RTEMS  5.1
reg_emacc.h
1 /* The header file is generated by make_header.py from EMACC.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_EMACC
40 #define LIBBSP_ARM_TMS570_EMACC
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t REVID; /*EMAC Control Module Revision ID Register*/
46  uint32_t SOFTRESET; /*EMAC Control Module Software Reset Register*/
47  uint8_t reserved1 [4];
48  uint32_t INTCONTROL; /*EMAC Control Module Interrupt Control Register*/
49  uint32_t C0RXTHRESHEN; /*EMAC Control Module Receive Threshold Interrupt Enable Register*/
50  uint32_t C0RXEN; /*EMAC Control Module Receive Interrupt Enable Register*/
51  uint32_t C0TXEN; /*EMAC Control Module Transmit Interrupt Enable Register*/
52  uint32_t C0MISCEN; /*EMAC Control Module Miscellaneous Interrupt Enable Register*/
53  uint8_t reserved2 [32];
54  uint32_t C0RXTHRESHSTAT; /*EMAC Control Module Receive Threshold Interrupt Status Register*/
55  uint32_t C0RXSTAT; /*EMAC Control Module Receive Interrupt Status Register*/
56  uint32_t C0TXSTAT; /*EMAC Control Module Transmit Interrupt Status Register*/
57  uint32_t C0MISCSTAT; /*EMAC Control Module Miscellaneous Interrupt Status Register*/
58  uint8_t reserved3 [32];
59  uint32_t C0RXIMAX; /*EMAC Control Module Receive Interrupts Per Millisecond Register*/
60  uint32_t C0TXIMAX; /*EMAC Control Module Transmit Interrupts Per Millisecond Register*/
62
63
64 /*---------------------TMS570_EMACC_REVID---------------------*/
65 /* field: REV - Identifies the EMAC Control Module revision. */
66 /* Whole 32 bits */
67
68 /*-------------------TMS570_EMACC_SOFTRESET-------------------*/
69 /* field: RESET - Software reset bit for the EMAC Control Module. */
70 #define TMS570_EMACC_SOFTRESET_RESET BSP_BIT32(0)
71
72
73 /*------------------TMS570_EMACC_INTCONTROL------------------*/
74 /* field: C0TXPACEEN - Enable pacing for TX interrupt pulse generation */
75 #define TMS570_EMACC_INTCONTROL_C0TXPACEEN BSP_BIT32(17)
76
77 /* field: C0RXPACEEN - Enable pacing for RX interrupt pulse generation */
78 #define TMS570_EMACC_INTCONTROL_C0RXPACEEN BSP_BIT32(16)
79
80 /* field: INTPRESCALE - Number of internal EMAC module reference clock periods within a 4 us time window (see */
81 #define TMS570_EMACC_INTCONTROL_INTPRESCALE(val) BSP_FLD32(val,0, 11)
82 #define TMS570_EMACC_INTCONTROL_INTPRESCALE_GET(reg) BSP_FLD32GET(reg,0, 11)
83 #define TMS570_EMACC_INTCONTROL_INTPRESCALE_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
84
85
86 /*-----------------TMS570_EMACC_C0RXTHRESHEN-----------------*/
87 /* field: RXCH7THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 7 */
88 #define TMS570_EMACC_C0RXTHRESHEN_RXCH7THRESHEN BSP_BIT32(7)
89
90 /* field: RXCH6THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 6 */
91 #define TMS570_EMACC_C0RXTHRESHEN_RXCH6THRESHEN BSP_BIT32(6)
92
93 /* field: RXCH5THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 5 */
94 #define TMS570_EMACC_C0RXTHRESHEN_RXCH5THRESHEN BSP_BIT32(5)
95
96 /* field: RXCH4THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 4 */
97 #define TMS570_EMACC_C0RXTHRESHEN_RXCH4THRESHEN BSP_BIT32(4)
98
