RTEMS  5.1
reg_flash.h
1 /* The header file is generated by make_header.py from FLASH.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_FLASH
40 #define LIBBSP_ARM_TMS570_FLASH
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t FRDCNTL; /*Flash Option Control Register*/
46  uint8_t reserved1 [4];
47  uint32_t FEDACTRL1; /*Flash Error Detection and Correction Control Register 1*/
48  uint32_t FEDACTRL2; /*Flash Error Detection and Correction Control Register 2*/
49  uint32_t FCORERRCNT; /*Flash Correctable Error Count Register*/
50  uint32_t FCORERRADD; /*Flash Correctable Error Address Register*/
51  uint32_t FCORERRPOS; /*Flash Correctable Error Position Register*/
52  uint32_t FEDACSTATUS; /*Flash Error Detection and Correction Status Register*/
53  uint32_t FUNCERRADD; /*Flash Un-Correctable Error Address Register*/
54  uint32_t FEDACSDIS; /*Flash Error Detection and Correction Sector Disable Register*/
55  uint32_t FPRIMADDTAG; /*Flash Primary Address Tag Register*/
56  uint32_t FDUPADDTAG; /*Flash Duplicate Address Tag Register*/
57  uint32_t FBPROT; /*Flash Bank Protection Register*/
58  uint32_t FBSE; /*Flash Bank Sector Enable Register*/
59  uint32_t FBBUSY; /*Flash Bank Busy Register*/
60  uint32_t FBAC; /*Flash Bank Access Control Register*/
61  uint32_t FBFALLBACK; /*Flash Bank Fallback Power Register*/
62  uint32_t FBPRDY; /*Flash Bank/Pump Ready Register*/
63  uint32_t FPAC1; /*Flash Pump Access Control Register 1*/
64  uint32_t FPAC2; /*Flash Pump Access Control Register 2*/
65  uint32_t FMAC; /*Flash Module Access Control Register*/
66  uint32_t FMSTAT; /*Flash Module Status Register*/
67  uint32_t FEMUDMSW; /*EEPROM Emulation Data MSW Register*/
68  uint32_t FEMUDLSW; /*EEPROM Emulation Data LSW Register*/
69  uint32_t FEMUECC; /*EEPROM Emulation ECC Register*/
70  uint8_t reserved2 [4];
71  uint32_t FEMUADDR; /*EEPROM Emulation Address Register*/
72  uint32_t FDIAGCTRL; /*Diagnostic Control Register*/
73  uint32_t FRAWDATAH; /*Uncorrected Raw Data High Register*/
74  uint32_t FRAWDATAL; /*Uncorrected Raw Data Low Register*/
75  uint32_t FRAWECC; /*Uncorrected Raw ECC Register*/
76  uint32_t FPAROVR; /*Parity Override Register*/
77  uint8_t reserved3 [64];
78  uint32_t FEDACSDIS2; /*Flash Error Detection and Correction Sector Disable Register 2*/
79  uint8_t reserved4 [452];
80  uint32_t FSMWRENA; /*FSM Register Write Enable*/
81  uint8_t reserved5 [24];
82  uint32_t FSMSECTOR; /*FSM Sector Register*/
83  uint8_t reserved6 [16];
84  uint32_t EEPROMCONFIG; /*EEPROM Emulation Configuration Register*/
85  uint8_t reserved7 [76];
86  uint32_t EECTRL1; /*EEPROM Emulation Error Detection and Correction Control Register 1*/
87  uint32_t EECTRL2; /*EEPROM Emulation Error Detection and Correction Control Register 2*/
88  uint32_t EECORERRCNT; /*EEPROM Emulation Correctable Error Count Register*/
89  uint32_t EECORERRADD; /*EEPROM Emulation Correctable Error Address Register*/
90  uint32_t EECORERRPOS; /*EEPROM Emulation Correctable Error Bit Position Register*/
91  uint32_t EESTATUS; /*EEPROM Emulation Error Status Register*/
92  uint32_t EEUNCERRADD; /*EEPROM Emulation Un-Correctable Error Address Register*/
93  uint8_t reserved8 [220];
94  uint32_t FCFGBANK; /*Flash Bank Configuration Register*/
96
97
98 /*--------------------TMS570_FLASH_FRDCNTL--------------------*/
99 /* field: RWAIT - Random/data Read Wait State */
100 #define TMS570_FLASH_FRDCNTL_RWAIT(val) BSP_FLD32(val,8, 11)
101 #define TMS570_FLASH_FRDCNTL_RWAIT_GET(reg) BSP_FLD32GET(reg,8, 11)
102 #define TMS570_FLASH_FRDCNTL_RWAIT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
103
104 /* field: ASWSTEN - Address Setup Wait State Enable */
105 #define TMS570_FLASH_FRDCNTL_ASWSTEN BSP_BIT32(4)
106
107 /* field: ENPIPE - Enable Pipeline Mode */
108 #define TMS570_FLASH_FRDCNTL_ENPIPE BSP_BIT32(0)
109
110
111 /*-------------------TMS570_FLASH_FEDACTRL1-------------------*/
112 /* field: SUSP_IGNR - Suspend Ignore. */
113 #define TMS570_FLASH_FEDACTRL1_SUSP_IGNR BSP_BIT32(24)
