RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
tms570
include
bsp
ti_herc
reg_pom.h
1
/* The header file is generated by make_header.py from POM.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_POM
40
#define LIBBSP_ARM_TMS570_POM
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t PROGSTART;
/*POM Program Region Start Address Register*/
46
uint32_t OVLSTART;
/*POM Overlay Region Start Address Register*/
47
uint32_t REGSIZE;
/*POM Region Size Register */
48
uint32_t Reser;
/*Reserved*/
49
tms570_pom_region_t
50
51
typedef
struct
52
uint32_t GLBCTRL;
/*POM Global Control Register*/
53
uint32_t REV;
/*POM Revision ID*/
54
uint32_t CLKCTRL;
/*POM Clock Gate Control Register*/
55
uint32_t FLG;
/*POM Status Register*/
56
uint8_t reserved1 [496];
57
tms570_pom_region_t
REG[32];
/*Program Regions*/
58
uint8_t reserved2 [2816];
59
uint32_t ITCTRL;
/*POM Integration Control Register*/
60
uint8_t reserved3 [156];
61
uint32_t CLAIMSET;
/*POM Claim Set Register*/
62
uint32_t CLAIMCLR;
/*POM Claim Clear Register*/
63
uint8_t reserved4 [8];
64
uint32_t LOCKACCESS;
/*POM Lock Access Register*/
65
uint32_t LOCKSTATUS;
/*POM Lock Status Register*/
66
uint32_t AUTHSTATUS;
/*POM Authentication Status Register*/
67
uint8_t reserved5 [12];
68
uint32_t DEVID;
/*POM Device ID Register*/
69
uint32_t DEVTYPE;
/*POM Device Type Register*/
70
uint32_t PERIPHERALID4;
/*POM Peripheral ID 4 Register*/
71
uint32_t PERIPHERALID5;
/*POM Peripheral ID 5 Register*/
72
uint32_t PERIPHERALID6;
/*POM Peripheral ID 6 Register*/
73
uint32_t PERIPHERALID7;
/*POM Peripheral ID 7 Register*/
74
uint32_t PERIPHERALID0;
/*POM Peripheral ID 0 Register*/
75
uint32_t PERIPHERALID1;
/*POM Peripheral ID 1 Register*/
76
uint32_t PERIPHERALID2;
/*POM Peripheral ID 2 Register*/
77
uint32_t PERIPHERALID3;
/*POM Peripheral ID 3 Register*/
78
uint32_t COMPONENTID0;
/*POM Component ID 0 Register*/
79
uint32_t COMPONENTID1;
/*POM Component ID 1 Register*/
80
uint32_t COMPONENTID2;
/*POM Component ID 2 Register*/
81
uint32_t COMPONENTID3;
/*POM Component ID 3 Register*/
82
tms570_pom_t
83
84
85
/*--------------------TMS570_POM_PROGSTART--------------------*/
86
/* field: STARTADDRESS - Defines the start address of the program memory region. */
87
#define TMS570_POM_PROGSTART_STARTADDRESS(val) BSP_FLD32(val,0, 22)
88
#define TMS570_POM_PROGSTART_STARTADDRESS_GET(reg) BSP_FLD32GET(reg,0, 22)
89
#define TMS570_POM_PROGSTART_STARTADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 22)
90
91
92
/*--------------------TMS570_POM_OVLSTART--------------------*/
93
/* field: STARTADDRESS - Defines the start address of the overlay memory region. */
94
#define TMS570_POM_OVLSTART_STARTADDRESS(val) BSP_FLD32(val,0, 22)
95
#define TMS570_POM_OVLSTART_STARTADDRESS_GET(reg) BSP_FLD32GET(reg,0, 22)
96
#define TMS570_POM_OVLSTART_STARTADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 22)
97
98
99
/*---------------------TMS570_POM_REGSIZE---------------------*/
100
/* field: SIZE - Region size */
101
#define TMS570_POM_REGSIZE_SIZE(val) BSP_FLD32(val,0, 3)
102
#define TMS570_POM_REGSIZE_SIZE_GET(reg) BSP_FLD32GET(reg,0, 3)
103
#define TMS570_POM_REGSIZE_SIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
104
105
106
