RTEMS  5.1
reg_flex_ray.h
1 /* The header file is generated by make_header.py from FLEX_RAY.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_FLEX_RAY
40 #define LIBBSP_ARM_TMS570_FLEX_RAY
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t GSN0; /*Global Static Number 0*/
46  uint32_t GSN1; /*Global Static Number 1*/
47  uint8_t reserved1 [8];
48  uint32_t GCS; /*Global Control Set*/
49  uint32_t GCR; /*Global Control Reset*/
50  uint32_t TSCB; /*Transfer Status Current Buffer*/
51  uint32_t LTBCC; /*Last Transferred Buffer to Communication Controller*/
52  uint32_t LTBSM; /*Last Transferred Buffer to System Memory*/
53  uint32_t TBA; /*Transfer Base Address*/
54  uint32_t NTBA; /*Next Transfer Base Address*/
55  uint32_t BAMS; /*Base Address of Mirrored Status*/
56  uint32_t SAMP; /*Start Address of Memory Protection*/
57  uint32_t EAMP; /*End Address of Memory Protection*/
58  uint8_t reserved2 [8];
59  uint32_t TSMO1; /*Transfer to System Memory Occurred 1*/
60  uint32_t TSMO2; /*Transfer to System Memory Occurred 2*/
61  uint32_t TSMO3; /*Transfer to System Memory Occurred 3*/
62  uint32_t TSMO4; /*Transfer to System Memory Occurred 4*/
63  uint32_t TCCO1; /*Transfer to Communication Controller Occurred 1*/
64  uint32_t TCCO2; /*Transfer to Communication Controller Occurred 2*/
65  uint32_t TCCO3; /*Transfer to Communication Controller Occurred 3*/
66  uint32_t TCCO4; /*Transfer to Communication Controller Occurred 4*/
67  uint32_t TOOFF; /*Transfer Occurred Offset*/
68  uint8_t reserved3 [12];
69  uint32_t PEADR; /*Parity Error Address*/
70  uint32_t TEIF; /*Transfer Error Interrupt*/
71  uint32_t TEIRES; /*Transfer Error Interrupt Enable Set*/
72  uint32_t TEIRER; /*Transfer Error Interrupt Enable Reset*/
73  uint32_t TTSMS1; /*Trigger Transfer to System Memory Set 1*/
74  uint32_t TTSMR1; /*Trigger Transfer to System Memory Reset 1*/
75  uint32_t TTSMS2; /*Trigger Transfer to System Memory Set 2*/
76  uint32_t TTSMR2; /*Trigger Transfer to System Memory Reset 2*/
77  uint32_t TTSMS3; /*Trigger Transfer to System Memory Set 3*/
78  uint32_t TTSMR3; /*Trigger Transfer to System Memory Reset 3*/
79  uint32_t TTSMS4; /*Trigger Transfer to System Memory Set 4*/
80  uint32_t TTSMR4; /*Trigger Transfer to System Memory Reset 4*/
81  uint32_t TTCCS1; /*Trigger Transfer to Communication Controller Set 1*/
82  uint32_t TTCCR1; /*Trigger Transfer to Communication Controller Reset 1*/
83  uint32_t TTCCS2; /*Trigger Transfer to Communication Controller Set 2*/
84  uint32_t TTCCR2; /*Trigger Transfer to Communication Controller Reset 2*/
85  uint32_t TTCCS3; /*Trigger Transfer to Communication Controller Set 3*/
86  uint32_t TTCCR3; /*Trigger Transfer to Communication Controller Reset 3*/
87  uint32_t TTCCS4; /*Trigger Transfer to Communication Controller Set 4*/
88  uint32_t TTCCR4; /*Trigger Transfer to Communication Controller Reset 4*/
89  uint32_t ETESMS1; /*Enable Transfer on Event to System Memory Set 1*/
90  uint32_t ETESMR1; /*Enable Transfer on Event to System Memory Reset 1*/
91  uint32_t ETESMS2; /*Enable Transfer on Event to System Memory Set 2*/
92  uint32_t ETESMR2; /*Enable Transfer on Event to System Memory Reset 2*/
93  uint32_t ETESMS3; /*Enable Transfer on Event to System Memory Set 3*/
94  uint32_t ETESMR3; /*Enable Transfer on Event to System Memory Reset 3*/
