RTEMS  5.1
reg_pmm.h
1 /* The header file is generated by make_header.py from PMM.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_PMM
40 #define LIBBSP_ARM_TMS570_PMM
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t LOGICPDPWRCTRL0; /*Logic Power Domain Control Register 0*/
46  uint8_t reserved1 [12];
47  uint32_t MEMPDPWRCTRL0; /*Memory Power Domain Control Register 0*/
48  uint8_t reserved2 [12];
49  uint32_t PDCLKDISREG; /*Power Domain Clock Disable Register*/
50  uint32_t PDCLKDISSETREG; /*Power Domain Clock Disable Set Register*/
51  uint32_t PDCLKDISCLRREG; /*Power Domain Clock Disable Clear Register*/
52  uint8_t reserved3 [20];
53  uint32_t LOGICPDPWRSTAT[4]; /*Logic Power Domain PD2 Power Status Registers*/
54  uint8_t reserved4 [48];
55  uint32_t MEMPDPWRSTAT[3]; /*Memory Power Domain RAM_PD1 Power Status Registers*/
56  uint8_t reserved5 [20];
57  uint32_t GLOBALCTRL1; /*Global Control Register 1*/
58  uint8_t reserved6 [4];
59  uint32_t GLOBALSTAT; /*Global Status Register*/
60  uint32_t PRCKEYREG; /*PSCON Diagnostic Compare Key Register*/
61  uint32_t LPDDCSTAT1; /*LogicPD PSCON Diagnostic Compare Status Register 1*/
62  uint32_t LPDDCSTAT2; /*LogicPD PSCON Diagnostic Compare Status Register 2*/
63  uint32_t MPDDCSTAT1; /*Memory PD PSCON Diagnostic Compare Status Register 1*/
64  uint32_t MPDDCSTAT2; /*Memory PD PSCON Diagnostic Compare Status Register 2*/
65  uint32_t ISODIAGSTAT; /*Isolation Diagnostic Status Register*/
66 } tms570_pmm_t;
67
68
69 /*-----------------TMS570_PMM_LOGICPDPWRCTRL0-----------------*/
70 /* field: LOGICPDON0 - Read in User and Privileged Mode. Write in Privileged Mode only. */
71 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0(val) BSP_FLD32(val,24, 27)
72 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0_GET(reg) BSP_FLD32GET(reg,24, 27)
73 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
74
75 /* field: LOGICPDON1 - Read in User and Privileged Mode. Write in Privileged Mode only. */
76 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1(val) BSP_FLD32(val,16, 19)
77 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1_GET(reg) BSP_FLD32GET(reg,16, 19)
78 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
79
80 /* field: LOGICPDON2 - Read in User and Privileged Mode. Write in Privileged Mode only. */
81 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2(val) BSP_FLD32(val,8, 11)
82 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2_GET(reg) BSP_FLD32GET(reg,8, 11)
83 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON2_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
84
85 /* field: LOGICPDON3 - Read in User and Privileged Mode. Write in Privileged Mode only. */
86 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3(val) BSP_FLD32(val,0, 3)
87 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3_GET(reg) BSP_FLD32GET(reg,0, 3)
88 #define TMS570_PMM_LOGICPDPWRCTRL0_LOGICPDON3_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
89
90
91 /*------------------TMS570_PMM_MEMPDPWRCTRL0------------------*/
92 /* field: MEMPDON0 - Read in User and Privileged Mode. Write in Privileged Mode only. */
93 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0(val) BSP_FLD32(val,24, 27)
94 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0_GET(reg) BSP_FLD32GET(reg,24, 27)
95 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
96
97 /* field: MEMPDON1 - Read in User and Privileged Mode. Write in Privileged Mode only. */
98 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1(val) BSP_FLD32(val,16, 19)
99 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1_GET(reg) BSP_FLD32GET(reg,16, 19)
100 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
101
102 /* field: MEMPDON2 - Read in User and Privileged Mode. Write in Privileged Mode only. */
103 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2(val) BSP_FLD32(val,8, 11)
104 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2_GET(reg) BSP_FLD32GET(reg,8, 11)
105 #define TMS570_PMM_MEMPDPWRCTRL0_MEMPDON2_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
