RTEMS  5.1
reg_spi.h
1 /* The header file is generated by make_header.py from SPI.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_SPI
40 #define LIBBSP_ARM_TMS570_SPI
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t GCR0; /*SPI Global Control Register 0*/
46  uint32_t GCR1; /*SPI Global Control Register 1*/
47  uint32_t INT0; /*SPI Interrupt Register*/
48  uint32_t LVL; /*SPI Interrupt Level Register*/
49  uint32_t FLG; /*SPI Flag Register*/
50  uint32_t PC0; /*SPI Pin Control Register 0*/
51  uint32_t PC1; /*SPI Pin Control Register 1*/
52  uint32_t PC2; /*SPI Pin Control Register 2*/
53  uint32_t PC3; /*SPI Pin Control Register 3*/
54  uint32_t PC4; /*SPI Pin Control Register 4*/
55  uint32_t PC5; /*SPI Pin Control Register 5*/
56  uint32_t PC6; /*SPI Pin Control Register 6*/
57  uint32_t PC7; /*SPI Pin Control Register 7*/
58  uint32_t PC8; /*SPI Pin Control Register 8*/
59  uint32_t DAT0; /*SPI Transmit Data Register 0*/
60  uint32_t DAT1; /*SPI Transmit Data Register 1*/
61  uint32_t BUF; /*SPI Receive Buffer Register*/
62  uint32_t EMU; /*SPI Emulation Register*/
63  uint32_t DELAY; /*SPI Delay Register*/
64  uint32_t DEF; /*SPI Default Chip Select Register*/
65  uint32_t FMT0; /*SPI Data Format Register 0*/
66  uint32_t FMT1; /*SPI Data Format Register 1*/
67  uint32_t FMT2; /*SPI Data Format Register 2*/
68  uint32_t FMT3; /*SPI Data Format Register 3*/
69  uint32_t INTVECT0; /*Interrupt Vector 0*/
70  uint32_t INTVECT1; /*Interrupt Vector 1*/
71  uint8_t reserved1 [4];
72  uint32_t PMCTRL; /*Parallel/Modulo Mode Control Register*/
73  uint32_t MIBSPIE; /*Multi-buffer Mode Enable Register*/
74  uint32_t TGITENST; /*TG Interrupt Enable Set Register*/
75  uint32_t TGITENCR; /*TG Interrupt Enable Clear Register*/
76  uint32_t TGITLVST; /*Transfer Group Interrupt Level Set Register*/
77  uint32_t TGITLVCR; /*Transfer Group Interrupt Level Clear Register*/
78  uint32_t TGINTFLG; /*Transfer Group Interrupt Flag Register*/
79  uint8_t reserved2 [8];
80  uint32_t TICKCNT; /*Tick Count Register*/
81  uint32_t LTGPEND; /*Last TG End Pointer*/
82  uint32_t TGCTRL[16]; /*TG Control Registers*/
83  uint32_t DMACTRL[8]; /*DMA Channel Control Register*/
84  uint32_t DMACOUNT[8]; /*DMA COUNT Register*/
85  uint32_t DMACNTLEN; /*DMA Large Count*/
86  uint8_t reserved3 [4];
87  uint32_t UERRCTRL; /*Multi-buffer RAM Uncorrectable Parity Error Control Register*/
88  uint32_t UERRSTAT; /*Multi-buffer RAM Uncorrectable Parity Error Status Register*/
89  uint32_t UERRADDRRX; /*RXRAM Uncorrectable Parity Error Address Register*/
90  uint32_t UERRADDRTX; /*TXRAM Uncorrectable Parity Error Address Register*/
91  uint32_t RXOVRN_BUF_ADDR; /*RXRAM Overrun Buffer Address Register*/
92  uint32_t IOLPBKTSTCR; /*I/O Loopback Test Control Register*/
93  uint32_t EXT_PRESCALE1; /*SPI Extended Prescale Register 1*/
94  uint32_t EXT_PRESCALE2; /*SPI Extended Prescale Register 2*/
95 } tms570_spi_t;
96
97
98 /*----------------------TMS570_SPI_GCR0----------------------*/
99 /* field: nRESET - This is the local reset control for the module. */
100 #define TMS570_SPI_GCR0_nRESET BSP_BIT32(0)
101
102
103 /*----------------------TMS570_SPI_GCR1----------------------*/
104 /* field: SPIEN - SPI enable. This bit enables SPI transfers. */
105 #define TMS570_SPI_GCR1_SPIEN BSP_BIT32(24)
106
107 /* field: LOOPBACK - Internal loop-back test mode. The internal self-test option can be enabled by setting this bit. */
108 #define TMS570_SPI_GCR1_LOOPBACK BSP_BIT32(16)
109
110 /* field: POWERDOWN - When active, the SPI state machine enters a power-down state. */
111 #define TMS570_SPI_GCR1_POWERDOWN BSP_BIT32(8)
112
113 /* field: CLKMOD - Clock mode. This bit selects either an internal or external clock source. */
114 #define TMS570_SPI_GCR1_CLKMOD BSP_BIT32(1)
115
116 /* field: MASTER - SPISIMO/SPISOMI pin direction determination. */
117 #define TMS570_SPI_GCR1_MASTER BSP_BIT32(0)
118
119
120 /*----------------------TMS570_SPI_INT0----------------------*/
121 /* field: ENABLEHIGHZ - SPIENA pin high-impedance enable. */
122 #define TMS570_SPI_INT0_ENABLEHIGHZ BSP_BIT32(24)
123
124 /* field: DMAREQEN - DMA request enable. */
125 #define TMS570_SPI_INT0_DMAREQEN BSP_BIT32(16)
126
127
128 /*-----------------------TMS570_SPI_LVL-----------------------*/
129 /* field: TXINTLVL - Transmit interrupt level. */
130 #define TMS570_SPI_LVL_TXINTLVL BSP_BIT32(9)
131
132 /* field: RXINTLVL - Receive interrupt level. */
133 #define TMS570_SPI_LVL_RXINTLVL BSP_BIT32(8)
134
135 /* field: RXOVRNINTLVL - Receive overrun interrupt level. */
136 #define TMS570_SPI_LVL_RXOVRNINTLVL BSP_BIT32(6)
137
138 /* field: BITERRLVL - Bit error interrupt level. */
139 #define TMS570_SPI_LVL_BITERRLVL BSP_BIT32(4)
140
141 /* field: DESYNCLVL - Desynchronized slave interrupt level. (master mode only). */
142 #define TMS570_SPI_LVL_DESYNCLVL BSP_BIT32(3)
143
144 /* field: PARERRLVL - Parity error interrupt level. */
145 #define TMS570_SPI_LVL_PARERRLVL BSP_BIT32(2)
146
147 /* field: TIMEOUTLVL - SPIENA pin time-out interrupt level. */
148 #define TMS570_SPI_LVL_TIMEOUTLVL BSP_BIT32(1)
149
150 /* field: DLENERRLVL - Data length error interrupt level (line) select. */
151 #define TMS570_SPI_LVL_DLENERRLVL BSP_BIT32(0)
152
153
154 /*-----------------------TMS570_SPI_FLG-----------------------*/
155 /* field: BUFINITACTIVE - Indicates the status of multi-buffer initialization process. */
156 #define TMS570_SPI_FLG_BUFINITACTIVE BSP_BIT32(24)
157
158 /* field: TXINTFLG - Transmitter-empty interrupt flag. */
159 #define TMS570_SPI_FLG_TXINTFLG BSP_BIT32(9)