95  uint32_t ETESMS4; /*Enable Transfer on Event to System Memory Set 4*/
96  uint32_t ETESMR4; /*Enable Transfer on Event to System Memory Reset 4*/
97  uint32_t CESMS1; /*Clear on Event to System Memory Set 1*/
98  uint32_t CESMR1; /*Clear on Event to System Memory Reset 1*/
99  uint32_t CESMS2; /*Clear on Event to System Memory Set 2*/
100  uint32_t CESMR2; /*Clear on Event to System Memory Reset 2*/
101  uint32_t CESMS3; /*Clear on Event to System Memory Set 3*/
102  uint32_t CESMR3; /*Clear on Event to System Memory Reset 3*/
103  uint32_t CESMS4; /*Clear on Event to System Memory Set 4*/
104  uint32_t CESMR4; /*Clear on Event to System Memory Reset 4*/
105  uint32_t TSMIES1; /*Transfer to System Memory Interrupt Enable Set 1*/
106  uint32_t TSMIER1; /*Transfer to System Memory Interrupt Enable Reset 1*/
107  uint32_t TSMIES2; /*Transfer to System Memory Interrupt Enable Set 2*/
108  uint32_t TSMIER2; /*Transfer to System Memory Interrupt Enable Reset 2*/
109  uint32_t TSMIES3; /*Transfer to System Memory Interrupt Enable Set 3*/
110  uint32_t TSMIER3; /*Transfer to System Memory Interrupt Enable Reset 3*/
111  uint32_t TSMIES4; /*Transfer to System Memory Interrupt Enable Set 4*/
112  uint32_t TSMIER4; /*Transfer to System Memory Interrupt Enable Reset 4*/
113  uint32_t TCCIES1; /*Transfer to Communication Controller Interrupt Enable Set 1*/
114  uint32_t TCCIER1; /*Transfer to Communication Controller Interrupt Enable Reset 1*/
115  uint32_t TCCIES2; /*Transfer to Communication Controller Interrupt Enable Set 2*/
116  uint32_t TCCIER2; /*Transfer to Communication Controller Interrupt Enable Reset 2*/
117  uint32_t TCCIES3; /*Transfer to Communication Controller Interrupt Enable Set 3*/
118  uint32_t TCCIER3; /*Transfer to Communication Controller Interrupt Enable Reset 3*/
119  uint32_t TCCIES4; /*Transfer to Communication Controller Interrupt Enable Set 4*/
120  uint32_t TCCIER4; /*Transfer to Communication Controller Interrupt Enable Reset 4*/
122
123
124 /*--------------------TMS570_FLEX_RAY_GSN0--------------------*/
125 /* field: Data_A - Data_A(15-0) */
126 #define TMS570_FLEX_RAY_GSN0_Data_A(val) BSP_FLD32(val,16, 31)
127 #define TMS570_FLEX_RAY_GSN0_Data_A_GET(reg) BSP_FLD32GET(reg,16, 31)
128 #define TMS570_FLEX_RAY_GSN0_Data_A_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
129
130 /* field: Data_B - (complement of Data_A(15-0)) */
131 #define TMS570_FLEX_RAY_GSN0_Data_B(val) BSP_FLD32(val,0, 15)
132 #define TMS570_FLEX_RAY_GSN0_Data_B_GET(reg) BSP_FLD32GET(reg,0, 15)
133 #define TMS570_FLEX_RAY_GSN0_Data_B_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
134
135
136 /*--------------------TMS570_FLEX_RAY_GSN1--------------------*/
137 /* field: Data_C - Data_C(15-0) */
138 #define TMS570_FLEX_RAY_GSN1_Data_C(val) BSP_FLD32(val,16, 31)
139 #define TMS570_FLEX_RAY_GSN1_Data_C_GET(reg) BSP_FLD32GET(reg,16, 31)
140 #define TMS570_FLEX_RAY_GSN1_Data_C_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
141
142 /* field: Data_D - (complement of Data_C(15-0)) */
143 #define TMS570_FLEX_RAY_GSN1_Data_D(val) BSP_FLD32(val,0, 15)
144 #define TMS570_FLEX_RAY_GSN1_Data_D_GET(reg) BSP_FLD32GET(reg,0, 15)
145 #define TMS570_FLEX_RAY_GSN1_Data_D_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
146
147
148 /*--------------------TMS570_FLEX_RAY_GCS--------------------*/