114
115 /* field: EDACMODE - Error Correction Mode. */
116 #define TMS570_FLASH_FEDACTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
117 #define TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
118 #define TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
119
120 /* field: EOFEN - Event on Ones Fail Enable */
121 #define TMS570_FLASH_FEDACTRL1_EOFEN BSP_BIT32(10)
122
123 /* field: EZFEN - Event on Zeros Fail Enable */
124 #define TMS570_FLASH_FEDACTRL1_EZFEN BSP_BIT32(9)
125
126 /* field: EPEN - Error Profiling Enable. */
127 #define TMS570_FLASH_FEDACTRL1_EPEN BSP_BIT32(8)
128
129 /* field: EDACEN - Error Detection and Correction Enable */
130 #define TMS570_FLASH_FEDACTRL1_EDACEN(val) BSP_FLD32(val,0, 3)
131 #define TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg) BSP_FLD32GET(reg,0, 3)
132 #define TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
133
134
135 /*-------------------TMS570_FLASH_FEDACTRL2-------------------*/
136 /* field: SEC_THRESHOLD - Single Error Correction Threshold */
137 #define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
138 #define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
139 #define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
140
141
142 /*------------------TMS570_FLASH_FCORERRCNT------------------*/
143 /* field: FERRCNT - Single Error Correction Count */
144 #define TMS570_FLASH_FCORERRCNT_FERRCNT(val) BSP_FLD32(val,0, 15)
145 #define TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
146 #define TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
147
148
149 /*------------------TMS570_FLASH_FCORERRADD------------------*/
150 /* field: COR_ERR_ADD - Correctable Error Address */
151 #define TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
152 #define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
153 #define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
154
155 /* field: B_OFF - Byte Offset */
156 #define TMS570_FLASH_FCORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
157 #define TMS570_FLASH_FCORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
158 #define TMS570_FLASH_FCORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
159
160
161 /*------------------TMS570_FLASH_FCORERRPOS------------------*/
162 /* field: BUS2 - Bus 2 Error */
163 #define TMS570_FLASH_FCORERRPOS_BUS2 BSP_BIT32(9)
164
165 /* field: TYPE - ErrorType */
166 #define TMS570_FLASH_FCORERRPOS_TYPE BSP_BIT32(8)
167
168 /* field: ERR_POS - The bit address of the single bit error */
169 #define TMS570_FLASH_FCORERRPOS_ERR_POS(val) BSP_FLD32(val,0, 7)
170 #define TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
171 #define TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
172
173
174 /*------------------TMS570_FLASH_FEDACSTATUS------------------*/
175 /* field: Reserved - Read returns 0. Writes have no effect. */
176 #define TMS570_FLASH_FEDACSTATUS_Reserved(val) BSP_FLD32(val,26, 31)
177 #define TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg) BSP_FLD32GET(reg,26, 31)
178 #define TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
179
180 /* field: FSM_DONE - Flash State Machine Done */
181 #define TMS570_FLASH_FEDACSTATUS_FSM_DONE BSP_BIT32(24)
182
183 /* field: COMB2_MAL_G - Bus 2 Compare Malfunction Flag. */
184 #define TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G BSP_BIT32(19)
185
186 /* field: ECC_B2_MAL_ - Bus 2 ECC Malfunction Error Flag */
187 #define TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_ BSP_BIT32(18)
188
189 /* field: B2_UNC_ERR - Bus 2 uncorrectable error */
190 #define TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR BSP_BIT32(17)
191
192 /* field: B2_COR_ERR - Bus 2 Correctable Error */
193 #define TMS570_FLASH_FEDACSTATUS_B2_COR_ERR BSP_BIT32(16)
194
195 /* field: D_UNC_ERR - Diagnostic Uncorrectable Error */
196 #define TMS570_FLASH_FEDACSTATUS_D_UNC_ERR BSP_BIT32(12)
197
198 /* field: ADD_TAG_ERR - Address Tag Register Error Flag */
