RTEMS  5.1
reg_crc.h
1 /* The header file is generated by make_header.py from CRC.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_CRC
40 #define LIBBSP_ARM_TMS570_CRC
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t CTRL0; /*CRC Global Control Register*/
46  uint8_t reserved1 [4];
47  uint32_t CTRL1; /*CRC Global Control Register 1*/
48  uint8_t reserved2 [4];
49  uint32_t CTRL2; /*CRC Global Control Register 2*/
50  uint8_t reserved3 [4];
51  uint32_t INTS; /*CRC Interrupt Enable Set Register*/
52  uint8_t reserved4 [4];
53  uint32_t INTR; /*CRC Interrupt Enable Reset Register*/
54  uint8_t reserved5 [4];
55  uint32_t STATUS; /*CRC Interrupt Status Register*/
56  uint8_t reserved6 [4];
57  uint32_t INT_OFFS_REG; /*CRC Interrupt Offset Register*/
58  uint8_t reserved7 [4];
59  uint32_t BUSY; /*CRC Busy Register*/
60  uint8_t reserved8 [4];
61  uint32_t PCOUNT_REG1; /*CRC Channel 1 Pattern Counter Preload Register*/
62  uint32_t SCOUNT_REG1; /*CRC Channel 1 Sector Counter Preload Register*/
63  uint32_t CURSEC_REG1; /*CRC Channel 1 Current Sector Register*/
64  uint32_t WDTOPLD1; /*CRC Channel 1 Watchdog Timeout Preload Register*/
65  uint32_t BCTOPLD1; /*CRC Channel 1 Block Complete Timeout Preload Register*/
66  uint8_t reserved9 [12];
67  uint32_t PSA_SIGREGL1; /*Channel 1 PSA Signature Low Register*/
68  uint32_t PSA_SIGREGH1; /*Channel 1 PSA Signature High Register*/
69  uint32_t REGL1; /*Channel 1 CRC Value Low Register*/
70  uint32_t REGH1; /*Channel 1 CRC Value High Register*/
71  uint32_t PSA_SECSIGREGL1; /*Channel 1 PSA Sector Signature Low Register*/
72  uint32_t PSA_SECSIGREGH1; /*Channel 1 PSA Sector Signature High Register*/
73  uint32_t RAW_DATAREGL1; /*Channel 1 Raw Data Low Register*/
74  uint32_t RAW_DATAREGH1; /*Channel 1 Raw Data High Register*/
75  uint32_t PCOUNT_REG2; /*CRC Channel 2 Pattern Counter Preload Register*/
76  uint32_t SCOUNT_REG2; /*CRC Channel 2 Sector Counter Preload Register*/
77  uint32_t CURSEC_REG2; /*CRC Current Sector Register 2*/
78  uint32_t WDTOPLD2; /*CRC Channel 2 Watchdog Timeout Preload Register A*/
79  uint32_t BCTOPLD2; /*CRC Channel 2 Block Complete Timeout Preload Register B*/
80  uint8_t reserved10 [12];
81  uint32_t PSA_SIGREGL2; /*Channel 2 PSA Signature Low Register*/
82  uint32_t PSA_SIGREGH2; /*Channel 2 PSA Signature High Register*/
83  uint32_t REGL2; /*Channel 2 CRC Value Low Register*/
84  uint32_t REGH2; /*Channel 2 CRC Value High Register*/
85  uint32_t PSA_SECSIGREGL2; /*Channel 2 PSA Sector Signature Low Register*/
86  uint32_t PSA_SECSIGREGH2; /*Channel 2 PSA Sector Signature High Register*/
87  uint32_t RAW_DATAREGL2; /*Channel 2 Raw Data Low Register*/
88  uint32_t RAW_DATAREGH2; /*Channel 2 Raw Data High Register*/
89  uint8_t reserved11 [128];
90  uint32_t BUS_SEL; /*Data Bus Selection Register*/
91 } tms570_crc_t;
92
93
94 /*----------------------TMS570_CRC_CTRL0----------------------*/
95 /* field: CH2_PSA_SWREST - Channel 2 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
96 #define TMS570_CRC_CTRL0_CH2_PSA_SWREST BSP_BIT32(8)
97
98 /* field: CH1_PSA_SWREST - Channel 1 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
99 #define TMS570_CRC_CTRL0_CH1_PSA_SWREST BSP_BIT32(0)
100
101
102 /*----------------------TMS570_CRC_CTRL1----------------------*/
