RTEMS  5.1
reg_iomm.h
1 /* The header file is generated by make_header.py from IOMM.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_IOMM
40 #define LIBBSP_ARM_TMS570_IOMM
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t PINMMR0; /*Pin Multiplexing Control Register 0*/
46  uint32_t PINMMR1; /*Pin Multiplexing Control Register 1*/
47  uint32_t PINMMR2; /*Pin Multiplexing Control Register 2*/
48  uint32_t PINMMR3; /*Pin Multiplexing Control Register 3*/
49  uint32_t PINMMR4; /*Pin Multiplexing Control Register 4*/
50  uint32_t PINMMR5; /*Pin Multiplexing Control Register 5*/
51  uint32_t PINMMR6; /*Pin Multiplexing Control Register 6*/
52  uint32_t PINMMR7; /*Pin Multiplexing Control Register 7*/
53  uint32_t PINMMR8; /*Pin Multiplexing Control Register 8*/
54  uint32_t PINMMR9; /*Pin Multiplexing Control Register 9*/
55  uint32_t PINMMR10; /*Pin Multiplexing Control Register 10*/
56  uint32_t PINMMR11; /*Pin Multiplexing Control Register 11*/
57  uint32_t PINMMR12; /*Pin Multiplexing Control Register 12*/
58  uint32_t PINMMR13; /*Pin Multiplexing Control Register 13*/
59  uint32_t PINMMR14; /*Pin Multiplexing Control Register 14*/
60  uint32_t PINMMR15; /*Pin Multiplexing Control Register 15*/
61  uint32_t PINMMR16; /*Pin Multiplexing Control Register 16*/
62  uint32_t PINMMR17; /*Pin Multiplexing Control Register 17*/
63  uint32_t PINMMR18; /*Pin Multiplexing Control Register 18*/
64  uint32_t PINMMR19; /*Pin Multiplexing Control Register 19*/
65  uint32_t PINMMR20; /*Pin Multiplexing Control Register 20*/
66  uint32_t PINMMR21; /*Pin Multiplexing Control Register 21*/
67  uint32_t PINMMR22; /*Pin Multiplexing Control Register 22*/
68  uint32_t PINMMR23; /*Pin Multiplexing Control Register 23*/
69  uint32_t PINMMR24; /*Pin Multiplexing Control Register 24*/
70  uint32_t PINMMR25; /*Pin Multiplexing Control Register 25*/
71  uint32_t PINMMR26; /*Pin Multiplexing Control Register 26*/
72  uint32_t PINMMR27; /*Pin Multiplexing Control Register 27*/
73  uint32_t PINMMR28; /*Pin Multiplexing Control Register 28*/
74  uint32_t PINMMR29; /*Pin Multiplexing Control Register 29*/
75  uint32_t PINMMR30; /*Pin Multiplexing Control Register 30*/
77
78 typedef struct{
79  uint32_t REVISION_REG; /*Revision Register*/
80  uint8_t reserved1 [28];
81  uint32_t ENDIAN_REG; /*Device Endianness Register*/
82  uint8_t reserved2 [20];
83  uint32_t KICK_REG0; /*Kicker Register 0*/
84  uint32_t KICK_REG1; /*Kicker Register 1*/
85  uint8_t reserved3 [160];
86  uint32_t ERR_RAW_STATUS_REG;/*Error Raw Status / Set Register*/
87  uint32_t ERR_ENABLED_STATUS_REG;/*Error Enabled Status / Clear Register*/
88  uint32_t ERR_ENABLE_REG; /*Error Signaling Enable Register*/
89  uint32_t ERR_ENABLE_CLR_REG;/*Error Signaling Enable Clear Register*/
90  uint8_t reserved4 [4];
91  uint32_t FAULT_ADDRESS_REG; /*Fault Address Register*/
92  uint32_t FAULT_STATUS_REG; /*Fault Status Register*/
93  uint32_t FAULT_CLEAR_REG; /*Fault Clear Register*/
94  uint8_t reserved5 [16];
95  tms570_pinmux_t PINMUX; /*Pin Multiplexing Control Registers*/
97
98
99 /*--------------------TMS570_IOMM_PINMMRx--------------------*/
100 /* field: PINMMRx24To31 - Each of these byte-fields control the functionality on a given ball/pin. */
101 #define TMS570_IOMM_PINMMRx_PINMMRx24To31(val) BSP_FLD32(val,24, 31)
102 #define TMS570_IOMM_PINMMRx_PINMMRx24To31_GET(reg) BSP_FLD32GET(reg,24, 31)
103 #define TMS570_IOMM_PINMMRx_PINMMRx24To31_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