149 /* field: ENDVBM - Endianness Correction on VBusp Master */
150 #define TMS570_FLEX_RAY_GCS_ENDVBM BSP_BIT32(31)
151
152 /* field: ENDVBS - Endianness correction on VBusp Slave */
153 #define TMS570_FLEX_RAY_GCS_ENDVBS BSP_BIT32(30)
154
155 /* field: ENDRx - Endianness Correction for No (header or payload) Data Sink Access */
156 #define TMS570_FLEX_RAY_GCS_ENDRx(val) BSP_FLD32(val,28, 29)
157 #define TMS570_FLEX_RAY_GCS_ENDRx_GET(reg) BSP_FLD32GET(reg,28, 29)
158 #define TMS570_FLEX_RAY_GCS_ENDRx_SET(reg,val) BSP_FLD32SET(reg, val,28, 29)
159
160 /* field: ENDHx - Endianness Correction for Header */
161 #define TMS570_FLEX_RAY_GCS_ENDHx(val) BSP_FLD32(val,26, 27)
162 #define TMS570_FLEX_RAY_GCS_ENDHx_GET(reg) BSP_FLD32GET(reg,26, 27)
163 #define TMS570_FLEX_RAY_GCS_ENDHx_SET(reg,val) BSP_FLD32SET(reg, val,26, 27)
164
165 /* field: ENDPx - Endianness Correction for Payload */
166 #define TMS570_FLEX_RAY_GCS_ENDPx(val) BSP_FLD32(val,24, 25)
167 #define TMS570_FLEX_RAY_GCS_ENDPx_GET(reg) BSP_FLD32GET(reg,24, 25)
168 #define TMS570_FLEX_RAY_GCS_ENDPx_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
169
170 /* field: PRIO - Transfer Priority */
171 #define TMS570_FLEX_RAY_GCS_PRIO BSP_BIT32(21)
172
173 /* field: PEFT - Parity for Test */
174 #define TMS570_FLEX_RAY_GCS_PEFT BSP_BIT32(20)
175
176 /* field: PELx - Parity Lock */
177 #define TMS570_FLEX_RAY_GCS_PELx(val) BSP_FLD32(val,16, 19)
178 #define TMS570_FLEX_RAY_GCS_PELx_GET(reg) BSP_FLD32GET(reg,16, 19)
179 #define TMS570_FLEX_RAY_GCS_PELx_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
180
181 /* field: CETESM - Clear ETESM Register */
182 #define TMS570_FLEX_RAY_GCS_CETESM BSP_BIT32(14)
183
184 /* field: CTTCC - Clear TTCC Register */
185 #define TMS570_FLEX_RAY_GCS_CTTCC BSP_BIT32(13)
186
187 /* field: CTTSM - Clear TTSM Register */
188 #define TMS570_FLEX_RAY_GCS_CTTSM BSP_BIT32(12)
189
190 /* field: ETSM - Enable Transfer Status Mirrored */
191 #define TMS570_FLEX_RAY_GCS_ETSM BSP_BIT32(8)
192
193 /* field: SILE - Status Interrupt Line Enable */
194 #define TMS570_FLEX_RAY_GCS_SILE BSP_BIT32(5)
195
196 /* field: EILE - Error Interrupt Line Enable */
197 #define TMS570_FLEX_RAY_GCS_EILE BSP_BIT32(4)
198
199 /* field: TUH - Transfer Unit Halted */
200 #define TMS570_FLEX_RAY_GCS_TUH BSP_BIT32(1)
201
202 /* field: TUE - Transfer Unit Enabled */
203 #define TMS570_FLEX_RAY_GCS_TUE BSP_BIT32(0)
204
205
206 /*--------------------TMS570_FLEX_RAY_GCR--------------------*/
207 /* field: ENDVBM - Endianness Correction on VBusp Master */
208 #define TMS570_FLEX_RAY_GCR_ENDVBM BSP_BIT32(31)
209
210 /* field: ENDVBS - Endianness correction on VBusp Slave */
211 #define TMS570_FLEX_RAY_GCR_ENDVBS BSP_BIT32(30)
212
213 /* field: ENDRx - Endianness Correction for No (header or payload) Data Sink Access */
214 #define TMS570_FLEX_RAY_GCR_ENDRx(val) BSP_FLD32(val,28, 29)
215 #define TMS570_FLEX_RAY_GCR_ENDRx_GET(reg) BSP_FLD32GET(reg,28, 29)
216 #define TMS570_FLEX_RAY_GCR_ENDRx_SET(reg,val) BSP_FLD32SET(reg, val,28, 29)
217
218 /* field: ENDHx - Endianness Correction for Header */
219 #define TMS570_FLEX_RAY_GCR_ENDHx(val) BSP_FLD32(val,26, 27)
220 #define TMS570_FLEX_RAY_GCR_ENDHx_GET(reg) BSP_FLD32GET(reg,26, 27)
221 #define TMS570_FLEX_RAY_GCR_ENDHx_SET(reg,val) BSP_FLD32SET(reg, val,26, 27)
222