160
161 /* field: RXINTFLG - Receiver-full interrupt flag. */
162 #define TMS570_SPI_FLG_RXINTFLG BSP_BIT32(8)
163
164 /* field: RXOVRNINTFLG - Receiver overrun flag. */
165 #define TMS570_SPI_FLG_RXOVRNINTFLG BSP_BIT32(6)
166
167 /* field: BITERRFLG - Mismatch of internal transmit data and transmitted data. */
168 #define TMS570_SPI_FLG_BITERRFLG BSP_BIT32(4)
169
170 /* field: DESYNCFLG - Desynchronization of slave device. */
171 #define TMS570_SPI_FLG_DESYNCFLG BSP_BIT32(3)
172
173 /* field: PARITYERRFLG - Calculated parity differs from received parity bit. */
174 #define TMS570_SPI_FLG_PARITYERRFLG BSP_BIT32(2)
175
176 /* field: TIMEOUTFLG - Time-out caused by nonactivation of ENA signal. */
177 #define TMS570_SPI_FLG_TIMEOUTFLG BSP_BIT32(1)
178
179 /* field: DLENERRFLG - Data-length error flag. */
180 #define TMS570_SPI_FLG_DLENERRFLG BSP_BIT32(0)
181
182
183 /*-----------------------TMS570_SPI_PC0-----------------------*/
184 /* field: SOMIFUN - Slave out, master in function. */
185 #define TMS570_SPI_PC0_SOMIFUN(val) BSP_FLD32(val,24, 31)
186 #define TMS570_SPI_PC0_SOMIFUN_GET(reg) BSP_FLD32GET(reg,24, 31)
187 #define TMS570_SPI_PC0_SOMIFUN_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
188
189 /* field: SIMOFUN - Slave in, master out function. */
190 #define TMS570_SPI_PC0_SIMOFUN(val) BSP_FLD32(val,16, 23)
191 #define TMS570_SPI_PC0_SIMOFUN_GET(reg) BSP_FLD32GET(reg,16, 23)
192 #define TMS570_SPI_PC0_SIMOFUN_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
193
194 /* field: SOMIFUN0 - SOMIFUN0 */
195 #define TMS570_SPI_PC0_SOMIFUN0 BSP_BIT32(11)
196
197 /* field: SIMOFUN0 - Slave in, master out function. */
198 #define TMS570_SPI_PC0_SIMOFUN0 BSP_BIT32(10)
199
200 /* field: CLKFUN - CLKFUN */
201 #define TMS570_SPI_PC0_CLKFUN BSP_BIT32(9)
202
203 /* field: ENAFUN - SPIENA function. */
204 #define TMS570_SPI_PC0_ENAFUN BSP_BIT32(8)
205
206 /* field: SCSFUN - SPISCSx function. */
207 #define TMS570_SPI_PC0_SCSFUN(val) BSP_FLD32(val,0, 7)
208 #define TMS570_SPI_PC0_SCSFUN_GET(reg) BSP_FLD32GET(reg,0, 7)
209 #define TMS570_SPI_PC0_SCSFUN_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
210
211
212 /*-----------------------TMS570_SPI_PC1-----------------------*/
213 /* field: SOMIDIR - SPISOMIx direction. Controls the direction of SPISOMIx when used for general-purpose I/O. */
214 #define TMS570_SPI_PC1_SOMIDIR(val) BSP_FLD32(val,24, 31)
215 #define TMS570_SPI_PC1_SOMIDIR_GET(reg) BSP_FLD32GET(reg,24, 31)
216 #define TMS570_SPI_PC1_SOMIDIR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
217
218 /* field: SIMODIR - SPISIMOx direction. Controls the direction of SPISIMOx when used for general-purpose I/O. */
219 #define TMS570_SPI_PC1_SIMODIR(val) BSP_FLD32(val,16, 23)
220 #define TMS570_SPI_PC1_SIMODIR_GET(reg) BSP_FLD32GET(reg,16, 23)
221 #define TMS570_SPI_PC1_SIMODIR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
222
223 /* field: SOMIDIR0 - PISOMI0 direction. */
224 #define TMS570_SPI_PC1_SOMIDIR0 BSP_BIT32(11)
225
226 /* field: SIMODIR0 - SPISIMO0 direction. */
227 #define TMS570_SPI_PC1_SIMODIR0 BSP_BIT32(10)
228
229 /* field: CLKDIR - SPICLK direction. */
230 #define TMS570_SPI_PC1_CLKDIR BSP_BIT32(9)
231
232 /* field: ENADIR - SPIENA direction. */
233 #define TMS570_SPI_PC1_ENADIR BSP_BIT32(8)
234
235 /* field: SCSDIR - SPISCSx direction. */
236 #define TMS570_SPI_PC1_SCSDIR(val) BSP_FLD32(val,0, 7)
237 #define TMS570_SPI_PC1_SCSDIR_GET(reg) BSP_FLD32GET(reg,0, 7)
238 #define TMS570_SPI_PC1_SCSDIR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
239
240
241 /*-----------------------TMS570_SPI_PC2-----------------------*/
242 /* field: SOMIDIN - SPISOMIx data in. The value of the SPISOMIx pins. */
243 #define TMS570_SPI_PC2_SOMIDIN(val) BSP_FLD32(val,24, 31)
244 #define TMS570_SPI_PC2_SOMIDIN_GET(reg) BSP_FLD32GET(reg,24, 31)
245 #define TMS570_SPI_PC2_SOMIDIN_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
246
247 /* field: SIMODIN - SPISIMOx data in. The value of the SPISIMOx pins. */
248 #define TMS570_SPI_PC2_SIMODIN(val) BSP_FLD32(val,16, 23)
249 #define TMS570_SPI_PC2_SIMODIN_GET(reg) BSP_FLD32GET(reg,16, 23)
250 #define TMS570_SPI_PC2_SIMODIN_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
251
252 /* field: SOMIDIN0 - SPISOMI0 data in. The value of the SPISOMI0 pin. */
253 #define TMS570_SPI_PC2_SOMIDIN0 BSP_BIT32(11)
254
255 /* field: SIMODIN0 - SPISIMO0 data in. The value of the SPISIMO0 pin. */
256 #define TMS570_SPI_PC2_SIMODIN0 BSP_BIT32(10)
257
258 /* field: CLKDIN - Clock data in. The value of the SPICLK pin. pin. */
259 #define TMS570_SPI_PC2_CLKDIN BSP_BIT32(9)
260
261 /* field: ENADIN - SPIENA data in. The the value of the SPIENA pin. */
262 #define TMS570_SPI_PC2_ENADIN BSP_BIT32(8)
263
264 /* field: SCSDIN - SPISCSx data in. The value of the SPISCSx pin. */
265 #define TMS570_SPI_PC2_SCSDIN(val) BSP_FLD32(val,0, 7)
266 #define TMS570_SPI_PC2_SCSDIN_GET(reg) BSP_FLD32GET(reg,0, 7)
267 #define TMS570_SPI_PC2_SCSDIN_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
268
269
270 /*-----------------------TMS570_SPI_PC3-----------------------*/
271 /* field: SOMIDOUT - SPISOMIx data out write. */
272 #define TMS570_SPI_PC3_SOMIDOUT(val) BSP_FLD32(val,24, 31)
273 #define TMS570_SPI_PC3_SOMIDOUT_GET(reg) BSP_FLD32GET(reg,24, 31)
274 #define TMS570_SPI_PC3_SOMIDOUT_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
275
276 /* field: SIMODOUT - SPISIMOx data out write. */
277 #define TMS570_SPI_PC3_SIMODOUT(val) BSP_FLD32(val,16, 23)
278 #define TMS570_SPI_PC3_SIMODOUT_GET(reg) BSP_FLD32GET(reg,16, 23)
