RTEMS  5.1
reg_emif.h
1 /* The header file is generated by make_header.py from EMIF.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_EMIF
40 #define LIBBSP_ARM_TMS570_EMIF
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t MIDR; /*Module ID Register*/
46  uint32_t AWCC; /*Asynchronous Wait Cycle Configuration Register*/
47  uint32_t SDCR; /*SDRAM Configuration Register*/
48  uint32_t SDRCR; /*SDRAM Refresh Control Register*/
49  uint32_t CE2CFG; /*Asynchronous 1 Configuration Register*/
50  uint32_t CE3CFG; /*Asynchronous 2 Configuration Register*/
51  uint32_t CE4CFG; /*Asynchronous 3 Configuration Register*/
52  uint32_t CE5CFG; /*Asynchronous 4 Configuration Register*/
53  uint32_t SDTIMR; /*SDRAM Timing Register*/
54  uint8_t reserved1 [24];
55  uint32_t SDSRETR; /*SDRAM Self Refresh Exit Timing Register*/
56  uint32_t INTRAW; /*EMIF Interrupt Raw Register*/
57  uint32_t INTMSK; /*EMIF Interrupt Mask Register*/
58  uint32_t INTMSKSET; /*EMIF Interrupt Mask Set Register*/
59  uint32_t INTMSKCLR; /*EMIF Interrupt Mask Clear Register*/
60  uint8_t reserved2 [24];
61  uint32_t PMCR; /*Page Mode Control Register*/
63
64
65 /*----------------------TMS570_EMIF_MIDR----------------------*/
66 /* field: REV - Module ID of EMIF. See the device-specific data manual. */
67 /* Whole 32 bits */
68
69 /*----------------------TMS570_EMIF_AWCC----------------------*/
70 /* field: WP1 - EMIF_nWAIT[1] polarity bit. This bit defines the polarity of the EMIF_nWAIT[1] pin. */
71 #define TMS570_EMIF_AWCC_WP1 BSP_BIT32(29)
72
73 /* field: WP0 - EMIF_nWAIT[0] polarity bit. This bit defines the polarity of the EMIF_nWAIT[0] pin. */
74 #define TMS570_EMIF_AWCC_WP0 BSP_BIT32(28)
75
76 /* field: CS5_WAIT - Chip Select 5 WAIT signal selection. */
77 #define TMS570_EMIF_AWCC_CS5_WAIT(val) BSP_FLD32(val,22, 23)
78 #define TMS570_EMIF_AWCC_CS5_WAIT_GET(reg) BSP_FLD32GET(reg,22, 23)
79 #define TMS570_EMIF_AWCC_CS5_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,22, 23)
80
81 /* field: CS4_WAIT - Chip Select 4 WAIT signal selection. */
82 #define TMS570_EMIF_AWCC_CS4_WAIT(val) BSP_FLD32(val,20, 21)
83 #define TMS570_EMIF_AWCC_CS4_WAIT_GET(reg) BSP_FLD32GET(reg,20, 21)
84 #define TMS570_EMIF_AWCC_CS4_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,20, 21)
85
86 /* field: CS3_WAIT - be used for memory accesses to chip select 3 memory space. */
87 #define TMS570_EMIF_AWCC_CS3_WAIT(val) BSP_FLD32(val,18, 19)
88 #define TMS570_EMIF_AWCC_CS3_WAIT_GET(reg) BSP_FLD32GET(reg,18, 19)
89 #define TMS570_EMIF_AWCC_CS3_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,18, 19)
90
91 /* field: CS2_WAIT - Chip Select 2 WAIT signal selection. */
92 #define TMS570_EMIF_AWCC_CS2_WAIT(val) BSP_FLD32(val,16, 17)
93 #define TMS570_EMIF_AWCC_CS2_WAIT_GET(reg) BSP_FLD32GET(reg,16, 17)
94 #define TMS570_EMIF_AWCC_CS2_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
95
96 /* field: MAX_EXT_WAIT - Maximum extended wait cycles. */
97 #define TMS570_EMIF_AWCC_MAX_EXT_WAIT(val) BSP_FLD32(val,0, 7)
98 #define TMS570_EMIF_AWCC_MAX_EXT_WAIT_GET(reg) BSP_FLD32GET(reg,0, 7)
99 #define TMS570_EMIF_AWCC_MAX_EXT_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
100
101
102 /*----------------------TMS570_EMIF_SDCR----------------------*/
103 /* field: SR - Self-Refresh mode bit. */
104 #define TMS570_EMIF_SDCR_SR BSP_BIT32(31)
105
106 /* field: PD - Power Down bit. This bit controls entering and exiting of the power-down mode. */
107 #define TMS570_EMIF_SDCR_PD BSP_BIT32(30)
108
109 /* field: PDWR - Perform refreshes during power down. */
110 #define TMS570_EMIF_SDCR_PDWR BSP_BIT32(29)
111
112 /* field: NM - Narrow mode bit. This bit defines whether a 16- or 32-bit-wide SDRAM is connected to the EMIF. */
113 #define TMS570_EMIF_SDCR_NM BSP_BIT32(14)
114
115 /* field: CL - CAS Latency. */
116 #define TMS570_EMIF_SDCR_CL(val) BSP_FLD32(val,9, 11)