223 /* field: ENDPx - Endianness Correction for Payload */
224 #define TMS570_FLEX_RAY_GCR_ENDPx(val) BSP_FLD32(val,24, 25)
225 #define TMS570_FLEX_RAY_GCR_ENDPx_GET(reg) BSP_FLD32GET(reg,24, 25)
226 #define TMS570_FLEX_RAY_GCR_ENDPx_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
227
228 /* field: PRIO - Transfer Priority */
229 #define TMS570_FLEX_RAY_GCR_PRIO BSP_BIT32(21)
230
231 /* field: PEFT - Parity for Test */
232 #define TMS570_FLEX_RAY_GCR_PEFT BSP_BIT32(20)
233
234 /* field: PELx - Parity Lock */
235 #define TMS570_FLEX_RAY_GCR_PELx(val) BSP_FLD32(val,16, 19)
236 #define TMS570_FLEX_RAY_GCR_PELx_GET(reg) BSP_FLD32GET(reg,16, 19)
237 #define TMS570_FLEX_RAY_GCR_PELx_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
238
239 /* field: CETESM - Clear ETESM Register */
240 #define TMS570_FLEX_RAY_GCR_CETESM BSP_BIT32(14)
241
242 /* field: CTTCC - Clear TTCC Register */
243 #define TMS570_FLEX_RAY_GCR_CTTCC BSP_BIT32(13)
244
245 /* field: CTTSM - Clear TTSM Register */
246 #define TMS570_FLEX_RAY_GCR_CTTSM BSP_BIT32(12)
247
248 /* field: ETSM - Enable Transfer Status Mirrored */
249 #define TMS570_FLEX_RAY_GCR_ETSM BSP_BIT32(8)
250
251 /* field: SILE - Status Interrupt Line Enable */
252 #define TMS570_FLEX_RAY_GCR_SILE BSP_BIT32(5)
253
254 /* field: EILE - Error Interrupt Line Enable */
255 #define TMS570_FLEX_RAY_GCR_EILE BSP_BIT32(4)
256
257 /* field: TUH - Transfer Unit Halted */
258 #define TMS570_FLEX_RAY_GCR_TUH BSP_BIT32(1)
259
260 /* field: TUE - Transfer Unit Enabled */
261 #define TMS570_FLEX_RAY_GCR_TUE BSP_BIT32(0)
262
263
264 /*--------------------TMS570_FLEX_RAY_TSCB--------------------*/
265 /* field: TSMS - Transfer State Machine Status */
266 #define TMS570_FLEX_RAY_TSCB_TSMS(val) BSP_FLD32(val,16, 20)
267 #define TMS570_FLEX_RAY_TSCB_TSMS_GET(reg) BSP_FLD32GET(reg,16, 20)
268 #define TMS570_FLEX_RAY_TSCB_TSMS_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
269
270 /* field: STUH - Status of Transfer Unit State Machine for Halt Detection */
271 #define TMS570_FLEX_RAY_TSCB_STUH BSP_BIT32(12)
272
273 /* field: IDLE - Detects Transfer State Machine State IDLE */
274 #define TMS570_FLEX_RAY_TSCB_IDLE BSP_BIT32(8)
275
276 /* field: BN - Buffer Number */
277 #define TMS570_FLEX_RAY_TSCB_BN(val) BSP_FLD32(val,0, 6)
278 #define TMS570_FLEX_RAY_TSCB_BN_GET(reg) BSP_FLD32GET(reg,0, 6)
279 #define TMS570_FLEX_RAY_TSCB_BN_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
280
281
282 /*-------------------TMS570_FLEX_RAY_LTBCC-------------------*/
283 /* field: BN - Buffer number. */
284 #define TMS570_FLEX_RAY_LTBCC_BN(val) BSP_FLD32(val,0, 6)
285 #define TMS570_FLEX_RAY_LTBCC_BN_GET(reg) BSP_FLD32GET(reg,0, 6)
286 #define TMS570_FLEX_RAY_LTBCC_BN_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
287
288
289 /*-------------------TMS570_FLEX_RAY_LTBSM-------------------*/
290 /* field: BN - Buffer number. */
291 #define TMS570_FLEX_RAY_LTBSM_BN(val) BSP_FLD32(val,0, 6)
292 #define TMS570_FLEX_RAY_LTBSM_BN_GET(reg) BSP_FLD32GET(reg,0, 6)
293 #define TMS570_FLEX_RAY_LTBSM_BN_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
294
295
296 /*--------------------TMS570_FLEX_RAY_TBA--------------------*/
297 /* field: TBA - Transfer Base Address. */
298 /* Whole 32 bits */
299
300 /*--------------------TMS570_FLEX_RAY_NTBA--------------------*/
301 /* field: nTBA - nTBA(31-0) */