104
105 /* field: PINMMRx16To23 - Each of these byte-fields control the functionality on a given ball/pin. */
106 #define TMS570_IOMM_PINMMRx_PINMMRx16To23(val) BSP_FLD32(val,16, 23)
107 #define TMS570_IOMM_PINMMRx_PINMMRx16To23_GET(reg) BSP_FLD32GET(reg,16, 23)
108 #define TMS570_IOMM_PINMMRx_PINMMRx16To23_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
109
110 /* field: PINMMRx8To16 - Each of these byte-fields control the functionality on a given ball/pin. */
111 #define TMS570_IOMM_PINMMRx_PINMMRx8To16(val) BSP_FLD32(val,8, 15)
112 #define TMS570_IOMM_PINMMRx_PINMMRx8To16_GET(reg) BSP_FLD32GET(reg,8, 15)
113 #define TMS570_IOMM_PINMMRx_PINMMRx8To16_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
114
115 /* field: PINMMRx0To7 - Each of these byte-fields control the functionality on a given ball/pin. */
116 #define TMS570_IOMM_PINMMRx_PINMMRx0To7(val) BSP_FLD32(val,0, 7)
117 #define TMS570_IOMM_PINMMRx_PINMMRx0To7_GET(reg) BSP_FLD32GET(reg,0, 7)
118 #define TMS570_IOMM_PINMMRx_PINMMRx0To7_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
119
120
121 /*------------------TMS570_IOMM_REVISION_REG------------------*/
122 /* field: REV_SCHEME - Revision Scheme */
123 #define TMS570_IOMM_REVISION_REG_REV_SCHEME(val) BSP_FLD32(val,30, 31)
124 #define TMS570_IOMM_REVISION_REG_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
125 #define TMS570_IOMM_REVISION_REG_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
126
127 /* field: REV_MODULE - Module Id */
128 #define TMS570_IOMM_REVISION_REG_REV_MODULE(val) BSP_FLD32(val,16, 27)
129 #define TMS570_IOMM_REVISION_REG_REV_MODULE_GET(reg) BSP_FLD32GET(reg,16, 27)
130 #define TMS570_IOMM_REVISION_REG_REV_MODULE_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
131
132 /* field: REV_RTL - RTL Revision */
133 #define TMS570_IOMM_REVISION_REG_REV_RTL(val) BSP_FLD32(val,11, 15)
134 #define TMS570_IOMM_REVISION_REG_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
135 #define TMS570_IOMM_REVISION_REG_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
136
137 /* field: REV_MAJOR - Major Revision */
138 #define TMS570_IOMM_REVISION_REG_REV_MAJOR(val) BSP_FLD32(val,8, 10)
139 #define TMS570_IOMM_REVISION_REG_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
140 #define TMS570_IOMM_REVISION_REG_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
141
142 /* field: REV_CUSTOM - REV CUSTOM 0 Custom Revision */
143 #define TMS570_IOMM_REVISION_REG_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
144 #define TMS570_IOMM_REVISION_REG_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
145 #define TMS570_IOMM_REVISION_REG_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
146
147 /* field: REV_MINOR - Minor Revision */
148 #define TMS570_IOMM_REVISION_REG_REV_MINOR(val) BSP_FLD32(val,0, 5)
149 #define TMS570_IOMM_REVISION_REG_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
150 #define TMS570_IOMM_REVISION_REG_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
151
152
153 /*-------------------TMS570_IOMM_ENDIAN_REG-------------------*/
154 /* field: ENDIAN - Device endianness */
155 #define TMS570_IOMM_ENDIAN_REG_ENDIAN BSP_BIT32(0)
156
157
158 /*-------------------TMS570_IOMM_KICK_REG0-------------------*/
159 /* field: KICK0 - Kicker 0 Register. */
160 /* Whole 32 bits */
161
162 /*-------------------TMS570_IOMM_KICK_REG1-------------------*/
163 /* field: KICK1 - Kicker 1 Register. */
164 /* Whole 32 bits */
165