103 /* field: PWDN - Power Down. */
104 #define TMS570_CRC_CTRL1_PWDN BSP_BIT32(0)
105
106
107 /*----------------------TMS570_CRC_CTRL2----------------------*/
108 /* field: CH2_MODE - Channel 2 Mode Selection */
109 #define TMS570_CRC_CTRL2_CH2_MODE(val) BSP_FLD32(val,8, 9)
110 #define TMS570_CRC_CTRL2_CH2_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
111 #define TMS570_CRC_CTRL2_CH2_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
112
113 /* field: CH1_TRACEEN - Channel 1 Data Trace Enable. When set, the channel is put into data trace mode. */
114 #define TMS570_CRC_CTRL2_CH1_TRACEEN BSP_BIT32(4)
115
116 /* field: CH1_MODE - Channel 1 Mode Selection */
117 #define TMS570_CRC_CTRL2_CH1_MODE(val) BSP_FLD32(val,0, 1)
118 #define TMS570_CRC_CTRL2_CH1_MODE_GET(reg) BSP_FLD32GET(reg,0, 1)
119 #define TMS570_CRC_CTRL2_CH1_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
120
121
122 /*----------------------TMS570_CRC_INTS----------------------*/
123 /* field: CH2_TIMEOUTENS - Channel 2 Timeout Interrupt Enable Bit. */
124 #define TMS570_CRC_INTS_CH2_TIMEOUTENS BSP_BIT32(12)
125
126 /* field: CH2_UNDERENS - Channel 2 Underrun Interrupt Enable Bit. */
127 #define TMS570_CRC_INTS_CH2_UNDERENS BSP_BIT32(11)
128
129 /* field: CH2_OVERENS - Channel 2 Overrun Interrupt Enable Bit. */
130 #define TMS570_CRC_INTS_CH2_OVERENS BSP_BIT32(10)
131
132 /* field: CH2_CRCFAILENS - Channel 2 CRC Fail Interrupt Enable Bit. */
133 #define TMS570_CRC_INTS_CH2_CRCFAILENS BSP_BIT32(9)
134
135 /* field: CH2_CCITENS - Channel 2 Compression Complete Interrupt Enable Bit. */
136 #define TMS570_CRC_INTS_CH2_CCITENS BSP_BIT32(8)
137
138 /* field: CH1_TIMEOUTENS - Channel 1 Timeout Interrupt Enable Bit. */
139 #define TMS570_CRC_INTS_CH1_TIMEOUTENS BSP_BIT32(4)
140
141 /* field: CH1_UNDERENS - Channel 1 Underrun Interrupt Enable Bit. */
142 #define TMS570_CRC_INTS_CH1_UNDERENS BSP_BIT32(3)
143
144 /* field: CH1_OVERENS - CH1_OVERENS Channel 1 Overrun Interrupt Enable Bit. */
145 #define TMS570_CRC_INTS_CH1_OVERENS BSP_BIT32(2)
146
147 /* field: CH1_CRCFAILENS - Channel 1 CRC Fail Interrupt Enable Bit. */
148 #define TMS570_CRC_INTS_CH1_CRCFAILENS BSP_BIT32(1)
149
150 /* field: CH1_CCITENS - Channel 1 Compression Complete Interrupt Enable Bit. */
151 #define TMS570_CRC_INTS_CH1_CCITENS BSP_BIT32(0)
152
153
154 /*----------------------TMS570_CRC_INTR----------------------*/
155 /* field: CH2_TIMEOUTENR - Channel 2 Timeout Interrupt Enable Bit. */
156 #define TMS570_CRC_INTR_CH2_TIMEOUTENR BSP_BIT32(12)
157
158 /* field: CH2_UNDERENR - Channel 2 Underrun Interrupt Enable Bit. */
159 #define TMS570_CRC_INTR_CH2_UNDERENR BSP_BIT32(11)
160
161 /* field: CH2_OVERENR - Channel 2 Overrun Interrupt Enable Bit. */
162 #define TMS570_CRC_INTR_CH2_OVERENR BSP_BIT32(10)
163
164 /* field: CH2_CRCFAILENR - Channel 2 CRC Fail Interrupt Enable Bit. */
165 #define TMS570_CRC_INTR_CH2_CRCFAILENR BSP_BIT32(9)
166
167 /* field: CH2_CCITENR - Channel 2 Compression Complete Interrupt Enable Bit. */
168 #define TMS570_CRC_INTR_CH2_CCITENR BSP_BIT32(8)
169
170 /* field: CH1_TIMEOUTENR - Channel 1 Timeout Interrupt Enable Bit. */
171 #define TMS570_CRC_INTR_CH1_TIMEOUTENR BSP_BIT32(4)
172
173 /* field: CH1_UNDERENR - interrupt. Writing a zero has no effect. */
