RTEMS
5.1
39 #ifndef LIBBSP_ARM_TMS570_DMA 40 #define LIBBSP_ARM_TMS570_DMA 52 uint8_t reserved1 [4];
54 uint8_t reserved2 [4];
56 uint8_t reserved3 [4];
58 uint8_t reserved4 [4];
60 uint8_t reserved5 [4];
62 uint8_t reserved6 [4];
64 uint8_t reserved7 [4];
66 uint8_t reserved8 [4];
68 uint8_t reserved9 [4];
70 uint8_t reserved10 [4];
72 uint8_t reserved11 [48];
75 uint8_t reserved12 [24];
77 uint8_t reserved13 [4];
79 uint8_t reserved14 [4];
81 uint8_t reserved15 [4];
83 uint8_t reserved16 [4];
85 uint8_t reserved17 [4];
87 uint8_t reserved18 [4];
89 uint8_t reserved19 [4];
91 uint8_t reserved20 [4];
93 uint8_t reserved21 [4];
95 uint8_t reserved22 [4];
97 uint8_t reserved23 [4];
99 uint8_t reserved24 [4];
101 uint8_t reserved25 [4];
103 uint8_t reserved26 [4];
105 uint8_t reserved27 [4];
107 uint8_t reserved28 [4];
109 uint8_t reserved29 [4];
111 uint8_t reserved30 [4];
113 uint8_t reserved31 [4];
124 uint8_t reserved32 [4];
130 uint8_t reserved33 [12];
134 uint8_t reserved34 [4];
153 #define TMS570_DMA_GCTRL_DMA_EN BSP_BIT32(16) 156 #define TMS570_DMA_GCTRL_BUS_BUSY BSP_BIT32(14) 159 #define TMS570_DMA_GCTRL_DEBUG_MODE(val) BSP_FLD32(val,8, 9) 160 #define TMS570_DMA_GCTRL_DEBUG_MODE_GET(reg) BSP_FLD32GET(reg,8, 9) 161 #define TMS570_DMA_GCTRL_DEBUG_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9) 164 #define TMS570_DMA_GCTRL_DMA_RES BSP_BIT32(0) 169 #define TMS570_DMA_PEND_PEND(val) BSP_FLD32(val,0, 15) 170 #define TMS570_DMA_PEND_PEND_GET(reg) BSP_FLD32GET(reg,0, 15) 171 #define TMS570_DMA_PEND_PEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 176 #define TMS570_DMA_DMASTAT_STCH(val) BSP_FLD32(val,0, 15) 177 #define TMS570_DMA_DMASTAT_STCH_GET(reg) BSP_FLD32GET(reg,0, 15) 178 #define TMS570_DMA_DMASTAT_STCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 183 #define TMS570_DMA_HWCHENAS_HWCHENA(val) BSP_FLD32(val,0, 15) 184 #define TMS570_DMA_HWCHENAS_HWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15) 185 #define TMS570_DMA_HWCHENAS_HWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 190 #define TMS570_DMA_HWCHENAR_HWCHDIS(val) BSP_FLD32(val,0, 15) 191 #define TMS570_DMA_HWCHENAR_HWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 192 #define TMS570_DMA_HWCHENAR_HWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 197 #define TMS570_DMA_SWCHENAS_SWCHENA(val) BSP_FLD32(val,0, 15) 198 #define TMS570_DMA_SWCHENAS_SWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15) 199 #define TMS570_DMA_SWCHENAS_SWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 204 #define TMS570_DMA_SWCHENAR_SWCHDIS(val) BSP_FLD32(val,0, 15) 205 #define TMS570_DMA_SWCHENAR_SWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 206 #define TMS570_DMA_SWCHENAR_SWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 211 #define TMS570_DMA_CHPRIOS_CPS(val) BSP_FLD32(val,0, 15) 212 #define TMS570_DMA_CHPRIOS_CPS_GET(reg) BSP_FLD32GET(reg,0, 15) 213 #define TMS570_DMA_CHPRIOS_CPS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 218 #define TMS570_DMA_CHPRIOR_CPR(val) BSP_FLD32(val,0, 15) 