99 /* field: RXCH3THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 3 */
100 #define TMS570_EMACC_C0RXTHRESHEN_RXCH3THRESHEN BSP_BIT32(3)
101
102 /* field: RXCH2THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 2 */
103 #define TMS570_EMACC_C0RXTHRESHEN_RXCH2THRESHEN BSP_BIT32(2)
104
105 /* field: RXCH1THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 1 */
106 #define TMS570_EMACC_C0RXTHRESHEN_RXCH1THRESHEN BSP_BIT32(1)
107
108 /* field: RXCH0THRESHEN - Enable C0RXTHRESHPULSE interrupt generation for RX Channel 0 */
109 #define TMS570_EMACC_C0RXTHRESHEN_RXCH0THRESHEN BSP_BIT32(0)
110
111
112 /*--------------------TMS570_EMACC_C0RXEN--------------------*/
113 /* field: RXCH7EN - Enable C0RXPULSE interrupt generation for RX Channel 7 */
114 #define TMS570_EMACC_C0RXEN_RXCH7EN BSP_BIT32(7)
115
116 /* field: RXCH6EN - Enable C0RXPULSE interrupt generation for RX Channel 6 */
117 #define TMS570_EMACC_C0RXEN_RXCH6EN BSP_BIT32(6)
118
119 /* field: RXCH5EN - Enable C0RXPULSE interrupt generation for RX Channel 5 */
120 #define TMS570_EMACC_C0RXEN_RXCH5EN BSP_BIT32(5)
121
122 /* field: RXCH4EN - Enable C0RXPULSE interrupt generation for RX Channel 4 */
123 #define TMS570_EMACC_C0RXEN_RXCH4EN BSP_BIT32(4)
124
125 /* field: RXCH3EN - Enable C0RXPULSE interrupt generation for RX Channel 3 */
126 #define TMS570_EMACC_C0RXEN_RXCH3EN BSP_BIT32(3)
127
128 /* field: RXCH2EN - Enable C0RXPULSE interrupt generation for RX Channel 2 */
129 #define TMS570_EMACC_C0RXEN_RXCH2EN BSP_BIT32(2)
130
131 /* field: RXCH1EN - Enable C0RXPULSE interrupt generation for RX Channel 1 */
132 #define TMS570_EMACC_C0RXEN_RXCH1EN BSP_BIT32(1)
133
134 /* field: RXCH0EN - Enable C0RXPULSE interrupt generation for RX Channel 0 */
135 #define TMS570_EMACC_C0RXEN_RXCH0EN BSP_BIT32(0)
136
137
138 /*--------------------TMS570_EMACC_C0TXEN--------------------*/
139 /* field: TXCH7EN - Enable C0TXPULSE interrupt generation for TX Channel 7 */
140 #define TMS570_EMACC_C0TXEN_TXCH7EN BSP_BIT32(7)
141
142 /* field: TXCH6EN - TXCH6EN */
143 #define TMS570_EMACC_C0TXEN_TXCH6EN BSP_BIT32(6)
144
145 /* field: TXCH5EN - Enable C0TXPULSE interrupt generation for TX Channel 5 */
146 #define TMS570_EMACC_C0TXEN_TXCH5EN BSP_BIT32(5)
147
148 /* field: TXCH4EN - Enable C0TXPULSE interrupt generation for TX Channel 4 */
149 #define TMS570_EMACC_C0TXEN_TXCH4EN BSP_BIT32(4)
150
151 /* field: TXCH3EN - Enable C0TXPULSE interrupt generation for TX Channel 3 */
152 #define TMS570_EMACC_C0TXEN_TXCH3EN BSP_BIT32(3)
153
154 /* field: TXCH2EN - Enable C0TXPULSE interrupt generation for TX Channel 2 */
155 #define TMS570_EMACC_C0TXEN_TXCH2EN BSP_BIT32(2)
156
157 /* field: TXCH1EN - Enable C0TXPULSE interrupt generation for TX Channel 1 */
158 #define TMS570_EMACC_C0TXEN_TXCH1EN BSP_BIT32(1)
159
160 /* field: TXCH0EN - Enable C0TXPULSE interrupt generation for TX Channel 0 */
161 #define TMS570_EMACC_C0TXEN_TXCH0EN BSP_BIT32(0)
162
163
164 /*-------------------TMS570_EMACC_C0MISCEN-------------------*/
165 /* field: STATPENDEN - Enable C0MISCPULSE interrupt generation when EMAC statistics interrupts are generated */