174 #define TMS570_CRC_INTR_CH1_UNDERENR BSP_BIT32(3)
175
176 /* field: CH1_OVERENR - CH1_OVERENR */
177 #define TMS570_CRC_INTR_CH1_OVERENR BSP_BIT32(2)
178
179 /* field: CH1_CRCFAILENR - Channel 1 CRC Fail Interrupt Enable Bit. */
180 #define TMS570_CRC_INTR_CH1_CRCFAILENR BSP_BIT32(1)
181
182 /* field: CH1_CCITENR - Channel 1 Compression Complete Interrupt Enable Bit. */
183 #define TMS570_CRC_INTR_CH1_CCITENR BSP_BIT32(0)
184
185
186 /*---------------------TMS570_CRC_STATUS---------------------*/
187 /* field: CH2_TIMEOUT - Channel 2 CRC Timeout Status Flag. This bit is cleared by writing a '1' to it only. */
188 #define TMS570_CRC_STATUS_CH2_TIMEOUT BSP_BIT32(12)
189
190 /* field: CH2_UNDER - Channel 2 CRC Underrun Status Flag. This bit is cleared by writing a '1' to it only. */
191 #define TMS570_CRC_STATUS_CH2_UNDER BSP_BIT32(11)
192
193 /* field: CH2_OVER - Channel 2 CRC Overrun Status Flag. This bit is cleared by writing a '1' to it only. */
194 #define TMS570_CRC_STATUS_CH2_OVER BSP_BIT32(10)
195
196 /* field: CH2_CRCFAIL - Channel 2 CRC Compare Fail Status Flag. This bit is cleared by writing a '1' to it only. */
197 #define TMS570_CRC_STATUS_CH2_CRCFAIL BSP_BIT32(9)
198
199 /* field: CH2_CCIT - Channel 2 CRC Pattern Compression Complete Status Flag. */
200 #define TMS570_CRC_STATUS_CH2_CCIT BSP_BIT32(8)
201
202 /* field: CH1_TIMEOUT - Writing a zero has no effect. Reading from this bit gives the status (interrupt enable/disable). */
203 #define TMS570_CRC_STATUS_CH1_TIMEOUT BSP_BIT32(4)
204
205 /* field: CH1_UNDER - Channel 1 Underrun Interrupt Enable Bit. */
206 #define TMS570_CRC_STATUS_CH1_UNDER BSP_BIT32(3)
207
208 /* field: CH1_OVER - Channel 1 Overrun Interrupt Enable Bit. Writing a one to this bit disable the overrun interrupt. */
209 #define TMS570_CRC_STATUS_CH1_OVER BSP_BIT32(2)
210
211 /* field: CH1_CRCFAIL - Channel 1 CRC Fail Interrupt Enable Bit. */
212 #define TMS570_CRC_STATUS_CH1_CRCFAIL BSP_BIT32(1)
213
214 /* field: CH1_CCIT - Channel 1 CRC Pattern Compression Complete Status Flag. */
215 #define TMS570_CRC_STATUS_CH1_CCIT BSP_BIT32(0)
216
217
218 /*------------------TMS570_CRC_INT_OFFS_REG------------------*/
219 /* field: OFSTREG - CRC Interrupt Offset. This register indicates the highest priority pending interrupt vector address. */
220 #define TMS570_CRC_INT_OFFS_REG_OFSTREG(val) BSP_FLD32(val,0, 7)
221 #define TMS570_CRC_INT_OFFS_REG_OFSTREG_GET(reg) BSP_FLD32GET(reg,0, 7)
222 #define TMS570_CRC_INT_OFFS_REG_OFSTREG_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
223
224
225 /*----------------------TMS570_CRC_BUSY----------------------*/
226 /* field: CH2_BUSY - CH2_BUSY. */
227 #define TMS570_CRC_BUSY_CH2_BUSY BSP_BIT32(8)
228
229 /* field: CH1_BUSY - CH1_BUSY. */
230 #define TMS570_CRC_BUSY_CH1_BUSY BSP_BIT32(0)
231
232
233 /*-------------------TMS570_CRC_PCOUNT_REG1-------------------*/
234 /* field: CRC_PAT_COUNT1 - Channel 1 Pattern Counter Preload Register. */
235 #define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1(val) BSP_FLD32(val,0, 19)
236 #define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
237 #define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
238
239
240 /*-------------------TMS570_CRC_SCOUNT_REG1-------------------*/
241 /* field: CRC_SEC_COUNT1 - Channel 1 Sector Counter Preload Register. */
