RTEMS  5.1
reg_sci.h
1 /* The header file is generated by make_header.py from SCI.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_SCI
40 #define LIBBSP_ARM_TMS570_SCI
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t GCR0; /*SCI Global Control Register 0*/
46  uint32_t GCR1; /*SCI Global Control Register 1*/
47  uint32_t GCR2; /*SCI Global Control Register 2*/
48  uint32_t SETINT; /*SCI Set Interrupt Register*/
49  uint32_t CLEARINT; /*SCI Clear Interrupt Register*/
50  uint32_t SETINTLVL; /*SCI Set Interrupt Level Register*/
51  uint32_t CLEARINTLVL; /*SCI Clear Interrupt Level Register*/
52  uint32_t FLR; /*SCI Flags Register*/
53  uint32_t INTVECT0; /*SCI Interrupt Vector Offset 0*/
54  uint32_t INTVECT1; /*SCI Interrupt Vector Offset 1*/
55  uint32_t FORMAT; /*SCI Format Control Register*/
56  uint32_t BRS; /*Baud Rate Selection Register*/
57  uint32_t ED; /*Receiver Emulation Data Buffer*/
58  uint32_t RD; /*Receiver Data Buffer*/
59  uint32_t TD; /*Transmit Data Buffer*/
60  uint32_t PIO0; /*SCI Pin I/O Control Register 0*/
61  uint32_t PIO1; /*SCI Pin I/O Control Register 1*/
62  uint32_t PIO2; /*SCI Pin I/O Control Register 2*/
63  uint32_t PIO3; /*SCI Pin I/O Control Register 3*/
64  uint32_t PIO4; /*SCI Pin I/O Control Register 4*/
65  uint32_t PIO5; /*SCI Pin I/O Control Register 5*/
66  uint32_t PIO6; /*SCI Pin I/O Control Register 6*/
67  uint32_t PIO7; /*SCI Pin I/O Control Register 7*/
68  uint32_t PIO8; /*SCI Pin I/O Control Register 8*/
69  uint8_t reserved1 [48];
70  uint32_t IODFTCTRL; /*Input/Output Error Enable Register*/
71 } tms570_sci_t;
72
73
74 /*----------------------TMS570_SCI_GCR0----------------------*/
75 /* field: Reserved - Read returns 0. Writes have no effect. */
76 #define TMS570_SCI_GCR0_Reserved(val) BSP_FLD32(val,1, 31)
77 #define TMS570_SCI_GCR0_Reserved_GET(reg) BSP_FLD32GET(reg,1, 31)
78 #define TMS570_SCI_GCR0_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,1, 31)
79
80 /* field: RESET - This bit resets the SCI module. */
81 #define TMS570_SCI_GCR0_RESET BSP_BIT32(0)
82
83
84 /*----------------------TMS570_SCI_GCR1----------------------*/
85 /* field: TXENA - Transmit enable. */
86 #define TMS570_SCI_GCR1_TXENA BSP_BIT32(25)
87
88 /* field: RXENA - Receive enable. RXENA allows or prevents the transfer of data from SCIRXSHF to SCIRD. */
89 #define TMS570_SCI_GCR1_RXENA BSP_BIT32(24)
90
91 /* field: CONT - Continue on suspend. */
92 #define TMS570_SCI_GCR1_CONT BSP_BIT32(17)
93
94 /* field: LOOP_BACK - Loopback bit. The self-checking option for the SCI can be selected with this bit. */
95 #define TMS570_SCI_GCR1_LOOP_BACK BSP_BIT32(16)
96
97 /* field: POWERDOWN - If the POWERDOWN bit is set while the receiver is actively receiving data and the wake-up */
98 #define TMS570_SCI_GCR1_POWERDOWN BSP_BIT32(9)
99
100 /* field: SLEEP - SCI sleep. In a multiprocessor configuration, this bit controls the receive sleep function. */
101 #define TMS570_SCI_GCR1_SLEEP BSP_BIT32(8)
102
103 /* field: SWnRST - Software reset (active low). This bit is effective in LIN and SCI modes. */
104 #define TMS570_SCI_GCR1_SWnRST BSP_BIT32(7)
