RTEMS  5.1
reg_emacm.h
1 /* The header file is generated by make_header.py from EMACM.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_EMACM
40 #define LIBBSP_ARM_TMS570_EMACM
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t TXREVID; /*Transmit Revision ID Register*/
46  uint32_t TXCONTROL; /*Transmit Control Register*/
47  uint32_t TXTEARDOWN; /*Transmit Teardown Register*/
48  uint8_t reserved1 [4];
49  uint32_t RXREVID; /*Receive Revision ID Register*/
50  uint32_t RXCONTROL; /*Receive Control Register*/
51  uint32_t RXTEARDOWN; /*Receive Teardown Register*/
52  uint8_t reserved2 [100];
53  uint32_t TXINTSTATRAW; /*Transmit Interrupt Status (Unmasked) Register*/
54  uint32_t TXINTSTATMASKED; /*Transmit Interrupt Status (Masked) Register*/
55  uint32_t TXINTMASKSET; /*Transmit Interrupt Mask Set Register*/
56  uint32_t TXINTMASKCLEAR; /*Transmit Interrupt Clear Register*/
57  uint32_t MACINVECTOR; /*MAC Input Vector Register*/
58  uint32_t MACEOIVECTOR; /*MAC End Of Interrupt Vector Register*/
59  uint8_t reserved3 [8];
60  uint32_t RXINTSTATRAW; /*Receive Interrupt Status (Unmasked) Register*/
61  uint32_t RXINTSTATMASKED; /*Receive Interrupt Status (Masked) Register*/
62  uint32_t RXINTMASKSET; /*Receive Interrupt Mask Set Register*/
63  uint32_t RXINTMASKCLEAR; /*Receive Interrupt Mask Clear Register*/
64  uint32_t MACINTSTATRAW; /*MAC Interrupt Status (Unmasked) Register*/
65  uint32_t MACINTSTATMASKED; /*MAC Interrupt Status (Masked) Register*/
66  uint32_t MACINTMASKSET; /*MAC Interrupt Mask Set Register*/
67  uint32_t MACINTMASKCLEAR; /*MAC Interrupt Mask Clear Register*/
68  uint8_t reserved4 [64];
69  uint32_t RXMBPENABLE; /*Receive Multicast/Broadcast/Promiscuous Channel Enable*/
70  uint32_t RXUNICASTSET; /*Receive Unicast Enable Set Register*/
71  uint32_t RXUNICASTCLEAR; /*Receive Unicast Clear Register*/
72  uint32_t RXMAXLEN; /*Receive Maximum Length Register*/
73  uint32_t RXBUFFEROFFSET; /*Receive Buffer Offset Register*/
74  uint32_t RXFILTERLOWTHRESH; /*Receive Filter Low Priority Frame Threshold Register*/
75  uint8_t reserved5 [8];
76  uint32_t RXFLOWTHRESH[8]; /*Receive Channel Flow Control Threshold Register*/
77  uint32_t RXFREEBUFFER[8]; /*Receive Channel Free Buffer Count Register*/
78  uint32_t MACCONTROL; /*MAC Control Register*/
79  uint32_t MACSTATUS; /*MAC Status Register*/
80  uint32_t EMCONTROL; /*Emulation Control Register*/
81  uint32_t FIFOCONTROL; /*FIFO Control Register*/
82  uint32_t MACCONFIG; /*MAC Configuration Register*/
83  uint32_t SOFTRESET; /*Soft Reset Register*/
84  uint8_t reserved6 [88];
85  uint32_t MACSRCADDRLO; /*MAC Source Address Low Bytes Register*/
86  uint32_t MACSRCADDRHI; /*MAC Source Address High Bytes Register*/
87  uint32_t MACHASH1; /*MAC Hash Address Register 1*/
88  uint32_t MACHASH2; /*MAC Hash Address Register 2*/
89  uint32_t BOFFTEST; /*Back Off Test Register*/
90  uint32_t TPACETEST; /*Transmit Pacing Algorithm Test Register*/
91  uint32_t RXPAUSE; /*Receive Pause Timer Register*/
92  uint32_t TXPAUSE; /*Transmit Pause Timer Register*/
93  uint8_t reserved7 [784];
94  uint32_t MACADDRLO; /*MAC Address Low Bytes Register*/
95  uint32_t MACADDRHI; /*MAC Address High Bytes Register*/
96  uint32_t MACINDEX; /*MAC Index Register*/
97  uint8_t reserved8 [244];
98  uint32_t TXHDP[8]; /*Transmit Channel DMA Head Descriptor Pointer Register*/
99  uint32_t RXHDP[8]; /*Receive Channel DMA Head Descriptor Pointer Register*/
100  uint32_t TXCP[8]; /*Transmit Channel Completion Pointer Register*/
101  uint32_t RXCP[8]; /*Receive Channel Completion Pointer Register*/
103
104
105 /*--------------------TMS570_EMACM_TXREVID--------------------*/
106 /* field: TXREV - Transmit module revision */
107 /* Whole 32 bits */
108
109 /*-------------------TMS570_EMACM_TXCONTROL-------------------*/
110 /* field: TXEN - Transmit enable */
111 #define TMS570_EMACM_TXCONTROL_TXEN BSP_BIT32(0)
112
113
114 /*------------------TMS570_EMACM_TXTEARDOWN------------------*/
115 /* field: TXTDNCH - Transmit teardown channel. */
116 #define TMS570_EMACM_TXTEARDOWN_TXTDNCH(val) BSP_FLD32(val,0, 2)
117 #define TMS570_EMACM_TXTEARDOWN_TXTDNCH_GET(reg) BSP_FLD32GET(reg,0, 2)
118 #define TMS570_EMACM_TXTEARDOWN_TXTDNCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
119
120
121 /*--------------------TMS570_EMACM_RXREVID--------------------*/
122 /* field: RXREV - Receive module revision */
123 /* Whole 32 bits */
124
125 /*-------------------TMS570_EMACM_RXCONTROL-------------------*/
126 /* field: RXEN - Receive enable */
127 #define TMS570_EMACM_RXCONTROL_RXEN BSP_BIT32(0)
128
129
130 /*------------------TMS570_EMACM_RXTEARDOWN------------------*/
131 /* field: RXTDNCH - Receive teardown channel. */
132 #define TMS570_EMACM_RXTEARDOWN_RXTDNCH(val) BSP_FLD32(val,0, 2)
133 #define TMS570_EMACM_RXTEARDOWN_RXTDNCH_GET(reg) BSP_FLD32GET(reg,0, 2)
134 #define TMS570_EMACM_RXTEARDOWN_RXTDNCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
135
136
137 /*-----------------TMS570_EMACM_TXINTSTATRAW-----------------*/
138 /* field: TX7PEND - TX7PEND raw interrupt read (before mask) */
139 #define TMS570_EMACM_TXINTSTATRAW_TX7PEND BSP_BIT32(7)
140
141 /* field: TX6PEND - TX6PEND raw interrupt read (before mask) */
142 #define TMS570_EMACM_TXINTSTATRAW_TX6PEND BSP_BIT32(6)
143
144 /* field: TX5PEND - TX5PEND raw interrupt read (before mask) */
145 #define TMS570_EMACM_TXINTSTATRAW_TX5PEND BSP_BIT32(5)
146
147 /* field: TX4PEND - X4PEND raw interrupt read (before mask) */
148 #define TMS570_EMACM_TXINTSTATRAW_TX4PEND BSP_BIT32(4)
149
150 /* field: TX3PEND - TX3PEND raw interrupt read (before mask) */
151 #define TMS570_EMACM_TXINTSTATRAW_TX3PEND BSP_BIT32(3)