117 #define TMS570_EMIF_SDCR_CL_GET(reg) BSP_FLD32GET(reg,9, 11)
118 #define TMS570_EMIF_SDCR_CL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
119
120 /* field: BIT11_9LOCK - Bits 11 to 9 lock. CL can only be written if BIT11_9LOCK is simultaneously written with a 1. */
121 #define TMS570_EMIF_SDCR_BIT11_9LOCK BSP_BIT32(8)
122
123 /* field: IBANK - Internal SDRAM Bank size. */
124 #define TMS570_EMIF_SDCR_IBANK(val) BSP_FLD32(val,4, 6)
125 #define TMS570_EMIF_SDCR_IBANK_GET(reg) BSP_FLD32GET(reg,4, 6)
126 #define TMS570_EMIF_SDCR_IBANK_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
127
128 /* field: PAGESIZE - Page Size. This field defines the internal page size of connected SDRAM devices. */
129 #define TMS570_EMIF_SDCR_PAGESIZE(val) BSP_FLD32(val,0, 2)
130 #define TMS570_EMIF_SDCR_PAGESIZE_GET(reg) BSP_FLD32GET(reg,0, 2)
131 #define TMS570_EMIF_SDCR_PAGESIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
132
133
134 /*---------------------TMS570_EMIF_SDRCR---------------------*/
135 /* field: RR - Refresh Rate. This field is used to define the SDRAM refresh period in terms of EMIF_CLK cycles. */
136 #define TMS570_EMIF_SDRCR_RR(val) BSP_FLD32(val,0, 12)
137 #define TMS570_EMIF_SDRCR_RR_GET(reg) BSP_FLD32GET(reg,0, 12)
138 #define TMS570_EMIF_SDRCR_RR_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
139
140
141 /*---------------------TMS570_EMIF_CE2CFG---------------------*/
142 /* field: SS - Select Strobe bit. */
143 #define TMS570_EMIF_CE2CFG_SS BSP_BIT32(31)
144
145 /* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
146 #define TMS570_EMIF_CE2CFG_EW BSP_BIT32(30)
147
148 /* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
149 #define TMS570_EMIF_CE2CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
150 #define TMS570_EMIF_CE2CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
151 #define TMS570_EMIF_CE2CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
152
153 /* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
154 #define TMS570_EMIF_CE2CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
155 #define TMS570_EMIF_CE2CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
156 #define TMS570_EMIF_CE2CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
157
158 /* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
159 #define TMS570_EMIF_CE2CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
160 #define TMS570_EMIF_CE2CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
161 #define TMS570_EMIF_CE2CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
162
163 /* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
164 #define TMS570_EMIF_CE2CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
165 #define TMS570_EMIF_CE2CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
166 #define TMS570_EMIF_CE2CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
167
168 /* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
169 #define TMS570_EMIF_CE2CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
170 #define TMS570_EMIF_CE2CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
171 #define TMS570_EMIF_CE2CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
172
173 /* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
174 #define TMS570_EMIF_CE2CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
175 #define TMS570_EMIF_CE2CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
176 #define TMS570_EMIF_CE2CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
177
178 /* field: TA - Minimum Turn-Around time. */
179 #define TMS570_EMIF_CE2CFG_TA(val) BSP_FLD32(val,2, 3)
180 #define TMS570_EMIF_CE2CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
181 #define TMS570_EMIF_CE2CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
182
183 /* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
184 #define TMS570_EMIF_CE2CFG_ASIZE(val) BSP_FLD32(val,0, 1)
