RTEMS  5.1
reg_sys2.h
1 /* The header file is generated by make_header.py from SYS2.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_SYS2
40 #define LIBBSP_ARM_TMS570_SYS2
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t PLLCTL3; /*PLL Control Register 3*/
46  uint8_t reserved1 [4];
47  uint32_t STCCLKDIV; /*CPU Logic BIST Clock Divider*/
48  uint8_t reserved2 [24];
49  uint32_t ECPCNTL; /*ECP Control Register*/
50  uint8_t reserved3 [20];
51  uint32_t CLK2CNTRL; /*Clock 2 Control Register*/
52  uint32_t VCLKACON1; /*Peripheral Asynchronous Clock Configuration 1 Register*/
53  uint8_t reserved4 [44];
54  uint32_t CLKSLIP; /*Clock Slip Register*/
55  uint8_t reserved5 [120];
56  uint32_t EFC_CTLREG; /*EFUSE Controller Control Register*/
57  uint32_t DIEDL_REG0; /*Die Identification Register*/
58  uint32_t DIEDH_REG1; /*Die Identification Register*/
59  uint32_t DIEDL_REG2; /*Die Identification Register*/
60  uint32_t DIEDH_REG3; /*Die Identification Register*/
62
63
64 /*--------------------TMS570_SYS2_PLLCTL3--------------------*/
65 /* field: ODPLL2 - Internal PLL Output Divider */
66 #define TMS570_SYS2_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31)
67 #define TMS570_SYS2_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31)
68 #define TMS570_SYS2_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
69
70 /* field: PLLDIV2 - PLL2 Output Clock Divider */
71 #define TMS570_SYS2_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28)
72 #define TMS570_SYS2_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28)
73 #define TMS570_SYS2_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
74
75 /* field: REFCLKDIV2 - REFCLKDIV2 */
76 #define TMS570_SYS2_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21)
77 #define TMS570_SYS2_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21)
78 #define TMS570_SYS2_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
79
80 /* field: PLLMUL2 - PLL2 Multiplication Factor */
81 #define TMS570_SYS2_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15)
82 #define TMS570_SYS2_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15)
83 #define TMS570_SYS2_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
84
85
86 /*-------------------TMS570_SYS2_STCCLKDIV-------------------*/
87 /* field: CLKDIV - Clock divider/prescaler for CPU clock during logic BIST */
88 #define TMS570_SYS2_STCCLKDIV_CLKDIV(val) BSP_FLD32(val,24, 26)
89 #define TMS570_SYS2_STCCLKDIV_CLKDIV_GET(reg) BSP_FLD32GET(reg,24, 26)
90 #define TMS570_SYS2_STCCLKDIV_CLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
91
92
93 /*--------------------TMS570_SYS2_ECPCNTL--------------------*/
94 /* field: ECPSSEL - This bit allows the selection between VCLK and OSCIN as the clock source for ECLK. */
95 #define TMS570_SYS2_ECPCNTL_ECPSSEL BSP_BIT32(24)
96
97 /* field: ECPCOS - ECP continue on suspend. */
98 #define TMS570_SYS2_ECPCNTL_ECPCOS BSP_BIT32(23)
99
100 /* field: ECPINSEL - Select ECP input clock source. */
101 #define TMS570_SYS2_ECPCNTL_ECPINSEL(val) BSP_FLD32(val,6, 17)
102 #define TMS570_SYS2_ECPCNTL_ECPINSEL_GET(reg) BSP_FLD32GET(reg,6, 17)
103 #define TMS570_SYS2_ECPCNTL_ECPINSEL_SET(reg,val) BSP_FLD32SET(reg, val,6, 17)
104
105 /* field: ECPDIV - ECP divider value. */
106 #define TMS570_SYS2_ECPCNTL_ECPDIV(val) BSP_FLD32(val,0, 15)
107 #define TMS570_SYS2_ECPCNTL_ECPDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