105
106 /* field: CLOCK - CLOCK */
107 #define TMS570_SCI_GCR1_CLOCK BSP_BIT32(5)
108
109 /* field: STOP - SCI number of stop bits per frame. */
110 #define TMS570_SCI_GCR1_STOP BSP_BIT32(4)
111
112 /* field: PARITY - SCI parity odd/even selection. If the PARITY ENA bit is set, PARITY designates odd or even parity. */
113 #define TMS570_SCI_GCR1_PARITY BSP_BIT32(3)
114
115 /* field: PARITY_ENA - Parity enable. This bit enables or disables the parity function. */
116 #define TMS570_SCI_GCR1_PARITY_ENA BSP_BIT32(2)
117
118 /* field: TIMING_MODE - SCI timing mode bit. */
119 #define TMS570_SCI_GCR1_TIMING_MODE BSP_BIT32(1)
120
121 /* field: COMM_MODE - SCI communication mode bit. */
122 #define TMS570_SCI_GCR1_COMM_MODE BSP_BIT32(0)
123
124
125 /*----------------------TMS570_SCI_GCR2----------------------*/
126 /* field: CC - Compare checksum. LIN mode only. */
127 #define TMS570_SCI_GCR2_CC BSP_BIT32(17)
128
129 /* field: SC - Send checksum byte. This bit is effective in LIN mode only. */
130 #define TMS570_SCI_GCR2_SC BSP_BIT32(16)
131
132 /* field: GEN_WU - Generate wakeup signal. This bit is effective in LIN mode only. */
133 #define TMS570_SCI_GCR2_GEN_WU BSP_BIT32(8)
134
135 /* field: POWERDOWN - Power down. This bit is effective in LIN or SCI mode. */
136 #define TMS570_SCI_GCR2_POWERDOWN BSP_BIT32(0)
137
138
139 /*---------------------TMS570_SCI_SETINT---------------------*/
140 /* field: SET_FE_INT - */
141 #define TMS570_SCI_SETINT_SET_FE_INT BSP_BIT32(26)
142
143 /* field: SET_OE_INT - SET OE INT */
144 #define TMS570_SCI_SETINT_SET_OE_INT BSP_BIT32(25)
145
146 /* field: SET_PE_INT - Set parity interrupt. */
147 #define TMS570_SCI_SETINT_SET_PE_INT BSP_BIT32(24)
148
149 /* field: SET_RX_DMA_ALL - SET RX DMA ALL */
150 #define TMS570_SCI_SETINT_SET_RX_DMA_ALL BSP_BIT32(18)
151
152 /* field: SET_RX_DMA - SET RX DMA */
153 #define TMS570_SCI_SETINT_SET_RX_DMA BSP_BIT32(17)
154
155 /* field: SET_TX_DMA - Set transmit DMA. To enable DMA requests for the transmitter, this bit must be set. */
156 #define TMS570_SCI_SETINT_SET_TX_DMA BSP_BIT32(16)
157
158 /* field: SET_RX_INT - SET RX INT */
159 #define TMS570_SCI_SETINT_SET_RX_INT BSP_BIT32(9)
160
161 /* field: SET_TX_INT - Set transmitter interrupt. */
162 #define TMS570_SCI_SETINT_SET_TX_INT BSP_BIT32(8)
163
164 /* field: SET_WAKEUP_INT - Set wakeup interrupt. */
165 #define TMS570_SCI_SETINT_SET_WAKEUP_INT BSP_BIT32(1)
166
167 /* field: SET_BRKDT_INT - Set breakdetect interrupt. */
168 #define TMS570_SCI_SETINT_SET_BRKDT_INT BSP_BIT32(0)
169
170
171 /*--------------------TMS570_SCI_CLEARINT--------------------*/
172 /* field: CLR_FE_INT - Clear framing-error interrupt. This bit disables the framing-error interrupt when set. */
173 #define TMS570_SCI_CLEARINT_CLR_FE_INT BSP_BIT32(26)
174
175 /* field: CLR_CE_INT - Clear overrun-error interrupt. This bit disables the SCI overrun error interrupt when set. */
176 #define TMS570_SCI_CLEARINT_CLR_CE_INT BSP_BIT32(25)
177
178 /* field: CLR_PE_INT - Clear parity interrupt. This bit disables the parity error interrupt when set. */