302 /* Whole 32 bits */
303
304 /*--------------------TMS570_FLEX_RAY_BAMS--------------------*/
305 /* field: BAMS - Base Address of Mirrored Status32-bit base pointer, 2 LSB are not significant (32-bit */
306 /* Whole 32 bits */
307
308 /*--------------------TMS570_FLEX_RAY_SAMP--------------------*/
309 /* field: SAMP - Start Address Memory Protection. */
310 /* Whole 32 bits */
311
312 /*--------------------TMS570_FLEX_RAY_EAMP--------------------*/
313 /* field: EAMP - End Address Memory Protection. */
314 /* Whole 32 bits */
315
316 /*-------------------TMS570_FLEX_RAY_TSMO1-------------------*/
317 /* field: TSMO1 - Transfer to System Memory Occurred Register 1. */
318 /* Whole 32 bits */
319
320 /*-------------------TMS570_FLEX_RAY_TSMO2-------------------*/
321 /* field: TSMO1 - Transfer to System Memory Occurred Register 1. */
322 /* Whole 32 bits */
323
324 /*-------------------TMS570_FLEX_RAY_TSMO3-------------------*/
325 /* field: TSMO1 - Transfer to System Memory Occurred Register 1. */
326 /* Whole 32 bits */
327
328 /*-------------------TMS570_FLEX_RAY_TSMO4-------------------*/
329 /* field: TSMO1 - Transfer to System Memory Occurred Register 1. */
330 /* Whole 32 bits */
331
332 /*-------------------TMS570_FLEX_RAY_TCCO1-------------------*/
333 /* field: TCCO1 - Transfer to Communication Controller Occurred Register 1. */
334 /* Whole 32 bits */
335
336 /*-------------------TMS570_FLEX_RAY_TCCO2-------------------*/
337 /* field: TCCO1 - Transfer to Communication Controller Occurred Register 1. */
338 /* Whole 32 bits */
339
340 /*-------------------TMS570_FLEX_RAY_TCCO3-------------------*/
341 /* field: TCCO1 - Transfer to Communication Controller Occurred Register 1. */
342 /* Whole 32 bits */
343
344 /*-------------------TMS570_FLEX_RAY_TCCO4-------------------*/
345 /* field: TCCO1 - Transfer to Communication Controller Occurred Register 1. */
346 /* Whole 32 bits */
347
348 /*-------------------TMS570_FLEX_RAY_TOOFF-------------------*/
349 /* field: TDIR - Transfer Direction. */
350 #define TMS570_FLEX_RAY_TOOFF_TDIR BSP_BIT32(8)
351
352 /* field: OFF - Offset Vector */
353 #define TMS570_FLEX_RAY_TOOFF_OFF(val) BSP_FLD32(val,0, 7)
354 #define TMS570_FLEX_RAY_TOOFF_OFF_GET(reg) BSP_FLD32GET(reg,0, 7)
355 #define TMS570_FLEX_RAY_TOOFF_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
356
357
358 /*-------------------TMS570_FLEX_RAY_PEADR-------------------*/
359 /* field: ADR - Address of failing TCR location. */
360 #define TMS570_FLEX_RAY_PEADR_ADR(val) BSP_FLD32(val,0, 8)
361 #define TMS570_FLEX_RAY_PEADR_ADR_GET(reg) BSP_FLD32GET(reg,0, 8)
362 #define TMS570_FLEX_RAY_PEADR_ADR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
363
364
365 /*--------------------TMS570_FLEX_RAY_TEIF--------------------*/
366 /* field: MPV - Memory Protection Violation. */
367 #define TMS570_FLEX_RAY_TEIF_MPV BSP_BIT32(17)
368
369 /* field: PE - Parity Error. The flag signals a parity error to the host. */
370 #define TMS570_FLEX_RAY_TEIF_PE BSP_BIT32(16)
371
372 /* field: RSTAT - Status of VBUS on read transfers. */
373 #define TMS570_FLEX_RAY_TEIF_RSTAT(val) BSP_FLD32(val,8, 10)
374 #define TMS570_FLEX_RAY_TEIF_RSTAT_GET(reg) BSP_FLD32GET(reg,8, 10)
375 #define TMS570_FLEX_RAY_TEIF_RSTAT_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
376