152
153 /* field: TX2PEND - TX2PEND raw interrupt read (before mask) */
154 #define TMS570_EMACM_TXINTSTATRAW_TX2PEND BSP_BIT32(2)
155
156 /* field: TX1PEND - TX1PEND raw interrupt read (before mask) */
157 #define TMS570_EMACM_TXINTSTATRAW_TX1PEND BSP_BIT32(1)
158
159 /* field: TX0PEND - TX0PEND raw interrupt read (before mask) */
160 #define TMS570_EMACM_TXINTSTATRAW_TX0PEND BSP_BIT32(0)
161
162
163 /*----------------TMS570_EMACM_TXINTSTATMASKED----------------*/
164 /* field: TX7PEND - TX7PEND masked interrupt read */
165 #define TMS570_EMACM_TXINTSTATMASKED_TX7PEND BSP_BIT32(7)
166
167 /* field: TX6PEND - TX6PEND masked interrupt read */
168 #define TMS570_EMACM_TXINTSTATMASKED_TX6PEND BSP_BIT32(6)
169
170 /* field: TX5PEND - TX5PEND masked interrupt read */
171 #define TMS570_EMACM_TXINTSTATMASKED_TX5PEND BSP_BIT32(5)
172
173 /* field: TX4PEND - TX4PEND masked interrupt read */
174 #define TMS570_EMACM_TXINTSTATMASKED_TX4PEND BSP_BIT32(4)
175
176 /* field: TX3PEND - TX3PEND masked interrupt read */
177 #define TMS570_EMACM_TXINTSTATMASKED_TX3PEND BSP_BIT32(3)
178
179 /* field: TX2PEND - TX2PEND masked interrupt read */
180 #define TMS570_EMACM_TXINTSTATMASKED_TX2PEND BSP_BIT32(2)
181
182 /* field: TX1PEND - TX1PEND masked interrupt read */
183 #define TMS570_EMACM_TXINTSTATMASKED_TX1PEND BSP_BIT32(1)
184
185 /* field: TX0PEND - TX0PEND masked interrupt read */
186 #define TMS570_EMACM_TXINTSTATMASKED_TX0PEND BSP_BIT32(0)
187
188
189 /*-----------------TMS570_EMACM_TXINTMASKSET-----------------*/
190 /* field: TX7MASK - Transmit channel 7 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
191 #define TMS570_EMACM_TXINTMASKSET_TX7MASK BSP_BIT32(7)
192
193 /* field: TX6MASK - Transmit channel 6 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
194 #define TMS570_EMACM_TXINTMASKSET_TX6MASK BSP_BIT32(6)
195
196 /* field: TX5MASK - Transmit channel 5 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
197 #define TMS570_EMACM_TXINTMASKSET_TX5MASK BSP_BIT32(5)
198
199 /* field: TX4MASK - Transmit channel 4 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
200 #define TMS570_EMACM_TXINTMASKSET_TX4MASK BSP_BIT32(4)
201
202 /* field: TX3MASK - Transmit channel 3 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
203 #define TMS570_EMACM_TXINTMASKSET_TX3MASK BSP_BIT32(3)
204
205 /* field: TX2MASK - Transmit channel 2 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
206 #define TMS570_EMACM_TXINTMASKSET_TX2MASK BSP_BIT32(2)
207
208 /* field: TX1MASK - Transmit channel 1 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
209 #define TMS570_EMACM_TXINTMASKSET_TX1MASK BSP_BIT32(1)
210
211 /* field: TX0MASK - Transmit channel 0 interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
212 #define TMS570_EMACM_TXINTMASKSET_TX0MASK BSP_BIT32(0)
213
214
215 /*----------------TMS570_EMACM_TXINTMASKCLEAR----------------*/
216 /* field: TX7MASK - Transmit channel 7 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
217 #define TMS570_EMACM_TXINTMASKCLEAR_TX7MASK BSP_BIT32(7)
218
219 /* field: TX6MASK - Transmit channel 6 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
220 #define TMS570_EMACM_TXINTMASKCLEAR_TX6MASK BSP_BIT32(6)
221
222 /* field: TX5MASK - Transmit channel 5 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
223 #define TMS570_EMACM_TXINTMASKCLEAR_TX5MASK BSP_BIT32(5)
224
225 /* field: TX4MASK - Transmit channel 4 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
226 #define TMS570_EMACM_TXINTMASKCLEAR_TX4MASK BSP_BIT32(4)
227
228 /* field: TX3MASK - Transmit channel 3 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
229 #define TMS570_EMACM_TXINTMASKCLEAR_TX3MASK BSP_BIT32(3)
230
231 /* field: TX2MASK - Transmit channel 2 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
232 #define TMS570_EMACM_TXINTMASKCLEAR_TX2MASK BSP_BIT32(2)
233
234 /* field: TX1MASK - Transmit channel 1 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
235 #define TMS570_EMACM_TXINTMASKCLEAR_TX1MASK BSP_BIT32(1)
236
237 /* field: TX0MASK - Transmit channel 0 interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
238 #define TMS570_EMACM_TXINTMASKCLEAR_TX0MASK BSP_BIT32(0)
239
240
241 /*------------------TMS570_EMACM_MACINVECTOR------------------*/
242 /* field: STATPEND - EMAC module statistics interrupt (STATPEND) pending status bit */
243 #define TMS570_EMACM_MACINVECTOR_STATPEND BSP_BIT32(27)
244
245 /* field: HOSTPEND - EMAC module host error interrupt (HOSTPEND) pending status bit */
246 #define TMS570_EMACM_MACINVECTOR_HOSTPEND BSP_BIT32(26)
247
248 /* field: LINKINT0 - MDIO module USERPHYSEL0 (LINKINT0) status bit */
249 #define TMS570_EMACM_MACINVECTOR_LINKINT0 BSP_BIT32(25)
250
251 /* field: USERINT0 - MDIO module USERACCESS0 (USERINT0) status bit */
252 #define TMS570_EMACM_MACINVECTOR_USERINT0 BSP_BIT32(24)
253
254 /* field: TXPEND - Transmit channels 0-7 interrupt (TXnPEND) pending status. Bit 16 is TX0PEND. */
255 #define TMS570_EMACM_MACINVECTOR_TXPEND(val) BSP_FLD32(val,16, 23)
256 #define TMS570_EMACM_MACINVECTOR_TXPEND_GET(reg) BSP_FLD32GET(reg,16, 23)
257 #define TMS570_EMACM_MACINVECTOR_TXPEND_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
258
259 /* field: RXTHRESHPEND - Receive channels 0-7 interrupt (RXnTHRESHPEND) pending status. */
260 #define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND(val) BSP_FLD32(val,8, 15)
261 #define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND_GET(reg) BSP_FLD32GET(reg,8, 15)
262 #define TMS570_EMACM_MACINVECTOR_RXTHRESHPEND_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
263
264 /* field: RXPEND - Receive channels 0-7 interrupt (RXnPEND) pending status bit. Bit 0 is RX0PEND. */
