RTEMS  5.1
reg_vim.h
1 /* The header file is generated by make_header.py from VIM.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_VIM
40 #define LIBBSP_ARM_TMS570_VIM
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t PARFLG; /*Interrupt Vector Table Parity Flag Register*/
46  uint32_t PARCTL; /*Interrupt Vector Table Parity Control Register*/
47  uint32_t ADDERR; /*Address Parity Error Register*/
48  uint32_t FBPARERR; /*Fall-Back Address Parity Error Register*/
49  uint8_t reserved1 [4];
50  uint32_t IRQINDEX; /*IRQ Index Offset Vector Register*/
51  uint32_t FIQINDEX; /*FIQ Index Offset Vector Register*/
52  uint8_t reserved2 [8];
53  uint32_t FIRQPR[3]; /*FIQ/IRQ Program Control Register*/
54  uint8_t reserved3 [4];
55  uint32_t INTREQ[3]; /*Pending Interrupt Read Location Register*/
56  uint8_t reserved4 [4];
57  uint32_t REQENASET[3]; /*Interrupt Enable Set Register */
58  uint8_t reserved5 [4];
59  uint32_t REQENACLR[3]; /*Interrupt Enable Clear Register */
60  uint8_t reserved6 [4];
61  uint32_t WAKEENASET[3]; /*Wake-Up Enable Set Register*/
62  uint8_t reserved7 [4];
63  uint32_t WAKEENACLR[3]; /*Wake-Up Enable Clear Registers*/
64  uint8_t reserved8 [4];
65  uint32_t IRQVECREG; /*IRQ Interrupt Vector Register*/
66  uint32_t FIQVECREG; /*FIQ Interrupt Vector Register*/
67  uint32_t CAPEVT; /*Capture Event Register*/
68  uint8_t reserved9 [4];
69  uint32_t CHANCTRL[24]; /*VIM Interrupt Control Register*/
70 } tms570_vim_t;
71
72
73 /*---------------------TMS570_VIM_PARFLG---------------------*/
74 /* field: PARFLG - The PARFLG indicates that a parity error has been found and that theInterrupt Vector Table is */
75 #define TMS570_VIM_PARFLG_PARFLG BSP_BIT32(0)
76
77
78 /*---------------------TMS570_VIM_PARCTL---------------------*/
79 /* field: TEST - This bit maps the parity bits into the Interrupt Vector Table frame to make them accessible by the */
80 #define TMS570_VIM_PARCTL_TEST BSP_BIT32(8)
81
82 /* field: PARENA - VIM parity enable. */
83 #define TMS570_VIM_PARCTL_PARENA(val) BSP_FLD32(val,0, 3)
84 #define TMS570_VIM_PARCTL_PARENA_GET(reg) BSP_FLD32GET(reg,0, 3)
85 #define TMS570_VIM_PARCTL_PARENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
86
87
88 /*---------------------TMS570_VIM_ADDERR---------------------*/
89 /* field: Interrupt_Vector_Table - Interrupt Vector Table offset. */
90 #define TMS570_VIM_ADDERR_Interrupt_Vector_Table(val) BSP_FLD32(val,9, 31)
91 #define TMS570_VIM_ADDERR_Interrupt_Vector_Table_GET(reg) BSP_FLD32GET(reg,9, 31)
92 #define TMS570_VIM_ADDERR_Interrupt_Vector_Table_SET(reg,val) BSP_FLD32SET(reg, val,9, 31)
93
94 /* field: ADDERR - Address parity error register. */
95 #define TMS570_VIM_ADDERR_ADDERR(val) BSP_FLD32(val,2, 8)
96 #define TMS570_VIM_ADDERR_ADDERR_GET(reg) BSP_FLD32GET(reg,2, 8)
97 #define TMS570_VIM_ADDERR_ADDERR_SET(reg,val) BSP_FLD32SET(reg, val,2, 8)
98
99 /* field: Word_offset - Word offset. Reads are always 0; writes have no effect. */
100 #define TMS570_VIM_ADDERR_Word_offset(val) BSP_FLD32(val,0, 1)
101 #define TMS570_VIM_ADDERR_Word_offset_GET(reg) BSP_FLD32GET(reg,0, 1)
102 #define TMS570_VIM_ADDERR_Word_offset_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
103
104
105 /*--------------------TMS570_VIM_FBPARERR--------------------*/
106 /* field: FBPARERR - Fall back address parity error. */
107 /* Whole 32 bits */
108
109 /*--------------------TMS570_VIM_IRQINDEX--------------------*/
110 /* field: IRQINDEX - IRQ index vector. */
111 #define TMS570_VIM_IRQINDEX_IRQINDEX(val) BSP_FLD32(val,0, 7)
112 #define TMS570_VIM_IRQINDEX_IRQINDEX_GET(reg) BSP_FLD32GET(reg,0, 7)
113 #define TMS570_VIM_IRQINDEX_IRQINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
114
115
116 /*--------------------TMS570_VIM_FIQINDEX--------------------*/
117 /* field: FIQINDEX - FIQ index offset vector. */