/*---------------------TMS570_POM_GLBCTRL---------------------*/
107
/* field: OTADDR - Overlay target Address. */
108
#define TMS570_POM_GLBCTRL_OTADDR(val) BSP_FLD32(val,23, 31)
109
#define TMS570_POM_GLBCTRL_OTADDR_GET(reg) BSP_FLD32GET(reg,23, 31)
110
#define TMS570_POM_GLBCTRL_OTADDR_SET(reg,val) BSP_FLD32SET(reg, val,23, 31)
111
112
/* field: ETO - Enable Timeout. Refer to Section 18.2.2 for more details on the timeout error. */
113
#define TMS570_POM_GLBCTRL_ETO(val) BSP_FLD32(val,8, 11)
114
#define TMS570_POM_GLBCTRL_ETO_GET(reg) BSP_FLD32GET(reg,8, 11)
115
#define TMS570_POM_GLBCTRL_ETO_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
116
117
/* field: ON_OFF - Turn functionality of POM on or off. */
118
#define TMS570_POM_GLBCTRL_ON_OFF(val) BSP_FLD32(val,0, 3)
119
#define TMS570_POM_GLBCTRL_ON_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
120
#define TMS570_POM_GLBCTRL_ON_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
121
122
123
/*-----------------------TMS570_POM_REV-----------------------*/
124
/* field: SCHEME - Used to distinguish between different ID schemes. */
125
#define TMS570_POM_REV_SCHEME(val) BSP_FLD32(val,30, 31)
126
#define TMS570_POM_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
127
#define TMS570_POM_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
128
129
/* field: FUNC - Indicates the SW compatible module family */
130
#define TMS570_POM_REV_FUNC(val) BSP_FLD32(val,16, 27)
131
#define TMS570_POM_REV_FUNC_GET(reg) BSP_FLD32GET(reg,16, 27)
132
#define TMS570_POM_REV_FUNC_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
133
134
/* field: RTL - RTL version number */
135
#define TMS570_POM_REV_RTL(val) BSP_FLD32(val,11, 15)
136
#define TMS570_POM_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
137
#define TMS570_POM_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
138
139
/* field: MAJOR - Major revision number */
140
#define TMS570_POM_REV_MAJOR(val) BSP_FLD32(val,8, 10)
141
#define TMS570_POM_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
142
#define TMS570_POM_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
143
144
/* field: CUSTOM - Indicates a device specific implementation */
145
#define TMS570_POM_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
146
#define TMS570_POM_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
147
#define TMS570_POM_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
148
149
/* field: 5_0 - MINOR 8h Minor revision number */
150
#define TMS570_POM_REV_5_0(val) BSP_FLD32(val,0, 5)
151
#define TMS570_POM_REV_5_0_GET(reg) BSP_FLD32GET(reg,0, 5)
152
#define TMS570_POM_REV_5_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
153
154
155
/*---------------------TMS570_POM_CLKCTRL---------------------*/
156
/* field: CLK_GATE_OFF - Do not modify this bit. Leave it in its reset state. */
157
#define TMS570_POM_CLKCTRL_CLK_GATE_OFF BSP_BIT32(0)
158
159
160
/*-----------------------TMS570_POM_FLG-----------------------*/
161
/* field: TO - Timeout. */
162
#define TMS570_POM_FLG_TO BSP_BIT32(0)
163
164
165
/*---------------------TMS570_POM_ITCTRL---------------------*/
166
/* field: Reserved - Read returns 0. Writes have no effect. */
167
/* Whole 32 bits */