106
107
108 /*-------------------TMS570_PMM_PDCLKDISREG-------------------*/
109 /* field: PDCLK_DIS_3 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[3]. */
110 #define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_3 BSP_BIT32(3)
111
112 /* field: PDCLK_DIS_2 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[2]. */
113 #define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_2 BSP_BIT32(2)
114
115 /* field: PDCLK_DIS_1 - ead in User and Privileged Mode returns the current value of PDCLK_DIS[1]. */
116 #define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_1 BSP_BIT32(1)
117
118 /* field: PDCLK_DIS_0 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[0]. */
119 #define TMS570_PMM_PDCLKDISREG_PDCLK_DIS_0 BSP_BIT32(0)
120
121
122 /*-----------------TMS570_PMM_PDCLKDISSETREG-----------------*/
123 /* field: PDCLK_DISSET_3 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[3]. */
124 #define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_3 BSP_BIT32(3)
125
126 /* field: PDCLK_DISSET_2 - Privileged Mode only. */
127 #define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_2 BSP_BIT32(2)
128
129 /* field: PDCLK_DISSET_1 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[1]. */
130 #define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_1 BSP_BIT32(1)
131
132 /* field: PDCLK_DISSET_0 - Read in User and Privileged Mode returns the current value of PDCLK_DISSET[0]. */
133 #define TMS570_PMM_PDCLKDISSETREG_PDCLK_DISSET_0 BSP_BIT32(0)
134
135
136 /*-----------------TMS570_PMM_PDCLKDISCLRREG-----------------*/
137 /* field: PDCLK_DISCLR_3 - PDCLK_DISCLR[3] */
138 #define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_3 BSP_BIT32(3)
139
140 /* field: PDCLK_DISCLR_2 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[2]. */
141 #define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_2 BSP_BIT32(2)
142
143 /* field: PDCLK_DISCLR_1 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[1]. */
144 #define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_1 BSP_BIT32(1)
145
146 /* field: PDCLK_DISCLR_0 - Read in User and Privileged Mode returns the current value of PDCLK_DIS[0]. */
147 #define TMS570_PMM_PDCLKDISCLRREG_PDCLK_DISCLR_0 BSP_BIT32(0)
148
149
150 /*-----------------TMS570_PMM_LOGICPDPWRSTAT-----------------*/
151 /* field: LOGIC_IN_TRANS0 - Logic in transition status for power domain PD2. */
152 #define TMS570_PMM_LOGICPDPWRSTAT_LOGIC_IN_TRANS0 BSP_BIT32(24)
153
154 /* field: MEM_IN_TRANS0 - Memory in transition status for power domain PD2. */
155 #define TMS570_PMM_LOGICPDPWRSTAT_MEM_IN_TRANS0 BSP_BIT32(16)
156
157 /* field: DOMAIN_ON0 - Current state of power domain PD2. */
158 #define TMS570_PMM_LOGICPDPWRSTAT_DOMAIN_ON0 BSP_BIT32(8)
159
160 /* field: LOGICPDPWR_STAT0 - Logic power domain PD2 power state. */
161 #define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0(val) BSP_FLD32(val,0, 1)
162 #define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0_GET(reg) BSP_FLD32GET(reg,0, 1)
163 #define TMS570_PMM_LOGICPDPWRSTAT_LOGICPDPWR_STAT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
164
165
166 /*------------------TMS570_PMM_MEMPDPWRSTAT------------------*/
167 /* field: LOGIC_IN_TRANS0 - Logic in transition status for power domain RAM_PD1. */
168 #define TMS570_PMM_MEMPDPWRSTAT_LOGIC_IN_TRANS0 BSP_BIT32(24)
169
170 /* field: MEM_IN_TRANS0 - Memory in transition status for power domain RAM_PD1. */
171 #define TMS570_PMM_MEMPDPWRSTAT_MEM_IN_TRANS0 BSP_BIT32(16)
172
173 /* field: DOMAIN_ON0 - Current state of power domain RAM_PD1. */
174 #define TMS570_PMM_MEMPDPWRSTAT_DOMAIN_ON0 BSP_BIT32(8)
175
176 /* field: MEMPDPWR_STAT0 - Memory power domain RAM_PD1 power state. */
177 #define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0(val) BSP_FLD32(val,0, 1)
178 #define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0_GET(reg) BSP_FLD32GET(reg,0, 1)
179 #define TMS570_PMM_MEMPDPWRSTAT_MEMPDPWR_STAT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
180