179 #define TMS570_SCI_CLEARINT_CLR_PE_INT BSP_BIT32(24)
180
181 /* field: CLR_RX_DMA_ALL - Clear receive DMA all. This bit clears the receive DMA request for address frames when set. */
182 #define TMS570_SCI_CLEARINT_CLR_RX_DMA_ALL BSP_BIT32(18)
183
184 /* field: CLR_RX_DMA - Clear receive DMA request. This bit disables the receive DMA request when set. */
185 #define TMS570_SCI_CLEARINT_CLR_RX_DMA BSP_BIT32(17)
186
187 /* field: CLR_TX_DMA - CLR TX DMA */
188 #define TMS570_SCI_CLEARINT_CLR_TX_DMA BSP_BIT32(16)
189
190 /* field: CLR_RX_INT - Clear receiver interrupt. This bit disables the receiver interrupt when set. */
191 #define TMS570_SCI_CLEARINT_CLR_RX_INT BSP_BIT32(9)
192
193 /* field: CLR_TX_INT - Clear transmitter interrupt. This bit disables the transmitter interrupt when set. */
194 #define TMS570_SCI_CLEARINT_CLR_TX_INT BSP_BIT32(8)
195
196 /* field: CLR_WAKEUP_INT - Clear wakeup interrupt. This bit disables the wakeup interrupt when set. */
197 #define TMS570_SCI_CLEARINT_CLR_WAKEUP_INT BSP_BIT32(1)
198
199 /* field: CLR_BRKDT_INT - Clear breakdetect interrupt. This bit disables the break-detect interrupt when set. */
200 #define TMS570_SCI_CLEARINT_CLR_BRKDT_INT BSP_BIT32(0)
201
202
203 /*--------------------TMS570_SCI_SETINTLVL--------------------*/
204 /* field: SET_FE_INT_LVL - Set framing-error interrupt level. */
205 #define TMS570_SCI_SETINTLVL_SET_FE_INT_LVL BSP_BIT32(26)
206
207 /* field: SET_CE_INT_LVL - Set overrun-error interrupt level. */
208 #define TMS570_SCI_SETINTLVL_SET_CE_INT_LVL BSP_BIT32(25)
209
210 /* field: SET_PE_INT_LVL - Set parity error interrupt level. */
211 #define TMS570_SCI_SETINTLVL_SET_PE_INT_LVL BSP_BIT32(24)
212
213 /* field: SET_RX_DMA_ALL_LVL - Set receive DMA all interrupt levels. */
214 #define TMS570_SCI_SETINTLVL_SET_RX_DMA_ALL_LVL BSP_BIT32(18)
215
216 /* field: SET_RX_INT_LVL - Set receiver interrupt level. */
217 #define TMS570_SCI_SETINTLVL_SET_RX_INT_LVL BSP_BIT32(9)
218
219 /* field: SET_TX_INT_LVL - Set transmitter interrupt level. */
220 #define TMS570_SCI_SETINTLVL_SET_TX_INT_LVL BSP_BIT32(8)
221
222 /* field: SET_WAKEUP_INT_LVL - Set wakeup interrupt level. */
223 #define TMS570_SCI_SETINTLVL_SET_WAKEUP_INT_LVL BSP_BIT32(1)
224
225 /* field: SET_BRKDT_INT_LVL - SET BRKDT INT LVL */
226 #define TMS570_SCI_SETINTLVL_SET_BRKDT_INT_LVL BSP_BIT32(0)
227
228
229 /*-------------------TMS570_SCI_CLEARINTLVL-------------------*/
230 /* field: CLR_FE_INT_LVL - Clear framing-error interrupt. */
231 #define TMS570_SCI_CLEARINTLVL_CLR_FE_INT_LVL BSP_BIT32(26)
232
233 /* field: CLR_CE_INT_LVL - CLR CE INT LVL */
234 #define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
235
236 /* field: CLR_CE_INT_LVL - CLR CE INT LVL */
237 #define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
238
239 /* field: CLR_PE_INT_LVL - */
240 #define TMS570_SCI_CLEARINTLVL_CLR_PE_INT_LVL BSP_BIT32(24)
241
242 /* field: CLR_RX_DMA_ALL_LVL - Clear receive DMA interrupt level. */
243 #define TMS570_SCI_CLEARINTLVL_CLR_RX_DMA_ALL_LVL BSP_BIT32(18)
244
245 /* field: CLR_RX_INT_LVL - Clear receiver interrupt. */