199 #define TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR BSP_BIT32(11)
200
201 /* field: ADD_PAR_ERR - Address Parity Error Flag */
202 #define TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR BSP_BIT32(10)
203
204 /* field: B1_UNC_ERR - Bus 1 Uncorrectable Error Flag */
205 #define TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR BSP_BIT32(8)
206
207 /* field: D_CORR_ERR - Diagnostic Correctable Error Status Flag */
208 #define TMS570_FLASH_FEDACSTATUS_D_CORR_ERR BSP_BIT32(3)
209
210 /* field: ERR_ONE_FLG - Error on One Fail Status Flag */
211 #define TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG BSP_BIT32(2)
212
213 /* field: ERR_ZERO__FLG - Error on Zero Fail Status Flag */
214 #define TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG BSP_BIT32(1)
215
216 /* field: ERR_PRF_FLG - Error Profiling Status Flag */
217 #define TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG BSP_BIT32(0)
218
219
220 /*------------------TMS570_FLASH_FUNCERRADD------------------*/
221 /* field: UNC_ERR_ADD - Un-correctable Error Address */
222 #define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
223 #define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
224 #define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
225
226 /* field: B_OFF - Byte offset */
227 #define TMS570_FLASH_FUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
228 #define TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
229 #define TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
230
231
232 /*-------------------TMS570_FLASH_FEDACSDIS-------------------*/
233 /* field: BankID1_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
234 #define TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val) BSP_FLD32(val,29, 31)
235 #define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
236 #define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
237
238 /* field: SectorID1_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
239 #define TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val) BSP_FLD32(val,24, 27)
240 #define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
241 #define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
242
243 /* field: BankID1 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
244 #define TMS570_FLASH_FEDACSDIS_BankID1(val) BSP_FLD32(val,21, 23)
245 #define TMS570_FLASH_FEDACSDIS_BankID1_GET(reg) BSP_FLD32GET(reg,21, 23)
246 #define TMS570_FLASH_FEDACSDIS_BankID1_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
247
248 /* field: SectorID1 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
249 #define TMS570_FLASH_FEDACSDIS_SectorID1(val) BSP_FLD32(val,16, 19)
250 #define TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg) BSP_FLD32GET(reg,16, 19)
251 #define TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
252
253 /* field: BankID0_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
254 #define TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val) BSP_FLD32(val,13, 15)
255 #define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
256 #define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
257
258 /* field: SectorID0_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
259 #define TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val) BSP_FLD32(val,8, 11)
260 #define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
261 #define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
262
263 /* field: BankID0 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
264 #define TMS570_FLASH_FEDACSDIS_BankID0(val) BSP_FLD32(val,5, 7)
265 #define TMS570_FLASH_FEDACSDIS_BankID0_GET(reg) BSP_FLD32GET(reg,5, 7)
266 #define TMS570_FLASH_FEDACSDIS_BankID0_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
267
268 /* field: SectorID0 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
269 #define TMS570_FLASH_FEDACSDIS_SectorID0(val) BSP_FLD32(val,0, 3)
270 #define TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg) BSP_FLD32GET(reg,0, 3)
271 #define TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
