RTEMS  5.1
reg_rti.h
1 /* The header file is generated by make_header.py from RTI.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_RTI
40 #define LIBBSP_ARM_TMS570_RTI
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t COMPx; /*RTI Compare x Register*/
46  uint32_t UDCPx; /*RTI Update Compare x Register*/
48
49 typedef struct{
50  uint32_t FRCx; /*RTI Free Running Counter x Register*/
51  uint32_t UCx; /*RTI Up Counter x Register*/
52  uint32_t CPUCx; /*RTI Compare Up Counter x Register*/
53  uint8_t reserved1 [4];
54  uint32_t CAFRCx; /*RTI Capture Free Running Counter x Register*/
55  uint32_t CAUCx; /*RTI Capture Up Counter x Register*/
56  uint32_t rsvd[2]; /*Reserved*/
58
59 typedef struct{
60  uint32_t GCTRL; /*RTI Global Control Register*/
61  uint32_t TBCTRL; /*RTI Timebase Control Register*/
62  uint32_t CAPCTRL; /*RTI Capture Control Register*/
63  uint32_t COMPCTRL; /*RTI Compare Control Register*/
64  tms570_rti_counter_t CNT[2];/*Counters*/
65  tms570_rti_compare_t CMP[4];/*Compares*/
66  uint32_t TBLCOMP; /*RTI Timebase Low Compare Register*/
67  uint32_t TBHCOMP; /*RTI Timebase High Compare Register*/
68  uint8_t reserved2 [8];
69  uint32_t SETINTENA; /*RTI Set Interrupt Enable Register*/
70  uint32_t CLEARINTENA; /*RTI Clear Interrupt Enable Register*/
71  uint32_t INTFLAG; /*RTI Interrupt Flag Register*/
72  uint8_t reserved3 [4];
73  uint32_t DWDCTRL; /*Digital Watchdog Control Register*/
74  uint32_t DWDPRLD; /*Digital Watchdog Preload Register*/
75  uint32_t WDSTATUS; /*Watchdog Status Register*/
76  uint32_t WDKEY; /*RTI Watchdog Key Register*/
77  uint32_t DWDCNTR; /*RTI Digital Watchdog Down Counter Register*/
78  uint32_t WWDRXNCTRL; /*Digital Windowed Watchdog Reaction Control Register*/
79  uint32_t WWDSIZECTRL; /*Digital Windowed Watchdog Window Size Control Register*/
80  uint32_t INTCLRENABLE; /*RTI Compare Interrupt Clear Enable Register*/
81  uint32_t COMP0CLR; /*RTI Compare 0 Clear Register*/
82  uint32_t COMP1CLR; /*RTI Compare 1 Clear Register*/
83  uint32_t COMP2CLR; /*RTI Compare 2 Clear Register*/
84  uint32_t COMP3CLR; /*RTI Compare 3 Clear Register*/
85 } tms570_rti_t;
86
87
88 /*----------------------TMS570_RTI_COMPx----------------------*/
89 /* field: COMPx - Compare x. */
90 /* Whole 32 bits */
91
92 /*----------------------TMS570_RTI_UDCPx----------------------*/
93 /* field: UDCPx - Update compare x. */
94 /* Whole 32 bits */
95
96 /*----------------------TMS570_RTI_FRCx----------------------*/
97 /* field: FRC0 - FRC0 */
98 /* Whole 32 bits */
99
100 /*-----------------------TMS570_RTI_UCx-----------------------*/
101 /* field: UC0 - Up counter 0. */
102 /* Whole 32 bits */
103
104 /*----------------------TMS570_RTI_CPUCx----------------------*/
105 /* field: CPUC0 - Compare up counter 0. This register holds the value that is compared with the up counter 0. */
106 /* Whole 32 bits */
107
108 /*---------------------TMS570_RTI_CAFRCx---------------------*/
109 /* field: CAFRC0 - Capture free running counter 0. */
110 /* Whole 32 bits */
111
112 /*----------------------TMS570_RTI_CAUCx----------------------*/
113 /* field: CAUC0 - Capture up counter 0. */
114 /* Whole 32 bits */
115
116 /*----------------------TMS570_RTI_rsvd----------------------*/
117 /* field: CAUC0 - Capture up counter 0. */
118 /* Whole 32 bits */
119
120 /*----------------------TMS570_RTI_GCTRL----------------------*/
121 /* field: NTUSEL - Select NTU signal. */
122 #define TMS570_RTI_GCTRL_NTUSEL(val) BSP_FLD32(val,16, 19)
