RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
tms570
include
bsp
ti_herc
reg_pll.h
1
/* The header file is generated by make_header.py from PLL.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_PLL
40
#define LIBBSP_ARM_TMS570_PLL
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t PLLCTL3;
/*PLL Control 3 Register*/
46
uint8_t reserved1 [108];
47
uint32_t CLKSLIP;
/*PLL Clock Slip Control Register*/
48
uint8_t reserved2 [7600];
49
uint32_t SSWPLL1;
/*PLL Modulation Depth Measurement Control Register*/
50
uint32_t SSWPLL2;
/*SSW PLL BIST Control Register 2*/
51
uint32_t SSWPLL3;
/*SSW PLL BIST Control Register 3*/
52
uint32_t CSDIS;
/*Clock Source Disable Register*/
53
uint32_t CSDISSET;
/*Clock Source Disable Set Register*/
54
uint32_t CSDISCLR;
/*Clock Source Disable Clear Register*/
55
uint8_t reserved3 [24];
56
uint32_t CSVSTAT;
/*Clock Source Valid Status Register*/
57
uint8_t reserved4 [24];
58
uint32_t PLLCTL1;
/*PLL Control 1 Register*/
59
uint32_t PLLCTL2;
/*PLL Control 2 Register*/
60
uint8_t reserved5 [16];
61
uint32_t LPOMONCTL;
/*LPO/Clock Monitor Control Register*/
62
uint32_t CLKTEST;
/*Clock Test Register*/
63
uint8_t reserved6 [16];
64
uint32_t GPREG1;
/*General Purpose Register*/
65
uint8_t reserved7 [72];
66
uint32_t GLBSTAT;
/*Global Status Register*/
67
tms570_pll_t
68
69
70
/*---------------------TMS570_PLL_PLLCTL3---------------------*/
71
/* field: ODPLL2 - Internal PLL Output Divider */
72
#define TMS570_PLL_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31)
73
#define TMS570_PLL_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31)
74
#define TMS570_PLL_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
75
76
/* field: PLLDIV2 - PLL2 Output Clock Divider */
77
#define TMS570_PLL_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28)
78
#define TMS570_PLL_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28)
79
#define TMS570_PLL_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
80
81
/* field: REFCLKDIV2 - Reference Clock Divider */
82
#define TMS570_PLL_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21)
83
#define TMS570_PLL_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21)
84
#define TMS570_PLL_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
85
86
/* field: PLLMUL2 - PLL2 Multiplication Factor */
87
#define TMS570_PLL_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15)
88
#define TMS570_PLL_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15)
89
#define TMS570_PLL_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
90
91
92
/*---------------------TMS570_PLL_CLKSLIP---------------------*/
93
/* field: PLL1_SLIP_FILTER_COUNT - Configure the count for the filtered PLL slip. Count is on 10M clock. */
94
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13)
95
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13)
96
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
97
98
/* field: PLL1_SLIP_FILTER_KEY - Enable the PLL filtering. */
99
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3)
100
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
101
#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
102
103
104
/*---------------------TMS570_PLL_SSWPLL1---------------------*/
105
/* field: CAPTURE_WINDOW_INDEX - The capture counter present in the PLL wrapper will count the PLL clock edges when */
106
#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX(val) BSP_FLD32(val,8, 15)
107
#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_GET(reg) BSP_FLD32GET(reg,8, 15)
108
#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
109
110
/* field: COUNTER_READ_READY - Counter read ready. */
111
#define TMS570_PLL_SSWPLL1_COUNTER_READ_READY BSP_BIT32(6)
112
113
/* field: COUNTER_RESET - Counter reset. */
114
#define TMS570_PLL_SSWPLL1_COUNTER_RESET BSP_BIT32(5)
115
116
/* field: COUNTER_EN - Counter enable. */
117
#define TMS570_PLL_SSWPLL1_COUNTER_EN BSP_BIT32(4)
118
119
/* field: TAP_COUNTER_DIS - The value in this register is used to program a particular bit in CLKOUT counter. */
120
#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS(val) BSP_FLD32(val,1, 3)
121
#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_GET(reg) BSP_FLD32GET(reg,1, 3)
122
#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_SET(reg,val) BSP_FLD32SET(reg, val,1, 3)
123
124
/* field: EXT_COUNTER_EN - Modulation Depth Measurement mode */
125
