RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
tms570
include
bsp
ti_herc
reg_htu.h
1
/* The header file is generated by make_header.py from HTU.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_HTU
40
#define LIBBSP_ARM_TMS570_HTU
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GC;
/*Global Control Register*/
46
uint32_t CPENA;
/*Control Packet Enable Register*/
47
uint32_t BUSY0;
/*Control Packet Busy Register 0*/
48
uint32_t BUSY1;
/*Control Packet Busy Register 1*/
49
uint32_t BUSY2;
/*Control Packet Busy Register 2*/
50
uint32_t BUSY3;
/*Control Packet Busy Register 3*/
51
uint32_t ACPE;
/*Active Control Packet and Error Register*/
52
uint8_t reserved1 [4];
53
uint32_t RLBECTRL;
/*Request Lost and Bus Error Control Register*/
54
uint32_t BFINTS;
/*Buffer Full Interrupt Enable Set Register*/
55
uint32_t BFINTC;
/*Buffer Full Interrupt Enable Clear Register*/
56
uint8_t reserved2 [8];
57
uint32_t INTOFF0;
/*Interrupt Offset Register 0*/
58
uint32_t INTOFF1;
/*Interrupt Offset Register 1*/
59
uint32_t BIM;
/*Buffer Initialization Mode Register*/
60
uint32_t RLOSTFL;
/*Request Lost Flag Register*/
61
uint32_t BFINTFL;
/*Buffer Full Interrupt Flag Register*/
62
uint32_t BERINTFL;
/*BER Interrupt Flag Register*/
63
uint32_t MP1S;
/*Memory Protection 1 Start Address Register*/
64
uint32_t MP1E;
/*Memory Protection 1 End Address Register*/
65
uint32_t DCTRL;
/*Debug Control Register*/
66
uint32_t WPR;
/*Watch Point Register*/
67
uint32_t WMR;
/*Watch Mask Register*/
68
uint32_t ID;
/*Module Identification Register*/
69
uint32_t PCR;
/*Parity Control Register*/
70
uint32_t
PAR
/*Parity Address Register*/
71
uint8_t reserved3 [4];
72
uint32_t MPCS;
/*Memory Protection Control and Status Register*/
73
uint32_t MP0S;
/*Memory Protection 0 Start Address Register*/
74
uint32_t MP0E;
/*Memory Protection 0 End Address Register*/
75
tms570_htu_t
76
77
78
/*-----------------------TMS570_HTU_GC-----------------------*/
79
/* field: VBUSHOLD - Hold the VBUS bus */
80
#define TMS570_HTU_GC_VBUSHOLD BSP_BIT32(24)
81
82
/* field: HTUEN - Transfer Unit Enable Bit */
83
#define TMS570_HTU_GC_HTUEN BSP_BIT32(16)
84
85
/* field: DEBM - Debug Mode */
86
#define TMS570_HTU_GC_DEBM BSP_BIT32(8)
87
88
/* field: HTURES - HTU Software Reset Request */
89
#define TMS570_HTU_GC_HTURES BSP_BIT32(0)
90
91
92
/*----------------------TMS570_HTU_CPENA----------------------*/
93
/* field: CPENA - CP Enable Bits */
94
#define TMS570_HTU_CPENA_CPENA(val) BSP_FLD32(val,0, 15)
95
#define TMS570_HTU_CPENA_CPENA_GET(reg) BSP_FLD32GET(reg,0, 15)
96
#define TMS570_HTU_CPENA_CPENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
97
98
99
/*----------------------TMS570_HTU_BUSY0----------------------*/
100
/* field: BUSY0A - Busy Flag for CP A of DCP 0 */
101
#define TMS570_HTU_BUSY0_BUSY0A BSP_BIT32(24)
102
103
/* field: BUSY0B - Busy Flag for CP B of DCP 0 */
104
#define TMS570_HTU_BUSY0_BUSY0B BSP_BIT32(16)
105
106
/* field: BUSY1A - Busy Flag for CP A of DCP 1 */
107
#define TMS570_HTU_BUSY0_BUSY1A BSP_BIT32(8)
108
109
/* field: BUSY1B - Busy Flag for CP B of DCP 1 */
110
#define TMS570_HTU_BUSY0_BUSY1B BSP_BIT32(0)
111
112
113
/*----------------------TMS570_HTU_BUSY1----------------------*/
114
/* field: BUSY2A - Busy Flag for CP A of DCP 2 */
115