185 #define TMS570_EMIF_CE2CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
186 #define TMS570_EMIF_CE2CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
187
188
189 /*---------------------TMS570_EMIF_CE3CFG---------------------*/
190 /* field: SS - Select Strobe bit. */
191 #define TMS570_EMIF_CE3CFG_SS BSP_BIT32(31)
192
193 /* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
194 #define TMS570_EMIF_CE3CFG_EW BSP_BIT32(30)
195
196 /* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
197 #define TMS570_EMIF_CE3CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
198 #define TMS570_EMIF_CE3CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
199 #define TMS570_EMIF_CE3CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
200
201 /* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
202 #define TMS570_EMIF_CE3CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
203 #define TMS570_EMIF_CE3CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
204 #define TMS570_EMIF_CE3CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
205
206 /* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
207 #define TMS570_EMIF_CE3CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
208 #define TMS570_EMIF_CE3CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
209 #define TMS570_EMIF_CE3CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
210
211 /* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
212 #define TMS570_EMIF_CE3CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
213 #define TMS570_EMIF_CE3CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
214 #define TMS570_EMIF_CE3CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
215
216 /* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
217 #define TMS570_EMIF_CE3CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
218 #define TMS570_EMIF_CE3CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
219 #define TMS570_EMIF_CE3CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
220
221 /* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
222 #define TMS570_EMIF_CE3CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
223 #define TMS570_EMIF_CE3CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
224 #define TMS570_EMIF_CE3CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
225
226 /* field: TA - Minimum Turn-Around time. */
227 #define TMS570_EMIF_CE3CFG_TA(val) BSP_FLD32(val,2, 3)
228 #define TMS570_EMIF_CE3CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
229 #define TMS570_EMIF_CE3CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
230
231 /* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
232 #define TMS570_EMIF_CE3CFG_ASIZE(val) BSP_FLD32(val,0, 1)
233 #define TMS570_EMIF_CE3CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
234 #define TMS570_EMIF_CE3CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
235
236
237 /*---------------------TMS570_EMIF_CE4CFG---------------------*/
238 /* field: SS - Select Strobe bit. */
239 #define TMS570_EMIF_CE4CFG_SS BSP_BIT32(31)
240
241 /* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
242 #define TMS570_EMIF_CE4CFG_EW BSP_BIT32(30)
243
244 /* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
245 #define TMS570_EMIF_CE4CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
246 #define TMS570_EMIF_CE4CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
247 #define TMS570_EMIF_CE4CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
248
249 /* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
250 #define TMS570_EMIF_CE4CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
251 #define TMS570_EMIF_CE4CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
252 #define TMS570_EMIF_CE4CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
253
254 /* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