279 #define TMS570_SPI_PC3_SIMODOUT_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
280
281 /* field: SOMIDOUT0 - SPISOMI0 data out write. */
282 #define TMS570_SPI_PC3_SOMIDOUT0 BSP_BIT32(11)
283
284 /* field: SIMODOUT0 - SPISIMO0 data out write. */
285 #define TMS570_SPI_PC3_SIMODOUT0 BSP_BIT32(10)
286
287 /* field: CLKDOUT - SPICLK data out write. */
288 #define TMS570_SPI_PC3_CLKDOUT BSP_BIT32(9)
289
290 /* field: ENADOUT - SPIENA data out write. */
291 #define TMS570_SPI_PC3_ENADOUT BSP_BIT32(8)
292
293 /* field: SCSDOUT - SPISCSx data out write. */
294 #define TMS570_SPI_PC3_SCSDOUT(val) BSP_FLD32(val,0, 7)
295 #define TMS570_SPI_PC3_SCSDOUT_GET(reg) BSP_FLD32GET(reg,0, 7)
296 #define TMS570_SPI_PC3_SCSDOUT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
297
298
299 /*-----------------------TMS570_SPI_PC4-----------------------*/
300 /* field: SOMISET - SPISOMIx data out set. */
301 #define TMS570_SPI_PC4_SOMISET(val) BSP_FLD32(val,24, 31)
302 #define TMS570_SPI_PC4_SOMISET_GET(reg) BSP_FLD32GET(reg,24, 31)
303 #define TMS570_SPI_PC4_SOMISET_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
304
305 /* field: SIMOSET - SPISIMOx data out set. */
306 #define TMS570_SPI_PC4_SIMOSET(val) BSP_FLD32(val,16, 23)
307 #define TMS570_SPI_PC4_SIMOSET_GET(reg) BSP_FLD32GET(reg,16, 23)
308 #define TMS570_SPI_PC4_SIMOSET_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
309
310 /* field: SOMISET0 - SPISOMI0 data out set. */
311 #define TMS570_SPI_PC4_SOMISET0 BSP_BIT32(11)
312
313 /* field: SIMOSET0 - purpose */
314 #define TMS570_SPI_PC4_SIMOSET0 BSP_BIT32(10)
315
316 /* field: CLKSET - SPICLK data out set. */
317 #define TMS570_SPI_PC4_CLKSET BSP_BIT32(9)
318
319 /* field: ENASET - SPIENA data out set. */
320 #define TMS570_SPI_PC4_ENASET BSP_BIT32(8)
321
322 /* field: SCSSET - SPISCSx data out set. */
323 #define TMS570_SPI_PC4_SCSSET(val) BSP_FLD32(val,0, 7)
324 #define TMS570_SPI_PC4_SCSSET_GET(reg) BSP_FLD32GET(reg,0, 7)
325 #define TMS570_SPI_PC4_SCSSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
326
327
328 /*-----------------------TMS570_SPI_PC5-----------------------*/
329 /* field: SOMICLR - SPISOMIx data out clear. */
330 #define TMS570_SPI_PC5_SOMICLR(val) BSP_FLD32(val,24, 31)
331 #define TMS570_SPI_PC5_SOMICLR_GET(reg) BSP_FLD32GET(reg,24, 31)
332 #define TMS570_SPI_PC5_SOMICLR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
333
334 /* field: SIMOCLR - SPISIMOx data out clear. */
335 #define TMS570_SPI_PC5_SIMOCLR(val) BSP_FLD32(val,16, 23)
336 #define TMS570_SPI_PC5_SIMOCLR_GET(reg) BSP_FLD32GET(reg,16, 23)
337 #define TMS570_SPI_PC5_SIMOCLR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
338
339 /* field: SOMICLR0 - SPISOMI0 data out cleart. */
340 #define TMS570_SPI_PC5_SOMICLR0 BSP_BIT32(11)
341
342 /* field: SIMOCLR0 - SPISIMO0 data out clear. */
343 #define TMS570_SPI_PC5_SIMOCLR0 BSP_BIT32(10)
344
345 /* field: CLKCLR - SPICLK data out clear. */
346 #define TMS570_SPI_PC5_CLKCLR BSP_BIT32(9)
347
348 /* field: ENACLR - SPIENA data out clear. */
349 #define TMS570_SPI_PC5_ENACLR BSP_BIT32(8)
350
351 /* field: SCSCLR - SPISCSx data out clear. */
352 #define TMS570_SPI_PC5_SCSCLR(val) BSP_FLD32(val,0, 7)
353 #define TMS570_SPI_PC5_SCSCLR_GET(reg) BSP_FLD32GET(reg,0, 7)
354 #define TMS570_SPI_PC5_SCSCLR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
355
356
357 /*-----------------------TMS570_SPI_PC6-----------------------*/
358 /* field: SOMIPDR - SPISOMIx open drain enable. */
359 #define TMS570_SPI_PC6_SOMIPDR(val) BSP_FLD32(val,24, 31)
360 #define TMS570_SPI_PC6_SOMIPDR_GET(reg) BSP_FLD32GET(reg,24, 31)
361 #define TMS570_SPI_PC6_SOMIPDR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
362
363 /* field: SIMOPDR - SPISIMOx open drain enable. */
364 #define TMS570_SPI_PC6_SIMOPDR(val) BSP_FLD32(val,16, 23)
365 #define TMS570_SPI_PC6_SIMOPDR_GET(reg) BSP_FLD32GET(reg,16, 23)
366 #define TMS570_SPI_PC6_SIMOPDR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
367
368 /* field: SOMIPDR0 - SOMI0 open-drain enable. */
369 #define TMS570_SPI_PC6_SOMIPDR0 BSP_BIT32(11)
370
371 /* field: SIMOPDR0 - SPISIMO0 open-drain enable. */
372 #define TMS570_SPI_PC6_SIMOPDR0 BSP_BIT32(10)
373
374 /* field: CLKPDR - CLK open drain enable. */
375 #define TMS570_SPI_PC6_CLKPDR BSP_BIT32(9)
376
377 /* field: ENAPDR - SPIENA pin open drain enable. */
378 #define TMS570_SPI_PC6_ENAPDR BSP_BIT32(8)
379
380 /* field: SCSPDR - SPISCSx open drain enable. */
381 #define TMS570_SPI_PC6_SCSPDR(val) BSP_FLD32(val,0, 7)
382 #define TMS570_SPI_PC6_SCSPDR_GET(reg) BSP_FLD32GET(reg,0, 7)
383 #define TMS570_SPI_PC6_SCSPDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
384
385
386 /*-----------------------TMS570_SPI_PC7-----------------------*/
387 /* field: SOMIDIS - SOMIx pull control enable/disable. */
388 #define TMS570_SPI_PC7_SOMIDIS(val) BSP_FLD32(val,24, 31)
389 #define TMS570_SPI_PC7_SOMIDIS_GET(reg) BSP_FLD32GET(reg,24, 31)
390 #define TMS570_SPI_PC7_SOMIDIS_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
391
392 /* field: SIMODIS - SIMOx pull control enable/disable. */
393 #define TMS570_SPI_PC7_SIMODIS(val) BSP_FLD32(val,16, 23)
394 #define TMS570_SPI_PC7_SIMODIS_GET(reg) BSP_FLD32GET(reg,16, 23)
395 #define TMS570_SPI_PC7_SIMODIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
396
397 /* field: SOMIPDIS0 - SPISOMI0 pull control enable/disable. */
398 #define TMS570_SPI_PC7_SOMIPDIS0 BSP_BIT32(11)
399
400 /* field: SIMOPDIS0 - SPISIMO0 pull control enable/disable. */
401 #define TMS570_SPI_PC7_SIMOPDIS0 BSP_BIT32(10)
402
403 /* field: CLKPDIS - CLK pull control enable/disable. */
