long CoherenceBlockSize; /* Unit of transfer in/out of cache
110  for which coherency is maintained;
111  normally <= CacheLineSize. */
112  unsigned long GranuleSize; /* Unit of lock allocation to avoid */
113  /* false sharing of locks. */
114
115  /* L1 Cache variables */
116  unsigned long CacheSize; /* L1 Cache size in KB. This is the */
117  /* total size of the L1, whether */
118  /* combined or split */
119  unsigned long CacheAttrib; /* L1CACHE_TYPE */
120  unsigned long CacheAssoc; /* L1 Cache associativity. Use this
121  for combined cache. If split, put
122  zeros here. */
123  unsigned long CacheLineSize; /* L1 Cache line size in bytes. Use
124  for combined cache. If split, put
125  zeros here. */
126  /* For split L1 Cache: (= combined if combined cache) */
127  unsigned long I_CacheSize;
128  unsigned long I_CacheAssoc;
129  unsigned long I_CacheLineSize;
130  unsigned long D_CacheSize;
131  unsigned long D_CacheAssoc;
132  unsigned long D_CacheLineSize;
133
134  /* Translation Lookaside Buffer variables */
135  unsigned long TLBSize; /* Total number of TLBs on the system */
136  unsigned long TLBAttrib; /* Combined I+D or split TLB */
137  unsigned long TLBAssoc; /* TLB Associativity. Use this for
138  combined TLB. If split, put zeros
139  here. */
140  /* For split TLB: (= combined if combined TLB) */
141  unsigned long I_TLBSize;
142  unsigned long I_TLBAssoc;
143  unsigned long D_TLBSize;
144  unsigned long D_TLBAssoc;
145
146  unsigned long ExtendedVPD; /* Offset to extended VPD area;
147  null if unused */
148  } VPD;
149
150 typedef enum _DEVICE_FLAGS {
151  Enabled = 0x4000, /* 1 - PCI device is enabled */
152  Integrated = 0x2000,
153  Failed = 0x1000, /* 1 - device failed POST code tests */
154  Static = 0x0800, /* 0 - dynamically configurable
155  1 - static */
156  Dock = 0x0400, /* 0 - not a docking station device
157  1 - is a docking station device */
158  Boot = 0x0200, /* 0 - device cannot be used for BOOT
159  1 - can be a BOOT device */
160  Configurable = 0x0100, /* 1 - device is configurable */
161  Disableable = 0x80, /* 1 - device can be disabled */
162  PowerManaged = 0x40, /* 0 - not managed; 1 - managed */
163  ReadOnly = 0x20, /* 1 - device is read only */
164  Removable = 0x10, /* 1 - device is removable */
165  ConsoleIn = 0x08,
166  ConsoleOut = 0x04,
167  Input = 0x02,
168  Output = 0x01
169  } DEVICE_FLAGS;
170
171 typedef enum _BUS_ID {
172  ISADEVICE = 0x01,
173  EISADEVICE = 0x02,
174  PCIDEVICE = 0x04,
175  PCMCIADEVICE = 0x08,
176  PNPISADEVICE = 0x10,
177  MCADEVICE = 0x20,
178  MXDEVICE = 0x40, /* Devices on mezzanine bus */
179  PROCESSORDEVICE = 0x80, /* Devices on processor bus */
180  VMEDEVICE = 0x100,
181  } BUS_ID;
182
183 typedef struct _DEVICE_ID {
184  unsigned long BusId; /* See BUS_ID enum above */
185  unsigned long DevId; /* Big Endian format */
186  unsigned long SerialNum; /* For multiple usage of a single
187  DevId */
188  unsigned long Flags; /* See DEVICE_FLAGS enum above */
189  unsigned char BaseType; /* See pnp.h for bit definitions */
190  unsigned char SubType; /* See pnp.h for bit definitions */
191  unsigned char Interface; /* See pnp.h for bit definitions */
192  unsigned char Spare;
193  } DEVICE_ID;
194
195 typedef union _BUS_ACCESS {
196  struct _PnPAccess{
197  unsigned char CSN;
198  unsigned char LogicalDevNumber;
199  unsigned short ReadDataPort;
200  } PnPAccess;
201  struct _ISAAccess{
202  unsigned char SlotNumber; /* ISA Slot Number generally not
203  available; 0 if unknown */
204  unsigned char LogicalDevNumber;
205  unsigned short ISAReserved;
206  } ISAAccess;
207  struct _MCAAccess{
208  unsigned char SlotNumber;
209  unsigned char LogicalDevNumber;
210  unsigned short MCAReserved;
211  } MCAAccess;
213  unsigned char SlotNumber;
214  unsigned char LogicalDevNumber;
215  unsigned short PCMCIAReserved;
216  } PCMCIAAccess;
217  struct _EISAAccess{
218  unsigned char SlotNumber;
219  unsigned char FunctionNumber;
220  unsigned short EISAReserved;
221  } EISAAccess;
222  struct _PCIAccess{
223  unsigned char BusNumber;
224  unsigned char DevFuncNumber;
225  unsigned short PCIReserved;
226  } PCIAccess;
228  unsigned char BusNumber;
229  unsigned char BUID;
230  unsigned short ProcBusReserved;
231  } ProcBusAccess;
232  } BUS_ACCESS;
233
234 /* Per logical device information */
235 typedef struct _PPC_DEVICE {
236  DEVICE_ID DeviceId;
237  BUS_ACCESS BusAccess;
238
239  /* The following three are offsets into the DevicePnPHeap */
240  /* All are in PnP compressed format */
241  unsigned long AllocatedOffset; /* Allocated resource description */
242  unsigned long PossibleOffset; /* Possible resource description */
243  unsigned long CompatibleOffset; /* Compatible device identifiers */
244  } PPC_DEVICE;
245
246 typedef enum _CPU_STATE {
247  CPU_GOOD = 0, /* CPU is present, and active */
248  CPU_GOOD_FW = 1, /* CPU is present, and in firmware */
249  CPU_OFF = 2, /* CPU is present, but inactive */
250  CPU_FAILED = 3, /* CPU is present, but failed POST */
251  CPU_NOT_PRESENT = 255 /* CPU not present */
252  } CPU_STATE;