265 #define TMS570_EMACM_MACINVECTOR_RXPEND(val) BSP_FLD32(val,0, 7)
266 #define TMS570_EMACM_MACINVECTOR_RXPEND_GET(reg) BSP_FLD32GET(reg,0, 7)
267 #define TMS570_EMACM_MACINVECTOR_RXPEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
268
269
270 /*-----------------TMS570_EMACM_MACEOIVECTOR-----------------*/
271 /* field: INTVECT - Acknowledge EMAC Control Module Interrupts */
272 #define TMS570_EMACM_MACEOIVECTOR_INTVECT(val) BSP_FLD32(val,0, 4)
273 #define TMS570_EMACM_MACEOIVECTOR_INTVECT_GET(reg) BSP_FLD32GET(reg,0, 4)
274 #define TMS570_EMACM_MACEOIVECTOR_INTVECT_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
275
276
277 /*-----------------TMS570_EMACM_RXINTSTATRAW-----------------*/
278 /* field: RX7THRESHPEND - RX7THRESHPEND raw interrupt read (before mask) */
279 #define TMS570_EMACM_RXINTSTATRAW_RX7THRESHPEND BSP_BIT32(15)
280
281 /* field: RX6THRESHPEND - RX6THRESHPEND raw interrupt read (before mask) */
282 #define TMS570_EMACM_RXINTSTATRAW_RX6THRESHPEND BSP_BIT32(14)
283
284 /* field: RX5THRESHPEND - RX5THRESHPEND raw interrupt read (before mask) */
285 #define TMS570_EMACM_RXINTSTATRAW_RX5THRESHPEND BSP_BIT32(13)
286
287 /* field: RX4THRESHPEND - RX4THRESHPEND raw interrupt read (before mask) */
288 #define TMS570_EMACM_RXINTSTATRAW_RX4THRESHPEND BSP_BIT32(12)
289
290 /* field: RX3THRESHPEND - RX3THRESHPEND raw interrupt read (before mask) */
291 #define TMS570_EMACM_RXINTSTATRAW_RX3THRESHPEND BSP_BIT32(11)
292
293 /* field: RX2THRESHPEND - RX2THRESHPEND raw interrupt read (before mask) */
294 #define TMS570_EMACM_RXINTSTATRAW_RX2THRESHPEND BSP_BIT32(10)
295
296 /* field: RX1THRESHPEND - RX1THRESHPEND raw interrupt read (before mask) */
297 #define TMS570_EMACM_RXINTSTATRAW_RX1THRESHPEND BSP_BIT32(9)
298
299 /* field: RX0THRESHPEND - RX0THRESHPEND raw interrupt read (before mask) */
300 #define TMS570_EMACM_RXINTSTATRAW_RX0THRESHPEND BSP_BIT32(8)
301
302 /* field: RX7PEND - RX7PEND raw interrupt read (before mask) */
303 #define TMS570_EMACM_RXINTSTATRAW_RX7PEND BSP_BIT32(7)
304
305 /* field: RX6PEND - RX6PEND raw interrupt read (before mask) */
306 #define TMS570_EMACM_RXINTSTATRAW_RX6PEND BSP_BIT32(6)
307
308 /* field: RX5PEND - RX5PEND raw interrupt read (before mask) */
309 #define TMS570_EMACM_RXINTSTATRAW_RX5PEND BSP_BIT32(5)
310
311 /* field: RX4PEND - RX4PEND raw interrupt read (before mask) */
312 #define TMS570_EMACM_RXINTSTATRAW_RX4PEND BSP_BIT32(4)
313
314 /* field: RX3PEND - RX3PEND raw interrupt read (before mask) */
315 #define TMS570_EMACM_RXINTSTATRAW_RX3PEND BSP_BIT32(3)
316
317 /* field: RX2PEND - RX2PEND raw interrupt read (before mask) */
318 #define TMS570_EMACM_RXINTSTATRAW_RX2PEND BSP_BIT32(2)
319
320 /* field: RX1PEND - RX1PEND raw interrupt read (before mask) */
321 #define TMS570_EMACM_RXINTSTATRAW_RX1PEND BSP_BIT32(1)
322
323 /* field: RX0PEND - RX0PEND raw interrupt read (before mask) */
324 #define TMS570_EMACM_RXINTSTATRAW_RX0PEND BSP_BIT32(0)
325
326
327 /*----------------TMS570_EMACM_RXINTSTATMASKED----------------*/
328 /* field: RX7THRESHPEND - RX7THRESHPEND masked interrupt read */
329 #define TMS570_EMACM_RXINTSTATMASKED_RX7THRESHPEND BSP_BIT32(15)
330
331 /* field: RX6THRESHPEND - RX6THRESHPEND masked interrupt read */
332 #define TMS570_EMACM_RXINTSTATMASKED_RX6THRESHPEND BSP_BIT32(14)
333
334 /* field: RX5THRESHPEND - RX5THRESHPEND masked interrupt read */
335 #define TMS570_EMACM_RXINTSTATMASKED_RX5THRESHPEND BSP_BIT32(13)
336
337 /* field: RX4THRESHPEND - RX4THRESHPEND masked interrupt read */
338 #define TMS570_EMACM_RXINTSTATMASKED_RX4THRESHPEND BSP_BIT32(12)
339
340 /* field: RX3THRESHPEND - RX3THRESHPEND masked interrupt read */
341 #define TMS570_EMACM_RXINTSTATMASKED_RX3THRESHPEND BSP_BIT32(11)
342
343 /* field: RX2THRESHPEND - RX2THRESHPEND masked interrupt read */
344 #define TMS570_EMACM_RXINTSTATMASKED_RX2THRESHPEND BSP_BIT32(10)
345
346 /* field: RX1THRESHPEND - RX1THRESHPEND masked interrupt read */
347 #define TMS570_EMACM_RXINTSTATMASKED_RX1THRESHPEND BSP_BIT32(9)
348
349 /* field: RX0THRESHPEND - RX0THRESHPEND masked interrupt read */
350 #define TMS570_EMACM_RXINTSTATMASKED_RX0THRESHPEND BSP_BIT32(8)
351
352 /* field: RX7PEND - RX7PEND masked interrupt read */
353 #define TMS570_EMACM_RXINTSTATMASKED_RX7PEND BSP_BIT32(7)
354
355 /* field: RX6PEND - RX6PEND masked interrupt read */
356 #define TMS570_EMACM_RXINTSTATMASKED_RX6PEND BSP_BIT32(6)
357
358 /* field: RX5PEND - RX5PEND masked interrupt read */
359 #define TMS570_EMACM_RXINTSTATMASKED_RX5PEND BSP_BIT32(5)
360
361 /* field: RX4PEND - RX4PEND masked interrupt read */
362 #define TMS570_EMACM_RXINTSTATMASKED_RX4PEND BSP_BIT32(4)
363
364 /* field: RX3PEND - RX3PEND masked interrupt read */
365 #define TMS570_EMACM_RXINTSTATMASKED_RX3PEND BSP_BIT32(3)
366
367 /* field: RX2PEND - RX2PEND masked interrupt read */
368 #define TMS570_EMACM_RXINTSTATMASKED_RX2PEND BSP_BIT32(2)
369
370 /* field: RX1PEND - RX1PEND masked interrupt read */
371 #define TMS570_EMACM_RXINTSTATMASKED_RX1PEND BSP_BIT32(1)
372
373 /* field: RX0PEND - RX0PEND masked interrupt read */
374 #define TMS570_EMACM_RXINTSTATMASKED_RX0PEND BSP_BIT32(0)
375
376
377 /*-----------------TMS570_EMACM_RXINTMASKSET-----------------*/
378 /* field: RX7THRESHMASK - Receive channel 7 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
379 #define TMS570_EMACM_RXINTMASKSET_RX7THRESHMASK BSP_BIT32(15)
380
381 /* field: RX6THRESHMASK - Receive channel 6 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
382 #define TMS570_EMACM_RXINTMASKSET_RX6THRESHMASK BSP_BIT32(14)
383
384 /* field: RX5THRESHMASK - Receive channel 5 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