219 #define TMS570_DMA_CHPRIOR_CPR_GET(reg) BSP_FLD32GET(reg,0, 15) 220 #define TMS570_DMA_CHPRIOR_CPR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 225 #define TMS570_DMA_GCHIENAS_GCHIE(val) BSP_FLD32(val,0, 15) 226 #define TMS570_DMA_GCHIENAS_GCHIE_GET(reg) BSP_FLD32GET(reg,0, 15) 227 #define TMS570_DMA_GCHIENAS_GCHIE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 232 #define TMS570_DMA_GCHIENAR_GCHID(val) BSP_FLD32(val,0, 15) 233 #define TMS570_DMA_GCHIENAR_GCHID_GET(reg) BSP_FLD32GET(reg,0, 15) 234 #define TMS570_DMA_GCHIENAR_GCHID_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 239 #define TMS570_DMA_DREQASI_CH0ASI(val) BSP_FLD32(val,24, 29) 240 #define TMS570_DMA_DREQASI_CH0ASI_GET(reg) BSP_FLD32GET(reg,24, 29) 241 #define TMS570_DMA_DREQASI_CH0ASI_SET(reg,val) BSP_FLD32SET(reg, val,24, 29) 244 #define TMS570_DMA_DREQASI_CH1ASI(val) BSP_FLD32(val,16, 21) 245 #define TMS570_DMA_DREQASI_CH1ASI_GET(reg) BSP_FLD32GET(reg,16, 21) 246 #define TMS570_DMA_DREQASI_CH1ASI_SET(reg,val) BSP_FLD32SET(reg, val,16, 21) 249 #define TMS570_DMA_DREQASI_CH2ASI(val) BSP_FLD32(val,8, 13) 250 #define TMS570_DMA_DREQASI_CH2ASI_GET(reg) BSP_FLD32GET(reg,8, 13) 251 #define TMS570_DMA_DREQASI_CH2ASI_SET(reg,val) BSP_FLD32SET(reg, val,8, 13) 254 #define TMS570_DMA_DREQASI_CH3ASI(val) BSP_FLD32(val,0, 5) 255 #define TMS570_DMA_DREQASI_CH3ASI_GET(reg) BSP_FLD32GET(reg,0, 5) 256 #define TMS570_DMA_DREQASI_CH3ASI_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 261 #define TMS570_DMA_PAR0_CH0PA(val) BSP_FLD32(val,28, 30) 262 #define TMS570_DMA_PAR0_CH0PA_GET(reg) BSP_FLD32GET(reg,28, 30) 263 #define TMS570_DMA_PAR0_CH0PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30) 266 #define TMS570_DMA_PAR0_CH1PA(val) BSP_FLD32(val,24, 26) 267 #define TMS570_DMA_PAR0_CH1PA_GET(reg) BSP_FLD32GET(reg,24, 26) 268 #define TMS570_DMA_PAR0_CH1PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26) 271 #define TMS570_DMA_PAR0_CH2PA(val) BSP_FLD32(val,20, 22) 272 #define TMS570_DMA_PAR0_CH2PA_GET(reg) BSP_FLD32GET(reg,20, 22) 273 #define TMS570_DMA_PAR0_CH2PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22) 276 #define TMS570_DMA_PAR0_CH3PA(val) BSP_FLD32(val,16, 18) 277 #define TMS570_DMA_PAR0_CH3PA_GET(reg) BSP_FLD32GET(reg,16, 18) 278 #define TMS570_DMA_PAR0_CH3PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18) 281 #define TMS570_DMA_PAR0_CH4PA(val) BSP_FLD32(val,12, 14) 282 #define TMS570_DMA_PAR0_CH4PA_GET(reg) BSP_FLD32GET(reg,12, 14) 283 #define TMS570_DMA_PAR0_CH4PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14) 286 #define TMS570_DMA_PAR0_CH5PA(val) BSP_FLD32(val,8, 10) 287 #define TMS570_DMA_PAR0_CH5PA_GET(reg) BSP_FLD32GET(reg,8, 10) 288 #define TMS570_DMA_PAR0_CH5PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10) 291 #define TMS570_DMA_PAR0_CH6PA(val) BSP_FLD32(val,4, 6) 292 #define TMS570_DMA_PAR0_CH6PA_GET(reg) BSP_FLD32GET(reg,4, 6) 293 #define TMS570_DMA_PAR0_CH6PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6) 296 #define TMS570_DMA_PAR0_CH7PA(val) BSP_FLD32(val,0, 