166 #define TMS570_EMACC_C0MISCEN_STATPENDEN BSP_BIT32(3)
167
168 /* field: HOSTPENDEN - HOSTPENDEN */
169 #define TMS570_EMACC_C0MISCEN_HOSTPENDEN BSP_BIT32(2)
170
171 /* field: LINKINT0EN - Enable C0MISCPULSE interrupt generation when MDIO LINKINT0 interrupts (corresponding to */
172 #define TMS570_EMACC_C0MISCEN_LINKINT0EN BSP_BIT32(1)
173
174 /* field: USERINT0EN - Enable C0MISCPULSE interrupt generation when MDIO USERINT0 interrupts (corresponding */
175 #define TMS570_EMACC_C0MISCEN_USERINT0EN BSP_BIT32(0)
176
177
178 /*----------------TMS570_EMACC_C0RXTHRESHSTAT----------------*/
179 /* field: RXCH7THRESHSTAT - Interrupt status for RX Channel 7 masked by the C0RXTHRESHEN register */
180 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH7THRESHSTAT BSP_BIT32(7)
181
182 /* field: RXCH6THRESHSTAT - Interrupt status for RX Channel 6 masked by the C0RXTHRESHEN register */
183 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH6THRESHSTAT BSP_BIT32(6)
184
185 /* field: RXCH5THRESHSTAT - Interrupt status for RX Channel 5 masked by the C0RXTHRESHEN register */
186 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH5THRESHSTAT BSP_BIT32(5)
187
188 /* field: RXCH4THRESHSTAT - Interrupt status for RX Channel 4 masked by the C0RXTHRESHEN register */
189 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH4THRESHSTAT BSP_BIT32(4)
190
191 /* field: RXCH3THRESHSTAT - Interrupt status for RX Channel 3 masked by the C0RXTHRESHEN register */
192 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH3THRESHSTAT BSP_BIT32(3)
193
194 /* field: RXCH2THRESHSTAT - Interrupt status for RX Channel 2 masked by the C0RXTHRESHEN register */
195 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH2THRESHSTAT BSP_BIT32(2)
196
197 /* field: RXCH1THRESHSTAT - Interrupt status for RX Channel 1 masked by the C0RXTHRESHEN register */
198 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH1THRESHSTAT BSP_BIT32(1)
199
200 /* field: RXCH0THRESHSTAT - Interrupt status for RX Channel 0 masked by the C0RXTHRESHEN register */
201 #define TMS570_EMACC_C0RXTHRESHSTAT_RXCH0THRESHSTAT BSP_BIT32(0)
202
203
204 /*-------------------TMS570_EMACC_C0RXSTAT-------------------*/
205 /* field: RXCH7STAT - RXCH7STAT */
206 #define TMS570_EMACC_C0RXSTAT_RXCH7STAT BSP_BIT32(7)
207
208 /* field: RXCH6STAT - Interrupt status for RX Channel 6 masked by the C0RXEN register */
209 #define TMS570_EMACC_C0RXSTAT_RXCH6STAT BSP_BIT32(6)
210
211 /* field: RXCH5STAT - Interrupt status for RX Channel 5 masked by the C0RXEN register */
212 #define TMS570_EMACC_C0RXSTAT_RXCH5STAT BSP_BIT32(5)
213
214 /* field: RXCH4STAT - Interrupt status for RX Channel 4 masked by the C0RXEN register */
215 #define TMS570_EMACC_C0RXSTAT_RXCH4STAT BSP_BIT32(4)
216
217 /* field: RXCH3STAT - Interrupt status for RX Channel 3 masked by the C0RXEN register */
218 #define TMS570_EMACC_C0RXSTAT_RXCH3STAT BSP_BIT32(3)
219
220 /* field: RXCH2STAT - H2STAT Interrupt status for RX Channel 2 masked by the C0RXEN register */
221 #define TMS570_EMACC_C0RXSTAT_RXCH2STAT BSP_BIT32(2)
222
223 /* field: RXCH1STAT - Interrupt status for RX Channel 1 masked by the C0RXEN register */