108 #define TMS570_SYS2_ECPCNTL_ECPDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
109
110
111 /*-------------------TMS570_SYS2_CLK2CNTRL-------------------*/
112 /* field: VCLK3R - VBUS clock3 ratio. */
113 #define TMS570_SYS2_CLK2CNTRL_VCLK3R(val) BSP_FLD32(val,0, 3)
114 #define TMS570_SYS2_CLK2CNTRL_VCLK3R_GET(reg) BSP_FLD32GET(reg,0, 3)
115 #define TMS570_SYS2_CLK2CNTRL_VCLK3R_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
116
117
118 /*-------------------TMS570_SYS2_VCLKACON1-------------------*/
119 /* field: VCLKA4R - Clock divider for the VCLKA4 source. Output will be present on VCLKA4_DIVR. */
120 #define TMS570_SYS2_VCLKACON1_VCLKA4R(val) BSP_FLD32(val,24, 26)
121 #define TMS570_SYS2_VCLKACON1_VCLKA4R_GET(reg) BSP_FLD32GET(reg,24, 26)
122 #define TMS570_SYS2_VCLKACON1_VCLKA4R_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
123
124 /* field: VCLKA4_DIV_CDDIS - Disable the VCLKA4 divider output. */
125 #define TMS570_SYS2_VCLKACON1_VCLKA4_DIV_CDDIS BSP_BIT32(20)
126
127 /* field: VCLKA4S - Peripheral asynchronous clock4 source. */
128 #define TMS570_SYS2_VCLKACON1_VCLKA4S(val) BSP_FLD32(val,16, 19)
129 #define TMS570_SYS2_VCLKACON1_VCLKA4S_GET(reg) BSP_FLD32GET(reg,16, 19)
130 #define TMS570_SYS2_VCLKACON1_VCLKA4S_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
131
132 /* field: VCLKA3R - Clock divider for the VCLKA3 source. Output will be present on VCLKA3_DIVR. */
133 #define TMS570_SYS2_VCLKACON1_VCLKA3R(val) BSP_FLD32(val,8, 10)
134 #define TMS570_SYS2_VCLKACON1_VCLKA3R_GET(reg) BSP_FLD32GET(reg,8, 10)
135 #define TMS570_SYS2_VCLKACON1_VCLKA3R_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
136
137 /* field: VCLKA3_DIV_CDDIS - Disable the VCLKA3 divider output. */
138 #define TMS570_SYS2_VCLKACON1_VCLKA3_DIV_CDDIS BSP_BIT32(4)
139
140 /* field: VCLKA3S - Peripheral asynchronous clock3 source. */
141 #define TMS570_SYS2_VCLKACON1_VCLKA3S(val) BSP_FLD32(val,0, 3)
142 #define TMS570_SYS2_VCLKACON1_VCLKA3S_GET(reg) BSP_FLD32GET(reg,0, 3)
143 #define TMS570_SYS2_VCLKACON1_VCLKA3S_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
144
145
146 /*--------------------TMS570_SYS2_CLKSLIP--------------------*/
147 /* field: PLL1_SLIP_FILTER_COUNT - Configure the count for the filtered PLL slip. Count is on 10M clock. */
148 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13)
149 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13)
150 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
151
152 /* field: PLL1_SLIP_FILTER_KEY - Enable the PLL filtering. */
153 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3)
154 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
155 #define TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
156
157
158 /*-------------------TMS570_SYS2_EFC_CTLREG-------------------*/
159 /* field: EFC_INSTR_WEN - Enable user write of 4 EFUSE controller instructions. */
160 #define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN(val) BSP_FLD32(val,0, 3)
161 #define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_GET(reg) BSP_FLD32GET(reg,0, 3)
162 #define TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
163
164
165 /*-----------------------TMS570_SYS2_x-----------------------*/
166 /* field: DIE - This read-only register contains the lower/upper word (31:0) of the die ID information. */
167 /* Whole 32 bits */
168
169
170 #endif /* LIBBSP_ARM_TMS570_SYS2 */
Definition: reg_sys2.h:44
Utility macros.
