RTEMS  5.1
reg_n2het.h
1 /* The header file is generated by make_header.py from N2HET.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_NHET
40 #define LIBBSP_ARM_TMS570_NHET
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t GCR; /*Global Configuration Register*/
46  uint32_t PFR; /*Prescale Factor Register*/
47  uint32_t ADDR; /*NHET Current Address Register*/
48  uint32_t OFF1; /*Offset Index Priority Level 1 Register*/
49  uint32_t OFF2; /*Offset Index Priority Level 2 Register*/
50  uint32_t INTENAS; /*Interrupt Enable Set Register*/
51  uint32_t INTENAC; /*Interrupt Enable Clear Register*/
52  uint32_t EXC1; /*Exception Control Register 1*/
53  uint32_t EXC2; /*Exception Control Register 2*/
54  uint32_t PRY; /*Interrupt Priority Register*/
55  uint32_t FLG; /*Interrupt Flag Register*/
56  uint32_t AND; /*AND Share Control Register*/
57  uint8_t reserved1 [4];
58  uint32_t HRSH; /*HR Share Control Register*/
59  uint32_t XOR; /*HR XOR-Share Control Register*/
60  uint32_t REQENS; /*Request Enable Set Register*/
61  uint32_t REQENC; /*Request Enable Clear Register*/
62  uint32_t REQDS; /*Request Destination Select Register*/
63  uint8_t reserved2 [4];
64  uint32_t DIR; /*NHET Direction Register*/
65  uint32_t DIN; /*NHET Data Input Register*/
66  uint32_t DOUT; /*NHET Data Output Register*/
67  uint32_t DSET; /*NHET Data Set Register*/
68  uint32_t DCLR; /*NHET Data Clear Register*/
69  uint32_t PDR; /*NHET Open Drain Register*/
70  uint32_t PULDIS; /*NHET Pull Disable Register*/
71  uint32_t PSL; /*NHET Pull Select Register*/
72  uint8_t reserved3 [8];
73  uint32_t PCR; /*Parity Control Register*/
74  uint32_t PAR; /*Parity Address Register*/
75  uint32_t PPR; /*Parity Pin Register*/
76  uint32_t SFPRLD; /*Suppression Filter Preload Register*/
77  uint32_t SFENA; /*Suppression Filter Enable Register*/
78  uint8_t reserved4 [4];
79  uint32_t LBPSEL; /*Loop Back Pair Select Register*/
80  uint32_t LBPDIR; /*Loop Back Pair Direction Register*/
81  uint32_t PINDIS; /*NHET Pin Disable Register*/
83
84
85 /*----------------------TMS570_NHET_GCR----------------------*/
86 /* field: HET_PIN_ENA - Enables the output buffers of the pin structures depending on the value of nDIS and DIR. */
87 #define TMS570_NHET_GCR_HET_PIN_ENA BSP_BIT32(24)
88
89 /* field: MP - Master Priority */
90 #define TMS570_NHET_GCR_MP(val) BSP_FLD32(val,21, 22)
91 #define TMS570_NHET_GCR_MP_GET(reg) BSP_FLD32GET(reg,21, 22)
92 #define TMS570_NHET_GCR_MP_SET(reg,val) BSP_FLD32SET(reg, val,21, 22)
93
94 /* field: PPF - Protect Program Fields */
95 #define TMS570_NHET_GCR_PPF BSP_BIT32(18)
96
97 /* field: IS - Ignore Suspend */
98 #define TMS570_NHET_GCR_IS BSP_BIT32(17)
99
100 /* field: CMS - Clk_master/slave */
101 #define TMS570_NHET_GCR_CMS BSP_BIT32(16)
102
103
104 /*----------------------TMS570_NHET_PFR----------------------*/
105 /* field: LRPFC - oop Resolution Pre-scale Factor Code */
106 #define TMS570_NHET_PFR_LRPFC(val) BSP_FLD32(val,8, 10)
107 #define TMS570_NHET_PFR_LRPFC_GET(reg) BSP_FLD32GET(reg,8, 10)
108 #define TMS570_NHET_PFR_LRPFC_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
109
110 /* field: HRPFC - High Resolution Pre-scale Factor Code */
111 #define TMS570_NHET_PFR_HRPFC(val) BSP_FLD32(val,0, 5)
112 #define TMS570_NHET_PFR_HRPFC_GET(reg) BSP_FLD32GET(reg,0, 5)
113 #define TMS570_NHET_PFR_HRPFC_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
114
115
116 /*----------------------TMS570_NHET_ADDR----------------------*/