168
169
/*--------------------TMS570_POM_CLAIMSET--------------------*/
170
/* field: SET1 - The module is claimed */
171
#define TMS570_POM_CLAIMSET_SET1 BSP_BIT32(1)
172
173
/* field: SET0 - The module is claimed */
174
#define TMS570_POM_CLAIMSET_SET0 BSP_BIT32(0)
175
176
177
/*--------------------TMS570_POM_CLAIMCLR--------------------*/
178
/* field: CLR1 - The module is claimed */
179
#define TMS570_POM_CLAIMCLR_CLR1 BSP_BIT32(1)
180
181
/* field: CLR0 - The module is claimed */
182
#define TMS570_POM_CLAIMCLR_CLR0 BSP_BIT32(0)
183
184
185
/*-------------------TMS570_POM_LOCKACCESS-------------------*/
186
187
/* Whole 32 bits */
188
189
/*-------------------TMS570_POM_LOCKSTATUS-------------------*/
190
191
/* Whole 32 bits */
192
193
/*-------------------TMS570_POM_AUTHSTATUS-------------------*/
194
195
/* Whole 32 bits */
196
197
/*----------------------TMS570_POM_DEVID----------------------*/
198
199
/* Whole 32 bits */
200
201
/*---------------------TMS570_POM_DEVTYPE---------------------*/
202
/* field: Sub_Type - Other */
203
#define TMS570_POM_DEVTYPE_Sub_Type(val) BSP_FLD32(val,4, 7)
204
#define TMS570_POM_DEVTYPE_Sub_Type_GET(reg) BSP_FLD32GET(reg,4, 7)
205
#define TMS570_POM_DEVTYPE_Sub_Type_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
206
207
/* field: Major_Type - Debug Control */
208
#define TMS570_POM_DEVTYPE_Major_Type(val) BSP_FLD32(val,0, 3)
209
#define TMS570_POM_DEVTYPE_Major_Type_GET(reg) BSP_FLD32GET(reg,0, 3)
210
#define TMS570_POM_DEVTYPE_Major_Type_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
211
212
213
/*------------------TMS570_POM_PERIPHERALID4------------------*/
214
/* field: 4KB_Count - Only 4KB implemented */
215
#define TMS570_POM_PERIPHERALID4_4KB_Count(val) BSP_FLD32(val,4, 7)
216
#define TMS570_POM_PERIPHERALID4_4KB_Count_GET(reg) BSP_FLD32GET(reg,4, 7)
217
#define TMS570_POM_PERIPHERALID4_4KB_Count_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
218
219
/* field: JEP_Continuation - JEP106 Code */
220
#define TMS570_POM_PERIPHERALID4_JEP_Continuation(val) BSP_FLD32(val,0, 3)
221
#define TMS570_POM_PERIPHERALID4_JEP_Continuation_GET(reg) BSP_FLD32GET(reg,0, 3)
222
#define TMS570_POM_PERIPHERALID4_JEP_Continuation_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
223
224
225
/*------------------TMS570_POM_PERIPHERALID5------------------*/
226
227
/* Whole 32 bits */
228
229
/*------------------TMS570_POM_PERIPHERALID6------------------*/
230
231
/* Whole 32 bits */
232
233
/*------------------TMS570_POM_PERIPHERALID7------------------*/
234
235
/* Whole 32 bits */
236
237
/*------------------TMS570_POM_PERIPHERALID0------------------*/
238
/* field: Part_Number - Reads 0, since POMREV defines the module */
239
#define TMS570_POM_PERIPHERALID0_Part_Number(val) BSP_FLD32(val,0, 7)
240
#define TMS570_POM_PERIPHERALID0_Part_Number_GET(reg) BSP_FLD32GET(reg,0, 7)
241
#define TMS570_POM_PERIPHERALID0_Part_Number_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
242
243
244
/*------------------TMS570_POM_PERIPHERALID1------------------*/
245
/* field: JEP106_Identity - Part of TI JEDEC number */
246
#define TMS570_POM_PERIPHERALID1_JEP106_Identity(val) BSP_FLD32(val,4, 7)
247