255 #define TMS570_EMIF_CE4CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
256 #define TMS570_EMIF_CE4CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
257 #define TMS570_EMIF_CE4CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
258
259 /* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
260 #define TMS570_EMIF_CE4CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
261 #define TMS570_EMIF_CE4CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
262 #define TMS570_EMIF_CE4CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
263
264 /* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
265 #define TMS570_EMIF_CE4CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
266 #define TMS570_EMIF_CE4CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
267 #define TMS570_EMIF_CE4CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
268
269 /* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
270 #define TMS570_EMIF_CE4CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
271 #define TMS570_EMIF_CE4CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
272 #define TMS570_EMIF_CE4CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
273
274 /* field: TA - Minimum Turn-Around time. */
275 #define TMS570_EMIF_CE4CFG_TA(val) BSP_FLD32(val,2, 3)
276 #define TMS570_EMIF_CE4CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
277 #define TMS570_EMIF_CE4CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
278
279 /* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
280 #define TMS570_EMIF_CE4CFG_ASIZE(val) BSP_FLD32(val,0, 1)
281 #define TMS570_EMIF_CE4CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
282 #define TMS570_EMIF_CE4CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
283
284
285 /*---------------------TMS570_EMIF_CE5CFG---------------------*/
286 /* field: SS - Select Strobe bit. */
287 #define TMS570_EMIF_CE5CFG_SS BSP_BIT32(31)
288
289 /* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
290 #define TMS570_EMIF_CE5CFG_EW BSP_BIT32(30)
291
292 /* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
293 #define TMS570_EMIF_CE5CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
294 #define TMS570_EMIF_CE5CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
295 #define TMS570_EMIF_CE5CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
296
297 /* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
298 #define TMS570_EMIF_CE5CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
299 #define TMS570_EMIF_CE5CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
300 #define TMS570_EMIF_CE5CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
301
302 /* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
303 #define TMS570_EMIF_CE5CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
304 #define TMS570_EMIF_CE5CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
305 #define TMS570_EMIF_CE5CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
306
307 /* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
308 #define TMS570_EMIF_CE5CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
309 #define TMS570_EMIF_CE5CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
310 #define TMS570_EMIF_CE5CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
311
312 /* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
313 #define TMS570_EMIF_CE5CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
314 #define TMS570_EMIF_CE5CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
315 #define TMS570_EMIF_CE5CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
316
317 /* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
318 #define TMS570_EMIF_CE5CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
319 #define TMS570_EMIF_CE5CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
320 #define TMS570_EMIF_CE5CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
321