#define TMS570_HTU_BUSY1_BUSY2A BSP_BIT32(24)
116
117
/* field: BUSY2B - Busy Flag for CP B of DCP 2 */
118
#define TMS570_HTU_BUSY1_BUSY2B BSP_BIT32(16)
119
120
/* field: BUSY3A - Busy Flag for CP A of DCP 3 */
121
#define TMS570_HTU_BUSY1_BUSY3A BSP_BIT32(8)
122
123
/* field: BUSY3B - Busy Flag for CP B of DCP 3 */
124
#define TMS570_HTU_BUSY1_BUSY3B BSP_BIT32(0)
125
126
127
/*----------------------TMS570_HTU_BUSY2----------------------*/
128
/* field: BUSY4A - Busy Flag for CP A of DCP 4 */
129
#define TMS570_HTU_BUSY2_BUSY4A BSP_BIT32(24)
130
131
/* field: BUSY4B - Busy Flag for CP B of DCP 4 */
132
#define TMS570_HTU_BUSY2_BUSY4B BSP_BIT32(16)
133
134
/* field: BUSY5A - Busy Flag for CP A of DCP 5 */
135
#define TMS570_HTU_BUSY2_BUSY5A BSP_BIT32(8)
136
137
/* field: BUSY5B - Busy Flag for CP B of DCP 5 */
138
#define TMS570_HTU_BUSY2_BUSY5B BSP_BIT32(0)
139
140
141
/*----------------------TMS570_HTU_BUSY3----------------------*/
142
/* field: BUSY6A - Busy Flag for CP A of DCP 6 */
143
#define TMS570_HTU_BUSY3_BUSY6A BSP_BIT32(24)
144
145
/* field: BUSY6B - Busy Flag for CP B of DCP 6 */
146
#define TMS570_HTU_BUSY3_BUSY6B BSP_BIT32(16)
147
148
/* field: BUSY7A - Busy Flag for CP A of DCP 7 */
149
#define TMS570_HTU_BUSY3_BUSY7A BSP_BIT32(8)
150
151
/* field: BUSY7B - Busy Flag for CP B of DCP 7 */
152
#define TMS570_HTU_BUSY3_BUSY7B BSP_BIT32(0)
153
154
155
/*----------------------TMS570_HTU_ACPE----------------------*/
156
/* field: ERRF - Error Flag */
157
#define TMS570_HTU_ACPE_ERRF BSP_BIT32(31)
158
159
160
/*--------------------TMS570_HTU_RLBECTRL--------------------*/
161
/* field: BERINTENA - Bus Error Interrupt Enable Bit */
162
#define TMS570_HTU_RLBECTRL_BERINTENA BSP_BIT32(16)
163
164
/* field: CORL - Continue On Request Lost Error */
165
#define TMS570_HTU_RLBECTRL_CORL BSP_BIT32(8)
166
167
/* field: RLINTENA - Request Lost Interrupt Enable Bit */
168
#define TMS570_HTU_RLBECTRL_RLINTENA BSP_BIT32(0)
169
170
171
/*---------------------TMS570_HTU_BFINTS---------------------*/
172
/* field: BFINTENA - Bus Full Interrupt Enable Bits. */
173
#define TMS570_HTU_BFINTS_BFINTENA(val) BSP_FLD32(val,0, 15)
174
#define TMS570_HTU_BFINTS_BFINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
175
#define TMS570_HTU_BFINTS_BFINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
176
177
178
/*---------------------TMS570_HTU_BFINTC---------------------*/
179
/* field: BFINTDIS - */
180
#define TMS570_HTU_BFINTC_BFINTDIS(val) BSP_FLD32(val,0, 15)
181
#define TMS570_HTU_BFINTC_BFINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
182
#define TMS570_HTU_BFINTC_BFINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
183
184
185
/*---------------------TMS570_HTU_INTOFF0---------------------*/
186
/* field: INTTYPE0 - Interrupt Type of Interrupt Line 0. */
187
#define TMS570_HTU_INTOFF0_INTTYPE0(val) BSP_FLD32(val,8, 10)
188
#define TMS570_HTU_INTOFF0_INTTYPE0_GET(reg) BSP_FLD32GET(reg,8, 10)
189
#define TMS570_HTU_INTOFF0_INTTYPE0_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
190
191
/* field: CPOFF0 - CP Offset. */
192
#define TMS570_HTU_INTOFF0_CPOFF0(val) BSP_FLD32(val,0, 4)
193
#define TMS570_HTU_INTOFF0_CPOFF0_GET(reg) BSP_FLD32GET(reg,0, 4)
194
#define TMS570_HTU_INTOFF0_CPOFF0_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
195
196