385 #define TMS570_EMACM_RXINTMASKSET_RX5THRESHMASK BSP_BIT32(13)
386
387 /* field: RX4THRESHMASK - Receive channel 4 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
388 #define TMS570_EMACM_RXINTMASKSET_RX4THRESHMASK BSP_BIT32(12)
389
390 /* field: RX3THRESHMASK - Receive channel 3 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
391 #define TMS570_EMACM_RXINTMASKSET_RX3THRESHMASK BSP_BIT32(11)
392
393 /* field: RX2THRESHMASK - Receive channel 2 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
394 #define TMS570_EMACM_RXINTMASKSET_RX2THRESHMASK BSP_BIT32(10)
395
396 /* field: RX1THRESHMASK - Receive channel 1 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
397 #define TMS570_EMACM_RXINTMASKSET_RX1THRESHMASK BSP_BIT32(9)
398
399 /* field: RX0THRESHMASK - Receive channel 0 threshold mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
400 #define TMS570_EMACM_RXINTMASKSET_RX0THRESHMASK BSP_BIT32(8)
401
402 /* field: RX7MASK - Receive channel 7 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
403 #define TMS570_EMACM_RXINTMASKSET_RX7MASK BSP_BIT32(7)
404
405 /* field: RX6MASK - Receive channel 6 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
406 #define TMS570_EMACM_RXINTMASKSET_RX6MASK BSP_BIT32(6)
407
408 /* field: RX5MASK - Receive channel 5 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
409 #define TMS570_EMACM_RXINTMASKSET_RX5MASK BSP_BIT32(5)
410
411 /* field: RX4MASK - Receive channel 4 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
412 #define TMS570_EMACM_RXINTMASKSET_RX4MASK BSP_BIT32(4)
413
414 /* field: RX3MASK - Receive channel 3 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
415 #define TMS570_EMACM_RXINTMASKSET_RX3MASK BSP_BIT32(3)
416
417 /* field: RX2MASK - Receive channel 2 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
418 #define TMS570_EMACM_RXINTMASKSET_RX2MASK BSP_BIT32(2)
419
420 /* field: RX1MASK - Receive channel 1 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
421 #define TMS570_EMACM_RXINTMASKSET_RX1MASK BSP_BIT32(1)
422
423 /* field: RX0MASK - Receive channel 0 mask set bit. Write 1 to enable interrupt; a write of 0 has no effect. */
424 #define TMS570_EMACM_RXINTMASKSET_RX0MASK BSP_BIT32(0)
425
426
427 /*----------------TMS570_EMACM_RXINTMASKCLEAR----------------*/
428 /* field: RX7THRESHMASK - Receive channel 7 threshold mask clear bit. */
429 #define TMS570_EMACM_RXINTMASKCLEAR_RX7THRESHMASK BSP_BIT32(15)
430
431 /* field: RX6THRESHMASK - Receive channel 6 threshold mask clear bit. */
432 #define TMS570_EMACM_RXINTMASKCLEAR_RX6THRESHMASK BSP_BIT32(14)
433
434 /* field: RX5THRESHMASK - Receive channel 5 threshold mask clear bit. */
435 #define TMS570_EMACM_RXINTMASKCLEAR_RX5THRESHMASK BSP_BIT32(13)
436
437 /* field: RX4THRESHMASK - Receive channel 4 threshold mask clear bit. */
438 #define TMS570_EMACM_RXINTMASKCLEAR_RX4THRESHMASK BSP_BIT32(12)
439
440 /* field: RX3THRESHMASK - Receive channel 3 threshold mask clear bit. */
441 #define TMS570_EMACM_RXINTMASKCLEAR_RX3THRESHMASK BSP_BIT32(11)
442
443 /* field: RX2THRESHMASK - Receive channel 2 threshold mask clear bit. */
444 #define TMS570_EMACM_RXINTMASKCLEAR_RX2THRESHMASK BSP_BIT32(10)
445
446 /* field: RX1THRESHMASK - Receive channel 1 threshold mask clear bit. */
447 #define TMS570_EMACM_RXINTMASKCLEAR_RX1THRESHMASK BSP_BIT32(9)
448
449 /* field: RX0THRESHMASK - Receive channel 0 threshold mask clear bit. */
450 #define TMS570_EMACM_RXINTMASKCLEAR_RX0THRESHMASK BSP_BIT32(8)
451
452 /* field: RX7MASK - Receive channel 7 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
453 #define TMS570_EMACM_RXINTMASKCLEAR_RX7MASK BSP_BIT32(7)
454
455 /* field: RX6MASK - Receive channel 6 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
456 #define TMS570_EMACM_RXINTMASKCLEAR_RX6MASK BSP_BIT32(6)
457
458 /* field: RX5MASK - Receive channel 5 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
459 #define TMS570_EMACM_RXINTMASKCLEAR_RX5MASK BSP_BIT32(5)
460
461 /* field: RX4MASK - Receive channel 4 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
462 #define TMS570_EMACM_RXINTMASKCLEAR_RX4MASK BSP_BIT32(4)
463
464 /* field: RX3MASK - Receive channel 3 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
465 #define TMS570_EMACM_RXINTMASKCLEAR_RX3MASK BSP_BIT32(3)
466
467 /* field: RX2MASK - Receive channel 2 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
468 #define TMS570_EMACM_RXINTMASKCLEAR_RX2MASK BSP_BIT32(2)
469
470 /* field: RX1MASK - Receive channel 1 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
471 #define TMS570_EMACM_RXINTMASKCLEAR_RX1MASK BSP_BIT32(1)
472
473 /* field: RX0MASK - Receive channel 0 mask clear bit. Write 1 to disable interrupt; a write of 0 has no effect. */
474 #define TMS570_EMACM_RXINTMASKCLEAR_RX0MASK BSP_BIT32(0)
475
476
477 /*-----------------TMS570_EMACM_MACINTSTATRAW-----------------*/
478 /* field: HOSTPEND - Host pending interrupt (HOSTPEND); raw interrupt read (before mask). */
479 #define TMS570_EMACM_MACINTSTATRAW_HOSTPEND BSP_BIT32(1)
480
481 /* field: STATPEND - Statistics pending interrupt (STATPEND); raw interrupt read (before mask). */
482 #define TMS570_EMACM_MACINTSTATRAW_STATPEND BSP_BIT32(0)
483
484
485 /*---------------TMS570_EMACM_MACINTSTATMASKED---------------*/
486 /* field: HOSTPEND - Host pending interrupt (HOSTPEND); masked interrupt read. */
487 #define TMS570_EMACM_MACINTSTATMASKED_HOSTPEND BSP_BIT32(1)
488
489 /* field: STATPEND - Statistics pending interrupt (STATPEND); masked interrupt read. */
490 #define TMS570_EMACM_MACINTSTATMASKED_STATPEND BSP_BIT32(0)
491
492
493 /*-----------------TMS570_EMACM_MACINTMASKSET-----------------*/