404 #define TMS570_SPI_PC7_CLKPDIS BSP_BIT32(9)
405
406 /* field: ENAPDIS - ENAPDIS ENABLE pull control enable/disable. */
407 #define TMS570_SPI_PC7_ENAPDIS BSP_BIT32(8)
408
409 /* field: SCSPDIS - SCSx pull control enable/disable. */
410 #define TMS570_SPI_PC7_SCSPDIS(val) BSP_FLD32(val,0, 7)
411 #define TMS570_SPI_PC7_SCSPDIS_GET(reg) BSP_FLD32GET(reg,0, 7)
412 #define TMS570_SPI_PC7_SCSPDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
413
414
415 /*-----------------------TMS570_SPI_PC8-----------------------*/
416 /* field: SOMIPSEL - SPISOMIx pull select. This bit selects the type of pull logic at the SOMIx pin. */
417 #define TMS570_SPI_PC8_SOMIPSEL(val) BSP_FLD32(val,24, 31)
418 #define TMS570_SPI_PC8_SOMIPSEL_GET(reg) BSP_FLD32GET(reg,24, 31)
419 #define TMS570_SPI_PC8_SOMIPSEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
420
421 /* field: SIMOPSEL - SIMOPSEL SPISIMOx pull select. This bit selects the type of pull logic at the SPISIMOx pin. */
422 #define TMS570_SPI_PC8_SIMOPSEL(val) BSP_FLD32(val,16, 23)
423 #define TMS570_SPI_PC8_SIMOPSEL_GET(reg) BSP_FLD32GET(reg,16, 23)
424 #define TMS570_SPI_PC8_SIMOPSEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
425
426 /* field: SOMIPSEL0 - SOMI pull select. This bit selects the type of pull logic at the SOMI pin. */
427 #define TMS570_SPI_PC8_SOMIPSEL0 BSP_BIT32(11)
428
429 /* field: SIMOPSEL0 - SPISIMO pull select. This bit selects the type of pull logic at the SPISIMO pin. */
430 #define TMS570_SPI_PC8_SIMOPSEL0 BSP_BIT32(10)
431
432 /* field: CLKPSEL - CLK pull select. This bit selects the type of pull logic at the CLK pin. */
433 #define TMS570_SPI_PC8_CLKPSEL BSP_BIT32(9)
434
435 /* field: ENAPSEL - ENABLE pull select. This bit selects the type of pull logic at the ENABLE pin. */
436 #define TMS570_SPI_PC8_ENAPSEL BSP_BIT32(8)
437
438 /* field: SCSPSEL - SCSx pull select. This bit selects the type of pull logic at the SCSx pin. */
439 #define TMS570_SPI_PC8_SCSPSEL(val) BSP_FLD32(val,0, 7)
440 #define TMS570_SPI_PC8_SCSPSEL_GET(reg) BSP_FLD32GET(reg,0, 7)
441 #define TMS570_SPI_PC8_SCSPSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
442
443
444 /*----------------------TMS570_SPI_DAT0----------------------*/
445 /* field: TXDATA - SPI transmit data. When written, these bits will be copied to the shift register if it is empty. */
446 #define TMS570_SPI_DAT0_TXDATA(val) BSP_FLD32(val,0, 15)
447 #define TMS570_SPI_DAT0_TXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
448 #define TMS570_SPI_DAT0_TXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
449
450
451 /*----------------------TMS570_SPI_DAT1----------------------*/
452 /* field: CSHOLD - Chip select hold mode. */
453 #define TMS570_SPI_DAT1_CSHOLD BSP_BIT32(28)
454
455 /* field: WDEL - Enable the delay counter at the end of the current transaction. */
456 #define TMS570_SPI_DAT1_WDEL BSP_BIT32(26)
457
458 /* field: DFSEL - Data word format select */
459 #define TMS570_SPI_DAT1_DFSEL(val) BSP_FLD32(val,24, 25)
460 #define TMS570_SPI_DAT1_DFSEL_GET(reg) BSP_FLD32GET(reg,24, 25)
461 #define TMS570_SPI_DAT1_DFSEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
462
463 /* field: CSNR - Chip select number. CSNR defines the chip-select that will be activated during the data transfer. */
464 #define TMS570_SPI_DAT1_CSNR(val) BSP_FLD32(val,16, 23)
465 #define TMS570_SPI_DAT1_CSNR_GET(reg) BSP_FLD32GET(reg,16, 23)
466 #define TMS570_SPI_DAT1_CSNR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
467
468 /* field: TXDATA - ransfer data.When written, these bits are copied to the shift register if it is empty. */
469 #define TMS570_SPI_DAT1_TXDATA(val) BSP_FLD32(val,0, 15)
470 #define TMS570_SPI_DAT1_TXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
471 #define TMS570_SPI_DAT1_TXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
472
473
474 /*-----------------------TMS570_SPI_BUF-----------------------*/
475 /* field: RXEMPTY - Receive data buffer empty. */
476 #define TMS570_SPI_BUF_RXEMPTY BSP_BIT32(31)
477
478 /* field: RXOVR - Receive data buffer overrun. */
479 #define TMS570_SPI_BUF_RXOVR BSP_BIT32(30)
480
481 /* field: TXFULL - Transmit data buffer full.This flag is a read-only flag. */
482 #define TMS570_SPI_BUF_TXFULL BSP_BIT32(29)
483
484 /* field: BITERR - Bit error.There was a mismatch of internal transmit data and transmitted data. */
485 #define TMS570_SPI_BUF_BITERR BSP_BIT32(28)
486
487 /* field: DESYNC - Desynchronization of slave device.This bit is valid in master mode only. */
488 #define TMS570_SPI_BUF_DESYNC BSP_BIT32(27)
489
490 /* field: PARITYERR - Parity error.The calculated parity differs from the received parity bit. */
491 #define TMS570_SPI_BUF_PARITYERR BSP_BIT32(26)
492
493 /* field: TIMEOUT - Time-out because of non-activation of ENA pin. */
494 #define TMS570_SPI_BUF_TIMEOUT BSP_BIT32(25)
495
496 /* field: DLENERR - Data length error flag. */
497 #define TMS570_SPI_BUF_DLENERR BSP_BIT32(24)
498
499 /* field: LCSNR - control field. It contains the chip select number that was activated during the last word transfer. */
500 #define TMS570_SPI_BUF_LCSNR(val) BSP_FLD32(val,16, 23)
501 #define TMS570_SPI_BUF_LCSNR_GET(reg) BSP_FLD32GET(reg,16, 23)
502 #define TMS570_SPI_BUF_LCSNR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
503
504 /* field: RXDATA - SPI receive data. */
505 #define TMS570_SPI_BUF_RXDATA(val) BSP_FLD32(val,0, 15)
506 #define TMS570_SPI_BUF_RXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
507 #define TMS570_SPI_BUF_RXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