2) 297 #define TMS570_DMA_PAR0_CH7PA_GET(reg) BSP_FLD32GET(reg,0, 2) 298 #define TMS570_DMA_PAR0_CH7PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2) 303 #define TMS570_DMA_PAR1_CH8PA(val) BSP_FLD32(val,28, 30) 304 #define TMS570_DMA_PAR1_CH8PA_GET(reg) BSP_FLD32GET(reg,28, 30) 305 #define TMS570_DMA_PAR1_CH8PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30) 308 #define TMS570_DMA_PAR1_CH9PA(val) BSP_FLD32(val,24, 26) 309 #define TMS570_DMA_PAR1_CH9PA_GET(reg) BSP_FLD32GET(reg,24, 26) 310 #define TMS570_DMA_PAR1_CH9PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26) 313 #define TMS570_DMA_PAR1_CH10PA(val) BSP_FLD32(val,20, 22) 314 #define TMS570_DMA_PAR1_CH10PA_GET(reg) BSP_FLD32GET(reg,20, 22) 315 #define TMS570_DMA_PAR1_CH10PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22) 318 #define TMS570_DMA_PAR1_CH11PA(val) BSP_FLD32(val,16, 18) 319 #define TMS570_DMA_PAR1_CH11PA_GET(reg) BSP_FLD32GET(reg,16, 18) 320 #define TMS570_DMA_PAR1_CH11PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18) 323 #define TMS570_DMA_PAR1_CH12PA(val) BSP_FLD32(val,12, 14) 324 #define TMS570_DMA_PAR1_CH12PA_GET(reg) BSP_FLD32GET(reg,12, 14) 325 #define TMS570_DMA_PAR1_CH12PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14) 328 #define TMS570_DMA_PAR1_CH13PA(val) BSP_FLD32(val,8, 10) 329 #define TMS570_DMA_PAR1_CH13PA_GET(reg) BSP_FLD32GET(reg,8, 10) 330 #define TMS570_DMA_PAR1_CH13PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10) 333 #define TMS570_DMA_PAR1_CH14PA(val) BSP_FLD32(val,4, 6) 334 #define TMS570_DMA_PAR1_CH14PA_GET(reg) BSP_FLD32GET(reg,4, 6) 335 #define TMS570_DMA_PAR1_CH14PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6) 338 #define TMS570_DMA_PAR1_CH15PA(val) BSP_FLD32(val,0, 2) 339 #define TMS570_DMA_PAR1_CH15PA_GET(reg) BSP_FLD32GET(reg,0, 2) 340 #define TMS570_DMA_PAR1_CH15PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2) 345 #define TMS570_DMA_FTCMAP_FTCAB(val) BSP_FLD32(val,0, 15) 346 #define TMS570_DMA_FTCMAP_FTCAB_GET(reg) BSP_FLD32GET(reg,0, 15) 347 #define TMS570_DMA_FTCMAP_FTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 352 #define TMS570_DMA_LFSMAP_LFSAB(val) BSP_FLD32(val,0, 15) 353 #define TMS570_DMA_LFSMAP_LFSAB_GET(reg) BSP_FLD32GET(reg,0, 15) 354 #define TMS570_DMA_LFSMAP_LFSAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 359 #define TMS570_DMA_HBCMAP_HBCAB(val) BSP_FLD32(val,0, 15) 360 #define TMS570_DMA_HBCMAP_HBCAB_GET(reg) BSP_FLD32GET(reg,0, 15) 361 #define TMS570_DMA_HBCMAP_HBCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 366 #define TMS570_DMA_BTCMAP_BTCAB(val) BSP_FLD32(val,0, 15) 367 #define TMS570_DMA_BTCMAP_BTCAB_GET(reg) BSP_FLD32GET(reg,0, 15) 368 #define TMS570_DMA_BTCMAP_BTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 373 #define TMS570_DMA_BERMAP_BERAB(val) BSP_FLD32(val,0, 15) 374 #define TMS570_DMA_BERMAP_BERAB_GET(reg) BSP_FLD32GET(reg,0, 15) 375 #define TMS570_DMA_BERMAP_BERAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 380 #define TMS570_DMA_FTCINTENAS_FTCINTENA(val) BSP_FLD32(val,0, 