494 /* field: HOSTMASK - Host error interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
495 #define TMS570_EMACM_MACINTMASKSET_HOSTMASK BSP_BIT32(1)
496
497 /* field: STATMASK - Statistics interrupt mask set bit. Write 1 to enable interrupt, a write of 0 has no effect. */
498 #define TMS570_EMACM_MACINTMASKSET_STATMASK BSP_BIT32(0)
499
500
501 /*----------------TMS570_EMACM_MACINTMASKCLEAR----------------*/
502 /* field: HOSTMASK - Host error interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
503 #define TMS570_EMACM_MACINTMASKCLEAR_HOSTMASK BSP_BIT32(1)
504
505 /* field: STATMASK - Statistics interrupt mask clear bit. Write 1 to disable interrupt, a write of 0 has no effect. */
506 #define TMS570_EMACM_MACINTMASKCLEAR_STATMASK BSP_BIT32(0)
507
508
509 /*------------------TMS570_EMACM_RXMBPENABLE------------------*/
510 /* field: RXPASSCRC - Pass receive CRC enable bit */
511 #define TMS570_EMACM_RXMBPENABLE_RXPASSCRC BSP_BIT32(30)
512
513 /* field: RXQOSEN - Receive quality of service enable bit */
514 #define TMS570_EMACM_RXMBPENABLE_RXQOSEN BSP_BIT32(29)
515
516 /* field: RXNOCHAIN - Receive no buffer chaining bit */
517 #define TMS570_EMACM_RXMBPENABLE_RXNOCHAIN BSP_BIT32(28)
518
519 /* field: RXCMFEN - Receive copy MAC control frames enable bit. */
520 #define TMS570_EMACM_RXMBPENABLE_RXCMFEN BSP_BIT32(24)
521
522 /* field: RXCSFEN - Receive copy short frames enable bit. */
523 #define TMS570_EMACM_RXMBPENABLE_RXCSFEN BSP_BIT32(23)
524
525 /* field: RXCEFEN - Receive copy error frames enable bit. */
526 #define TMS570_EMACM_RXMBPENABLE_RXCEFEN BSP_BIT32(22)
527
528 /* field: RXCAFEN - Receive copy all frames enable bit. */
529 #define TMS570_EMACM_RXMBPENABLE_RXCAFEN BSP_BIT32(21)
530
531 /* field: RXPROMCH - Receive promiscuous channel select */
532 #define TMS570_EMACM_RXMBPENABLE_RXPROMCH(val) BSP_FLD32(val,16, 18)
533 #define TMS570_EMACM_RXMBPENABLE_RXPROMCH_GET(reg) BSP_FLD32GET(reg,16, 18)
534 #define TMS570_EMACM_RXMBPENABLE_RXPROMCH_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
535
536 /* field: RXBROADEN - Receive broadcast enable. */
537 #define TMS570_EMACM_RXMBPENABLE_RXBROADEN BSP_BIT32(13)
538
539 /* field: RXBROADCH - Receive broadcast channel select */
540 #define TMS570_EMACM_RXMBPENABLE_RXBROADCH(val) BSP_FLD32(val,8, 10)
541 #define TMS570_EMACM_RXMBPENABLE_RXBROADCH_GET(reg) BSP_FLD32GET(reg,8, 10)
542 #define TMS570_EMACM_RXMBPENABLE_RXBROADCH_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
543
544 /* field: RXMULTEN - RX multicast enable. */
545 #define TMS570_EMACM_RXMBPENABLE_RXMULTEN BSP_BIT32(5)
546
547
548 /*-----------------TMS570_EMACM_RXUNICASTSET-----------------*/
549 /* field: RXCH7EN - Receive channel 7 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
550 #define TMS570_EMACM_RXUNICASTSET_RXCH7EN BSP_BIT32(7)
551
552 /* field: RXCH6EN - Receive channel 6 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
553 #define TMS570_EMACM_RXUNICASTSET_RXCH6EN BSP_BIT32(6)
554
555 /* field: RXCH5EN - Receive channel 5 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
556 #define TMS570_EMACM_RXUNICASTSET_RXCH5EN BSP_BIT32(5)
557
558 /* field: RXCH4EN - Receive channel 4 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
559 #define TMS570_EMACM_RXUNICASTSET_RXCH4EN BSP_BIT32(4)
560
561 /* field: RXCH3EN - Receive channel 3 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
562 #define TMS570_EMACM_RXUNICASTSET_RXCH3EN BSP_BIT32(3)
563
564 /* field: RXCH2EN - Receive channel 2 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
565 #define TMS570_EMACM_RXUNICASTSET_RXCH2EN BSP_BIT32(2)
566
567 /* field: RXCH1EN - Receive channel 1 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
568 #define TMS570_EMACM_RXUNICASTSET_RXCH1EN BSP_BIT32(1)
569
570 /* field: RXCH0EN - Receive channel 0 unicast enable set bit. Write 1 to set the enable, a write of 0 has no effect. */
571 #define TMS570_EMACM_RXUNICASTSET_RXCH0EN BSP_BIT32(0)
572
573
574 /*----------------TMS570_EMACM_RXUNICASTCLEAR----------------*/
575 /* field: RXCH7EN - Receive channel 7 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
576 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH7EN BSP_BIT32(7)
577
578 /* field: RXCH6EN - Receive channel 6 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
579 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH6EN BSP_BIT32(6)
580
581 /* field: RXCH5EN - Receive channel 5 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
582 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH5EN BSP_BIT32(5)
583
584 /* field: RXCH4EN - Receive channel 4 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
585 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH4EN BSP_BIT32(4)
586
587 /* field: RXCH3EN - Receive channel 3 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
588 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH3EN BSP_BIT32(3)
589
590 /* field: RXCH2EN - Receive channel 2 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
591 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH2EN BSP_BIT32(2)
592
593 /* field: RXCH1EN - Receive channel 1 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
594 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH1EN BSP_BIT32(1)
595
596 /* field: RXCH0EN - Receive channel 0 unicast enable clear bit. Write 1 to clear the enable, a write of 0 has no effect. */
597 #define TMS570_EMACM_RXUNICASTCLEAR_RXCH0EN BSP_BIT32(0)
598
599
600 /*-------------------TMS570_EMACM_RXMAXLEN-------------------*/
601 /* field: RXMAXLEN - Receive maximum frame length. These bits determine the maximum length of a received frame. */