272
273
274 /*------------------TMS570_FLASH_FPRIMADDTAG------------------*/
275 /* field: PRIM_ADD_TAG - Primary Address Tag Register */
276 #define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val) BSP_FLD32(val,4, 31)
277 #define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
278 #define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
279
280 /* field: 0 - Always 0000 */
281 #define TMS570_FLASH_FPRIMADDTAG_0(val) BSP_FLD32(val,0, 3)
282 #define TMS570_FLASH_FPRIMADDTAG_0_GET(reg) BSP_FLD32GET(reg,0, 3)
283 #define TMS570_FLASH_FPRIMADDTAG_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
284
285
286 /*------------------TMS570_FLASH_FDUPADDTAG------------------*/
287 /* field: DUP_ADD_TAG - Primary Address Tag Register */
288 #define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val) BSP_FLD32(val,4, 31)
289 #define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
290 #define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
291
292
293 /*--------------------TMS570_FLASH_FBPROT--------------------*/
294 /* field: PROTL1DIS - PROTL1DIS: Level 1 Protection Disabled */
295 #define TMS570_FLASH_FBPROT_PROTL1DIS BSP_BIT32(0)
296
297
298 /*---------------------TMS570_FLASH_FBSE---------------------*/
299 /* field: BSE - Bank Sector Enable */
300 #define TMS570_FLASH_FBSE_BSE(val) BSP_FLD32(val,0, 15)
301 #define TMS570_FLASH_FBSE_BSE_GET(reg) BSP_FLD32GET(reg,0, 15)
302 #define TMS570_FLASH_FBSE_BSE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
303
304
305 /*--------------------TMS570_FLASH_FBBUSY--------------------*/
306 /* field: BUSY - Bank Busy */
307 #define TMS570_FLASH_FBBUSY_BUSY(val) BSP_FLD32(val,0, 7)
308 #define TMS570_FLASH_FBBUSY_BUSY_GET(reg) BSP_FLD32GET(reg,0, 7)
309 #define TMS570_FLASH_FBBUSY_BUSY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
310
311
312 /*---------------------TMS570_FLASH_FBAC---------------------*/
313 /* field: OTPPROTDIS - OTP Sector Protection Disable. */
314 #define TMS570_FLASH_FBAC_OTPPROTDIS(val) BSP_FLD32(val,16, 23)
315 #define TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg) BSP_FLD32GET(reg,16, 23)
316 #define TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
317
318 /* field: 15_8 - BAGP 0-FFh Bank Active Grace Period. */
319 #define TMS570_FLASH_FBAC_15_8(val) BSP_FLD32(val,8, 15)
320 #define TMS570_FLASH_FBAC_15_8_GET(reg) BSP_FLD32GET(reg,8, 15)
321 #define TMS570_FLASH_FBAC_15_8_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
322
323 /* field: VREADST - VREAD Setup. */
324 #define TMS570_FLASH_FBAC_VREADST(val) BSP_FLD32(val,0, 7)
325 #define TMS570_FLASH_FBAC_VREADST_GET(reg) BSP_FLD32GET(reg,0, 7)
326 #define TMS570_FLASH_FBAC_VREADST_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
327
328
329 /*------------------TMS570_FLASH_FBFALLBACK------------------*/
330 /* field: BANKPWR7 - Bank 7 Fallback Power Mode */
331 #define TMS570_FLASH_FBFALLBACK_BANKPWR7(val) BSP_FLD32(val,14, 15)
332 #define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg) BSP_FLD32GET(reg,14, 15)
333 #define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
334
335 /* field: BANKPWR1 - Bank 1 Fallback Power Mode */
336 #define TMS570_FLASH_FBFALLBACK_BANKPWR1(val) BSP_FLD32(val,2, 3)
337 #define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg) BSP_FLD32GET(reg,2, 3)
338 #define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
339
340 /* field: BANKPWR0 - Bank 0 Fallback Power Mode */
341 #define TMS570_FLASH_FBFALLBACK_BANKPWR0(val) BSP_FLD32(val,0, 1)
342 #define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg) BSP_FLD32GET(reg,0, 1)
343 #define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
344
345
346 /*--------------------TMS570_FLASH_FBPRDY--------------------*/
347 /* field: BANKBUSY - Bank busy bits (one bit for each bank) */
348 #define TMS570_FLASH_FBPRDY_BANKBUSY(val) BSP_FLD32(val,16, 23)
349 #define TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg) BSP_FLD32GET(reg,16, 23)