322 /* field: TA - and writes, minus one cycle. See Section 17.2.6.3 for details. */
323 #define TMS570_EMIF_CE5CFG_TA(val) BSP_FLD32(val,2, 3)
324 #define TMS570_EMIF_CE5CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
325 #define TMS570_EMIF_CE5CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
326
327 /* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
328 #define TMS570_EMIF_CE5CFG_ASIZE(val) BSP_FLD32(val,0, 1)
329 #define TMS570_EMIF_CE5CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
330 #define TMS570_EMIF_CE5CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
331
332
333 /*---------------------TMS570_EMIF_SDTIMR---------------------*/
334 /* field: T_RFC - Specifies the Trfc value of the SDRAM. */
335 #define TMS570_EMIF_SDTIMR_T_RFC(val) BSP_FLD32(val,27, 31)
336 #define TMS570_EMIF_SDTIMR_T_RFC_GET(reg) BSP_FLD32GET(reg,27, 31)
337 #define TMS570_EMIF_SDTIMR_T_RFC_SET(reg,val) BSP_FLD32SET(reg, val,27, 31)
338
339 /* field: T_RP - Precharge (PRE) to Activate (ACTV) or Refresh (REFR) command, minus 1: */
340 #define TMS570_EMIF_SDTIMR_T_RP(val) BSP_FLD32(val,24, 26)
341 #define TMS570_EMIF_SDTIMR_T_RP_GET(reg) BSP_FLD32GET(reg,24, 26)
342 #define TMS570_EMIF_SDTIMR_T_RP_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
343
344 /* field: T_RCD - Specifies the Trcd value of the SDRAM. */
345 #define TMS570_EMIF_SDTIMR_T_RCD(val) BSP_FLD32(val,20, 22)
346 #define TMS570_EMIF_SDTIMR_T_RCD_GET(reg) BSP_FLD32GET(reg,20, 22)
347 #define TMS570_EMIF_SDTIMR_T_RCD_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
348
349 /* field: T_WR - Specifies the Twr value of the SDRAM. */
350 #define TMS570_EMIF_SDTIMR_T_WR(val) BSP_FLD32(val,16, 18)
351 #define TMS570_EMIF_SDTIMR_T_WR_GET(reg) BSP_FLD32GET(reg,16, 18)
352 #define TMS570_EMIF_SDTIMR_T_WR_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
353
354 /* field: T_RAS - Specifies the Tras value of the SDRAM. */
355 #define TMS570_EMIF_SDTIMR_T_RAS(val) BSP_FLD32(val,12, 15)
356 #define TMS570_EMIF_SDTIMR_T_RAS_GET(reg) BSP_FLD32GET(reg,12, 15)
357 #define TMS570_EMIF_SDTIMR_T_RAS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
358
359 /* field: T_RC - Specifies the Trc value of the SDRAM. */
360 #define TMS570_EMIF_SDTIMR_T_RC(val) BSP_FLD32(val,8, 11)
361 #define TMS570_EMIF_SDTIMR_T_RC_GET(reg) BSP_FLD32GET(reg,8, 11)
362 #define TMS570_EMIF_SDTIMR_T_RC_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
363
364 /* field: T_RRD - Specifies the Trrd value of the SDRAM. */
365 #define TMS570_EMIF_SDTIMR_T_RRD(val) BSP_FLD32(val,4, 6)
366 #define TMS570_EMIF_SDTIMR_T_RRD_GET(reg) BSP_FLD32GET(reg,4, 6)
367 #define TMS570_EMIF_SDTIMR_T_RRD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
368
369
370 /*--------------------TMS570_EMIF_SDSRETR--------------------*/
371 /* field: T_XS - This field specifies the minimum number of ECLKOUT cycles from Self-Refresh exit to any command, */
372 #define TMS570_EMIF_SDSRETR_T_XS(val) BSP_FLD32(val,0, 4)
373 #define TMS570_EMIF_SDSRETR_T_XS_GET(reg) BSP_FLD32GET(reg,0, 4)
374 #define TMS570_EMIF_SDSRETR_T_XS_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
375
376
377 /*---------------------TMS570_EMIF_INTRAW---------------------*/
378 /* field: WR - Wait Rise. */
379 #define TMS570_EMIF_INTRAW_WR BSP_BIT32(2)
380
381 /* field: LT - Line Trap. Set to 1 by hardware to indicate illegal memory access type or invalid cache line size. */
382 #define TMS570_EMIF_INTRAW_LT BSP_BIT32(1)
383
384 /* field: AT - Asynchronous Timeout. */
385 #define TMS570_EMIF_INTRAW_AT BSP_BIT32(0)
386
387
388 /*---------------------TMS570_EMIF_INTMSK---------------------*/
389 /* field: WR_MASKED - Wait Rise Masked. */
390 #define TMS570_EMIF_INTMSK_WR_MASKED BSP_BIT32(2)
391
392 /* field: LT_MASKED - Masked Line Trap. */
393 #define TMS570_EMIF_INTMSK_LT_MASKED BSP_BIT32(1)
394
395 /* field: AT_MASKED - Asynchronous Timeout Masked. */