602 #define TMS570_EMACM_RXMAXLEN_RXMAXLEN(val) BSP_FLD32(val,0, 15)
603 #define TMS570_EMACM_RXMAXLEN_RXMAXLEN_GET(reg) BSP_FLD32GET(reg,0, 15)
604 #define TMS570_EMACM_RXMAXLEN_RXMAXLEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
605
606
607 /*----------------TMS570_EMACM_RXBUFFEROFFSET----------------*/
608 /* field: RXBUFFEROFFSET - Receive buffer offset value. */
609 #define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET(val) BSP_FLD32(val,0, 15)
610 #define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET_GET(reg) BSP_FLD32GET(reg,0, 15)
611 #define TMS570_EMACM_RXBUFFEROFFSET_RXBUFFEROFFSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
612
613
614 /*---------------TMS570_EMACM_RXFILTERLOWTHRESH---------------*/
615 /* field: RXFILTERTHRESH - Receive filter low threshold. */
616 #define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH(val) BSP_FLD32(val,0, 7)
617 #define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH_GET(reg) BSP_FLD32GET(reg,0, 7)
618 #define TMS570_EMACM_RXFILTERLOWTHRESH_RXFILTERTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
619
620
621 /*-----------------TMS570_EMACM_RXFLOWTHRESH-----------------*/
622 /* field: RXnFLOWTHRESH - Receive flow threshold. */
623 #define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH(val) BSP_FLD32(val,0, 7)
624 #define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH_GET(reg) BSP_FLD32GET(reg,0, 7)
625 #define TMS570_EMACM_RXFLOWTHRESH_RXnFLOWTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
626
627
628 /*-----------------TMS570_EMACM_RXFREEBUFFER-----------------*/
629 /* field: RXnFREEBUF - Receive free buffer count. These bits contain the count of free buffers available. */
630 #define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF(val) BSP_FLD32(val,0, 15)
631 #define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF_GET(reg) BSP_FLD32GET(reg,0, 15)
632 #define TMS570_EMACM_RXFREEBUFFER_RXnFREEBUF_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
633
634
635 /*------------------TMS570_EMACM_MACCONTROL------------------*/
636 /* field: RMIISPEED - RMII interface transmit and receive speed select. */
637 #define TMS570_EMACM_MACCONTROL_RMIISPEED BSP_BIT32(15)
638
639 /* field: RXOFFLENBLOCK - Receive offset / length word write block. */
640 #define TMS570_EMACM_MACCONTROL_RXOFFLENBLOCK BSP_BIT32(14)
641
642 /* field: RXOWNERSHIP - Receive ownership write bit value. */
643 #define TMS570_EMACM_MACCONTROL_RXOWNERSHIP BSP_BIT32(13)
644
645 /* field: CMDIDLE - Command Idle bit */
646 #define TMS570_EMACM_MACCONTROL_CMDIDLE BSP_BIT32(11)
647
648 /* field: TXSHORTGAPEN - Transmit Short Gap Enable */
649 #define TMS570_EMACM_MACCONTROL_TXSHORTGAPEN BSP_BIT32(10)
650
651 /* field: TXPTYPE - Transmit queue priority type */
652 #define TMS570_EMACM_MACCONTROL_TXPTYPE BSP_BIT32(9)
653
654 /* field: TXPACE - Transmit pacing enable bit */
655 #define TMS570_EMACM_MACCONTROL_TXPACE BSP_BIT32(6)
656
657 /* field: GMIIEN - GMII enable bit */
658 #define TMS570_EMACM_MACCONTROL_GMIIEN BSP_BIT32(5)
659
660 /* field: TXFLOWEN - Transmit flow control enable bit. */
661 #define TMS570_EMACM_MACCONTROL_TXFLOWEN BSP_BIT32(4)
662
663 /* field: RXBUFFERFLOWEN - Receive buffer flow control enable bit */
664 #define TMS570_EMACM_MACCONTROL_RXBUFFERFLOWEN BSP_BIT32(3)
665
666 /* field: LOOPBACK - Loopback mode. The loopback mode forces internal full-duplex mode regardless of the FULLDUPLEX bit. */
667 #define TMS570_EMACM_MACCONTROL_LOOPBACK BSP_BIT32(1)
668
669 /* field: FULLDUPLEX - Full duplex mode. */
670 #define TMS570_EMACM_MACCONTROL_FULLDUPLEX BSP_BIT32(0)
671
672
673 /*-------------------TMS570_EMACM_MACSTATUS-------------------*/
674 /* field: IDLE - EMAC idle bit. This bit is cleared to 0 at reset; one clock after reset, it goes to 1. */
675 #define TMS570_EMACM_MACSTATUS_IDLE BSP_BIT32(31)
676
677 /* field: TXERRCODE - Transmit host error code. These bits indicate that EMAC detected transmit DMA related host errors. */
678 #define TMS570_EMACM_MACSTATUS_TXERRCODE(val) BSP_FLD32(val,20, 23)
679 #define TMS570_EMACM_MACSTATUS_TXERRCODE_GET(reg) BSP_FLD32GET(reg,20, 23)
680 #define TMS570_EMACM_MACSTATUS_TXERRCODE_SET(reg,val) BSP_FLD32SET(reg, val,20, 23)
681
682 /* field: TXERRCH - Transmit host error channel. These bits indicate which transmit channel the host error occurred on. */
683 #define TMS570_EMACM_MACSTATUS_TXERRCH(val) BSP_FLD32(val,16, 18)
684 #define TMS570_EMACM_MACSTATUS_TXERRCH_GET(reg) BSP_FLD32GET(reg,16, 18)
685 #define TMS570_EMACM_MACSTATUS_TXERRCH_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
686
687 /* field: RXERRCODE - Receive host error code. These bits indicate that EMAC detected receive DMA related host errors. */
688 #define TMS570_EMACM_MACSTATUS_RXERRCODE(val) BSP_FLD32(val,12, 15)
689 #define TMS570_EMACM_MACSTATUS_RXERRCODE_GET(reg) BSP_FLD32GET(reg,12, 15)
690 #define TMS570_EMACM_MACSTATUS_RXERRCODE_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
691
692 /* field: RXERRCH - Receive host error channel. These bits indicate which receive channel the host error occurred on. */
693 #define TMS570_EMACM_MACSTATUS_RXERRCH(val) BSP_FLD32(val,8, 10)
694 #define TMS570_EMACM_MACSTATUS_RXERRCH_GET(reg) BSP_FLD32GET(reg,8, 10)
695 #define TMS570_EMACM_MACSTATUS_RXERRCH_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
696
697 /* field: RXQOSACT - Receive Quality of Service (QOS) active bit. */
698 #define TMS570_EMACM_MACSTATUS_RXQOSACT BSP_BIT32(2)
699
700 /* field: RXFLOWACT - Receive flow control active bit. */
701 #define TMS570_EMACM_MACSTATUS_RXFLOWACT BSP_BIT32(1)
702