197
/*---------------------TMS570_HTU_INTOFF1---------------------*/
198
/* field: INTTYPE1 - INTTYPE1 Interrupt Type of Interrupt Line 1. */
199
#define TMS570_HTU_INTOFF1_INTTYPE1(val) BSP_FLD32(val,8, 10)
200
#define TMS570_HTU_INTOFF1_INTTYPE1_GET(reg) BSP_FLD32GET(reg,8, 10)
201
#define TMS570_HTU_INTOFF1_INTTYPE1_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
202
203
/* field: CPOFF1 - CP Offset. */
204
#define TMS570_HTU_INTOFF1_CPOFF1(val) BSP_FLD32(val,0, 4)
205
#define TMS570_HTU_INTOFF1_CPOFF1_GET(reg) BSP_FLD32GET(reg,0, 4)
206
#define TMS570_HTU_INTOFF1_CPOFF1_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
207
208
209
/*-----------------------TMS570_HTU_BIM-----------------------*/
210
/* field: BIM - Buffer Initialization Mode */
211
#define TMS570_HTU_BIM_BIM(val) BSP_FLD32(val,0, 7)
212
#define TMS570_HTU_BIM_BIM_GET(reg) BSP_FLD32GET(reg,0, 7)
213
#define TMS570_HTU_BIM_BIM_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
214
215
216
/*---------------------TMS570_HTU_RLOSTFL---------------------*/
217
/* field: CPRLFL - CP Request Lost Flags */
218
#define TMS570_HTU_RLOSTFL_CPRLFL(val) BSP_FLD32(val,0, 15)
219
#define TMS570_HTU_RLOSTFL_CPRLFL_GET(reg) BSP_FLD32GET(reg,0, 15)
220
#define TMS570_HTU_RLOSTFL_CPRLFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
221
222
223
/*---------------------TMS570_HTU_BFINTFL---------------------*/
224
/* field: BFINTFL - Buffer Full Interrupt Flags */
225
#define TMS570_HTU_BFINTFL_BFINTFL(val) BSP_FLD32(val,0, 15)
226
#define TMS570_HTU_BFINTFL_BFINTFL_GET(reg) BSP_FLD32GET(reg,0, 15)
227
#define TMS570_HTU_BFINTFL_BFINTFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
228
229
230
/*--------------------TMS570_HTU_BERINTFL--------------------*/
231
/* field: BERINTFL - Bus Error Interrupt Flags */
232
#define TMS570_HTU_BERINTFL_BERINTFL(val) BSP_FLD32(val,0, 15)
233
#define TMS570_HTU_BERINTFL_BERINTFL_GET(reg) BSP_FLD32GET(reg,0, 15)
234
#define TMS570_HTU_BERINTFL_BERINTFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
235
236
237
/*----------------------TMS570_HTU_MP1S----------------------*/
238
/* field: STARTADDRESS1 - he start address defines at which main memory address the region begins. */
239
/* Whole 32 bits */
240
241
/*----------------------TMS570_HTU_MP1E----------------------*/
242
/* field: ENDADDRESS1 - The end address defines at which address the region ends. */
243
/* Whole 32 bits */
244
245
/*----------------------TMS570_HTU_DCTRL----------------------*/
246
/* field: CPNUM - CP Number. These bit fields indicate the CP which should cause the watch point to match. */
247
#define TMS570_HTU_DCTRL_CPNUM(val) BSP_FLD32(val,24, 27)
248
#define TMS570_HTU_DCTRL_CPNUM_GET(reg) BSP_FLD32GET(reg,24, 27)
249
#define TMS570_HTU_DCTRL_CPNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
250
251
/* field: HTUDBGS - HTU Debug Status. */
252
#define TMS570_HTU_DCTRL_HTUDBGS BSP_BIT32(16)
253
254
/* field: DBREN - Debug Request Enable */
255
#define TMS570_HTU_DCTRL_DBREN BSP_BIT32(0)
256
257
258
/*-----------------------TMS570_HTU_WPR-----------------------*/
259
/* field: WP - Watch Point Register */
260
/* Whole 32 bits */
261
262
/*-----------------------TMS570_HTU_WMR-----------------------*/
263
/* field: WM - Watch Mask Register */
264