396 #define TMS570_EMIF_INTMSK_AT_MASKED BSP_BIT32(0)
397
398
399 /*-------------------TMS570_EMIF_INTMSKSET-------------------*/
400 /* field: WR_MASK_SET - Wait Rise Mask Set. This bit determines whether or not the wait rise Interrupt is enabled. */
401 #define TMS570_EMIF_INTMSKSET_WR_MASK_SET BSP_BIT32(2)
402
403 /* field: LT_MASK_SET - LT_MASK_SET Mask set for LT_MASKED bit in the EMIF interrupt mask register (INTMSK). */
404 #define TMS570_EMIF_INTMSKSET_LT_MASK_SET BSP_BIT32(1)
405
406 /* field: AT_MASK_SET - Asynchronous Timeout Mask Set. */
407 #define TMS570_EMIF_INTMSKSET_AT_MASK_SET BSP_BIT32(0)
408
409
410 /*-------------------TMS570_EMIF_INTMSKCLR-------------------*/
411 /* field: WR_MASK_CLR - Wait Rise Mask Clear. This bit determines whether or not the wait rise interrupt is enabled. */
412 #define TMS570_EMIF_INTMSKCLR_WR_MASK_CLR BSP_BIT32(2)
413
414 /* field: LT_MASK_CLR - 1 to this bit clears this bit, clears the LT_MASK_SET bit in the EMIF interrupt mask set register */
415 #define TMS570_EMIF_INTMSKCLR_LT_MASK_CLR BSP_BIT32(1)
416
417 /* field: AT_MASK_CLR - Asynchronous Timeout Mask Clear. */
418 #define TMS570_EMIF_INTMSKCLR_AT_MASK_CLR BSP_BIT32(0)
419
420
421 /*----------------------TMS570_EMIF_PMCR----------------------*/
422 /* field: CS5_PG_DEL - Page access delay for NOR Flash connected on CS5. CS5 is not available on this device. */
423 #define TMS570_EMIF_PMCR_CS5_PG_DEL(val) BSP_FLD32(val,26, 31)
424 #define TMS570_EMIF_PMCR_CS5_PG_DEL_GET(reg) BSP_FLD32GET(reg,26, 31)
425 #define TMS570_EMIF_PMCR_CS5_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
426
427 /* field: CS5_PG_SIZE - Page Size for NOR Flash connected on CS5. CS5 is not available on this device. */
428 #define TMS570_EMIF_PMCR_CS5_PG_SIZE BSP_BIT32(25)
429
430 /* field: CS5_PG_MD_EN - Page Mode enable for NOR Flash connected on CS5. CS5 is not available on this device. */
431 #define TMS570_EMIF_PMCR_CS5_PG_MD_EN BSP_BIT32(24)
432
433 /* field: CS4_PG_DEL - Page access delay for NOR Flash connected on CS4. */
434 #define TMS570_EMIF_PMCR_CS4_PG_DEL(val) BSP_FLD32(val,18, 23)
435 #define TMS570_EMIF_PMCR_CS4_PG_DEL_GET(reg) BSP_FLD32GET(reg,18, 23)
436 #define TMS570_EMIF_PMCR_CS4_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,18, 23)
437
438 /* field: CS4_PG_SIZE - Page Size for NOR Flash connected on CS4. */
439 #define TMS570_EMIF_PMCR_CS4_PG_SIZE BSP_BIT32(17)
440
441 /* field: CS4_PG_MD_EN - Page Mode enable for NOR Flash connected on CS4. */
442 #define TMS570_EMIF_PMCR_CS4_PG_MD_EN BSP_BIT32(16)
443
444 /* field: CS3_PG_DEL - the page read data to be valid, minus one cycle. This value must not be cleared to 0. */
445 #define TMS570_EMIF_PMCR_CS3_PG_DEL(val) BSP_FLD32(val,10, 15)
446 #define TMS570_EMIF_PMCR_CS3_PG_DEL_GET(reg) BSP_FLD32GET(reg,10, 15)
447 #define TMS570_EMIF_PMCR_CS3_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,10, 15)
448
449 /* field: CS3_PG_SIZE - Page Size for NOR Flash connected on CS3. */
450 #define TMS570_EMIF_PMCR_CS3_PG_SIZE BSP_BIT32(9)
451
452 /* field: CS3_PG_MD_EN - Page Mode enable for NOR Flash connected on CS3. */
453 #define TMS570_EMIF_PMCR_CS3_PG_MD_EN BSP_BIT32(8)
454
455 /* field: CS2_PG_DEL - Page access delay for NOR Flash connected on CS2. */
456 #define TMS570_EMIF_PMCR_CS2_PG_DEL(val) BSP_FLD32(val,2, 7)
457 #define TMS570_EMIF_PMCR_CS2_PG_DEL_GET(reg) BSP_FLD32GET(reg,2, 7)
458 #define TMS570_EMIF_PMCR_CS2_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,2, 7)
459
460 /* field: CS2_PG_SIZE - Page Size for NOR Flash connected on CS2. */
461 #define TMS570_EMIF_PMCR_CS2_PG_SIZE BSP_BIT32(1)
462
463 /* field: CS2_PG_MD_EN - Page Mode enable for NOR Flash connected on CS2. */
464 #define TMS570_EMIF_PMCR_CS2_PG_MD_EN BSP_BIT32(0)
465
466
467
468 #endif /* LIBBSP_ARM_TMS570_EMIF */
Utility macros.
Definition: reg_emif.h:44