703 /* field: TXFLOWACT - Transmit flow control active bit. */
704 #define TMS570_EMACM_MACSTATUS_TXFLOWACT BSP_BIT32(0)
705
706
707 /*-------------------TMS570_EMACM_EMCONTROL-------------------*/
708 /* field: SOFT - Emulation soft bit. */
709 #define TMS570_EMACM_EMCONTROL_SOFT BSP_BIT32(1)
710
711 /* field: FREE - Emulation free bit. */
712 #define TMS570_EMACM_EMCONTROL_FREE BSP_BIT32(0)
713
714
715 /*------------------TMS570_EMACM_FIFOCONTROL------------------*/
716 /* field: TXCELLTHRESH - Transmit FIFO cell threshold. */
717 #define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH(val) BSP_FLD32(val,0, 1)
718 #define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH_GET(reg) BSP_FLD32GET(reg,0, 1)
719 #define TMS570_EMACM_FIFOCONTROL_TXCELLTHRESH_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
720
721
722 /*-------------------TMS570_EMACM_MACCONFIG-------------------*/
723 /* field: TXCELLDEPTH - Transmit cell depth. These bits indicate the number of cells in the transmit FIFO. */
724 #define TMS570_EMACM_MACCONFIG_TXCELLDEPTH(val) BSP_FLD32(val,24, 31)
725 #define TMS570_EMACM_MACCONFIG_TXCELLDEPTH_GET(reg) BSP_FLD32GET(reg,24, 31)
726 #define TMS570_EMACM_MACCONFIG_TXCELLDEPTH_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
727
728 /* field: RXCELLDEPTH - Receive cell depth. These bits indicate the number of cells in the receive FIFO. */
729 #define TMS570_EMACM_MACCONFIG_RXCELLDEPTH(val) BSP_FLD32(val,16, 23)
730 #define TMS570_EMACM_MACCONFIG_RXCELLDEPTH_GET(reg) BSP_FLD32GET(reg,16, 23)
731 #define TMS570_EMACM_MACCONFIG_RXCELLDEPTH_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
732
733 /* field: ADDRESSTYPE - Address type */
734 #define TMS570_EMACM_MACCONFIG_ADDRESSTYPE(val) BSP_FLD32(val,8, 15)
735 #define TMS570_EMACM_MACCONFIG_ADDRESSTYPE_GET(reg) BSP_FLD32GET(reg,8, 15)
736 #define TMS570_EMACM_MACCONFIG_ADDRESSTYPE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
737
738 /* field: MACCFIG - MAC configuration value */
739 #define TMS570_EMACM_MACCONFIG_MACCFIG(val) BSP_FLD32(val,0, 7)
740 #define TMS570_EMACM_MACCONFIG_MACCFIG_GET(reg) BSP_FLD32GET(reg,0, 7)
741 #define TMS570_EMACM_MACCONFIG_MACCFIG_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
742
743
744 /*-------------------TMS570_EMACM_SOFTRESET-------------------*/
745 /* field: SOFTRESET - Software reset. Writing a 1 to this bit causes the EMAC logic to be reset. */
746 #define TMS570_EMACM_SOFTRESET_SOFTRESET BSP_BIT32(0)
747
748
749 /*-----------------TMS570_EMACM_MACSRCADDRLO-----------------*/
750 /* field: MACSRCADDR0 - MAC source address lower 8-0 bits (byte 0) */
751 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0(val) BSP_FLD32(val,8, 15)
752 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0_GET(reg) BSP_FLD32GET(reg,8, 15)
753 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR0_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
754
755 /* field: MACSRCADDR1 - MAC source address bits 15-8 (byte 1) */
756 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1(val) BSP_FLD32(val,0, 7)
757 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1_GET(reg) BSP_FLD32GET(reg,0, 7)
758 #define TMS570_EMACM_MACSRCADDRLO_MACSRCADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
759
760
761 /*-----------------TMS570_EMACM_MACSRCADDRHI-----------------*/
762 /* field: MACSRCADDR2 - MAC source address bits 23-16 (byte 2) */
763 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2(val) BSP_FLD32(val,24, 31)
764 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2_GET(reg) BSP_FLD32GET(reg,24, 31)
765 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR2_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
766
767 /* field: MACSRCADDR3 - MAC source address bits 31-24 (byte 3) */
768 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3(val) BSP_FLD32(val,16, 23)
769 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3_GET(reg) BSP_FLD32GET(reg,16, 23)
770 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR3_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
771
772 /* field: MACSRCADDR4 - MAC source address bits 39-32 (byte 4) */
773 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4(val) BSP_FLD32(val,8, 15)
774 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4_GET(reg) BSP_FLD32GET(reg,8, 15)
775 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR4_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
776
777 /* field: MACSRCADDR5 - MAC source address bits 47-40 (byte 5) */
778 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5(val) BSP_FLD32(val,0, 7)
779 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5_GET(reg) BSP_FLD32GET(reg,0, 7)
780 #define TMS570_EMACM_MACSRCADDRHI_MACSRCADDR5_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
781
782
783 /*-------------------TMS570_EMACM_MACHASH1-------------------*/
784 /* field: MACHASH1 - Least-significant 32 bits of the hash table corresponding to hash values 0 to 31. */
785 /* Whole 32 bits */
786
787 /*-------------------TMS570_EMACM_MACHASH2-------------------*/
788 /* field: MACHASH2 - Most-significant 32 bits of the hash table corresponding to hash values 32 to 63. */
789 /* Whole 32 bits */
790
791 /*-------------------TMS570_EMACM_BOFFTEST-------------------*/
792 /* field: RNDNUM - Backoff random number generator. */
793 #define TMS570_EMACM_BOFFTEST_RNDNUM(val) BSP_FLD32(val,16, 25)
794 #define TMS570_EMACM_BOFFTEST_RNDNUM_GET(reg) BSP_FLD32GET(reg,16, 25)
795 #define TMS570_EMACM_BOFFTEST_RNDNUM_SET(reg,val) BSP_FLD32SET(reg, val,16, 25)
796
797 /* field: COLLCOUNT - Collision count. These bits indicate the number of collisions the current frame has experienced. */