350 #define TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
351
352 /* field: PUMPRDY - Flash pump ready flag */
353 #define TMS570_FLASH_FBPRDY_PUMPRDY BSP_BIT32(15)
354
355 /* field: BANKRDY - Bank ready bits (one bit for each bank) */
356 #define TMS570_FLASH_FBPRDY_BANKRDY(val) BSP_FLD32(val,0, 7)
357 #define TMS570_FLASH_FBPRDY_BANKRDY_GET(reg) BSP_FLD32GET(reg,0, 7)
358 #define TMS570_FLASH_FBPRDY_BANKRDY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
359
360
361 /*---------------------TMS570_FLASH_FPAC1---------------------*/
362 /* field: PSLEEP - Pump Sleep. */
363 #define TMS570_FLASH_FPAC1_PSLEEP(val) BSP_FLD32(val,16, 26)
364 #define TMS570_FLASH_FPAC1_PSLEEP_GET(reg) BSP_FLD32GET(reg,16, 26)
365 #define TMS570_FLASH_FPAC1_PSLEEP_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
366
367 /* field: PUMPPWR - Flash Charge Pump Fallback Power Mode */
368 #define TMS570_FLASH_FPAC1_PUMPPWR BSP_BIT32(0)
369
370
371 /*---------------------TMS570_FLASH_FPAC2---------------------*/
372 /* field: PAGP - Pump Active Grace Period */
373 #define TMS570_FLASH_FPAC2_PAGP(val) BSP_FLD32(val,0, 15)
374 #define TMS570_FLASH_FPAC2_PAGP_GET(reg) BSP_FLD32GET(reg,0, 15)
375 #define TMS570_FLASH_FPAC2_PAGP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
376
377
378 /*---------------------TMS570_FLASH_FMAC---------------------*/
379 /* field: BANK - Bank Enable. */
380 #define TMS570_FLASH_FMAC_BANK(val) BSP_FLD32(val,0, 2)
381 #define TMS570_FLASH_FMAC_BANK_GET(reg) BSP_FLD32GET(reg,0, 2)
382 #define TMS570_FLASH_FMAC_BANK_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
383
384
385 /*--------------------TMS570_FLASH_FMSTAT--------------------*/
386 /* field: ILA - Illegal Address */
387 #define TMS570_FLASH_FMSTAT_ILA BSP_BIT32(14)
388
389 /* field: PGV - Program Verify */
390 #define TMS570_FLASH_FMSTAT_PGV BSP_BIT32(12)
391
392 /* field: EV - Erase Verify */
393 #define TMS570_FLASH_FMSTAT_EV BSP_BIT32(10)
394
395 /* field: BUSY - Busy */
396 #define TMS570_FLASH_FMSTAT_BUSY BSP_BIT32(8)
397
398 /* field: ERS - Erase Active */
399 #define TMS570_FLASH_FMSTAT_ERS BSP_BIT32(7)
400
401 /* field: PGM - Program Active */
402 #define TMS570_FLASH_FMSTAT_PGM BSP_BIT32(6)
403
404 /* field: INVDAT - Invalid Data */
405 #define TMS570_FLASH_FMSTAT_INVDAT BSP_BIT32(5)
406
407 /* field: CSTAT - Command Status */
408 #define TMS570_FLASH_FMSTAT_CSTAT BSP_BIT32(4)
409
410 /* field: VOLTSTAT - Core Voltage Status */
411 #define TMS570_FLASH_FMSTAT_VOLTSTAT BSP_BIT32(3)
412
413 /* field: ESUSP - Erase Suspended */
414 #define TMS570_FLASH_FMSTAT_ESUSP BSP_BIT32(2)
415
416 /* field: PSUSP - Program Suspended */
417 #define TMS570_FLASH_FMSTAT_PSUSP BSP_BIT32(1)
418
419 /* field: SLOCK - Sector Lock Status */
420 #define TMS570_FLASH_FMSTAT_SLOCK BSP_BIT32(0)
421
422
423 /*-------------------TMS570_FLASH_FEMUDMSW-------------------*/
424 /* field: EMU_DMSW - EEPROM Emulation Most Significant Data Word */
425 /* Whole 32 bits */
426
427 /*-------------------TMS570_FLASH_FEMUDLSW-------------------*/
428 /* field: EMU_DLSW - EEPROM Emulation Least Significant Data Word */
429 /* Whole 32 bits */
430
431 /*--------------------TMS570_FLASH_FEMUECC--------------------*/
432 /* field: EMU_ECC - This register can be written by the CPU in any mode. */
433 #define TMS570_FLASH_FEMUECC_EMU_ECC(val) BSP_FLD32(val,0, 7)
434 #define TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
435 #define TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
436
437
438 /*-------------------TMS570_FLASH_FEMUADDR-------------------*/
439 /* field: EMU_ADDR - EEPROM Emulation Address */
440 #define TMS570_FLASH_FEMUADDR_EMU_ADDR(val) BSP_FLD32(val,3, 21)
441 #define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg) BSP_FLD32GET(reg,3, 21)
442 #define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,3, 21)
443
444
445 /*-------------------TMS570_FLASH_FDIAGCTRL-------------------*/
446 /* field: DIAG_TRIG - Diagnostic Trigger */