#define TMS570_POM_PERIPHERALID1_JEP106_Identity_GET(reg) BSP_FLD32GET(reg,4, 7)
248
#define TMS570_POM_PERIPHERALID1_JEP106_Identity_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
249
250
251
#define TMS570_POM_PERIPHERALID1_Part_Number(val) BSP_FLD32(val,0, 3)
252
#define TMS570_POM_PERIPHERALID1_Part_Number_GET(reg) BSP_FLD32GET(reg,0, 3)
253
#define TMS570_POM_PERIPHERALID1_Part_Number_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
254
255
256
/*------------------TMS570_POM_PERIPHERALID2------------------*/
257
/* field: Revision - Reads 0, since POMREV defines the module */
258
#define TMS570_POM_PERIPHERALID2_Revision(val) BSP_FLD32(val,4, 7)
259
#define TMS570_POM_PERIPHERALID2_Revision_GET(reg) BSP_FLD32GET(reg,4, 7)
260
#define TMS570_POM_PERIPHERALID2_Revision_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
261
262
/* field: JEDEC - Indicates JEDEC assigned value */
263
#define TMS570_POM_PERIPHERALID2_JEDEC BSP_BIT32(3)
264
265
/* field: JEP106_Identity - JEDEC+JEP106 Identity Code (POMPERIPHERALID2)+JEP106 Identity Code */
266
#define TMS570_POM_PERIPHERALID2_JEP106_Identity(val) BSP_FLD32(val,0, 2)
267
#define TMS570_POM_PERIPHERALID2_JEP106_Identity_GET(reg) BSP_FLD32GET(reg,0, 2)
268
#define TMS570_POM_PERIPHERALID2_JEP106_Identity_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
269
270
271
/*------------------TMS570_POM_PERIPHERALID3------------------*/
272
273
/* Whole 32 bits */
274
275
/*------------------TMS570_POM_COMPONENTID0------------------*/
276
/* field: Preamble - Preamble */
277
#define TMS570_POM_COMPONENTID0_Preamble(val) BSP_FLD32(val,0, 7)
278
#define TMS570_POM_COMPONENTID0_Preamble_GET(reg) BSP_FLD32GET(reg,0, 7)
279
#define TMS570_POM_COMPONENTID0_Preamble_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
280
281
282
/*------------------TMS570_POM_COMPONENTID1------------------*/
283
/* field: Component_Class - CoreSight Component */
284
#define TMS570_POM_COMPONENTID1_Component_Class(val) BSP_FLD32(val,4, 7)
285
#define TMS570_POM_COMPONENTID1_Component_Class_GET(reg) BSP_FLD32GET(reg,4, 7)
286
#define TMS570_POM_COMPONENTID1_Component_Class_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
287
288
289
#define TMS570_POM_COMPONENTID1_Preamble(val) BSP_FLD32(val,0, 3)
290
#define TMS570_POM_COMPONENTID1_Preamble_GET(reg) BSP_FLD32GET(reg,0, 3)
291
#define TMS570_POM_COMPONENTID1_Preamble_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
292
293
294
/*------------------TMS570_POM_COMPONENTID2------------------*/
295
296
#define TMS570_POM_COMPONENTID2_Preamble(val) BSP_FLD32(val,0, 7)
297
#define TMS570_POM_COMPONENTID2_Preamble_GET(reg) BSP_FLD32GET(reg,0, 7)
298
#define TMS570_POM_COMPONENTID2_Preamble_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
299
300
301
/*------------------TMS570_POM_COMPONENTID3------------------*/
302
303
#define TMS570_POM_COMPONENTID3_Preamble(val) BSP_FLD32(val,0, 7)
304
#define TMS570_POM_COMPONENTID3_Preamble_GET(reg) BSP_FLD32GET(reg,0, 7)
305
#define TMS570_POM_COMPONENTID3_Preamble_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
306
307
308
309
#endif
/* LIBBSP_ARM_TMS570_POM */
tms570_pom_region_t
Definition:
reg_pom.h:44
utility.h
Utility macros.
tms570_pom_t
Definition:
reg_pom.h:51