242 #define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1(val) BSP_FLD32(val,0, 15)
243 #define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 15)
244 #define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
245
246
247 /*-------------------TMS570_CRC_CURSEC_REG1-------------------*/
248 /* field: CRC_CURSEC1 - Channel 1 Current Sector ID Register. */
249 #define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1(val) BSP_FLD32(val,0, 15)
250 #define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_GET(reg) BSP_FLD32GET(reg,0, 15)
251 #define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
252
253
254 /*--------------------TMS570_CRC_WDTOPLD1--------------------*/
255 /* field: CRC_WDTOPLD1 - CRC_WDTOPLD1 */
256 #define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1(val) BSP_FLD32(val,0, 23)
257 #define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
258 #define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
259
260
261 /*--------------------TMS570_CRC_BCTOPLD1--------------------*/
262 /* field: CRC_BCTOPLD1 - Channel 1 Block Complete Timeout Counter Preload Register. */
263 #define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1(val) BSP_FLD32(val,0, 23)
264 #define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
265 #define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
266
267
268 /*------------------TMS570_CRC_PSA_SIGREGL1------------------*/
269 /* field: PSASIG1 - Channel 1 PSA Signature Low Register. */
270 /* Whole 32 bits */
271
272 /*------------------TMS570_CRC_PSA_SIGREGH1------------------*/
273 /* field: PSASIG1 - register. */
274 /* Whole 32 bits */
275
276 /*----------------------TMS570_CRC_REGL1----------------------*/
277 /* field: CRC1 - Channel 1 CRC Value Low Register. */
278 /* Whole 32 bits */
279
280 /*----------------------TMS570_CRC_REGH1----------------------*/
281 /* field: CRC1 - Channel 1 CRC Value Low Register. */
282 /* Whole 32 bits */
283
284 /*-----------------TMS570_CRC_PSA_SECSIGREGL1-----------------*/
285 /* field: PSASECSIG1 - Channel 1 PSA Sector Signature Low Register. */
286 /* Whole 32 bits */
287
288 /*-----------------TMS570_CRC_PSA_SECSIGREGH1-----------------*/
289 /* field: PSASECSIG1 - Channel 1 PSA Sector Signature High Register. */
290 /* Whole 32 bits */
291
292 /*------------------TMS570_CRC_RAW_DATAREGL1------------------*/
293 /* field: RAW_DATA1 - hannel 1 Raw Data Low Register.This register contains bits 31:0 of the uncompressed raw data. */
294 /* Whole 32 bits */
295
296 /*------------------TMS570_CRC_RAW_DATAREGH1------------------*/
297 /* field: RAW_DATA1 - Channel 1 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data. */
298 /* Whole 32 bits */
299
300 /*-------------------TMS570_CRC_PCOUNT_REG2-------------------*/
301 /* field: CRC_PAT_COUNT2 - Channel 2 Pattern Counter Preload Register. */
302 #define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2(val) BSP_FLD32(val,0, 19)
303 #define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 19)
304 #define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
305
306
307 /*-------------------TMS570_CRC_SCOUNT_REG2-------------------*/
308 /* field: CRC_SEC_COUNT2 - Channel 2 Sector Counter Preload Register. */