377 /* field: WSTAT - Status of VBUS on write transfers. */
378 #define TMS570_FLEX_RAY_TEIF_WSTAT(val) BSP_FLD32(val,4, 6)
379 #define TMS570_FLEX_RAY_TEIF_WSTAT_GET(reg) BSP_FLD32GET(reg,4, 6)
380 #define TMS570_FLEX_RAY_TEIF_WSTAT_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
381
382 /* field: TNR - Transfer Not Ready. */
383 #define TMS570_FLEX_RAY_TEIF_TNR BSP_BIT32(1)
384
385 /* field: FAC - Forbidden Access. */
386 #define TMS570_FLEX_RAY_TEIF_FAC BSP_BIT32(0)
387
388
389 /*-------------------TMS570_FLEX_RAY_TEIRES-------------------*/
390 /* field: RSTATE - Read Error Interrupt Generation (interrupt generation on VBUS read transfer errors). */
391 #define TMS570_FLEX_RAY_TEIRES_RSTATE(val) BSP_FLD32(val,8, 10)
392 #define TMS570_FLEX_RAY_TEIRES_RSTATE_GET(reg) BSP_FLD32GET(reg,8, 10)
393 #define TMS570_FLEX_RAY_TEIRES_RSTATE_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
394
395 /* field: WSTATE - Write Error Interrupt Generation (interrupt generation on VBUS write transfer errors). */
396 #define TMS570_FLEX_RAY_TEIRES_WSTATE(val) BSP_FLD32(val,4, 6)
397 #define TMS570_FLEX_RAY_TEIRES_WSTATE_GET(reg) BSP_FLD32GET(reg,4, 6)
398 #define TMS570_FLEX_RAY_TEIRES_WSTATE_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
399
400 /* field: TNRE - Transfer Not Ready Enable. */
401 #define TMS570_FLEX_RAY_TEIRES_TNRE BSP_BIT32(1)
402
403 /* field: FACE - Forbidden Access Enable. */
404 #define TMS570_FLEX_RAY_TEIRES_FACE BSP_BIT32(0)
405
406
407 /*-------------------TMS570_FLEX_RAY_TEIRER-------------------*/
408 /* field: RSTATE - Read Error Interrupt Generation (interrupt generation on VBUS read transfer errors). */
409 #define TMS570_FLEX_RAY_TEIRER_RSTATE(val) BSP_FLD32(val,8, 10)
410 #define TMS570_FLEX_RAY_TEIRER_RSTATE_GET(reg) BSP_FLD32GET(reg,8, 10)
411 #define TMS570_FLEX_RAY_TEIRER_RSTATE_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
412
413 /* field: WSTATE - Write Error Interrupt Generation (interrupt generation on VBUS write transfer errors). */
414 #define TMS570_FLEX_RAY_TEIRER_WSTATE(val) BSP_FLD32(val,4, 6)
415 #define TMS570_FLEX_RAY_TEIRER_WSTATE_GET(reg) BSP_FLD32GET(reg,4, 6)
416 #define TMS570_FLEX_RAY_TEIRER_WSTATE_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
417
418 /* field: TNRE - Transfer Not Ready Enable. */
419 #define TMS570_FLEX_RAY_TEIRER_TNRE BSP_BIT32(1)
420
421 /* field: FACE - Forbidden Access Enable. */
422 #define TMS570_FLEX_RAY_TEIRER_FACE BSP_BIT32(0)
423
424
425 /*-------------------TMS570_FLEX_RAY_TTSMS1-------------------*/
426 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
427 /* Whole 32 bits */
428
429 /*-------------------TMS570_FLEX_RAY_TTSMR1-------------------*/
430 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
431 /* Whole 32 bits */
432
433 /*-------------------TMS570_FLEX_RAY_TTSMS2-------------------*/
434 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
435 /* Whole 32 bits */
436
437 /*-------------------TMS570_FLEX_RAY_TTSMR2-------------------*/
438 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
439 /* Whole 32 bits */
440
441 /*-------------------TMS570_FLEX_RAY_TTSMS3-------------------*/
442 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
443 /* Whole 32 bits */
444
445 /*-------------------TMS570_FLEX_RAY_TTSMR3-------------------*/
446 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