246 #define TMS570_SCI_CLEARINTLVL_CLR_RX_INT_LVL BSP_BIT32(9)
247
248 /* field: 8 - CLR TX INT LVL Clear transmitter interrupt. */
249 #define TMS570_SCI_CLEARINTLVL_8 BSP_BIT32(8)
250
251 /* field: CLR_WAKEUP_INT_LVL - Clear wakeup interrupt. */
252 #define TMS570_SCI_CLEARINTLVL_CLR_WAKEUP_INT_LVL BSP_BIT32(1)
253
254 /* field: CLR_BRKDT_INT_LVL - Clear breakdetect interrupt. */
255 #define TMS570_SCI_CLEARINTLVL_CLR_BRKDT_INT_LVL BSP_BIT32(0)
256
257
258 /*-----------------------TMS570_SCI_FLR-----------------------*/
259 /* field: FE - Framing error flag. This bit is effective in LIN or SCI-compatible mode. */
260 #define TMS570_SCI_FLR_FE BSP_BIT32(26)
261
262 /* field: OE - Overrun error flag. */
263 #define TMS570_SCI_FLR_OE BSP_BIT32(25)
264
265 /* field: PE - Parity error flag. This bit is set when a parity error is detected in the received data. */
266 #define TMS570_SCI_FLR_PE BSP_BIT32(24)
267
268 /* field: RXWAKE - Receiver wakeup detect flag. */
269 #define TMS570_SCI_FLR_RXWAKE BSP_BIT32(12)
270
271 /* field: TX_EMPTY - Transmitter empty flag. */
272 #define TMS570_SCI_FLR_TX_EMPTY BSP_BIT32(11)
273
274 /* field: TXWAKE - Transmitter wakeup method select. */
275 #define TMS570_SCI_FLR_TXWAKE BSP_BIT32(10)
276
277 /* field: RXRDY - Receiver ready flag. */
278 #define TMS570_SCI_FLR_RXRDY BSP_BIT32(9)
279
280 /* field: TXRDY - Transmitter buffer register ready flag. */
281 #define TMS570_SCI_FLR_TXRDY BSP_BIT32(8)
282
283 /* field: BUSY - Bus busy flag. TThis bit indicates whether the receiver is in the process of receiving a frame. */
284 #define TMS570_SCI_FLR_BUSY BSP_BIT32(3)
285
286 /* field: IDLE - SCI receiver in idle state. */
287 #define TMS570_SCI_FLR_IDLE BSP_BIT32(2)
288
289 /* field: WAKEUP - Wakeup flag. */
290 #define TMS570_SCI_FLR_WAKEUP BSP_BIT32(1)
291
292 /* field: BRKDT - SCI break-detect flag. This bit is set when the SCI detects a break condition on the LINRX pin. */
293 #define TMS570_SCI_FLR_BRKDT BSP_BIT32(0)
294
295
296 /*--------------------TMS570_SCI_INTVECT0--------------------*/
297 /* field: INVECT0 - Interrupt vector offset for INT0. This register indicates the offset for interrupt line INT0. */
298 #define TMS570_SCI_INTVECT0_INVECT0(val) BSP_FLD32(val,0, 3)
299 #define TMS570_SCI_INTVECT0_INVECT0_GET(reg) BSP_FLD32GET(reg,0, 3)
300 #define TMS570_SCI_INTVECT0_INVECT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
301
302
303 /*--------------------TMS570_SCI_INTVECT1--------------------*/
304 /* field: INVECT1 - Interrupt vector offset for INT1. This register indicates the offset for interrupt line INT1. */
305 #define TMS570_SCI_INTVECT1_INVECT1(val) BSP_FLD32(val,0, 3)
306 #define TMS570_SCI_INTVECT1_INVECT1_GET(reg) BSP_FLD32GET(reg,0, 3)
307 #define TMS570_SCI_INTVECT1_INVECT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
308
309
310 /*---------------------TMS570_SCI_FORMAT---------------------*/
311 /* field: CHAR - Character length control bits. These bits set the SCI character length from 1 to 8 bits. */
312 #define TMS570_SCI_FORMAT_CHAR(val) BSP_FLD32(val,0, 2)
313 #define TMS570_SCI_FORMAT_CHAR_GET(reg) BSP_FLD32GET(reg,0, 2)