224 #define TMS570_EMACC_C0RXSTAT_RXCH1STAT BSP_BIT32(1)
225
226 /* field: RXCH0STAT - Interrupt status for RX Channel 0 masked by the C0RXEN register */
227 #define TMS570_EMACC_C0RXSTAT_RXCH0STAT BSP_BIT32(0)
228
229
230 /*-------------------TMS570_EMACC_C0TXSTAT-------------------*/
231 /* field: TXCH7STAT - Interrupt status for TX Channel 7 masked by the C0TXEN register */
232 #define TMS570_EMACC_C0TXSTAT_TXCH7STAT BSP_BIT32(7)
233
234 /* field: TXCH6STAT - TXCH6STAT */
235 #define TMS570_EMACC_C0TXSTAT_TXCH6STAT BSP_BIT32(6)
236
237 /* field: TXCH5STAT - Interrupt status for TX Channel 5 masked by the C0TXEN register */
238 #define TMS570_EMACC_C0TXSTAT_TXCH5STAT BSP_BIT32(5)
239
240 /* field: TXCH4STAT - Interrupt status for TX Channel 4 masked by the C0TXEN register */
241 #define TMS570_EMACC_C0TXSTAT_TXCH4STAT BSP_BIT32(4)
242
243 /* field: TXCH3STAT - Interrupt status for TX Channel 3 masked by the C0TXEN register */
244 #define TMS570_EMACC_C0TXSTAT_TXCH3STAT BSP_BIT32(3)
245
246 /* field: TXCH2STAT - Interrupt status for TX Channel 2 masked by the C0TXEN register */
247 #define TMS570_EMACC_C0TXSTAT_TXCH2STAT BSP_BIT32(2)
248
249 /* field: TXCH1STAT - Interrupt status for TX Channel 1 masked by the C0TXEN register */
250 #define TMS570_EMACC_C0TXSTAT_TXCH1STAT BSP_BIT32(1)
251
252 /* field: TXCH0STAT - Interrupt status for TX Channel 0 masked by the C0TXEN register */
253 #define TMS570_EMACC_C0TXSTAT_TXCH0STAT BSP_BIT32(0)
254
255
256 /*------------------TMS570_EMACC_C0MISCSTAT------------------*/
257 /* field: STATPENDSTAT - Interrupt status for EMAC STATPEND masked by the C0MISCEN register */
258 #define TMS570_EMACC_C0MISCSTAT_STATPENDSTAT BSP_BIT32(3)
259
260 /* field: HOSTPENDSTAT - Interrupt status for EMAC HOSTPEND masked by the C0MISCEN register */
261 #define TMS570_EMACC_C0MISCSTAT_HOSTPENDSTAT BSP_BIT32(2)
262
263 /* field: LINKINT0STAT - Interrupt status for MDIO LINKINT0 masked by the C0MISCEN register */
264 #define TMS570_EMACC_C0MISCSTAT_LINKINT0STAT BSP_BIT32(1)
265
266 /* field: USERINT0STAT - Interrupt status for MDIO USERINT0 masked by the C0MISCEN register */
267 #define TMS570_EMACC_C0MISCSTAT_USERINT0STAT BSP_BIT32(0)
268
269
270 /*-------------------TMS570_EMACC_C0RXIMAX-------------------*/
271 /* field: RXIMAX - RXIMAX is the desired number of C0RXPULSE interrupts generated per millisecond when */
272 #define TMS570_EMACC_C0RXIMAX_RXIMAX(val) BSP_FLD32(val,0, 5)
273 #define TMS570_EMACC_C0RXIMAX_RXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
274 #define TMS570_EMACC_C0RXIMAX_RXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
275
276
277 /*-------------------TMS570_EMACC_C0TXIMAX-------------------*/
278 /* field: TXIMAX - TXIMAX is the desired number of C0TXPULSE interrupts generated per millisecond when */
279 #define TMS570_EMACC_C0TXIMAX_TXIMAX(val) BSP_FLD32(val,0, 5)
280 #define TMS570_EMACC_C0TXIMAX_TXIMAX_GET(reg) BSP_FLD32GET(reg,0, 5)
281 #define TMS570_EMACC_C0TXIMAX_TXIMAX_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
282
283
284
285 #endif /* LIBBSP_ARM_TMS570_EMACC */
Utility macros.
Definition: reg_emacc.h:44