181
182 /*-------------------TMS570_PMM_GLOBALCTRL1-------------------*/
183 /* field: PMCTRL_PWRDN - PMC/PSCON Power Down */
184 #define TMS570_PMM_GLOBALCTRL1_PMCTRL_PWRDN BSP_BIT32(8)
185
186 /* field: AUTO_CLK_WAKE_ENA - Automatic Clock Enable on Wake Up */
187 #define TMS570_PMM_GLOBALCTRL1_AUTO_CLK_WAKE_ENA BSP_BIT32(0)
188
189
190 /*-------------------TMS570_PMM_GLOBALSTAT-------------------*/
191 /* field: PMCTRL_IDLE - State of PMC and all PSCONs. */
192 #define TMS570_PMM_GLOBALSTAT_PMCTRL_IDLE BSP_BIT32(0)
193
194
195 /*--------------------TMS570_PMM_PRCKEYREG--------------------*/
196 /* field: MKEY - Diagnostic PSCON Mode Key. The mode key is applied to all individual PSCON compare units. */
197 #define TMS570_PMM_PRCKEYREG_MKEY(val) BSP_FLD32(val,0, 3)
198 #define TMS570_PMM_PRCKEYREG_MKEY_GET(reg) BSP_FLD32GET(reg,0, 3)
199 #define TMS570_PMM_PRCKEYREG_MKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
200
201
202 /*-------------------TMS570_PMM_LPDDCSTAT1-------------------*/
203 /* field: LCMPE - Logic Power Domain Compare Error */
204 #define TMS570_PMM_LPDDCSTAT1_LCMPE(val) BSP_FLD32(val,16, 19)
205 #define TMS570_PMM_LPDDCSTAT1_LCMPE_GET(reg) BSP_FLD32GET(reg,16, 19)
206 #define TMS570_PMM_LPDDCSTAT1_LCMPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
207
208 /* field: LSTC - Logic Power Domain Self-test Complete */
209 #define TMS570_PMM_LPDDCSTAT1_LSTC(val) BSP_FLD32(val,0, 3)
210 #define TMS570_PMM_LPDDCSTAT1_LSTC_GET(reg) BSP_FLD32GET(reg,0, 3)
211 #define TMS570_PMM_LPDDCSTAT1_LSTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
212
213
214 /*-------------------TMS570_PMM_LPDDCSTAT2-------------------*/
215 /* field: LSTET - Logic Power Domain Self-test Error Type */
216 #define TMS570_PMM_LPDDCSTAT2_LSTET(val) BSP_FLD32(val,16, 19)
217 #define TMS570_PMM_LPDDCSTAT2_LSTET_GET(reg) BSP_FLD32GET(reg,16, 19)
218 #define TMS570_PMM_LPDDCSTAT2_LSTET_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
219
220 /* field: LSTE - Logic Power Domain Self-test Error */
221 #define TMS570_PMM_LPDDCSTAT2_LSTE(val) BSP_FLD32(val,0, 3)
222 #define TMS570_PMM_LPDDCSTAT2_LSTE_GET(reg) BSP_FLD32GET(reg,0, 3)
223 #define TMS570_PMM_LPDDCSTAT2_LSTE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
224
225
226 /*-------------------TMS570_PMM_MPDDCSTAT1-------------------*/
227 /* field: MCMPE - Memory Power Domain Compare Error */
228 #define TMS570_PMM_MPDDCSTAT1_MCMPE(val) BSP_FLD32(val,16, 18)
229 #define TMS570_PMM_MPDDCSTAT1_MCMPE_GET(reg) BSP_FLD32GET(reg,16, 18)
230 #define TMS570_PMM_MPDDCSTAT1_MCMPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
231
232 /* field: MSTC - Memory Power Domain Self-test Complete */
233 #define TMS570_PMM_MPDDCSTAT1_MSTC(val) BSP_FLD32(val,0, 2)
234 #define TMS570_PMM_MPDDCSTAT1_MSTC_GET(reg) BSP_FLD32GET(reg,0, 2)
235 #define TMS570_PMM_MPDDCSTAT1_MSTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
236
237
238 /*-------------------TMS570_PMM_MPDDCSTAT2-------------------*/
239 /* field: MSTET - Memory Power Domain Self-test Error Type */
240 #define TMS570_PMM_MPDDCSTAT2_MSTET(val) BSP_FLD32(val,16, 18)
241 #define TMS570_PMM_MPDDCSTAT2_MSTET_GET(reg) BSP_FLD32GET(reg,16, 18)
242 #define TMS570_PMM_MPDDCSTAT2_MSTET_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
243
244 /* field: MSTE - Memory Power Domain Self-test Error */
245 #define TMS570_PMM_MPDDCSTAT2_MSTE(val) BSP_FLD32(val,0, 2)
246 #define TMS570_PMM_MPDDCSTAT2_MSTE_GET(reg) BSP_FLD32GET(reg,0, 2)
247 #define TMS570_PMM_MPDDCSTAT2_MSTE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
248
249
250 /*-------------------TMS570_PMM_ISODIAGSTAT-------------------*/
251 /* field: ISO_DIAG - Isolation Diagnostic */
252 #define TMS570_PMM_ISODIAGSTAT_ISO_DIAG(val) BSP_FLD32(val,0, 3)
253 #define TMS570_PMM_ISODIAGSTAT_ISO_DIAG_GET(reg) BSP_FLD32GET(reg,0, 3)
254 #define TMS570_PMM_ISODIAGSTAT_ISO_DIAG_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
255
256
257
258 #endif /* LIBBSP_ARM_TMS570_PMM */
Definition: reg_pmm.h:44
Utility macros.