#define TMS570_PLL_SSWPLL1_EXT_COUNTER_EN BSP_BIT32(0)
126
127
128
/*---------------------TMS570_PLL_SSWPLL2---------------------*/
129
/* field: SSW_CAPTURE_COUNT - Capture count. This register returns the value of the capture count. */
130
/* Whole 32 bits */
131
132
/*---------------------TMS570_PLL_SSWPLL3---------------------*/
133
/* field: SSW_CAPTURE_COUNT - Value of CLKout count register. */
134
/* Whole 32 bits */
135
136
/*----------------------TMS570_PLL_CSDIS----------------------*/
137
/* field: CLKSR_7_3_OFF - Clock source[7-3] off. */
138
#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
139
#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
140
#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
141
142
/* field: CLKSR_1_0_OFF - Clock source[1-0] off. */
143
#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
144
#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
145
#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
146
147
148
/*--------------------TMS570_PLL_CSDISSET--------------------*/
149
/* field: SETCLKSR_7_3_OFF - Set clock source[7-3] to the disabled state. */
150
#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
151
#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
152
#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
153
154
/* field: SETCLKSR_1_0_OFF - Set clock source[1-0] to the disabled state. */
155
#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
156
#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
157
#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
158
159
160
/*--------------------TMS570_PLL_CSDISCLR--------------------*/
161
/* field: CLRCLKSR_7_3_OFF - Enables clock source[7-3]. */
162
#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
163
#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
164
#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
165
166
/* field: CLRCLKSR_1_0_OFF - Enables clock source[1-0]. */
167
#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
168
#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
169
#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
170
171
172
/*---------------------TMS570_PLL_CSVSTAT---------------------*/
173
/* field: CLKSR_7_3V - Clock source[7-0] valid. */
174
#define TMS570_PLL_CSVSTAT_CLKSR_7_3V(val) BSP_FLD32(val,3, 7)
175
#define TMS570_PLL_CSVSTAT_CLKSR_7_3V_GET(reg) BSP_FLD32GET(reg,3, 7)
176
#define TMS570_PLL_CSVSTAT_CLKSR_7_3V_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
177
178
/* field: CLKSR_1_0V - Clock source[1-0] valid. */
179
#define TMS570_PLL_CSVSTAT_CLKSR_1_0V(val) BSP_FLD32(val,0, 1)
180
#define TMS570_PLL_CSVSTAT_CLKSR_1_0V_GET(reg) BSP_FLD32GET(reg,0, 1)
181
#define TMS570_PLL_CSVSTAT_CLKSR_1_0V_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
182
183
184
/*---------------------TMS570_PLL_PLLCTL1---------------------*/
185
/* field: ROS - Reset on PLL Slip */
186
#define TMS570_PLL_PLLCTL1_ROS BSP_BIT32(31)
187
188
/* field: MASK_SLIP - Mask detection of PLL slip */
189
#define TMS570_PLL_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30)
190
#define TMS570_PLL_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30)
191
#define TMS570_PLL_PLLCTL1_MASK_SLIP_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
192
193
/* field: PLLDIV - PLL Output Clock Divider */
194
#define TMS570_PLL_PLLCTL1_PLLDIV(val) BSP_FLD32(val,24, 28)
195
#define TMS570_PLL_PLLCTL1_PLLDIV_GET(reg) BSP_FLD32GET(reg,24, 28)
196
#define TMS570_PLL_PLLCTL1_PLLDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
197
198
/* field: ROF - Reset on Oscillator Fail */
199
#define TMS570_PLL_PLLCTL1_ROF BSP_BIT32(23)
200
201
/* field: REFCLKDIV - Reference Clock Divider */
202
#define TMS570_PLL_PLLCTL1_REFCLKDIV(val) BSP_FLD32(val,16, 21)
203
#define TMS570_PLL_PLLCTL1_REFCLKDIV_GET(reg) BSP_FLD32GET(reg,16, 21)
204
#define TMS570_PLL_PLLCTL1_REFCLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
205
206
/* field: PLLMUL - PLL Multiplication Factor */
207
#define TMS570_PLL_PLLCTL1_PLLMUL(val) BSP_FLD32(val,0, 15)
208
#define TMS570_PLL_PLLCTL1_PLLMUL_GET(reg) BSP_FLD32GET(reg,0, 15)
209
#define TMS570_PLL_PLLCTL1_PLLMUL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
210
211
212
/*---------------------TMS570_PLL_PLLCTL2---------------------*/
213
/* field: FMENA - Frequency Modulation Enable. */
214
#define TMS570_PLL_PLLCTL2_FMENA BSP_BIT32(31)
215
216
/* field: SPREADINGRATE - NS = SPREADINGRATE + 1 */