447 /* Whole 32 bits */
448
449 /*-------------------TMS570_FLEX_RAY_TTSMS4-------------------*/
450 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
451 /* Whole 32 bits */
452
453 /*-------------------TMS570_FLEX_RAY_TTSMR4-------------------*/
454 /* field: TTSMS1 - Trigger Transfer to System Memory Set 1. */
455 /* Whole 32 bits */
456
457 /*-------------------TMS570_FLEX_RAY_TTCCS1-------------------*/
458 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
459 /* Whole 32 bits */
460
461 /*-------------------TMS570_FLEX_RAY_TTCCR1-------------------*/
462 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
463 /* Whole 32 bits */
464
465 /*-------------------TMS570_FLEX_RAY_TTCCS2-------------------*/
466 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
467 /* Whole 32 bits */
468
469 /*-------------------TMS570_FLEX_RAY_TTCCR2-------------------*/
470 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
471 /* Whole 32 bits */
472
473 /*-------------------TMS570_FLEX_RAY_TTCCS3-------------------*/
474 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
475 /* Whole 32 bits */
476
477 /*-------------------TMS570_FLEX_RAY_TTCCR3-------------------*/
478 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
479 /* Whole 32 bits */
480
481 /*-------------------TMS570_FLEX_RAY_TTCCS4-------------------*/
482 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
483 /* Whole 32 bits */
484
485 /*-------------------TMS570_FLEX_RAY_TTCCR4-------------------*/
486 /* field: TTCCS1 - Trigger Transfer to Communication Controller Set 1. */
487 /* Whole 32 bits */
488
489 /*------------------TMS570_FLEX_RAY_ETESMS1------------------*/
490 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
491 /* Whole 32 bits */
492
493 /*------------------TMS570_FLEX_RAY_ETESMR1------------------*/
494 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
495 /* Whole 32 bits */
496
497 /*------------------TMS570_FLEX_RAY_ETESMS2------------------*/
498 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
499 /* Whole 32 bits */
500
501 /*------------------TMS570_FLEX_RAY_ETESMR2------------------*/
502 /* field: ETESMS1 - message buffers 0 to 31. */
503 /* Whole 32 bits */
504
505 /*------------------TMS570_FLEX_RAY_ETESMS3------------------*/
506 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
507 /* Whole 32 bits */
508
509 /*------------------TMS570_FLEX_RAY_ETESMR3------------------*/
510 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
511 /* Whole 32 bits */
512
513 /*------------------TMS570_FLEX_RAY_ETESMS4------------------*/
514 /* field: ETESMS1 - Enable Transfer on Event to System Memory Set 1. */
515 /* Whole 32 bits */
516
517 /*------------------TMS570_FLEX_RAY_ETESMR4------------------*/
518 /* field: ETESMS1 - message buffers 0 to 31. */
519 /* Whole 32 bits */
520
521 /*-------------------TMS570_FLEX_RAY_CESMS1-------------------*/
522 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
523 /* Whole 32 bits */
524
525 /*-------------------TMS570_FLEX_RAY_CESMR1-------------------*/
526 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
527 /* Whole 32 bits */
528
529 /*-------------------TMS570_FLEX_RAY_CESMS2-------------------*/
530 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
531 /* Whole 32 bits */
532