508
509
510 /*-----------------------TMS570_SPI_EMU-----------------------*/
511 /* field: EMU_RXDATA - SPI receive data. The SPI emulation register is a mirror of the SPIBUF register. */
512 #define TMS570_SPI_EMU_EMU_RXDATA(val) BSP_FLD32(val,0, 15)
513 #define TMS570_SPI_EMU_EMU_RXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
514 #define TMS570_SPI_EMU_EMU_RXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
515
516
517 /*----------------------TMS570_SPI_DELAY----------------------*/
518 /* field: C2TDELAY - Chip-select-active to transmit-start delay. See Figure 25-45 for an example. */
519 #define TMS570_SPI_DELAY_C2TDELAY(val) BSP_FLD32(val,24, 31)
520 #define TMS570_SPI_DELAY_C2TDELAY_GET(reg) BSP_FLD32GET(reg,24, 31)
521 #define TMS570_SPI_DELAY_C2TDELAY_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
522
523 /* field: T2CDELAY - T2CDELAY */
524 #define TMS570_SPI_DELAY_T2CDELAY(val) BSP_FLD32(val,16, 23)
525 #define TMS570_SPI_DELAY_T2CDELAY_GET(reg) BSP_FLD32GET(reg,16, 23)
526 #define TMS570_SPI_DELAY_T2CDELAY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
527
528 /* field: T2EDELAY - Transmit-data-finished to ENA-pin-inactive time-out. T2EDELAY is used in master mode only. */
529 #define TMS570_SPI_DELAY_T2EDELAY(val) BSP_FLD32(val,8, 15)
530 #define TMS570_SPI_DELAY_T2EDELAY_GET(reg) BSP_FLD32GET(reg,8, 15)
531 #define TMS570_SPI_DELAY_T2EDELAY_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
532
533 /* field: C2EDELAY - Chip-select-active to ENA-signal-active time-out. */
534 #define TMS570_SPI_DELAY_C2EDELAY(val) BSP_FLD32(val,0, 7)
535 #define TMS570_SPI_DELAY_C2EDELAY_GET(reg) BSP_FLD32GET(reg,0, 7)
536 #define TMS570_SPI_DELAY_C2EDELAY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
537
538
539 /*-----------------------TMS570_SPI_DEF-----------------------*/
540 /* field: CDEF - Chip select default pattern. Master-mode only. */
541 #define TMS570_SPI_DEF_CDEF(val) BSP_FLD32(val,0, 7)
542 #define TMS570_SPI_DEF_CDEF_GET(reg) BSP_FLD32GET(reg,0, 7)
543 #define TMS570_SPI_DEF_CDEF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
544
545
546 /*----------------------TMS570_SPI_FMTx----------------------*/
547 /* field: WDELAY - Delay in between transmissions for data format x (x= 0,1,2,3). */
548 #define TMS570_SPI_FMTx_WDELAY(val) BSP_FLD32(val,24, 31)
549 #define TMS570_SPI_FMTx_WDELAY_GET(reg) BSP_FLD32GET(reg,24, 31)
550 #define TMS570_SPI_FMTx_WDELAY_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
551
552 /* field: PARPOL - Parity polarity: even or odd. PARPOLx can be modified in privilege mode only. */
553 #define TMS570_SPI_FMTx_PARPOL BSP_BIT32(23)
554
555 /* field: PARITYENA - Parity enable for data format x. */
556 #define TMS570_SPI_FMTx_PARITYENA BSP_BIT32(22)
557
558 /* field: WAITENA - The master waits for the ENA signal from slave for data format x. */
559 #define TMS570_SPI_FMTx_WAITENA BSP_BIT32(21)
560
561 /* field: SHIFTDIR - Shift direction for data format x. */
562 #define TMS570_SPI_FMTx_SHIFTDIR BSP_BIT32(20)
563
564 /* field: HDUPLEX_ENAx - Half Duplex transfer mode enable for Data Format x. */
565 #define TMS570_SPI_FMTx_HDUPLEX_ENAx BSP_BIT32(19)
566
567 /* field: DIS_CS_TIMERS - Disable chip-select timers for this format. */
568 #define TMS570_SPI_FMTx_DIS_CS_TIMERS BSP_BIT32(18)
569
570 /* field: POLARITY - POLARITY */
571 #define TMS570_SPI_FMTx_POLARITY BSP_BIT32(17)
572
573 /* field: PHASE - SPI data format x clock delay. PHASEx defines the clock delay of data format x. */
574 #define TMS570_SPI_FMTx_PHASE BSP_BIT32(16)
575
576 /* field: PRESCALE - SPI data format x prescaler. */
577 #define TMS570_SPI_FMTx_PRESCALE(val) BSP_FLD32(val,8, 15)
578 #define TMS570_SPI_FMTx_PRESCALE_GET(reg) BSP_FLD32GET(reg,8, 15)
579 #define TMS570_SPI_FMTx_PRESCALE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
580
581 /* field: CHARLEN - SPI data format x data-word length. CHARLENx defines the word length of data format x. */
582 #define TMS570_SPI_FMTx_CHARLEN(val) BSP_FLD32(val,0, 4)
583 #define TMS570_SPI_FMTx_CHARLEN_GET(reg) BSP_FLD32GET(reg,0, 4)
584 #define TMS570_SPI_FMTx_CHARLEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
585
586
587 /*--------------------TMS570_SPI_INTVECT0--------------------*/
588 /* field: INTVECT0 - INTVECT0. Interrupt vector for interrupt line INT0. */
589 #define TMS570_SPI_INTVECT0_INTVECT0(val) BSP_FLD32(val,1, 5)
590 #define TMS570_SPI_INTVECT0_INTVECT0_GET(reg) BSP_FLD32GET(reg,1, 5)
591 #define TMS570_SPI_INTVECT0_INTVECT0_SET(reg,val) BSP_FLD32SET(reg, val,1, 5)
592
593 /* field: SUSPEND0 - Transfer suspended / Transfer finished interrupt flag. */
594 #define TMS570_SPI_INTVECT0_SUSPEND0 BSP_BIT32(0)
595
596
597 /*--------------------TMS570_SPI_INTVECT1--------------------*/
598 /* field: INTVECT1 - INTVECT1. Interrupt vector for interrupt line INT1. */
599 #define TMS570_SPI_INTVECT1_INTVECT1(val) BSP_FLD32(val,1, 5)
600 #define TMS570_SPI_INTVECT1_INTVECT1_GET(reg) BSP_FLD32GET(reg,1, 5)
601 #define TMS570_SPI_INTVECT1_INTVECT1_SET(reg,val) BSP_FLD32SET(reg, val,1, 5)
602
603 /* field: SUSPEND1 - Transfer suspended / Transfer finished interrupt flag. */
604 #define TMS570_SPI_INTVECT1_SUSPEND1 BSP_BIT32(0)
605
606
607 /*---------------------TMS570_SPI_PMCTRL---------------------*/
608 /* field: MOD_CLK_POL_3 - Modulo mode SPICLK polarity. */
609 #define TMS570_SPI_PMCTRL_MOD_CLK_POL_3 BSP_BIT32(29)
610
611 /* field: MMODE_3 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
612 #define TMS570_SPI_PMCTRL_MMODE_3(val) BSP_FLD32(val,26, 28)