117 /* field: HETADDR - N2HET Current Address */
118 #define TMS570_NHET_ADDR_HETADDR(val) BSP_FLD32(val,0, 8)
119 #define TMS570_NHET_ADDR_HETADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
120 #define TMS570_NHET_ADDR_HETADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
121
122
123 /*----------------------TMS570_NHET_OFF1----------------------*/
124 /* field: OFFSET1 - HETOFF1[5:0] indexes the currently pending high-priority interrupt. */
125 #define TMS570_NHET_OFF1_OFFSET1(val) BSP_FLD32(val,0, 5)
126 #define TMS570_NHET_OFF1_OFFSET1_GET(reg) BSP_FLD32GET(reg,0, 5)
127 #define TMS570_NHET_OFF1_OFFSET1_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
128
129
130 /*----------------------TMS570_NHET_OFF2----------------------*/
131 /* field: OFFSET2 - HETOFF2[5:0] indexes the currently pending low-priority interrupt. */
132 #define TMS570_NHET_OFF2_OFFSET2(val) BSP_FLD32(val,0, 5)
133 #define TMS570_NHET_OFF2_OFFSET2_GET(reg) BSP_FLD32GET(reg,0, 5)
134 #define TMS570_NHET_OFF2_OFFSET2_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
135
136
137 /*--------------------TMS570_NHET_INTENAS--------------------*/
138 /* field: HETINTENAS - Interrupt Enable Set bits. HETINTENAS is readable and writable in any operation mode. */
139 /* Whole 32 bits */
140
141 /*--------------------TMS570_NHET_INTENAC--------------------*/
142 /* field: HETINTENAC - Interrupt Enable Clear bits. HETINTENAC is readable and writable in any operation mode. */
143 /* Whole 32 bits */
144
145 /*----------------------TMS570_NHET_EXC1----------------------*/
146 /* field: APCNT_OVRFL_ENA - APCNT Overflow Enable */
147 #define TMS570_NHET_EXC1_APCNT_OVRFL_ENA BSP_BIT32(24)
148
149 /* field: APCNT_UNRFL_ENA - APCNT Underflow Enable */
150 #define TMS570_NHET_EXC1_APCNT_UNRFL_ENA BSP_BIT32(16)
151
152 /* field: PRGM_OVRFL_ENA - Program Overflow Enable */
153 #define TMS570_NHET_EXC1_PRGM_OVRFL_ENA BSP_BIT32(8)
154
155 /* field: APCNT_OVRFL_PRY - APCNT Overflow Exception Interrupt Priority */
156 #define TMS570_NHET_EXC1_APCNT_OVRFL_PRY BSP_BIT32(2)
157
158 /* field: APCNT_UNRFL_PRY - APCNT Underflow Exception Interrupt Priority */
159 #define TMS570_NHET_EXC1_APCNT_UNRFL_PRY BSP_BIT32(1)
160
161 /* field: PRGM_OVRFL_PRY - ProgramOverflow Exception Interrupt Priority */
162 #define TMS570_NHET_EXC1_PRGM_OVRFL_PRY BSP_BIT32(0)
163
164
165 /*----------------------TMS570_NHET_EXC2----------------------*/
166 /* field: DEBUG_STATUS_FLAG - Debug Status Flag. */
167 #define TMS570_NHET_EXC2_DEBUG_STATUS_FLAG BSP_BIT32(8)
168
169 /* field: APCNT_OVRFL_FLAG - APCNT Overflow Flag */
170 #define TMS570_NHET_EXC2_APCNT_OVRFL_FLAG BSP_BIT32(2)
171
172 /* field: APCNT_UNDFL_FLAG - APCNT Underflow Flag */
173 #define TMS570_NHET_EXC2_APCNT_UNDFL_FLAG BSP_BIT32(1)
174
175 /* field: PRGM_OVERFL_FLAG - Program Overflow Flag */
176 #define TMS570_NHET_EXC2_PRGM_OVERFL_FLAG BSP_BIT32(0)
177
178
179 /*----------------------TMS570_NHET_PRY----------------------*/
180 /* field: HETPRY - HET Interrupt Priority Level bits */
181 /* Whole 32 bits */
182
183 /*----------------------TMS570_NHET_FLG----------------------*/
184 /* field: HETFLAG - Interrupt Flag Register Bits */
185 /* Whole 32 bits */
186
187 /*----------------------TMS570_NHET_AND----------------------*/
188 /* field: AND_SHARE - AND Share Enable */
189 #define TMS570_NHET_AND_AND_SHARE(val) BSP_FLD32(val,0, 15)
190 #define TMS570_NHET_AND_AND_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