798 #define TMS570_EMACM_BOFFTEST_COLLCOUNT(val) BSP_FLD32(val,12, 15)
799 #define TMS570_EMACM_BOFFTEST_COLLCOUNT_GET(reg) BSP_FLD32GET(reg,12, 15)
800 #define TMS570_EMACM_BOFFTEST_COLLCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
801
802 /* field: TXBACKOFF - Backoff count. */
803 #define TMS570_EMACM_BOFFTEST_TXBACKOFF(val) BSP_FLD32(val,0, 9)
804 #define TMS570_EMACM_BOFFTEST_TXBACKOFF_GET(reg) BSP_FLD32GET(reg,0, 9)
805 #define TMS570_EMACM_BOFFTEST_TXBACKOFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
806
807
808 /*-------------------TMS570_EMACM_TPACETEST-------------------*/
809 /* field: PACEVAL - Pacing register current value. A nonzero value in this field indicates that transmit pacing is active. */
810 #define TMS570_EMACM_TPACETEST_PACEVAL(val) BSP_FLD32(val,0, 4)
811 #define TMS570_EMACM_TPACETEST_PACEVAL_GET(reg) BSP_FLD32GET(reg,0, 4)
812 #define TMS570_EMACM_TPACETEST_PACEVAL_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
813
814
815 /*--------------------TMS570_EMACM_RXPAUSE--------------------*/
816 /* field: PAUSETIMER - Receive pause timer value. */
817 #define TMS570_EMACM_RXPAUSE_PAUSETIMER(val) BSP_FLD32(val,0, 15)
818 #define TMS570_EMACM_RXPAUSE_PAUSETIMER_GET(reg) BSP_FLD32GET(reg,0, 15)
819 #define TMS570_EMACM_RXPAUSE_PAUSETIMER_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
820
821
822 /*--------------------TMS570_EMACM_TXPAUSE--------------------*/
823 /* field: PAUSETIMER - Transmit pause timer value. */
824 #define TMS570_EMACM_TXPAUSE_PAUSETIMER(val) BSP_FLD32(val,0, 15)
825 #define TMS570_EMACM_TXPAUSE_PAUSETIMER_GET(reg) BSP_FLD32GET(reg,0, 15)
826 #define TMS570_EMACM_TXPAUSE_PAUSETIMER_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
827
828
829 /*-------------------TMS570_EMACM_MACADDRLO-------------------*/
830 /* field: VALID - Address valid bit. */
831 #define TMS570_EMACM_MACADDRLO_VALID BSP_BIT32(20)
832
833 /* field: MATCHFILT - Match or filter bit */
834 #define TMS570_EMACM_MACADDRLO_MATCHFILT BSP_BIT32(19)
835
836 /* field: CHANNEL - Channel select. Determines which receive channel a valid address match will be transferred to. */
837 #define TMS570_EMACM_MACADDRLO_CHANNEL(val) BSP_FLD32(val,16, 18)
838 #define TMS570_EMACM_MACADDRLO_CHANNEL_GET(reg) BSP_FLD32GET(reg,16, 18)
839 #define TMS570_EMACM_MACADDRLO_CHANNEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
840
841 /* field: MACADDR0 - MAC address lower 8-0 bits (byte 0) */
842 #define TMS570_EMACM_MACADDRLO_MACADDR0(val) BSP_FLD32(val,8, 15)
843 #define TMS570_EMACM_MACADDRLO_MACADDR0_GET(reg) BSP_FLD32GET(reg,8, 15)
844 #define TMS570_EMACM_MACADDRLO_MACADDR0_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
845
846 /* field: MACADDR1 - MAC address bits 15-8 (byte 1) */
847 #define TMS570_EMACM_MACADDRLO_MACADDR1(val) BSP_FLD32(val,0, 7)
848 #define TMS570_EMACM_MACADDRLO_MACADDR1_GET(reg) BSP_FLD32GET(reg,0, 7)
849 #define TMS570_EMACM_MACADDRLO_MACADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
850
851
852 /*-------------------TMS570_EMACM_MACADDRHI-------------------*/
853 /* field: MACADDR2 - MAC source address bits 23-16 (byte 2) */
854 #define TMS570_EMACM_MACADDRHI_MACADDR2(val) BSP_FLD32(val,24, 31)
855 #define TMS570_EMACM_MACADDRHI_MACADDR2_GET(reg) BSP_FLD32GET(reg,24, 31)
856 #define TMS570_EMACM_MACADDRHI_MACADDR2_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
857
858 /* field: MACADDR3 - MAC source address bits 31-24 (byte 3) */
859 #define TMS570_EMACM_MACADDRHI_MACADDR3(val) BSP_FLD32(val,16, 23)
860 #define TMS570_EMACM_MACADDRHI_MACADDR3_GET(reg) BSP_FLD32GET(reg,16, 23)
861 #define TMS570_EMACM_MACADDRHI_MACADDR3_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
862
863 /* field: MACADDR4 - MAC source address bits 39-32 (byte 4) */
864 #define TMS570_EMACM_MACADDRHI_MACADDR4(val) BSP_FLD32(val,8, 15)
865 #define TMS570_EMACM_MACADDRHI_MACADDR4_GET(reg) BSP_FLD32GET(reg,8, 15)
866 #define TMS570_EMACM_MACADDRHI_MACADDR4_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
867
868 /* field: MACADDR5 - MAC source address bits 47-40 (byte 5). Bit 40 is the group bit. It is forced to 0 and read as 0. */
869 #define TMS570_EMACM_MACADDRHI_MACADDR5(val) BSP_FLD32(val,0, 7)
870 #define TMS570_EMACM_MACADDRHI_MACADDR5_GET(reg) BSP_FLD32GET(reg,0, 7)
871 #define TMS570_EMACM_MACADDRHI_MACADDR5_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
872
873
874 /*-------------------TMS570_EMACM_MACINDEX-------------------*/
875 /* field: MACINDEX - MAC address index. All eight addresses share the upper 40 bits. */
876 #define TMS570_EMACM_MACINDEX_MACINDEX(val) BSP_FLD32(val,0, 2)
877 #define TMS570_EMACM_MACINDEX_MACINDEX_GET(reg) BSP_FLD32GET(reg,0, 2)
878 #define TMS570_EMACM_MACINDEX_MACINDEX_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
879
880
881 /*---------------------TMS570_EMACM_TXHDP---------------------*/
882 /* field: TXnHDP - Transmit channel n DMA Head Descriptor pointer. */
883 /* Whole 32 bits */
884
885 /*---------------------TMS570_EMACM_RXHDP---------------------*/
886 /* field: RXnHDP - Receive channel n DMA Head Descriptor pointer. */
887 /* Whole 32 bits */
888
889 /*---------------------TMS570_EMACM_TXCP---------------------*/
890 /* field: TXnCP - Transmit channel n completion pointer register is written by the host with the buffer descriptor */
891 /* Whole 32 bits */
892
893 /*---------------------TMS570_EMACM_RXCP---------------------*/
894 /* field: RXnCP - Receive channel n completion pointer register is written by the host with the buffer descriptor */
895 /* Whole 32 bits */
896
897
898 #endif /* LIBBSP_ARM_TMS570_EMACM */
Definition: reg_emacm.h:44
Utility macros.