217
#define TMS570_PLL_PLLCTL2_SPREADINGRATE(val) BSP_FLD32(val,22, 30)
218
#define TMS570_PLL_PLLCTL2_SPREADINGRATE_GET(reg) BSP_FLD32GET(reg,22, 30)
219
#define TMS570_PLL_PLLCTL2_SPREADINGRATE_SET(reg,val) BSP_FLD32SET(reg, val,22, 30)
220
221
/* field: MULMOD - Multiplier Correction when Frequency Modulation is enabled. */
222
#define TMS570_PLL_PLLCTL2_MULMOD(val) BSP_FLD32(val,12, 20)
223
#define TMS570_PLL_PLLCTL2_MULMOD_GET(reg) BSP_FLD32GET(reg,12, 20)
224
#define TMS570_PLL_PLLCTL2_MULMOD_SET(reg,val) BSP_FLD32SET(reg, val,12, 20)
225
226
/* field: ODPLL - Internal PLL Output Divider. */
227
#define TMS570_PLL_PLLCTL2_ODPLL(val) BSP_FLD32(val,9, 11)
228
#define TMS570_PLL_PLLCTL2_ODPLL_GET(reg) BSP_FLD32GET(reg,9, 11)
229
#define TMS570_PLL_PLLCTL2_ODPLL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
230
231
/* field: SPR_AMOUNT - Spreading Amount. */
232
#define TMS570_PLL_PLLCTL2_SPR_AMOUNT(val) BSP_FLD32(val,0, 8)
233
#define TMS570_PLL_PLLCTL2_SPR_AMOUNT_GET(reg) BSP_FLD32GET(reg,0, 8)
234
#define TMS570_PLL_PLLCTL2_SPR_AMOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
235
236
237
/*--------------------TMS570_PLL_LPOMONCTL--------------------*/
238
/* field: BIAS_ENABLE - Bias enable. */
239
#define TMS570_PLL_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24)
240
241
/* field: OSCFRQCONFIGCNT - Configures the counter based on OSC frequency. */
242
#define TMS570_PLL_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16)
243
244
/* field: HFTRIM - High frequency oscillator trim value. */
245
#define TMS570_PLL_LPOMONCTL_HFTRIM(val) BSP_FLD32(val,8, 12)
246
#define TMS570_PLL_LPOMONCTL_HFTRIM_GET(reg) BSP_FLD32GET(reg,8, 12)
247
#define TMS570_PLL_LPOMONCTL_HFTRIM_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
248
249
250
/*---------------------TMS570_PLL_CLKTEST---------------------*/
251
/* field: ALTLIMPCLOCKENABLE - This bit selects a clock driven by the GIOB[0] pin as an alternate limp clock to the clock */
252
#define TMS570_PLL_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26)
253
254
/* field: RANGEDETCTRL - Range detection control. */
255
#define TMS570_PLL_CLKTEST_RANGEDETCTRL BSP_BIT32(25)
256
257
/* field: RANGEDETENASSEL - Selects range detection enable. This bit resets asynchronously on power on reset. */
258
#define TMS570_PLL_CLKTEST_RANGEDETENASSEL BSP_BIT32(24)
259
260
/* field: CLK_TEST_EN - Clock test enable. This bit enables the clock going to the ECLK pin. */
261
#define TMS570_PLL_CLKTEST_CLK_TEST_EN(val) BSP_FLD32(val,16, 19)
262
#define TMS570_PLL_CLKTEST_CLK_TEST_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
263
#define TMS570_PLL_CLKTEST_CLK_TEST_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
264
265
266
/*---------------------TMS570_PLL_GPREG1---------------------*/
267
/* field: EMIF_FUNC - Enable EMIF functions to be output. */
268
#define TMS570_PLL_GPREG1_EMIF_FUNC BSP_BIT32(31)
269
270
/* field: PLL1_FBSLIP_FILTER__COUNT - FBSLIP down counter programmed value. */
271
#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) BSP_FLD32(val,20, 25)
272
#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) BSP_FLD32GET(reg,20, 25)
273
#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
274
275
/* field: PLL1_RFSLIP_FILTER__KEY - Configures the system response when a FBSLIP is indicated by the */
276
#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) BSP_FLD32(val,16, 19)
277
#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
278
#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
279
280
/* field: OUTPUT_BUFFER_LOW_EMI_MODE - Control field for the low-EMI mode of output buffers for */
281
#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) BSP_FLD32(val,0, 15)
282
#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) BSP_FLD32GET(reg,0, 15)
283
#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
284
285
286
/*---------------------TMS570_PLL_GLBSTAT---------------------*/
287
/* field: FBSLIP - PLL over cycle slip detection. */
288
#define TMS570_PLL_GLBSTAT_FBSLIP BSP_BIT32(9)
289
290
/* field: RFSLIP - PLL under cycle slip detection. */
291
#define TMS570_PLL_GLBSTAT_RFSLIP BSP_BIT32(8)
292
293
/* field: OSCFAIL - Oscillator fail flag bit. */
294
#define TMS570_PLL_GLBSTAT_OSCFAIL BSP_BIT32(0)
295
296
297
298
#endif
/* LIBBSP_ARM_TMS570_PLL */
utility.h
Utility macros.
tms570_pll_t
Definition:
reg_pll.h:44
