RTEMS  5.1
reg_tcram.h
1 /* The header file is generated by make_header.py from TCRAM.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_TCRAM
40 #define LIBBSP_ARM_TMS570_TCRAM
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t RAMCTRL; /*TCRAM Module Control Register*/
46  uint32_t RAMTHRESHOLD; /*TCRAM Module Single-Bit Error Correction Threshold Register*/
47  uint32_t RAMOCCUR; /*TCRAM Module Single-Bit Error Occurrences Control Register*/
48  uint32_t RAMINTCTRL; /*TCRAM Module Interrupt Control Register*/
49  uint32_t RAMERRSTATUS; /*TCRAM Module Error Status Register*/
50  uint32_t RAMSERRADDR; /*TCRAM Module Single-Bit Error Address Register*/
51  uint8_t reserved1 [4];
52  uint32_t RAMUERRADDR; /*TCRAM Module Uncorrectable Error Address Register*/
53  uint8_t reserved2 [16];
54  uint32_t RAMTEST; /*TCRAM Module Test Mode Control Register*/
55  uint8_t reserved3 [4];
56  uint32_t RAMADDRDECVECT; /*TCRAM Module Test Mode Vector Register*/
57  uint32_t RAMPERADDR; /*TCRAM Module Parity Error Address Register*/
59
60
61 /*--------------------TMS570_TCRAM_RAMCTRL--------------------*/
62 /* field: EMU_TRACE_DIS - Emulation Mode Trace Disable. */
63 #define TMS570_TCRAM_RAMCTRL_EMU_TRACE_DIS BSP_BIT32(30)
64
65 /* field: ADDR_PARITY_OVERRIDE - Address Parity Override. */
66 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE(val) BSP_FLD32(val,24, 27)
67 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE_GET(reg) BSP_FLD32GET(reg,24, 27)
68 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
69
70 /* field: ADDR_PARITY_DISABLE - Address Parity Detect Disable. */
71 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE(val) BSP_FLD32(val,16, 19)
72 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE_GET(reg) BSP_FLD32GET(reg,16, 19)
73 #define TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
74
75 /* field: ECC_WR_EN - ECC Memory Write Enable. */
76 #define TMS570_TCRAM_RAMCTRL_ECC_WR_EN BSP_BIT32(8)
77
78 /* field: ECC_DETECT_EN - ECC Detect Enable. */
79 #define TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN(val) BSP_FLD32(val,0, 3)
80 #define TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN_GET(reg) BSP_FLD32GET(reg,0, 3)
81 #define TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
82
83
84 /*-----------------TMS570_TCRAM_RAMTHRESHOLD-----------------*/
85 /* field: THRESHOLD - Single-bit Error Threshold Count. */
86 #define TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD(val) BSP_FLD32(val,0, 15)
87 #define TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
88 #define TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
89
90
91 /*-------------------TMS570_TCRAM_RAMOCCUR-------------------*/
92 /* field: SINGLE_ERROR - Single-bit Error Correction Occurrences. */
93 #define TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR(val) BSP_FLD32(val,0, 15)
94 #define TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR_GET(reg) BSP_FLD32GET(reg,0, 15)
95 #define TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
96
97
98 /*------------------TMS570_TCRAM_RAMINTCTRL------------------*/
99 /* field: SERR_EN - Single-bit Error Correction Interrupt Enable. */
100 #define TMS570_TCRAM_RAMINTCTRL_SERR_EN BSP_BIT32(0)
101
102
103 /*-----------------TMS570_TCRAM_RAMERRSTATUS-----------------*/
104 /* field: WADDR_PAR_FAIL - This bit indicates a Write Address Parity Failure. */
105 #define TMS570_TCRAM_RAMERRSTATUS_WADDR_PAR_FAIL BSP_BIT32(9)