533 /*-------------------TMS570_FLEX_RAY_CESMR2-------------------*/
534 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
535 /* Whole 32 bits */
536
537 /*-------------------TMS570_FLEX_RAY_CESMS3-------------------*/
538 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
539 /* Whole 32 bits */
540
541 /*-------------------TMS570_FLEX_RAY_CESMR3-------------------*/
542 /* field: CESMS1 - CESMS1(31-0) */
543 /* Whole 32 bits */
544
545 /*-------------------TMS570_FLEX_RAY_CESMS4-------------------*/
546 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
547 /* Whole 32 bits */
548
549 /*-------------------TMS570_FLEX_RAY_CESMR4-------------------*/
550 /* field: CESMS1 - Clear on Event to System Memory Set 1. */
551 /* Whole 32 bits */
552
553 /*------------------TMS570_FLEX_RAY_TSMIES1------------------*/
554 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
555 /* Whole 32 bits */
556
557 /*------------------TMS570_FLEX_RAY_TSMIER1------------------*/
558 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
559 /* Whole 32 bits */
560
561 /*------------------TMS570_FLEX_RAY_TSMIES2------------------*/
562 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
563 /* Whole 32 bits */
564
565 /*------------------TMS570_FLEX_RAY_TSMIER2------------------*/
566 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
567 /* Whole 32 bits */
568
569 /*------------------TMS570_FLEX_RAY_TSMIES3------------------*/
570 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
571 /* Whole 32 bits */
572
573 /*------------------TMS570_FLEX_RAY_TSMIER3------------------*/
574 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
575 /* Whole 32 bits */
576
577 /*------------------TMS570_FLEX_RAY_TSMIES4------------------*/
578 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
579 /* Whole 32 bits */
580
581 /*------------------TMS570_FLEX_RAY_TSMIER4------------------*/
582 /* field: TTSMIES1 - Transfer to System Memory Interrupt Enable Set 1. */
583 /* Whole 32 bits */
584
585 /*------------------TMS570_FLEX_RAY_TCCIES1------------------*/
586 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
587 /* Whole 32 bits */
588
589 /*------------------TMS570_FLEX_RAY_TCCIER1------------------*/
590 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
591 /* Whole 32 bits */
592
593 /*------------------TMS570_FLEX_RAY_TCCIES2------------------*/
594 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
595 /* Whole 32 bits */
596
597 /*------------------TMS570_FLEX_RAY_TCCIER2------------------*/
598 /* field: TCCIES1 - to message buffers 0 to 31. */
599 /* Whole 32 bits */
600
601 /*------------------TMS570_FLEX_RAY_TCCIES3------------------*/
602 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
603 /* Whole 32 bits */
604
605 /*------------------TMS570_FLEX_RAY_TCCIER3------------------*/
606 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
607 /* Whole 32 bits */
608
609 /*------------------TMS570_FLEX_RAY_TCCIES4------------------*/
610 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
611 /* Whole 32 bits */
612
613 /*------------------TMS570_FLEX_RAY_TCCIER4------------------*/
614 /* field: TCCIES1 - Transfer to Communication Controller Interrupt Enable Set 1. */
615 /* Whole 32 bits */
616
617
618 #endif /* LIBBSP_ARM_TMS570_FLEX_RAY */
Definition: reg_flex_ray.h:44
Utility macros.