613 #define TMS570_SPI_PMCTRL_MMODE_3_GET(reg) BSP_FLD32GET(reg,26, 28)
614 #define TMS570_SPI_PMCTRL_MMODE_3_SET(reg,val) BSP_FLD32SET(reg, val,26, 28)
615
616 /* field: PMODE_3 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
617 #define TMS570_SPI_PMCTRL_PMODE_3(val) BSP_FLD32(val,24, 25)
618 #define TMS570_SPI_PMCTRL_PMODE_3_GET(reg) BSP_FLD32GET(reg,24, 25)
619 #define TMS570_SPI_PMCTRL_PMODE_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
620
621 /* field: MOD_CLK_POL_2 - Modulo mode SPICLK polarity. */
622 #define TMS570_SPI_PMCTRL_MOD_CLK_POL_2 BSP_BIT32(21)
623
624 /* field: MMODE_2 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
625 #define TMS570_SPI_PMCTRL_MMODE_2(val) BSP_FLD32(val,18, 20)
626 #define TMS570_SPI_PMCTRL_MMODE_2_GET(reg) BSP_FLD32GET(reg,18, 20)
627 #define TMS570_SPI_PMCTRL_MMODE_2_SET(reg,val) BSP_FLD32SET(reg, val,18, 20)
628
629 /* field: PMODE_2 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
630 #define TMS570_SPI_PMCTRL_PMODE_2(val) BSP_FLD32(val,16, 17)
631 #define TMS570_SPI_PMCTRL_PMODE_2_GET(reg) BSP_FLD32GET(reg,16, 17)
632 #define TMS570_SPI_PMCTRL_PMODE_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
633
634 /* field: MOD_CLK_POL_1 - Modulo mode SPICLK polarity. */
635 #define TMS570_SPI_PMCTRL_MOD_CLK_POL_1 BSP_BIT32(13)
636
637 /* field: MMODE_1 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
638 #define TMS570_SPI_PMCTRL_MMODE_1(val) BSP_FLD32(val,10, 12)
639 #define TMS570_SPI_PMCTRL_MMODE_1_GET(reg) BSP_FLD32GET(reg,10, 12)
640 #define TMS570_SPI_PMCTRL_MMODE_1_SET(reg,val) BSP_FLD32SET(reg, val,10, 12)
641
642 /* field: PMODE_1 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
643 #define TMS570_SPI_PMCTRL_PMODE_1(val) BSP_FLD32(val,8, 9)
644 #define TMS570_SPI_PMCTRL_PMODE_1_GET(reg) BSP_FLD32GET(reg,8, 9)
645 #define TMS570_SPI_PMCTRL_PMODE_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
646
647 /* field: MOD_CLK_POL_0 - Modulo mode SPICLK polarity. */
648 #define TMS570_SPI_PMCTRL_MOD_CLK_POL_0 BSP_BIT32(5)
649
650 /* field: MMODE_0 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
651 #define TMS570_SPI_PMCTRL_MMODE_0(val) BSP_FLD32(val,2, 4)
652 #define TMS570_SPI_PMCTRL_MMODE_0_GET(reg) BSP_FLD32GET(reg,2, 4)
653 #define TMS570_SPI_PMCTRL_MMODE_0_SET(reg,val) BSP_FLD32SET(reg, val,2, 4)
654
655 /* field: PMODE_0 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
656 #define TMS570_SPI_PMCTRL_PMODE_0(val) BSP_FLD32(val,0, 1)
657 #define TMS570_SPI_PMCTRL_PMODE_0_GET(reg) BSP_FLD32GET(reg,0, 1)
658 #define TMS570_SPI_PMCTRL_PMODE_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
659
660
661 /*---------------------TMS570_SPI_MIBSPIE---------------------*/
662 /* field: RXRAM_ACCESS - Receive-RAM access control. */
663 #define TMS570_SPI_MIBSPIE_RXRAM_ACCESS BSP_BIT32(16)
664
665 /* field: MSPIENA - Multi-buffer mode enable. */
666 #define TMS570_SPI_MIBSPIE_MSPIENA BSP_BIT32(0)
667
668
669 /*--------------------TMS570_SPI_TGITENST--------------------*/
670 /* field: SET_INTENRDY - TG interrupt set (enable) when transfer finished. */
671 #define TMS570_SPI_TGITENST_SET_INTENRDY(val) BSP_FLD32(val,16, 31)
672 #define TMS570_SPI_TGITENST_SET_INTENRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
673 #define TMS570_SPI_TGITENST_SET_INTENRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
674
675 /* field: SET_INTENSUS - TG interrupt set (enabled) when transfer suspended */
676 #define TMS570_SPI_TGITENST_SET_INTENSUS(val) BSP_FLD32(val,0, 15)
677 #define TMS570_SPI_TGITENST_SET_INTENSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
678 #define TMS570_SPI_TGITENST_SET_INTENSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
679
680
681 /*--------------------TMS570_SPI_TGITENCR--------------------*/
682 /* field: CLR_INTENRDY - TG interrupt clear (disabled) when transfer finished. */
683 #define TMS570_SPI_TGITENCR_CLR_INTENRDY(val) BSP_FLD32(val,16, 31)
684 #define TMS570_SPI_TGITENCR_CLR_INTENRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
685 #define TMS570_SPI_TGITENCR_CLR_INTENRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
686
687 /* field: CLR_INTENSUS - CLR INTENSUS */
688 #define TMS570_SPI_TGITENCR_CLR_INTENSUS(val) BSP_FLD32(val,0, 15)
689 #define TMS570_SPI_TGITENCR_CLR_INTENSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
690 #define TMS570_SPI_TGITENCR_CLR_INTENSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
691
692
693 /*--------------------TMS570_SPI_TGITLVST--------------------*/
694 /* field: SET_INTLVLRDY - Transfer-group completed interrupt level set. */
695 #define TMS570_SPI_TGITLVST_SET_INTLVLRDY(val) BSP_FLD32(val,16, 31)
696 #define TMS570_SPI_TGITLVST_SET_INTLVLRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
697 #define TMS570_SPI_TGITLVST_SET_INTLVLRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
698
699 /* field: SET_INTLVLSUS - Transfer-group suspended interrupt level set. */
700 #define TMS570_SPI_TGITLVST_SET_INTLVLSUS(val) BSP_FLD32(val,0, 15)
701 #define TMS570_SPI_TGITLVST_SET_INTLVLSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
702 #define TMS570_SPI_TGITLVST_SET_INTLVLSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
703
704
705 /*--------------------TMS570_SPI_TGITLVCR--------------------*/
706 /* field: CLR_INTLVLRDY - Transfer-group completed interrupt level clear. */
707 #define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY(val) BSP_FLD32(val,16, 31)
708 #define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
709 #define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
710