106
107 /* field: RADDR_PAR_FAIL - This bit indicates a Read Address Parity Failure. */
108 #define TMS570_TCRAM_RAMERRSTATUS_RADDR_PAR_FAIL BSP_BIT32(8)
109
110 /* field: DERR - This bit indicates a multi-bit error detected by the Cortex-R4F SECDED logic. */
111 #define TMS570_TCRAM_RAMERRSTATUS_DERR BSP_BIT32(5)
112
113 /* field: ADDR_COMP_LOGIC_FAIL - Address decode logic element failed. */
114 #define TMS570_TCRAM_RAMERRSTATUS_ADDR_COMP_LOGIC_FAIL BSP_BIT32(4)
115
116 /* field: ADDR_DEC_FAIL - Address decode failed. */
117 #define TMS570_TCRAM_RAMERRSTATUS_ADDR_DEC_FAIL BSP_BIT32(2)
118
119 /* field: SERR - Single Error Status. */
120 #define TMS570_TCRAM_RAMERRSTATUS_SERR BSP_BIT32(0)
121
122
123 /*------------------TMS570_TCRAM_RAMSERRADDR------------------*/
124 /* field: SINGLE_ERROR_ADDRESS - This register captures the bits 17-3 of the address for which the Cortex-R4F CPU */
125 #define TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS(val) BSP_FLD32(val,3, 17)
126 #define TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS_GET(reg) BSP_FLD32GET(reg,3, 17)
127 #define TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,3, 17)
128
129
130 /*------------------TMS570_TCRAM_RAMUERRADDR------------------*/
131 /* field: UNCORRECTABLE - address parity error. */
132 #define TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE(val) BSP_FLD32(val,3, 22)
133 #define TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE_GET(reg) BSP_FLD32GET(reg,3, 22)
134 #define TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE_SET(reg,val) BSP_FLD32SET(reg, val,3, 22)
135
136
137 /*--------------------TMS570_TCRAM_RAMTEST--------------------*/
138 /* field: TRIGGER - Test Trigger. */
139 #define TMS570_TCRAM_RAMTEST_TRIGGER BSP_BIT32(8)
140
141 /* field: TEST_MODE - Test Mode. This field selects either equality of inequality testing schemes. */
142 #define TMS570_TCRAM_RAMTEST_TEST_MODE(val) BSP_FLD32(val,6, 7)
143 #define TMS570_TCRAM_RAMTEST_TEST_MODE_GET(reg) BSP_FLD32GET(reg,6, 7)
144 #define TMS570_TCRAM_RAMTEST_TEST_MODE_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
145
146 /* field: TEST_ENABLE - Test Enable. */
147 #define TMS570_TCRAM_RAMTEST_TEST_ENABLE(val) BSP_FLD32(val,0, 3)
148 #define TMS570_TCRAM_RAMTEST_TEST_ENABLE_GET(reg) BSP_FLD32GET(reg,0, 3)
149 #define TMS570_TCRAM_RAMTEST_TEST_ENABLE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
150
151
152 /*----------------TMS570_TCRAM_RAMADDRDECVECT----------------*/
153 /* field: ECC_SELECT - ECC Select. */
154 #define TMS570_TCRAM_RAMADDRDECVECT_ECC_SELECT BSP_BIT32(26)
155
156 /* field: RAM_CHIP_SELECT - RAM Chip Select. */
157 #define TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT(val) BSP_FLD32(val,0, 15)
158 #define TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT_GET(reg) BSP_FLD32GET(reg,0, 15)
159 #define TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
160
161
162 /*------------------TMS570_TCRAM_RAMPERADDR------------------*/
163 /* field: ADDRESS_PARITY - Parity Error Address. */
164 #define TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY(val) BSP_FLD32(val,3, 22)
165 #define TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY_GET(reg) BSP_FLD32GET(reg,3, 22)
166 #define TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY_SET(reg,val) BSP_FLD32SET(reg, val,3, 22)
167
168
169
170 #endif /* LIBBSP_ARM_TMS570_TCRAM */
Definition: reg_tcram.h:44
Utility macros.