15) 381 #define TMS570_DMA_FTCINTENAS_FTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15) 382 #define TMS570_DMA_FTCINTENAS_FTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 387 #define TMS570_DMA_FTCINTENAR_FTCINTDIS(val) BSP_FLD32(val,0, 15) 388 #define TMS570_DMA_FTCINTENAR_FTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 389 #define TMS570_DMA_FTCINTENAR_FTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 394 #define TMS570_DMA_LFSINTENAS_LFSINTENA(val) BSP_FLD32(val,0, 15) 395 #define TMS570_DMA_LFSINTENAS_LFSINTENA_GET(reg) BSP_FLD32GET(reg,0, 15) 396 #define TMS570_DMA_LFSINTENAS_LFSINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 401 #define TMS570_DMA_LFSINTENAR_LFSINTDIS(val) BSP_FLD32(val,0, 15) 402 #define TMS570_DMA_LFSINTENAR_LFSINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 403 #define TMS570_DMA_LFSINTENAR_LFSINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 408 #define TMS570_DMA_HBCINTENAS_HBCINTENA(val) BSP_FLD32(val,0, 15) 409 #define TMS570_DMA_HBCINTENAS_HBCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15) 410 #define TMS570_DMA_HBCINTENAS_HBCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 415 #define TMS570_DMA_HBCINTENAR_HBCINTDIS(val) BSP_FLD32(val,0, 15) 416 #define TMS570_DMA_HBCINTENAR_HBCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 417 #define TMS570_DMA_HBCINTENAR_HBCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 422 #define TMS570_DMA_BTCINTENAS_BTCINTENA(val) BSP_FLD32(val,0, 15) 423 #define TMS570_DMA_BTCINTENAS_BTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15) 424 #define TMS570_DMA_BTCINTENAS_BTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 429 #define TMS570_DMA_BTCINTENAR_BTCINTDIS(val) BSP_FLD32(val,0, 15) 430 #define TMS570_DMA_BTCINTENAR_BTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15) 431 #define TMS570_DMA_BTCINTENAR_BTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 436 #define TMS570_DMA_GINTFLAG_GINT(val) BSP_FLD32(val,0, 15) 437 #define TMS570_DMA_GINTFLAG_GINT_GET(reg) BSP_FLD32GET(reg,0, 15) 438 #define TMS570_DMA_GINTFLAG_GINT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 443 #define TMS570_DMA_FTCFLAG_FTCI(val) BSP_FLD32(val,0, 15) 444 #define TMS570_DMA_FTCFLAG_FTCI_GET(reg) BSP_FLD32GET(reg,0, 15) 445 #define TMS570_DMA_FTCFLAG_FTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 450 #define TMS570_DMA_LFSFLAG_LFSI(val) BSP_FLD32(val,0, 15) 451 #define TMS570_DMA_LFSFLAG_LFSI_GET(reg) BSP_FLD32GET(reg,0, 15) 452 #define TMS570_DMA_LFSFLAG_LFSI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 457 #define TMS570_DMA_HBCFLAG_HBCI(val) BSP_FLD32(val,0, 15) 458 #define TMS570_DMA_HBCFLAG_HBCI_GET(reg) BSP_FLD32GET(reg,0, 15) 459 #define TMS570_DMA_HBCFLAG_HBCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 464 #define TMS570_DMA_BTCFLAG_BTCI(val) BSP_FLD32(val,0, 15) 465 #define TMS570_DMA_BTCFLAG_BTCI_GET(reg) BSP_FLD32GET(reg,0, 15) 466 #define TMS570_DMA_BTCFLAG_BTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 