447 #define TMS570_FLASH_FDIAGCTRL_DIAG_TRIG BSP_BIT32(24)
448
449 /* field: DIAG_EN_KEY - Diagnostic Enable Key */
450 #define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val) BSP_FLD32(val,16, 19)
451 #define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
452 #define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
453
454 /* field: DIAG_ECC_SEL - Diagnostic SECDED Select */
455 #define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val) BSP_FLD32(val,12, 14)
456 #define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg) BSP_FLD32GET(reg,12, 14)
457 #define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
458
459
460 /*-------------------TMS570_FLASH_FRAWDATAH-------------------*/
461 /* field: RAW_DATA_ - Uncorrected Raw Data */
462 /* Whole 32 bits */
463
464 /*-------------------TMS570_FLASH_FRAWDATAL-------------------*/
465 /* field: RAW_DATA_ - Uncorrected Raw Data. Same as FRAW_DATAH but stores lower 32 bits. */
466 /* Whole 32 bits */
467
468 /*--------------------TMS570_FLASH_FRAWECC--------------------*/
469 /* field: PIPE_BUF - Error came from pipeline buffer hit */
470 #define TMS570_FLASH_FRAWECC_PIPE_BUF BSP_BIT32(8)
471
472 /* field: RAW_ECC - Uncorrected Raw ECC */
473 #define TMS570_FLASH_FRAWECC_RAW_ECC(val) BSP_FLD32(val,0, 7)
474 #define TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
475 #define TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
476
477
478 /*--------------------TMS570_FLASH_FPAROVR--------------------*/
479 /* field: BNK_INV_PAR - Buffer Invert Parity */
480 #define TMS570_FLASH_FPAROVR_BNK_INV_PAR BSP_BIT32(16)
481
482 /* field: BUS_PAR_DIS - Disable Bus Parity */
483 #define TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val) BSP_FLD32(val,12, 15)
484 #define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg) BSP_FLD32GET(reg,12, 15)
485 #define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
486
487 /* field: PAR_OVR_KEY - When this value is 101, the selected ADD_INV_PAR and DAT_INV_PAR fields will become active. */
488 #define TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val) BSP_FLD32(val,9, 11)
489 #define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg) BSP_FLD32GET(reg,9, 11)
490 #define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
491
492 /* field: ADD_INV_PAR - Address Odd Parity */
493 #define TMS570_FLASH_FPAROVR_ADD_INV_PAR BSP_BIT32(8)
494
495 /* field: DAT_INV_PAR - Data Odd Parity */
496 #define TMS570_FLASH_FPAROVR_DAT_INV_PAR(val) BSP_FLD32(val,0, 7)
497 #define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg) BSP_FLD32GET(reg,0, 7)
498 #define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
499
500
501 /*------------------TMS570_FLASH_FEDACSDIS2------------------*/
502 /* field: BankID3_Inverse - The bank ID inverse bits are used with the bank ID bits to select the bank for which a sector */
503 #define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val) BSP_FLD32(val,29, 31)
504 #define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
505 #define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
506
507 /* field: SectorID3_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is disabled. */
508 #define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val) BSP_FLD32(val,24, 27)
509 #define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
510 #define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
511
512 /* field: BankID3 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
513 #define TMS570_FLASH_FEDACSDIS2_BankID3(val) BSP_FLD32(val,21, 23)
514 #define TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg) BSP_FLD32GET(reg,21, 23)
515 #define TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
516
517 /* field: SectorID3 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
518 #define TMS570_FLASH_FEDACSDIS2_SectorID3(val) BSP_FLD32(val,16, 19)
519 #define TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg) BSP_FLD32GET(reg,16, 19)
520 #define TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
