RTEMS  5.1
reg_pbist.h
1 /* The header file is generated by make_header.py from PBIST.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_PBIST
40 #define LIBBSP_ARM_TMS570_PBIST
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t DNW[88]; /*Reserved DO NOT WRITE*/
46  uint32_t RAMT; /*RAM Configuration Register*/
47  uint32_t DLR; /*Datalogger Register*/
48  uint8_t reserved1 [24];
49  uint32_t PACT; /*PBIST Activate/ROM Clock Enable Register*/
50  uint32_t PBISTID; /*PBIST ID Register*/
51  uint32_t OVER; /*Override Register*/
52  uint8_t reserved2 [4];
53  uint32_t FSRF0; /*Fail Status Fail Register 0*/
54  uint8_t reserved3 [4];
55  uint32_t FSRC0; /*Fail Status Count Register 0*/
56  uint32_t FSRC1; /*Fail Status Count Register 1*/
57  uint32_t FSRA0; /*Fail Status Address 0 Register*/
58  uint32_t FSRA1; /*Fail Status Address 1 Register*/
59  uint32_t FSRDL0; /*Fail Status Data Register 0*/
60  uint8_t reserved4 [4];
61  uint32_t FSRDL1; /*Fail Status Data Register 1*/
62  uint8_t reserved5 [12];
63  uint32_t ROM; /*ROM Mask Register*/
64  uint32_t ALGO; /*ROM Algorithm Mask Register*/
65  uint32_t RINFOL; /*RAM Info Mask Lower Register*/
66  uint32_t RINFOUL; /*RAM Info Mask Lower Register*/
68
69
70 /*----------------------TMS570_PBIST_DNW----------------------*/
71 /* field: Reserved - Do not write */
72 /* Whole 32 bits */
73
74 /*---------------------TMS570_PBIST_RAMT---------------------*/
75 /* field: RGS - Ram Group Select. Refer Table 2-5 for information on the RGS value for each memory. */
76 #define TMS570_PBIST_RAMT_RGS(val) BSP_FLD32(val,24, 31)
77 #define TMS570_PBIST_RAMT_RGS_GET(reg) BSP_FLD32GET(reg,24, 31)
78 #define TMS570_PBIST_RAMT_RGS_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
79
80 /* field: RDS - Return Data Select. Refer Table 2-5 for information on the RDS values for each memory. */
81 #define TMS570_PBIST_RAMT_RDS(val) BSP_FLD32(val,16, 23)
82 #define TMS570_PBIST_RAMT_RDS_GET(reg) BSP_FLD32GET(reg,16, 23)
83 #define TMS570_PBIST_RAMT_RDS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
84
85 /* field: DWR - Data Width Register */
86 #define TMS570_PBIST_RAMT_DWR(val) BSP_FLD32(val,8, 15)
87 #define TMS570_PBIST_RAMT_DWR_GET(reg) BSP_FLD32GET(reg,8, 15)
88 #define TMS570_PBIST_RAMT_DWR_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
89
90 /* field: SMS - Sense Margin Select Register */
91 #define TMS570_PBIST_RAMT_SMS(val) BSP_FLD32(val,6, 7)
92 #define TMS570_PBIST_RAMT_SMS_GET(reg) BSP_FLD32GET(reg,6, 7)
93 #define TMS570_PBIST_RAMT_SMS_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
94
95 /* field: PLS - Pipeline Latency Select */
96 #define TMS570_PBIST_RAMT_PLS(val) BSP_FLD32(val,2, 5)
97 #define TMS570_PBIST_RAMT_PLS_GET(reg) BSP_FLD32GET(reg,2, 5)
98 #define TMS570_PBIST_RAMT_PLS_SET(reg,val) BSP_FLD32SET(reg, val,2, 5)
99
100 /* field: RLS - RAM Latency Select */
101 #define TMS570_PBIST_RAMT_RLS(val) BSP_FLD32(val,0, 1)
102 #define TMS570_PBIST_RAMT_RLS_GET(reg) BSP_FLD32GET(reg,0, 1)
103 #define TMS570_PBIST_RAMT_RLS_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
104
105
106 /*----------------------TMS570_PBIST_DLR----------------------*/
107 /* field: DLR4 - Config access: setting this bit allows the host processor to configure the PBIST controller registers */
108 #define TMS570_PBIST_DLR_DLR4 BSP_BIT32(4)
109
110 /* field: DLR2 - ROM-based testing: setting this bit enables the PBIST controller to execute test algorithms that are */
111 #define TMS570_PBIST_DLR_DLR2 BSP_BIT32(2)
112
113
114 /*---------------------TMS570_PBIST_PACT---------------------*/
115 /* field: PACT1 - PBIST Activate */
116 #define TMS570_PBIST_PACT_PACT1 BSP_BIT32(1)