253
254 typedef struct _PPC_CPU {
255  unsigned long CpuType; /* Result of mfspr from Processor
256  Version Register (PVR).
257  PVR(0-15) = Version (e.g. 601)
258  PVR(16-31 = EC Level */
259  unsigned char CpuNumber; /* CPU Number for this processor */
260  unsigned char CpuState; /* CPU State, see CPU_STATE enum */
261  unsigned short Reserved;
262  } PPC_CPU;
263
264 typedef struct _PPC_MEM {
265  unsigned long SIMMSize; /* 0 - absent or bad
266  8M, 32M (in MB) */
267  } PPC_MEM;
268
269 typedef enum _MEM_USAGE {
270  Other = 0x8000,
271  ResumeBlock = 0x4000, /* for use by power management */
272  SystemROM = 0x2000, /* Flash memory (populated) */
273  UnPopSystemROM = 0x1000, /* Unpopulated part of SystemROM area */
274  IOMemory = 0x0800,
275  SystemIO = 0x0400,
276  SystemRegs = 0x0200,
277  PCIAddr = 0x0100,
278  PCIConfig = 0x80,
279  ISAAddr = 0x40,
280  Unpopulated = 0x20, /* Unpopulated part of System Memory */
281  Free = 0x10, /* Free part of System Memory */
282  BootImage = 0x08, /* BootImage part of System Memory */
283  FirmwareCode = 0x04, /* FirmwareCode part of System Memory */
284  FirmwareHeap = 0x02, /* FirmwareHeap part of System Memory */
285  FirmwareStack = 0x01 /* FirmwareStack part of System Memory*/
286  } MEM_USAGE;
287
288 typedef struct _MEM_MAP {
289  unsigned long Usage; /* See MEM_USAGE above */
290  unsigned long BasePage; /* Page number measured in 4KB pages */
291  unsigned long PageCount; /* Page count measured in 4KB pages */
292  } MEM_MAP;
293
294 typedef struct _RESIDUAL {
295  unsigned long ResidualLength; /* Length of Residual */
296  unsigned char Version; /* of this data structure */
297  unsigned char Revision; /* of this data structure */
298  unsigned short EC; /* of this data structure */
299  /* VPD */
300  VPD VitalProductData;
301  /* CPU */
302  unsigned short MaxNumCpus; /* Max CPUs in this system */
303  unsigned short ActualNumCpus; /* ActualNumCpus < MaxNumCpus means */
304  /* that there are unpopulated or */
305  /* otherwise unusable cpu locations */
306  PPC_CPU Cpus[MAX_CPUS];
307  /* Memory */
308  unsigned long TotalMemory; /* Total amount of memory installed */
309  unsigned long GoodMemory; /* Total amount of good memory */
310  unsigned long ActualNumMemSegs;
311  MEM_MAP Segs[MAX_MEM_SEGS];
312  unsigned long ActualNumMemories;
313  PPC_MEM Memories[MAX_MEMS];
314  /* Devices */
315  unsigned long ActualNumDevices;
316  PPC_DEVICE Devices[MAX_DEVICES];
317  unsigned char DevicePnPHeap[2*MAX_DEVICES*AVE_PNP_SIZE];
318  } RESIDUAL;
319
320 #ifndef NULL
321 #define NULL 0
322 #endif
323
324 static inline int
325 residual_fw_is_qemu(RESIDUAL *r)
326 {
327  return QEMU == r->VitalProductData.FirmwareSupplier;
328 }
329
330 extern RESIDUAL residualCopy;
331
332 extern void print_residual_device_info(void);
333 #ifndef __BOOT__
334 extern PPC_DEVICE *residual_find_device(RESIDUAL *res, unsigned long BusMask,
335  unsigned char * DevID, int BaseType,
336  int SubType, int Interface, int n);
337 #else
338 extern PPC_DEVICE *residual_find_device(unsigned long BusMask,
339  unsigned char * DevID, int BaseType,
340  int SubType, int Interface, int n);
341 #endif
342 extern PnP_TAG_PACKET *PnP_find_packet(unsigned char *p, unsigned packet_tag,
343  int n);
344 extern PnP_TAG_PACKET *PnP_find_small_vendor_packet(unsigned char *p,
345  unsigned packet_type,
346  int n);
347 extern PnP_TAG_PACKET *PnP_find_large_vendor_packet(unsigned char *p,
348  unsigned packet_type,
349  int n);
350 /*
351  * Prototypes for methods called only from .S for dependency tracking
352  */
353 uint32_t res_copy(void);
354
355 #endif /* ASM */
356 #endif /* ndef _RESIDUAL_ */
Definition: residual.h:79
Definition: residual.h:264
Definition: residual.h:195
Definition: residual.h:212
Definition: residual.h:288
unsigned p
Definition: tte.h:90
Definition: pnp.h:505
Definition: residual.h:207
Definition: residual.h:201
Definition: residual.h:254
Definition: residual.h:217
Definition: residual.h:235
Definition: residual.h:196
Definition: residual.h:294
Definition: residual.h:227
Definition: residual.h:183
Definition: residual.h:222