521
522 /* field: BankID2_Inverse - is disabled. The only bank that supports sector disable is bank 7. */
523 #define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val) BSP_FLD32(val,13, 15)
524 #define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
525 #define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
526
527 /* field: SectorID2_inverse - The sector ID inverse bits are used with the sector ID bits to determine which sector is */
528 #define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val) BSP_FLD32(val,8, 11)
529 #define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
530 #define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
531
532 /* field: BankID2 - The bank ID bits are used with the bank ID inverse bits to select the bank for which a sector */
533 #define TMS570_FLASH_FEDACSDIS2_BankID2(val) BSP_FLD32(val,5, 7)
534 #define TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg) BSP_FLD32GET(reg,5, 7)
535 #define TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
536
537 /* field: SectorID2 - The sector ID bits are used with the sector ID inverse bits to determine which sector is */
538 #define TMS570_FLASH_FEDACSDIS2_SectorID2(val) BSP_FLD32(val,0, 3)
539 #define TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg) BSP_FLD32GET(reg,0, 3)
540 #define TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
541
542
543 /*-------------------TMS570_FLASH_FSMWRENA-------------------*/
544 /* field: WR_ENA - Flash State Machine Write Enable */
545 #define TMS570_FLASH_FSMWRENA_WR_ENA(val) BSP_FLD32(val,0, 2)
546 #define TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg) BSP_FLD32GET(reg,0, 2)
547 #define TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
548
549
550 /*-------------------TMS570_FLASH_FSMSECTOR-------------------*/
551 /* field: SECT_ERASED - Sectors Erased */
552 #define TMS570_FLASH_FSMSECTOR_SECT_ERASED(val) BSP_FLD32(val,16, 31)
553 #define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg) BSP_FLD32GET(reg,16, 31)
554 #define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
555
556
557 /*-----------------TMS570_FLASH_EEPROMCONFIG-----------------*/
558 /* field: EWAIT - EEPROM Wait state Counter */
559 #define TMS570_FLASH_EEPROMCONFIG_EWAIT(val) BSP_FLD32(val,16, 19)
560 #define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg) BSP_FLD32GET(reg,16, 19)
561 #define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
562
563 /* field: AUTOSUSP_EN - Auto Suspend Enable */
564 #define TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN BSP_BIT32(8)
565
566 /* field: AUTOSTART_GRACE - Auto-suspend Startup Grace Period */
567 #define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val) BSP_FLD32(val,0, 7)
568 #define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg) BSP_FLD32GET(reg,0, 7)
569 #define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
570
571
572 /*--------------------TMS570_FLASH_EECTRL1--------------------*/
573 /* field: EDACMODE - Error Correction Mode. */
574 #define TMS570_FLASH_EECTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
575 #define TMS570_FLASH_EECTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
576 #define TMS570_FLASH_EECTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
577
578 /* field: EE_EOFEN - EEPROM Emulation Event on a correctable One's Fail Enable bit */
579 #define TMS570_FLASH_EECTRL1_EE_EOFEN BSP_BIT32(10)
580
581 /* field: EE_EZFEN - EEPROM Emulation Event on a correctable Zero's Fail Enable bit */
582 #define TMS570_FLASH_EECTRL1_EE_EZFEN BSP_BIT32(9)
583
584 /* field: EE_EPEN - EEPROM Emulation Error Profiling Enable. */
585 #define TMS570_FLASH_EECTRL1_EE_EPEN BSP_BIT32(8)
586
587
588 /*--------------------TMS570_FLASH_EECTRL2--------------------*/
589 /* field: EE_SEC_THRESHOLD - EEPROM Emulation Single Error Correction Threshold */
590 #define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
591 #define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