/* Whole 32 bits */
265
266
/*-----------------------TMS570_HTU_ID-----------------------*/
267
/* field: CLASS - Module Class */
268
#define TMS570_HTU_ID_CLASS(val) BSP_FLD32(val,16, 23)
269
#define TMS570_HTU_ID_CLASS_GET(reg) BSP_FLD32GET(reg,16, 23)
270
#define TMS570_HTU_ID_CLASS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
271
272
/* field: TYPE - Subtype within a Class */
273
#define TMS570_HTU_ID_TYPE(val) BSP_FLD32(val,8, 15)
274
#define TMS570_HTU_ID_TYPE_GET(reg) BSP_FLD32GET(reg,8, 15)
275
#define TMS570_HTU_ID_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
276
277
/* field: REV - Module Revision Number */
278
#define TMS570_HTU_ID_REV(val) BSP_FLD32(val,0, 7)
279
#define TMS570_HTU_ID_REV_GET(reg) BSP_FLD32GET(reg,0, 7)
280
#define TMS570_HTU_ID_REV_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
281
282
283
/*-----------------------TMS570_HTU_PCR-----------------------*/
284
/* field: COPE - Continue on Parity Error */
285
#define TMS570_HTU_PCR_COPE BSP_BIT32(16)
286
287
/* field: TEST - Test. */
288
#define TMS570_HTU_PCR_TEST BSP_BIT32(8)
289
290
/* field: PARITY_ENA - Enable/Disable Parity Checking. */
291
#define TMS570_HTU_PCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
292
#define TMS570_HTU_PCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
293
#define TMS570_HTU_PCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
294
295
296
/*-----------------------TMS570_HTU_PAR-----------------------*/
297
/* field: PEFT - Parity Error Fault Flag. */
298
#define TMS570_HTU_PAR_PEFT BSP_BIT32(16)
299
300
/* field: PAOFF - PAOFF */
301
#define TMS570_HTU_PAR_PAOFF(val) BSP_FLD32(val,0, 8)
302
#define TMS570_HTU_PAR_PAOFF_GET(reg) BSP_FLD32GET(reg,0, 8)
303
#define TMS570_HTU_PAR_PAOFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
304
305
306
/*----------------------TMS570_HTU_MPCS----------------------*/
307
/* field: CPNUM0 - Control Packet Number for single memory protection region configuration. */
308
#define TMS570_HTU_MPCS_CPNUM0(val) BSP_FLD32(val,24, 27)
309
#define TMS570_HTU_MPCS_CPNUM0_GET(reg) BSP_FLD32GET(reg,24, 27)
310
#define TMS570_HTU_MPCS_CPNUM0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
311
312
/* field: MPEFT1 - MPEFT1 */
313
#define TMS570_HTU_MPCS_MPEFT1 BSP_BIT32(17)
314
315
/* field: MPEFT0 - Memory Protection Error Fault Flag 0. */
316
#define TMS570_HTU_MPCS_MPEFT0 BSP_BIT32(16)
317
318
/* field: CPNUM1 - Control Packet Number for single memory protection region configuration. */
319
#define TMS570_HTU_MPCS_CPNUM1(val) BSP_FLD32(val,8, 11)
320
#define TMS570_HTU_MPCS_CPNUM1_GET(reg) BSP_FLD32GET(reg,8, 11)
321
#define TMS570_HTU_MPCS_CPNUM1_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
322
323
324
/*----------------------TMS570_HTU_MP0S----------------------*/
325
/* field: ISTARTADDRESS0 - The start address defines at which main memory address the region begins. */
326
/* Whole 32 bits */
327
328
/*----------------------TMS570_HTU_MP0E----------------------*/
329
/* field: ENDADDRESS0 - The end address defines at which address the region ends. */
330
/* Whole 32 bits */
331
332
333
#endif
/* LIBBSP_ARM_TMS570_HTU */
utility.h
Utility macros.
tms570_htu_t
Definition:
reg_htu.h:44
PAR
#define PAR
physical addr reg base for rd and wr
Definition:
wd80x3.h:113