711 /* field: CLR_INTLVLSUS - Transfer group suspended interrupt level clear. */
712 #define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS(val) BSP_FLD32(val,0, 15)
713 #define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
714 #define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
715
716
717 /*--------------------TMS570_SPI_TGINTFLG--------------------*/
718 /* field: INTFLGRDY - Transfer-group interrupt flag for a transfer-completed interrupt. */
719 #define TMS570_SPI_TGINTFLG_INTFLGRDY(val) BSP_FLD32(val,16, 31)
720 #define TMS570_SPI_TGINTFLG_INTFLGRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
721 #define TMS570_SPI_TGINTFLG_INTFLGRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
722
723 /* field: INTFLGSUS - ransfer-group interrupt flag for a transfer-suspend interrupt. */
724 #define TMS570_SPI_TGINTFLG_INTFLGSUS(val) BSP_FLD32(val,0, 15)
725 #define TMS570_SPI_TGINTFLG_INTFLGSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
726 #define TMS570_SPI_TGINTFLG_INTFLGSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
727
728
729 /*---------------------TMS570_SPI_TICKCNT---------------------*/
730 /* field: TICKENA - Tick counter enable. */
731 #define TMS570_SPI_TICKCNT_TICKENA BSP_BIT32(31)
732
733 /* field: RELOAD - Pre-load the tick counter. */
734 #define TMS570_SPI_TICKCNT_RELOAD BSP_BIT32(30)
735
736 /* field: CLKCTRL - Tick counter clock source control. */
737 #define TMS570_SPI_TICKCNT_CLKCTRL(val) BSP_FLD32(val,28, 29)
738 #define TMS570_SPI_TICKCNT_CLKCTRL_GET(reg) BSP_FLD32GET(reg,28, 29)
739 #define TMS570_SPI_TICKCNT_CLKCTRL_SET(reg,val) BSP_FLD32SET(reg, val,28, 29)
740
741 /* field: TICKVALUE - counter is loaded with the contents of TICKVALUE every time an underflow condition occurs and */
742 #define TMS570_SPI_TICKCNT_TICKVALUE(val) BSP_FLD32(val,0, 15)
743 #define TMS570_SPI_TICKCNT_TICKVALUE_GET(reg) BSP_FLD32GET(reg,0, 15)
744 #define TMS570_SPI_TICKCNT_TICKVALUE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
745
746
747 /*---------------------TMS570_SPI_LTGPEND---------------------*/
748 /* field: TG_IN_SERVICE - The TG number currently being serviced by the sequencer. */
749 #define TMS570_SPI_LTGPEND_TG_IN_SERVICE(val) BSP_FLD32(val,24, 28)
750 #define TMS570_SPI_LTGPEND_TG_IN_SERVICE_GET(reg) BSP_FLD32GET(reg,24, 28)
751 #define TMS570_SPI_LTGPEND_TG_IN_SERVICE_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
752
753 /* field: LPEND - Last TG end pointer. */
754 #define TMS570_SPI_LTGPEND_LPEND(val) BSP_FLD32(val,8, 14)
755 #define TMS570_SPI_LTGPEND_LPEND_GET(reg) BSP_FLD32GET(reg,8, 14)
756 #define TMS570_SPI_LTGPEND_LPEND_SET(reg,val) BSP_FLD32SET(reg, val,8, 14)
757
758
759 /*---------------------TMS570_SPI_TGCTRL---------------------*/
760 /* field: TGENA - TGx enable. */
761 #define TMS570_SPI_TGCTRL_TGENA BSP_BIT32(31)
762
763 /* field: ONESHOTx - Single transfer for TGx. */
764 #define TMS570_SPI_TGCTRL_ONESHOTx BSP_BIT32(30)
765
766 /* field: PRSTx - TGx pointer reset mode. Configures the way to resolve trigger events during an ongoing transfer. */
767 #define TMS570_SPI_TGCTRL_PRSTx BSP_BIT32(29)
768
769 /* field: TGTDx - TG triggered. */
770 #define TMS570_SPI_TGCTRL_TGTDx BSP_BIT32(28)
771
772
773 /*---------------------TMS570_SPI_DMACTRL---------------------*/
774 /* field: ONESHOT - Auto-disable of DMA channel after ICOUNT+1 transfers. */
775 #define TMS570_SPI_DMACTRL_ONESHOT BSP_BIT32(31)
776
777 /* field: BUFIDx - Buffer utilized for DMA transfer. */
778 #define TMS570_SPI_DMACTRL_BUFIDx(val) BSP_FLD32(val,24, 30)
779 #define TMS570_SPI_DMACTRL_BUFIDx_GET(reg) BSP_FLD32GET(reg,24, 30)
780 #define TMS570_SPI_DMACTRL_BUFIDx_SET(reg,val) BSP_FLD32SET(reg, val,24, 30)
781
782 /* field: RXDMA_MAPx - Each MibSPI DMA channel can be linked to two physical DMA Request lines of the DMA */
783 #define TMS570_SPI_DMACTRL_RXDMA_MAPx(val) BSP_FLD32(val,20, 23)
784 #define TMS570_SPI_DMACTRL_RXDMA_MAPx_GET(reg) BSP_FLD32GET(reg,20, 23)
785 #define TMS570_SPI_DMACTRL_RXDMA_MAPx_SET(reg,val) BSP_FLD32SET(reg, val,20, 23)
786
787 /* field: TXDMA_MAPx - Each MibSPI DMA channel can be linked to two physical DMA Request lines of the DMA */
788 #define TMS570_SPI_DMACTRL_TXDMA_MAPx(val) BSP_FLD32(val,16, 19)
789 #define TMS570_SPI_DMACTRL_TXDMA_MAPx_GET(reg) BSP_FLD32GET(reg,16, 19)
790 #define TMS570_SPI_DMACTRL_TXDMA_MAPx_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
791
792 /* field: RXDMAENAx - Receive data DMA channel enable. */
793 #define TMS570_SPI_DMACTRL_RXDMAENAx BSP_BIT32(15)
794
795 /* field: TXDAMENAx - Transmit data DMA channel enable. */
796 #define TMS570_SPI_DMACTRL_TXDAMENAx BSP_BIT32(14)
797
798 /* field: NOBRKx - Non-interleaved DMA block transfer. This bit is available in master mode only. */
799 #define TMS570_SPI_DMACTRL_NOBRKx BSP_BIT32(13)
800
801 /* field: ICOUNTx - Initial count of DMA transfers. */
802 #define TMS570_SPI_DMACTRL_ICOUNTx(val) BSP_FLD32(val,8, 12)
803 #define TMS570_SPI_DMACTRL_ICOUNTx_GET(reg) BSP_FLD32GET(reg,8, 12)
804 #define TMS570_SPI_DMACTRL_ICOUNTx_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
805
806 /* field: COUNT_BIT17x - The 17th bit of the COUNT field of DMAxCOUNT register. */
807 #define TMS570_SPI_DMACTRL_COUNT_BIT17x BSP_BIT32(6)
808
809 /* field: COUNTx - Actual number of remaining DMA transfers. */
810 #define TMS570_SPI_DMACTRL_COUNTx(val) BSP_FLD32(val,0, 5)
811 #define TMS570_SPI_DMACTRL_COUNTx_GET(reg) BSP_FLD32GET(reg,0, 5)
812 #define TMS570_SPI_DMACTRL_COUNTx_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
813
814