592 #define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
593
594
595 /*------------------TMS570_FLASH_EECORERRCNT------------------*/
596 /* field: EE_ERRCNT - Single Error Correction Count */
597 #define TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val) BSP_FLD32(val,0, 15)
598 #define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
599 #define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
600
601
602 /*------------------TMS570_FLASH_EECORERRADD------------------*/
603 /* field: COR_ERR_ADD - Correctable Error Address */
604 #define TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
605 #define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
606 #define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
607
608 /* field: B_OFF - Byte offset */
609 #define TMS570_FLASH_EECORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
610 #define TMS570_FLASH_EECORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
611 #define TMS570_FLASH_EECORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
612
613
614 /*------------------TMS570_FLASH_EECORERRPOS------------------*/
615 /* field: TYPE - ErrorType */
616 #define TMS570_FLASH_EECORERRPOS_TYPE BSP_BIT32(8)
617
618 /* field: EE_ERR_POS - The bit address of the single bit error */
619 #define TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val) BSP_FLD32(val,0, 7)
620 #define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
621 #define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
622
623
624 /*-------------------TMS570_FLASH_EESTATUS-------------------*/
625 /* field: EE_D_UNC_ERR - Diagnostic Mode Uncorrectable Error Status Flag */
626 #define TMS570_FLASH_EESTATUS_EE_D_UNC_ERR BSP_BIT32(12)
627
628 /* field: EE_UNC_ERR - EEPROM Emulation Uncorrectable Error Flag */
629 #define TMS570_FLASH_EESTATUS_EE_UNC_ERR BSP_BIT32(8)
630
631 /* field: EE_CMG - EEPROM Emulation Compare Malfunction Good */
632 #define TMS570_FLASH_EESTATUS_EE_CMG BSP_BIT32(6)
633
634 /* field: EE_CME - . */
635 #define TMS570_FLASH_EESTATUS_EE_CME BSP_BIT32(4)
636
637 /* field: EE_D_COR_ERR - Diagnostic Correctable Error Flag */
638 #define TMS570_FLASH_EESTATUS_EE_D_COR_ERR BSP_BIT32(3)
639
640 /* field: EE_ERR_ONE_FLG - Error on One Fail Error Flag */
641 #define TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG BSP_BIT32(2)
642
643 /* field: EE_ERR_ZERO_FLG - Error on Zero Fail Error Flag */
644 #define TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG BSP_BIT32(1)
645
646 /* field: EE_ERR_PRF_FLG - Error Profiling Error Flag */
647 #define TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG BSP_BIT32(0)
648
649
650 /*------------------TMS570_FLASH_EEUNCERRADD------------------*/
651 /* field: UNC_ERR_ADD - Un-correctable Error Address */
652 #define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
653 #define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
654 #define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
655
656 /* field: B_OFF - Byte offset */
657 #define TMS570_FLASH_EEUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
658 #define TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
659 #define TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
660
661
662 /*-------------------TMS570_FLASH_FCFGBANK-------------------*/
663 /* field: EE_BANK_WIDTH - Bank 7 width (144 bits wide) */
664 #define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val) BSP_FLD32(val,20, 31)
665 #define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,20, 31)
666 #define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,20, 31)
667
668 /* field: MAIN_BANK_WIDTH - Width of main flash banks (144 bits wide) */
669 #define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val) BSP_FLD32(val,4, 15)
670 #define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,4, 15)
671 #define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,4, 15)
672
673
674
675 #endif /* LIBBSP_ARM_TMS570_FLASH */
Definition: reg_flash.h:44
Utility macros.