123 #define TMS570_RTI_GCTRL_NTUSEL_GET(reg) BSP_FLD32GET(reg,16, 19)
124 #define TMS570_RTI_GCTRL_NTUSEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
125
126 /* field: COS - Continue on suspend. */
127 #define TMS570_RTI_GCTRL_COS BSP_BIT32(15)
128
129 /* field: CNT1EN - Counter 1 enable. This bit starts and stops counter block 1 (RTIUC1 and RTIFRC1). */
130 #define TMS570_RTI_GCTRL_CNT1EN BSP_BIT32(1)
131
132 /* field: CNT0EN - Counter 0 enable. This bit starts and stops counter block 0 (RTIUC0 and RTIFRC0). */
133 #define TMS570_RTI_GCTRL_CNT0EN BSP_BIT32(0)
134
135
136 /*---------------------TMS570_RTI_TBCTRL---------------------*/
137 /* field: INC - Increment free running counter 0. */
138 #define TMS570_RTI_TBCTRL_INC BSP_BIT32(1)
139
140 /* field: TBEXT - Timebase external. */
141 #define TMS570_RTI_TBCTRL_TBEXT BSP_BIT32(0)
142
143
144 /*---------------------TMS570_RTI_CAPCTRL---------------------*/
145 /* field: CAPCNTR1 - Capture counter 1. */
146 #define TMS570_RTI_CAPCTRL_CAPCNTR1 BSP_BIT32(1)
147
148 /* field: CAPCNTR0 - Capture counter 0. */
149 #define TMS570_RTI_CAPCTRL_CAPCNTR0 BSP_BIT32(0)
150
151
152 /*--------------------TMS570_RTI_COMPCTRL--------------------*/
153 /* field: COMPSEL3 - Compare select 3. */
154 #define TMS570_RTI_COMPCTRL_COMPSEL3 BSP_BIT32(12)
155
156 /* field: COMPSEL2 - Compare select 2. */
157 #define TMS570_RTI_COMPCTRL_COMPSEL2 BSP_BIT32(8)
158
159 /* field: COMPSEL1 - Compare select 1. */
160 #define TMS570_RTI_COMPCTRL_COMPSEL1 BSP_BIT32(4)
161
162 /* field: COMPSEL0 - Compare select 0. */
163 #define TMS570_RTI_COMPCTRL_COMPSEL0 BSP_BIT32(0)
164
165
166 /*---------------------TMS570_RTI_TBLCOMP---------------------*/
167 /* field: TBLCOMP - Timebase low compare value. */
168 /* Whole 32 bits */
169
170 /*---------------------TMS570_RTI_TBHCOMP---------------------*/
171 /* field: TBHCOMP - Timebase high compare value. */
172 /* Whole 32 bits */
173
174 /*--------------------TMS570_RTI_SETINTENA--------------------*/
175 /* field: SETOVL1INT - Set free running counter 1 overflow interrupt. */
176 #define TMS570_RTI_SETINTENA_SETOVL1INT BSP_BIT32(18)
177
178 /* field: SETOVL0INT - Set free running counter 0 overflow interrupt. */
179 #define TMS570_RTI_SETINTENA_SETOVL0INT BSP_BIT32(17)
180
181 /* field: SETTBINT - Set timebase interrupt. */
182 #define TMS570_RTI_SETINTENA_SETTBINT BSP_BIT32(16)
183
184 /* field: SETDMA3 - Set compare DMA request 3. */
185 #define TMS570_RTI_SETINTENA_SETDMA3 BSP_BIT32(11)
186
187 /* field: SETDMA2 - Set compare DMA request 2. */
188 #define TMS570_RTI_SETINTENA_SETDMA2 BSP_BIT32(10)
189
190 /* field: SETDMA1 - Set compare DMA request 1. */
191 #define TMS570_RTI_SETINTENA_SETDMA1 BSP_BIT32(9)
192
193 /* field: SETDMA0 - Set compare DMA request 0. */
194 #define TMS570_RTI_SETINTENA_SETDMA0 BSP_BIT32(8)
195
196 /* field: SETINT3 - Set compare interrupt 3. */
197 #define TMS570_RTI_SETINTENA_SETINT3 BSP_BIT32(3)
198
199 /* field: SETINT2 - Set compare interrupt 2. */
200 #define TMS570_RTI_SETINTENA_SETINT2 BSP_BIT32(2)
201
202 /* field: SETINT1 - Set compare interrupt 1. */
203 #define TMS570_RTI_SETINTENA_SETINT1 BSP_BIT32(1)
204
205 /* field: SETINT0 - Set compare interrupt 0. */
206 #define TMS570_RTI_SETINTENA_SETINT0 BSP_BIT32(0)
207
208
209 /*-------------------TMS570_RTI_CLEARINTENA-------------------*/
210 /* field: CLEAROVL1INT - Clear free running counter 1 overflow interrupt. */
211 #define TMS570_RTI_CLEARINTENA_CLEAROVL1INT BSP_BIT32(18)