166 /*---------------TMS570_IOMM_ERR_RAW_STATUS_REG---------------*/
167 /* field: ADDR_ERR - Addressing Error Status and Error Signaling Enable. */
168 #define TMS570_IOMM_ERR_RAW_STATUS_REG_ADDR_ERR BSP_BIT32(1)
169
170 /* field: PROT_ERR - register inside the IOMM is written in the CPU's user mode of operation. */
171 #define TMS570_IOMM_ERR_RAW_STATUS_REG_PROT_ERR BSP_BIT32(0)
172
173
174 /*-------------TMS570_IOMM_ERR_ENABLED_STATUS_REG-------------*/
175 /* field: ENABLED_ADDR_ERR - Addressing Error Signaling Enable Status and Status Clear */
176 #define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_ADDR_ERR BSP_BIT32(1)
177
178 /* field: ENABLED_PROT_ERR - Protection Error Signaling Enable Status and Status Clear */
179 #define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_PROT_ERR BSP_BIT32(0)
180
181
182 /*-----------------TMS570_IOMM_ERR_ENABLE_REG-----------------*/
183 /* field: ADDR_ERR_EN - Addressing Error Signaling Enable */
184 #define TMS570_IOMM_ERR_ENABLE_REG_ADDR_ERR_EN BSP_BIT32(1)
185
186 /* field: PROT_ERR_EN - Protection ErrorSignaling Enable */
187 #define TMS570_IOMM_ERR_ENABLE_REG_PROT_ERR_EN BSP_BIT32(0)
188
189
190 /*---------------TMS570_IOMM_ERR_ENABLE_CLR_REG---------------*/
191 /* field: ADDR_ERR_EN_CLR - Addressing Error Signaling Enable Clear */
192 #define TMS570_IOMM_ERR_ENABLE_CLR_REG_ADDR_ERR_EN_CLR BSP_BIT32(1)
193
194 /* field: PROT_ERR_EN_CLR - Protection Error Signaling Enable Clear */
195 #define TMS570_IOMM_ERR_ENABLE_CLR_REG_PROT_ERR_EN_CLR BSP_BIT32(0)
196
197
198 /*---------------TMS570_IOMM_FAULT_ADDRESS_REG---------------*/
199 /* field: FAULT_ADDR - Fault Address. */
200 /* Whole 32 bits */
201
202 /*----------------TMS570_IOMM_FAULT_STATUS_REG----------------*/
203 /* field: FAULT_ID - Faulting Transaction ID */
204 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID(val) BSP_FLD32(val,24, 27)
205 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_GET(reg) BSP_FLD32GET(reg,24, 27)
206 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
207
208 /* field: FAULT_MSTID - ID of Master that initiated the faulting transaction */
209 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID(val) BSP_FLD32(val,16, 23)
210 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_GET(reg) BSP_FLD32GET(reg,16, 23)
211 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
212
213 /* field: FAULT_PRIVID - Faulting Privilege ID */
214 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID(val) BSP_FLD32(val,9, 12)
215 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_GET(reg) BSP_FLD32GET(reg,9, 12)
216 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_SET(reg,val) BSP_FLD32SET(reg, val,9, 12)
217
218 /* field: FAULT_TYPE - Type of fault detected */
219 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE(val) BSP_FLD32(val,0, 5)
220 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_GET(reg) BSP_FLD32GET(reg,0, 5)
221 #define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
222
223
224 /*----------------TMS570_IOMM_FAULT_CLEAR_REG----------------*/
225 /* field: FAULT_CLEAR - Fault Clear */
226 #define TMS570_IOMM_FAULT_CLEAR_REG_FAULT_CLEAR BSP_BIT32(0)
227
228
229 /*---------------------TMS570_IOMM_PINMUX---------------------*/
230 /* field: FAULT_CLEAR - Fault Clear */
231 #define TMS570_IOMM_PINMUX_FAULT_CLEAR BSP_BIT32(0)
232
233
234
235 #endif /* LIBBSP_ARM_TMS570_IOMM */
Definition: reg_iomm.h:78
Utility macros.
Definition: reg_iomm.h:44