191 #define TMS570_NHET_AND_AND_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
192
193
194 /*----------------------TMS570_NHET_HRSH----------------------*/
195 /* field: HR_SHARE - HR Share Bits */
196 #define TMS570_NHET_HRSH_HR_SHARE(val) BSP_FLD32(val,0, 15)
197 #define TMS570_NHET_HRSH_HR_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
198 #define TMS570_NHET_HRSH_HR_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
199
200
201 /*----------------------TMS570_NHET_XOR----------------------*/
202 /* field: XOR_SHARE - XOR Share Enable */
203 #define TMS570_NHET_XOR_XOR_SHARE(val) BSP_FLD32(val,0, 15)
204 #define TMS570_NHET_XOR_XOR_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
205 #define TMS570_NHET_XOR_XOR_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
206
207
208 /*---------------------TMS570_NHET_REQENS---------------------*/
209 /* field: REQ_ENA_n - Request Enable Bits */
210 #define TMS570_NHET_REQENS_REQ_ENA_n(val) BSP_FLD32(val,0, 7)
211 #define TMS570_NHET_REQENS_REQ_ENA_n_GET(reg) BSP_FLD32GET(reg,0, 7)
212 #define TMS570_NHET_REQENS_REQ_ENA_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
213
214
215 /*---------------------TMS570_NHET_REQENC---------------------*/
216 /* field: REQ_DIS_n - Request Disable Bits */
217 #define TMS570_NHET_REQENC_REQ_DIS_n(val) BSP_FLD32(val,0, 7)
218 #define TMS570_NHET_REQENC_REQ_DIS_n_GET(reg) BSP_FLD32GET(reg,0, 7)
219 #define TMS570_NHET_REQENC_REQ_DIS_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
220
221
222 /*---------------------TMS570_NHET_REQDS---------------------*/
223 /* field: TDBS_n - HTU, DMA or Both Select Bits */
224 #define TMS570_NHET_REQDS_TDBS_n(val) BSP_FLD32(val,16, 23)
225 #define TMS570_NHET_REQDS_TDBS_n_GET(reg) BSP_FLD32GET(reg,16, 23)
226 #define TMS570_NHET_REQDS_TDBS_n_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
227
228 /* field: TDS_n - HTU or DMA Select Bits */
229 #define TMS570_NHET_REQDS_TDS_n(val) BSP_FLD32(val,0, 7)
230 #define TMS570_NHET_REQDS_TDS_n_GET(reg) BSP_FLD32GET(reg,0, 7)
231 #define TMS570_NHET_REQDS_TDS_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
232
233
234 /*----------------------TMS570_NHET_DIR----------------------*/
235 /* field: HETDIR_n - Data direction of NHET pins */
236 /* Whole 32 bits */
237
238 /*----------------------TMS570_NHET_DIN----------------------*/
239 /* field: HETDIN_n - Data input. This bit displays the logic state of the pin. */
240 /* Whole 32 bits */
241
242 /*----------------------TMS570_NHET_DOUT----------------------*/
243 /* field: HETDOUT_n - Data out write. Writes to this bit will only take effect when the pin is configured as an output. */
244 /* Whole 32 bits */
245
246 /*----------------------TMS570_NHET_DSET----------------------*/
247 /* field: HETDSET_n - This register allows bits of HETDOUT to be set while avoiding the pitfalls of a readmodify- write */
248 /* Whole 32 bits */
249
250 /*----------------------TMS570_NHET_DCLR----------------------*/
251 /* field: HETDCLR_n - This register allows bits of HETDOUT to be cleared while avoiding the pitfalls of a read-modifywrite */
252 /* Whole 32 bits */
253
254 /*----------------------TMS570_NHET_PDR----------------------*/
255 /* field: HETPDR_n - Open drain control for HET[n] pins */
256 /* Whole 32 bits */
257
258 /*---------------------TMS570_NHET_PULDIS---------------------*/
259 /* field: HETPULDIS_n - Pull disable for N2HET pins */
260 /* Whole 32 bits */
261
262 /*----------------------TMS570_NHET_PSL----------------------*/