212
213 /* field: CLEAROVL0INT - Clear free running counter 0 overflow interrupt. */
214 #define TMS570_RTI_CLEARINTENA_CLEAROVL0INT BSP_BIT32(17)
215
216 /* field: CLEARTBINT - Clear timebase interrupt. */
217 #define TMS570_RTI_CLEARINTENA_CLEARTBINT BSP_BIT32(16)
218
219 /* field: CLEARDMA3 - Clear compare DMA request 3. */
220 #define TMS570_RTI_CLEARINTENA_CLEARDMA3 BSP_BIT32(11)
221
222 /* field: CLEARDMA2 - Clear compare DMA request 2. */
223 #define TMS570_RTI_CLEARINTENA_CLEARDMA2 BSP_BIT32(10)
224
225 /* field: CLEARDMA1 - Clear compare DMA request 1. */
226 #define TMS570_RTI_CLEARINTENA_CLEARDMA1 BSP_BIT32(9)
227
228 /* field: CLEARDMA0 - Clear compare DMA request 0. */
229 #define TMS570_RTI_CLEARINTENA_CLEARDMA0 BSP_BIT32(8)
230
231 /* field: CLEARINT3 - Clear compare interrupt 3. */
232 #define TMS570_RTI_CLEARINTENA_CLEARINT3 BSP_BIT32(3)
233
234 /* field: CLEARINT2 - Clear compare interrupt 2. */
235 #define TMS570_RTI_CLEARINTENA_CLEARINT2 BSP_BIT32(2)
236
237 /* field: CLEARINT1 - Clear compare interrupt 1. */
238 #define TMS570_RTI_CLEARINTENA_CLEARINT1 BSP_BIT32(1)
239
240 /* field: CLEARINT0 - Clear compare interrupt 0. */
241 #define TMS570_RTI_CLEARINTENA_CLEARINT0 BSP_BIT32(0)
242
243
244 /*---------------------TMS570_RTI_INTFLAG---------------------*/
245 /* field: OVL1INT - Free running counter 1 overflow interrupt flag. This bit determines if an interrupt is pending. */
246 #define TMS570_RTI_INTFLAG_OVL1INT BSP_BIT32(18)
247
248 /* field: OVL0INT - Free running counter 0 overflow interrupt flag. This bit determines if an interrupt is pending. */
249 #define TMS570_RTI_INTFLAG_OVL0INT BSP_BIT32(17)
250
251 /* field: TBINT - Timebase interrupt flag. */
252 #define TMS570_RTI_INTFLAG_TBINT BSP_BIT32(16)
253
254 /* field: INT3 - Interrupt flag 3. These bits determine if an interrupt due to a Compare 3 match is pending. */
255 #define TMS570_RTI_INTFLAG_INT3 BSP_BIT32(3)
256
257 /* field: INT2 - Interrupt flag 2. These bits determine if an interrupt due to a Compare 2 match is pending. */
258 #define TMS570_RTI_INTFLAG_INT2 BSP_BIT32(2)
259
260 /* field: INT1 - Interrupt flag 1. These bits determine if an interrupt due to a Compare 1 match is pending. */
261 #define TMS570_RTI_INTFLAG_INT1 BSP_BIT32(1)
262
263 /* field: INT0 - Interrupt flag 0. These bits determine if an interrupt due to a Compare 0 match is pending. */
264 #define TMS570_RTI_INTFLAG_INT0 BSP_BIT32(0)
265
266
267 /*---------------------TMS570_RTI_DWDCTRL---------------------*/
268 /* field: DWDCTRL - DWDCTRL Digital Watchdog Control. */
269 /* Whole 32 bits */
270
271 /*---------------------TMS570_RTI_DWDPRLD---------------------*/
272 /* field: DWDPRLD - Digital Watchdog Preload Value. */
273 #define TMS570_RTI_DWDPRLD_DWDPRLD(val) BSP_FLD32(val,0, 15)
274 #define TMS570_RTI_DWDPRLD_DWDPRLD_GET(reg) BSP_FLD32GET(reg,0, 15)
275 #define TMS570_RTI_DWDPRLD_DWDPRLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
276
277
278 /*--------------------TMS570_RTI_WDSTATUS--------------------*/
279 /* field: DWWD_ST - Windowed Watchdog Status */
280 #define TMS570_RTI_WDSTATUS_DWWD_ST BSP_BIT32(5)
281
282 /* field: END_TIME_VIOL - Windowed Watchdog End Time Violation Status. */
283 #define TMS570_RTI_WDSTATUS_END_TIME_VIOL BSP_BIT32(4)
284
285 /* field: START_TIME_VIOL - Windowed Watchdog Start Time Violation Status. */
286 #define TMS570_RTI_WDSTATUS_START_TIME_VIOL BSP_BIT32(3)
287
288 /* field: KEY_ST - Watchdog key status. */