471 #define TMS570_DMA_BERFLAG_BERI(val) BSP_FLD32(val,0, 15) 472 #define TMS570_DMA_BERFLAG_BERI_GET(reg) BSP_FLD32GET(reg,0, 15) 473 #define TMS570_DMA_BERFLAG_BERI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15) 478 #define TMS570_DMA_FTCAOFFSET_sbz(val) BSP_FLD32(val,6, 7) 479 #define TMS570_DMA_FTCAOFFSET_sbz_GET(reg) BSP_FLD32GET(reg,6, 7) 480 #define TMS570_DMA_FTCAOFFSET_sbz_SET(reg,val) BSP_FLD32SET(reg, val,6, 7) 483 #define TMS570_DMA_FTCAOFFSET_FTCA(val) BSP_FLD32(val,0, 5) 484 #define TMS570_DMA_FTCAOFFSET_FTCA_GET(reg) BSP_FLD32GET(reg,0, 5) 485 #define TMS570_DMA_FTCAOFFSET_FTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 490 #define TMS570_DMA_LFSAOFFSET_LFSA(val) BSP_FLD32(val,0, 5) 491 #define TMS570_DMA_LFSAOFFSET_LFSA_GET(reg) BSP_FLD32GET(reg,0, 5) 492 #define TMS570_DMA_LFSAOFFSET_LFSA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 497 #define TMS570_DMA_HBCAOFFSET_HBCA(val) BSP_FLD32(val,0, 5) 498 #define TMS570_DMA_HBCAOFFSET_HBCA_GET(reg) BSP_FLD32GET(reg,0, 5) 499 #define TMS570_DMA_HBCAOFFSET_HBCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 504 #define TMS570_DMA_BTCAOFFSET_BTCA(val) BSP_FLD32(val,0, 5) 505 #define TMS570_DMA_BTCAOFFSET_BTCA_GET(reg) BSP_FLD32GET(reg,0, 5) 506 #define TMS570_DMA_BTCAOFFSET_BTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 511 #define TMS570_DMA_BERAOFFSET_BERA(val) BSP_FLD32(val,0, 5) 512 #define TMS570_DMA_BERAOFFSET_BERA_GET(reg) BSP_FLD32GET(reg,0, 5) 513 #define TMS570_DMA_BERAOFFSET_BERA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 518 #define TMS570_DMA_FTCBOFFSET_FTCB(val) BSP_FLD32(val,0, 5) 519 #define TMS570_DMA_FTCBOFFSET_FTCB_GET(reg) BSP_FLD32GET(reg,0, 5) 520 #define TMS570_DMA_FTCBOFFSET_FTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 525 #define TMS570_DMA_LFSBOFFSET_LFSB(val) BSP_FLD32(val,0, 5) 526 #define TMS570_DMA_LFSBOFFSET_LFSB_GET(reg) BSP_FLD32GET(reg,0, 5) 527 #define TMS570_DMA_LFSBOFFSET_LFSB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 532 #define TMS570_DMA_HBCBOFFSET_HBCB(val) BSP_FLD32(val,0, 5) 533 #define TMS570_DMA_HBCBOFFSET_HBCB_GET(reg) BSP_FLD32GET(reg,0, 5) 534 #define TMS570_DMA_HBCBOFFSET_HBCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 539 #define TMS570_DMA_BTCBOFFSET_BTCB(val) BSP_FLD32(val,0, 5) 540 #define TMS570_DMA_BTCBOFFSET_BTCB_GET(reg) BSP_FLD32GET(reg,0, 5) 541 #define TMS570_DMA_BTCBOFFSET_BTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 546 #define TMS570_DMA_BERBOFFSET_BERB(val) BSP_FLD32(val,0, 5) 547 #define TMS570_DMA_BERBOFFSET_BERB_GET(reg) BSP_FLD32GET(reg,0, 5) 548 #define TMS570_DMA_BERBOFFSET_BERB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5) 553 #define TMS570_DMA_PTCRL_PENDB BSP_BIT32(24) 556 #define TMS570_DMA_PTCRL_BYB BSP_BIT32(18) 559 #define TMS570_DMA_PTCRL_PSFRHQPB BSP_BIT32(17) 562 #define TMS570_DMA_PTCRL_PSFRLQPB BSP_BIT32(16) 567 #define TMS570_DMA_RTCTRL_RTC BSP_BIT32(0) 572 #define TMS570_DMA_DCTRL_CHNUM(val) BSP_FLD32(val,24, 28) 573 #define TMS570_DMA_DCTRL_CHNUM_GET(reg) BSP_FLD32GET(reg,24, 