263 /* field: HETPSL_n - Pull select for NHET pins */
264 /* Whole 32 bits */
265
266 /*----------------------TMS570_NHET_PCR----------------------*/
267 /* field: TEST - Test Bit. */
268 #define TMS570_NHET_PCR_TEST BSP_BIT32(8)
269
270 /* field: PARITY_ENA - Enable/disable parity checking. */
271 #define TMS570_NHET_PCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
272 #define TMS570_NHET_PCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
273 #define TMS570_NHET_PCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
274
275
276 /*----------------------TMS570_NHET_PAR----------------------*/
277 /* field: PAOFF - Parity Error Address Offset. */
278 #define TMS570_NHET_PAR_PAOFF(val) BSP_FLD32(val,2, 12)
279 #define TMS570_NHET_PAR_PAOFF_GET(reg) BSP_FLD32GET(reg,2, 12)
280 #define TMS570_NHET_PAR_PAOFF_SET(reg,val) BSP_FLD32SET(reg, val,2, 12)
281
282
283 /*----------------------TMS570_NHET_PPR----------------------*/
284 /* field: HETPPR_n - NHET Parity Pin Select Bits - Allows HET[n] pins to be configured to drive to a known state when */
285 /* Whole 32 bits */
286
287 /*---------------------TMS570_NHET_SFPRLD---------------------*/
288 /* field: CCDIV - Counter Clock Divider */
289 #define TMS570_NHET_SFPRLD_CCDIV(val) BSP_FLD32(val,16, 17)
290 #define TMS570_NHET_SFPRLD_CCDIV_GET(reg) BSP_FLD32GET(reg,16, 17)
291 #define TMS570_NHET_SFPRLD_CCDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
292
293 /* field: CPRLD - Counter Preload Value */
294 #define TMS570_NHET_SFPRLD_CPRLD(val) BSP_FLD32(val,0, 9)
295 #define TMS570_NHET_SFPRLD_CPRLD_GET(reg) BSP_FLD32GET(reg,0, 9)
296 #define TMS570_NHET_SFPRLD_CPRLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
297
298
299 /*---------------------TMS570_NHET_SFENA---------------------*/
300 /* field: HETSFENA_n - Suppression Filter Enable Bits */
301 /* Whole 32 bits */
302
303 /*---------------------TMS570_NHET_LBPSEL---------------------*/
304 /* field: LBPTYPE - Loop Back Pair Type Select Bits */
305 #define TMS570_NHET_LBPSEL_LBPTYPE(val) BSP_FLD32(val,16, 31)
306 #define TMS570_NHET_LBPSEL_LBPTYPE_GET(reg) BSP_FLD32GET(reg,16, 31)
307 #define TMS570_NHET_LBPSEL_LBPTYPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
308
309 /* field: LBPSEL - Loop Back Pair Select Bits */
310 #define TMS570_NHET_LBPSEL_LBPSEL(val) BSP_FLD32(val,0, 15)
311 #define TMS570_NHET_LBPSEL_LBPSEL_GET(reg) BSP_FLD32GET(reg,0, 15)
312 #define TMS570_NHET_LBPSEL_LBPSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
313
314
315 /*---------------------TMS570_NHET_LBPDIR---------------------*/
316 /* field: LBPTSTENA - Loopback Test Enable Key */
317 #define TMS570_NHET_LBPDIR_LBPTSTENA(val) BSP_FLD32(val,16, 19)
318 #define TMS570_NHET_LBPDIR_LBPTSTENA_GET(reg) BSP_FLD32GET(reg,16, 19)
319 #define TMS570_NHET_LBPDIR_LBPTSTENA_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
320
321 /* field: LBPDIR - Loop Back Pair Direction Bits */
322 #define TMS570_NHET_LBPDIR_LBPDIR(val) BSP_FLD32(val,0, 15)
323 #define TMS570_NHET_LBPDIR_LBPDIR_GET(reg) BSP_FLD32GET(reg,0, 15)
324 #define TMS570_NHET_LBPDIR_LBPDIR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
325
326
327 /*---------------------TMS570_NHET_PINDIS---------------------*/
328 /* field: HETPINDIS_n - N2HET Pin Disable Bits */
329 /* Whole 32 bits */
330
331
332 #endif /* LIBBSP_ARM_TMS570_NHET */
Definition: reg_n2het.h:44
Utility macros.
#define PAR
physical addr reg base for rd and wr
Definition: wd80x3.h:113