309 #define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2(val) BSP_FLD32(val,0, 15)
310 #define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 15)
311 #define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
312
313
314 /*-------------------TMS570_CRC_CURSEC_REG2-------------------*/
315 /* field: CRC_CURSEC2 - Channel 2 Current Sector ID Register. */
316 #define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2(val) BSP_FLD32(val,0, 15)
317 #define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_GET(reg) BSP_FLD32GET(reg,0, 15)
318 #define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
319
320
321 /*--------------------TMS570_CRC_WDTOPLD2--------------------*/
322 /* field: CRC_WDTOPLD2 - Channel 2 Watchdog Timeout Counter Preload Register. */
323 #define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2(val) BSP_FLD32(val,0, 23)
324 #define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
325 #define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
326
327
328 /*--------------------TMS570_CRC_BCTOPLD2--------------------*/
329 /* field: CRC_BCTOPLD2 - Channel 2 Block Complete Timeout Counter Preload Register. */
330 #define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2(val) BSP_FLD32(val,0, 23)
331 #define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
332 #define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
333
334
335 /*------------------TMS570_CRC_PSA_SIGREGL2------------------*/
336 /* field: PSASIG2 - Channel 2 PSA Signature Low Register. */
337 /* Whole 32 bits */
338
339 /*------------------TMS570_CRC_PSA_SIGREGH2------------------*/
340 /* field: PSASIG2 - Channel 2 PSA Signature High Register. */
341 /* Whole 32 bits */
342
343 /*----------------------TMS570_CRC_REGL2----------------------*/
344 /* field: CRC2 - stored at CRC2[31:0] register. */
345 /* Whole 32 bits */
346
347 /*----------------------TMS570_CRC_REGH2----------------------*/
348 /* field: CRC2 - Channel 2 CRC Value High Register. */
349 /* Whole 32 bits */
350
351 /*-----------------TMS570_CRC_PSA_SECSIGREGL2-----------------*/
352 /* field: PSASECSIG2 - Channel 2 PSA Sector Signature Low Register. */
353 /* Whole 32 bits */
354
355 /*-----------------TMS570_CRC_PSA_SECSIGREGH2-----------------*/
356 /* field: PSASECSIG2 - Channel 2 PSA Sector Signature High Register. */
357 /* Whole 32 bits */
358
359 /*------------------TMS570_CRC_RAW_DATAREGL2------------------*/
360 /* field: RAW_DATA2 - Channel 2 Raw Data Low Register. This register contains bits 31:0 of the uncompressed raw data.. */
361 /* Whole 32 bits */
362
363 /*------------------TMS570_CRC_RAW_DATAREGH2------------------*/
364 /* field: RAW_DATA2 - Channel 2 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data.. */
365 /* Whole 32 bits */
366
367 /*---------------------TMS570_CRC_BUS_SEL---------------------*/
368 /* field: MEn - Enable/disables the tracing of Peripheral Bus Master */
369 #define TMS570_CRC_BUS_SEL_MEn BSP_BIT32(2)
370
371 /* field: DTCMEn - Enable/disables the tracing of data TCM */
372 #define TMS570_CRC_BUS_SEL_DTCMEn BSP_BIT32(1)
373
374 /* field: ITCMEn - Enable/disables the tracing of instruction TCM */
375 #define TMS570_CRC_BUS_SEL_ITCMEn BSP_BIT32(0)
376
377
378
379 #endif /* LIBBSP_ARM_TMS570_CRC */
Utility macros.
Definition: reg_crc.h:44