118 #define TMS570_VIM_FIQINDEX_FIQINDEX(val) BSP_FLD32(val,0, 7)
119 #define TMS570_VIM_FIQINDEX_FIQINDEX_GET(reg) BSP_FLD32GET(reg,0, 7)
120 #define TMS570_VIM_FIQINDEX_FIQINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
121
122
123 /*---------------------TMS570_VIM_FIRQPR---------------------*/
124 /* field: FIRQPRx - FIQ/IRQ program control bits. 96 bit register. 0-1 bits reserved. */
125 /* Whole 32 bits */
126
127 /*---------------------TMS570_VIM_INTREQ---------------------*/
128 /* field: INTREQx - Pending interrupt bits. 96 bit register. */
129 /* Whole 32 bits */
130
131 /*--------------------TMS570_VIM_REQENASET--------------------*/
132 /* field: REQENASETx - Request enable set bits. 96 bit register. 0-1 bits reserved. */
133 /* Whole 32 bits */
134
135 /*--------------------TMS570_VIM_REQENACLR--------------------*/
136 /* field: REQENACLRx - Request enable clear bits. 96 bit register. 0-1 bits reserved. */
137 /* Whole 32 bits */
138
139 /*-------------------TMS570_VIM_WAKEENASET-------------------*/
140 /* field: WAKEENASETx - Wake-up enable set bits. This vector determines whether the wake-up interrupt line is enabled. */
141 /* Whole 32 bits */
142
143 /*-------------------TMS570_VIM_WAKEENACLR-------------------*/
144 /* field: WAKEENACLRx - Wake-up enable clear bits. This vector determines whether the wake-up interrupt line is enabled. */
145 /* Whole 32 bits */
146
147 /*--------------------TMS570_VIM_IRQVECREG--------------------*/
148 /* field: IRQVECREG - IRQ interrupt vector register. */
149 /* Whole 32 bits */
150
151 /*--------------------TMS570_VIM_FIQVECREG--------------------*/
152 /* field: FIQVECREG - FIQ interrupt vector register. */
153 /* Whole 32 bits */
154
155 /*---------------------TMS570_VIM_CAPEVT---------------------*/
156 /* field: CAPEVTSRC1 - Capture event source 1 mapping control. */
157 #define TMS570_VIM_CAPEVT_CAPEVTSRC1(val) BSP_FLD32(val,16, 22)
158 #define TMS570_VIM_CAPEVT_CAPEVTSRC1_GET(reg) BSP_FLD32GET(reg,16, 22)
159 #define TMS570_VIM_CAPEVT_CAPEVTSRC1_SET(reg,val) BSP_FLD32SET(reg, val,16, 22)
160
161 /* field: CAPEVTSRC0 - the capture event source 0 of the RTI: */
162 #define TMS570_VIM_CAPEVT_CAPEVTSRC0(val) BSP_FLD32(val,0, 6)
163 #define TMS570_VIM_CAPEVT_CAPEVTSRC0_GET(reg) BSP_FLD32GET(reg,0, 6)
164 #define TMS570_VIM_CAPEVT_CAPEVTSRC0_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
165
166
167 /*--------------------TMS570_VIM_CHANCTRL--------------------*/
168 /* field: CHANMAPx0 - CHANMAPx 0(6-0). Interrupt CHANx 0 mapping control. */
169 #define TMS570_VIM_CHANCTRL_CHANMAPx0(val) BSP_FLD32(val,24, 30)
170 #define TMS570_VIM_CHANCTRL_CHANMAPx0_GET(reg) BSP_FLD32GET(reg,24, 30)
171 #define TMS570_VIM_CHANCTRL_CHANMAPx0_SET(reg,val) BSP_FLD32SET(reg, val,24, 30)
172
173 /* field: CHANMAPx1 - CHANMAPx 1(6-0). Interrupt CHANx 1 mapping control. */
174 #define TMS570_VIM_CHANCTRL_CHANMAPx1(val) BSP_FLD32(val,16, 22)
175 #define TMS570_VIM_CHANCTRL_CHANMAPx1_GET(reg) BSP_FLD32GET(reg,16, 22)
176 #define TMS570_VIM_CHANCTRL_CHANMAPx1_SET(reg,val) BSP_FLD32SET(reg, val,16, 22)
177
178 /* field: CHANMAPx2 - CHANMAPx 2(6-0). Interrupt CHANx 2 mapping control. */
179 #define TMS570_VIM_CHANCTRL_CHANMAPx2(val) BSP_FLD32(val,8, 14)
180 #define TMS570_VIM_CHANCTRL_CHANMAPx2_GET(reg) BSP_FLD32GET(reg,8, 14)
181 #define TMS570_VIM_CHANCTRL_CHANMAPx2_SET(reg,val) BSP_FLD32SET(reg, val,8, 14)
182
183 /* field: CHANMAPx3 - CHANMAPx 3(6-0). Interrupt CHANx 3 mapping control. */
184 #define TMS570_VIM_CHANCTRL_CHANMAPx3(val) BSP_FLD32(val,0, 6)
185 #define TMS570_VIM_CHANCTRL_CHANMAPx3_GET(reg) BSP_FLD32GET(reg,0, 6)
186 #define TMS570_VIM_CHANCTRL_CHANMAPx3_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
187
188
189
190 #endif /* LIBBSP_ARM_TMS570_VIM */
Definition: reg_vim.h:44
Utility macros.