314 #define TMS570_SCI_FORMAT_CHAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
315
316
317 /*-----------------------TMS570_SCI_BRS-----------------------*/
318 /* field: BAUD - SCI 24-bit baud selection. */
319 #define TMS570_SCI_BRS_BAUD(val) BSP_FLD32(val,0, 23)
320 #define TMS570_SCI_BRS_BAUD_GET(reg) BSP_FLD32GET(reg,0, 23)
321 #define TMS570_SCI_BRS_BAUD_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
322
323
324 /*-----------------------TMS570_SCI_ED-----------------------*/
325 /* field: ED - Emulator data. Reading SCIED[7:0] does not clear the RXRDY flag, unlike reading SCIRD. */
326 #define TMS570_SCI_ED_ED(val) BSP_FLD32(val,0, 7)
327 #define TMS570_SCI_ED_ED_GET(reg) BSP_FLD32GET(reg,0, 7)
328 #define TMS570_SCI_ED_ED_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
329
330
331 /*-----------------------TMS570_SCI_RD-----------------------*/
332 /* field: RD - Receiver data. */
333 #define TMS570_SCI_RD_RD(val) BSP_FLD32(val,0, 7)
334 #define TMS570_SCI_RD_RD_GET(reg) BSP_FLD32GET(reg,0, 7)
335 #define TMS570_SCI_RD_RD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
336
337
338 /*-----------------------TMS570_SCI_TD-----------------------*/
339 /* field: TD - Transmit data. Data to be transmitted is written to the SCITD register. */
340 #define TMS570_SCI_TD_TD(val) BSP_FLD32(val,0, 7)
341 #define TMS570_SCI_TD_TD_GET(reg) BSP_FLD32GET(reg,0, 7)
342 #define TMS570_SCI_TD_TD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
343
344
345 /*----------------------TMS570_SCI_PIO0----------------------*/
346 /* field: TX_FUNC - Transfer function. This bit defines the function of pin SCITX. */
347 #define TMS570_SCI_PIO0_TX_FUNC BSP_BIT32(2)
348
349 /* field: RX_FUNC - Receive function.This bit defines the function of pin SCIRX. */
350 #define TMS570_SCI_PIO0_RX_FUNC BSP_BIT32(1)
351
352
353 /*----------------------TMS570_SCI_PIO1----------------------*/
354 /* field: TX_DIR - Transmit pin direction. */
355 #define TMS570_SCI_PIO1_TX_DIR BSP_BIT32(2)
356
357 /* field: RX_DIR - Receive pin direction. */
358 #define TMS570_SCI_PIO1_RX_DIR BSP_BIT32(1)
359
360
361 /*----------------------TMS570_SCI_PIO2----------------------*/
362 /* field: TX_IN - Transmit pin in. This bit contains the current value on the SCITX pin. */
363 #define TMS570_SCI_PIO2_TX_IN BSP_BIT32(2)
364
365 /* field: RX_IN - Receive pin in. This bit contains the current value on the SCIRX pin. */
366 #define TMS570_SCI_PIO2_RX_IN BSP_BIT32(1)
367
368
369 /*----------------------TMS570_SCI_PIO3----------------------*/
370 /* field: TX_OUT - Transmit pin out. */
371 #define TMS570_SCI_PIO3_TX_OUT BSP_BIT32(2)
372
373 /* field: RX_OUT - Receive pin out. */
374 #define TMS570_SCI_PIO3_RX_OUT BSP_BIT32(1)
375
376
377 /*----------------------TMS570_SCI_PIO4----------------------*/
378 /* field: TX_SET - Transmit pin set. */
379 #define TMS570_SCI_PIO4_TX_SET BSP_BIT32(2)
380
381 /* field: RX_SET - Receive pin set. */
382 #define TMS570_SCI_PIO4_RX_SET BSP_BIT32(1)
383
384
385 /*----------------------TMS570_SCI_PIO5----------------------*/
386 /* field: TX_CLR - Transmit pin clear. */