289 #define TMS570_RTI_WDSTATUS_KEY_ST BSP_BIT32(2)
290
291 /* field: DWD_ST - DWD status. */
292 #define TMS570_RTI_WDSTATUS_DWD_ST BSP_BIT32(1)
293
294
295 /*----------------------TMS570_RTI_WDKEY----------------------*/
296 /* field: WDKEY - Watchdog key. These bits provide the key sequence location. */
297 #define TMS570_RTI_WDKEY_WDKEY(val) BSP_FLD32(val,0, 15)
298 #define TMS570_RTI_WDKEY_WDKEY_GET(reg) BSP_FLD32GET(reg,0, 15)
299 #define TMS570_RTI_WDKEY_WDKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
300
301
302 /*---------------------TMS570_RTI_DWDCNTR---------------------*/
303 /* field: DWDCNTR - DWD down counter. */
304 #define TMS570_RTI_DWDCNTR_DWDCNTR(val) BSP_FLD32(val,0, 24)
305 #define TMS570_RTI_DWDCNTR_DWDCNTR_GET(reg) BSP_FLD32GET(reg,0, 24)
306 #define TMS570_RTI_DWDCNTR_DWDCNTR_SET(reg,val) BSP_FLD32SET(reg, val,0, 24)
307
308
309 /*-------------------TMS570_RTI_WWDRXNCTRL-------------------*/
310 /* field: WWDRXN - The DWWD reaction */
311 #define TMS570_RTI_WWDRXNCTRL_WWDRXN(val) BSP_FLD32(val,0, 3)
312 #define TMS570_RTI_WWDRXNCTRL_WWDRXN_GET(reg) BSP_FLD32GET(reg,0, 3)
313 #define TMS570_RTI_WWDRXNCTRL_WWDRXN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
314
315
316 /*-------------------TMS570_RTI_WWDSIZECTRL-------------------*/
317 /* field: WWDSIZE - The DWWD window size */
318 /* Whole 32 bits */
319
320 /*------------------TMS570_RTI_INTCLRENABLE------------------*/
321 /* field: INTCLRENABLE3 - Enables the auto-clear functionality on the compare 3 interrupt. */
322 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3(val) BSP_FLD32(val,24, 27)
323 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3_GET(reg) BSP_FLD32GET(reg,24, 27)
324 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
325
326 /* field: INTCLRENABLE2 - Enables the auto-clear functionality on the compare 2 interrupt. */
327 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2(val) BSP_FLD32(val,16, 19)
328 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2_GET(reg) BSP_FLD32GET(reg,16, 19)
329 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
330
331 /* field: INTCLRENABLE1 - Enables the auto-clear functionality on the compare 1 interrupt. */
332 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1(val) BSP_FLD32(val,8, 11)
333 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1_GET(reg) BSP_FLD32GET(reg,8, 11)
334 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
335
336 /* field: INTCLRENABLE0 - Enables the auto-clear functionality on the compare 0 interrupt. */
337 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0(val) BSP_FLD32(val,0, 3)
338 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0_GET(reg) BSP_FLD32GET(reg,0, 3)
339 #define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
340
341
342 /*--------------------TMS570_RTI_COMP0CLR--------------------*/
343 /* field: CMP0CLR - Compare 0 clear. */
344 /* Whole 32 bits */
345
346 /*--------------------TMS570_RTI_COMP1CLR--------------------*/
347 /* field: CMP0CLR - Compare 1 clear. */
348 /* Whole 32 bits */
349
350 /*--------------------TMS570_RTI_COMP2CLR--------------------*/
351 /* field: CMP2CLR - Compare 2 clear. */
352 /* Whole 32 bits */
353
354 /*--------------------TMS570_RTI_COMP3CLR--------------------*/
355 /* field: CMP3CLR - Compare 3 clear. */
356 /* Whole 32 bits */
357
358
359 #endif /* LIBBSP_ARM_TMS570_RTI */
Definition: reg_rti.h:59
Definition: reg_rti.h:49
Utility macros.
Definition: reg_rti.h:44