117
118 /* field: PACT0 - ROM Clock Enable Register */
119 #define TMS570_PBIST_PACT_PACT0 BSP_BIT32(0)
120
121
122 /*--------------------TMS570_PBIST_PBISTID--------------------*/
123 /* field: PBIST_ID - This is a unique ID assigned to each PBIST controller in a device with multiple PBIST controllers. */
124 #define TMS570_PBIST_PBISTID_PBIST_ID(val) BSP_FLD32(val,0, 7)
125 #define TMS570_PBIST_PBISTID_PBIST_ID_GET(reg) BSP_FLD32GET(reg,0, 7)
126 #define TMS570_PBIST_PBISTID_PBIST_ID_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
127
128
129 /*---------------------TMS570_PBIST_OVER---------------------*/
130 /* field: OVER0 - RINFO Override Bit */
131 #define TMS570_PBIST_OVER_OVER0 BSP_BIT32(0)
132
133
134 /*---------------------TMS570_PBIST_FSRF0---------------------*/
135 /* field: FSRF0 - Fail Status 0. */
136 #define TMS570_PBIST_FSRF0_FSRF0 BSP_BIT32(0)
137
138
139 /*---------------------TMS570_PBIST_FSRC0---------------------*/
140 /* field: FSRC0 - Fail Status Count 0. Indicates the number of failures on port 0. */
141 #define TMS570_PBIST_FSRC0_FSRC0(val) BSP_FLD32(val,0, 7)
142 #define TMS570_PBIST_FSRC0_FSRC0_GET(reg) BSP_FLD32GET(reg,0, 7)
143 #define TMS570_PBIST_FSRC0_FSRC0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
144
145
146 /*---------------------TMS570_PBIST_FSRC1---------------------*/
147 /* field: FSRC1 - Fail Status Count 1. Indicates the number of failures on port 1. */
148 #define TMS570_PBIST_FSRC1_FSRC1(val) BSP_FLD32(val,0, 7)
149 #define TMS570_PBIST_FSRC1_FSRC1_GET(reg) BSP_FLD32GET(reg,0, 7)
150 #define TMS570_PBIST_FSRC1_FSRC1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
151
152
153 /*---------------------TMS570_PBIST_FSRA0---------------------*/
154 /* field: FSRA0 - Fail Status Address 0. Contains the address of the first failure. */
155 #define TMS570_PBIST_FSRA0_FSRA0(val) BSP_FLD32(val,0, 15)
156 #define TMS570_PBIST_FSRA0_FSRA0_GET(reg) BSP_FLD32GET(reg,0, 15)
157 #define TMS570_PBIST_FSRA0_FSRA0_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
158
159
160 /*---------------------TMS570_PBIST_FSRA1---------------------*/
161 /* field: FSRA1 - Fail Status Address 1. Contains the address of the first failure. */
162 #define TMS570_PBIST_FSRA1_FSRA1(val) BSP_FLD32(val,0, 15)
163 #define TMS570_PBIST_FSRA1_FSRA1_GET(reg) BSP_FLD32GET(reg,0, 15)
164 #define TMS570_PBIST_FSRA1_FSRA1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
165
166
167 /*--------------------TMS570_PBIST_FSRDL0--------------------*/
168 /* field: FSRDL1 - Failure data on port 1 */
169 /* Whole 32 bits */
170
171 /*--------------------TMS570_PBIST_FSRDL1--------------------*/
172 /* field: FSRDL1 - Failure data on port 1 */
173 /* Whole 32 bits */
174
175 /*----------------------TMS570_PBIST_ROM----------------------*/
176 /* field: ROM - ROM Mask */
177 #define TMS570_PBIST_ROM_ROM(val) BSP_FLD32(val,0, 1)
178 #define TMS570_PBIST_ROM_ROM_GET(reg) BSP_FLD32GET(reg,0, 1)
179 #define TMS570_PBIST_ROM_ROM_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
180
181
182 /*---------------------TMS570_PBIST_ALGO---------------------*/
183 /* field: ROM_ALG_MASK - Each bit corresponds to a specific algorithm */
184 /* Whole 32 bits */
185
186 /*--------------------TMS570_PBIST_RINFOL--------------------*/
187 /* field: RAM_ALG_MASK_LOW - Each bit corresponds to a specific algorithm */
188 /* Whole 32 bits */
189
190 /*--------------------TMS570_PBIST_RINFOUL--------------------*/
191 /* field: RAM_ALG_MASK_UP - Each bit corresponds to a specific algorithm */
192 /* Whole 32 bits */
193
194
195 #endif /* LIBBSP_ARM_TMS570_PBIST */
Utility macros.
Definition: reg_pbist.h:44