28) 574 #define TMS570_DMA_DCTRL_CHNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 28) 577 #define TMS570_DMA_DCTRL_DMADBGS BSP_BIT32(16) 580 #define TMS570_DMA_DCTRL_DBGEN BSP_BIT32(0) 601 #define TMS570_DMA_PBACTC_PBFTCOUNT(val) BSP_FLD32(val,16, 28) 602 #define TMS570_DMA_PBACTC_PBFTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 28) 603 #define TMS570_DMA_PBACTC_PBFTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 28) 606 #define TMS570_DMA_PBACTC_PBETCOUNT(val) BSP_FLD32(val,0, 12) 607 #define TMS570_DMA_PBACTC_PBETCOUNT_GET(reg) BSP_FLD32GET(reg,0, 12) 608 #define TMS570_DMA_PBACTC_PBETCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 12) 613 #define TMS570_DMA_DMAPCR_ERRA BSP_BIT32(16) 616 #define TMS570_DMA_DMAPCR_TEST BSP_BIT32(8) 619 #define TMS570_DMA_DMAPCR_PARITY_ENA(val) BSP_FLD32(val,0, 3) 620 #define TMS570_DMA_DMAPCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3) 621 #define TMS570_DMA_DMAPCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3) 626 #define TMS570_DMA_DMAPAR_EDFLAG BSP_BIT32(24) 629 #define TMS570_DMA_DMAPAR_ERRORADDRESS(val) BSP_FLD32(val,0, 11) 630 #define TMS570_DMA_DMAPAR_ERRORADDRESS_GET(reg) BSP_FLD32GET(reg,0, 11) 631 #define TMS570_DMA_DMAPAR_ERRORADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 11) 636 #define TMS570_DMA_DMAMPCTRL_INT3AB BSP_BIT32(28) 639 #define TMS570_DMA_DMAMPCTRL_INT3ENA BSP_BIT32(27) 642 #define TMS570_DMA_DMAMPCTRL_REG3AP(val) BSP_FLD32(val,25, 26) 643 #define TMS570_DMA_DMAMPCTRL_REG3AP_GET(reg) BSP_FLD32GET(reg,25, 26) 644 #define TMS570_DMA_DMAMPCTRL_REG3AP_SET(reg,val) BSP_FLD32SET(reg, val,25, 26) 647 #define TMS570_DMA_DMAMPCTRL_REG3ENA BSP_BIT32(24) 650 #define TMS570_DMA_DMAMPCTRL_INT2AB BSP_BIT32(20) 653 #define TMS570_DMA_DMAMPCTRL_INT2ENA BSP_BIT32(19) 656 #define TMS570_DMA_DMAMPCTRL_REG2AP(val) BSP_FLD32(val,17, 18) 657 #define TMS570_DMA_DMAMPCTRL_REG2AP_GET(reg) BSP_FLD32GET(reg,17, 18) 658 #define TMS570_DMA_DMAMPCTRL_REG2AP_SET(reg,val) BSP_FLD32SET(reg, val,17, 18) 661 #define TMS570_DMA_DMAMPCTRL_REG2ENA BSP_BIT32(16) 664 #define TMS570_DMA_DMAMPCTRL_INT1AB BSP_BIT32(12) 667 #define TMS570_DMA_DMAMPCTRL_INT1ENA BSP_BIT32(11) 670 #define TMS570_DMA_DMAMPCTRL_REG1AP(val) BSP_FLD32(val,9, 10) 671 #define TMS570_DMA_DMAMPCTRL_REG1AP_GET(reg) BSP_FLD32GET(reg,9, 10) 672 #define TMS570_DMA_DMAMPCTRL_REG1AP_SET(reg,val) BSP_FLD32SET(reg, val,9, 10) 675 #define TMS570_DMA_DMAMPCTRL_REG1ENA BSP_BIT32(8) 678 #define TMS570_DMA_DMAMPCTRL_INT0AB BSP_BIT32(4) 681 #define TMS570_DMA_DMAMPCTRL_INT0ENA BSP_BIT32(3) 684 #define TMS570_DMA_DMAMPCTRL_REG0AP(val) BSP_FLD32(val,1, 2) 685 #define TMS570_DMA_DMAMPCTRL_REG0AP_GET(reg) BSP_FLD32GET(reg,1, 2) 686 #define TMS570_DMA_DMAMPCTRL_REG0AP_SET(reg,val) BSP_FLD32SET(reg, val,1, 2) 689 #define TMS570_DMA_DMAMPCTRL_REG0ENA BSP_BIT32(0) 694 #define TMS570_DMA_DMAMPST_REG3FT BSP_BIT32(24) 697 #define TMS570_DMA_DMAMPST_REG2FT BSP_BIT32(16) 700 #define TMS570_DMA_DMAMPST_REG1FT BSP_BIT32(8) 703 #define TMS570_DMA_DMAMPST_REG0FT BSP_BIT32(0)