815 /*--------------------TMS570_SPI_DMACOUNT--------------------*/
816 /* field: ICOUNTx - Every time COUNTx hits zero, it is reloaded with ICOUNTx. */
817 #define TMS570_SPI_DMACOUNT_ICOUNTx(val) BSP_FLD32(val,16, 31)
818 #define TMS570_SPI_DMACOUNT_ICOUNTx_GET(reg) BSP_FLD32GET(reg,16, 31)
819 #define TMS570_SPI_DMACOUNT_ICOUNTx_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
820
821 /* field: COUNTx - The actual number of remaining DMA transfers. */
822 #define TMS570_SPI_DMACOUNT_COUNTx(val) BSP_FLD32(val,0, 15)
823 #define TMS570_SPI_DMACOUNT_COUNTx_GET(reg) BSP_FLD32GET(reg,0, 15)
824 #define TMS570_SPI_DMACOUNT_COUNTx_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
825
826
827 /*--------------------TMS570_SPI_DMACNTLEN--------------------*/
828 /* field: LARGE_COUNT - Select either the 16-bit DMAxCOUNT counters or the smaller counters in DMAxCTRL. */
829 #define TMS570_SPI_DMACNTLEN_LARGE_COUNT BSP_BIT32(0)
830
831
832 /*--------------------TMS570_SPI_UERRCTRL--------------------*/
833 /* field: PTESTEN - Parity memory test enable. */
834 #define TMS570_SPI_UERRCTRL_PTESTEN BSP_BIT32(8)
835
836 /* field: EDEN - Error detection enable. These bits enable parity error detection. */
837 #define TMS570_SPI_UERRCTRL_EDEN(val) BSP_FLD32(val,0, 3)
838 #define TMS570_SPI_UERRCTRL_EDEN_GET(reg) BSP_FLD32GET(reg,0, 3)
839 #define TMS570_SPI_UERRCTRL_EDEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
840
841
842 /*--------------------TMS570_SPI_UERRSTAT--------------------*/
843 /* field: EDFLG1 - RXRAM. */
844 #define TMS570_SPI_UERRSTAT_EDFLG1 BSP_BIT32(1)
845
846 /* field: EDFLG0 - Uncorrectable parity error detection flag. */
847 #define TMS570_SPI_UERRSTAT_EDFLG0 BSP_BIT32(0)
848
849
850 /*-------------------TMS570_SPI_UERRADDRRX-------------------*/
851 /* field: OVERADDR1 - Uncorrectable parity error address for RXRAM. */
852 #define TMS570_SPI_UERRADDRRX_OVERADDR1(val) BSP_FLD32(val,0, 9)
853 #define TMS570_SPI_UERRADDRRX_OVERADDR1_GET(reg) BSP_FLD32GET(reg,0, 9)
854 #define TMS570_SPI_UERRADDRRX_OVERADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
855
856
857 /*-------------------TMS570_SPI_UERRADDRTX-------------------*/
858 /* field: UERRADDR0 - a parity error is generated while reading from TXRAM. */
859 #define TMS570_SPI_UERRADDRTX_UERRADDR0(val) BSP_FLD32(val,0, 8)
860 #define TMS570_SPI_UERRADDRTX_UERRADDR0_GET(reg) BSP_FLD32GET(reg,0, 8)
861 #define TMS570_SPI_UERRADDRTX_UERRADDR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
862
863
864 /*-----------------TMS570_SPI_RXOVRN_BUF_ADDR-----------------*/
865 /* field: RXOVRN_BUF_ADDR - Address in RXRAM at which an overwrite occurred. */
866 #define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR(val) BSP_FLD32(val,0, 9)
867 #define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR_GET(reg) BSP_FLD32GET(reg,0, 9)
868 #define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
869
870
871 /*-------------------TMS570_SPI_IOLPBKTSTCR-------------------*/
872 /* field: SCS_FAIL_FLG - Bit indicating a failure on SPISCS pin compare during analog loopback. */
873 #define TMS570_SPI_IOLPBKTSTCR_SCS_FAIL_FLG BSP_BIT32(24)
874
875 /* field: CTRL_BITERR - Controls inducing of BITERR during I/O loopback test mode. */
876 #define TMS570_SPI_IOLPBKTSTCR_CTRL_BITERR BSP_BIT32(20)
877
878 /* field: CTRL_DESYNC - Controls inducing of the desync error during I/O loopback test mode. */
879 #define TMS570_SPI_IOLPBKTSTCR_CTRL_DESYNC BSP_BIT32(19)
880
881 /* field: CTRL_PARERR - Controls inducing of the parity errors during I/O loopback test mode. */
882 #define TMS570_SPI_IOLPBKTSTCR_CTRL_PARERR BSP_BIT32(18)
883
884 /* field: CTRL_TIMEOUT - Controls inducing of the timeout error during I/O loopback test mode. */
885 #define TMS570_SPI_IOLPBKTSTCR_CTRL_TIMEOUT BSP_BIT32(17)
886
887 /* field: CTRL_DLENERR - Controls inducing of the data length error during I/O loopback test mode. */
888 #define TMS570_SPI_IOLPBKTSTCR_CTRL_DLENERR BSP_BIT32(16)
889
890 /* field: IOLPBKSTENA - Module I/O loopback test enable key. */
891 #define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA(val) BSP_FLD32(val,8, 11)
892 #define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
893 #define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
894
895 /* field: ERR_SCS_PIN - Inject error on chip-select pin number x. */
896 #define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN(val) BSP_FLD32(val,3, 5)
897 #define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN_GET(reg) BSP_FLD32GET(reg,3, 5)
898 #define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN_SET(reg,val) BSP_FLD32SET(reg, val,3, 5)
899
900 /* field: CTRL_SCS_PIN - Enable/disable the injection of an error on the SPISCS[3:0] pins. */
901 #define TMS570_SPI_IOLPBKTSTCR_CTRL_SCS_PIN BSP_BIT32(2)
902
903 /* field: LPBK_TYPE - Module I/O loopback type (analog/digital). */
904 #define TMS570_SPI_IOLPBKTSTCR_LPBK_TYPE BSP_BIT32(1)
905
906 /* field: RXP_ENA - Enable analog loopback through the receive pin. */
907 #define TMS570_SPI_IOLPBKTSTCR_RXP_ENA BSP_BIT32(0)
908
909
910 /*------------------TMS570_SPI_EXT_PRESCALEx------------------*/
911 /* field: EPRESCALE_FMTx - EPRESCALE_FMTx. Extended Prescale value for SPIFMTx. */
912 #define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx(val) BSP_FLD32(val,16, 26)
913 #define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx_GET(reg) BSP_FLD32GET(reg,16, 26)
914 #define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
915
916
917
918 #endif /* LIBBSP_ARM_TMS570_SPI */
Definition: reg_spi.h:44
Utility macros.