387 #define TMS570_SCI_PIO5_TX_CLR BSP_BIT32(2)
388
389 /* field: RX_CLR - Receive pin clear. */
390 #define TMS570_SCI_PIO5_RX_CLR BSP_BIT32(1)
391
392
393 /*----------------------TMS570_SCI_PIO6----------------------*/
394 /* field: TX_PDR - Transmit pin open drain enable. */
395 #define TMS570_SCI_PIO6_TX_PDR BSP_BIT32(2)
396
397 /* field: RX_PDR - Receive pin open drain enable. */
398 #define TMS570_SCI_PIO6_RX_PDR BSP_BIT32(1)
399
400
401 /*----------------------TMS570_SCI_PIO7----------------------*/
402 /* field: TX_PD - Transmit pin pull control disable. This bit disables pull control capability on the input pin SCITX. */
403 #define TMS570_SCI_PIO7_TX_PD BSP_BIT32(2)
404
405 /* field: RX_PD - Receive pin pull control disable. This bit disables pull control capability on the input pin SCIRX. */
406 #define TMS570_SCI_PIO7_RX_PD BSP_BIT32(1)
407
408
409 /*----------------------TMS570_SCI_PIO8----------------------*/
410 /* field: TX_PSL - TX pin pull select. This bit selects pull type in the input pin SCITX. */
411 #define TMS570_SCI_PIO8_TX_PSL BSP_BIT32(2)
412
413 /* field: RX_PSL - RX pin pull select. This bit selects pull type in the input pin SCIRX. */
414 #define TMS570_SCI_PIO8_RX_PSL BSP_BIT32(1)
415
416
417 /*--------------------TMS570_SCI_IODFTCTRL--------------------*/
418 /* field: FEN - Frame error enable. This bit is used to create a frame error. */
419 #define TMS570_SCI_IODFTCTRL_FEN BSP_BIT32(26)
420
421 /* field: PEN - Parity error enable. This bit is used to create a parity error. */
422 #define TMS570_SCI_IODFTCTRL_PEN BSP_BIT32(25)
423
424 /* field: BRKD_TENA - Break detect error enable. This bit is used to create a BRKDT error. */
425 #define TMS570_SCI_IODFTCTRL_BRKD_TENA BSP_BIT32(24)
426
427 /* field: PIN_SAMPLE_MASK - Pin sample mask. */
428 #define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK(val) BSP_FLD32(val,19, 20)
429 #define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg) BSP_FLD32GET(reg,19, 20)
430 #define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg,val) BSP_FLD32SET(reg, val,19, 20)
431
432 /* field: TX_SHIFT - Transmit shift. */
433 #define TMS570_SCI_IODFTCTRL_TX_SHIFT(val) BSP_FLD32(val,16, 18)
434 #define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET(reg) BSP_FLD32GET(reg,16, 18)
435 #define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
436
437 /* field: IODFTENA - IODFT enable key. Write access permitted in Privilege mode only. */
438 #define TMS570_SCI_IODFTCTRL_IODFTENA(val) BSP_FLD32(val,8, 11)
439 #define TMS570_SCI_IODFTCTRL_IODFTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
440 #define TMS570_SCI_IODFTCTRL_IODFTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
441
442 /* field: LPBENA - Module loopback enable. Write access permitted in Privilege mode only. */
443 #define TMS570_SCI_IODFTCTRL_LPBENA BSP_BIT32(1)
444
445 /* field: RXPENA - Module analog loopback through receive pin enable. */
446 #define TMS570_SCI_IODFTCTRL_RXPENA BSP_BIT32(0)
447
448
449
450 #endif /* LIBBSP_ARM_TMS570_SCI */
Utility macros.
Definition: reg_sci.h:44
